[U-Boot] [PATCH v3 1/2] APM821xx: Add CPU support
APM821XX is a new line of SoCs which are derivatives of PPC44X family of processors. This patch adds support of CPU, cache, tlb, 32k ocm, bootstraps, PLB and AHB bus.
Signed-off-by: Tirumala R Marri tmarri@apm.com --- V2: * Removed Defines added to 405ex. V3: * Change APM82XXX to APM821XX * Modify the way cpu id is printed. * Correct inadvertent change. * Sort define list. * Remove comment for get_sys_info(). * Define a symbolic constat ISRAM1_OCM_SIZE. * Create apm821xx.h instead of using ppc440.h * Correct multiline comment. --- arch/powerpc/cpu/ppc4xx/cpu.c | 36 ++- arch/powerpc/cpu/ppc4xx/cpu_init.c | 5 +- arch/powerpc/cpu/ppc4xx/speed.c | 76 +++++- arch/powerpc/cpu/ppc4xx/start.S | 11 +- arch/powerpc/cpu/ppc4xx/tlb.c | 2 + arch/powerpc/include/asm/ppc4xx-ebc.h | 4 + arch/powerpc/include/asm/ppc4xx-isram.h | 14 +- arch/powerpc/include/asm/ppc4xx-sdram.h | 12 +- arch/powerpc/include/asm/ppc4xx-uic.h | 5 +- arch/powerpc/include/asm/processor.h | 1 + include/apm821xx.h | 493 +++++++++++++++++++++++++++++++ include/ppc4xx.h | 11 +- 12 files changed, 645 insertions(+), 25 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/cpu.c b/arch/powerpc/cpu/ppc4xx/cpu.c index 851065c..2c12907 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu.c +++ b/arch/powerpc/cpu/ppc4xx/cpu.c @@ -80,7 +80,8 @@ static int pci_async_enabled(void) #endif /* CONFIG_PCI */
#if defined(CONFIG_PCI) && !defined(CONFIG_IOP480) && \ - !defined(CONFIG_405) && !defined(CONFIG_405EX) + !defined(CONFIG_405) && !defined(CONFIG_405EX) && \ + !defined(CONFIG_APM821XX) int pci_arbiter_enabled(void) { #if defined(CONFIG_405GP) @@ -250,6 +251,21 @@ static char *bootstrap_str[] = { }; static char bootstrap_char[] = { 'A', 'B', 'C', 'D', 'E', 'G', 'F', 'H' }; #endif +#if defined(CONFIG_APM821XX) +#define SDR0_PINSTP_SHIFT 29 +static char *bootstrap_str[] = { + "RESERVED", + "RESERVED", + "RESERVED", + "NAND (8 bits)", + "NOR (8 bits)", + "NOR (8 bits) w/PLL Bypassed", + "I2C (Addr 0x54)", + "I2C (Addr 0x52)", +}; +static char bootstrap_char[] = { 'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H' }; +#endif +
#if defined(SDR0_PINSTP_SHIFT) static int bootstrap_option(void) @@ -285,7 +301,7 @@ int checkcpu (void) uint pvr = get_pvr(); ulong clock = gd->cpu_clk; char buf[32]; -#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || defined(CONFIG_APM821XX) u32 reg; #endif
@@ -301,7 +317,9 @@ int checkcpu (void) puts("CPU: ");
get_sys_info(&sys_info); - +#if defined(CONFIG_APM821XX) + puts("APM PowerPC APM821XX"); +#else #if defined(CONFIG_XILINX_440) puts("IBM PowerPC 4"); #else @@ -320,6 +338,7 @@ int checkcpu (void) puts("40"); #endif #endif +#endif
switch (pvr) { case PVR_405GP_RB: @@ -598,7 +617,18 @@ int checkcpu (void) puts("GX Rev. A"); strcpy(addstr, "No Security support"); break; +#if defined(CONFIG_APM821XX) + case PVR_APM821XX_RA: + mfsdr(SDR0_ECID3, reg); + if (reg & 0x00200000) + puts("181 Rev. A");
+ if (reg & 0x00100000) + strcpy(addstr, "No Security support"); + else + strcpy(addstr, "Security support"); + break; +#endif case PVR_VIRTEX5: puts("x5 VIRTEX5"); break; diff --git a/arch/powerpc/cpu/ppc4xx/cpu_init.c b/arch/powerpc/cpu/ppc4xx/cpu_init.c index b31bd0b..009a35a 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu_init.c +++ b/arch/powerpc/cpu/ppc4xx/cpu_init.c @@ -237,7 +237,8 @@ cpu_init_f (void)
reconfigure_pll(CONFIG_SYS_PLL_RECONFIG);
-#if (defined(CONFIG_405EP) || defined (CONFIG_405EX)) && !defined(CONFIG_SYS_4xx_GPIO_TABLE) +#if !defined(CONFIG_APM821XX) && (defined(CONFIG_405EP) || \ + defined(CONFIG_405EX)) && !defined(CONFIG_SYS_4xx_GPIO_TABLE) /* * GPIO0 setup (select GPIO or alternate function) */ @@ -393,7 +394,7 @@ cpu_init_f (void) #if defined(CONFIG_405EX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) /* * Set PLB4 arbiter (Segment 0 and 1) to 4 deep pipeline read */ diff --git a/arch/powerpc/cpu/ppc4xx/speed.c b/arch/powerpc/cpu/ppc4xx/speed.c index 906face..9538736 100644 --- a/arch/powerpc/cpu/ppc4xx/speed.c +++ b/arch/powerpc/cpu/ppc4xx/speed.c @@ -189,7 +189,7 @@ ulong get_PCI_freq (void) #elif defined(CONFIG_440)
#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) static u8 pll_fwdv_multi_bits[] = { /* values for: 1 - 16 */ 0x00, 0x01, 0x0f, 0x04, 0x09, 0x0a, 0x0d, 0x0e, 0x03, 0x0c, @@ -250,6 +250,79 @@ u32 get_cpr0_fbdv(unsigned long cpr_reg_fbdv) return 0; }
+#if defined(CONFIG_APM821XX) + +void get_sys_info(sys_info_t *sysInfo) +{ + unsigned long plld; + unsigned long temp; + unsigned long mul; + unsigned long cpudv; + unsigned long plb2dv; + unsigned long ddr2dv; + + /* Calculate Forward divisor A and Feeback divisor */ + mfcpr(CPR0_PLLD, plld); + + temp = CPR0_PLLD_FWDVA(plld); + sysInfo->pllFwdDivA = get_cpr0_fwdv(temp); + + temp = CPR0_PLLD_FDV(plld); + sysInfo->pllFbkDiv = get_cpr0_fbdv(temp); + + /* Calculate OPB clock divisor */ + mfcpr(CPR0_OPBD, temp); + temp = CPR0_OPBD_OPBDV(temp); + sysInfo->pllOpbDiv = temp ? temp : 4; + + /* Calculate Peripheral clock divisor */ + mfcpr(CPR0_PERD, temp); + temp = CPR0_PERD_PERDV(temp); + sysInfo->pllExtBusDiv = temp ? temp : 4; + + /* Calculate CPU clock divisor */ + mfcpr(CPR0_CPUD, temp); + temp = CPR0_CPUD_CPUDV(temp); + cpudv = temp ? temp : 8; + + /* Calculate PLB2 clock divisor */ + mfcpr(CPR0_PLB2D, temp); + temp = CPR0_PLB2D_PLB2DV(temp); + plb2dv = temp ? temp : 4; + + /* Calculate DDR2 clock divisor */ + mfcpr(CPR0_DDR2D, temp); + temp = CPR0_DDR2D_DDR2DV(temp); + ddr2dv = temp ? temp : 4; + + /* Calculate 'M' based on feedback source */ + mfcpr(CPR0_PLLC, temp); + temp = CPR0_PLLC_SEL(temp); + if (temp == 0) { + /* PLL internal feedback */ + mul = sysInfo->pllFbkDiv; + } else { + /* PLL PerClk feedback */ + mul = sysInfo->pllFwdDivA * sysInfo->pllFbkDiv * cpudv + * plb2dv * 2 * sysInfo->pllOpbDiv * + sysInfo->pllExtBusDiv; + } + + /* Now calculate the individual clocks */ + sysInfo->freqVCOMhz = (mul * CONFIG_SYS_CLK_FREQ) + (mul >> 1); + sysInfo->freqProcessor = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv; + sysInfo->freqPLB = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv / plb2dv / 2; + sysInfo->freqOPB = sysInfo->freqPLB / sysInfo->pllOpbDiv; + sysInfo->freqEBC = sysInfo->freqOPB / sysInfo->pllExtBusDiv; + sysInfo->freqDDR = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv / ddr2dv / 2; + sysInfo->freqUART = sysInfo->freqPLB; +} + +#else + /* * AMCC_TODO: verify this routine against latest EAS, cause stuff changed * with latest EAS @@ -307,6 +380,7 @@ void get_sys_info (sys_info_t * sysInfo)
return; } +#endif
#elif defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) diff --git a/arch/powerpc/cpu/ppc4xx/start.S b/arch/powerpc/cpu/ppc4xx/start.S index 4bad32f..74277fe 100644 --- a/arch/powerpc/cpu/ppc4xx/start.S +++ b/arch/powerpc/cpu/ppc4xx/start.S @@ -700,7 +700,8 @@ _start: defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460SX) mtdcr L2_CACHE_CFG,r0 /* Ensure L2 Cache is off */ -#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) lis r1, 0x0000 ori r1,r1,0x0008 /* Set L2_CACHE_CFG[RDBW]=1 */ mtdcr L2_CACHE_CFG,r1 @@ -728,7 +729,8 @@ _start: lis r1, 0x8003 ori r1,r1, 0x0980 /* fourth 64k */ mtdcr ISRAM0_SB3CR,r1 -#elif defined(CONFIG_440SPE) || defined(CONFIG_460EX) || defined(CONFIG_460GT) +#elif defined(CONFIG_440SPE) || defined(CONFIG_460EX) || \ + defined(CONFIG_460GT) || defined(CONFIG_APM821XX) lis r1,0x0000 /* BAS = X_0000_0000 */ ori r1,r1,0x0984 /* first 64k */ mtdcr ISRAM0_SB0CR,r1 @@ -741,7 +743,8 @@ _start: lis r1, 0x0003 ori r1,r1, 0x0984 /* fourth 64k */ mtdcr ISRAM0_SB3CR,r1 -#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) lis r2,0x7fff ori r2,r2,0xffff mfdcr r1,ISRAM1_DPC @@ -752,7 +755,7 @@ _start: mtdcr ISRAM1_PMEG,r1
lis r1,0x0004 /* BAS = 4_0004_0000 */ - ori r1,r1,0x0984 /* 64k */ + ori r1,r1,ISRAM1_SIZE /* ocm size */ mtdcr ISRAM1_SB0CR,r1 #endif #elif defined(CONFIG_460SX) diff --git a/arch/powerpc/cpu/ppc4xx/tlb.c b/arch/powerpc/cpu/ppc4xx/tlb.c index 24a9a9c..9a8964a 100644 --- a/arch/powerpc/cpu/ppc4xx/tlb.c +++ b/arch/powerpc/cpu/ppc4xx/tlb.c @@ -25,7 +25,9 @@
#if defined(CONFIG_440)
+#if !defined(CONFIG_APM821XX) #include <ppc440.h> +#endif #include <asm/cache.h> #include <asm/io.h> #include <asm/mmu.h> diff --git a/arch/powerpc/include/asm/ppc4xx-ebc.h b/arch/powerpc/include/asm/ppc4xx-ebc.h index 9c17e46..2c79118 100644 --- a/arch/powerpc/include/asm/ppc4xx-ebc.h +++ b/arch/powerpc/include/asm/ppc4xx-ebc.h @@ -73,6 +73,10 @@ #define EBC_NUM_BANKS 3 #endif
+#if defined(CONFIG_APM821XX) +#define EBC_NUM_BANKS 3 +#endif + /* Bank Configuration Register */ #define EBC_BXCR(n) (n) #define EBC_BXCR_BANK_SIZE(n) (0x100000 << (((n) & EBC_BXCR_BS_MASK) >> 17)) diff --git a/arch/powerpc/include/asm/ppc4xx-isram.h b/arch/powerpc/include/asm/ppc4xx-isram.h index d6d17ac..32e1297 100644 --- a/arch/powerpc/include/asm/ppc4xx-isram.h +++ b/arch/powerpc/include/asm/ppc4xx-isram.h @@ -25,7 +25,8 @@ /* * Internal SRAM */ -#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) +#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_APM821XX) #define ISRAM0_DCR_BASE 0x380 #else #define ISRAM0_DCR_BASE 0x020 @@ -42,7 +43,8 @@ #define ISRAM0_REVID (ISRAM0_DCR_BASE+0x09) /* SRAM bus revision id reg */ #define ISRAM0_DPC (ISRAM0_DCR_BASE+0x0a) /* SRAM data parity check reg */
-#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) #define ISRAM1_DCR_BASE 0x0B0 #define ISRAM1_SB0CR (ISRAM1_DCR_BASE+0x00) /* SRAM1 bank config 0*/ #define ISRAM1_BEAR (ISRAM1_DCR_BASE+0x04) /* SRAM1 bus error addr reg */ @@ -54,13 +56,19 @@ #define ISRAM1_DPC (ISRAM1_DCR_BASE+0x0a) /* SRAM1 data parity check reg */ #endif /* CONFIG_460EX || CONFIG_460GT */
+#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define ISRAM1_SIZE 0x0984 /* OCM size 64k */ +#elif defined(CONFIG_APM821XX) +#define ISRAM1_SIZE 0x0784 /* OCM size 32k */ +#endif + /* * L2 Cache */ #if defined (CONFIG_440GX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) #define L2_CACHE_BASE 0x030 #define L2_CACHE_CFG (L2_CACHE_BASE+0x00) /* L2 Cache Config */ #define L2_CACHE_CMD (L2_CACHE_BASE+0x01) /* L2 Cache Command */ diff --git a/arch/powerpc/include/asm/ppc4xx-sdram.h b/arch/powerpc/include/asm/ppc4xx-sdram.h index 4ec1ef8..8575c4d 100644 --- a/arch/powerpc/include/asm/ppc4xx-sdram.h +++ b/arch/powerpc/include/asm/ppc4xx-sdram.h @@ -292,7 +292,7 @@ */ #if defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) #define SDRAM_RXBAS_SDBA_MASK 0xFFE00000 /* Base address */ #define SDRAM_RXBAS_SDBA_ENCODE(n) ((u32)(((phys_size_t)(n) >> 2) & 0xFFE00000)) #define SDRAM_RXBAS_SDBA_DECODE(n) ((((phys_size_t)(n)) & 0xFFE00000) << 2) @@ -365,7 +365,7 @@ /* * Memory controller registers */ -#ifdef CONFIG_405EX +#if defined(CONFIG_405EX) || defined(CONFIG_APM821XX) #define SDRAM_BESR 0x00 /* PLB bus error status (read/clear) */ #define SDRAM_BESRT 0x01 /* PLB bus error status (test/set) */ #define SDRAM_BEARL 0x02 /* PLB bus error address low */ @@ -375,9 +375,9 @@ #define SDRAM_PLBOPT 0x08 /* PLB slave options */ #define SDRAM_PUABA 0x09 /* PLB upper address base */ #define SDRAM_MCSTAT 0x1F /* memory controller status */ -#else /* CONFIG_405EX */ +#else /* CONFIG_405EX || CONFIG_APM821XX */ #define SDRAM_MCSTAT 0x14 /* memory controller status */ -#endif /* CONFIG_405EX */ +#endif /* CONFIG_405EX || CONFIG_APM821XX */ #define SDRAM_MCOPT1 0x20 /* memory controller options 1 */ #define SDRAM_MCOPT2 0x21 /* memory controller options 2 */ #define SDRAM_MODT0 0x22 /* on die termination for bank 0 */ @@ -423,12 +423,12 @@ #define SDRAM_MEMODE 0x89 /* memory extended mode */ #define SDRAM_ECCES 0x98 /* ECC error status */ #define SDRAM_CID 0xA4 /* core ID */ -#ifndef CONFIG_405EX +#if !defined(CONFIG_405EX) && !defined(CONFIG_APM821XX) #define SDRAM_RID 0xA8 /* revision ID */ #endif #define SDRAM_FCSR 0xB0 /* feedback calibration status */ #define SDRAM_RTSR 0xB1 /* run time status tracking */ -#ifdef CONFIG_405EX +#if defined(CONFIG_405EX) || defined(CONFIG_APM821XX) #define SDRAM_RID 0xF8 /* revision ID */ #endif
diff --git a/arch/powerpc/include/asm/ppc4xx-uic.h b/arch/powerpc/include/asm/ppc4xx-uic.h index 782d045..3714a0a 100644 --- a/arch/powerpc/include/asm/ppc4xx-uic.h +++ b/arch/powerpc/include/asm/ppc4xx-uic.h @@ -31,7 +31,7 @@ */ #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) #define UIC_MAX 4 #elif defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_405EX) @@ -252,7 +252,8 @@ #define VECNUM_ETH0 (32 + 28) #endif /* CONFIG_440SPE */
-#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) /* UIC 0 */ #define VECNUM_UIC2NCI 10 #define VECNUM_UIC2CI 11 diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 84a1e2e..9cafe85 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -916,6 +916,7 @@ #define PVR_460SX_RA_V1 0x13541801 /* 460SX rev A Variant 1 Security disabled */ #define PVR_460GX_RA 0x13541802 /* 460GX rev A */ #define PVR_460GX_RA_V1 0x13541803 /* 460GX rev A Variant 1 Security disabled */ +#define PVR_APM821XX_RA 0x12C41C80 /* APM821XX rev A */ #define PVR_601 0x00010000 #define PVR_602 0x00050000 #define PVR_603 0x00030000 diff --git a/include/apm821xx.h b/include/apm821xx.h new file mode 100644 index 0000000..fdf7fb7 --- /dev/null +++ b/include/apm821xx.h @@ -0,0 +1,493 @@ +/*----------------------------------------------------------------------------+ +| This source code is dual-licensed. You may use it under the terms of the +| GNU General Public License version 2, or under the license below. +| +| This source code has been made available to you by IBM on an AS-IS +| basis. Anyone receiving this source is licensed under IBM +| copyrights to use it in any way he or she deems fit, including +| copying it, modifying it, compiling it, and redistributing it either +| with or without modifications. No license under IBM patents or +| patent applications is to be implied by the copyright license. +| +| Any user of this software should understand that IBM cannot provide +| technical support for this software and will not be responsible for +| any consequences resulting from the use of this software. +| +| Any person who transfers this source code or any derivative work +| must include the IBM copyright notice, this paragraph, and the +| preceding two paragraphs in the transferred software. +| +| COPYRIGHT I B M CORPORATION 1999 +| LICENSED MATERIAL - PROGRAM PROPERTY OF I B M ++----------------------------------------------------------------------------*/ + +/* + * (C) Copyright 2006 + * Sylvie Gohl, AMCC/IBM, gohl.sylvie@fr.ibm.com + * Jacqueline Pira-Ferriol, AMCC/IBM, jpira-ferriol@fr.ibm.com + * Thierry Roman, AMCC/IBM, thierry_roman@fr.ibm.com + * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com + * Robert Snyder, AMCC/IBM, rob.snyder@fr.ibm.com + * Tirumala Marri, APM/IBM, tmarri@apm.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __APM821XX_H__ +#define __APM821XX_H__ + +#define CONFIG_SYS_DCACHE_SIZE (32 << 10) /* For AMCC 440 CPUs */ + +/**************************************************************************** + * DCRs & Related + ****************************************************************************/ + +/* + * Clocking Controller + */ +/* values for clkcfga register - indirect addressing of these regs */ +#define CPR0_CLKUPD 0x0020 +#define CPR0_PLLC 0x0040 +#define CPR0_PLLC_SEL(pllc) (((pllc) & 0x01000000) >> 24) +#define CPR0_PLLD 0x0060 +#define CPR0_PLLD_FDV(plld) (((plld) & 0xff000000) >> 24) +#define CPR0_PLLD_FWDVA(plld) (((plld) & 0x000f0000) >> 16) +#define CPR0_CPUD 0x0080 +#define CPR0_CPUD_CPUDV(cpud) (((cpud) & 0x07000000) >> 24) +#define CPR0_PLB2D 0x00a0 +#define CPR0_PLB2D_PLB2DV(plb2d) (((plb2d) & 0x06000000) >> 25) +#define CPR0_OPBD 0x00c0 +#define CPR0_OPBD_OPBDV(opbd) (((opbd) & 0x03000000) >> 24) +#define CPR0_PERD 0x00e0 +#define CPR0_PERD_PERDV(perd) (((perd) & 0x03000000) >> 24) +#define CPR0_DDR2D 0x0100 +#define CPR0_DDR2D_DDR2DV(ddr2d) (((ddr2d) & 0x06000000) >> 25) +#define CLK_ICFG 0x0140 + +#define BOOT_STRAP_OPTION_A 0x00000000 +#define BOOT_STRAP_OPTION_B 0x00000001 +#define BOOT_STRAP_OPTION_D 0x00000003 +#define BOOT_STRAP_OPTION_E 0x00000004 + +#define SDR0_SDSTP0 0x0020 /* */ +#define SDR0_SDSTP1 0x0021 /* */ +#define SDR0_PINSTP 0x0040 +#define SDR0_SDCS0 0x0060 +#define SDR0_EBC 0x0100 +#define SDR0_UART0 0x0120 /* UART0 Config */ +#define SDR0_UART1 0x0121 /* UART1 Config */ +#define SDR0_UART2 0x0122 /* UART2 Config */ +#define SDR0_UART3 0x0123 /* UART3 Config */ +#define SDR0_CP440 0x0180 +#define SDR0_XCR 0x01c0 +#define SDR0_XPLLC 0x01c1 +#define SDR0_XPLLD 0x01c2 +#define SDR0_SRST 0x0200 +#define SD0_AMP0 0x0240 /* Override PLB4 prio for up to 8 masters */ +#define SD0_AMP1 0x0241 /* Override PLB3 prio for up to 8 masters */ +#define SDR0_PCI0 0x0300 +#define SDR0_USB0 0x0320 +#define SDR0_CUST0 0x4000 +#define SDR0_CUST1 0x4002 +#define SDR0_PFC0 0x4100 /* Pin Function 0 */ +#define SDR0_PFC1 0x4101 /* Pin Function 1 */ +#define SDR0_MFR 0x4300 /* SDR0_MFR reg */ + +/* + *Core Configuration/MMU configuration for 440 (CCR1 for 440x5 only). + */ +#define CCR0_PRE 0x40000000 +#define CCR0_CRPE 0x08000000 +#define CCR0_DSTG 0x00200000 +#define CCR0_DAPUIB 0x00100000 +#define CCR0_DTB 0x00008000 +#define CCR0_GICBT 0x00004000 +#define CCR0_GDCBT 0x00002000 +#define CCR0_FLSTA 0x00000100 +#define CCR0_ICSLC_MASK 0x0000000C +#define CCR0_ICSLT_MASK 0x00000003 +#define CCR1_TCS_MASK 0x00000080 +#define CCR1_TCS_INTCLK 0x00000000 +#define CCR1_TCS_EXTCLK 0x00000080 +#define MMUCR_SWOA 0x01000000 +#define MMUCR_U1TE 0x00400000 +#define MMUCR_U2SWOAE 0x00200000 +#define MMUCR_DULXE 0x00800000 +#define MMUCR_IULXE 0x00400000 +#define MMUCR_STS 0x00100000 +#define MMUCR_STID_MASK 0x000000FF + +/* + * External Bus Controller + */ +/* values for EBC0_CFGADDR register - indirect addressing of these regs */ +#define PB0CR 0x00 /* periph bank 0 config reg */ +#define PB1CR 0x01 /* periph bank 1 config reg */ +#define PB2CR 0x02 /* periph bank 2 config reg */ +#define PB3CR 0x03 /* periph bank 3 config reg */ +#define PB4CR 0x04 /* periph bank 4 config reg */ +#define PB5CR 0x05 /* periph bank 5 config reg */ +#define PB6CR 0x06 /* periph bank 6 config reg */ +#define PB7CR 0x07 /* periph bank 7 config reg */ +#define PB0AP 0x10 /* periph bank 0 access parameters */ +#define PB1AP 0x11 /* periph bank 1 access parameters */ +#define PB2AP 0x12 /* periph bank 2 access parameters */ +#define PB3AP 0x13 /* periph bank 3 access parameters */ +#define PB4AP 0x14 /* periph bank 4 access parameters */ +#define PB5AP 0x15 /* periph bank 5 access parameters */ +#define PB6AP 0x16 /* periph bank 6 access parameters */ +#define PB7AP 0x17 /* periph bank 7 access parameters */ +#define PBEAR 0x20 /* periph bus error addr reg */ +#define PBESR 0x21 /* periph bus error status reg */ +#define EBC0_CFG 0x23 /* external bus configuration reg */ + +/* + * On-Chip Buses + */ +/* + * Clocking, Power Management and Chip Control + */ +#define CNTRL_DCR_BASE 0x0b0 + +#define CPC0_SYS0 (CNTRL_DCR_BASE+0x30) /* System config reg 0 */ +#define CPC0_SYS1 (CNTRL_DCR_BASE+0x31) /* System config reg 1 */ + +#define CPC0_STRP0 (CNTRL_DCR_BASE+0x34) /* Power-on config reg 0(RO) */ +#define CPC0_STRP1 (CNTRL_DCR_BASE+0x35) /* Power-on config reg 1(RO) */ + +#define CPC0_GPIO (CNTRL_DCR_BASE+0x38) /* GPIO config reg */ + +#define CPC0_CR0 (CNTRL_DCR_BASE+0x3b) /* Control 0 reg */ +#define CPC0_CR1 (CNTRL_DCR_BASE+0x3a) /* Control 1 reg */ + +/* + * DMA + */ +#define DMA_DCR_BASE 0x100 +#define DMACR0 (DMA_DCR_BASE+0x00) /* DMA channel control reg 0 */ +#define DMACT0 (DMA_DCR_BASE+0x01) /* DMA count register 0 */ +#define DMACR1 (DMA_DCR_BASE+0x08) /* DMA channel control reg 1 */ +#define DMACT1 (DMA_DCR_BASE+0x09) /* DMA count register 1 */ +#define DMACR2 (DMA_DCR_BASE+0x10) /* DMA channel control reg 2 */ +#define DMACT2 (DMA_DCR_BASE+0x11) /* DMA count register 2 */ +#define DMACR3 (DMA_DCR_BASE+0x18) /* DMA channel control reg 2 */ +#define DMASR (DMA_DCR_BASE+0x20) /* DMA status register */ +#define DMASGC (DMA_DCR_BASE+0x23) /* DMA scatter/gather cmd register */ + +/* + * Memory Access Layer + */ +#define MAL_DCR_BASE 0x180 +#define MAL0_CFG (MAL_DCR_BASE + 0x00) /* MAL Config reg */ +#define MAL0_ESR (MAL_DCR_BASE + 0x01) /* Error Status (Read/Clear)*/ +#define MAL0_IER (MAL_DCR_BASE + 0x02) /* Interrupt enable */ +#define MAL0_TXCASR (MAL_DCR_BASE + 0x04) /* TX Channel active (set) */ +#define MAL0_TXCARR (MAL_DCR_BASE + 0x05) /* TX Channel active (rst) */ +#define MAL0_TXEOBISR (MAL_DCR_BASE + 0x06) /* TX End of buf int status */ +#define MAL0_TXDEIR (MAL_DCR_BASE + 0x07) /* TX Descr. Error Int */ +#define MAL0_TXBADDR (MAL_DCR_BASE + 0x09) /* TX descriptor base addr */ +#define MAL0_RXCASR (MAL_DCR_BASE + 0x10) /* RX Channel active (set) */ +#define MAL0_RXCARR (MAL_DCR_BASE + 0x11) /* RX Channel actve (reset) */ +#define MAL0_RXEOBISR (MAL_DCR_BASE + 0x12) /* RX End of buf int status */ +#define MAL0_RXDEIR (MAL_DCR_BASE + 0x13) /* RX Descr. Error Int */ +#define MAL0_RXBADDR (MAL_DCR_BASE + 0x15) /* RX descriptor base addr */ +#define MAL0_TXCTP0R (MAL_DCR_BASE + 0x20) /* TX 0 Channel table pointer */ +#define MAL0_TXCTP1R (MAL_DCR_BASE + 0x21) /* TX 1 Channel table pointer */ +#define MAL0_TXCTP2R (MAL_DCR_BASE + 0x22) /* TX 2 Channel table pointer */ +#define MAL0_TXCTP3R (MAL_DCR_BASE + 0x23) /* TX 3 Channel table pointer */ +#define MAL0_RXCTP0R (MAL_DCR_BASE + 0x40) /* RX 0 Channel table pointer */ +#define MAL0_RXCTP1R (MAL_DCR_BASE + 0x41) /* RX 1 Channel table pointer */ +#define MAL0_RCBS0 (MAL_DCR_BASE + 0x60) /* RX 0 Channel buffer size */ +#define MAL0_RCBS1 (MAL_DCR_BASE + 0x61) /* RX 1 Channel buffer size */ +/* + * SDR0 Bit Settings + */ + +#define SDR0_DDR0 0x00E1 +#define SDR0_DDR0_DDRM_ENCODE(n) ((((u32)(n)) & 0x03) << 29) +#define SDR0_DDR0_DDRM_DECODE(n) ((((u32)(n)) >> 29) & 0x03) +#define SDR0_DDR0_TUNE_ENCODE(n) ((((u32)(n)) & 0x2FF) << 0) +#define SDR0_DDR0_TUNE_DECODE(n) ((((u32)(n)) >> 0) & 0x2FF) + +#define SDR_SDSTP1_RL_DECODE(x) (((x) & 0x000C0000) >> 18) +#define SDR_SDSTP1_RL_EBC 0x0 +#define SDR_SDSTP1_RL_NDFC 0x2 + +/* ECID */ +#define SDR0_ECID0 0x0080 +#define SDR0_ECID1 0x0081 +#define SDR0_ECID2 0x0082 +#define SDR0_ECID3 0x0083 + +/* AHB config. */ +#define AHB_TOP 0xA4 +#define AHB_BOT 0xA5 +#define SDR0_AHB_CFG 0x370 + +/* DDR SDRAM Controller clock (CPR register)*/ +#define SDR0_DDRCE 0x00E0 /* SDR register */ +#define CPR0_DDR2D 0x0100 /* CPR register */ +#define CPR0_DDR2D_DDR2DV_ENCODE(n) ((((u32)(n)) & 0x03) << 25) +#define CPR0_DDR2D_DDR2DV_DECODE(n) ((((u32)(n)) >> 25) & 0x03) + +#define SDR0_SDCS_SDD (0x80000000 >> 31) + +#define SDR0_SRST0 SDR0_SRST /* for compatability reasons */ +#define SDR0_SRST0_BGO 0x80000000 /* PLB to OPB bridge */ +#define SDR0_SRST0_PLB4 0x40000000 /* PLB4 arbiter */ +#define SDR0_SRST0_EBC 0x20000000 /* External bus controller */ +#define SDR0_SRST0_OPB 0x10000000 /* OPB arbiter */ +#define SDR0_SRST0_UART0 0x08000000 /* Universal async receiver/ + transmitter 0 */ +#define SDR0_SRST0_UART1 0x04000000 /* Universal async receiver/ + transmitter 1 */ +#define SDR0_SRST0_IIC0 0x02000000 /* Inter intgrated circuit 0 */ +#define SDR0_SRST0_IIC1 0x01000000 /* Inter intgrated circuit 1 */ +#define SDR0_SRST0_GPIO0 0x00800000 /* General purpose I/O 0 */ +#define SDR0_SRST0_GPT 0x00400000 /* General purpose timer */ +#define SDR0_SRST0_DMC 0x00200000 /* DDR SDRAM mem controller */ +#define SDR0_SRST0_PCI 0x00100000 /* PCI */ +#define SDR0_SRST0_CPM0 0x00020000 /* Clock and power mgmt */ +#define SDR0_SRST0_IMU 0x00010000 /* I2O DMA */ +#define SDR0_SRST0_UIC0 0x00008000 /* Universal intr ctrller 0 */ +#define SDR0_SRST0_UIC1 0x00004000 /* Universal intr ctrller 1 */ +#define SDR0_SRST0_SRAM 0x00002000 /* Universal intr ctrller 0 */ +#define SDR0_SRST0_UIC2 0x00001000 /* Universal intr ctrller 2 */ +#define SDR0_SRST0_UIC3 0x00000800 /* Universal intr ctrller 3 */ +#define SDR0_SRST0_OCM 0x00000400 /* Universal intr ctrller 0 */ +#define SDR0_SRST0_UART2 0x00000200 /* Universal asynchronous receiver/ + transmitter 2 */ +#define SDR0_SRST0_MAL 0x00000100 /* Media access layer */ +#define SDR0_SRST0_GPTR 0x00000040 /* General purpose timer */ +#define SDR0_SRST0_L2CACHE 0x00000004 /* L2 Cache */ +#define SDR0_SRST0_UART3 0x00000002 /* Universal asynchronous receiver/ + transmitter 3 */ +#define SDR0_SRST0_GPIO1 0x00000001 /* General purpose I/O 1 */ + +#define SDR0_SRST1 0x201 +#define SDR0_SRST1_RLL 0x80000000 /* SRIO RLL */ +#define SDR0_SRST1_SCP 0x40000000 /* Serial communications port */ +#define SDR0_SRST1_PLBARB 0x20000000 /* PLB Arbiter */ +#define SDR0_SRST1_EIPPKP 0x10000000 /* EIPPPKP */ +#define SDR0_SRST1_EIP94 0x08000000 /* EIP 94 */ +#define SDR0_SRST1_EMAC0 0x04000000 /* Ethernet media access + controller 0 */ +#define SDR0_SRST1_EMAC1 0x02000000 /* Ethernet media access + controller 1 */ +#define SDR0_SRST1_EMAC2 0x01000000 /* Ethernet media access + controller 2 */ +#define SDR0_SRST1_EMAC3 0x00800000 /* Ethernet media access + controller 3 */ +#define SDR0_SRST1_ZMII 0x00400000 /* Ethernet ZMII/RMII/SMII */ +#define SDR0_SRST1_RGMII0 0x00200000 /* Ethernet RGMII/RTBI 0 */ +#define SDR0_SRST1_RGMII1 0x00100000 /* Ethernet RGMII/RTBI 1 */ +#define SDR0_SRST1_DMA4 0x00080000 /* DMA to PLB4 */ +#define SDR0_SRST1_DMA4CH 0x00040000 /* DMA Channel to PLB4 */ +#define SDR0_SRST1_SATAPHY 0x00020000 /* Serial ATA PHY */ +#define SDR0_SRST1_SRIODEV 0x00010000 /* Serial Rapid IO core, PCS, + serdes */ +#define SDR0_SRST1_SRIOPCS 0x00008000 /* Serial Rapid PCS */ +#define SDR0_SRST1_NDFC 0x00004000 /* Nand flash controller */ +#define SDR0_SRST1_SRIOPLB 0x00002000 /* Serial Rapid IO PLB */ +#define SDR0_SRST1_ETHPLL 0x00001000 /* Ethernet PLL */ +#define SDR0_SRST1_TAHOE1 0x00000800 /* Ethernet Tahoe 1 */ +#define SDR0_SRST1_TAHOE0 0x00000400 /* Ethernet Tahoe 0 */ +#define SDR0_SRST1_SGMII0 0x00000200 /* Ethernet SGMII 0 */ +#define SDR0_SRST1_SGMII1 0x00000100 /* Ethernet SGMII 1 */ +#define SDR0_SRST1_SGMII2 0x00000080 /* Ethernet SGMII 2 */ +#define SDR0_SRST1_AHB 0x00000040 /* PLB4XAHB bridge */ +#define SDR0_SRST1_USBOTGPHY 0x00000020 /* USB 2.0 OTG PHY */ +#define SDR0_SRST1_USBOTG 0x00000010 /* USB 2.0 OTG controller */ +#define SDR0_SRST1_USBHOST 0x00000008 /* USB 2.0 Host controller */ +#define SDR0_SRST1_AHBDMAC 0x00000004 /* AHB DMA controller */ +#define SDR0_SRST1_AHBICM 0x00000002 /* AHB inter-connect matrix */ +#define SDR0_SRST1_SATA 0x00000001 /* Serial ATA controller */ + +/* + * Clocking + */ +#define PLLSYS0_ENG_MASK 0x80000000 /* 0 = SysClk, 1 = PLL VCO */ +#define PLLSYS0_SRC_MASK 0x40000000 /* 0 = PLL A, 1 = PLL B */ +#define PLLSYS0_SEL_MASK 0x38000000 /* 0 = PLL,1 = CPU,5=PerClk*/ +#define PLLSYS0_TUNE_MASK 0x07fe0000 /* PLL Tune bits */ +#define PLLSYS0_FB_DIV_MASK 0x0001f000 /* Feedback divisor */ +#define PLLSYS0_FWD_DIV_A_MASK 0x00000f00 /* Fwd Div A */ +#define PLLSYS0_FWD_DIV_B_MASK 0x000000e0 /* Fwd Div B */ +#define PLLSYS0_PRI_DIV_B_MASK 0x0000001c /* PLL Primary Divisor B */ +#define PLLSYS0_OPB_DIV_MASK 0x00000003 /* OPB Divisor */ + +#define PLLC_ENG_MASK 0x20000000 /* PLL primary forward divisor src */ +#define PLLC_SRC_MASK 0x20000000 /* PLL feedback source */ +#define PLLD_FBDV_MASK 0x1f000000 /* PLL Feedback Divisor */ +#define PLLD_FWDVA_MASK 0x000f0000 /* PLL Forward Divisor A */ +#define PLLD_FWDVB_MASK 0x00000700 /* PLL Forward Divisor B */ +#define PLLD_LFBDV_MASK 0x0000003f /* PLL Local Feedback Divisor */ + +#define OPBDDV_MASK 0x03000000 /* OPB Clock Divisor Register */ +#define PERDV_MASK 0x07000000 /* Periferal Clock Divisor */ +#define PRADV_MASK 0x07000000 /* Primary Divisor A */ +#define PRBDV_MASK 0x07000000 /* Primary Divisor B */ +#define SPCID_MASK 0x03000000 /* Sync PCI Divisor */ + +#define PLL_VCO_FREQ_MIN 500 /* Min VCO freq (MHz) */ +#define PLL_VCO_FREQ_MAX 1000 /* Max VCO freq (MHz) */ +#define PLL_CPU_FREQ_MAX 400 /* Max CPU freq (MHz) */ +#define PLL_PLB_FREQ_MAX 133 /* Max PLB freq (MHz) */ + +/* Strap 1 Register */ +#define PLLSYS1_LF_DIV_MASK 0xfc000000 /* PLL Local Feedback Div */ +#define PLLSYS1_PERCLK_DIV_MASK 0x03000000 /* Peripheral Clk Divisor */ +#define PLLSYS1_MAL_DIV_MASK 0x00c00000 /* MAL Clk Divisor */ +#define PLLSYS1_RW_MASK 0x00300000 /* ROM width */ +#define PLLSYS1_EAR_MASK 0x00080000 /* ERAP Addres reset vector */ +#define PLLSYS1_PAE_MASK 0x00040000 /* PCI arbitor enable */ +#define PLLSYS1_PCHE_MASK 0x00020000 /* PCI host config enable */ +#define PLLSYS1_PISE_MASK 0x00010000 /* PCI init seq. enable */ +#define PLLSYS1_PCWE_MASK 0x00008000 /* PCI local cpu wait enable */ +#define PLLSYS1_PPIM_MASK 0x00007800 /* PCI inbound map */ +#define PLLSYS1_PR64E_MASK 0x00000400 /* PCI init Req64 enable */ +#define PLLSYS1_PXFS_MASK 0x00000300 /* PCI-X Freq Sel */ +#define PLLSYS1_RSVD_MASK 0x00000080 /* RSVD */ +#define PLLSYS1_PDM_MASK 0x00000040 /* PCI-X Driver Mode */ +#define PLLSYS1_EPS_MASK 0x00000038 /* Ethernet Pin Select */ +#define PLLSYS1_RMII_MASK 0x00000004 /* RMII Mode */ +#define PLLSYS1_TRE_MASK 0x00000002 /* GPIO Trace Enable */ +#define PLLSYS1_NTO1_MASK 0x00000001 /* CPU:PLB N-to-1 ratio */ + +#define PCIL0_VENDID (PCIL0_CFGBASE + PCI_VENDOR_ID) +#define PCIL0_DEVID (PCIL0_CFGBASE + PCI_DEVICE_ID) +#define PCIL0_CMD (PCIL0_CFGBASE + PCI_COMMAND) +#define PCIL0_STATUS (PCIL0_CFGBASE + PCI_STATUS) +#define PCIL0_REVID (PCIL0_CFGBASE + PCI_REVISION_ID) +#define PCIL0_CLS (PCIL0_CFGBASE + PCI_CLASS_CODE) +#define PCIL0_CACHELS (PCIL0_CFGBASE + PCI_CACHE_LINE_SIZE) +#define PCIL0_LATTIM (PCIL0_CFGBASE + PCI_LATENCY_TIMER) +#define PCIL0_HDTYPE (PCIL0_CFGBASE + PCI_HEADER_TYPE) +#define PCIL0_BIST (PCIL0_CFGBASE + PCI_BIST) +#define PCIL0_BAR0 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_0) +#define PCIL0_BAR1 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_1) +#define PCIL0_BAR2 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_2) +#define PCIL0_BAR3 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_3) +#define PCIL0_BAR4 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_4) +#define PCIL0_BAR5 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_5) +#define PCIL0_CISPTR (PCIL0_CFGBASE + PCI_CARDBUS_CIS) +#define PCIL0_SBSYSVID (PCIL0_CFGBASE + PCI_SUBSYSTEM_VENDOR_ID) +#define PCIL0_SBSYSID (PCIL0_CFGBASE + PCI_SUBSYSTEM_ID) +#define PCIL0_EROMBA (PCIL0_CFGBASE + PCI_ROM_ADDRESS) +#define PCIL0_CAP (PCIL0_CFGBASE + PCI_CAPABILITY_LIST) +#define PCIL0_RES0 (PCIL0_CFGBASE + 0x0035) +#define PCIL0_RES1 (PCIL0_CFGBASE + 0x0036) +#define PCIL0_RES2 (PCIL0_CFGBASE + 0x0038) +#define PCIL0_INTLN (PCIL0_CFGBASE + PCI_INTERRUPT_LINE) +#define PCIL0_INTPN (PCIL0_CFGBASE + PCI_INTERRUPT_PIN) +#define SDR0_EMACxTXST_FUR 0x02000000 /* TX FIFO underrun */ +#define SDR0_EMACxTXST_BC 0x01000000 /* broadcase address */ +#define SDR0_EMACxTXST_MC 0x00800000 /* multicast address */ +#define SDR0_EMACxTXST_UC 0x00400000 /* unicast address */ +#define SDR0_EMACxTXST_FP 0x00200000 /* frame paused by ctrl pkt */ +#define SDR0_EMACxTXST_BFCS 0x00100000 /* bad FCS in the txmitted fr*/ +#define SDR0_EMACxTXST_CPF 0x00080000 /* TX control pause frame */ +#define SDR0_EMACxTXST_CF 0x00040000 /* TX control frame */ +#define SDR0_EMACxTXST_MSIZ 0x00020000 /* 1024-max bytes txmitted */ +#define SDR0_EMACxTXST_1023 0x00010000 /* 512-1023 bytes txmitted */ +#define SDR0_EMACxTXST_511 0x00008000 /* 256-511 bytes txmitted */ +#define SDR0_EMACxTXST_255 0x00004000 /* 128-255 bytes txmitted */ +#define SDR0_EMACxTXST_127 0x00002000 /* 65-127 bytes txmitted */ +#define SDR0_EMACxTXST_64 0x00001000 /* 64 bytes txmitted */ +#define SDR0_EMACxTXST_SQE 0x00000800 /* SQE indication */ +#define SDR0_EMACxTXST_LOC 0x00000400 /* loss of carrier sense */ +#define SDR0_EMACxTXST_IERR 0x00000080 /* EMAC internal error */ +#define SDR0_EMACxTXST_EDF 0x00000040 /* excessive deferral */ +#define SDR0_EMACxTXST_ECOL 0x00000020 /* excessive collisions */ +#define SDR0_EMACxTXST_LCOL 0x00000010 /* late collision */ +#define SDR0_EMACxTXST_DFFR 0x00000008 /* deferred frame */ +#define SDR0_EMACxTXST_MCOL 0x00000004 /* multiple collision frame */ +#define SDR0_EMACxTXST_SCOL 0x00000002 /* single collision frame */ +#define SDR0_EMACxTXST_TXOK 0x00000001 /* transmit OK */ + +#define PCIL0_MINGNT (PCIL0_CFGBASE + PCI_MIN_GNT) +#define PCIL0_MAXLTNCY (PCIL0_CFGBASE + PCI_MAX_LAT) + +#define PCIL0_BRDGOPT1 (PCIL0_CFGBASE + 0x0040) +#define PCIL0_BRDGOPT2 (PCIL0_CFGBASE + 0x0044) + +#define PCIL0_POM0LAL (PCIL0_CFGBASE + 0x0068) +#define PCIL0_POM0LAH (PCIL0_CFGBASE + 0x006c) +#define PCIL0_POM0SA (PCIL0_CFGBASE + 0x0070) +#define PCIL0_POM0PCIAL (PCIL0_CFGBASE + 0x0074) +#define PCIL0_POM0PCIAH (PCIL0_CFGBASE + 0x0078) +#define PCIL0_POM1LAL (PCIL0_CFGBASE + 0x007c) +#define PCIL0_POM1LAH (PCIL0_CFGBASE + 0x0080) +#define PCIL0_POM1SA (PCIL0_CFGBASE + 0x0084) +#define PCIL0_POM1PCIAL (PCIL0_CFGBASE + 0x0088) +#define PCIL0_POM1PCIAH (PCIL0_CFGBASE + 0x008c) +#define PCIL0_POM2SA (PCIL0_CFGBASE + 0x0090) + +#define PCIL0_PIM0SA (PCIL0_CFGBASE + 0x0098) +#define PCIL0_PIM0LAL (PCIL0_CFGBASE + 0x009c) +#define PCIL0_PIM0LAH (PCIL0_CFGBASE + 0x00a0) +#define PCIL0_PIM1SA (PCIL0_CFGBASE + 0x00a4) +#define PCIL0_PIM1LAL (PCIL0_CFGBASE + 0x00a8) +#define PCIL0_PIM1LAH (PCIL0_CFGBASE + 0x00ac) +#define PCIL0_PIM2SA (PCIL0_CFGBASE + 0x00b0) +#define PCIL0_PIM2LAL (PCIL0_CFGBASE + 0x00b4) +#define PCIL0_PIM2LAH (PCIL0_CFGBASE + 0x00b8) + +#define PCIL0_STS (PCIL0_CFGBASE + 0x00e0) + +/***************************************************************************** + * GPIO macro register define + *****************************************************************************/ + +#define GPIO0_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000B00) + +#define GPIO0_OR (GPIO0_BASE+0x0) +#define GPIO0_TCR (GPIO0_BASE+0x4) +#define GPIO0_OSRL (GPIO0_BASE+0x8) +#define GPIO0_OSRH (GPIO0_BASE+0xC) +#define GPIO0_TSRL (GPIO0_BASE+0x10) +#define GPIO0_TSRH (GPIO0_BASE+0x14) +#define GPIO0_ODR (GPIO0_BASE+0x18) +#define GPIO0_IR (GPIO0_BASE+0x1C) +#define GPIO0_RR1 (GPIO0_BASE+0x20) +#define GPIO0_RR2 (GPIO0_BASE+0x24) +#define GPIO0_RR3 (GPIO0_BASE+0x28) +#define GPIO0_ISR1L (GPIO0_BASE+0x30) +#define GPIO0_ISR1H (GPIO0_BASE+0x34) +#define GPIO0_ISR2L (GPIO0_BASE+0x38) +#define GPIO0_ISR2H (GPIO0_BASE+0x3C) +#define GPIO0_ISR3L (GPIO0_BASE+0x40) +#define GPIO0_ISR3H (GPIO0_BASE+0x44) + +#define GPIO1_OR (GPIO1_BASE+0x0) +#define GPIO1_TCR (GPIO1_BASE+0x4) +#define GPIO1_OSRL (GPIO1_BASE+0x8) +#define GPIO1_OSRH (GPIO1_BASE+0xC) +#define GPIO1_TSRL (GPIO1_BASE+0x10) +#define GPIO1_TSRH (GPIO1_BASE+0x14) +#define GPIO1_ODR (GPIO1_BASE+0x18) +#define GPIO1_IR (GPIO1_BASE+0x1C) +#define GPIO1_RR1 (GPIO1_BASE+0x20) +#define GPIO1_RR2 (GPIO1_BASE+0x24) +#define GPIO1_RR3 (GPIO1_BASE+0x28) +#define GPIO1_ISR1L (GPIO1_BASE+0x30) +#define GPIO1_ISR1H (GPIO1_BASE+0x34) +#define GPIO1_ISR2L (GPIO1_BASE+0x38) +#define GPIO1_ISR2H (GPIO1_BASE+0x3C) +#define GPIO1_ISR3L (GPIO1_BASE+0x40) +#define GPIO1_ISR3H (GPIO1_BASE+0x44) + +#endif /* __APM821XX_H__ */ diff --git a/include/ppc4xx.h b/include/ppc4xx.h index ee30a4c..06230bd 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -44,14 +44,15 @@ #if defined(CONFIG_405EX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) #define CONFIG_SDRAM_PPC4xx_IBM_DDR2 /* IBM DDR(2) controller */ #endif
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_405EZ) || defined(CONFIG_405EX) || \ - defined(CONFIG_460EX) || defined(CONFIG_460GT) + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) #define CONFIG_NAND_NDFC #endif
@@ -61,7 +62,7 @@ defined(CONFIG_440GR) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX)
#define PLB_ARBITER_BASE 0x80
@@ -99,7 +100,9 @@
#endif /* 440EP/EPX 440GR/GRX 440SP/SPE 460EX/GT/SX 405EX*/
-#if defined(CONFIG_440) +#if defined(CONFIG_APM821XX) +#include <apm821xx.h> +#elif defined(CONFIG_440) #include <ppc440.h> #else #include <ppc405.h>
Hi Marri,
Look mostly good. One comment though below.
V2:
- Removed Defines added to 405ex.
V3:
- Change APM82XXX to APM821XX
- Modify the way cpu id is printed.
- Correct inadvertent change.
- Sort define list.
- Remove comment for get_sys_info().
- Define a symbolic constat ISRAM1_OCM_SIZE.
- Create apm821xx.h instead of using ppc440.h
- Correct multiline comment.
I know that Wolfgang specifically asked you to add this file for this "new" SoC. But I'm not so sure if this is the right way. Most of the defines in this new file are a plain copy from include/ppc440.h.
Wolfgang, do you really think this is better than adding support for this SoC into ppc440.h? After all, the CPU core of this SoC is still a PPC4xx PowerPC.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Dear Stefan Roese,
It makes no sense to duplicate common parts. Only different code should be moved to separate files.
Viele Grüße,
[Marri] It is only few lines of code is different. Any way I will make a change and Send it. Regards, Marri
Hi Marri,
Please wait a day or two. I have an idea on how to best cleanup this PPC4xx header mess and will post some patches for it soon. It would be best if you could rebase your work on those patches then (if we find a consensus here).
Cheers, Stefan
Stefan,
Sure I will wait for your changes.
Regards, Marri
On Thu, Sep 9, 2010 at 10:39 AM, Stefan Roese sr@denx.de wrote:
Hi Marri,
Hi Stefan, just a heads up. There are number of processors coming down the pipeline. All with the apm8Xxxx convention. The X is processor family and the later xxx are SoC specializations.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
participants (5)
Feng Kan
Stefan Roese
Tirumala Marri
tmarri@apm.com
