[U-Boot] [patch u-boot git 2/5] davinci: cpu-specific build uses conditional make syntax
From: David Brownell dbrownell@users.sourceforge.net
Update cpu/arm926ejs/davinci/Makefile to use COBJ-y type syntax. Add the first conditional: for EMAC driver support. Not all chips have an EMAC; and boards might not use it, anyway.
This doesn't touch PHY configuration; that should eventually become conditional too.
Signed-off-by: David Brownell dbrownell@users.sourceforge.net --- cpu/arm926ejs/davinci/Makefile | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
--- a/cpu/arm926ejs/davinci/Makefile +++ b/cpu/arm926ejs/davinci/Makefile @@ -27,15 +27,17 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(SOC).a
-COBJS = timer.o ether.o lxt972.o dp83848.o psc.o +COBJS-y += timer.o psc.o +COBJS-$(CONFIG_DRIVER_TI_EMAC) += ether.o lxt972.o dp83848.o + SOBJS = reset.o
ifndef CONFIG_SKIP_LOWLEVEL_INIT SOBJS += lowlevel_init.o endif
-SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) START := $(addprefix $(obj),$(START))
all: $(obj).depend $(LIB)
David Brownell
