[U-Boot] [PATCH] devices: Use list_add_tail() instead of list_add() to register a device
This patch fixes a problem spotted on Glacier/Canyonlands (and most likely lots of other board ports), that no serial output was seen after console initialization in console_init_r(). This is because the last added console device was used instead of the first added.
This patch fixes this problem by using list_add_tail() instead of list_add() to register a device. This way the first added console is used again.
Signed-off-by: Stefan Roese sr@denx.de --- common/devices.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/devices.c b/common/devices.c index 8beebe2..7d0ac2e 100644 --- a/common/devices.c +++ b/common/devices.c @@ -155,7 +155,7 @@ int device_register (device_t * dev) _dev = device_clone(dev); if(!_dev) return -1; - list_add(&(_dev->list), &(devs.list)); + list_add_tail(&(_dev->list), &(devs.list)); return 0; }
Dear Stefan Roese,
Thanks, applied.
Stefan Roese
