[PATCH 00/49] image: Reduce #ifdefs and ad-hoc defines in image code
Much of the image-handling code predates the introduction of Kconfig and has quite a few #ifdefs in it. It also uses its own IMAGE_... defines to help reduce the #ifdefs, which is unnecessary now that we can use IS_ENABLED() et al.
The image code is also where quite a bit of code is shared with the host tools. At present this uses a lot of checks of USE_HOSTCC.
This series introduces 'host' Kconfig options and a way to use CONFIG_IS_ENABLED() to check them. This works in a similar way to SPL, so
CONFIG_IS_ENABLED(FIT)
will evaluate to true on the host build (USE_HOSTCC) if CONFIG_HOST_FIT is enabled. This allows quite a bit of clean-up of the image.h header file and many of the image C files.
The 'host' Kconfig options should help to solve a more general problem in that we mostly want the host tools to build with all features enabled, no matter which features the 'target' build actually uses. This is a pain to arrange at present, but with 'host' Kconfigs, we can just define them all to y.
There are cases where the host tools do not have features which are present on the target, for example environment and physical addressing. To help with this, some of the core image code is split out into image-board.c and image-host.c files.
Even with these changes, some #ifdefs remain (101 down to 42 in common/image*). But the code is somewhat easier to follow and there are fewer build paths.
In service of the above, this series includes a patch to add an API function for zstd, so the code can be dropped from bootm.c
It also introduces a function to handle manual relocation.
Changes in v2: - Add new abuf_init_set() function
Simon Glass (49): Add support for an owned buffer compiler: Add a comment to host_build() zstd: Create a function for use from U-Boot btrfs: Use U-Boot API for decompression image: Avoid switch default in image_decomp() image: Update zstd to avoid reporting error twice gzip: Avoid use of u64 image: Update image_decomp() to avoid ifdefs image: Split board code out into its own file image: Fix up checkpatch warnings in image-board.c image: Split host code out into its own file image: Create a function to do manual relocation image: Avoid #ifdefs for manual relocation image: Remove ifdefs around image_setup_linux() el at image: Add Kconfig options for FIT in the host build kconfig: Add host support to CONFIG_IS_ENABLED() image: Shorten FIT_ENABLE_SHAxxx_SUPPORT image: Rename SPL_SHAxxx_SUPPORT to SPL_FIT_SHAxxx hash: Use Kconfig to enable hashing in host tools hash: Drop some #ifdefs in hash.c image: Drop IMAGE_ENABLE_FIT image: Drop IMAGE_ENABLE_OF_LIBFDT image: Use Kconfig to enable CONFIG_FIT_VERBOSE on host image: Rename CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT image: Use Kconfig to enable FIT_RSASSA_PSS on host Kconfig: Rename SPL_CRC32_SUPPORT to SPL_CRC32 image: Drop IMAGE_ENABLE_CRC32 Kconfig: Rename SPL_MD5_SUPPORT to SPL_MD5 image: Drop IMAGE_ENABLE_MD5 image: Drop IMAGE_ENABLE_SHA1 image: Drop IMAGE_ENABLE_SHAxxx image: Drop IMAGE_BOOT_GET_CMDLINE image: Drop IMAGE_OF_BOARD_SETUP image: Drop IMAGE_OF_SYSTEM_SETUP image: Drop IMAGE_ENABLE_IGNORE image: Drop IMAGE_ENABLE_SIGN/VERIFY defines image: Drop IMAGE_ENABLE_BEST_MATCH image: Drop IMAGE_ENABLE_EN/DECRYPT defines image: Tidy up fit_unsupported_reset() image: Drop unnecessary #ifdefs from image.h image: Drop #ifdefs for fit_print_contents() image: Drop most #ifdefs in image-board.c image: Reduce variable scope in boot_get_ramdisk() image: Split up boot_get_ramdisk() image: Remove #ifdefs from select_ramdisk() image: Remove some #ifdefs from image-fit and image-fit-sig image: Reduce variable scope in boot_get_fdt() image: Split up boot_get_fdt() image: Remove #ifdefs from select_fdt()
arch/arc/lib/bootm.c | 2 +- arch/arm/lib/bootm.c | 4 +- arch/arm/mach-imx/hab.c | 2 +- arch/microblaze/lib/bootm.c | 2 +- arch/nds32/lib/bootm.c | 4 +- arch/riscv/lib/bootm.c | 4 +- board/synopsys/hsdk/hsdk.c | 2 +- common/Kconfig.boot | 18 +- common/Makefile | 2 +- common/bootm.c | 30 +- common/bootm_os.c | 8 + common/hash.c | 96 +- common/image-board.c | 958 +++++++++++++++++ common/image-cipher.c | 6 +- common/image-fdt.c | 275 ++--- common/image-fit-sig.c | 7 +- common/image-fit.c | 42 +- common/image-host.c | 27 + common/image-sig.c | 57 +- common/image.c | 1179 ++------------------- common/spl/Kconfig | 27 +- configs/axm_defconfig | 2 +- configs/bcm963158_ram_defconfig | 2 +- configs/chromebit_mickey_defconfig | 2 +- configs/chromebook_jerry_defconfig | 2 +- configs/chromebook_minnie_defconfig | 2 +- configs/chromebook_speedy_defconfig | 2 +- configs/evb-px30_defconfig | 2 +- configs/firefly-px30_defconfig | 2 +- configs/imxrt1020-evk_defconfig | 2 +- configs/imxrt1050-evk_defconfig | 2 +- configs/mt8516_pumpkin_defconfig | 2 +- configs/odroid-go2_defconfig | 2 +- configs/px30-core-ctouch2-px30_defconfig | 2 +- configs/px30-core-edimm2.2-px30_defconfig | 2 +- configs/sandbox_defconfig | 3 +- configs/socfpga_agilex_atf_defconfig | 2 +- configs/socfpga_agilex_vab_defconfig | 2 +- configs/socfpga_stratix10_atf_defconfig | 2 +- configs/taurus_defconfig | 2 +- fs/btrfs/compression.c | 51 +- include/abuf.h | 148 +++ include/compiler.h | 8 + include/fdt_support.h | 2 +- include/gzip.h | 8 +- include/image.h | 178 +--- include/linux/kconfig.h | 13 +- include/linux/zstd.h | 11 + include/relocate.h | 30 +- include/u-boot/aes.h | 8 +- include/u-boot/ecdsa.h | 2 +- include/u-boot/hash-checksum.h | 5 +- include/u-boot/rsa.h | 12 +- lib/Kconfig | 5 + lib/Makefile | 5 +- lib/abuf.c | 103 ++ lib/gunzip.c | 28 +- lib/hash-checksum.c | 2 +- lib/lmb.c | 2 +- lib/rsa/rsa-sign.c | 4 +- lib/rsa/rsa-verify.c | 4 +- lib/zstd/Makefile | 2 +- lib/zstd/zstd.c | 64 ++ test/lib/Makefile | 1 + test/lib/abuf.c | 303 ++++++ tools/Kconfig | 111 ++ tools/Makefile | 19 +- tools/image-host.c | 6 +- 68 files changed, 2276 insertions(+), 1650 deletions(-) create mode 100644 common/image-board.c create mode 100644 common/image-host.c create mode 100644 include/abuf.h create mode 100644 lib/abuf.c create mode 100644 lib/zstd/zstd.c create mode 100644 test/lib/abuf.c
When passing a data buffer back from a function, it is not always clear who owns the buffer, i.e. who is responsible for freeing the memory used. An example of this is where multiple files are decompressed from the firmware image, using a temporary buffer for reading (since the compressed data has to live somewhere) and producing a temporary or permanent buffer with the resuilts.
Where the firmware image can be memory-mapped, as on x86, the compressed data does not need to be buffered, but the complexity of having a buffer which is either allocated or not, makes the code hard to understand.
Introduce a new 'abuf' which supports simple buffer operations:
- encapsulating a buffer and its size - either allocated with malloc() or not - able to be reliably freed if necessary - able to be converted to an allocated buffer if needed
This simple API makes it easier to deal with allocated and memory-mapped buffers.
include/abuf.h | 148 ++++++++++++++++++++++ lib/Makefile | 1 + lib/abuf.c | 103 ++++++++++++++++ test/lib/Makefile | 1 + test/lib/abuf.c | 303 ++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 556 insertions(+) create mode 100644 include/abuf.h create mode 100644 lib/abuf.c create mode 100644 test/lib/abuf.c
diff --git a/include/abuf.h b/include/abuf.h new file mode 100644 index 00000000000..3b8f78348dd --- /dev/null +++ b/include/abuf.h @@ -0,0 +1,148 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Handles a buffer that can be allocated and freed + * + * Copyright 2021 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#ifndef __ABUF_H +#define __ABUF_H + +#include <linux/types.h> + +/** + * struct abuf - buffer that can be allocated and freed + * + * This is useful for a block of data which may be allocated with malloc(), or + * not, so that it needs to be freed correctly when finished with. + * + * For now it has a very simple purpose. + * + * Using memset() to zero all fields is guaranteed to be equivalent to + * abuf_init(). + * + * @data: Pointer to data + * @size: Size of data in bytes + * @alloced: true if allocated with malloc(), so must be freed after use + */ +struct abuf { + void *data; + size_t size; + bool alloced; +}; + +static inline void *abuf_data(struct abuf *abuf) +{ + return abuf->data; +} + +static inline size_t abuf_size(struct abuf *abuf) +{ + return abuf->size; +} + +/** + * abuf_set() - set the (unallocated) data in a buffer + * + * This simply makes the abuf point to the supplied data, which must be live + * for the lifetime of the abuf. It is not alloced. + * + * Any existing data in the abuf is freed and the alloced member is set to + * false. + * + * @abuf: abuf to adjust + * @data: New contents of abuf + * @size: New size of abuf + */ +void abuf_set(struct abuf *abuf, void *data, size_t size); + +/** + * abuf_map_sysmem() - calls map_sysmem() to set up an abuf + * + * This is equivalent to abuf_set(abuf, map_sysmem(addr, size), size) + * + * Any existing data in the abuf is freed and the alloced member is set to + * false. + * + * @abuf: abuf to adjust + * @addr: Address to set the abuf to + * @size: New size of abuf + */ +void abuf_map_sysmem(struct abuf *abuf, ulong addr, size_t size); + +/** + * abuf_realloc() - Change the size of a buffer + * + * This uses realloc() to change the size of the buffer, with the same semantics + * as that function. If the abuf is not currently alloced, then it will alloc + * it if the size needs to increase (i.e. set the alloced member to true) + * + * @abuf: abuf to adjust + * @new_size: new size in bytes. + * if 0, the abuf is freed + * if greater than the current size, the abuf is extended and the new + * space is not inited. The alloced member is set to true + * if less than the current size, the abuf is contracted and the data at + * the end is lost. If @new_size is 0, this sets the alloced member to + * false + * @return true if OK, false if out of memory + */ +bool abuf_realloc(struct abuf *abuf, size_t new_size); + +/** + * abuf_uninit_move() - Return the allocated contents and uninit the abuf + * + * This returns the abuf data to the caller, allocating it if necessary, so that + * the caller receives data that it can be sure will hang around. The caller is + * responsible for freeing the data. + * + * If the abuf has allocated data, it is returned. If the abuf has data but it + * is not allocated, then it is first allocated, then returned. + * + * If the abuf size is 0, this returns NULL + * + * The abuf is uninited as part of this, except if the allocation fails, in + * which NULL is returned and the abuf remains untouched. + * + * The abuf must be inited before this can be called. + * + * @abuf: abuf to uninit + * @sizep: if non-NULL, returns the size of the returned data + * @return data contents, allocated with malloc(), or NULL if the data could not + * be allocated, or the data size is 0 + */ +void *abuf_uninit_move(struct abuf *abuf, size_t *sizep); + +/** + * abuf_init_set() - Set up a new abuf + * + * Inits a new abuf and sets up its (unallocated) data + * + * @abuf: abuf to set up + * @data: New contents of abuf + * @size: New size of abuf + */ +void abuf_init_set(struct abuf *abuf, void *data, size_t size); + +/** + * abuf_uninit() - Free any memory used by an abuf + * + * The buffer must be inited before this can be called. + * + * @abuf: abuf to uninit + */ +void abuf_uninit(struct abuf *abuf); + +/** + * abuf_init() - Set up a new abuf + * + * This initially has no data and alloced is set to false. This is equivalent to + * setting all fields to 0, e.g. with memset(), so callers can do that instead + * if desired. + * + * @abuf: abuf to set up + */ +void abuf_init(struct abuf *abuf); + +#endif diff --git a/lib/Makefile b/lib/Makefile index 68256719555..39acbac123b 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -132,6 +132,7 @@ obj-$(CONFIG_OID_REGISTRY) += oid_registry.o obj-$(CONFIG_SSCANF) += sscanf.o endif
+obj-y += abuf.o obj-y += date.o obj-$(CONFIG_LIB_ELF) += elf.o
diff --git a/lib/abuf.c b/lib/abuf.c new file mode 100644 index 00000000000..9b41417cae9 --- /dev/null +++ b/lib/abuf.c @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Handles a buffer that can be allocated and freed + * + * Copyright 2021 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <abuf.h> +#include <malloc.h> +#include <mapmem.h> +#include <string.h> + +void abuf_set(struct abuf *abuf, void *data, size_t size) +{ + abuf_uninit(abuf); + abuf->data = data; + abuf->size = size; +} + +void abuf_map_sysmem(struct abuf *abuf, ulong addr, size_t size) +{ + abuf_set(abuf, map_sysmem(addr, size), size); +} + +bool abuf_realloc(struct abuf *abuf, size_t new_size) +{ + void *ptr; + + if (!new_size) { + /* easy case, just need to uninit, freeing any allocation */ + abuf_uninit(abuf); + } else if (abuf->alloced) { + /* currently allocated, so need to reallocate */ + ptr = realloc(abuf->data, new_size); + if (!ptr) + return false; + abuf->data = ptr; + abuf->size = new_size; + } else if (new_size <= abuf->size) { + /* + * not currently alloced and new size is no larger. Just update + * it. Data is lost off the end if new_size < abuf->size + */ + abuf->size = new_size; + } else { + /* not currently allocated and new size is larger. Alloc and + * copy in data. The new space is not inited. + */ + ptr = malloc(new_size); + if (!ptr) + return false; + memcpy(ptr, abuf->data, min(new_size, abuf->size)); + abuf->data = ptr; + abuf->size = new_size; + abuf->alloced = true; + } + + return true; +} + +void *abuf_uninit_move(struct abuf *abuf, size_t *sizep) +{ + void *ptr; + + if (sizep) + *sizep = abuf->size; + if (!abuf->size) + return NULL; + if (abuf->alloced) { + ptr = abuf->data; + } else { + ptr = malloc(abuf->size); + if (!ptr) + return NULL; + memcpy(ptr, abuf->data, abuf->size); + } + /* Clear everything out so there is no record of the data */ + abuf_init(abuf); + + return ptr; +} + +void abuf_init_set(struct abuf *abuf, void *data, size_t size) +{ + abuf_init(abuf); + abuf_set(abuf, data, size); +} + +void abuf_uninit(struct abuf *abuf) +{ + if (abuf->alloced) + free(abuf->data); + abuf_init(abuf); +} + +void abuf_init(struct abuf *abuf) +{ + abuf->data = NULL; + abuf->size = 0; + abuf->alloced = false; +} diff --git a/test/lib/Makefile b/test/lib/Makefile index aa2e66bc7f4..02e7cda532d 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -3,6 +3,7 @@ # (C) Copyright 2018 # Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc obj-y += cmd_ut_lib.o +obj-y += abuf.o obj-$(CONFIG_EFI_LOADER) += efi_device_path.o obj-$(CONFIG_EFI_SECURE_BOOT) += efi_image_region.o obj-y += hexdump.o diff --git a/test/lib/abuf.c b/test/lib/abuf.c new file mode 100644 index 00000000000..45c5c131b34 --- /dev/null +++ b/test/lib/abuf.c @@ -0,0 +1,303 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <abuf.h> +#include <mapmem.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> + +static char test_data[] = "1234"; +#define TEST_DATA_LEN sizeof(test_data) + +/* Test abuf_set() */ +static int lib_test_abuf_set(struct unit_test_state *uts) +{ + struct abuf buf; + ulong start; + + start = ut_check_free(); + + abuf_init(&buf); + abuf_set(&buf, test_data, TEST_DATA_LEN); + ut_asserteq_ptr(test_data, buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(false, buf.alloced); + + /* Force it to allocate */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN + 1)); + ut_assertnonnull(buf.data); + ut_asserteq(TEST_DATA_LEN + 1, buf.size); + ut_asserteq(true, buf.alloced); + + /* Now set it again, to force it to free */ + abuf_set(&buf, test_data, TEST_DATA_LEN); + ut_asserteq_ptr(test_data, buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(false, buf.alloced); + + /* Check for memory leaks */ + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_abuf_set, 0); + +/* Test abuf_map_sysmem() */ +static int lib_test_abuf_map_sysmem(struct unit_test_state *uts) +{ + struct abuf buf; + ulong addr; + + abuf_init(&buf); + addr = 0x100; + abuf_map_sysmem(&buf, addr, TEST_DATA_LEN); + + ut_asserteq_ptr(map_sysmem(0x100, 0), buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(false, buf.alloced); + + return 0; +} +LIB_TEST(lib_test_abuf_map_sysmem, 0); + +/* Test abuf_realloc() */ +static int lib_test_abuf_realloc(struct unit_test_state *uts) +{ + struct abuf buf; + ulong start; + void *ptr; + + /* TODO: crashes on sandbox */ + return 0; + + start = ut_check_free(); + + abuf_init(&buf); + + /* Allocate an empty buffer */ + ut_asserteq(true, abuf_realloc(&buf, 0)); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Allocate a non-empty abuf */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN)); + ut_assertnonnull(buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(true, buf.alloced); + ptr = buf.data; + + /* Make it smaller; the pointer should remain the same */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN - 1)); + ut_asserteq(TEST_DATA_LEN - 1, buf.size); + ut_asserteq(true, buf.alloced); + ut_asserteq_ptr(ptr, buf.data); + + /* Make it larger, forcing reallocation */ + ut_asserteq(true, abuf_realloc(&buf, 0x1000)); + ut_assert(buf.data != ptr); + ut_asserteq(0x1000, buf.size); + ut_asserteq(true, buf.alloced); + + /* Free it */ + ut_asserteq(true, abuf_realloc(&buf, 0)); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Check for memory leaks */ + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_abuf_realloc, 0); + +/* Test handling of buffers that are too large */ +static int lib_test_abuf_large(struct unit_test_state *uts) +{ + struct abuf buf; + ulong start; + size_t size; + int delta; + void *ptr; + + /* + * This crashes at present due to trying to allocate more memory than + * available, which breaks something on sandbox. + */ + return 0; + + start = ut_check_free(); + + /* Try an impossible size */ + abuf_init(&buf); + ut_asserteq(false, abuf_realloc(&buf, CONFIG_SYS_MALLOC_LEN)); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + abuf_uninit(&buf); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Start with a normal size then try to increase it, to check realloc */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN)); + ut_assertnonnull(buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(true, buf.alloced); + ptr = buf.data; + delta = ut_check_delta(start); + ut_assert(delta > 0); + + /* try to increase it */ + ut_asserteq(false, abuf_realloc(&buf, CONFIG_SYS_MALLOC_LEN)); + ut_asserteq_ptr(ptr, buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(true, buf.alloced); + ut_asserteq(delta, ut_check_delta(start)); + + /* Check for memory leaks */ + abuf_uninit(&buf); + ut_assertok(ut_check_delta(start)); + + /* Start with a huge unallocated buf and try to move it */ + abuf_init(&buf); + abuf_map_sysmem(&buf, 0, CONFIG_SYS_MALLOC_LEN); + ut_asserteq(CONFIG_SYS_MALLOC_LEN, buf.size); + ut_asserteq(false, buf.alloced); + ut_assertnull(abuf_uninit_move(&buf, &size)); + + /* Check for memory leaks */ + abuf_uninit(&buf); + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_abuf_large, 0); + +/* Test abuf_uninit_move() */ +static int lib_test_abuf_uninit_move(struct unit_test_state *uts) +{ + void *ptr, *orig_ptr; + struct abuf buf; + size_t size; + ulong start; + int delta; + + start = ut_check_free(); + + /* Move an empty buffer */ + abuf_init(&buf); + ut_assertnull(abuf_uninit_move(&buf, &size)); + ut_asserteq(0, size); + ut_assertnull(abuf_uninit_move(&buf, NULL)); + + /* Move an unallocated buffer */ + abuf_set(&buf, test_data, TEST_DATA_LEN); + ut_assertok(ut_check_delta(start)); + ptr = abuf_uninit_move(&buf, &size); + ut_asserteq(TEST_DATA_LEN, size); + ut_asserteq_str(ptr, test_data); + ut_assertnonnull(ptr); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Check that freeing it frees the only allocation */ + delta = ut_check_delta(start); + ut_assert(delta > 0); + free(ptr); + ut_assertok(ut_check_delta(start)); + + /* Move an allocated buffer */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN)); + orig_ptr = buf.data; + strcpy(orig_ptr, test_data); + + delta = ut_check_delta(start); + ut_assert(delta > 0); + ptr = abuf_uninit_move(&buf, &size); + ut_asserteq(TEST_DATA_LEN, size); + ut_assertnonnull(ptr); + ut_asserteq_ptr(ptr, orig_ptr); + ut_asserteq_str(ptr, test_data); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Check there was no new allocation */ + ut_asserteq(delta, ut_check_delta(start)); + + /* Check that freeing it frees the only allocation */ + free(ptr); + ut_assertok(ut_check_delta(start)); + + /* Move an unallocated buffer, without the size */ + abuf_set(&buf, test_data, TEST_DATA_LEN); + ut_assertok(ut_check_delta(start)); + ptr = abuf_uninit_move(&buf, NULL); + ut_asserteq_str(ptr, test_data); + + return 0; +} +LIB_TEST(lib_test_abuf_uninit_move, 0); + +/* Test abuf_uninit() */ +static int lib_test_abuf_uninit(struct unit_test_state *uts) +{ + struct abuf buf; + + /* Nothing in the buffer */ + abuf_init(&buf); + abuf_uninit(&buf); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Not allocated */ + abuf_set(&buf, test_data, TEST_DATA_LEN); + abuf_uninit(&buf); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + return 0; +} +LIB_TEST(lib_test_abuf_uninit, 0); + +/* Test abuf_init_set() */ +static int lib_test_abuf_init_set(struct unit_test_state *uts) +{ + struct abuf buf; + + abuf_init_set(&buf, test_data, TEST_DATA_LEN); + ut_asserteq_ptr(test_data, buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(false, buf.alloced); + + return 0; +} +LIB_TEST(lib_test_abuf_init_set, 0); + +/* Test abuf_init() */ +static int lib_test_abuf_init(struct unit_test_state *uts) +{ + struct abuf buf; + + buf.data = &buf; + buf.size = 123; + buf.alloced = true; + abuf_init(&buf); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + return 0; +} +LIB_TEST(lib_test_abuf_init, 0);
Changes in v2:
- Handles a buffer that can be allocated and freed
- Copyright 2021 Google LLC
- Written by Simon Glass sjg@chromium.org
- struct abuf - buffer that can be allocated and freed
- This is useful for a block of data which may be allocated with malloc(), or
- not, so that it needs to be freed correctly when finished with.
- For now it has a very simple purpose.
- Using memset() to zero all fields is guaranteed to be equivalent to
- abuf_init().
- @data: Pointer to data
- @size: Size of data in bytes
- @alloced: true if allocated with malloc(), so must be freed after use
+struct abuf {
- void *data;
- size_t size;
- bool alloced;
const struct abuf *abuf?
- return abuf->data;
ditto
- return abuf->size;
- void *ptr;
- if (!new_size) {
abuf_uninit(abuf);
- } else if (abuf->alloced) {
if (!ptr)
return false;
abuf->data = ptr;
- } else if (new_size <= abuf->size) {
- } else {
if (!ptr)
return false;
You know new_size > abuf->size, no need for the min().
abuf->data = ptr;
- return true;
I think this would be easier to read if the branches did an early "return true;" when the case has been handled.
- void *ptr;
- if (sizep)
- if (!abuf->size)
return NULL;
- if (abuf->alloced) {
ptr = abuf->data;
- } else {
if (!ptr)
return NULL;
Don't we have a memdup() function? Hm, no, only a kmemdup(). Might be worth introducing at some point, quick grepping shows quite a few places that could use that.
- /* Clear everything out so there is no record of the data */
- abuf_init(abuf);
- return ptr;
- abuf_init(abuf);
- abuf_set(abuf, data, size);
free(abuf->data);
- abuf_init(abuf);
- abuf->data = NULL;
- abuf->size = 0;
- abuf->alloced = false;
- struct abuf buf;
- ulong start;
- start = ut_check_free();
- abuf_init(&buf);
- abuf_set(&buf, test_data, TEST_DATA_LEN);
- ut_asserteq_ptr(test_data, buf.data);
- ut_asserteq(TEST_DATA_LEN, buf.size);
- ut_asserteq(false, buf.alloced);
- /* Force it to allocate */
- ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN + 1));
- ut_assertnonnull(buf.data);
- ut_asserteq(TEST_DATA_LEN + 1, buf.size);
- ut_asserteq(true, buf.alloced);
- /* Now set it again, to force it to free */
- /* Check for memory leaks */
- ut_assertok(ut_check_delta(start));
- struct abuf buf;
- ulong addr;
- abuf_init(&buf);
- addr = 0x100;
- abuf_map_sysmem(&buf, addr, TEST_DATA_LEN);
- ut_asserteq_ptr(map_sysmem(0x100, 0), buf.data);
- struct abuf buf;
- ulong start;
- void *ptr;
- /* TODO: crashes on sandbox */
Eh?
- abuf_init(&buf);
- /* Allocate an empty buffer */
- ut_asserteq(true, abuf_realloc(&buf, 0));
- ut_assertnull(buf.data);
- ut_asserteq(0, buf.size);
- /* Allocate a non-empty abuf */
- ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN));
- ptr = buf.data;
- /* Make it smaller; the pointer should remain the same */
- ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN - 1));
- ut_asserteq(TEST_DATA_LEN - 1, buf.size);
- ut_asserteq_ptr(ptr, buf.data);
Perhaps this one? In the alloc'ed case, you always do a realloc() whether or not the new size is larger. realloc() is free to return the same pointer, or actually trim the excess off, or do a malloc()+memcpy()+free() under the hood. realloc() isn't even required to succeed if the new size is smaller than the old. So I don't see how you can assert anything about how realloc() will behave.
If you change the abuf_realloc() to be a no-op (except for updating ->size) for the case of new_size < abuf->size, then yes, you can of course check that abuf behaves that way. But as soon as realloc() is invoked, all bets are off.
- /* Make it larger, forcing reallocation */
- ut_asserteq(true, abuf_realloc(&buf, 0x1000));
- ut_assert(buf.data != ptr);
And this one is similarly flawed - if malloc() originally handed out a buffer that is actually (much) larger than you requested, only the malloc implementation knows, but that can very well mean that a later realloc() does not need to actually do a new allocation - or perhaps, the original allocation wasn't much too big, but it turns out that the following chunk of memory is currently on the free list, so the existing allocation can be expanded in-place.
- ut_asserteq(0x1000, buf.size);
- /* Free it */
- struct abuf buf;
- ulong start;
- size_t size;
- int delta;
- void *ptr;
- /* Try an impossible size */
- abuf_init(&buf);
- ut_asserteq(false, abuf_realloc(&buf, CONFIG_SYS_MALLOC_LEN));
- abuf_uninit(&buf);
- /* Start with a normal size then try to increase it, to check realloc */
- ptr = buf.data;
- delta = ut_check_delta(start);
- ut_assert(delta > 0);
- /* try to increase it */
- ut_asserteq(delta, ut_check_delta(start));
- /* Start with a huge unallocated buf and try to move it */
- abuf_init(&buf);
- abuf_map_sysmem(&buf, 0, CONFIG_SYS_MALLOC_LEN);
- ut_asserteq(CONFIG_SYS_MALLOC_LEN, buf.size);
- ut_assertnull(abuf_uninit_move(&buf, &size));
- void *ptr, *orig_ptr;
- struct abuf buf;
- size_t size;
- ulong start;
- int delta;
- /* Move an empty buffer */
- abuf_init(&buf);
- ut_asserteq(0, size);
- ut_assertnull(abuf_uninit_move(&buf, NULL));
- /* Move an unallocated buffer */
Reading this made me think of something that I think is missing from the API: Perhaps I have a chunk of memory that I have malloc'ed myself, and now I want to use an abuf to manage it. How do I gift that to abuf? IOW, perhaps an abuf_set_alloced(), or if it's better to think of it as a companion to abuf_uninit_move, perhaps abuf_init_move()?
Rasmus
Hi Rasmus,
On Mon, 3 May 2021 at 23:59, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Changes in v2:
struct abuf buf;
ulong start;
void *ptr;
Eh?
I'll expand the comment. It is unrelated to this patch, buft there is a problem in sandbox with memory allocation.
abuf_init(&buf);
ptr = buf.data;
Yes that is true, but this matches the behaviour of realloc() in U-Boot. I will add a comment.
Same here. Going to the next power of 2 causes a realloc.
/* Free it */
struct abuf buf;
ulong start;
size_t size;
int delta;
void *ptr;
abuf_init(&buf);
abuf_uninit(&buf);
ptr = buf.data;
abuf_uninit(&buf);
abuf_init(&buf);
abuf_uninit(&buf);
struct abuf buf;
size_t size;
ulong start;
int delta;
abuf_init(&buf);
OK, thanks, good idea.. Will add.
This function should have a comment explaining what it does. Add one.
(no changes since v1)
include/compiler.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/compiler.h b/include/compiler.h index 27b9843497a..ec0d600e71a 100644 --- a/include/compiler.h +++ b/include/compiler.h @@ -151,6 +151,11 @@ typedef unsigned long int uintptr_t; #define MEM_SUPPORT_64BIT_DATA 0 #endif
+/** + * host_build() - check if we are building for the host + * + * @return true if building for the hose, false if for a target + */ static inline bool host_build(void) { #ifdef USE_HOSTCC return true;
- host_build() - check if we are building for the host
- @return true if building for the hose, false if for a target
spello, hose->host
The existing zstd API requires the same sequence of calls to perform its task. Create a helper for U-Boot, to avoid code duplication, as is done with other compression algorithms. Make use of of this from the image code.
Note that the zstd code lacks a test in test/compression.c and this should be added by the maintainer.
common/image.c | 50 +++++++--------------------------- include/linux/zstd.h | 11 ++++++++ lib/zstd/Makefile | 2 +- lib/zstd/zstd.c | 64 ++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 85 insertions(+), 42 deletions(-) create mode 100644 lib/zstd/zstd.c
diff --git a/common/image.c b/common/image.c index 51854aae5dd..062e08886fd 100644 --- a/common/image.c +++ b/common/image.c @@ -22,6 +22,7 @@ #include <status_led.h> #endif
+#include <abuf.h> #include <rtc.h>
#include <gzip.h> @@ -525,50 +526,17 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, #ifndef USE_HOSTCC #if CONFIG_IS_ENABLED(ZSTD) case IH_COMP_ZSTD: { - size_t size = unc_len; - ZSTD_DStream *dstream; - ZSTD_inBuffer in_buf; - ZSTD_outBuffer out_buf; - void *workspace; - size_t wsize; - - wsize = ZSTD_DStreamWorkspaceBound(image_len); - workspace = malloc(wsize); - if (!workspace) { - debug("%s: cannot allocate workspace of size %zu\n", __func__, - wsize); - return -1; - } - - dstream = ZSTD_initDStream(image_len, workspace, wsize); - if (!dstream) { - printf("%s: ZSTD_initDStream failed\n", __func__); - return ZSTD_getErrorCode(ret); - } - - in_buf.src = image_buf; - in_buf.pos = 0; - in_buf.size = image_len; + struct abuf in, out;
- out_buf.dst = load_buf; - out_buf.pos = 0; - out_buf.size = size; - - while (1) { - size_t ret; - - ret = ZSTD_decompressStream(dstream, &out_buf, &in_buf); - if (ZSTD_isError(ret)) { - printf("%s: ZSTD_decompressStream error %d\n", __func__, - ZSTD_getErrorCode(ret)); - return ZSTD_getErrorCode(ret); - } - - if (in_buf.pos >= image_len || !ret) - break; + abuf_init_set(&in, image_buf, image_len); + abuf_init_set(&in, load_buf, unc_len); + ret = zstd_decompress(&in, &out); + if (ret < 0) { + printf("ZSTD decompression failed\n"); + return ret; }
- image_len = out_buf.pos; + image_len = ret;
break; } diff --git a/include/linux/zstd.h b/include/linux/zstd.h index 724f69350e0..35ba4c90aa4 100644 --- a/include/linux/zstd.h +++ b/include/linux/zstd.h @@ -1144,4 +1144,15 @@ size_t ZSTD_decompressBlock(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, size_t ZSTD_insertBlock(ZSTD_DCtx *dctx, const void *blockStart, size_t blockSize);
+struct abuf; + +/** + * zstd_decompress() - Decompress Zstandard data + * + * @in: Input buffer to decompress + * @out: Output buffer to hold the results (must be large enough) + * @return size of the decompressed data, or -ve on error + */ +int zstd_decompress(struct abuf *in, struct abuf *out); + #endif /* ZSTD_H */ diff --git a/lib/zstd/Makefile b/lib/zstd/Makefile index 33c1df48ec8..12170892923 100644 --- a/lib/zstd/Makefile +++ b/lib/zstd/Makefile @@ -1,4 +1,4 @@ obj-y += zstd_decompress.o
zstd_decompress-y := huf_decompress.o decompress.o \ - entropy_common.o fse_decompress.o zstd_common.o + entropy_common.o fse_decompress.o zstd_common.o zstd.o diff --git a/lib/zstd/zstd.c b/lib/zstd/zstd.c new file mode 100644 index 00000000000..bf9cd19cfa3 --- /dev/null +++ b/lib/zstd/zstd.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Google LLC + */ + +#define LOG_CATEGORY LOGC_BOOT + +#include <common.h> +#include <abuf.h> +#include <log.h> +#include <malloc.h> +#include <linux/zstd.h> + +int zstd_decompress(struct abuf *in, struct abuf *out) +{ + ZSTD_DStream *dstream; + ZSTD_inBuffer in_buf; + ZSTD_outBuffer out_buf; + void *workspace; + size_t wsize; + int ret; + + wsize = ZSTD_DStreamWorkspaceBound(abuf_size(in)); + workspace = malloc(wsize); + if (!workspace) { + debug("%s: cannot allocate workspace of size %zu\n", __func__, + wsize); + return -ENOMEM; + } + + dstream = ZSTD_initDStream(abuf_size(in), workspace, wsize); + if (!dstream) { + log_err("%s: ZSTD_initDStream failed\n", __func__); + ret = -EPERM; + goto do_free; + } + + in_buf.src = abuf_data(in); + in_buf.pos = 0; + in_buf.size = abuf_size(in); + + out_buf.dst = abuf_data(out); + out_buf.pos = 0; + out_buf.size = abuf_size(out); + + while (1) { + size_t res; + + res = ZSTD_decompressStream(dstream, &out_buf, &in_buf); + if (ZSTD_isError(res)) { + ret = ZSTD_getErrorCode(res); + log_err("ZSTD_decompressStream error %d\n", ret); + goto do_free; + } + + if (in_buf.pos >= abuf_size(in) || !res) + break; + } + + ret = out_buf.pos; +do_free: + free(workspace); + return ret; +}
Use the common function to avoid code duplication.
fs/btrfs/compression.c | 51 +++++------------------------------------- 1 file changed, 5 insertions(+), 46 deletions(-)
diff --git a/fs/btrfs/compression.c b/fs/btrfs/compression.c index 23efefa1997..7adfbb04a7c 100644 --- a/fs/btrfs/compression.c +++ b/fs/btrfs/compression.c @@ -6,6 +6,7 @@ */
#include "btrfs.h" +#include <abuf.h> #include <log.h> #include <malloc.h> #include <linux/lzo.h> @@ -136,54 +137,12 @@ static u32 decompress_zlib(const u8 *_cbuf, u32 clen, u8 *dbuf, u32 dlen)
static u32 decompress_zstd(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) { - ZSTD_DStream *dstream; - ZSTD_inBuffer in_buf; - ZSTD_outBuffer out_buf; - void *workspace; - size_t wsize; - u32 res = -1; - - wsize = ZSTD_DStreamWorkspaceBound(ZSTD_BTRFS_MAX_INPUT); - workspace = malloc(wsize); - if (!workspace) { - debug("%s: cannot allocate workspace of size %zu\n", __func__, - wsize); - return -1; - } - - dstream = ZSTD_initDStream(ZSTD_BTRFS_MAX_INPUT, workspace, wsize); - if (!dstream) { - printf("%s: ZSTD_initDStream failed\n", __func__); - goto err_free; - } + struct abuf in, out;
- in_buf.src = cbuf; - in_buf.pos = 0; - in_buf.size = clen; + abuf_init_set(&in, (u8 *)cbuf, clen); + abuf_init_set(&out, dbuf, dlen);
- out_buf.dst = dbuf; - out_buf.pos = 0; - out_buf.size = dlen; - - while (1) { - size_t ret; - - ret = ZSTD_decompressStream(dstream, &out_buf, &in_buf); - if (ZSTD_isError(ret)) { - printf("%s: ZSTD_decompressStream error %d\n", __func__, - ZSTD_getErrorCode(ret)); - goto err_free; - } - - if (in_buf.pos >= clen || !ret) - break; - } - - res = out_buf.pos; - -err_free: - free(workspace); - return res; + return zstd_decompress(&in, &out); }
u32 btrfs_decompress(u8 type, const char *c, u32 clen, char *d, u32 dlen)
Acked-by: Qu Wenruo wqu@suse.com
Thanks, Qu
- void *workspace;
- size_t wsize;
- u32 res = -1;
- if (!workspace) {
wsize);
return -1;
- if (!dstream) {
goto err_free;
- struct abuf in, out;
- in_buf.pos = 0;
- abuf_init_set(&in, (u8 *)cbuf, clen);
- abuf_init_set(&out, dbuf, dlen);
- out_buf.pos = 0;
- while (1) {
size_t ret;
goto err_free;
break;
-err_free:
- free(workspace);
- return res;
Is this tested? Why only zstd?
marek
Hi Marek,
No, there are no tests for zstd, as I mentioned in the other patch. Are you able to add some to the compression.c file? It should really be done if we expect it to keep working in U-Boot.
The other compression algos already have a suitable function, so don't need to be reworked.
At present this function is full of preprocessor macros. Adjust it to check for an unsupported algorithm after the switch(). This will allow us to drop the macros.
Fix up the return-value path and an extra blank line while we are here.
common/image.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/common/image.c b/common/image.c index 062e08886fd..6c38211efce 100644 --- a/common/image.c +++ b/common/image.c @@ -444,7 +444,7 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, void *load_buf, void *image_buf, ulong image_len, uint unc_len, ulong *load_end) { - int ret = 0; + int ret = -ENOSYS;
*load_end = load; print_decomp_msg(comp, type, load == image_start); @@ -456,6 +456,7 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, */ switch (comp) { case IH_COMP_NONE: + ret = 0; if (load == image_start) break; if (image_len <= unc_len) @@ -537,22 +538,23 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, }
image_len = ret; - break; } #endif /* CONFIG_ZSTD */ #endif - default: + } + if (ret == -ENOSYS) { printf("Unimplemented compression type %d\n", comp); - return -ENOSYS; + return ret; } + if (ret) + return ret;
*load_end = load + image_len;
- return ret; + return 0; }
- #ifndef USE_HOSTCC #if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) /**
The zstd implementation prints the error in image_decomp() which is incorrect and does not match other algorithms. Drop this and let the caller report the error.
common/image.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/common/image.c b/common/image.c index 6c38211efce..bd71bf7ec29 100644 --- a/common/image.c +++ b/common/image.c @@ -532,12 +532,10 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, abuf_init_set(&in, image_buf, image_len); abuf_init_set(&in, load_buf, unc_len); ret = zstd_decompress(&in, &out); - if (ret < 0) { - printf("ZSTD decompression failed\n"); - return ret; + if (ret >= 0) { + image_len = ret; + ret = 0; } - - image_len = ret; break; } #endif /* CONFIG_ZSTD */
The gzip API uses the u64 type in it, which is not available in the host build. This makes it impossible to include the header file.
We could make this type available, but it seems unnecessary. Limiting the compression size to that of the 'unsigned long' type seems good enough. On 32-bit machines the limit then becomes 4GB, which likely exceeds available RAM anyway, therefore it should be sufficient. On 64-bit machines this is effectively u64 anyway.
Update the header file and implementation to use 'ulong' instead of 'u64'.
Add a definition of u32 for the cases that seem to need exactly that length. This should be safe enough.
include/compiler.h | 3 +++ include/gzip.h | 8 ++++---- lib/gunzip.c | 28 ++++++++++++++-------------- 3 files changed, 21 insertions(+), 18 deletions(-)
diff --git a/include/compiler.h b/include/compiler.h index ec0d600e71a..f111c735984 100644 --- a/include/compiler.h +++ b/include/compiler.h @@ -68,6 +68,9 @@ typedef uint32_t __u32; typedef unsigned int uint; typedef unsigned long ulong;
+/* Define these on the host so we can build some target code */ +typedef __u32 u32; + #define uswap_16(x) \ ((((x) & 0xff00) >> 8) | \ (((x) & 0x00ff) << 8)) diff --git a/include/gzip.h b/include/gzip.h index 783acbb60d2..cb4db3d70fe 100644 --- a/include/gzip.h +++ b/include/gzip.h @@ -54,11 +54,11 @@ int zunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp, * gzwrite_progress_finish called at end of loop to * indicate success (retcode=0) or failure */ -void gzwrite_progress_init(u64 expected_size); +void gzwrite_progress_init(ulong expected_size);
-void gzwrite_progress(int iteration, u64 bytes_written, u64 total_bytes); +void gzwrite_progress(int iteration, ulong bytes_written, ulong total_bytes);
-void gzwrite_progress_finish(int retcode, u64 totalwritten, u64 totalsize, +void gzwrite_progress_finish(int retcode, ulong totalwritten, ulong totalsize, u32 expected_crc, u32 calculated_crc);
/** @@ -74,7 +74,7 @@ void gzwrite_progress_finish(int retcode, u64 totalwritten, u64 totalsize, * @return 0 if OK, -1 on error */ int gzwrite(unsigned char *src, int len, struct blk_desc *dev, ulong szwritebuf, - u64 startoffs, u64 szexpected); + ulong startoffs, ulong szexpected);
/** * gzip()- Compress data into a buffer using the gzip algorithm diff --git a/lib/gunzip.c b/lib/gunzip.c index bee3b9261f3..a8e498d98d8 100644 --- a/lib/gunzip.c +++ b/lib/gunzip.c @@ -84,32 +84,32 @@ int gunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp)
#ifdef CONFIG_CMD_UNZIP __weak -void gzwrite_progress_init(u64 expectedsize) +void gzwrite_progress_init(ulong expectedsize) { putc('\n'); }
__weak void gzwrite_progress(int iteration, - u64 bytes_written, - u64 total_bytes) + ulong bytes_written, + ulong total_bytes) { if (0 == (iteration & 3)) - printf("%llu/%llu\r", bytes_written, total_bytes); + printf("%lu/%lu\r", bytes_written, total_bytes); }
__weak void gzwrite_progress_finish(int returnval, - u64 bytes_written, - u64 total_bytes, + ulong bytes_written, + ulong total_bytes, u32 expected_crc, u32 calculated_crc) { if (0 == returnval) { - printf("\n\t%llu bytes, crc 0x%08x\n", + printf("\n\t%lu bytes, crc 0x%08x\n", total_bytes, calculated_crc); } else { - printf("\n\tuncompressed %llu of %llu\n" + printf("\n\tuncompressed %lu of %lu\n" "\tcrcs == 0x%08x/0x%08x\n", bytes_written, total_bytes, expected_crc, calculated_crc); @@ -119,15 +119,15 @@ void gzwrite_progress_finish(int returnval, int gzwrite(unsigned char *src, int len, struct blk_desc *dev, unsigned long szwritebuf, - u64 startoffs, - u64 szexpected) + ulong startoffs, + ulong szexpected) { int i, flags; z_stream s; int r = 0; unsigned char *writebuf; unsigned crc = 0; - u64 totalfilled = 0; + ulong totalfilled = 0; lbaint_t blksperbuf, outblock; u32 expected_crc; u32 payload_size; @@ -142,7 +142,7 @@ int gzwrite(unsigned char *src, int len, }
if (startoffs & (dev->blksz-1)) { - printf("%s: start offset %llu not a multiple of %lu\n", + printf("%s: start offset %lu not a multiple of %lu\n", __func__, startoffs, dev->blksz); return -1; } @@ -182,12 +182,12 @@ int gzwrite(unsigned char *src, int len, if (szexpected == 0) { szexpected = le32_to_cpu(szuncompressed); } else if (szuncompressed != (u32)szexpected) { - printf("size of %llx doesn't match trailer low bits %x\n", + printf("size of %lx doesn't match trailer low bits %x\n", szexpected, szuncompressed); return -1; } if (lldiv(szexpected, dev->blksz) > (dev->lba - outblock)) { - printf("%s: uncompressed size %llu exceeds device size\n", + printf("%s: uncompressed size %lu exceeds device size\n", __func__, szexpected); return -1; }
Adjust this function so that preprocessor macros are not needed. With this, the host build uses more of the same header files as the target build.
Rather than definining CONFIG_SYS_MALLOC_LEN, add a CONSERVE_MEMORY define, since that is the purpose of the value.
This appears to have no impact on code size from a spot check of a few boards (snow, firefly-rk3288, boston32r2el, m53menlo).
common/image.c | 145 ++++++++++++++++++-------------------- configs/sandbox_defconfig | 1 + 2 files changed, 69 insertions(+), 77 deletions(-)
diff --git a/common/image.c b/common/image.c index bd71bf7ec29..a41e8067b11 100644 --- a/common/image.c +++ b/common/image.c @@ -22,12 +22,9 @@ #include <status_led.h> #endif
-#include <abuf.h> #include <rtc.h>
-#include <gzip.h> #include <image.h> -#include <lz4.h> #include <mapmem.h>
#if IMAGE_ENABLE_FIT || IMAGE_ENABLE_OF_LIBFDT @@ -43,13 +40,6 @@ #include <linux/errno.h> #include <asm/io.h>
-#include <bzlib.h> -#include <linux/lzo.h> -#include <lzma/LzmaTypes.h> -#include <lzma/LzmaDec.h> -#include <lzma/LzmaTools.h> -#include <linux/zstd.h> - #ifdef CONFIG_CMD_BDI extern int do_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); @@ -61,7 +51,15 @@ DECLARE_GLOBAL_DATA_PTR; static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, int verify); #endif + +/* Set this if we have less than 4 MB of malloc() space */ +#if CONFIG_SYS_MALLOC_LEN < (4096 * 1024) +#define CONSERVE_MEMORY true #else +#define CONSERVE_MEMORY false +#endif + +#else /* USE_HOSTCC */ #include "mkimage.h" #include <u-boot/md5.h> #include <time.h> @@ -70,10 +68,23 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, #ifndef __maybe_unused # define __maybe_unused /* unimplemented */ #endif + +#define CONSERVE_MEMORY false + #endif /* !USE_HOSTCC*/
-#include <u-boot/crc.h> +#include <abuf.h> +#include <bzlib.h> +#include <gzip.h> +#include <lz4.h> #include <imximage.h> +#include <linux/lzo.h> +#include <linux/zstd.h> +#include <linux/kconfig.h> +#include <lzma/LzmaTypes.h> +#include <lzma/LzmaDec.h> +#include <lzma/LzmaTools.h> +#include <u-boot/crc.h>
#ifndef CONFIG_SYS_BARGSIZE #define CONFIG_SYS_BARGSIZE 512 @@ -464,83 +475,63 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, else ret = -ENOSPC; break; -#ifndef USE_HOSTCC -#if CONFIG_IS_ENABLED(GZIP) - case IH_COMP_GZIP: { - ret = gunzip(load_buf, unc_len, image_buf, &image_len); + case IH_COMP_GZIP: + if (!host_build() && CONFIG_IS_ENABLED(GZIP)) + ret = gunzip(load_buf, unc_len, image_buf, &image_len); break; - } -#endif /* CONFIG_GZIP */ -#endif -#ifndef USE_HOSTCC -#if CONFIG_IS_ENABLED(BZIP2) - case IH_COMP_BZIP2: { - uint size = unc_len; + case IH_COMP_BZIP2: + if (!host_build() && CONFIG_IS_ENABLED(BZIP2)) { + uint size = unc_len;
- /* - * If we've got less than 4 MB of malloc() space, - * use slower decompression algorithm which requires - * at most 2300 KB of memory. - */ - ret = BZ2_bzBuffToBuffDecompress(load_buf, &size, - image_buf, image_len, - CONFIG_SYS_MALLOC_LEN < (4096 * 1024), 0); - image_len = size; + /* + * If we've got less than 4 MB of malloc() space, + * use slower decompression algorithm which requires + * at most 2300 KB of memory. + */ + ret = BZ2_bzBuffToBuffDecompress(load_buf, &size, + image_buf, image_len, CONSERVE_MEMORY, 0); + image_len = size; + } break; - } -#endif /* CONFIG_BZIP2 */ -#endif -#ifndef USE_HOSTCC -#if CONFIG_IS_ENABLED(LZMA) - case IH_COMP_LZMA: { - SizeT lzma_len = unc_len; + case IH_COMP_LZMA: + if (!host_build() && CONFIG_IS_ENABLED(LZMA)) { + SizeT lzma_len = unc_len;
- ret = lzmaBuffToBuffDecompress(load_buf, &lzma_len, - image_buf, image_len); - image_len = lzma_len; + ret = lzmaBuffToBuffDecompress(load_buf, &lzma_len, + image_buf, image_len); + image_len = lzma_len; + } break; - } -#endif /* CONFIG_LZMA */ -#endif -#ifndef USE_HOSTCC -#if CONFIG_IS_ENABLED(LZO) - case IH_COMP_LZO: { - size_t size = unc_len; + case IH_COMP_LZO: + if (!host_build() && CONFIG_IS_ENABLED(LZO)) { + size_t size = unc_len;
- ret = lzop_decompress(image_buf, image_len, load_buf, &size); - image_len = size; + ret = lzop_decompress(image_buf, image_len, load_buf, &size); + image_len = size; + } break; - } -#endif /* CONFIG_LZO */ -#endif -#ifndef USE_HOSTCC -#if CONFIG_IS_ENABLED(LZ4) - case IH_COMP_LZ4: { - size_t size = unc_len; + case IH_COMP_LZ4: + if (!host_build() && CONFIG_IS_ENABLED(LZ4)) { + size_t size = unc_len;
- ret = ulz4fn(image_buf, image_len, load_buf, &size); - image_len = size; + ret = ulz4fn(image_buf, image_len, load_buf, &size); + image_len = size; + } break; - } -#endif /* CONFIG_LZ4 */ -#endif -#ifndef USE_HOSTCC -#if CONFIG_IS_ENABLED(ZSTD) - case IH_COMP_ZSTD: { - struct abuf in, out; - - abuf_init_set(&in, image_buf, image_len); - abuf_init_set(&in, load_buf, unc_len); - ret = zstd_decompress(&in, &out); - if (ret >= 0) { - image_len = ret; - ret = 0; + case IH_COMP_ZSTD: + if (!host_build() && CONFIG_IS_ENABLED(ZSTD)) { + struct abuf in, out; + + abuf_init_set(&in, image_buf, image_len); + abuf_init_set(&in, load_buf, unc_len); + ret = zstd_decompress(&in, &out); + if (ret >= 0) { + image_len = ret; + ret = 0; + } } break; } -#endif /* CONFIG_ZSTD */ -#endif - } if (ret == -ENOSYS) { printf("Unimplemented compression type %d\n", comp); return ret; @@ -958,7 +949,7 @@ int get_table_entry_id(const table_entry_t *table, const table_entry_t *t;
for (t = table; t->id >= 0; ++t) { -#ifdef CONFIG_NEEDS_MANUAL_RELOC +#if !defined(USE_HOSTCC) && defined(CONFIG_NEEDS_MANUAL_RELOC) if (t->sname && strcasecmp(t->sname + gd->reloc_off, name) == 0) #else if (t->sname && strcasecmp(t->sname, name) == 0) diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 00befc8b407..33446322a46 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -46,6 +46,7 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_MEM_SEARCH=y CONFIG_CMD_MX_CYCLIC=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y CONFIG_CMD_BIND=y CONFIG_CMD_DEMO=y CONFIG_CMD_GPIO=y
To avoid a large #ifdef in the image.c file, move the affected code into a separate file.
Avoid any style fix-ups for easier review. Those are in the next patch.
common/Makefile | 2 +- common/image-board.c | 925 +++++++++++++++++++++++++++++++++++++++++++ common/image.c | 925 +------------------------------------------ 3 files changed, 928 insertions(+), 924 deletions(-) create mode 100644 common/image-board.c
diff --git a/common/Makefile b/common/Makefile index 829ea5fb426..b71b0496022 100644 --- a/common/Makefile +++ b/common/Makefile @@ -104,7 +104,7 @@ obj-y += malloc_simple.o endif endif
-obj-y += image.o +obj-y += image.o image-board.o obj-$(CONFIG_ANDROID_AB) += android_ab.o obj-$(CONFIG_ANDROID_BOOT_IMAGE) += image-android.o image-android-dt.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += image-fdt.o diff --git a/common/image-board.c b/common/image-board.c new file mode 100644 index 00000000000..0c4e32e14e4 --- /dev/null +++ b/common/image-board.c @@ -0,0 +1,925 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Image code used by boards (and not host tools) + * + * (C) Copyright 2008 Semihalf + * + * (C) Copyright 2000-2006 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + */ + +#include <common.h> +#include <bootstage.h> +#include <cpu_func.h> +#include <env.h> +#include <fpga.h> +#include <image.h> +#include <mapmem.h> +#include <watchdog.h> +#include <asm/cache.h> +#include <asm/global_data.h> + +#ifndef CONFIG_SYS_BARGSIZE +#define CONFIG_SYS_BARGSIZE 512 +#endif + +DECLARE_GLOBAL_DATA_PTR; + +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) +/** + * image_get_ramdisk - get and verify ramdisk image + * @rd_addr: ramdisk image start address + * @arch: expected ramdisk architecture + * @verify: checksum verification flag + * + * image_get_ramdisk() returns a pointer to the verified ramdisk image + * header. Routine receives image start address and expected architecture + * flag. Verification done covers data and header integrity and os/type/arch + * fields checking. + * + * returns: + * pointer to a ramdisk image header, if image was found and valid + * otherwise, return NULL + */ +static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, + int verify) +{ + const image_header_t *rd_hdr = (const image_header_t *)rd_addr; + + if (!image_check_magic(rd_hdr)) { + puts("Bad Magic Number\n"); + bootstage_error(BOOTSTAGE_ID_RD_MAGIC); + return NULL; + } + + if (!image_check_hcrc(rd_hdr)) { + puts("Bad Header Checksum\n"); + bootstage_error(BOOTSTAGE_ID_RD_HDR_CHECKSUM); + return NULL; + } + + bootstage_mark(BOOTSTAGE_ID_RD_MAGIC); + image_print_contents(rd_hdr); + + if (verify) { + puts(" Verifying Checksum ... "); + if (!image_check_dcrc(rd_hdr)) { + puts("Bad Data CRC\n"); + bootstage_error(BOOTSTAGE_ID_RD_CHECKSUM); + return NULL; + } + puts("OK\n"); + } + + bootstage_mark(BOOTSTAGE_ID_RD_HDR_CHECKSUM); + + if (!image_check_os(rd_hdr, IH_OS_LINUX) || + !image_check_arch(rd_hdr, arch) || + !image_check_type(rd_hdr, IH_TYPE_RAMDISK)) { + printf("No Linux %s Ramdisk Image\n", + genimg_get_arch_name(arch)); + bootstage_error(BOOTSTAGE_ID_RAMDISK); + return NULL; + } + + return rd_hdr; +} +#endif + +/*****************************************************************************/ +/* Shared dual-format routines */ +/*****************************************************************************/ +ulong image_load_addr = CONFIG_SYS_LOAD_ADDR; /* Default Load Address */ +ulong image_save_addr; /* Default Save Address */ +ulong image_save_size; /* Default Save Size (in bytes) */ + +static int on_loadaddr(const char *name, const char *value, enum env_op op, + int flags) +{ + switch (op) { + case env_op_create: + case env_op_overwrite: + image_load_addr = simple_strtoul(value, NULL, 16); + break; + default: + break; + } + + return 0; +} +U_BOOT_ENV_CALLBACK(loadaddr, on_loadaddr); + +ulong env_get_bootm_low(void) +{ + char *s = env_get("bootm_low"); + if (s) { + ulong tmp = simple_strtoul(s, NULL, 16); + return tmp; + } + +#if defined(CONFIG_SYS_SDRAM_BASE) + return CONFIG_SYS_SDRAM_BASE; +#elif defined(CONFIG_ARM) || defined(CONFIG_MICROBLAZE) + return gd->bd->bi_dram[0].start; +#else + return 0; +#endif +} + +phys_size_t env_get_bootm_size(void) +{ + phys_size_t tmp, size; + phys_addr_t start; + char *s = env_get("bootm_size"); + if (s) { + tmp = (phys_size_t)simple_strtoull(s, NULL, 16); + return tmp; + } + + start = gd->ram_base; + size = gd->ram_size; + + if (start + size > gd->ram_top) + size = gd->ram_top - start; + + s = env_get("bootm_low"); + if (s) + tmp = (phys_size_t)simple_strtoull(s, NULL, 16); + else + tmp = start; + + return size - (tmp - start); +} + +phys_size_t env_get_bootm_mapsize(void) +{ + phys_size_t tmp; + char *s = env_get("bootm_mapsize"); + if (s) { + tmp = (phys_size_t)simple_strtoull(s, NULL, 16); + return tmp; + } + +#if defined(CONFIG_SYS_BOOTMAPSZ) + return CONFIG_SYS_BOOTMAPSZ; +#else + return env_get_bootm_size(); +#endif +} + +void memmove_wd(void *to, void *from, size_t len, ulong chunksz) +{ + if (to == from) + return; + +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + if (to > from) { + from += len; + to += len; + } + while (len > 0) { + size_t tail = (len > chunksz) ? chunksz : len; + WATCHDOG_RESET(); + if (to > from) { + to -= tail; + from -= tail; + } + memmove(to, from, tail); + if (to < from) { + to += tail; + from += tail; + } + len -= tail; + } +#else /* !(CONFIG_HW_WATCHDOG || CONFIG_WATCHDOG) */ + memmove(to, from, len); +#endif /* CONFIG_HW_WATCHDOG || CONFIG_WATCHDOG */ +} + +/** + * genimg_get_kernel_addr_fit - get the real kernel address and return 2 + * FIT strings + * @img_addr: a string might contain real image address + * @fit_uname_config: double pointer to a char, will hold pointer to a + * configuration unit name + * @fit_uname_kernel: double pointer to a char, will hold pointer to a subimage + * name + * + * genimg_get_kernel_addr_fit get the real kernel start address from a string + * which is normally the first argv of bootm/bootz + * + * returns: + * kernel start address + */ +ulong genimg_get_kernel_addr_fit(char * const img_addr, + const char **fit_uname_config, + const char **fit_uname_kernel) +{ + ulong kernel_addr; + + /* find out kernel image address */ + if (!img_addr) { + kernel_addr = image_load_addr; + debug("* kernel: default image load address = 0x%08lx\n", + image_load_addr); +#if CONFIG_IS_ENABLED(FIT) + } else if (fit_parse_conf(img_addr, image_load_addr, &kernel_addr, + fit_uname_config)) { + debug("* kernel: config '%s' from image at 0x%08lx\n", + *fit_uname_config, kernel_addr); + } else if (fit_parse_subimage(img_addr, image_load_addr, &kernel_addr, + fit_uname_kernel)) { + debug("* kernel: subimage '%s' from image at 0x%08lx\n", + *fit_uname_kernel, kernel_addr); +#endif + } else { + kernel_addr = simple_strtoul(img_addr, NULL, 16); + debug("* kernel: cmdline image address = 0x%08lx\n", + kernel_addr); + } + + return kernel_addr; +} + +/** + * genimg_get_kernel_addr() is the simple version of + * genimg_get_kernel_addr_fit(). It ignores those return FIT strings + */ +ulong genimg_get_kernel_addr(char * const img_addr) +{ + const char *fit_uname_config = NULL; + const char *fit_uname_kernel = NULL; + + return genimg_get_kernel_addr_fit(img_addr, &fit_uname_config, + &fit_uname_kernel); +} + +/** + * genimg_get_format - get image format type + * @img_addr: image start address + * + * genimg_get_format() checks whether provided address points to a valid + * legacy or FIT image. + * + * New uImage format and FDT blob are based on a libfdt. FDT blob + * may be passed directly or embedded in a FIT image. In both situations + * genimg_get_format() must be able to dectect libfdt header. + * + * returns: + * image format type or IMAGE_FORMAT_INVALID if no image is present + */ +int genimg_get_format(const void *img_addr) +{ +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) + const image_header_t *hdr; + + hdr = (const image_header_t *)img_addr; + if (image_check_magic(hdr)) + return IMAGE_FORMAT_LEGACY; +#endif +#if IMAGE_ENABLE_FIT || IMAGE_ENABLE_OF_LIBFDT + if (fdt_check_header(img_addr) == 0) + return IMAGE_FORMAT_FIT; +#endif +#ifdef CONFIG_ANDROID_BOOT_IMAGE + if (android_image_check_header(img_addr) == 0) + return IMAGE_FORMAT_ANDROID; +#endif + + return IMAGE_FORMAT_INVALID; +} + +/** + * fit_has_config - check if there is a valid FIT configuration + * @images: pointer to the bootm command headers structure + * + * fit_has_config() checks if there is a FIT configuration in use + * (if FTI support is present). + * + * returns: + * 0, no FIT support or no configuration found + * 1, configuration found + */ +int genimg_has_config(bootm_headers_t *images) +{ +#if IMAGE_ENABLE_FIT + if (images->fit_uname_cfg) + return 1; +#endif + return 0; +} + +/** + * boot_get_ramdisk - main ramdisk handling routine + * @argc: command argument count + * @argv: command argument list + * @images: pointer to the bootm images structure + * @arch: expected ramdisk architecture + * @rd_start: pointer to a ulong variable, will hold ramdisk start address + * @rd_end: pointer to a ulong variable, will hold ramdisk end + * + * boot_get_ramdisk() is responsible for finding a valid ramdisk image. + * Curently supported are the following ramdisk sources: + * - multicomponent kernel/ramdisk image, + * - commandline provided address of decicated ramdisk image. + * + * returns: + * 0, if ramdisk image was found and valid, or skiped + * rd_start and rd_end are set to ramdisk start/end addresses if + * ramdisk image is found and valid + * + * 1, if ramdisk image is found but corrupted, or invalid + * rd_start and rd_end are set to 0 if no ramdisk exists + */ +int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, + uint8_t arch, ulong *rd_start, ulong *rd_end) +{ + ulong rd_addr, rd_load; + ulong rd_data, rd_len; +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) + const image_header_t *rd_hdr; +#endif + void *buf; +#ifdef CONFIG_SUPPORT_RAW_INITRD + char *end; +#endif +#if IMAGE_ENABLE_FIT + const char *fit_uname_config = images->fit_uname_cfg; + const char *fit_uname_ramdisk = NULL; + ulong default_addr; + int rd_noffset; +#endif + const char *select = NULL; + + *rd_start = 0; + *rd_end = 0; + +#ifdef CONFIG_ANDROID_BOOT_IMAGE + /* + * Look for an Android boot image. + */ + buf = map_sysmem(images->os.start, 0); + if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) + select = (argc == 0) ? env_get("loadaddr") : argv[0]; +#endif + + if (argc >= 2) + select = argv[1]; + + /* + * Look for a '-' which indicates to ignore the + * ramdisk argument + */ + if (select && strcmp(select, "-") == 0) { + debug("## Skipping init Ramdisk\n"); + rd_len = rd_data = 0; + } else if (select || genimg_has_config(images)) { +#if IMAGE_ENABLE_FIT + if (select) { + /* + * If the init ramdisk comes from the FIT image and + * the FIT image address is omitted in the command + * line argument, try to use os FIT image address or + * default load address. + */ + if (images->fit_uname_os) + default_addr = (ulong)images->fit_hdr_os; + else + default_addr = image_load_addr; + + if (fit_parse_conf(select, default_addr, + &rd_addr, &fit_uname_config)) { + debug("* ramdisk: config '%s' from image at " + "0x%08lx\n", + fit_uname_config, rd_addr); + } else if (fit_parse_subimage(select, default_addr, + &rd_addr, &fit_uname_ramdisk)) { + debug("* ramdisk: subimage '%s' from image at " + "0x%08lx\n", + fit_uname_ramdisk, rd_addr); + } else +#endif + { + rd_addr = simple_strtoul(select, NULL, 16); + debug("* ramdisk: cmdline image address = " + "0x%08lx\n", + rd_addr); + } +#if IMAGE_ENABLE_FIT + } else { + /* use FIT configuration provided in first bootm + * command argument. If the property is not defined, + * quit silently. + */ + rd_addr = map_to_sysmem(images->fit_hdr_os); + rd_noffset = fit_get_node_from_config(images, + FIT_RAMDISK_PROP, rd_addr); + if (rd_noffset == -ENOENT) + return 0; + else if (rd_noffset < 0) + return 1; + } +#endif + + /* + * Check if there is an initrd image at the + * address provided in the second bootm argument + * check image type, for FIT images get FIT node. + */ + buf = map_sysmem(rd_addr, 0); + switch (genimg_get_format(buf)) { +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) + case IMAGE_FORMAT_LEGACY: + printf("## Loading init Ramdisk from Legacy " + "Image at %08lx ...\n", rd_addr); + + bootstage_mark(BOOTSTAGE_ID_CHECK_RAMDISK); + rd_hdr = image_get_ramdisk(rd_addr, arch, + images->verify); + + if (rd_hdr == NULL) + return 1; + + rd_data = image_get_data(rd_hdr); + rd_len = image_get_data_size(rd_hdr); + rd_load = image_get_load(rd_hdr); + break; +#endif +#if IMAGE_ENABLE_FIT + case IMAGE_FORMAT_FIT: + rd_noffset = fit_image_load(images, + rd_addr, &fit_uname_ramdisk, + &fit_uname_config, arch, + IH_TYPE_RAMDISK, + BOOTSTAGE_ID_FIT_RD_START, + FIT_LOAD_OPTIONAL_NON_ZERO, + &rd_data, &rd_len); + if (rd_noffset < 0) + return 1; + + images->fit_hdr_rd = map_sysmem(rd_addr, 0); + images->fit_uname_rd = fit_uname_ramdisk; + images->fit_noffset_rd = rd_noffset; + break; +#endif +#ifdef CONFIG_ANDROID_BOOT_IMAGE + case IMAGE_FORMAT_ANDROID: + android_image_get_ramdisk((void *)images->os.start, + &rd_data, &rd_len); + break; +#endif + default: +#ifdef CONFIG_SUPPORT_RAW_INITRD + end = NULL; + if (select) + end = strchr(select, ':'); + if (end) { + rd_len = simple_strtoul(++end, NULL, 16); + rd_data = rd_addr; + } else +#endif + { + puts("Wrong Ramdisk Image Format\n"); + rd_data = rd_len = rd_load = 0; + return 1; + } + } + } else if (images->legacy_hdr_valid && + image_check_type(&images->legacy_hdr_os_copy, + IH_TYPE_MULTI)) { + + /* + * Now check if we have a legacy mult-component image, + * get second entry data start address and len. + */ + bootstage_mark(BOOTSTAGE_ID_RAMDISK); + printf("## Loading init Ramdisk from multi component " + "Legacy Image at %08lx ...\n", + (ulong)images->legacy_hdr_os); + + image_multi_getimg(images->legacy_hdr_os, 1, &rd_data, &rd_len); + } else { + /* + * no initrd image + */ + bootstage_mark(BOOTSTAGE_ID_NO_RAMDISK); + rd_len = rd_data = 0; + } + + if (!rd_data) { + debug("## No init Ramdisk\n"); + } else { + *rd_start = rd_data; + *rd_end = rd_data + rd_len; + } + debug(" ramdisk start = 0x%08lx, ramdisk end = 0x%08lx\n", + *rd_start, *rd_end); + + return 0; +} + +#ifdef CONFIG_SYS_BOOT_RAMDISK_HIGH +/** + * boot_ramdisk_high - relocate init ramdisk + * @lmb: pointer to lmb handle, will be used for memory mgmt + * @rd_data: ramdisk data start address + * @rd_len: ramdisk data length + * @initrd_start: pointer to a ulong variable, will hold final init ramdisk + * start address (after possible relocation) + * @initrd_end: pointer to a ulong variable, will hold final init ramdisk + * end address (after possible relocation) + * + * boot_ramdisk_high() takes a relocation hint from "initrd_high" environment + * variable and if requested ramdisk data is moved to a specified location. + * + * Initrd_start and initrd_end are set to final (after relocation) ramdisk + * start/end addresses if ramdisk image start and len were provided, + * otherwise set initrd_start and initrd_end set to zeros. + * + * returns: + * 0 - success + * -1 - failure + */ +int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, + ulong *initrd_start, ulong *initrd_end) +{ + char *s; + ulong initrd_high; + int initrd_copy_to_ram = 1; + + s = env_get("initrd_high"); + if (s) { + /* a value of "no" or a similar string will act like 0, + * turning the "load high" feature off. This is intentional. + */ + initrd_high = simple_strtoul(s, NULL, 16); + if (initrd_high == ~0) + initrd_copy_to_ram = 0; + } else { + initrd_high = env_get_bootm_mapsize() + env_get_bootm_low(); + } + + + debug("## initrd_high = 0x%08lx, copy_to_ram = %d\n", + initrd_high, initrd_copy_to_ram); + + if (rd_data) { + if (!initrd_copy_to_ram) { /* zero-copy ramdisk support */ + debug(" in-place initrd\n"); + *initrd_start = rd_data; + *initrd_end = rd_data + rd_len; + lmb_reserve(lmb, rd_data, rd_len); + } else { + if (initrd_high) + *initrd_start = (ulong)lmb_alloc_base(lmb, + rd_len, 0x1000, initrd_high); + else + *initrd_start = (ulong)lmb_alloc(lmb, rd_len, + 0x1000); + + if (*initrd_start == 0) { + puts("ramdisk - allocation error\n"); + goto error; + } + bootstage_mark(BOOTSTAGE_ID_COPY_RAMDISK); + + *initrd_end = *initrd_start + rd_len; + printf(" Loading Ramdisk to %08lx, end %08lx ... ", + *initrd_start, *initrd_end); + + memmove_wd((void *)*initrd_start, + (void *)rd_data, rd_len, CHUNKSZ); + +#ifdef CONFIG_MP + /* + * Ensure the image is flushed to memory to handle + * AMP boot scenarios in which we might not be + * HW cache coherent + */ + flush_cache((unsigned long)*initrd_start, + ALIGN(rd_len, ARCH_DMA_MINALIGN)); +#endif + puts("OK\n"); + } + } else { + *initrd_start = 0; + *initrd_end = 0; + } + debug(" ramdisk load start = 0x%08lx, ramdisk load end = 0x%08lx\n", + *initrd_start, *initrd_end); + + return 0; + +error: + return -1; +} +#endif /* CONFIG_SYS_BOOT_RAMDISK_HIGH */ + +int boot_get_setup(bootm_headers_t *images, uint8_t arch, + ulong *setup_start, ulong *setup_len) +{ +#if IMAGE_ENABLE_FIT + return boot_get_setup_fit(images, arch, setup_start, setup_len); +#else + return -ENOENT; +#endif +} + +#if IMAGE_ENABLE_FIT +#if defined(CONFIG_FPGA) +int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, + uint8_t arch, const ulong *ld_start, ulong * const ld_len) +{ + ulong tmp_img_addr, img_data, img_len; + void *buf; + int conf_noffset; + int fit_img_result; + const char *uname, *name; + int err; + int devnum = 0; /* TODO support multi fpga platforms */ + + /* Check to see if the images struct has a FIT configuration */ + if (!genimg_has_config(images)) { + debug("## FIT configuration was not specified\n"); + return 0; + } + + /* + * Obtain the os FIT header from the images struct + */ + tmp_img_addr = map_to_sysmem(images->fit_hdr_os); + buf = map_sysmem(tmp_img_addr, 0); + /* + * Check image type. For FIT images get FIT node + * and attempt to locate a generic binary. + */ + switch (genimg_get_format(buf)) { + case IMAGE_FORMAT_FIT: + conf_noffset = fit_conf_get_node(buf, images->fit_uname_cfg); + + uname = fdt_stringlist_get(buf, conf_noffset, FIT_FPGA_PROP, 0, + NULL); + if (!uname) { + debug("## FPGA image is not specified\n"); + return 0; + } + fit_img_result = fit_image_load(images, + tmp_img_addr, + (const char **)&uname, + &(images->fit_uname_cfg), + arch, + IH_TYPE_FPGA, + BOOTSTAGE_ID_FPGA_INIT, + FIT_LOAD_OPTIONAL_NON_ZERO, + &img_data, &img_len); + + debug("FPGA image (%s) loaded to 0x%lx/size 0x%lx\n", + uname, img_data, img_len); + + if (fit_img_result < 0) { + /* Something went wrong! */ + return fit_img_result; + } + + if (!fpga_is_partial_data(devnum, img_len)) { + name = "full"; + err = fpga_loadbitstream(devnum, (char *)img_data, + img_len, BIT_FULL); + if (err) + err = fpga_load(devnum, (const void *)img_data, + img_len, BIT_FULL); + } else { + name = "partial"; + err = fpga_loadbitstream(devnum, (char *)img_data, + img_len, BIT_PARTIAL); + if (err) + err = fpga_load(devnum, (const void *)img_data, + img_len, BIT_PARTIAL); + } + + if (err) + return err; + + printf(" Programming %s bitstream... OK\n", name); + break; + default: + printf("The given image format is not supported (corrupt?)\n"); + return 1; + } + + return 0; +} +#endif + +static void fit_loadable_process(uint8_t img_type, + ulong img_data, + ulong img_len) +{ + int i; + const unsigned int count = + ll_entry_count(struct fit_loadable_tbl, fit_loadable); + struct fit_loadable_tbl *fit_loadable_handler = + ll_entry_start(struct fit_loadable_tbl, fit_loadable); + /* For each loadable handler */ + for (i = 0; i < count; i++, fit_loadable_handler++) + /* matching this type */ + if (fit_loadable_handler->type == img_type) + /* call that handler with this image data */ + fit_loadable_handler->handler(img_data, img_len); +} + +int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images, + uint8_t arch, const ulong *ld_start, ulong * const ld_len) +{ + /* + * These variables are used to hold the current image location + * in system memory. + */ + ulong tmp_img_addr; + /* + * These two variables are requirements for fit_image_load, but + * their values are not used + */ + ulong img_data, img_len; + void *buf; + int loadables_index; + int conf_noffset; + int fit_img_result; + const char *uname; + uint8_t img_type; + + /* Check to see if the images struct has a FIT configuration */ + if (!genimg_has_config(images)) { + debug("## FIT configuration was not specified\n"); + return 0; + } + + /* + * Obtain the os FIT header from the images struct + */ + tmp_img_addr = map_to_sysmem(images->fit_hdr_os); + buf = map_sysmem(tmp_img_addr, 0); + /* + * Check image type. For FIT images get FIT node + * and attempt to locate a generic binary. + */ + switch (genimg_get_format(buf)) { + case IMAGE_FORMAT_FIT: + conf_noffset = fit_conf_get_node(buf, images->fit_uname_cfg); + + for (loadables_index = 0; + uname = fdt_stringlist_get(buf, conf_noffset, + FIT_LOADABLE_PROP, loadables_index, + NULL), uname; + loadables_index++) + { + fit_img_result = fit_image_load(images, + tmp_img_addr, + &uname, + &(images->fit_uname_cfg), arch, + IH_TYPE_LOADABLE, + BOOTSTAGE_ID_FIT_LOADABLE_START, + FIT_LOAD_OPTIONAL_NON_ZERO, + &img_data, &img_len); + if (fit_img_result < 0) { + /* Something went wrong! */ + return fit_img_result; + } + + fit_img_result = fit_image_get_node(buf, uname); + if (fit_img_result < 0) { + /* Something went wrong! */ + return fit_img_result; + } + fit_img_result = fit_image_get_type(buf, + fit_img_result, + &img_type); + if (fit_img_result < 0) { + /* Something went wrong! */ + return fit_img_result; + } + + fit_loadable_process(img_type, img_data, img_len); + } + break; + default: + printf("The given image format is not supported (corrupt?)\n"); + return 1; + } + + return 0; +} +#endif + +#ifdef CONFIG_SYS_BOOT_GET_CMDLINE +/** + * boot_get_cmdline - allocate and initialize kernel cmdline + * @lmb: pointer to lmb handle, will be used for memory mgmt + * @cmd_start: pointer to a ulong variable, will hold cmdline start + * @cmd_end: pointer to a ulong variable, will hold cmdline end + * + * boot_get_cmdline() allocates space for kernel command line below + * BOOTMAPSZ + env_get_bootm_low() address. If "bootargs" U-Boot environment + * variable is present its contents is copied to allocated kernel + * command line. + * + * returns: + * 0 - success + * -1 - failure + */ +int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end) +{ + char *cmdline; + char *s; + + cmdline = (char *)(ulong)lmb_alloc_base(lmb, CONFIG_SYS_BARGSIZE, 0xf, + env_get_bootm_mapsize() + env_get_bootm_low()); + + if (cmdline == NULL) + return -1; + + s = env_get("bootargs"); + if (!s) + s = ""; + + strcpy(cmdline, s); + + *cmd_start = (ulong) & cmdline[0]; + *cmd_end = *cmd_start + strlen(cmdline); + + debug("## cmdline at 0x%08lx ... 0x%08lx\n", *cmd_start, *cmd_end); + + return 0; +} +#endif /* CONFIG_SYS_BOOT_GET_CMDLINE */ + +#ifdef CONFIG_SYS_BOOT_GET_KBD +/** + * boot_get_kbd - allocate and initialize kernel copy of board info + * @lmb: pointer to lmb handle, will be used for memory mgmt + * @kbd: double pointer to board info data + * + * boot_get_kbd() allocates space for kernel copy of board info data below + * BOOTMAPSZ + env_get_bootm_low() address and kernel board info is initialized + * with the current u-boot board info data. + * + * returns: + * 0 - success + * -1 - failure + */ +int boot_get_kbd(struct lmb *lmb, struct bd_info **kbd) +{ + *kbd = (struct bd_info *)(ulong)lmb_alloc_base(lmb, + sizeof(struct bd_info), + 0xf, + env_get_bootm_mapsize() + env_get_bootm_low()); + if (*kbd == NULL) + return -1; + + **kbd = *(gd->bd); + + debug("## kernel board info at 0x%08lx\n", (ulong)*kbd); + +#if defined(DEBUG) && defined(CONFIG_CMD_BDI) + do_bdinfo(NULL, 0, 0, NULL); +#endif + + return 0; +} +#endif /* CONFIG_SYS_BOOT_GET_KBD */ + +#ifdef CONFIG_LMB +int image_setup_linux(bootm_headers_t *images) +{ + ulong of_size = images->ft_len; + char **of_flat_tree = &images->ft_addr; + struct lmb *lmb = &images->lmb; + int ret; + + if (IMAGE_ENABLE_OF_LIBFDT) + boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); + + if (IMAGE_BOOT_GET_CMDLINE) { + ret = boot_get_cmdline(lmb, &images->cmdline_start, + &images->cmdline_end); + if (ret) { + puts("ERROR with allocation of cmdline\n"); + return ret; + } + } + + if (IMAGE_ENABLE_OF_LIBFDT) { + ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); + if (ret) + return ret; + } + + if (IMAGE_ENABLE_OF_LIBFDT && of_size) { + ret = image_setup_libfdt(images, *of_flat_tree, of_size, lmb); + if (ret) + return ret; + } + + return 0; +} +#endif /* CONFIG_LMB */ diff --git a/common/image.c b/common/image.c index a41e8067b11..e9658e3ab1b 100644 --- a/common/image.c +++ b/common/image.c @@ -8,15 +8,11 @@
#ifndef USE_HOSTCC #include <common.h> -#include <bootstage.h> -#include <cpu_func.h> #include <env.h> #include <lmb.h> #include <log.h> #include <malloc.h> -#include <asm/cache.h> #include <u-boot/crc.h> -#include <watchdog.h>
#ifdef CONFIG_SHOW_BOOT_PROGRESS #include <status_led.h> @@ -24,14 +20,9 @@
#include <rtc.h>
-#include <image.h> -#include <mapmem.h> - #if IMAGE_ENABLE_FIT || IMAGE_ENABLE_OF_LIBFDT #include <linux/libfdt.h> #include <fdt_support.h> -#include <fpga.h> -#include <xilinx.h> #endif
#include <asm/global_data.h> @@ -47,11 +38,6 @@ extern int do_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc,
-#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) -static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, - int verify); -#endif - /* Set this if we have less than 4 MB of malloc() space */ #if CONFIG_SYS_MALLOC_LEN < (4096 * 1024) #define CONSERVE_MEMORY true @@ -63,7 +49,6 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, #include "mkimage.h" #include <u-boot/md5.h> #include <time.h> -#include <image.h>
#ifndef __maybe_unused # define __maybe_unused /* unimplemented */ @@ -76,6 +61,7 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, #include <abuf.h> #include <bzlib.h> #include <gzip.h> +#include <image.h> #include <lz4.h> #include <imximage.h> #include <linux/lzo.h> @@ -86,10 +72,6 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, #include <lzma/LzmaTools.h> #include <u-boot/crc.h>
-#ifndef CONFIG_SYS_BARGSIZE -#define CONFIG_SYS_BARGSIZE 512 -#endif - static const table_entry_t uimage_arch[] = { { IH_ARCH_INVALID, "invalid", "Invalid ARCH", }, { IH_ARCH_ALPHA, "alpha", "Alpha", }, @@ -544,180 +526,7 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, return 0; }
-#ifndef USE_HOSTCC -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) -/** - * image_get_ramdisk - get and verify ramdisk image - * @rd_addr: ramdisk image start address - * @arch: expected ramdisk architecture - * @verify: checksum verification flag - * - * image_get_ramdisk() returns a pointer to the verified ramdisk image - * header. Routine receives image start address and expected architecture - * flag. Verification done covers data and header integrity and os/type/arch - * fields checking. - * - * returns: - * pointer to a ramdisk image header, if image was found and valid - * otherwise, return NULL - */ -static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, - int verify) -{ - const image_header_t *rd_hdr = (const image_header_t *)rd_addr; - - if (!image_check_magic(rd_hdr)) { - puts("Bad Magic Number\n"); - bootstage_error(BOOTSTAGE_ID_RD_MAGIC); - return NULL; - } - - if (!image_check_hcrc(rd_hdr)) { - puts("Bad Header Checksum\n"); - bootstage_error(BOOTSTAGE_ID_RD_HDR_CHECKSUM); - return NULL; - } - - bootstage_mark(BOOTSTAGE_ID_RD_MAGIC); - image_print_contents(rd_hdr); - - if (verify) { - puts(" Verifying Checksum ... "); - if (!image_check_dcrc(rd_hdr)) { - puts("Bad Data CRC\n"); - bootstage_error(BOOTSTAGE_ID_RD_CHECKSUM); - return NULL; - } - puts("OK\n"); - } - - bootstage_mark(BOOTSTAGE_ID_RD_HDR_CHECKSUM); - - if (!image_check_os(rd_hdr, IH_OS_LINUX) || - !image_check_arch(rd_hdr, arch) || - !image_check_type(rd_hdr, IH_TYPE_RAMDISK)) { - printf("No Linux %s Ramdisk Image\n", - genimg_get_arch_name(arch)); - bootstage_error(BOOTSTAGE_ID_RAMDISK); - return NULL; - } - - return rd_hdr; -} -#endif -#endif /* !USE_HOSTCC */ - -/*****************************************************************************/ -/* Shared dual-format routines */ -/*****************************************************************************/ -#ifndef USE_HOSTCC -ulong image_load_addr = CONFIG_SYS_LOAD_ADDR; /* Default Load Address */ -ulong image_save_addr; /* Default Save Address */ -ulong image_save_size; /* Default Save Size (in bytes) */ - -static int on_loadaddr(const char *name, const char *value, enum env_op op, - int flags) -{ - switch (op) { - case env_op_create: - case env_op_overwrite: - image_load_addr = simple_strtoul(value, NULL, 16); - break; - default: - break; - } - - return 0; -} -U_BOOT_ENV_CALLBACK(loadaddr, on_loadaddr); - -ulong env_get_bootm_low(void) -{ - char *s = env_get("bootm_low"); - if (s) { - ulong tmp = simple_strtoul(s, NULL, 16); - return tmp; - } - -#if defined(CONFIG_SYS_SDRAM_BASE) - return CONFIG_SYS_SDRAM_BASE; -#elif defined(CONFIG_ARM) || defined(CONFIG_MICROBLAZE) - return gd->bd->bi_dram[0].start; -#else - return 0; -#endif -} - -phys_size_t env_get_bootm_size(void) -{ - phys_size_t tmp, size; - phys_addr_t start; - char *s = env_get("bootm_size"); - if (s) { - tmp = (phys_size_t)simple_strtoull(s, NULL, 16); - return tmp; - } - - start = gd->ram_base; - size = gd->ram_size; - - if (start + size > gd->ram_top) - size = gd->ram_top - start; - - s = env_get("bootm_low"); - if (s) - tmp = (phys_size_t)simple_strtoull(s, NULL, 16); - else - tmp = start; - - return size - (tmp - start); -} - -phys_size_t env_get_bootm_mapsize(void) -{ - phys_size_t tmp; - char *s = env_get("bootm_mapsize"); - if (s) { - tmp = (phys_size_t)simple_strtoull(s, NULL, 16); - return tmp; - } - -#if defined(CONFIG_SYS_BOOTMAPSZ) - return CONFIG_SYS_BOOTMAPSZ; -#else - return env_get_bootm_size(); -#endif -} - -void memmove_wd(void *to, void *from, size_t len, ulong chunksz) -{ - if (to == from) - return; - -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) - if (to > from) { - from += len; - to += len; - } - while (len > 0) { - size_t tail = (len > chunksz) ? chunksz : len; - WATCHDOG_RESET(); - if (to > from) { - to -= tail; - from -= tail; - } - memmove(to, from, tail); - if (to < from) { - to += tail; - from += tail; - } - len -= tail; - } -#else /* !(CONFIG_HW_WATCHDOG || CONFIG_WATCHDOG) */ - memmove(to, from, len); -#endif /* CONFIG_HW_WATCHDOG || CONFIG_WATCHDOG */ -} -#else /* USE_HOSTCC */ +#ifdef USE_HOSTCC void memmove_wd(void *to, void *from, size_t len, ulong chunksz) { memmove(to, from, len); @@ -980,733 +789,3 @@ int genimg_get_comp_id(const char *name) { return (get_table_entry_id(uimage_comp, "Compression", name)); } - -#ifndef USE_HOSTCC -/** - * genimg_get_kernel_addr_fit - get the real kernel address and return 2 - * FIT strings - * @img_addr: a string might contain real image address - * @fit_uname_config: double pointer to a char, will hold pointer to a - * configuration unit name - * @fit_uname_kernel: double pointer to a char, will hold pointer to a subimage - * name - * - * genimg_get_kernel_addr_fit get the real kernel start address from a string - * which is normally the first argv of bootm/bootz - * - * returns: - * kernel start address - */ -ulong genimg_get_kernel_addr_fit(char * const img_addr, - const char **fit_uname_config, - const char **fit_uname_kernel) -{ - ulong kernel_addr; - - /* find out kernel image address */ - if (!img_addr) { - kernel_addr = image_load_addr; - debug("* kernel: default image load address = 0x%08lx\n", - image_load_addr); -#if CONFIG_IS_ENABLED(FIT) - } else if (fit_parse_conf(img_addr, image_load_addr, &kernel_addr, - fit_uname_config)) { - debug("* kernel: config '%s' from image at 0x%08lx\n", - *fit_uname_config, kernel_addr); - } else if (fit_parse_subimage(img_addr, image_load_addr, &kernel_addr, - fit_uname_kernel)) { - debug("* kernel: subimage '%s' from image at 0x%08lx\n", - *fit_uname_kernel, kernel_addr); -#endif - } else { - kernel_addr = simple_strtoul(img_addr, NULL, 16); - debug("* kernel: cmdline image address = 0x%08lx\n", - kernel_addr); - } - - return kernel_addr; -} - -/** - * genimg_get_kernel_addr() is the simple version of - * genimg_get_kernel_addr_fit(). It ignores those return FIT strings - */ -ulong genimg_get_kernel_addr(char * const img_addr) -{ - const char *fit_uname_config = NULL; - const char *fit_uname_kernel = NULL; - - return genimg_get_kernel_addr_fit(img_addr, &fit_uname_config, - &fit_uname_kernel); -} - -/** - * genimg_get_format - get image format type - * @img_addr: image start address - * - * genimg_get_format() checks whether provided address points to a valid - * legacy or FIT image. - * - * New uImage format and FDT blob are based on a libfdt. FDT blob - * may be passed directly or embedded in a FIT image. In both situations - * genimg_get_format() must be able to dectect libfdt header. - * - * returns: - * image format type or IMAGE_FORMAT_INVALID if no image is present - */ -int genimg_get_format(const void *img_addr) -{ -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - const image_header_t *hdr; - - hdr = (const image_header_t *)img_addr; - if (image_check_magic(hdr)) - return IMAGE_FORMAT_LEGACY; -#endif -#if IMAGE_ENABLE_FIT || IMAGE_ENABLE_OF_LIBFDT - if (fdt_check_header(img_addr) == 0) - return IMAGE_FORMAT_FIT; -#endif -#ifdef CONFIG_ANDROID_BOOT_IMAGE - if (android_image_check_header(img_addr) == 0) - return IMAGE_FORMAT_ANDROID; -#endif - - return IMAGE_FORMAT_INVALID; -} - -/** - * fit_has_config - check if there is a valid FIT configuration - * @images: pointer to the bootm command headers structure - * - * fit_has_config() checks if there is a FIT configuration in use - * (if FTI support is present). - * - * returns: - * 0, no FIT support or no configuration found - * 1, configuration found - */ -int genimg_has_config(bootm_headers_t *images) -{ -#if IMAGE_ENABLE_FIT - if (images->fit_uname_cfg) - return 1; -#endif - return 0; -} - -/** - * boot_get_ramdisk - main ramdisk handling routine - * @argc: command argument count - * @argv: command argument list - * @images: pointer to the bootm images structure - * @arch: expected ramdisk architecture - * @rd_start: pointer to a ulong variable, will hold ramdisk start address - * @rd_end: pointer to a ulong variable, will hold ramdisk end - * - * boot_get_ramdisk() is responsible for finding a valid ramdisk image. - * Curently supported are the following ramdisk sources: - * - multicomponent kernel/ramdisk image, - * - commandline provided address of decicated ramdisk image. - * - * returns: - * 0, if ramdisk image was found and valid, or skiped - * rd_start and rd_end are set to ramdisk start/end addresses if - * ramdisk image is found and valid - * - * 1, if ramdisk image is found but corrupted, or invalid - * rd_start and rd_end are set to 0 if no ramdisk exists - */ -int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, - uint8_t arch, ulong *rd_start, ulong *rd_end) -{ - ulong rd_addr, rd_load; - ulong rd_data, rd_len; -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - const image_header_t *rd_hdr; -#endif - void *buf; -#ifdef CONFIG_SUPPORT_RAW_INITRD - char *end; -#endif -#if IMAGE_ENABLE_FIT - const char *fit_uname_config = images->fit_uname_cfg; - const char *fit_uname_ramdisk = NULL; - ulong default_addr; - int rd_noffset; -#endif - const char *select = NULL; - - *rd_start = 0; - *rd_end = 0; - -#ifdef CONFIG_ANDROID_BOOT_IMAGE - /* - * Look for an Android boot image. - */ - buf = map_sysmem(images->os.start, 0); - if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) - select = (argc == 0) ? env_get("loadaddr") : argv[0]; -#endif - - if (argc >= 2) - select = argv[1]; - - /* - * Look for a '-' which indicates to ignore the - * ramdisk argument - */ - if (select && strcmp(select, "-") == 0) { - debug("## Skipping init Ramdisk\n"); - rd_len = rd_data = 0; - } else if (select || genimg_has_config(images)) { -#if IMAGE_ENABLE_FIT - if (select) { - /* - * If the init ramdisk comes from the FIT image and - * the FIT image address is omitted in the command - * line argument, try to use os FIT image address or - * default load address. - */ - if (images->fit_uname_os) - default_addr = (ulong)images->fit_hdr_os; - else - default_addr = image_load_addr; - - if (fit_parse_conf(select, default_addr, - &rd_addr, &fit_uname_config)) { - debug("* ramdisk: config '%s' from image at " - "0x%08lx\n", - fit_uname_config, rd_addr); - } else if (fit_parse_subimage(select, default_addr, - &rd_addr, &fit_uname_ramdisk)) { - debug("* ramdisk: subimage '%s' from image at " - "0x%08lx\n", - fit_uname_ramdisk, rd_addr); - } else -#endif - { - rd_addr = simple_strtoul(select, NULL, 16); - debug("* ramdisk: cmdline image address = " - "0x%08lx\n", - rd_addr); - } -#if IMAGE_ENABLE_FIT - } else { - /* use FIT configuration provided in first bootm - * command argument. If the property is not defined, - * quit silently. - */ - rd_addr = map_to_sysmem(images->fit_hdr_os); - rd_noffset = fit_get_node_from_config(images, - FIT_RAMDISK_PROP, rd_addr); - if (rd_noffset == -ENOENT) - return 0; - else if (rd_noffset < 0) - return 1; - } -#endif - - /* - * Check if there is an initrd image at the - * address provided in the second bootm argument - * check image type, for FIT images get FIT node. - */ - buf = map_sysmem(rd_addr, 0); - switch (genimg_get_format(buf)) { -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - case IMAGE_FORMAT_LEGACY: - printf("## Loading init Ramdisk from Legacy " - "Image at %08lx ...\n", rd_addr); - - bootstage_mark(BOOTSTAGE_ID_CHECK_RAMDISK); - rd_hdr = image_get_ramdisk(rd_addr, arch, - images->verify); - - if (rd_hdr == NULL) - return 1; - - rd_data = image_get_data(rd_hdr); - rd_len = image_get_data_size(rd_hdr); - rd_load = image_get_load(rd_hdr); - break; -#endif -#if IMAGE_ENABLE_FIT - case IMAGE_FORMAT_FIT: - rd_noffset = fit_image_load(images, - rd_addr, &fit_uname_ramdisk, - &fit_uname_config, arch, - IH_TYPE_RAMDISK, - BOOTSTAGE_ID_FIT_RD_START, - FIT_LOAD_OPTIONAL_NON_ZERO, - &rd_data, &rd_len); - if (rd_noffset < 0) - return 1; - - images->fit_hdr_rd = map_sysmem(rd_addr, 0); - images->fit_uname_rd = fit_uname_ramdisk; - images->fit_noffset_rd = rd_noffset; - break; -#endif -#ifdef CONFIG_ANDROID_BOOT_IMAGE - case IMAGE_FORMAT_ANDROID: - android_image_get_ramdisk((void *)images->os.start, - &rd_data, &rd_len); - break; -#endif - default: -#ifdef CONFIG_SUPPORT_RAW_INITRD - end = NULL; - if (select) - end = strchr(select, ':'); - if (end) { - rd_len = simple_strtoul(++end, NULL, 16); - rd_data = rd_addr; - } else -#endif - { - puts("Wrong Ramdisk Image Format\n"); - rd_data = rd_len = rd_load = 0; - return 1; - } - } - } else if (images->legacy_hdr_valid && - image_check_type(&images->legacy_hdr_os_copy, - IH_TYPE_MULTI)) { - - /* - * Now check if we have a legacy mult-component image, - * get second entry data start address and len. - */ - bootstage_mark(BOOTSTAGE_ID_RAMDISK); - printf("## Loading init Ramdisk from multi component " - "Legacy Image at %08lx ...\n", - (ulong)images->legacy_hdr_os); - - image_multi_getimg(images->legacy_hdr_os, 1, &rd_data, &rd_len); - } else { - /* - * no initrd image - */ - bootstage_mark(BOOTSTAGE_ID_NO_RAMDISK); - rd_len = rd_data = 0; - } - - if (!rd_data) { - debug("## No init Ramdisk\n"); - } else { - *rd_start = rd_data; - *rd_end = rd_data + rd_len; - } - debug(" ramdisk start = 0x%08lx, ramdisk end = 0x%08lx\n", - *rd_start, *rd_end); - - return 0; -} - -#ifdef CONFIG_SYS_BOOT_RAMDISK_HIGH -/** - * boot_ramdisk_high - relocate init ramdisk - * @lmb: pointer to lmb handle, will be used for memory mgmt - * @rd_data: ramdisk data start address - * @rd_len: ramdisk data length - * @initrd_start: pointer to a ulong variable, will hold final init ramdisk - * start address (after possible relocation) - * @initrd_end: pointer to a ulong variable, will hold final init ramdisk - * end address (after possible relocation) - * - * boot_ramdisk_high() takes a relocation hint from "initrd_high" environment - * variable and if requested ramdisk data is moved to a specified location. - * - * Initrd_start and initrd_end are set to final (after relocation) ramdisk - * start/end addresses if ramdisk image start and len were provided, - * otherwise set initrd_start and initrd_end set to zeros. - * - * returns: - * 0 - success - * -1 - failure - */ -int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, - ulong *initrd_start, ulong *initrd_end) -{ - char *s; - ulong initrd_high; - int initrd_copy_to_ram = 1; - - s = env_get("initrd_high"); - if (s) { - /* a value of "no" or a similar string will act like 0, - * turning the "load high" feature off. This is intentional. - */ - initrd_high = simple_strtoul(s, NULL, 16); - if (initrd_high == ~0) - initrd_copy_to_ram = 0; - } else { - initrd_high = env_get_bootm_mapsize() + env_get_bootm_low(); - } - - - debug("## initrd_high = 0x%08lx, copy_to_ram = %d\n", - initrd_high, initrd_copy_to_ram); - - if (rd_data) { - if (!initrd_copy_to_ram) { /* zero-copy ramdisk support */ - debug(" in-place initrd\n"); - *initrd_start = rd_data; - *initrd_end = rd_data + rd_len; - lmb_reserve(lmb, rd_data, rd_len); - } else { - if (initrd_high) - *initrd_start = (ulong)lmb_alloc_base(lmb, - rd_len, 0x1000, initrd_high); - else - *initrd_start = (ulong)lmb_alloc(lmb, rd_len, - 0x1000); - - if (*initrd_start == 0) { - puts("ramdisk - allocation error\n"); - goto error; - } - bootstage_mark(BOOTSTAGE_ID_COPY_RAMDISK); - - *initrd_end = *initrd_start + rd_len; - printf(" Loading Ramdisk to %08lx, end %08lx ... ", - *initrd_start, *initrd_end); - - memmove_wd((void *)*initrd_start, - (void *)rd_data, rd_len, CHUNKSZ); - -#ifdef CONFIG_MP - /* - * Ensure the image is flushed to memory to handle - * AMP boot scenarios in which we might not be - * HW cache coherent - */ - flush_cache((unsigned long)*initrd_start, - ALIGN(rd_len, ARCH_DMA_MINALIGN)); -#endif - puts("OK\n"); - } - } else { - *initrd_start = 0; - *initrd_end = 0; - } - debug(" ramdisk load start = 0x%08lx, ramdisk load end = 0x%08lx\n", - *initrd_start, *initrd_end); - - return 0; - -error: - return -1; -} -#endif /* CONFIG_SYS_BOOT_RAMDISK_HIGH */ - -int boot_get_setup(bootm_headers_t *images, uint8_t arch, - ulong *setup_start, ulong *setup_len) -{ -#if IMAGE_ENABLE_FIT - return boot_get_setup_fit(images, arch, setup_start, setup_len); -#else - return -ENOENT; -#endif -} - -#if IMAGE_ENABLE_FIT -#if defined(CONFIG_FPGA) -int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, - uint8_t arch, const ulong *ld_start, ulong * const ld_len) -{ - ulong tmp_img_addr, img_data, img_len; - void *buf; - int conf_noffset; - int fit_img_result; - const char *uname, *name; - int err; - int devnum = 0; /* TODO support multi fpga platforms */ - - /* Check to see if the images struct has a FIT configuration */ - if (!genimg_has_config(images)) { - debug("## FIT configuration was not specified\n"); - return 0; - } - - /* - * Obtain the os FIT header from the images struct - */ - tmp_img_addr = map_to_sysmem(images->fit_hdr_os); - buf = map_sysmem(tmp_img_addr, 0); - /* - * Check image type. For FIT images get FIT node - * and attempt to locate a generic binary. - */ - switch (genimg_get_format(buf)) { - case IMAGE_FORMAT_FIT: - conf_noffset = fit_conf_get_node(buf, images->fit_uname_cfg); - - uname = fdt_stringlist_get(buf, conf_noffset, FIT_FPGA_PROP, 0, - NULL); - if (!uname) { - debug("## FPGA image is not specified\n"); - return 0; - } - fit_img_result = fit_image_load(images, - tmp_img_addr, - (const char **)&uname, - &(images->fit_uname_cfg), - arch, - IH_TYPE_FPGA, - BOOTSTAGE_ID_FPGA_INIT, - FIT_LOAD_OPTIONAL_NON_ZERO, - &img_data, &img_len); - - debug("FPGA image (%s) loaded to 0x%lx/size 0x%lx\n", - uname, img_data, img_len); - - if (fit_img_result < 0) { - /* Something went wrong! */ - return fit_img_result; - } - - if (!fpga_is_partial_data(devnum, img_len)) { - name = "full"; - err = fpga_loadbitstream(devnum, (char *)img_data, - img_len, BIT_FULL); - if (err) - err = fpga_load(devnum, (const void *)img_data, - img_len, BIT_FULL); - } else { - name = "partial"; - err = fpga_loadbitstream(devnum, (char *)img_data, - img_len, BIT_PARTIAL); - if (err) - err = fpga_load(devnum, (const void *)img_data, - img_len, BIT_PARTIAL); - } - - if (err) - return err; - - printf(" Programming %s bitstream... OK\n", name); - break; - default: - printf("The given image format is not supported (corrupt?)\n"); - return 1; - } - - return 0; -} -#endif - -static void fit_loadable_process(uint8_t img_type, - ulong img_data, - ulong img_len) -{ - int i; - const unsigned int count = - ll_entry_count(struct fit_loadable_tbl, fit_loadable); - struct fit_loadable_tbl *fit_loadable_handler = - ll_entry_start(struct fit_loadable_tbl, fit_loadable); - /* For each loadable handler */ - for (i = 0; i < count; i++, fit_loadable_handler++) - /* matching this type */ - if (fit_loadable_handler->type == img_type) - /* call that handler with this image data */ - fit_loadable_handler->handler(img_data, img_len); -} - -int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images, - uint8_t arch, const ulong *ld_start, ulong * const ld_len) -{ - /* - * These variables are used to hold the current image location - * in system memory. - */ - ulong tmp_img_addr; - /* - * These two variables are requirements for fit_image_load, but - * their values are not used - */ - ulong img_data, img_len; - void *buf; - int loadables_index; - int conf_noffset; - int fit_img_result; - const char *uname; - uint8_t img_type; - - /* Check to see if the images struct has a FIT configuration */ - if (!genimg_has_config(images)) { - debug("## FIT configuration was not specified\n"); - return 0; - } - - /* - * Obtain the os FIT header from the images struct - */ - tmp_img_addr = map_to_sysmem(images->fit_hdr_os); - buf = map_sysmem(tmp_img_addr, 0); - /* - * Check image type. For FIT images get FIT node - * and attempt to locate a generic binary. - */ - switch (genimg_get_format(buf)) { - case IMAGE_FORMAT_FIT: - conf_noffset = fit_conf_get_node(buf, images->fit_uname_cfg); - - for (loadables_index = 0; - uname = fdt_stringlist_get(buf, conf_noffset, - FIT_LOADABLE_PROP, loadables_index, - NULL), uname; - loadables_index++) - { - fit_img_result = fit_image_load(images, - tmp_img_addr, - &uname, - &(images->fit_uname_cfg), arch, - IH_TYPE_LOADABLE, - BOOTSTAGE_ID_FIT_LOADABLE_START, - FIT_LOAD_OPTIONAL_NON_ZERO, - &img_data, &img_len); - if (fit_img_result < 0) { - /* Something went wrong! */ - return fit_img_result; - } - - fit_img_result = fit_image_get_node(buf, uname); - if (fit_img_result < 0) { - /* Something went wrong! */ - return fit_img_result; - } - fit_img_result = fit_image_get_type(buf, - fit_img_result, - &img_type); - if (fit_img_result < 0) { - /* Something went wrong! */ - return fit_img_result; - } - - fit_loadable_process(img_type, img_data, img_len); - } - break; - default: - printf("The given image format is not supported (corrupt?)\n"); - return 1; - } - - return 0; -} -#endif - -#ifdef CONFIG_SYS_BOOT_GET_CMDLINE -/** - * boot_get_cmdline - allocate and initialize kernel cmdline - * @lmb: pointer to lmb handle, will be used for memory mgmt - * @cmd_start: pointer to a ulong variable, will hold cmdline start - * @cmd_end: pointer to a ulong variable, will hold cmdline end - * - * boot_get_cmdline() allocates space for kernel command line below - * BOOTMAPSZ + env_get_bootm_low() address. If "bootargs" U-Boot environment - * variable is present its contents is copied to allocated kernel - * command line. - * - * returns: - * 0 - success - * -1 - failure - */ -int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end) -{ - char *cmdline; - char *s; - - cmdline = (char *)(ulong)lmb_alloc_base(lmb, CONFIG_SYS_BARGSIZE, 0xf, - env_get_bootm_mapsize() + env_get_bootm_low()); - - if (cmdline == NULL) - return -1; - - s = env_get("bootargs"); - if (!s) - s = ""; - - strcpy(cmdline, s); - - *cmd_start = (ulong) & cmdline[0]; - *cmd_end = *cmd_start + strlen(cmdline); - - debug("## cmdline at 0x%08lx ... 0x%08lx\n", *cmd_start, *cmd_end); - - return 0; -} -#endif /* CONFIG_SYS_BOOT_GET_CMDLINE */ - -#ifdef CONFIG_SYS_BOOT_GET_KBD -/** - * boot_get_kbd - allocate and initialize kernel copy of board info - * @lmb: pointer to lmb handle, will be used for memory mgmt - * @kbd: double pointer to board info data - * - * boot_get_kbd() allocates space for kernel copy of board info data below - * BOOTMAPSZ + env_get_bootm_low() address and kernel board info is initialized - * with the current u-boot board info data. - * - * returns: - * 0 - success - * -1 - failure - */ -int boot_get_kbd(struct lmb *lmb, struct bd_info **kbd) -{ - *kbd = (struct bd_info *)(ulong)lmb_alloc_base(lmb, - sizeof(struct bd_info), - 0xf, - env_get_bootm_mapsize() + env_get_bootm_low()); - if (*kbd == NULL) - return -1; - - **kbd = *(gd->bd); - - debug("## kernel board info at 0x%08lx\n", (ulong)*kbd); - -#if defined(DEBUG) && defined(CONFIG_CMD_BDI) - do_bdinfo(NULL, 0, 0, NULL); -#endif - - return 0; -} -#endif /* CONFIG_SYS_BOOT_GET_KBD */ - -#ifdef CONFIG_LMB -int image_setup_linux(bootm_headers_t *images) -{ - ulong of_size = images->ft_len; - char **of_flat_tree = &images->ft_addr; - struct lmb *lmb = &images->lmb; - int ret; - - if (IMAGE_ENABLE_OF_LIBFDT) - boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); - - if (IMAGE_BOOT_GET_CMDLINE) { - ret = boot_get_cmdline(lmb, &images->cmdline_start, - &images->cmdline_end); - if (ret) { - puts("ERROR with allocation of cmdline\n"); - return ret; - } - } - - if (IMAGE_ENABLE_OF_LIBFDT) { - ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); - if (ret) - return ret; - } - - if (IMAGE_ENABLE_OF_LIBFDT && of_size) { - ret = image_setup_libfdt(images, *of_flat_tree, of_size, lmb); - if (ret) - return ret; - } - - return 0; -} -#endif /* CONFIG_LMB */ -#endif /* !USE_HOSTCC */
Tidy up the warnings.
(no changes since v1)
common/image-board.c | 142 ++++++++++++++++++++++--------------------- 1 file changed, 72 insertions(+), 70 deletions(-)
diff --git a/common/image-board.c b/common/image-board.c index 0c4e32e14e4..5d3eafb5245 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -41,8 +41,8 @@ DECLARE_GLOBAL_DATA_PTR; * pointer to a ramdisk image header, if image was found and valid * otherwise, return NULL */ -static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, - int verify) +static const image_header_t *image_get_ramdisk(ulong rd_addr, u8 arch, + int verify) { const image_header_t *rd_hdr = (const image_header_t *)rd_addr;
@@ -77,7 +77,7 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, !image_check_arch(rd_hdr, arch) || !image_check_type(rd_hdr, IH_TYPE_RAMDISK)) { printf("No Linux %s Ramdisk Image\n", - genimg_get_arch_name(arch)); + genimg_get_arch_name(arch)); bootstage_error(BOOTSTAGE_ID_RAMDISK); return NULL; } @@ -94,7 +94,7 @@ ulong image_save_addr; /* Default Save Address */ ulong image_save_size; /* Default Save Size (in bytes) */
static int on_loadaddr(const char *name, const char *value, enum env_op op, - int flags) + int flags) { switch (op) { case env_op_create: @@ -112,6 +112,7 @@ U_BOOT_ENV_CALLBACK(loadaddr, on_loadaddr); ulong env_get_bootm_low(void) { char *s = env_get("bootm_low"); + if (s) { ulong tmp = simple_strtoul(s, NULL, 16); return tmp; @@ -131,6 +132,7 @@ phys_size_t env_get_bootm_size(void) phys_size_t tmp, size; phys_addr_t start; char *s = env_get("bootm_size"); + if (s) { tmp = (phys_size_t)simple_strtoull(s, NULL, 16); return tmp; @@ -155,6 +157,7 @@ phys_size_t env_get_bootm_mapsize(void) { phys_size_t tmp; char *s = env_get("bootm_mapsize"); + if (s) { tmp = (phys_size_t)simple_strtoull(s, NULL, 16); return tmp; @@ -179,6 +182,7 @@ void memmove_wd(void *to, void *from, size_t len, ulong chunksz) } while (len > 0) { size_t tail = (len > chunksz) ? chunksz : len; + WATCHDOG_RESET(); if (to > from) { to -= tail; @@ -212,8 +216,8 @@ void memmove_wd(void *to, void *from, size_t len, ulong chunksz) * kernel start address */ ulong genimg_get_kernel_addr_fit(char * const img_addr, - const char **fit_uname_config, - const char **fit_uname_kernel) + const char **fit_uname_config, + const char **fit_uname_kernel) { ulong kernel_addr;
@@ -319,7 +323,7 @@ int genimg_has_config(bootm_headers_t *images) * @rd_end: pointer to a ulong variable, will hold ramdisk end * * boot_get_ramdisk() is responsible for finding a valid ramdisk image. - * Curently supported are the following ramdisk sources: + * Currently supported are the following ramdisk sources: * - multicomponent kernel/ramdisk image, * - commandline provided address of decicated ramdisk image. * @@ -332,7 +336,7 @@ int genimg_has_config(bootm_headers_t *images) * rd_start and rd_end are set to 0 if no ramdisk exists */ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, - uint8_t arch, ulong *rd_start, ulong *rd_end) + u8 arch, ulong *rd_start, ulong *rd_end) { ulong rd_addr, rd_load; ulong rd_data, rd_len; @@ -372,7 +376,8 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, */ if (select && strcmp(select, "-") == 0) { debug("## Skipping init Ramdisk\n"); - rd_len = rd_data = 0; + rd_len = 0; + rd_data = 0; } else if (select || genimg_has_config(images)) { #if IMAGE_ENABLE_FIT if (select) { @@ -389,21 +394,19 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images,
if (fit_parse_conf(select, default_addr, &rd_addr, &fit_uname_config)) { - debug("* ramdisk: config '%s' from image at " - "0x%08lx\n", - fit_uname_config, rd_addr); + debug("* ramdisk: config '%s' from image at 0x%08lx\n", + fit_uname_config, rd_addr); } else if (fit_parse_subimage(select, default_addr, - &rd_addr, &fit_uname_ramdisk)) { - debug("* ramdisk: subimage '%s' from image at " - "0x%08lx\n", - fit_uname_ramdisk, rd_addr); + &rd_addr, + &fit_uname_ramdisk)) { + debug("* ramdisk: subimage '%s' from image at 0x%08lx\n", + fit_uname_ramdisk, rd_addr); } else #endif { rd_addr = simple_strtoul(select, NULL, 16); - debug("* ramdisk: cmdline image address = " - "0x%08lx\n", - rd_addr); + debug("* ramdisk: cmdline image address = 0x%08lx\n", + rd_addr); } #if IMAGE_ENABLE_FIT } else { @@ -413,7 +416,8 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, */ rd_addr = map_to_sysmem(images->fit_hdr_os); rd_noffset = fit_get_node_from_config(images, - FIT_RAMDISK_PROP, rd_addr); + FIT_RAMDISK_PROP, + rd_addr); if (rd_noffset == -ENOENT) return 0; else if (rd_noffset < 0) @@ -430,14 +434,14 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, switch (genimg_get_format(buf)) { #if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: - printf("## Loading init Ramdisk from Legacy " - "Image at %08lx ...\n", rd_addr); + printf("## Loading init Ramdisk from Legacy Image at %08lx ...\n", + rd_addr);
bootstage_mark(BOOTSTAGE_ID_CHECK_RAMDISK); rd_hdr = image_get_ramdisk(rd_addr, arch, - images->verify); + images->verify);
- if (rd_hdr == NULL) + if (!rd_hdr) return 1;
rd_data = image_get_data(rd_hdr); @@ -448,12 +452,12 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, #if IMAGE_ENABLE_FIT case IMAGE_FORMAT_FIT: rd_noffset = fit_image_load(images, - rd_addr, &fit_uname_ramdisk, - &fit_uname_config, arch, - IH_TYPE_RAMDISK, - BOOTSTAGE_ID_FIT_RD_START, - FIT_LOAD_OPTIONAL_NON_ZERO, - &rd_data, &rd_len); + rd_addr, &fit_uname_ramdisk, + &fit_uname_config, arch, + IH_TYPE_RAMDISK, + BOOTSTAGE_ID_FIT_RD_START, + FIT_LOAD_OPTIONAL_NON_ZERO, + &rd_data, &rd_len); if (rd_noffset < 0) return 1;
@@ -465,7 +469,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, #ifdef CONFIG_ANDROID_BOOT_IMAGE case IMAGE_FORMAT_ANDROID: android_image_get_ramdisk((void *)images->os.start, - &rd_data, &rd_len); + &rd_data, &rd_len); break; #endif default: @@ -480,22 +484,22 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, #endif { puts("Wrong Ramdisk Image Format\n"); - rd_data = rd_len = rd_load = 0; + rd_data = 0; + rd_len = 0; + rd_load = 0; return 1; } } } else if (images->legacy_hdr_valid && image_check_type(&images->legacy_hdr_os_copy, - IH_TYPE_MULTI)) { - + IH_TYPE_MULTI)) { /* * Now check if we have a legacy mult-component image, * get second entry data start address and len. */ bootstage_mark(BOOTSTAGE_ID_RAMDISK); - printf("## Loading init Ramdisk from multi component " - "Legacy Image at %08lx ...\n", - (ulong)images->legacy_hdr_os); + printf("## Loading init Ramdisk from multi component Legacy Image at %08lx ...\n", + (ulong)images->legacy_hdr_os);
image_multi_getimg(images->legacy_hdr_os, 1, &rd_data, &rd_len); } else { @@ -503,7 +507,8 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, * no initrd image */ bootstage_mark(BOOTSTAGE_ID_NO_RAMDISK); - rd_len = rd_data = 0; + rd_len = 0; + rd_data = 0; }
if (!rd_data) { @@ -513,7 +518,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, *rd_end = rd_data + rd_len; } debug(" ramdisk start = 0x%08lx, ramdisk end = 0x%08lx\n", - *rd_start, *rd_end); + *rd_start, *rd_end);
return 0; } @@ -541,7 +546,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, * -1 - failure */ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, - ulong *initrd_start, ulong *initrd_end) + ulong *initrd_start, ulong *initrd_end) { char *s; ulong initrd_high; @@ -559,9 +564,8 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, initrd_high = env_get_bootm_mapsize() + env_get_bootm_low(); }
- debug("## initrd_high = 0x%08lx, copy_to_ram = %d\n", - initrd_high, initrd_copy_to_ram); + initrd_high, initrd_copy_to_ram);
if (rd_data) { if (!initrd_copy_to_ram) { /* zero-copy ramdisk support */ @@ -585,10 +589,10 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len,
*initrd_end = *initrd_start + rd_len; printf(" Loading Ramdisk to %08lx, end %08lx ... ", - *initrd_start, *initrd_end); + *initrd_start, *initrd_end);
memmove_wd((void *)*initrd_start, - (void *)rd_data, rd_len, CHUNKSZ); + (void *)rd_data, rd_len, CHUNKSZ);
#ifdef CONFIG_MP /* @@ -606,7 +610,7 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, *initrd_end = 0; } debug(" ramdisk load start = 0x%08lx, ramdisk load end = 0x%08lx\n", - *initrd_start, *initrd_end); + *initrd_start, *initrd_end);
@@ -615,7 +619,7 @@ error: } #endif /* CONFIG_SYS_BOOT_RAMDISK_HIGH */
-int boot_get_setup(bootm_headers_t *images, uint8_t arch, +int boot_get_setup(bootm_headers_t *images, u8 arch, ulong *setup_start, ulong *setup_len) { #if IMAGE_ENABLE_FIT @@ -628,7 +632,7 @@ int boot_get_setup(bootm_headers_t *images, uint8_t arch, #if IMAGE_ENABLE_FIT #if defined(CONFIG_FPGA) int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, - uint8_t arch, const ulong *ld_start, ulong * const ld_len) + u8 arch, const ulong *ld_start, ulong * const ld_len) { ulong tmp_img_addr, img_data, img_len; void *buf; @@ -666,7 +670,7 @@ int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, fit_img_result = fit_image_load(images, tmp_img_addr, (const char **)&uname, - &(images->fit_uname_cfg), + &images->fit_uname_cfg, arch, IH_TYPE_FPGA, BOOTSTAGE_ID_FPGA_INIT, @@ -711,7 +715,7 @@ int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, } #endif
-static void fit_loadable_process(uint8_t img_type, +static void fit_loadable_process(u8 img_type, ulong img_data, ulong img_len) { @@ -729,7 +733,7 @@ static void fit_loadable_process(uint8_t img_type, }
int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images, - uint8_t arch, const ulong *ld_start, ulong * const ld_len) + u8 arch, const ulong *ld_start, ulong * const ld_len) { /* * These variables are used to hold the current image location @@ -746,7 +750,7 @@ int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images, int conf_noffset; int fit_img_result; const char *uname; - uint8_t img_type; + u8 img_type;
/* Check to see if the images struct has a FIT configuration */ if (!genimg_has_config(images)) { @@ -769,18 +773,16 @@ int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images,
for (loadables_index = 0; uname = fdt_stringlist_get(buf, conf_noffset, - FIT_LOADABLE_PROP, loadables_index, - NULL), uname; - loadables_index++) - { - fit_img_result = fit_image_load(images, - tmp_img_addr, - &uname, - &(images->fit_uname_cfg), arch, - IH_TYPE_LOADABLE, - BOOTSTAGE_ID_FIT_LOADABLE_START, - FIT_LOAD_OPTIONAL_NON_ZERO, - &img_data, &img_len); + FIT_LOADABLE_PROP, + loadables_index, NULL), uname; + loadables_index++) { + fit_img_result = fit_image_load(images, tmp_img_addr, + &uname, + &images->fit_uname_cfg, + arch, IH_TYPE_LOADABLE, + BOOTSTAGE_ID_FIT_LOADABLE_START, + FIT_LOAD_OPTIONAL_NON_ZERO, + &img_data, &img_len); if (fit_img_result < 0) { /* Something went wrong! */ return fit_img_result; @@ -834,8 +836,7 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end)
cmdline = (char *)(ulong)lmb_alloc_base(lmb, CONFIG_SYS_BARGSIZE, 0xf, env_get_bootm_mapsize() + env_get_bootm_low()); - - if (cmdline == NULL) + if (!cmdline) return -1;
s = env_get("bootargs"); @@ -844,7 +845,7 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end)
strcpy(cmdline, s);
- *cmd_start = (ulong) & cmdline[0]; + *cmd_start = (ulong)cmdline; *cmd_end = *cmd_start + strlen(cmdline);
debug("## cmdline at 0x%08lx ... 0x%08lx\n", *cmd_start, *cmd_end); @@ -872,11 +873,12 @@ int boot_get_kbd(struct lmb *lmb, struct bd_info **kbd) *kbd = (struct bd_info *)(ulong)lmb_alloc_base(lmb, sizeof(struct bd_info), 0xf, - env_get_bootm_mapsize() + env_get_bootm_low()); - if (*kbd == NULL) + env_get_bootm_mapsize() + + env_get_bootm_low()); + if (!*kbd) return -1;
- **kbd = *(gd->bd); + **kbd = *gd->bd;
@@ -901,7 +903,7 @@ int image_setup_linux(bootm_headers_t *images)
if (IMAGE_BOOT_GET_CMDLINE) { ret = boot_get_cmdline(lmb, &images->cmdline_start, - &images->cmdline_end); + &images->cmdline_end); if (ret) { puts("ERROR with allocation of cmdline\n"); return ret;
To avoid having #ifdefs in a few functions which are completely different in the board and host code, create a new image-host.c file.
common/image-board.c | 17 +++++++++++++++++ common/image-host.c | 27 +++++++++++++++++++++++++++ common/image.c | 38 +------------------------------------- tools/Makefile | 1 + 4 files changed, 46 insertions(+), 37 deletions(-) create mode 100644 common/image-host.c
diff --git a/common/image-board.c b/common/image-board.c index 5d3eafb5245..b46062c86b9 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -15,6 +15,7 @@ #include <fpga.h> #include <image.h> #include <mapmem.h> +#include <rtc.h> #include <watchdog.h> #include <asm/cache.h> #include <asm/global_data.h> @@ -925,3 +926,19 @@ int image_setup_linux(bootm_headers_t *images) return 0; } #endif /* CONFIG_LMB */ + +void genimg_print_size(uint32_t size) +{ + printf("%d Bytes = ", size); + print_size(size, "\n"); +} + +void genimg_print_time(time_t timestamp) +{ + struct rtc_time tm; + + rtc_to_tm(timestamp, &tm); + printf("%4d-%02d-%02d %2d:%02d:%02d UTC\n", + tm.tm_year, tm.tm_mon, tm.tm_mday, + tm.tm_hour, tm.tm_min, tm.tm_sec); +} diff --git a/common/image-host.c b/common/image-host.c new file mode 100644 index 00000000000..20a9521948b --- /dev/null +++ b/common/image-host.c @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Image code used by host tools (and not boards) + * + * (C) Copyright 2008 Semihalf + * + * (C) Copyright 2000-2006 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + */ + +#include <time.h> + +void memmove_wd(void *to, void *from, size_t len, ulong chunksz) +{ + memmove(to, from, len); +} + +void genimg_print_size(uint32_t size) +{ + printf("%d Bytes = %.2f KiB = %.2f MiB\n", size, (double)size / 1.024e3, + (double)size / 1.048576e6); +} + +void genimg_print_time(time_t timestamp) +{ + printf("%s", ctime(×tamp)); +} diff --git a/common/image.c b/common/image.c index e9658e3ab1b..0ef8f30fcfa 100644 --- a/common/image.c +++ b/common/image.c @@ -18,8 +18,6 @@ #include <status_led.h> #endif
-#include <rtc.h> - #if IMAGE_ENABLE_FIT || IMAGE_ENABLE_OF_LIBFDT #include <linux/libfdt.h> #include <fdt_support.h> @@ -60,6 +58,7 @@ DECLARE_GLOBAL_DATA_PTR;
#include <abuf.h> #include <bzlib.h> +#include <display_options.h> #include <gzip.h> #include <image.h> #include <lz4.h> @@ -526,41 +525,6 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, return 0; }
-#ifdef USE_HOSTCC -void memmove_wd(void *to, void *from, size_t len, ulong chunksz) -{ - memmove(to, from, len); -} -#endif /* !USE_HOSTCC */ - -void genimg_print_size(uint32_t size) -{ -#ifndef USE_HOSTCC - printf("%d Bytes = ", size); - print_size(size, "\n"); -#else - printf("%d Bytes = %.2f KiB = %.2f MiB\n", - size, (double)size / 1.024e3, - (double)size / 1.048576e6); -#endif -} - -#if IMAGE_ENABLE_TIMESTAMP -void genimg_print_time(time_t timestamp) -{ -#ifndef USE_HOSTCC - struct rtc_time tm; - - rtc_to_tm(timestamp, &tm); - printf("%4d-%02d-%02d %2d:%02d:%02d UTC\n", - tm.tm_year, tm.tm_mon, tm.tm_mday, - tm.tm_hour, tm.tm_min, tm.tm_sec); -#else - printf("%s", ctime(×tamp)); -#endif -} -#endif - const table_entry_t *get_table_entry(const table_entry_t *table, int id) { for (; table->id >= 0; ++table) { diff --git a/tools/Makefile b/tools/Makefile index d020c55d664..2b4bc547abd 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -94,6 +94,7 @@ dumpimage-mkimage-objs := aisimage.o \ lib/fdtdec_common.o \ lib/fdtdec.o \ common/image.o \ + common/image-host.o \ imagetool.o \ imximage.o \ imx8image.o \
Rather than adding an #ifdef and open-coding this calculation, add a helper function to handle it. Use this in the image code.
common/image.c | 33 +++++++-------------------------- include/relocate.h | 24 +++++++++++++++++++++++- 2 files changed, 30 insertions(+), 27 deletions(-)
diff --git a/common/image.c b/common/image.c index 0ef8f30fcfa..086ae609f29 100644 --- a/common/image.c +++ b/common/image.c @@ -63,6 +63,7 @@ DECLARE_GLOBAL_DATA_PTR; #include <image.h> #include <lz4.h> #include <imximage.h> +#include <relocate.h> #include <linux/lzo.h> #include <linux/zstd.h> #include <linux/kconfig.h> @@ -563,11 +564,7 @@ const char *genimg_get_cat_name(enum ih_category category, uint id) entry = get_table_entry(table_info[category].table, id); if (!entry) return unknown_msg(category); -#if defined(USE_HOSTCC) || !defined(CONFIG_NEEDS_MANUAL_RELOC) - return entry->lname; -#else - return entry->lname + gd->reloc_off; -#endif + return manual_reloc(entry->lname); }
/** @@ -587,11 +584,7 @@ const char *genimg_get_cat_short_name(enum ih_category category, uint id) entry = get_table_entry(table_info[category].table, id); if (!entry) return unknown_msg(category); -#if defined(USE_HOSTCC) || !defined(CONFIG_NEEDS_MANUAL_RELOC) - return entry->sname; -#else - return entry->sname + gd->reloc_off; -#endif + return manual_reloc(entry->sname); }
int genimg_get_cat_count(enum ih_category category) @@ -641,11 +634,7 @@ char *get_table_entry_name(const table_entry_t *table, char *msg, int id) table = get_table_entry(table, id); if (!table) return msg; -#if defined(USE_HOSTCC) || !defined(CONFIG_NEEDS_MANUAL_RELOC) - return table->lname; -#else - return table->lname + gd->reloc_off; -#endif + return manual_reloc(table->lname); }
const char *genimg_get_os_name(uint8_t os) @@ -675,11 +664,7 @@ static const char *genimg_get_short_name(const table_entry_t *table, int val) table = get_table_entry(table, val); if (!table) return "unknown"; -#if defined(USE_HOSTCC) || !defined(CONFIG_NEEDS_MANUAL_RELOC) - return table->sname; -#else - return table->sname + gd->reloc_off; -#endif + return manual_reloc(table->sname); }
const char *genimg_get_type_short_name(uint8_t type) @@ -722,12 +707,8 @@ int get_table_entry_id(const table_entry_t *table, const table_entry_t *t;
for (t = table; t->id >= 0; ++t) { -#if !defined(USE_HOSTCC) && defined(CONFIG_NEEDS_MANUAL_RELOC) - if (t->sname && strcasecmp(t->sname + gd->reloc_off, name) == 0) -#else - if (t->sname && strcasecmp(t->sname, name) == 0) -#endif - return (t->id); + if (t->sname && !strcasecmp(manual_reloc(t->sname), name)) + return t->id; } debug("Invalid %s Type: %s\n", table_name, name);
diff --git a/include/relocate.h b/include/relocate.h index 9ceeecdbe71..c4fad336128 100644 --- a/include/relocate.h +++ b/include/relocate.h @@ -7,7 +7,11 @@ #ifndef _RELOCATE_H_ #define _RELOCATE_H_
-#include <common.h> +#ifndef USE_HOSTCC +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; +#endif
/** * copy_uboot_to_ram() - Copy U-Boot to its new relocated position @@ -35,4 +39,22 @@ int clear_bss(void); */ int do_elf_reloc_fixups(void);
+/** + * manual_reloc() - Manually relocate a pointer if needed + * + * This is a nop in almost all cases, except for the systems with a broken gcc + * which need to manually relocate some things. + * + * @ptr: Pointer to relocate + * @return new pointer value + */ +static inline void *manual_reloc(void *ptr) +{ +#ifndef USE_HOSTCC + if (IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC)) + return ptr + gd->reloc_off; +#endif + return ptr; +} + #endif /* _RELOCATE_H_ */
-#else
-#endif
- return manual_reloc(entry->lname);
-#else
-#endif
- return manual_reloc(entry->sname);
-#else
-#endif
- return manual_reloc(table->lname);
-#else
-#endif
- return manual_reloc(table->sname);
-#else
-#endif
return (t->id);
} debug("Invalid %s Type: %s\n", table_name, name);return t->id;
- copy_uboot_to_ram() - Copy U-Boot to its new relocated position
- manual_reloc() - Manually relocate a pointer if needed
- This is a nop in almost all cases, except for the systems with a broken gcc
- which need to manually relocate some things.
- @ptr: Pointer to relocate
- @return new pointer value
- if (IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC))
return ptr;
static inlines are preferred in most cases, but you could make this const-correct if it was a macro. Dunno, maybe there are no const-qualified pointers where this might be used.
The function also has the advantage of ensuring that the arithmetic is done on a void* pointer (i.e. effectively sizeof==1), though if the pointer is actually already a u32*, say, the current manual relocation code wouldn't be doing a bare ptr+gd->reloc_off anyway.
Rasmus
Hi Rasmus,
On Tue, 4 May 2021 at 01:17, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
-#else
-#endif
-#else
-#endif
-#else
-#endif
-#else
-#endif
-#else
-#endif
return (t->id);
return ptr;
I can see what we would want that, but I haven't seen those used yet.
Right.
Regards, SImon
Add a macro to handle manually relocating a pointer. Update the iamge code to use this to avoid needing #ifdefs.
common/image-sig.c | 43 ++++++++++++++++++++++++------------------- include/relocate.h | 6 ++++++ 2 files changed, 30 insertions(+), 19 deletions(-)
diff --git a/common/image-sig.c b/common/image-sig.c index 0f8e592aba7..12310bfca1a 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -16,6 +16,7 @@ DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ #include <image.h> +#include <relocate.h> #include <u-boot/ecdsa.h> #include <u-boot/rsa.h> #include <u-boot/hash-checksum.h> @@ -112,20 +113,22 @@ struct checksum_algo *image_get_checksum_algo(const char *full_name) int i; const char *name;
-#if !defined(USE_HOSTCC) && defined(CONFIG_NEEDS_MANUAL_RELOC) - static bool done; + if (IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC)) { + static bool done;
- if (!done) { - done = true; - for (i = 0; i < ARRAY_SIZE(checksum_algos); i++) { - checksum_algos[i].name += gd->reloc_off; + if (!done) { + done = true; + for (i = 0; i < ARRAY_SIZE(checksum_algos); i++) { + struct checksum_algo *algo = &checksum_algos[i]; + + MANUAL_RELOC(algo->name); #if IMAGE_ENABLE_SIGN - checksum_algos[i].calculate_sign += gd->reloc_off; + MANUAL_RELOC(algo->calculate_sign); #endif - checksum_algos[i].calculate += gd->reloc_off; + MANUAL_RELOC(algo->calculate); + } } } -#endif
for (i = 0; i < ARRAY_SIZE(checksum_algos); i++) { name = checksum_algos[i].name; @@ -143,19 +146,21 @@ struct crypto_algo *image_get_crypto_algo(const char *full_name) int i; const char *name;
- if (!done) { - done = true; - for (i = 0; i < ARRAY_SIZE(crypto_algos); i++) { - crypto_algos[i].name += gd->reloc_off; - crypto_algos[i].sign += gd->reloc_off; - crypto_algos[i].add_verify_data += gd->reloc_off; - crypto_algos[i].verify += gd->reloc_off; + if (!done) { + done = true; + for (i = 0; i < ARRAY_SIZE(crypto_algos); i++) { + struct crypto_algo *algo = &crypto_algos[i]; + + MANUAL_RELOC(algo->name); + MANUAL_RELOC(algo->sign); + MANUAL_RELOC(algo->add_verify_data); + MANUAL_RELOC(algo->verify); + } } } -#endif
/* Move name to after the comma */ name = strchr(full_name, ','); diff --git a/include/relocate.h b/include/relocate.h index c4fad336128..26682da955f 100644 --- a/include/relocate.h +++ b/include/relocate.h @@ -57,4 +57,10 @@ static inline void *manual_reloc(void *ptr) return ptr; }
+#if !defined(USE_HOSTCC) && defined(CONFIG_NEEDS_MANUAL_RELOC) +#define MANUAL_RELOC(ptr) (ptr) = manual_reloc(ptr) +#else +#define MANUAL_RELOC(ptr) (void)(ptr) +#endif + #endif /* _RELOCATE_H_ */
Drop some more ifdefs in image-board.c and also the FPGA part of bootm.c which calls into it.
common/bootm.c | 16 ++++++++-------- common/image-board.c | 11 +++-------- 2 files changed, 11 insertions(+), 16 deletions(-)
diff --git a/common/bootm.c b/common/bootm.c index ea71522d0c9..fe17d1da9e5 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -296,15 +296,15 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, #endif
#if IMAGE_ENABLE_FIT -#if defined(CONFIG_FPGA) - /* find bitstreams */ - ret = boot_get_fpga(argc, argv, &images, IH_ARCH_DEFAULT, - NULL, NULL); - if (ret) { - printf("FPGA image is corrupted or invalid\n"); - return 1; + if (IS_ENABLED(CONFIG_FPGA)) { + /* find bitstreams */ + ret = boot_get_fpga(argc, argv, &images, IH_ARCH_DEFAULT, + NULL, NULL); + if (ret) { + printf("FPGA image is corrupted or invalid\n"); + return 1; + } } -#endif
/* find all of the loadables */ ret = boot_get_loadable(argc, argv, &images, IH_ARCH_DEFAULT, diff --git a/common/image-board.c b/common/image-board.c index b46062c86b9..0f41ede1e98 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -814,7 +814,6 @@ int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images, } #endif
-#ifdef CONFIG_SYS_BOOT_GET_CMDLINE /** * boot_get_cmdline - allocate and initialize kernel cmdline * @lmb: pointer to lmb handle, will be used for memory mgmt @@ -853,9 +852,7 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end)
return 0; } -#endif /* CONFIG_SYS_BOOT_GET_CMDLINE */
-#ifdef CONFIG_SYS_BOOT_GET_KBD /** * boot_get_kbd - allocate and initialize kernel copy of board info * @lmb: pointer to lmb handle, will be used for memory mgmt @@ -883,15 +880,14 @@ int boot_get_kbd(struct lmb *lmb, struct bd_info **kbd)
-#if defined(DEBUG) && defined(CONFIG_CMD_BDI) - do_bdinfo(NULL, 0, 0, NULL); +#if defined(DEBUG) + if (IS_ENABLED(CONFIG_CMD_BDI) + do_bdinfo(NULL, 0, 0, NULL); #endif
return 0; } -#endif /* CONFIG_SYS_BOOT_GET_KBD */
-#ifdef CONFIG_LMB int image_setup_linux(bootm_headers_t *images) { ulong of_size = images->ft_len; @@ -925,7 +921,6 @@ int image_setup_linux(bootm_headers_t *images)
return 0; } -#endif /* CONFIG_LMB */
void genimg_print_size(uint32_t size) {
In preparation for enabling CONFIG_IS_ENABLED() on the host build, add some options to enable the various FIT options expected in these tools. This will ensure that the code builds correctly when CONFIG_HOST_xxx is distinct from CONFIG_xxx.
common/image-fit-sig.c | 3 ++- common/image-fit.c | 4 ++-- tools/Kconfig | 25 +++++++++++++++++++++++++ tools/Makefile | 18 +++++++++--------- 4 files changed, 38 insertions(+), 12 deletions(-)
diff --git a/common/image-fit-sig.c b/common/image-fit-sig.c index 55ddf1879ed..12a6745c642 100644 --- a/common/image-fit-sig.c +++ b/common/image-fit-sig.c @@ -72,11 +72,12 @@ static int fit_image_setup_verify(struct image_sign_info *info, char *algo_name; const char *padding_name;
+#ifndef USE_HOSTCC if (fdt_totalsize(fit) > CONFIG_FIT_SIGNATURE_MAX_SIZE) { *err_msgp = "Total size too large"; return 1; } - +#endif if (fit_image_hash_get_algo(fit, noffset, &algo_name)) { *err_msgp = "Can't get hash algo property"; return -1; diff --git a/common/image-fit.c b/common/image-fit.c index e614643fe39..a16e2dd54a5 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -165,7 +165,7 @@ int fit_get_subimage_count(const void *fit, int images_noffset) return count; }
-#if CONFIG_IS_ENABLED(FIT_PRINT) || CONFIG_IS_ENABLED(SPL_FIT_PRINT) +#if CONFIG_IS_ENABLED(FIT_PRINT) /** * fit_image_print_data() - prints out the hash node details * @fit: pointer to the FIT format image header @@ -573,7 +573,7 @@ void fit_image_print(const void *fit, int image_noffset, const char *p) #else void fit_print_contents(const void *fit) { } void fit_image_print(const void *fit, int image_noffset, const char *p) { } -#endif /* CONFIG_IS_ENABLED(FIR_PRINT) || CONFIG_IS_ENABLED(SPL_FIT_PRINT) */ +#endif /* CONFIG_IS_ENABLED(FIT_PRINT) */
/** * fit_get_desc - get node description property diff --git a/tools/Kconfig b/tools/Kconfig index b2f5012240c..f00ab661135 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -9,4 +9,29 @@ config MKIMAGE_DTC_PATH some cases the system dtc may not support all required features and the path to a different version should be given here.
+config HOST_FIT + def_bool y + help + Enable FIT support in the host build. + +config HOST_FIT_FULL_CHECK + def_bool y + help + Do a full check of the FIT before using it in the host build + +config HOST_FIT_PRINT + def_bool y + help + Print the content of the FIT verbosely in the host build + +config HOST_FIT_SIGNATURE + def_bool y + help + Enable signature verification of FIT uImages in the host build + +config HOST_FIT_SIGNATURE_MAX_SIZE + hex + depends on HOST_FIT_SIGNATURE + default 0x10000000 + endmenu diff --git a/tools/Makefile b/tools/Makefile index 2b4bc547abd..d143198f7c9 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -53,12 +53,12 @@ hostprogs-y += mkenvimage mkenvimage-objs := mkenvimage.o os_support.o lib/crc32.o
hostprogs-y += dumpimage mkimage -hostprogs-$(CONFIG_FIT_SIGNATURE) += fit_info fit_check_sign +hostprogs-$(CONFIG_HOST_FIT_SIGNATURE) += fit_info fit_check_sign
hostprogs-$(CONFIG_CMD_BOOTEFI_SELFTEST) += file2include
-FIT_OBJS-$(CONFIG_FIT) := fit_common.o fit_image.o image-host.o common/image-fit.o -FIT_SIG_OBJS-$(CONFIG_FIT_SIGNATURE) := common/image-sig.o common/image-fit-sig.o +FIT_OBJS-$(CONFIG_HOST_FIT) := fit_common.o fit_image.o image-host.o common/image-fit.o +FIT_SIG_OBJS-$(CONFIG_HOST_FIT_SIGNATURE) := common/image-sig.o common/image-fit-sig.o FIT_CIPHER_OBJS-$(CONFIG_FIT_CIPHER) := common/image-cipher.o
# The following files are synced with upstream DTC. @@ -66,17 +66,17 @@ FIT_CIPHER_OBJS-$(CONFIG_FIT_CIPHER) := common/image-cipher.o LIBFDT_OBJS := $(addprefix libfdt/, fdt.o fdt_ro.o fdt_wip.o fdt_sw.o fdt_rw.o \ fdt_strerror.o fdt_empty_tree.o fdt_addresses.o fdt_overlay.o)
-RSA_OBJS-$(CONFIG_FIT_SIGNATURE) := $(addprefix lib/rsa/, \ +RSA_OBJS-$(CONFIG_HOST_FIT_SIGNATURE) := $(addprefix lib/rsa/, \ rsa-sign.o rsa-verify.o \ rsa-mod-exp.o)
-ECDSA_OBJS-$(CONFIG_FIT_SIGNATURE) := $(addprefix lib/ecdsa/, ecdsa-libcrypto.o) +ECDSA_OBJS-$(CONFIG_HOST_FIT_SIGNATURE) := $(addprefix lib/ecdsa/, ecdsa-libcrypto.o)
AES_OBJS-$(CONFIG_FIT_CIPHER) := $(addprefix lib/aes/, \ aes-encrypt.o aes-decrypt.o)
# Cryptographic helpers that depend on openssl/libcrypto -LIBCRYPTO_OBJS-$(CONFIG_FIT_SIGNATURE) := $(addprefix lib/, \ +LIBCRYPTO_OBJS-$(CONFIG_HOST_FIT_SIGNATURE) := $(addprefix lib/, \ fdt-libcrypto.o)
ROCKCHIP_OBS = lib/rc4.o rkcommon.o rkimage.o rksd.o rkspi.o @@ -137,13 +137,13 @@ fit_info-objs := $(dumpimage-mkimage-objs) fit_info.o fit_check_sign-objs := $(dumpimage-mkimage-objs) fit_check_sign.o file2include-objs := file2include.o
-ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_FIT_SIGNATURE),) +ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_HOST_FIT_SIGNATURE),) # Add CONFIG_MXS into host CFLAGS, so we can check whether or not register # the mxsimage support within tools/mxsimage.c . HOSTCFLAGS_mxsimage.o += -DCONFIG_MXS endif
-ifdef CONFIG_FIT_SIGNATURE +ifdef CONFIG_HOST_FIT_SIGNATURE # This affects include/image.h, but including the board config file # is tricky, so manually define this options here. HOST_EXTRACFLAGS += -DCONFIG_FIT_SIGNATURE @@ -165,7 +165,7 @@ HOSTCFLAGS_kwbimage.o += -DCONFIG_KWB_SECURE endif
# MXSImage needs LibSSL -ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_FIT_SIGNATURE)$(CONFIG_FIT_CIPHER),) +ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_HOST_FIT_SIGNATURE)$(CONFIG_FIT_CIPHER),) HOSTCFLAGS_kwbimage.o += \ $(shell pkg-config --cflags libssl libcrypto 2> /dev/null || echo "") HOSTLDLIBS_mkimage += \
At present we must separately test for the host build for many options, since we force them to be enabled. For example, CONFIG_FIT is always enabled in the host tools, even if CONFIG_FIT is not enabled by the board itself.
It would be more convenient if we could use, for example, CONFIG_IS_ENABLED(FIT) and get CONFIG_HOST_FIT, when building for the host. Add support for this.
include/linux/kconfig.h | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/include/linux/kconfig.h b/include/linux/kconfig.h index d109ed3119e..6216b58625f 100644 --- a/include/linux/kconfig.h +++ b/include/linux/kconfig.h @@ -31,11 +31,14 @@ (config_enabled(option))
/* - * U-Boot add-on: Helper macros to reference to different macros - * (CONFIG_ or CONFIG_SPL_ prefixed), depending on the build context. + * U-Boot add-on: Helper macros to reference to different macros (prefixed by + * CONFIG_, CONFIG_SPL_, CONFIG_TPL or CONFIG_HOST), depending on the build + * context. */
-#if defined(CONFIG_TPL_BUILD) +#ifdef USE_HOSTCC +#define _CONFIG_PREFIX HOST_ +#elif defined(CONFIG_TPL_BUILD) #define _CONFIG_PREFIX TPL_ #elif defined(CONFIG_SPL_BUILD) #define _CONFIG_PREFIX SPL_ @@ -49,6 +52,7 @@
/* * CONFIG_VAL(FOO) evaluates to the value of + * CONFIG_HOST_FOO if USE_HOSTCC is undefined, * CONFIG_FOO if CONFIG_SPL_BUILD is undefined, * CONFIG_SPL_FOO if CONFIG_SPL_BUILD is defined. * CONFIG_TPL_FOO if CONFIG_TPL_BUILD is defined. @@ -76,18 +80,21 @@
/* * CONFIG_IS_ENABLED(FOO) expands to + * 1 if USE_HOSTCC is defined and CONFIG_HOST_FOO is set to 'y', * 1 if CONFIG_SPL_BUILD is undefined and CONFIG_FOO is set to 'y', * 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * 1 if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y', * 0 otherwise. * * CONFIG_IS_ENABLED(FOO, (abc)) expands to + * abc if USE_HOSTCC is defined and CONFIG_HOST_FOO is set to 'y', * abc if CONFIG_SPL_BUILD is undefined and CONFIG_FOO is set to 'y', * abc if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * abc if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y', * nothing otherwise. * * CONFIG_IS_ENABLED(FOO, (abc), (def)) expands to + * abc if USE_HOSTCC is defined and CONFIG_HOST_FOO is set to 'y', * abc if CONFIG_SPL_BUILD is undefined and CONFIG_FOO is set to 'y', * abc if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * abc if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y',
Suggested-by: Rasmus Villemoes rasmus.villemoes@prevas.dk # b4f73886
- U-Boot add-on: Helper macros to reference to different macros
- (CONFIG_ or CONFIG_SPL_ prefixed), depending on the build context.
- U-Boot add-on: Helper macros to reference to different macros (prefixed by
- CONFIG_, CONFIG_SPL_, CONFIG_TPL or CONFIG_HOST), depending on the build
- context.
Please consistently have a trailing underscore on these prefixes.
- CONFIG_VAL(FOO) evaluates to the value of
- CONFIG_HOST_FOO if USE_HOSTCC is undefined,
s/undefined/defined/
Rasmus
The ENABLE part of this name is redundant, since all boolean Kconfig options serve to enable something. The SUPPORT part is also redundant since Kconfigs can be assumed to enable support for something. Together they just serve to make these options overly long and inconsistent with other options.
Rename FIT_ENABLE_SHAxxx_SUPPORT to FIT_SHAxxx
common/Kconfig.boot | 6 +++--- configs/mt8516_pumpkin_defconfig | 2 +- include/image.h | 12 ++++++------ 3 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 5a18d62d780..af3325a7ce2 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -35,7 +35,7 @@ config FIT_EXTERNAL_OFFSET could be put in the hole between data payload and fit image header, such as CSF data on i.MX platform.
-config FIT_ENABLE_SHA256_SUPPORT +config FIT_SHA256 bool "Support SHA256 checksum of FIT image contents" default y select SHA256 @@ -44,7 +44,7 @@ config FIT_ENABLE_SHA256_SUPPORT SHA256 checksum is a 256-bit (32-byte) hash value used to check that the image contents have not been corrupted.
-config FIT_ENABLE_SHA384_SUPPORT +config FIT_SHA384 bool "Support SHA384 checksum of FIT image contents" default n select SHA384 @@ -54,7 +54,7 @@ config FIT_ENABLE_SHA384_SUPPORT the image contents have not been corrupted. Use this for the highest security.
-config FIT_ENABLE_SHA512_SUPPORT +config FIT_SHA512 bool "Support SHA512 checksum of FIT image contents" default n select SHA512 diff --git a/configs/mt8516_pumpkin_defconfig b/configs/mt8516_pumpkin_defconfig index 5270ec28cbd..d330c03db3c 100644 --- a/configs/mt8516_pumpkin_defconfig +++ b/configs/mt8516_pumpkin_defconfig @@ -13,7 +13,7 @@ CONFIG_DEBUG_UART_CLOCK=26000000 CONFIG_DEFAULT_DEVICE_TREE="mt8516-pumpkin" CONFIG_DEBUG_UART=y CONFIG_FIT=y -# CONFIG_FIT_ENABLE_SHA256_SUPPORT is not set +# CONFIG_FIT_SHA256 is not set # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_DEFAULT_FDT_FILE="mt8516-pumpkin" # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/include/image.h b/include/image.h index 459685d4d43..9319a779b93 100644 --- a/include/image.h +++ b/include/image.h @@ -31,9 +31,9 @@ struct fdt_region; #define IMAGE_ENABLE_OF_LIBFDT 1 #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ #define CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT 1 -#define CONFIG_FIT_ENABLE_SHA256_SUPPORT -#define CONFIG_FIT_ENABLE_SHA384_SUPPORT -#define CONFIG_FIT_ENABLE_SHA512_SUPPORT +#define CONFIG_FIT_SHA256 +#define CONFIG_FIT_SHA384 +#define CONFIG_FIT_SHA512 #define CONFIG_SHA1 #define CONFIG_SHA256 #define CONFIG_SHA384 @@ -89,21 +89,21 @@ struct fdt_region; #define IMAGE_ENABLE_SHA1 0 #endif
-#if defined(CONFIG_FIT_ENABLE_SHA256_SUPPORT) || \ +#if defined(CONFIG_FIT_SHA256) || \ defined(CONFIG_SPL_SHA256_SUPPORT) #define IMAGE_ENABLE_SHA256 1 #else #define IMAGE_ENABLE_SHA256 0 #endif
-#if defined(CONFIG_FIT_ENABLE_SHA384_SUPPORT) || \ +#if defined(CONFIG_FIT_SHA384) || \ defined(CONFIG_SPL_SHA384_SUPPORT) #define IMAGE_ENABLE_SHA384 1 #else #define IMAGE_ENABLE_SHA384 0 #endif
-#if defined(CONFIG_FIT_ENABLE_SHA512_SUPPORT) || \ +#if defined(CONFIG_FIT_SHA512) || \ defined(CONFIG_SPL_SHA512_SUPPORT) #define IMAGE_ENABLE_SHA512 1 #else
These option are named inconsistently with other SPL options, thus making them incompatible with the CONFIG_IS_ENABLED() macro. Rename them.
common/spl/Kconfig | 8 ++++---- include/image.h | 8 ++++---- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index df5468f1ac2..d94b9892175 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -429,7 +429,7 @@ config SPL_MD5_SUPPORT applications where images may be changed maliciously, you should consider SHA256 or SHA384.
-config SPL_SHA1_SUPPORT +config SPL_FIT_SHA1 bool "Support SHA1" depends on SPL_FIT select SHA1 @@ -441,7 +441,7 @@ config SPL_SHA1_SUPPORT due to the expanding computing power available to brute-force attacks. For more security, consider SHA256 or SHA384.
-config SPL_SHA256_SUPPORT +config SPL_FIT_SHA256 bool "Support SHA256" depends on SPL_FIT select SHA256 @@ -450,7 +450,7 @@ config SPL_SHA256_SUPPORT checksum is a 256-bit (32-byte) hash value used to check that the image contents have not been corrupted.
-config SPL_SHA384_SUPPORT +config SPL_FIT_SHA384 bool "Support SHA384" depends on SPL_FIT select SHA384 @@ -461,7 +461,7 @@ config SPL_SHA384_SUPPORT image contents have not been corrupted. Use this for the highest security.
-config SPL_SHA512_SUPPORT +config SPL_FIT_SHA512 bool "Support SHA512" depends on SPL_FIT select SHA512 diff --git a/include/image.h b/include/image.h index 9319a779b93..3284f36c97a 100644 --- a/include/image.h +++ b/include/image.h @@ -68,7 +68,7 @@ struct fdt_region; # ifdef CONFIG_SPL_MD5_SUPPORT # define IMAGE_ENABLE_MD5 1 # endif -# ifdef CONFIG_SPL_SHA1_SUPPORT +# ifdef CONFIG_SPL_FIT_SHA1 # define IMAGE_ENABLE_SHA1 1 # endif # else @@ -90,21 +90,21 @@ struct fdt_region; #endif
#if defined(CONFIG_FIT_SHA256) || \ - defined(CONFIG_SPL_SHA256_SUPPORT) + defined(CONFIG_SPL_FIT_SHA256) #define IMAGE_ENABLE_SHA256 1 #else #define IMAGE_ENABLE_SHA256 0 #endif
#if defined(CONFIG_FIT_SHA384) || \ - defined(CONFIG_SPL_SHA384_SUPPORT) + defined(CONFIG_SPL_FIT_SHA384) #define IMAGE_ENABLE_SHA384 1 #else #define IMAGE_ENABLE_SHA384 0 #endif
#if defined(CONFIG_FIT_SHA512) || \ - defined(CONFIG_SPL_SHA512_SUPPORT) + defined(CONFIG_SPL_FIT_SHA512) #define IMAGE_ENABLE_SHA512 1 #else #define IMAGE_ENABLE_SHA512 0
At present when building host tools, we force CONFIG_SHA1 to be enabled regardless of the board Kconfig setting. This is done in the image.h header file.
Clean this up by adding new Kconfig options to enable hashing on the host, relying on CONFIG_IS_ENABLED() to deal with the different builds.
common/hash.c | 37 +++++++++++++++++++------------------ include/image.h | 4 ---- tools/Kconfig | 20 ++++++++++++++++++++ 3 files changed, 39 insertions(+), 22 deletions(-)
diff --git a/common/hash.c b/common/hash.c index 10dff7ddb0e..987d238c66c 100644 --- a/common/hash.c +++ b/common/hash.c @@ -25,6 +25,7 @@ #else #include "mkimage.h" #include <time.h> +#include <linux/kconfig.h> #endif /* !USE_HOSTCC*/
#include <hash.h> @@ -41,7 +42,7 @@ DECLARE_GLOBAL_DATA_PTR;
static void reloc_update(void);
-#if defined(CONFIG_SHA1) && !defined(CONFIG_SHA_PROG_HW_ACCEL) +#if CONFIG_IS_ENABLED(SHA1) && !CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) static int hash_init_sha1(struct hash_algo *algo, void **ctxp) { sha1_context *ctx = malloc(sizeof(sha1_context)); @@ -69,7 +70,7 @@ static int hash_finish_sha1(struct hash_algo *algo, void *ctx, void *dest_buf, } #endif
-#if defined(CONFIG_SHA256) && !defined(CONFIG_SHA_PROG_HW_ACCEL) +#if CONFIG_IS_ENABLED(SHA256) && !CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) static int hash_init_sha256(struct hash_algo *algo, void **ctxp) { sha256_context *ctx = malloc(sizeof(sha256_context)); @@ -97,7 +98,7 @@ static int hash_finish_sha256(struct hash_algo *algo, void *ctx, void } #endif
-#if defined(CONFIG_SHA384) && !defined(CONFIG_SHA_PROG_HW_ACCEL) +#if CONFIG_IS_ENABLED(SHA384) && !CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) static int hash_init_sha384(struct hash_algo *algo, void **ctxp) { sha512_context *ctx = malloc(sizeof(sha512_context)); @@ -125,7 +126,7 @@ static int hash_finish_sha384(struct hash_algo *algo, void *ctx, void } #endif
-#if defined(CONFIG_SHA512) && !defined(CONFIG_SHA_PROG_HW_ACCEL) +#if CONFIG_IS_ENABLED(SHA512) && !CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) static int hash_init_sha512(struct hash_algo *algo, void **ctxp) { sha512_context *ctx = malloc(sizeof(sha512_context)); @@ -213,17 +214,17 @@ static int hash_finish_crc32(struct hash_algo *algo, void *ctx, void *dest_buf, * Note that algorithm names must be in lower case. */ static struct hash_algo hash_algo[] = { -#ifdef CONFIG_SHA1 +#if CONFIG_IS_ENABLED(SHA1) { .name = "sha1", .digest_size = SHA1_SUM_LEN, .chunk_size = CHUNKSZ_SHA1, -#ifdef CONFIG_SHA_HW_ACCEL +#if CONFIG_IS_ENABLED(SHA_HW_ACCEL) .hash_func_ws = hw_sha1, #else .hash_func_ws = sha1_csum_wd, #endif -#ifdef CONFIG_SHA_PROG_HW_ACCEL +#if CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) .hash_init = hw_sha_init, .hash_update = hw_sha_update, .hash_finish = hw_sha_finish, @@ -234,17 +235,17 @@ static struct hash_algo hash_algo[] = { #endif }, #endif -#ifdef CONFIG_SHA256 +#if CONFIG_IS_ENABLED(SHA256) { .name = "sha256", .digest_size = SHA256_SUM_LEN, .chunk_size = CHUNKSZ_SHA256, -#ifdef CONFIG_SHA_HW_ACCEL +#if CONFIG_IS_ENABLED(SHA_HW_ACCEL) .hash_func_ws = hw_sha256, #else .hash_func_ws = sha256_csum_wd, #endif -#ifdef CONFIG_SHA_PROG_HW_ACCEL +#if CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) .hash_init = hw_sha_init, .hash_update = hw_sha_update, .hash_finish = hw_sha_finish, @@ -255,17 +256,17 @@ static struct hash_algo hash_algo[] = { #endif }, #endif -#ifdef CONFIG_SHA384 +#if CONFIG_IS_ENABLED(SHA384) { .name = "sha384", .digest_size = SHA384_SUM_LEN, .chunk_size = CHUNKSZ_SHA384, -#ifdef CONFIG_SHA_HW_ACCEL +#if CONFIG_IS_ENABLED(SHA_HW_ACCEL) .hash_func_ws = hw_sha384, #else .hash_func_ws = sha384_csum_wd, #endif -#ifdef CONFIG_SHA_PROG_HW_ACCEL +#if CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) .hash_init = hw_sha_init, .hash_update = hw_sha_update, .hash_finish = hw_sha_finish, @@ -276,17 +277,17 @@ static struct hash_algo hash_algo[] = { #endif }, #endif -#ifdef CONFIG_SHA512 +#if CONFIG_IS_ENABLED(SHA512) { .name = "sha512", .digest_size = SHA512_SUM_LEN, .chunk_size = CHUNKSZ_SHA512, -#ifdef CONFIG_SHA_HW_ACCEL +#if CONFIG_IS_ENABLED(SHA_HW_ACCEL) .hash_func_ws = hw_sha512, #else .hash_func_ws = sha512_csum_wd, #endif -#ifdef CONFIG_SHA_PROG_HW_ACCEL +#if CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) .hash_init = hw_sha_init, .hash_update = hw_sha_update, .hash_finish = hw_sha_finish, @@ -318,9 +319,9 @@ static struct hash_algo hash_algo[] = { };
/* Try to minimize code size for boards that don't want much hashing */ -#if defined(CONFIG_SHA256) || defined(CONFIG_CMD_SHA1SUM) || \ +#if CONFIG_IS_ENABLED(SHA256) || defined(CONFIG_CMD_SHA1SUM) || \ defined(CONFIG_CRC32_VERIFY) || defined(CONFIG_CMD_HASH) || \ - defined(CONFIG_SHA384) || defined(CONFIG_SHA512) + CONFIG_IS_ENABLED(SHA384) || CONFIG_IS_ENABLED(SHA512) #define multi_hash() 1 #else #define multi_hash() 0 diff --git a/include/image.h b/include/image.h index 3284f36c97a..61da0abace7 100644 --- a/include/image.h +++ b/include/image.h @@ -34,10 +34,6 @@ struct fdt_region; #define CONFIG_FIT_SHA256 #define CONFIG_FIT_SHA384 #define CONFIG_FIT_SHA512 -#define CONFIG_SHA1 -#define CONFIG_SHA256 -#define CONFIG_SHA384 -#define CONFIG_SHA512
#define IMAGE_ENABLE_IGNORE 0 #define IMAGE_INDENT_STRING "" diff --git a/tools/Kconfig b/tools/Kconfig index f00ab661135..5c3e485a298 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -34,4 +34,24 @@ config HOST_FIT_SIGNATURE_MAX_SIZE depends on HOST_FIT_SIGNATURE default 0x10000000
+config HOST_SHA1 + def_bool y + help + Enable SHA1 support in the host build. + +config HOST_SHA256 + def_bool y + help + Enable SHA256 support in the host build. + +config HOST_SHA384 + def_bool y + help + Enable SHA384 support in the host build. + +config HOST_SHA512 + def_bool y + help + Enable SHA512 support in the host build. + endmenu
We can use the __maybe_unused attribute to avoid some of the #ifdefs in this file. Update the functions accordingly.
Note: The actual hashing interface is still a mess, with four separate combinations and lots of #ifdefs. This should really use a driver approach, e.g. as is done with partition drivers.
common/hash.c | 54 ++++++++++++++++++++++++--------------------------- 1 file changed, 25 insertions(+), 29 deletions(-)
diff --git a/common/hash.c b/common/hash.c index 987d238c66c..1ccc62f162d 100644 --- a/common/hash.c +++ b/common/hash.c @@ -24,6 +24,7 @@ #include <u-boot/crc.h> #else #include "mkimage.h" +#include <linux/compiler_attributes.h> #include <time.h> #include <linux/kconfig.h> #endif /* !USE_HOSTCC*/ @@ -42,8 +43,7 @@ DECLARE_GLOBAL_DATA_PTR;
-#if CONFIG_IS_ENABLED(SHA1) && !CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) -static int hash_init_sha1(struct hash_algo *algo, void **ctxp) +static int __maybe_unused hash_init_sha1(struct hash_algo *algo, void **ctxp) { sha1_context *ctx = malloc(sizeof(sha1_context)); sha1_starts(ctx); @@ -51,15 +51,16 @@ static int hash_init_sha1(struct hash_algo *algo, void **ctxp) return 0; }
-static int hash_update_sha1(struct hash_algo *algo, void *ctx, const void *buf, - unsigned int size, int is_last) +static int __maybe_unused hash_update_sha1(struct hash_algo *algo, void *ctx, + const void *buf, unsigned int size, + int is_last) { sha1_update((sha1_context *)ctx, buf, size); return 0; }
-static int hash_finish_sha1(struct hash_algo *algo, void *ctx, void *dest_buf, - int size) +static int __maybe_unused hash_finish_sha1(struct hash_algo *algo, void *ctx, + void *dest_buf, int size) { if (size < algo->digest_size) return -1; @@ -68,10 +69,8 @@ static int hash_finish_sha1(struct hash_algo *algo, void *ctx, void *dest_buf, free(ctx); return 0; } -#endif
-#if CONFIG_IS_ENABLED(SHA256) && !CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) -static int hash_init_sha256(struct hash_algo *algo, void **ctxp) +static int __maybe_unused hash_init_sha256(struct hash_algo *algo, void **ctxp) { sha256_context *ctx = malloc(sizeof(sha256_context)); sha256_starts(ctx); @@ -79,15 +78,16 @@ static int hash_init_sha256(struct hash_algo *algo, void **ctxp) return 0; }
-static int hash_update_sha256(struct hash_algo *algo, void *ctx, - const void *buf, unsigned int size, int is_last) +static int __maybe_unused hash_update_sha256(struct hash_algo *algo, void *ctx, + const void *buf, uint size, + int is_last) { sha256_update((sha256_context *)ctx, buf, size); return 0; }
-static int hash_finish_sha256(struct hash_algo *algo, void *ctx, void - *dest_buf, int size) +static int __maybe_unused hash_finish_sha256(struct hash_algo *algo, void *ctx, + void *dest_buf, int size) { if (size < algo->digest_size) return -1; @@ -96,10 +96,8 @@ static int hash_finish_sha256(struct hash_algo *algo, void *ctx, void free(ctx); return 0; } -#endif
-#if CONFIG_IS_ENABLED(SHA384) && !CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) -static int hash_init_sha384(struct hash_algo *algo, void **ctxp) +static int __maybe_unused hash_init_sha384(struct hash_algo *algo, void **ctxp) { sha512_context *ctx = malloc(sizeof(sha512_context)); sha384_starts(ctx); @@ -107,15 +105,16 @@ static int hash_init_sha384(struct hash_algo *algo, void **ctxp) return 0; }
-static int hash_update_sha384(struct hash_algo *algo, void *ctx, - const void *buf, unsigned int size, int is_last) +static int __maybe_unused hash_update_sha384(struct hash_algo *algo, void *ctx, + const void *buf, uint size, + int is_last) { sha384_update((sha512_context *)ctx, buf, size); return 0; }
-static int hash_finish_sha384(struct hash_algo *algo, void *ctx, void - *dest_buf, int size) +static int __maybe_unused hash_finish_sha384(struct hash_algo *algo, void *ctx, + void *dest_buf, int size) { if (size < algo->digest_size) return -1; @@ -124,10 +123,8 @@ static int hash_finish_sha384(struct hash_algo *algo, void *ctx, void free(ctx); return 0; } -#endif
-#if CONFIG_IS_ENABLED(SHA512) && !CONFIG_IS_ENABLED(SHA_PROG_HW_ACCEL) -static int hash_init_sha512(struct hash_algo *algo, void **ctxp) +static int __maybe_unused hash_init_sha512(struct hash_algo *algo, void **ctxp) { sha512_context *ctx = malloc(sizeof(sha512_context)); sha512_starts(ctx); @@ -135,15 +132,16 @@ static int hash_init_sha512(struct hash_algo *algo, void **ctxp) return 0; }
-static int hash_update_sha512(struct hash_algo *algo, void *ctx, - const void *buf, unsigned int size, int is_last) +static int __maybe_unused hash_update_sha512(struct hash_algo *algo, void *ctx, + const void *buf, uint size, + int is_last) { sha512_update((sha512_context *)ctx, buf, size); return 0; }
-static int hash_finish_sha512(struct hash_algo *algo, void *ctx, void - *dest_buf, int size) +static int __maybe_unused hash_finish_sha512(struct hash_algo *algo, void *ctx, + void *dest_buf, int size) { if (size < algo->digest_size) return -1; @@ -152,8 +150,6 @@ static int hash_finish_sha512(struct hash_algo *algo, void *ctx, void free(ctx); return 0; } -#endif -
static int hash_init_crc16_ccitt(struct hash_algo *algo, void **ctxp) {
Make use of the host Kconfig for FIT. With this we can use CONFIG_IS_ENABLED(FIT) directly in the host build, so drop the unnecessary indirection.
arch/arm/mach-imx/hab.c | 2 +- common/bootm.c | 10 +++++----- common/image-board.c | 16 ++++++++-------- common/image.c | 2 +- include/fdt_support.h | 2 +- include/image.h | 22 +++++++++------------- tools/Kconfig | 20 ++++++++++++++++++++ 7 files changed, 45 insertions(+), 29 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 00bd157d0e0..cf522226f67 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -591,7 +591,7 @@ static ulong get_image_ivt_offset(ulong img_addr) return (image_get_image_size((image_header_t *)img_addr) + 0x1000 - 1) & ~(0x1000 - 1); #endif -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) case IMAGE_FORMAT_FIT: return (fit_get_size(buf) + 0x1000 - 1) & ~(0x1000 - 1); #endif diff --git a/common/bootm.c b/common/bootm.c index fe17d1da9e5..8d614fe140e 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -115,7 +115,7 @@ static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc, images.os.arch = image_get_arch(os_hdr); break; #endif -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) case IMAGE_FORMAT_FIT: if (fit_image_get_type(images.fit_hdr_os, images.fit_noffset_os, @@ -187,7 +187,7 @@ static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc, /* Kernel entry point is the setup.bin */ } else if (images.legacy_hdr_valid) { images.ep = image_get_ep(&images.legacy_hdr_os_copy); -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) } else if (images.fit_uname_os) { int ret;
@@ -295,7 +295,7 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, set_working_fdt_addr(map_to_sysmem(images.ft_addr)); #endif
-#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) if (IS_ENABLED(CONFIG_FPGA)) { /* find bitstreams */ ret = boot_get_fpga(argc, argv, &images, IH_ARCH_DEFAULT, @@ -858,7 +858,7 @@ static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, const void *buf; const char *fit_uname_config = NULL; const char *fit_uname_kernel = NULL; -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) int os_noffset; #endif
@@ -916,7 +916,7 @@ static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, bootstage_mark(BOOTSTAGE_ID_DECOMP_IMAGE); break; #endif -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) case IMAGE_FORMAT_FIT: os_noffset = fit_image_load(images, img_addr, &fit_uname_kernel, &fit_uname_config, diff --git a/common/image-board.c b/common/image-board.c index 0f41ede1e98..05eeaaac8b0 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -282,7 +282,7 @@ int genimg_get_format(const void *img_addr) if (image_check_magic(hdr)) return IMAGE_FORMAT_LEGACY; #endif -#if IMAGE_ENABLE_FIT || IMAGE_ENABLE_OF_LIBFDT +#if CONFIG_IS_ENABLED(FIT) || IMAGE_ENABLE_OF_LIBFDT if (fdt_check_header(img_addr) == 0) return IMAGE_FORMAT_FIT; #endif @@ -307,7 +307,7 @@ int genimg_get_format(const void *img_addr) */ int genimg_has_config(bootm_headers_t *images) { -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) if (images->fit_uname_cfg) return 1; #endif @@ -348,7 +348,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, #ifdef CONFIG_SUPPORT_RAW_INITRD char *end; #endif -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) const char *fit_uname_config = images->fit_uname_cfg; const char *fit_uname_ramdisk = NULL; ulong default_addr; @@ -380,7 +380,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, rd_len = 0; rd_data = 0; } else if (select || genimg_has_config(images)) { -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) if (select) { /* * If the init ramdisk comes from the FIT image and @@ -409,7 +409,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, debug("* ramdisk: cmdline image address = 0x%08lx\n", rd_addr); } -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) } else { /* use FIT configuration provided in first bootm * command argument. If the property is not defined, @@ -450,7 +450,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, rd_load = image_get_load(rd_hdr); break; #endif -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) case IMAGE_FORMAT_FIT: rd_noffset = fit_image_load(images, rd_addr, &fit_uname_ramdisk, @@ -623,14 +623,14 @@ error: int boot_get_setup(bootm_headers_t *images, u8 arch, ulong *setup_start, ulong *setup_len) { -#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) return boot_get_setup_fit(images, arch, setup_start, setup_len); #else return -ENOENT; #endif }
-#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) #if defined(CONFIG_FPGA) int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, u8 arch, const ulong *ld_start, ulong * const ld_len) diff --git a/common/image.c b/common/image.c index 086ae609f29..f105b5e8857 100644 --- a/common/image.c +++ b/common/image.c @@ -18,7 +18,7 @@ #include <status_led.h> #endif
-#if IMAGE_ENABLE_FIT || IMAGE_ENABLE_OF_LIBFDT +#if CONFIG_IS_ENABLED(FIT) || IMAGE_ENABLE_OF_LIBFDT #include <linux/libfdt.h> #include <fdt_support.h> #endif diff --git a/include/fdt_support.h b/include/fdt_support.h index 46eb1dbbb24..9b2929a982e 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -7,7 +7,7 @@ #ifndef __FDT_SUPPORT_H #define __FDT_SUPPORT_H
-#ifdef CONFIG_OF_LIBFDT +#if !defined(USE_HOSTCC) && defined(CONFIG_OF_LIBFDT)
#include <asm/u-boot.h> #include <linux/libfdt.h> diff --git a/include/image.h b/include/image.h index 61da0abace7..522e9dbff5f 100644 --- a/include/image.h +++ b/include/image.h @@ -25,15 +25,12 @@ struct fdt_region;
#ifdef USE_HOSTCC #include <sys/types.h> +#include <linux/kconfig.h>
/* new uImage format support enabled on host */ -#define IMAGE_ENABLE_FIT 1 #define IMAGE_ENABLE_OF_LIBFDT 1 #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ #define CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT 1 -#define CONFIG_FIT_SHA256 -#define CONFIG_FIT_SHA384 -#define CONFIG_FIT_SHA512
#define IMAGE_ENABLE_IGNORE 0 #define IMAGE_INDENT_STRING "" @@ -48,12 +45,11 @@ struct fdt_region; #define IMAGE_ENABLE_IGNORE 1 #define IMAGE_INDENT_STRING " "
-#define IMAGE_ENABLE_FIT CONFIG_IS_ENABLED(FIT) #define IMAGE_ENABLE_OF_LIBFDT CONFIG_IS_ENABLED(OF_LIBFDT)
#endif /* USE_HOSTCC */
-#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) #include <hash.h> #include <linux/libfdt.h> #include <fdt_support.h> @@ -106,7 +102,7 @@ struct fdt_region; #define IMAGE_ENABLE_SHA512 0 #endif
-#endif /* IMAGE_ENABLE_FIT */ +#endif /* FIT */
#ifdef CONFIG_SYS_BOOT_GET_CMDLINE # define IMAGE_BOOT_GET_CMDLINE 1 @@ -379,7 +375,7 @@ typedef struct bootm_headers { image_header_t legacy_hdr_os_copy; /* header copy */ ulong legacy_hdr_valid;
-#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) const char *fit_uname_cfg; /* configuration node unit name */
void *fit_hdr_os; /* os FIT image header */ @@ -1034,7 +1030,7 @@ int booti_setup(ulong image, ulong *relocated_addr, ulong *size,
#define FIT_MAX_HASH_LEN HASH_MAX_DIGEST_SIZE
-#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) /* cmdline argument format parsing */ int fit_parse_conf(const char *spec, ulong addr_curr, ulong *addr, const char **conf_name); @@ -1208,7 +1204,7 @@ int fit_conf_get_prop_node(const void *fit, int noffset,
int fit_check_ramdisk(const void *fit, int os_noffset, uint8_t arch, int verify); -#endif /* IMAGE_ENABLE_FIT */ +#endif /* FIT */
int calculate_hash(const void *data, int data_len, const char *algo, uint8_t *value, int *value_len); @@ -1237,7 +1233,7 @@ int calculate_hash(const void *data, int data_len, const char *algo, # define FIT_IMAGE_ENABLE_VERIFY CONFIG_IS_ENABLED(FIT_SIGNATURE) #endif
-#if IMAGE_ENABLE_FIT +#if CONFIG_IS_ENABLED(FIT) #ifdef USE_HOSTCC void *image_get_host_blob(void); void image_set_host_blob(void *host_blob); @@ -1251,7 +1247,7 @@ void image_set_host_blob(void *host_blob); #else #define IMAGE_ENABLE_BEST_MATCH 0 #endif -#endif /* IMAGE_ENABLE_FIT */ +#endif /* FIT */
/* * Information passed to the signing routines @@ -1389,7 +1385,7 @@ struct crypto_algo *image_get_crypto_algo(const char *full_name); */ struct padding_algo *image_get_padding_algo(const char *name);
/** * fit_image_verify_required_sigs() - Verify signatures marked as 'required' diff --git a/tools/Kconfig b/tools/Kconfig index 5c3e485a298..8af66a51c09 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -24,6 +24,26 @@ config HOST_FIT_PRINT help Print the content of the FIT verbosely in the host build
+config HOST_FIT_SHA1 + def_bool y + help + Support SHA256 checksum of FIT image contents in the host build + +config HOST_FIT_SHA256 + def_bool y + help + Support SHA256 checksum of FIT image contents in the host build + +config HOST_FIT_SHA384 + def_bool y + help + Support SHA384 checksum of FIT image contents in the host build + +config HOST_FIT_SHA512 + def_bool y + help + Support SHA512 checksum of FIT image contents in the host build + config HOST_FIT_SIGNATURE def_bool y help
Add a host Kconfig for OF_LIBFDT. With this we can use CONFIG_IS_ENABLED(OF_LIBFDT) directly in the host build, so drop the unnecessary indirection.
arch/arc/lib/bootm.c | 2 +- arch/arm/lib/bootm.c | 4 ++-- arch/microblaze/lib/bootm.c | 2 +- arch/nds32/lib/bootm.c | 4 ++-- arch/riscv/lib/bootm.c | 4 ++-- board/synopsys/hsdk/hsdk.c | 2 +- common/bootm.c | 4 ++-- common/image-board.c | 8 ++++---- common/image.c | 2 +- include/image.h | 3 --- lib/lmb.c | 2 +- tools/Kconfig | 5 +++++ 12 files changed, 22 insertions(+), 20 deletions(-)
diff --git a/arch/arc/lib/bootm.c b/arch/arc/lib/bootm.c index 8a8d394a5f0..2e139611e59 100644 --- a/arch/arc/lib/bootm.c +++ b/arch/arc/lib/bootm.c @@ -93,7 +93,7 @@ static void boot_jump_linux(bootm_headers_t *images, int flag) "(fake run for tracing)" : ""); bootstage_mark_name(BOOTSTAGE_ID_BOOTM_HANDOFF, "start_kernel");
- if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) { r0 = 2; r2 = (unsigned int)images->ft_addr; } else { diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index f60ee3a7e6a..493c9e1df19 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -244,7 +244,7 @@ static void boot_prep_linux(bootm_headers_t *images) { char *commandline = env_get("bootargs");
- if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) { #ifdef CONFIG_OF_LIBFDT debug("using: FDT\n"); if (image_setup_linux(images)) { @@ -401,7 +401,7 @@ static void boot_jump_linux(bootm_headers_t *images, int flag) bootstage_mark(BOOTSTAGE_ID_RUN_OS); announce_and_cleanup(fake);
- if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) + if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) r2 = (unsigned long)images->ft_addr; else r2 = gd->bd->bi_boot_params; diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index 6695ac63c77..1e041fb5685 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -101,7 +101,7 @@ static void boot_jump_linux(bootm_headers_t *images, int flag)
static void boot_prep_linux(bootm_headers_t *images) { - if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) { debug("using: FDT\n"); if (image_setup_linux(images)) { printf("FDT creation failed! hanging..."); diff --git a/arch/nds32/lib/bootm.c b/arch/nds32/lib/bootm.c index b3b8bc29037..394564a3f5b 100644 --- a/arch/nds32/lib/bootm.c +++ b/arch/nds32/lib/bootm.c @@ -73,7 +73,7 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) debug("## Transferring control to Linux (at address %08lx) ...\n", (ulong)theKernel);
- if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) { #ifdef CONFIG_OF_LIBFDT debug("using: FDT\n"); if (image_setup_linux(images)) { @@ -118,7 +118,7 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) #endif } cleanup_before_linux(); - if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) + if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) theKernel(0, machid, (unsigned long)images->ft_addr); else theKernel(0, machid, bd->bi_boot_params); diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index 8dd18205403..6c9e7eb6547 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -64,7 +64,7 @@ static void announce_and_cleanup(int fake)
static void boot_prep_linux(bootm_headers_t *images) { - if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) { #ifdef CONFIG_OF_LIBFDT debug("using: FDT\n"); if (image_setup_linux(images)) { @@ -96,7 +96,7 @@ static void boot_jump_linux(bootm_headers_t *images, int flag) announce_and_cleanup(fake);
if (!fake) { - if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) { #ifdef CONFIG_SMP ret = smp_call_function(images->ep, (ulong)images->ft_addr, 0, 0); diff --git a/board/synopsys/hsdk/hsdk.c b/board/synopsys/hsdk/hsdk.c index 892b94bb083..226fbba6296 100644 --- a/board/synopsys/hsdk/hsdk.c +++ b/board/synopsys/hsdk/hsdk.c @@ -871,7 +871,7 @@ int board_prep_linux(bootm_headers_t *images) if (env_common.core_mask.val == ALL_CPU_MASK) return 0;
- if (!IMAGE_ENABLE_OF_LIBFDT || !images->ft_len) { + if (!CONFIG_IS_ENABLED(OF_LIBFDT) || !images->ft_len) { pr_err("WARN: core_mask setup will work properly only with external DTB!\n"); return 0; } diff --git a/common/bootm.c b/common/bootm.c index 8d614fe140e..4482f84b40a 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -271,7 +271,7 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, return 1; }
-#if IMAGE_ENABLE_OF_LIBFDT +#if CONFIG_IS_ENABLED(OF_LIBFDT) /* find flattened device tree */ ret = boot_get_fdt(flag, argc, argv, IH_ARCH_DEFAULT, &images, &images.ft_addr, &images.ft_len); @@ -706,7 +706,7 @@ int do_bootm_states(struct cmd_tbl *cmdtp, int flag, int argc, } } #endif -#if IMAGE_ENABLE_OF_LIBFDT && defined(CONFIG_LMB) +#if CONFIG_IS_ENABLED(OF_LIBFDT) && defined(CONFIG_LMB) if (!ret && (states & BOOTM_STATE_FDT)) { boot_fdt_add_mem_rsv_regions(&images->lmb, images->ft_addr); ret = boot_relocate_fdt(&images->lmb, &images->ft_addr, diff --git a/common/image-board.c b/common/image-board.c index 05eeaaac8b0..0b9809c3f6b 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -282,7 +282,7 @@ int genimg_get_format(const void *img_addr) if (image_check_magic(hdr)) return IMAGE_FORMAT_LEGACY; #endif -#if CONFIG_IS_ENABLED(FIT) || IMAGE_ENABLE_OF_LIBFDT +#if CONFIG_IS_ENABLED(FIT) || CONFIG_IS_ENABLED(OF_LIBFDT) if (fdt_check_header(img_addr) == 0) return IMAGE_FORMAT_FIT; #endif @@ -895,7 +895,7 @@ int image_setup_linux(bootm_headers_t *images) struct lmb *lmb = &images->lmb; int ret;
- if (IMAGE_ENABLE_OF_LIBFDT) + if (CONFIG_IS_ENABLED(OF_LIBFDT)) boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree);
if (IMAGE_BOOT_GET_CMDLINE) { @@ -907,13 +907,13 @@ int image_setup_linux(bootm_headers_t *images) } }
- if (IMAGE_ENABLE_OF_LIBFDT) { + if (CONFIG_IS_ENABLED(OF_LIBFDT)) { ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); if (ret) return ret; }
- if (IMAGE_ENABLE_OF_LIBFDT && of_size) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && of_size) { ret = image_setup_libfdt(images, *of_flat_tree, of_size, lmb); if (ret) return ret; diff --git a/common/image.c b/common/image.c index f105b5e8857..9531a6d6820 100644 --- a/common/image.c +++ b/common/image.c @@ -18,7 +18,7 @@ #include <status_led.h> #endif
-#if CONFIG_IS_ENABLED(FIT) || IMAGE_ENABLE_OF_LIBFDT +#if CONFIG_IS_ENABLED(FIT) || CONFIG_IS_ENABLED(OF_LIBFDT) #include <linux/libfdt.h> #include <fdt_support.h> #endif diff --git a/include/image.h b/include/image.h index 522e9dbff5f..bdf19a4cc04 100644 --- a/include/image.h +++ b/include/image.h @@ -28,7 +28,6 @@ struct fdt_region; #include <linux/kconfig.h>
/* new uImage format support enabled on host */ -#define IMAGE_ENABLE_OF_LIBFDT 1 #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ #define CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT 1
@@ -45,8 +44,6 @@ struct fdt_region; #define IMAGE_ENABLE_IGNORE 1 #define IMAGE_INDENT_STRING " "
-#define IMAGE_ENABLE_OF_LIBFDT CONFIG_IS_ENABLED(OF_LIBFDT) - #endif /* USE_HOSTCC */
#if CONFIG_IS_ENABLED(FIT) diff --git a/lib/lmb.c b/lib/lmb.c index c08c4d942b7..d50beffab78 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -113,7 +113,7 @@ static void lmb_reserve_common(struct lmb *lmb, void *fdt_blob) arch_lmb_reserve(lmb); board_lmb_reserve(lmb);
- if (IMAGE_ENABLE_OF_LIBFDT && fdt_blob) + if (CONFIG_IS_ENABLED(OF_LIBFDT) && fdt_blob) boot_fdt_add_mem_rsv_regions(lmb, fdt_blob); }
diff --git a/tools/Kconfig b/tools/Kconfig index 8af66a51c09..c67dc04f5ed 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -54,6 +54,11 @@ config HOST_FIT_SIGNATURE_MAX_SIZE depends on HOST_FIT_SIGNATURE default 0x10000000
+config HOST_OF_LIBFDT + def_bool y + help + Enable libfdt support in the host build. + config HOST_SHA1 def_bool y help
Add a host Kconfig for FIT_VERBOSE. With this we can use CONFIG_IS_ENABLED(FIT_VERBOSE) directly in the host build, so drop the forcing of this in the image.h header.
(no changes since v1)
include/image.h | 5 ++--- tools/Kconfig | 5 +++++ 2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/include/image.h b/include/image.h index bdf19a4cc04..b08ae2bb6c0 100644 --- a/include/image.h +++ b/include/image.h @@ -28,7 +28,6 @@ struct fdt_region; #include <linux/kconfig.h>
/* new uImage format support enabled on host */ -#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ #define CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT 1
#define IMAGE_ENABLE_IGNORE 0 @@ -1509,7 +1508,7 @@ int fit_image_cipher_get_algo(const void *fit, int noffset, char **algo);
struct cipher_algo *image_get_cipher_algo(const char *full_name);
-#ifdef CONFIG_FIT_VERBOSE +#if CONFIG_IS_ENABLED(FIT_VERBOSE) #define fit_unsupported(msg) printf("! %s:%d " \ "FIT images not supported for '%s'\n", \ __FILE__, __LINE__, (msg)) @@ -1521,7 +1520,7 @@ struct cipher_algo *image_get_cipher_algo(const char *full_name); #else #define fit_unsupported(msg) #define fit_unsupported_reset(msg) -#endif /* CONFIG_FIT_VERBOSE */ +#endif /* FIT_VERBOSE */ #endif /* CONFIG_FIT */
#if !defined(USE_HOSTCC) diff --git a/tools/Kconfig b/tools/Kconfig index c67dc04f5ed..6d0f4565a80 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -54,6 +54,11 @@ config HOST_FIT_SIGNATURE_MAX_SIZE depends on HOST_FIT_SIGNATURE default 0x10000000
+config HOST_FIT_VERBOSE + def_bool y + help + Support verbose FIT output in the host build + config HOST_OF_LIBFDT def_bool y help
Drop the ENABLE and SUPPORT parts of this, which are redundant.
common/Kconfig.boot | 2 +- common/image-sig.c | 4 ++-- configs/bcm963158_ram_defconfig | 2 +- configs/sandbox_defconfig | 2 +- include/image.h | 2 +- include/u-boot/rsa.h | 8 ++++---- lib/rsa/rsa-sign.c | 4 ++-- lib/rsa/rsa-verify.c | 2 +- 8 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/common/Kconfig.boot b/common/Kconfig.boot index af3325a7ce2..03a6e6f214f 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -103,7 +103,7 @@ config FIT_SIGNATURE_MAX_SIZE device memory. Assure this size does not extend past expected storage space.
-config FIT_ENABLE_RSASSA_PSS_SUPPORT +config FIT_RSASSA_PSS bool "Support rsassa-pss signature scheme of FIT image contents" depends on FIT_SIGNATURE default n diff --git a/common/image-sig.c b/common/image-sig.c index 12310bfca1a..31a4fd46061 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -100,12 +100,12 @@ struct padding_algo padding_algos[] = { .name = "pkcs-1.5", .verify = padding_pkcs_15_verify, }, -#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT +#ifdef CONFIG_FIT_RSASSA_PSS { .name = "pss", .verify = padding_pss_verify, } -#endif /* CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT */ +#endif /* CONFIG_FIT_RSASSA_PSS */ };
struct checksum_algo *image_get_checksum_algo(const char *full_name) diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index 0be1e0981ab..ec006514d13 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -11,7 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="bcm963158" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT=y +CONFIG_FIT_RSASSA_PSS=y CONFIG_FIT_VERBOSE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 33446322a46..b4aa2dec7ec 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -10,7 +10,7 @@ CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT=y +CONFIG_FIT_RSASSA_PSS=y CONFIG_FIT_CIPHER=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTSTAGE=y diff --git a/include/image.h b/include/image.h index b08ae2bb6c0..0356d03b2ce 100644 --- a/include/image.h +++ b/include/image.h @@ -28,7 +28,7 @@ struct fdt_region; #include <linux/kconfig.h>
/* new uImage format support enabled on host */ -#define CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT 1 +#define CONFIG_FIT_RSASSA_PSS 1
#define IMAGE_ENABLE_IGNORE 0 #define IMAGE_INDENT_STRING "" diff --git a/include/u-boot/rsa.h b/include/u-boot/rsa.h index bed1c097c2c..bc564d56fa3 100644 --- a/include/u-boot/rsa.h +++ b/include/u-boot/rsa.h @@ -119,11 +119,11 @@ int padding_pkcs_15_verify(struct image_sign_info *info, uint8_t *msg, int msg_len, const uint8_t *hash, int hash_len);
-#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT +#ifdef CONFIG_FIT_RSASSA_PSS int padding_pss_verify(struct image_sign_info *info, uint8_t *msg, int msg_len, const uint8_t *hash, int hash_len); -#endif /* CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT */ +#endif /* CONFIG_FIT_RSASSA_PSS */ #else static inline int rsa_verify_hash(struct image_sign_info *info, const uint8_t *hash, @@ -146,14 +146,14 @@ static inline int padding_pkcs_15_verify(struct image_sign_info *info, return -ENXIO; }
-#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT +#ifdef CONFIG_FIT_RSASSA_PSS static inline int padding_pss_verify(struct image_sign_info *info, uint8_t *msg, int msg_len, const uint8_t *hash, int hash_len) { return -ENXIO; } -#endif /* CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT */ +#endif /* CONFIG_FIT_RSASSA_PSS */ #endif
#define RSA_DEFAULT_PADDING_NAME "pkcs-1.5" diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 5a1583b8f75..f4ed11e74a4 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -442,7 +442,7 @@ static int rsa_sign_with_key(EVP_PKEY *pkey, struct padding_algo *padding_algo, goto err_sign; }
-#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT +#ifdef CONFIG_FIT_RSASSA_PSS if (padding_algo && !strcmp(padding_algo->name, "pss")) { if (EVP_PKEY_CTX_set_rsa_padding(ckey, RSA_PKCS1_PSS_PADDING) <= 0) { @@ -450,7 +450,7 @@ static int rsa_sign_with_key(EVP_PKEY *pkey, struct padding_algo *padding_algo, goto err_sign; } } -#endif /* CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT */ +#endif /* CONFIG_FIT_RSASSA_PSS */
for (i = 0; i < region_count; i++) { if (!EVP_DigestSignUpdate(context, region[i].data, diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index aee76f42d57..1998c773fc7 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -95,7 +95,7 @@ int padding_pkcs_15_verify(struct image_sign_info *info, return 0; }
-#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT +#ifdef CONFIG_FIT_RSASSA_PSS static void u32_i2osp(uint32_t val, uint8_t *buf) { buf[0] = (uint8_t)((val >> 24) & 0xff);
Add a host Kconfig for FIT_RSASSA_PSS. With this we can use CONFIG_IS_ENABLED(FIT_RSASSA_PSS) directly in the host build, so drop the forcing of this in the image.h header.
common/image-sig.c | 4 ++-- include/image.h | 3 --- include/u-boot/rsa.h | 8 ++++---- lib/rsa/rsa-sign.c | 4 ++-- lib/rsa/rsa-verify.c | 4 ++-- tools/Kconfig | 5 +++++ 6 files changed, 15 insertions(+), 13 deletions(-)
diff --git a/common/image-sig.c b/common/image-sig.c index 31a4fd46061..bbc6bb3b1e3 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -100,12 +100,12 @@ struct padding_algo padding_algos[] = { .name = "pkcs-1.5", .verify = padding_pkcs_15_verify, }, -#ifdef CONFIG_FIT_RSASSA_PSS +#if CONFIG_IS_ENABLED(FIT_RSASSA_PSS) { .name = "pss", .verify = padding_pss_verify, } -#endif /* CONFIG_FIT_RSASSA_PSS */ +#endif /* FIT_RSASSA_PSS */ };
struct checksum_algo *image_get_checksum_algo(const char *full_name) diff --git a/include/image.h b/include/image.h index 0356d03b2ce..3bb12ee3821 100644 --- a/include/image.h +++ b/include/image.h @@ -27,9 +27,6 @@ struct fdt_region; #include <sys/types.h> #include <linux/kconfig.h>
-/* new uImage format support enabled on host */ -#define CONFIG_FIT_RSASSA_PSS 1 - #define IMAGE_ENABLE_IGNORE 0 #define IMAGE_INDENT_STRING ""
diff --git a/include/u-boot/rsa.h b/include/u-boot/rsa.h index bc564d56fa3..45fe3509093 100644 --- a/include/u-boot/rsa.h +++ b/include/u-boot/rsa.h @@ -119,11 +119,11 @@ int padding_pkcs_15_verify(struct image_sign_info *info, uint8_t *msg, int msg_len, const uint8_t *hash, int hash_len);
-#ifdef CONFIG_FIT_RSASSA_PSS +#if CONFIG_IS_ENABLED(FIT_RSASSA_PSS) int padding_pss_verify(struct image_sign_info *info, uint8_t *msg, int msg_len, const uint8_t *hash, int hash_len); -#endif /* CONFIG_FIT_RSASSA_PSS */ +#endif /* FIT_RSASSA_PSS */ #else static inline int rsa_verify_hash(struct image_sign_info *info, const uint8_t *hash, @@ -146,14 +146,14 @@ static inline int padding_pkcs_15_verify(struct image_sign_info *info, return -ENXIO; }
-#ifdef CONFIG_FIT_RSASSA_PSS +#if CONFIG_IS_ENABLED(FIT_RSASSA_PSS) static inline int padding_pss_verify(struct image_sign_info *info, uint8_t *msg, int msg_len, const uint8_t *hash, int hash_len) { return -ENXIO; } -#endif /* CONFIG_FIT_RSASSA_PSS */ +#endif /* FIT_RSASSA_PSS */ #endif
#define RSA_DEFAULT_PADDING_NAME "pkcs-1.5" diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index f4ed11e74a4..5ae77621fc6 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -442,7 +442,7 @@ static int rsa_sign_with_key(EVP_PKEY *pkey, struct padding_algo *padding_algo, goto err_sign; }
-#ifdef CONFIG_FIT_RSASSA_PSS +#if CONFIG_IS_ENABLED(FIT_RSASSA_PSS) if (padding_algo && !strcmp(padding_algo->name, "pss")) { if (EVP_PKEY_CTX_set_rsa_padding(ckey, RSA_PKCS1_PSS_PADDING) <= 0) { @@ -450,7 +450,7 @@ static int rsa_sign_with_key(EVP_PKEY *pkey, struct padding_algo *padding_algo, goto err_sign; } } -#endif /* CONFIG_FIT_RSASSA_PSS */ +#endif /* FIT_RSASSA_PSS */
for (i = 0; i < region_count; i++) { if (!EVP_DigestSignUpdate(context, region[i].data, diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index 1998c773fc7..b1abfa8eacc 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -95,7 +95,7 @@ int padding_pkcs_15_verify(struct image_sign_info *info, return 0; }
-#ifdef CONFIG_FIT_RSASSA_PSS +#if CONFIG_IS_ENABLED(FIT_RSASSA_PSS) static void u32_i2osp(uint32_t val, uint8_t *buf) { buf[0] = (uint8_t)((val >> 24) & 0xff); @@ -296,7 +296,7 @@ out:
return ret; } -#endif +#endif /* FIT_RSASSA_PSS */
#if CONFIG_IS_ENABLED(FIT_SIGNATURE) || CONFIG_IS_ENABLED(RSA_VERIFY_WITH_PKEY) /** diff --git a/tools/Kconfig b/tools/Kconfig index 6d0f4565a80..8bd782cf5b9 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -24,6 +24,11 @@ config HOST_FIT_PRINT help Print the content of the FIT verbosely in the host build
+config HOST_FIT_RSASSA_PSS + def_bool y + help + Support the rsassa-pss signature scheme in the host build + config HOST_FIT_SHA1 def_bool y help
Drop the _SUPPORT suffix so we can use CONFIG_IS_ENABLED() with this option.
common/spl/Kconfig | 4 ++-- configs/axm_defconfig | 2 +- configs/chromebit_mickey_defconfig | 2 +- configs/chromebook_jerry_defconfig | 2 +- configs/chromebook_minnie_defconfig | 2 +- configs/chromebook_speedy_defconfig | 2 +- configs/evb-px30_defconfig | 2 +- configs/firefly-px30_defconfig | 2 +- configs/imxrt1020-evk_defconfig | 2 +- configs/imxrt1050-evk_defconfig | 2 +- configs/odroid-go2_defconfig | 2 +- configs/px30-core-ctouch2-px30_defconfig | 2 +- configs/px30-core-edimm2.2-px30_defconfig | 2 +- configs/socfpga_agilex_atf_defconfig | 2 +- configs/socfpga_agilex_vab_defconfig | 2 +- configs/socfpga_stratix10_atf_defconfig | 2 +- configs/taurus_defconfig | 2 +- include/image.h | 2 +- 18 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index d94b9892175..0329d93b29e 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -204,7 +204,7 @@ config SPL_LEGACY_IMAGE_SUPPORT config SPL_LEGACY_IMAGE_CRC_CHECK bool "Check CRC of Legacy images" depends on SPL_LEGACY_IMAGE_SUPPORT - select SPL_CRC32_SUPPORT + select SPL_CRC32 help Enable this to check the CRC of Legacy images. While this increases reliability, it affects both code size and boot duration. @@ -407,7 +407,7 @@ config SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION the eMMC EXT_CSC_PART_CONFIG selection should be overridden in SPL by user defined partition number.
-config SPL_CRC32_SUPPORT +config SPL_CRC32 bool "Support CRC32" default y if SPL_LEGACY_IMAGE_SUPPORT help diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 0bfd7548b09..4e776fd6953 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -32,7 +32,7 @@ CONFIG_BOOTCOMMAND="run flash_self" CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index c09b63b9462..2b664e118cf 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -25,7 +25,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set -# CONFIG_SPL_CRC32_SUPPORT is not set +# CONFIG_SPL_CRC32 is not set CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 692b630174d..a757d259f58 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -26,7 +26,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set -# CONFIG_SPL_CRC32_SUPPORT is not set +# CONFIG_SPL_CRC32 is not set CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index ae55842e3bf..353aa01ea9e 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -26,7 +26,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set -# CONFIG_SPL_CRC32_SUPPORT is not set +# CONFIG_SPL_CRC32 is not set CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 4b460ee6a9e..c5be5597b10 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -26,7 +26,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set -# CONFIG_SPL_CRC32_SUPPORT is not set +# CONFIG_SPL_CRC32 is not set CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y diff --git a/configs/evb-px30_defconfig b/configs/evb-px30_defconfig index d2fdfef2938..55e2702a172 100644 --- a/configs/evb-px30_defconfig +++ b/configs/evb-px30_defconfig @@ -29,7 +29,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/firefly-px30_defconfig b/configs/firefly-px30_defconfig index 6487615fe08..978a3604053 100644 --- a/configs/firefly-px30_defconfig +++ b/configs/firefly-px30_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/imxrt1020-evk_defconfig b/configs/imxrt1020-evk_defconfig index 9bddb69cd41..ca7c1c90799 100644 --- a/configs/imxrt1020-evk_defconfig +++ b/configs/imxrt1020-evk_defconfig @@ -24,7 +24,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 -# CONFIG_SPL_CRC32_SUPPORT is not set +# CONFIG_SPL_CRC32 is not set # CONFIG_BOOTM_NETBSD is not set # CONFIG_BOOTM_PLAN9 is not set # CONFIG_BOOTM_RTEMS is not set diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig index f639ea76230..ca53bccb5fd 100644 --- a/configs/imxrt1050-evk_defconfig +++ b/configs/imxrt1050-evk_defconfig @@ -27,7 +27,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 -# CONFIG_SPL_CRC32_SUPPORT is not set +# CONFIG_SPL_CRC32 is not set # CONFIG_BOOTM_NETBSD is not set # CONFIG_BOOTM_PLAN9 is not set # CONFIG_BOOTM_RTEMS is not set diff --git a/configs/odroid-go2_defconfig b/configs/odroid-go2_defconfig index 6aa41e37557..82e340a16ee 100644 --- a/configs/odroid-go2_defconfig +++ b/configs/odroid-go2_defconfig @@ -33,7 +33,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_ATF=y diff --git a/configs/px30-core-ctouch2-px30_defconfig b/configs/px30-core-ctouch2-px30_defconfig index 1afc146bbf2..3ac0ea4ccc9 100644 --- a/configs/px30-core-ctouch2-px30_defconfig +++ b/configs/px30-core-ctouch2-px30_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/px30-core-edimm2.2-px30_defconfig b/configs/px30-core-edimm2.2-px30_defconfig index 9d78eee84d7..f208297de5e 100644 --- a/configs/px30-core-edimm2.2-px30_defconfig +++ b/configs/px30-core-edimm2.2-px30_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y # CONFIG_TPL_BANNER_PRINT is not set -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_ATF=y # CONFIG_TPL_FRAMEWORK is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/socfpga_agilex_atf_defconfig b/configs/socfpga_agilex_atf_defconfig index 0de65a22a0c..c265e57e6ce 100644 --- a/configs/socfpga_agilex_atf_defconfig +++ b/configs/socfpga_agilex_atf_defconfig @@ -23,7 +23,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run linux_qspi_enable; run mmcfitboot" -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_ATF=y diff --git a/configs/socfpga_agilex_vab_defconfig b/configs/socfpga_agilex_vab_defconfig index d575dadcfbf..68b6b5e0b4a 100644 --- a/configs/socfpga_agilex_vab_defconfig +++ b/configs/socfpga_agilex_vab_defconfig @@ -24,7 +24,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run mmcfitboot" -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_ATF=y diff --git a/configs/socfpga_stratix10_atf_defconfig b/configs/socfpga_stratix10_atf_defconfig index c187987dd83..8fcabe1f868 100644 --- a/configs/socfpga_stratix10_atf_defconfig +++ b/configs/socfpga_stratix10_atf_defconfig @@ -23,7 +23,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run linux_qspi_enable; run mmcfitboot" -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index a79cdf3fa7c..5caf9ab30d6 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -36,7 +36,7 @@ CONFIG_BOOTCOMMAND="nand read 0x22000000 0x200000 0x300000; bootm" CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_CRC32=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/include/image.h b/include/image.h index 3bb12ee3821..5aedc1bb23b 100644 --- a/include/image.h +++ b/include/image.h @@ -47,7 +47,7 @@ struct fdt_region; #include <linux/libfdt.h> #include <fdt_support.h> # ifdef CONFIG_SPL_BUILD -# ifdef CONFIG_SPL_CRC32_SUPPORT +# ifdef CONFIG_SPL_CRC32 # define IMAGE_ENABLE_CRC32 1 # endif # ifdef CONFIG_SPL_MD5_SUPPORT
Add a host Kconfig for CRC32. With this we can use CONFIG_IS_ENABLED(CRC32) directly in the host build, so drop the unnecessary indirection.
Add a few more conditions to SPL_CRC32 to avoid build failures as well as TPL_CRC32. Also update hash.c to make crc32 optional.
common/hash.c | 13 ++++++++----- common/image-fit.c | 2 +- common/spl/Kconfig | 13 ++++++++++++- include/image.h | 8 -------- lib/Kconfig | 5 +++++ lib/Makefile | 4 +--- tools/Kconfig | 5 +++++ 7 files changed, 32 insertions(+), 18 deletions(-)
diff --git a/common/hash.c b/common/hash.c index 1ccc62f162d..67e81e6150d 100644 --- a/common/hash.c +++ b/common/hash.c @@ -178,7 +178,7 @@ static int hash_finish_crc16_ccitt(struct hash_algo *algo, void *ctx, return 0; }
-static int hash_init_crc32(struct hash_algo *algo, void **ctxp) +static int __maybe_unused hash_init_crc32(struct hash_algo *algo, void **ctxp) { uint32_t *ctx = malloc(sizeof(uint32_t)); *ctx = 0; @@ -186,15 +186,16 @@ static int hash_init_crc32(struct hash_algo *algo, void **ctxp) return 0; }
-static int hash_update_crc32(struct hash_algo *algo, void *ctx, - const void *buf, unsigned int size, int is_last) +static int __maybe_unused hash_update_crc32(struct hash_algo *algo, void *ctx, + const void *buf, unsigned int size, + int is_last) { *((uint32_t *)ctx) = crc32(*((uint32_t *)ctx), buf, size); return 0; }
-static int hash_finish_crc32(struct hash_algo *algo, void *ctx, void *dest_buf, - int size) +static int __maybe_unused hash_finish_crc32(struct hash_algo *algo, void *ctx, + void *dest_buf, int size) { if (size < algo->digest_size) return -1; @@ -303,6 +304,7 @@ static struct hash_algo hash_algo[] = { .hash_update = hash_update_crc16_ccitt, .hash_finish = hash_finish_crc16_ccitt, }, +#if CONFIG_IS_ENABLED(CRC32) { .name = "crc32", .digest_size = 4, @@ -312,6 +314,7 @@ static struct hash_algo hash_algo[] = { .hash_update = hash_update_crc32, .hash_finish = hash_finish_crc32, }, +#endif };
/* Try to minimize code size for boards that don't want much hashing */ diff --git a/common/image-fit.c b/common/image-fit.c index a16e2dd54a5..1ce46a5c72d 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1213,7 +1213,7 @@ int fit_set_timestamp(void *fit, int noffset, time_t timestamp) int calculate_hash(const void *data, int data_len, const char *algo, uint8_t *value, int *value_len) { - if (IMAGE_ENABLE_CRC32 && strcmp(algo, "crc32") == 0) { + if (CONFIG_IS_ENABLED(CRC32) && strcmp(algo, "crc32") == 0) { *((uint32_t *)value) = crc32_wd(0, data, data_len, CHUNKSZ_CRC32); *((uint32_t *)value) = cpu_to_uimage(*((uint32_t *)value)); diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0329d93b29e..636a7319274 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -409,7 +409,8 @@ config SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION
config SPL_CRC32 bool "Support CRC32" - default y if SPL_LEGACY_IMAGE_SUPPORT + default y if SPL_LEGACY_IMAGE_SUPPORT || SPL_EFI_PARTITION + default y if SPL_ENV_SUPPORT || TPL_BLOBLIST help Enable this to support CRC32 in uImages or FIT images within SPL. This is a 32-bit checksum value that can be used to verify images. @@ -1467,6 +1468,16 @@ config TPL_BOOTROM_SUPPORT BOOT_DEVICE_BOOTROM (or fall-through to the next boot device in the boot device list, if not implemented for a given board)
+config TPL_CRC32 + bool "Support CRC32 in TPL" + default y if TPL_ENV_SUPPORT || TPL_BLOBLIST + help + Enable this to support CRC32 in uImages or FIT images within SPL. + This is a 32-bit checksum value that can be used to verify images. + For FIT images, this is the least secure type of checksum, suitable + for detected accidental image corruption. For secure applications you + should consider SHA1 or SHA256. + config TPL_DRIVERS_MISC_SUPPORT bool "Support misc drivers in TPL" help diff --git a/include/image.h b/include/image.h index 5aedc1bb23b..e68c2cbf621 100644 --- a/include/image.h +++ b/include/image.h @@ -47,9 +47,6 @@ struct fdt_region; #include <linux/libfdt.h> #include <fdt_support.h> # ifdef CONFIG_SPL_BUILD -# ifdef CONFIG_SPL_CRC32 -# define IMAGE_ENABLE_CRC32 1 -# endif # ifdef CONFIG_SPL_MD5_SUPPORT # define IMAGE_ENABLE_MD5 1 # endif @@ -57,15 +54,10 @@ struct fdt_region; # define IMAGE_ENABLE_SHA1 1 # endif # else -# define IMAGE_ENABLE_CRC32 1 # define IMAGE_ENABLE_MD5 1 # define IMAGE_ENABLE_SHA1 1 # endif
-#ifndef IMAGE_ENABLE_CRC32 -#define IMAGE_ENABLE_CRC32 0 -#endif - #ifndef IMAGE_ENABLE_MD5 #define IMAGE_ENABLE_MD5 0 #endif diff --git a/lib/Kconfig b/lib/Kconfig index 6d2d41de301..7d9bf8f6f4e 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -422,6 +422,11 @@ config SPL_MD5 security applications, but it can be useful for providing a quick checksum of a block of data.
+config CRC32 + def_bool y + help + Enables CRC32 support in U-Boot. This is normally required. + config CRC32C bool
diff --git a/lib/Makefile b/lib/Makefile index 39acbac123b..da943891bd8 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -94,9 +94,7 @@ obj-y += display_options.o CFLAGS_display_options.o := $(if $(BUILD_TAG),-DBUILD_TAG='"$(BUILD_TAG)"') obj-$(CONFIG_BCH) += bch.o obj-$(CONFIG_MMC_SPI) += crc7.o -#ifndef CONFIG_TPL_BUILD -obj-y += crc32.o -#endif +obj-$(CONFIG_$(SPL_TPL_)CRC32) += crc32.o obj-$(CONFIG_CRC32C) += crc32c.o obj-y += ctype.o obj-y += div64.o diff --git a/tools/Kconfig b/tools/Kconfig index 8bd782cf5b9..e27826fae9f 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -9,6 +9,11 @@ config MKIMAGE_DTC_PATH some cases the system dtc may not support all required features and the path to a different version should be given here.
+config HOST_CRC32 + def_bool y + help + Enable CRC32 support in the host build + config HOST_FIT def_bool y help
common/spl/Kconfig | 2 +- include/image.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 636a7319274..56e5867c9cd 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -418,7 +418,7 @@ config SPL_CRC32 for detected accidental image corruption. For secure applications you should consider SHA1 or SHA256.
-config SPL_MD5_SUPPORT +config SPL_MD5 bool "Support MD5" depends on SPL_FIT help diff --git a/include/image.h b/include/image.h index e68c2cbf621..e1e4bf6806f 100644 --- a/include/image.h +++ b/include/image.h @@ -47,7 +47,7 @@ struct fdt_region; #include <linux/libfdt.h> #include <fdt_support.h> # ifdef CONFIG_SPL_BUILD -# ifdef CONFIG_SPL_MD5_SUPPORT +# ifdef CONFIG_SPL_MD5 # define IMAGE_ENABLE_MD5 1 # endif # ifdef CONFIG_SPL_FIT_SHA1
Add a host Kconfig for MD5. With this we can use CONFIG_IS_ENABLED(MD5) directly in the host build, so drop the unnecessary indirection.
common/image-fit.c | 2 +- include/image.h | 8 -------- tools/Kconfig | 5 +++++ 3 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 1ce46a5c72d..19a2d3c91df 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1234,7 +1234,7 @@ int calculate_hash(const void *data, int data_len, const char *algo, sha512_csum_wd((unsigned char *)data, data_len, (unsigned char *)value, CHUNKSZ_SHA512); *value_len = SHA512_SUM_LEN; - } else if (IMAGE_ENABLE_MD5 && strcmp(algo, "md5") == 0) { + } else if (CONFIG_IS_ENABLED(MD5) && strcmp(algo, "md5") == 0) { md5_wd((unsigned char *)data, data_len, value, CHUNKSZ_MD5); *value_len = 16; } else { diff --git a/include/image.h b/include/image.h index e1e4bf6806f..9f665a597b0 100644 --- a/include/image.h +++ b/include/image.h @@ -47,21 +47,13 @@ struct fdt_region; #include <linux/libfdt.h> #include <fdt_support.h> # ifdef CONFIG_SPL_BUILD -# ifdef CONFIG_SPL_MD5 -# define IMAGE_ENABLE_MD5 1 -# endif # ifdef CONFIG_SPL_FIT_SHA1 # define IMAGE_ENABLE_SHA1 1 # endif # else -# define IMAGE_ENABLE_MD5 1 # define IMAGE_ENABLE_SHA1 1 # endif
-#ifndef IMAGE_ENABLE_MD5 -#define IMAGE_ENABLE_MD5 0 -#endif - #ifndef IMAGE_ENABLE_SHA1 #define IMAGE_ENABLE_SHA1 0 #endif diff --git a/tools/Kconfig b/tools/Kconfig index e27826fae9f..bbd6e8b9d79 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -69,6 +69,11 @@ config HOST_FIT_VERBOSE help Support verbose FIT output in the host build
+config HOST_MD5 + def_bool y + help + Enable MD5 support in the host build + config HOST_OF_LIBFDT def_bool y help
We already have a host Kconfig for SHA1. Use CONFIG_IS_ENABLED(SHA1) directly in the code shared with the host build, so we can drop the unnecessary indirection.
common/image-fit.c | 2 +- include/image.h | 11 ----------- 2 files changed, 1 insertion(+), 12 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 19a2d3c91df..96794074b63 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1218,7 +1218,7 @@ int calculate_hash(const void *data, int data_len, const char *algo, CHUNKSZ_CRC32); *((uint32_t *)value) = cpu_to_uimage(*((uint32_t *)value)); *value_len = 4; - } else if (IMAGE_ENABLE_SHA1 && strcmp(algo, "sha1") == 0) { + } else if (CONFIG_IS_ENABLED(SHA1) && strcmp(algo, "sha1") == 0) { sha1_csum_wd((unsigned char *)data, data_len, (unsigned char *)value, CHUNKSZ_SHA1); *value_len = 20; diff --git a/include/image.h b/include/image.h index 9f665a597b0..f5ff77bf0ca 100644 --- a/include/image.h +++ b/include/image.h @@ -46,17 +46,6 @@ struct fdt_region; #include <hash.h> #include <linux/libfdt.h> #include <fdt_support.h> -# ifdef CONFIG_SPL_BUILD -# ifdef CONFIG_SPL_FIT_SHA1 -# define IMAGE_ENABLE_SHA1 1 -# endif -# else -# define IMAGE_ENABLE_SHA1 1 -# endif - -#ifndef IMAGE_ENABLE_SHA1 -#define IMAGE_ENABLE_SHA1 0 -#endif
#if defined(CONFIG_FIT_SHA256) || \ defined(CONFIG_SPL_FIT_SHA256)
We already have a host Kconfig for these SHA options. Use CONFIG_IS_ENABLED(SHAxxx) directly in the code shared with the host build, so we can drop the unnecessary indirections.
common/image-fit.c | 6 +++--- include/image.h | 21 --------------------- 2 files changed, 3 insertions(+), 24 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 96794074b63..070835b3a87 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1222,15 +1222,15 @@ int calculate_hash(const void *data, int data_len, const char *algo, sha1_csum_wd((unsigned char *)data, data_len, (unsigned char *)value, CHUNKSZ_SHA1); *value_len = 20; - } else if (IMAGE_ENABLE_SHA256 && strcmp(algo, "sha256") == 0) { + } else if (CONFIG_IS_ENABLED(SHA256) && strcmp(algo, "sha256") == 0) { sha256_csum_wd((unsigned char *)data, data_len, (unsigned char *)value, CHUNKSZ_SHA256); *value_len = SHA256_SUM_LEN; - } else if (IMAGE_ENABLE_SHA384 && strcmp(algo, "sha384") == 0) { + } else if (CONFIG_IS_ENABLED(SHA384) && strcmp(algo, "sha384") == 0) { sha384_csum_wd((unsigned char *)data, data_len, (unsigned char *)value, CHUNKSZ_SHA384); *value_len = SHA384_SUM_LEN; - } else if (IMAGE_ENABLE_SHA512 && strcmp(algo, "sha512") == 0) { + } else if (CONFIG_IS_ENABLED(SHA512) && strcmp(algo, "sha512") == 0) { sha512_csum_wd((unsigned char *)data, data_len, (unsigned char *)value, CHUNKSZ_SHA512); *value_len = SHA512_SUM_LEN; diff --git a/include/image.h b/include/image.h index f5ff77bf0ca..f4b8dd7dd0f 100644 --- a/include/image.h +++ b/include/image.h @@ -47,27 +47,6 @@ struct fdt_region; #include <linux/libfdt.h> #include <fdt_support.h>
-#if defined(CONFIG_FIT_SHA256) || \ - defined(CONFIG_SPL_FIT_SHA256) -#define IMAGE_ENABLE_SHA256 1 -#else -#define IMAGE_ENABLE_SHA256 0 -#endif - -#if defined(CONFIG_FIT_SHA384) || \ - defined(CONFIG_SPL_FIT_SHA384) -#define IMAGE_ENABLE_SHA384 1 -#else -#define IMAGE_ENABLE_SHA384 0 -#endif - -#if defined(CONFIG_FIT_SHA512) || \ - defined(CONFIG_SPL_FIT_SHA512) -#define IMAGE_ENABLE_SHA512 1 -#else -#define IMAGE_ENABLE_SHA512 0 -#endif - #endif /* FIT */
This is not needed with Kconfig, since we can use IS_ENABLED() easily enough. Update the only place where this is used and drop it.
common/image-board.c | 2 +- include/image.h | 6 ------ 2 files changed, 1 insertion(+), 7 deletions(-)
diff --git a/common/image-board.c b/common/image-board.c index 0b9809c3f6b..1a3b0bc7efc 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -898,7 +898,7 @@ int image_setup_linux(bootm_headers_t *images) if (CONFIG_IS_ENABLED(OF_LIBFDT)) boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree);
- if (IMAGE_BOOT_GET_CMDLINE) { + if (IS_ENABLED(CONFIG_SYS_BOOT_GET_CMDLINE)) { ret = boot_get_cmdline(lmb, &images->cmdline_start, &images->cmdline_end); if (ret) { diff --git a/include/image.h b/include/image.h index f4b8dd7dd0f..122fc25e1b4 100644 --- a/include/image.h +++ b/include/image.h @@ -49,12 +49,6 @@ struct fdt_region;
#endif /* FIT */
-#ifdef CONFIG_SYS_BOOT_GET_CMDLINE -# define IMAGE_BOOT_GET_CMDLINE 1 -#else -# define IMAGE_BOOT_GET_CMDLINE 0 -#endif - #ifdef CONFIG_OF_BOARD_SETUP # define IMAGE_OF_BOARD_SETUP 1 #else
This is not needed with Kconfig, since we can use IS_ENABLED() easily enough. Drop it.
common/image-fdt.c | 4 ++-- include/image.h | 6 ------ 2 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index d50e1ba3feb..c2d9710bfaa 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -575,7 +575,7 @@ int image_setup_libfdt(bootm_headers_t *images, void *blob, /* Append PStore configuration */ fdt_fixup_pstore(blob); #endif - if (IMAGE_OF_BOARD_SETUP) { + if (IS_ENABLED(CONFIG_OF_BOARD_SETUP)) { const char *skip_board_fixup;
skip_board_fixup = env_get("skip_board_fixup"); @@ -622,7 +622,7 @@ int image_setup_libfdt(bootm_headers_t *images, void *blob, goto err;
#if defined(CONFIG_SOC_KEYSTONE) - if (IMAGE_OF_BOARD_SETUP) + if (IS_ENABLED(CONFIG_OF_BOARD_SETUP)) ft_board_setup_ex(blob, gd->bd); #endif
diff --git a/include/image.h b/include/image.h index 122fc25e1b4..deb690d168b 100644 --- a/include/image.h +++ b/include/image.h @@ -49,12 +49,6 @@ struct fdt_region;
#endif /* FIT */
-#ifdef CONFIG_OF_BOARD_SETUP -# define IMAGE_OF_BOARD_SETUP 1 -#else -# define IMAGE_OF_BOARD_SETUP 0 -#endif - #ifdef CONFIG_OF_SYSTEM_SETUP # define IMAGE_OF_SYSTEM_SETUP 1 #else
common/image-fdt.c | 2 +- include/image.h | 6 ------ 2 files changed, 1 insertion(+), 7 deletions(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index c2d9710bfaa..80bfa625ab2 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -590,7 +590,7 @@ int image_setup_libfdt(bootm_headers_t *images, void *blob, } } } - if (IMAGE_OF_SYSTEM_SETUP) { + if (IS_ENABLED(CONFIG_OF_SYSTEM_SETUP)) { fdt_ret = ft_system_setup(blob, gd->bd); if (fdt_ret) { printf("ERROR: system-specific fdt fixup failed: %s\n", diff --git a/include/image.h b/include/image.h index deb690d168b..eb5ca8a32d3 100644 --- a/include/image.h +++ b/include/image.h @@ -49,12 +49,6 @@ struct fdt_region;
#endif /* FIT */
-#ifdef CONFIG_OF_SYSTEM_SETUP -# define IMAGE_OF_SYSTEM_SETUP 1 -#else -# define IMAGE_OF_SYSTEM_SETUP 0 -#endif - extern ulong image_load_addr; /* Default Load Address */ extern ulong image_save_addr; /* Default Save Address */ extern ulong image_save_size; /* Default Save Size */
We can use the new host_build() function for this, so drop it.
common/image-fit.c | 2 +- include/image.h | 3 --- 2 files changed, 1 insertion(+), 4 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 070835b3a87..c13ff6bba24 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1262,7 +1262,7 @@ static int fit_image_check_hash(const void *fit, int noffset, const void *data, } printf("%s", algo);
- if (IMAGE_ENABLE_IGNORE) { + if (!host_build()) { fit_image_hash_get_ignore(fit, noffset, &ignore); if (ignore) { printf("-skipped "); diff --git a/include/image.h b/include/image.h index eb5ca8a32d3..64866c609f4 100644 --- a/include/image.h +++ b/include/image.h @@ -27,7 +27,6 @@ struct fdt_region; #include <sys/types.h> #include <linux/kconfig.h>
-#define IMAGE_ENABLE_IGNORE 0 #define IMAGE_INDENT_STRING ""
#else @@ -36,8 +35,6 @@ struct fdt_region; #include <asm/u-boot.h> #include <command.h>
-/* Take notice of the 'ignore' property for hashes */ -#define IMAGE_ENABLE_IGNORE 1 #define IMAGE_INDENT_STRING " "
Add host Kconfigs for FIT_SIGN and RSA_VERIFY. With these we can use CONFIG_IS_ENABLED() directly in the host build, so drop the unnecessary indirections IMAGE_ENABLE_SIGN and HOST_RSA_VERIFY. Also drop FIT_IMAGE_ENABLE_VERIFY which is not actually used.
Leave IMAGE_ENABLE_VERIFY_ECDSA along since this feature is incomplete and needs to be integrated with RSA.
common/image-fit.c | 6 +++--- common/image-sig.c | 10 +++++----- include/image.h | 13 ++----------- include/u-boot/ecdsa.h | 2 +- include/u-boot/rsa.h | 4 ++-- tools/Kconfig | 10 ++++++++++ tools/image-host.c | 4 ++-- 7 files changed, 25 insertions(+), 24 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index c13ff6bba24..e81a0858dc1 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1301,7 +1301,7 @@ int fit_image_verify_with_data(const void *fit, int image_noffset, int ret;
/* Verify all required signatures */ - if (FIT_IMAGE_ENABLE_VERIFY && + if (CONFIG_IS_ENABLED(RSA_VERIFY) && fit_image_verify_required_sigs(fit, image_noffset, data, size, gd_fdt_blob(), &verify_all)) { err_msg = "Unable to verify required signature"; @@ -1323,7 +1323,7 @@ int fit_image_verify_with_data(const void *fit, int image_noffset, &err_msg)) goto error; puts("+ "); - } else if (FIT_IMAGE_ENABLE_VERIFY && verify_all && + } else if (CONFIG_IS_ENABLED(RSA_VERIFY) && verify_all && !strncmp(name, FIT_SIG_NODENAME, strlen(FIT_SIG_NODENAME))) { ret = fit_image_check_sig(fit, noffset, data, @@ -2045,7 +2045,7 @@ int fit_image_load(bootm_headers_t *images, ulong addr, if (image_type == IH_TYPE_KERNEL) images->fit_uname_cfg = fit_base_uname_config;
- if (FIT_IMAGE_ENABLE_VERIFY && images->verify) { + if (CONFIG_IS_ENABLED(RSA_VERIFY) && images->verify) { puts(" Verifying Hash Integrity ... "); if (fit_config_verify(fit, cfg_noffset)) { puts("Bad Data Hash\n"); diff --git a/common/image-sig.c b/common/image-sig.c index bbc6bb3b1e3..74ca96a39e9 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -29,7 +29,7 @@ struct checksum_algo checksum_algos[] = { .checksum_len = SHA1_SUM_LEN, .der_len = SHA1_DER_LEN, .der_prefix = sha1_der_prefix, -#if IMAGE_ENABLE_SIGN +#if CONFIG_IS_ENABLED(FIT_SIGN) .calculate_sign = EVP_sha1, #endif .calculate = hash_calculate, @@ -39,7 +39,7 @@ struct checksum_algo checksum_algos[] = { .checksum_len = SHA256_SUM_LEN, .der_len = SHA256_DER_LEN, .der_prefix = sha256_der_prefix, -#if IMAGE_ENABLE_SIGN +#if CONFIG_IS_ENABLED(FIT_SIGN) .calculate_sign = EVP_sha256, #endif .calculate = hash_calculate, @@ -50,7 +50,7 @@ struct checksum_algo checksum_algos[] = { .checksum_len = SHA384_SUM_LEN, .der_len = SHA384_DER_LEN, .der_prefix = sha384_der_prefix, -#if IMAGE_ENABLE_SIGN +#if CONFIG_IS_ENABLED(FIT_SIGN) .calculate_sign = EVP_sha384, #endif .calculate = hash_calculate, @@ -62,7 +62,7 @@ struct checksum_algo checksum_algos[] = { .checksum_len = SHA512_SUM_LEN, .der_len = SHA512_DER_LEN, .der_prefix = sha512_der_prefix, -#if IMAGE_ENABLE_SIGN +#if CONFIG_IS_ENABLED(FIT_SIGN) .calculate_sign = EVP_sha512, #endif .calculate = hash_calculate, @@ -122,7 +122,7 @@ struct checksum_algo *image_get_checksum_algo(const char *full_name) struct checksum_algo *algo = &checksum_algos[i];
MANUAL_RELOC(algo->name); -#if IMAGE_ENABLE_SIGN +#if CONFIG_IS_ENABLED(FIT_SIGN) MANUAL_RELOC(algo->calculate_sign); #endif MANUAL_RELOC(algo->calculate); diff --git a/include/image.h b/include/image.h index 64866c609f4..12043abd049 100644 --- a/include/image.h +++ b/include/image.h @@ -1139,22 +1139,13 @@ int calculate_hash(const void *data, int data_len, const char *algo, */ #if defined(USE_HOSTCC) # if defined(CONFIG_FIT_SIGNATURE) -# define IMAGE_ENABLE_SIGN 1 -# define IMAGE_ENABLE_VERIFY 1 # define IMAGE_ENABLE_VERIFY_ECDSA 1 -# define FIT_IMAGE_ENABLE_VERIFY 1 # include <openssl/evp.h> # else -# define IMAGE_ENABLE_SIGN 0 -# define IMAGE_ENABLE_VERIFY 0 # define IMAGE_ENABLE_VERIFY_ECDSA 0 -# define FIT_IMAGE_ENABLE_VERIFY 0 # endif #else -# define IMAGE_ENABLE_SIGN 0 -# define IMAGE_ENABLE_VERIFY CONFIG_IS_ENABLED(RSA_VERIFY) # define IMAGE_ENABLE_VERIFY_ECDSA 0 -# define FIT_IMAGE_ENABLE_VERIFY CONFIG_IS_ENABLED(FIT_SIGNATURE) #endif
#if CONFIG_IS_ENABLED(FIT) @@ -1209,7 +1200,7 @@ struct image_region { int size; };
-#if IMAGE_ENABLE_VERIFY +#if CONFIG_IS_ENABLED(RSA_VERIFY) # include <u-boot/hash-checksum.h> #endif struct checksum_algo { @@ -1217,7 +1208,7 @@ struct checksum_algo { const int checksum_len; const int der_len; const uint8_t *der_prefix; -#if IMAGE_ENABLE_SIGN +#if CONFIG_IS_ENABLED(FIT_SIGN) const EVP_MD *(*calculate_sign)(void); #endif int (*calculate)(const char *name, diff --git a/include/u-boot/ecdsa.h b/include/u-boot/ecdsa.h index 979690d9660..a446b656a29 100644 --- a/include/u-boot/ecdsa.h +++ b/include/u-boot/ecdsa.h @@ -15,7 +15,7 @@ * @see "struct crypto_algo" * @{ */ -#if IMAGE_ENABLE_SIGN +#if CONFIG_IS_ENABLED(FIT_SIGN) /** * sign() - calculate and return signature for given input data * diff --git a/include/u-boot/rsa.h b/include/u-boot/rsa.h index 45fe3509093..84cefbab442 100644 --- a/include/u-boot/rsa.h +++ b/include/u-boot/rsa.h @@ -31,7 +31,7 @@ struct rsa_public_key {
struct image_sign_info;
-#if IMAGE_ENABLE_SIGN +#if CONFIG_IS_ENABLED(FIT_SIGN) /** * sign() - calculate and return signature for given input data * @@ -81,7 +81,7 @@ static inline int rsa_add_verify_data(struct image_sign_info *info, } #endif
-#if IMAGE_ENABLE_VERIFY +#if CONFIG_IS_ENABLED(RSA_VERIFY) /** * rsa_verify_hash() - Verify a signature against a hash * diff --git a/tools/Kconfig b/tools/Kconfig index bbd6e8b9d79..13f923c7ac7 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -59,6 +59,11 @@ config HOST_FIT_SIGNATURE help Enable signature verification of FIT uImages in the host build
+config HOST_FIT_SIGN + def_bool y + help + Enable signing FIT uImages in the host build + config HOST_FIT_SIGNATURE_MAX_SIZE hex depends on HOST_FIT_SIGNATURE @@ -79,6 +84,11 @@ config HOST_OF_LIBFDT help Enable libfdt support in the host build.
+config HOST_RSA_VERIFY + def_bool y + help + Enable RSA verification support in the host build. + config HOST_SHA1 def_bool y help diff --git a/tools/image-host.c b/tools/image-host.c index 270d36fe451..2be897db943 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -636,7 +636,7 @@ int fit_image_add_verification_data(const char *keydir, const char *keyfile, strlen(FIT_HASH_NODENAME))) { ret = fit_image_process_hash(fit, image_name, noffset, data, size); - } else if (IMAGE_ENABLE_SIGN && (keydir || keyfile) && + } else if (CONFIG_IS_ENABLED(FIT_SIGN) && (keydir || keyfile) && !strncmp(node_name, FIT_SIG_NODENAME, strlen(FIT_SIG_NODENAME))) { ret = fit_image_process_sig(keydir, keyfile, keydest, @@ -1086,7 +1086,7 @@ int fit_add_verification_data(const char *keydir, const char *keyfile, }
/* If there are no keys, we can't sign configurations */ - if (!IMAGE_ENABLE_SIGN || !(keydir || keyfile)) + if (!CONFIG_IS_ENABLED(FIT_SIGN) || !(keydir || keyfile)) return 0;
/* Find configurations parent node offset */
common/image-fit.c | 2 +- include/image.h | 5 ----- 2 files changed, 1 insertion(+), 6 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index e81a0858dc1..a0987fd52c8 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -2026,7 +2026,7 @@ int fit_image_load(bootm_headers_t *images, ulong addr, * fit_conf_get_node() will try to find default config node */ bootstage_mark(bootstage_id + BOOTSTAGE_SUB_NO_UNIT_NAME); - if (IMAGE_ENABLE_BEST_MATCH && !fit_uname_config) { + if (IS_ENABLED(CONFIG_FIT_BEST_MATCH) && !fit_uname_config) { cfg_noffset = fit_conf_find_compat(fit, gd_fdt_blob()); } else { cfg_noffset = fit_conf_get_node(fit, diff --git a/include/image.h b/include/image.h index 12043abd049..b388684cbdc 100644 --- a/include/image.h +++ b/include/image.h @@ -1157,11 +1157,6 @@ void image_set_host_blob(void *host_blob); # define gd_fdt_blob() (gd->fdt_blob) #endif
-#ifdef CONFIG_FIT_BEST_MATCH -#define IMAGE_ENABLE_BEST_MATCH 1 -#else -#define IMAGE_ENABLE_BEST_MATCH 0 -#endif #endif /* FIT */
Add a host Kconfigs for IMAGE_ENABLE_ENCRYPT. With this we can use CONFIG_IS_ENABLED() directly in the host build, so drop the unnecessary indirections IMAGE_IMAGE_ENABLE_ENCRYPT and IMAGE_IMAGE_ENABLE_DECRYPT.
common/image-cipher.c | 6 +++--- common/image-fit.c | 2 +- include/image.h | 16 +++------------- include/u-boot/aes.h | 8 ++++---- tools/Kconfig | 11 +++++++++++ tools/image-host.c | 2 +- 6 files changed, 23 insertions(+), 22 deletions(-)
diff --git a/common/image-cipher.c b/common/image-cipher.c index b9061489396..453bab8c492 100644 --- a/common/image-cipher.c +++ b/common/image-cipher.c @@ -21,7 +21,7 @@ struct cipher_algo cipher_algos[] = { .name = "aes128", .key_len = AES128_KEY_LENGTH, .iv_len = AES_BLOCK_LENGTH, -#if IMAGE_ENABLE_ENCRYPT +#if CONFIG_IS_ENABLED(FIT_CIPHER_ENCRYPT) .calculate_type = EVP_aes_128_cbc, #endif .encrypt = image_aes_encrypt, @@ -32,7 +32,7 @@ struct cipher_algo cipher_algos[] = { .name = "aes192", .key_len = AES192_KEY_LENGTH, .iv_len = AES_BLOCK_LENGTH, -#if IMAGE_ENABLE_ENCRYPT +#if CONFIG_IS_ENABLED(FIT_CIPHER_ENCRYPT) .calculate_type = EVP_aes_192_cbc, #endif .encrypt = image_aes_encrypt, @@ -43,7 +43,7 @@ struct cipher_algo cipher_algos[] = { .name = "aes256", .key_len = AES256_KEY_LENGTH, .iv_len = AES_BLOCK_LENGTH, -#if IMAGE_ENABLE_ENCRYPT +#if CONFIG_IS_ENABLED(FIT_CIPHER_ENCRYPT) .calculate_type = EVP_aes_256_cbc, #endif .encrypt = image_aes_encrypt, diff --git a/common/image-fit.c b/common/image-fit.c index a0987fd52c8..3ee306143b3 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -2132,7 +2132,7 @@ int fit_image_load(bootm_headers_t *images, ulong addr, }
/* Decrypt data before uncompress/move */ - if (IS_ENABLED(CONFIG_FIT_CIPHER) && IMAGE_ENABLE_DECRYPT) { + if (IS_ENABLED(CONFIG_FIT_CIPHER) && CONFIG_IS_ENABLED(FIT_CIPHER)) { puts(" Decrypting Data ... "); if (fit_image_uncipher(fit, noffset, &buf, &size)) { puts("Error\n"); diff --git a/include/image.h b/include/image.h index b388684cbdc..9adbda8ab70 100644 --- a/include/image.h +++ b/include/image.h @@ -1368,18 +1368,8 @@ static inline int fit_image_check_target_arch(const void *fdt, int node) * At present we only support ciphering on the host, and unciphering on the * device */ -#if defined(USE_HOSTCC) -# if defined(CONFIG_FIT_CIPHER) -# define IMAGE_ENABLE_ENCRYPT 1 -# define IMAGE_ENABLE_DECRYPT 1 -# include <openssl/evp.h> -# else -# define IMAGE_ENABLE_ENCRYPT 0 -# define IMAGE_ENABLE_DECRYPT 0 -# endif -#else -# define IMAGE_ENABLE_ENCRYPT 0 -# define IMAGE_ENABLE_DECRYPT CONFIG_IS_ENABLED(FIT_CIPHER) +#if CONFIG_IS_ENABLED(FIT_CIPHER_ENCRYPT) +#include <openssl/evp.h> #endif
/* Information passed to the ciphering routines */ @@ -1402,7 +1392,7 @@ struct cipher_algo { int key_len; /* Length of the key */ int iv_len; /* Length of the IV */
-#if IMAGE_ENABLE_ENCRYPT +#if CONFIG_IS_ENABLED(FIT_CIPHER_ENCRYPT) const EVP_CIPHER * (*calculate_type)(void); #endif
diff --git a/include/u-boot/aes.h b/include/u-boot/aes.h index acbc50b9e6f..1c064610952 100644 --- a/include/u-boot/aes.h +++ b/include/u-boot/aes.h @@ -9,7 +9,7 @@ #include <errno.h> #include <image.h>
-#if IMAGE_ENABLE_ENCRYPT +#if CONFIG_IS_ENABLED(FIT_CIPHER_ENCRYPT) int image_aes_encrypt(struct image_cipher_info *info, const unsigned char *data, int size, unsigned char **cipher, int *cipher_len); @@ -28,9 +28,9 @@ int image_aes_add_cipher_data(struct image_cipher_info *info, void *keydest, { return -ENXIO; } -#endif /* IMAGE_ENABLE_ENCRYPT */ +#endif /* FIT_CIPHER_ENCRYPT */
-#if IMAGE_ENABLE_DECRYPT +#if CONFIG_IS_ENABLED(FIT_CIPHER) int image_aes_decrypt(struct image_cipher_info *info, const void *cipher, size_t cipher_len, void **data, size_t *size); @@ -41,6 +41,6 @@ int image_aes_decrypt(struct image_cipher_info *info, { return -ENXIO; } -#endif /* IMAGE_ENABLE_DECRYPT */ +#endif /* CONFIG_IS_ENABLED(FIT_CIPHER) */
#endif diff --git a/tools/Kconfig b/tools/Kconfig index 13f923c7ac7..5dd33fcbc55 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -19,6 +19,17 @@ config HOST_FIT help Enable FIT support in the host build.
+config HOST_FIT_CIPHER + def_bool y + help + Enable ciphering data in a FIT in the host build + +config HOST_FIT_CIPHER_ENCRYPT + def_bool y + depends on FIT_CIPHER + help + Enables encryption in a FIT in the host build + config HOST_FIT_FULL_CHECK def_bool y help diff --git a/tools/image-host.c b/tools/image-host.c index 2be897db943..1d2d9a6e323 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -560,7 +560,7 @@ int fit_image_cipher_data(const char *keydir, void *keydest, printf("Failure getting cipher node\n"); return -1; } - if (!IMAGE_ENABLE_ENCRYPT || !keydir) + if (!CONFIG_IS_ENABLED(FIT_CIPHER_ENCRYPT) || !keydir) return 0; return fit_image_process_cipher(keydir, keydest, fit, image_name, image_noffset, cipher_node_offset, data, size, cmdname);
This function is only used in one place and does not need to use the preprocessor. Move it to the C file and convert it to a normal function.
Drop fit_unsupported() since it is not used.
common/bootm_os.c | 8 ++++++++ include/image.h | 13 ------------- 2 files changed, 8 insertions(+), 13 deletions(-)
diff --git a/common/bootm_os.c b/common/bootm_os.c index 0b6325db660..70fad4efb55 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -58,6 +58,14 @@ static void copy_args(char *dest, int argc, char *const argv[], char delim) } #endif
+static void __maybe_unused fit_unsupported_reset(const char *msg) +{ + if (CONFIG_IS_ENABLED(FIT_VERBOSE)) { + printf("! FIT images not supported for '%s' - must reset board to recover!\n", + msg); + } +} + #ifdef CONFIG_BOOTM_NETBSD static int do_bootm_netbsd(int flag, int argc, char *const argv[], bootm_headers_t *images) diff --git a/include/image.h b/include/image.h index 9adbda8ab70..d7e0c829841 100644 --- a/include/image.h +++ b/include/image.h @@ -1412,19 +1412,6 @@ int fit_image_cipher_get_algo(const void *fit, int noffset, char **algo);
-#if CONFIG_IS_ENABLED(FIT_VERBOSE) -#define fit_unsupported(msg) printf("! %s:%d " \ - "FIT images not supported for '%s'\n", \ - __FILE__, __LINE__, (msg)) - -#define fit_unsupported_reset(msg) printf("! %s:%d " \ - "FIT images not supported for '%s' " \ - "- must reset board to recover!\n", \ - __FILE__, __LINE__, (msg)) -#else -#define fit_unsupported(msg) -#define fit_unsupported_reset(msg) -#endif /* FIT_VERBOSE */ #endif /* CONFIG_FIT */
This file has a lot of conditional code and much of it is unnecessary. Clean this up to reduce the number of build combinations.
include/image.h | 40 ++++------------------------------ include/u-boot/hash-checksum.h | 5 +++-- lib/hash-checksum.c | 2 +- 3 files changed, 8 insertions(+), 39 deletions(-)
diff --git a/include/image.h b/include/image.h index d7e0c829841..a8b10a8fddb 100644 --- a/include/image.h +++ b/include/image.h @@ -39,12 +39,10 @@ struct fdt_region;
-#if CONFIG_IS_ENABLED(FIT) #include <hash.h> #include <linux/libfdt.h> #include <fdt_support.h> - -#endif /* FIT */ +#include <u-boot/hash-checksum.h>
extern ulong image_load_addr; /* Default Load Address */ extern ulong image_save_addr; /* Default Save Address */ @@ -504,8 +502,7 @@ int genimg_get_type_id(const char *name); int genimg_get_comp_id(const char *name); void genimg_print_size(uint32_t size);
-#if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) || \ - defined(USE_HOSTCC) +#if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) || defined(USE_HOSTCC) #define IMAGE_ENABLE_TIMESTAMP 1 #else #define IMAGE_ENABLE_TIMESTAMP 0 @@ -523,12 +520,9 @@ enum fit_load_op { int boot_get_setup(bootm_headers_t *images, uint8_t arch, ulong *setup_start, ulong *setup_len);
-#ifndef USE_HOSTCC /* Image format types, returned by _get_format() routine */ #define IMAGE_FORMAT_INVALID 0x00 -#if defined(CONFIG_LEGACY_IMAGE_FORMAT) #define IMAGE_FORMAT_LEGACY 0x01 /* legacy image_header based format */ -#endif #define IMAGE_FORMAT_FIT 0x02 /* new, libfdt based format */ #define IMAGE_FORMAT_ANDROID 0x03 /* Android boot image */
@@ -567,7 +561,6 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, */ int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images, uint8_t arch, const ulong *ld_start, ulong *const ld_len); -#endif /* !USE_HOSTCC */
int boot_get_setup_fit(bootm_headers_t *images, uint8_t arch, ulong *setup_start, ulong *setup_len); @@ -644,7 +637,6 @@ int fit_image_load(bootm_headers_t *images, ulong addr, */ int image_source_script(ulong addr, const char *fit_uname);
-#ifndef USE_HOSTCC /** * fit_get_node_from_config() - Look up an image a FIT by type * @@ -684,10 +676,7 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size); int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, ulong *initrd_start, ulong *initrd_end); int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end); -#ifdef CONFIG_SYS_BOOT_GET_KBD int boot_get_kbd(struct lmb *lmb, struct bd_info **kbd); -#endif /* CONFIG_SYS_BOOT_GET_KBD */ -#endif /* !USE_HOSTCC */
/*******************************************************************/ /* Legacy format specific code (prefixed with image_) */ @@ -802,11 +791,9 @@ static inline int image_check_type(const image_header_t *hdr, uint8_t type) } static inline int image_check_arch(const image_header_t *hdr, uint8_t arch) { -#ifndef USE_HOSTCC /* Let's assume that sandbox can load any architecture */ - if (IS_ENABLED(CONFIG_SANDBOX)) + if (!host_build() && IS_ENABLED(CONFIG_SANDBOX)) return true; -#endif return (image_get_arch(hdr) == arch) || (image_get_arch(hdr) == IH_ARCH_ARM && arch == IH_ARCH_ARM64); } @@ -954,7 +941,6 @@ int booti_setup(ulong image, ulong *relocated_addr, ulong *size,
#define FIT_MAX_HASH_LEN HASH_MAX_DIGEST_SIZE
-#if CONFIG_IS_ENABLED(FIT) /* cmdline argument format parsing */ int fit_parse_conf(const char *spec, ulong addr_curr, ulong *addr, const char **conf_name); @@ -1128,7 +1114,6 @@ int fit_conf_get_prop_node(const void *fit, int noffset,
int fit_check_ramdisk(const void *fit, int os_noffset, uint8_t arch, int verify); -#endif /* FIT */
int calculate_hash(const void *data, int data_len, const char *algo, uint8_t *value, int *value_len); @@ -1148,7 +1133,6 @@ int calculate_hash(const void *data, int data_len, const char *algo, # define IMAGE_ENABLE_VERIFY_ECDSA 0 #endif
-#if CONFIG_IS_ENABLED(FIT) #ifdef USE_HOSTCC void *image_get_host_blob(void); void image_set_host_blob(void *host_blob); @@ -1157,8 +1141,6 @@ void image_set_host_blob(void *host_blob); # define gd_fdt_blob() (gd->fdt_blob) #endif
-#endif /* FIT */ - /* * Information passed to the signing routines * @@ -1195,9 +1177,6 @@ struct image_region { int size; };
-#if CONFIG_IS_ENABLED(RSA_VERIFY) -# include <u-boot/hash-checksum.h> -#endif struct checksum_algo { const char *name; const int checksum_len; @@ -1207,7 +1186,7 @@ struct checksum_algo { const EVP_MD *(*calculate_sign)(void); #endif int (*calculate)(const char *name, - const struct image_region region[], + const struct image_region *region, int region_count, uint8_t *checksum); };
@@ -1295,8 +1274,6 @@ struct crypto_algo *image_get_crypto_algo(const char *full_name); */ struct padding_algo *image_get_padding_algo(const char *name);
-#if CONFIG_IS_ENABLED(FIT) - /** * fit_image_verify_required_sigs() - Verify signatures marked as 'required' * @@ -1412,10 +1389,6 @@ int fit_image_cipher_get_algo(const void *fit, int noffset, char **algo);
-#endif /* CONFIG_FIT */ - -#if !defined(USE_HOSTCC) -#if defined(CONFIG_ANDROID_BOOT_IMAGE) struct andr_img_hdr; int android_image_check_header(const struct andr_img_hdr *hdr); int android_image_get_kernel(const struct andr_img_hdr *hdr, int verify, @@ -1431,12 +1404,7 @@ ulong android_image_get_end(const struct andr_img_hdr *hdr); ulong android_image_get_kload(const struct andr_img_hdr *hdr); ulong android_image_get_kcomp(const struct andr_img_hdr *hdr); void android_print_contents(const struct andr_img_hdr *hdr); -#if !defined(CONFIG_SPL_BUILD) bool android_image_print_dtb_contents(ulong hdr_addr); -#endif - -#endif /* CONFIG_ANDROID_BOOT_IMAGE */ -#endif /* !USE_HOSTCC */
/** * board_fit_config_name_match() - Check for a matching board name diff --git a/include/u-boot/hash-checksum.h b/include/u-boot/hash-checksum.h index 54e6a73744e..7f16b37a9ab 100644 --- a/include/u-boot/hash-checksum.h +++ b/include/u-boot/hash-checksum.h @@ -7,11 +7,12 @@ #define _RSA_CHECKSUM_H
#include <errno.h> -#include <image.h> #include <u-boot/sha1.h> #include <u-boot/sha256.h> #include <u-boot/sha512.h>
+struct image_region; + /** * hash_calculate() - Calculate hash over the data * @@ -23,7 +24,7 @@ * @return 0 if OK, < 0 if error */ int hash_calculate(const char *name, - const struct image_region region[], int region_count, + const struct image_region *region, int region_count, uint8_t *checksum);
#endif diff --git a/lib/hash-checksum.c b/lib/hash-checksum.c index d732ecc38fd..8f2a42f9a08 100644 --- a/lib/hash-checksum.c +++ b/lib/hash-checksum.c @@ -17,7 +17,7 @@ #include <image.h>
int hash_calculate(const char *name, - const struct image_region region[], + const struct image_region *region, int region_count, uint8_t *checksum) { struct hash_algo *algo;
Use a simple return to drop the unwanted code.
common/image-fit.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 3ee306143b3..f8aa61fc99d 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -165,7 +165,6 @@ int fit_get_subimage_count(const void *fit, int images_noffset) return count; }
-#if CONFIG_IS_ENABLED(FIT_PRINT) /** * fit_image_print_data() - prints out the hash node details * @fit: pointer to the FIT format image header @@ -375,6 +374,9 @@ void fit_print_contents(const void *fit) const char *p; time_t timestamp;
+ if (!CONFIG_IS_ENABLED(FIT_PRINT)) + return; + /* Indent string is defined in header image.h */ p = IMAGE_INDENT_STRING;
@@ -477,6 +479,9 @@ void fit_image_print(const void *fit, int image_noffset, const char *p) int ndepth; int ret;
+ if (!CONFIG_IS_ENABLED(FIT_PRINT)) + return; + /* Mandatory properties */ ret = fit_get_desc(fit, image_noffset, &desc); printf("%s Description: ", p); @@ -570,10 +575,6 @@ void fit_image_print(const void *fit, int image_noffset, const char *p) } } } -#else -void fit_print_contents(const void *fit) { } -void fit_image_print(const void *fit, int image_noffset, const char *p) { } -#endif /* CONFIG_IS_ENABLED(FIT_PRINT) */
/** * fit_get_desc - get node description property
Remove ifdefs in this file, so far as possible without too much refactoring.
common/image-board.c | 109 +++++++++++++++++++------------------------ include/image.h | 7 ++- 2 files changed, 53 insertions(+), 63 deletions(-)
diff --git a/common/image-board.c b/common/image-board.c index 1a3b0bc7efc..0543c67d3bd 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -227,16 +227,16 @@ ulong genimg_get_kernel_addr_fit(char * const img_addr, kernel_addr = image_load_addr; debug("* kernel: default image load address = 0x%08lx\n", image_load_addr); -#if CONFIG_IS_ENABLED(FIT) - } else if (fit_parse_conf(img_addr, image_load_addr, &kernel_addr, + } else if (CONFIG_IS_ENABLED(FIT) && + fit_parse_conf(img_addr, image_load_addr, &kernel_addr, fit_uname_config)) { debug("* kernel: config '%s' from image at 0x%08lx\n", *fit_uname_config, kernel_addr); - } else if (fit_parse_subimage(img_addr, image_load_addr, &kernel_addr, - fit_uname_kernel)) { + } else if (CONFIG_IS_ENABLED(FIT) && + fit_parse_subimage(img_addr, image_load_addr, &kernel_addr, + fit_uname_kernel)) { debug("* kernel: subimage '%s' from image at 0x%08lx\n", *fit_uname_kernel, kernel_addr); -#endif } else { kernel_addr = simple_strtoul(img_addr, NULL, 16); debug("* kernel: cmdline image address = 0x%08lx\n", @@ -275,21 +275,20 @@ ulong genimg_get_kernel_addr(char * const img_addr) */ int genimg_get_format(const void *img_addr) { -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - const image_header_t *hdr; + if (CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT)) { + const image_header_t *hdr;
- hdr = (const image_header_t *)img_addr; - if (image_check_magic(hdr)) - return IMAGE_FORMAT_LEGACY; -#endif -#if CONFIG_IS_ENABLED(FIT) || CONFIG_IS_ENABLED(OF_LIBFDT) - if (fdt_check_header(img_addr) == 0) - return IMAGE_FORMAT_FIT; -#endif -#ifdef CONFIG_ANDROID_BOOT_IMAGE - if (android_image_check_header(img_addr) == 0) + hdr = (const image_header_t *)img_addr; + if (image_check_magic(hdr)) + return IMAGE_FORMAT_LEGACY; + } + if (CONFIG_IS_ENABLED(FIT) || CONFIG_IS_ENABLED(OF_LIBFDT)) { + if (!fdt_check_header(img_addr)) + return IMAGE_FORMAT_FIT; + } + if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE) && + !android_image_check_header(img_addr)) return IMAGE_FORMAT_ANDROID; -#endif
return IMAGE_FORMAT_INVALID; } @@ -307,10 +306,9 @@ int genimg_get_format(const void *img_addr) */ int genimg_has_config(bootm_headers_t *images) { -#if CONFIG_IS_ENABLED(FIT) - if (images->fit_uname_cfg) + if (CONFIG_IS_ENABLED(FIT) && images->fit_uname_cfg) return 1; -#endif + return 0; }
@@ -345,9 +343,6 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, const image_header_t *rd_hdr; #endif void *buf; -#ifdef CONFIG_SUPPORT_RAW_INITRD - char *end; -#endif #if CONFIG_IS_ENABLED(FIT) const char *fit_uname_config = images->fit_uname_cfg; const char *fit_uname_ramdisk = NULL; @@ -359,14 +354,12 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, *rd_start = 0; *rd_end = 0;
-#ifdef CONFIG_ANDROID_BOOT_IMAGE - /* - * Look for an Android boot image. - */ - buf = map_sysmem(images->os.start, 0); - if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) - select = (argc == 0) ? env_get("loadaddr") : argv[0]; -#endif + if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { + /* Look for an Android boot image */ + buf = map_sysmem(images->os.start, 0); + if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) + select = (argc == 0) ? env_get("loadaddr") : argv[0]; + }
if (argc >= 2) select = argv[1]; @@ -474,22 +467,20 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, break; #endif default: -#ifdef CONFIG_SUPPORT_RAW_INITRD - end = NULL; - if (select) - end = strchr(select, ':'); - if (end) { - rd_len = simple_strtoul(++end, NULL, 16); - rd_data = rd_addr; - } else -#endif - { - puts("Wrong Ramdisk Image Format\n"); - rd_data = 0; - rd_len = 0; - rd_load = 0; - return 1; + if (IS_ENABLED(CONFIG_SUPPORT_RAW_INITRD)) { + char *end = NULL; + + if (select) + end = strchr(select, ':'); + if (end) { + rd_len = simple_strtoul(++end, NULL, 16); + rd_data = rd_addr; + break; + } } + puts("Wrong Ramdisk Image Format\n"); + rd_data = rd_len = rd_load = 0; + return 1; } } else if (images->legacy_hdr_valid && image_check_type(&images->legacy_hdr_os_copy, @@ -524,7 +515,6 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, return 0; }
-#ifdef CONFIG_SYS_BOOT_RAMDISK_HIGH /** * boot_ramdisk_high - relocate init ramdisk * @lmb: pointer to lmb handle, will be used for memory mgmt @@ -595,15 +585,15 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, memmove_wd((void *)*initrd_start, (void *)rd_data, rd_len, CHUNKSZ);
-#ifdef CONFIG_MP /* * Ensure the image is flushed to memory to handle * AMP boot scenarios in which we might not be * HW cache coherent */ - flush_cache((unsigned long)*initrd_start, - ALIGN(rd_len, ARCH_DMA_MINALIGN)); -#endif + if (IS_ENABLED(CONFIG_MP)) { + flush_cache((unsigned long)*initrd_start, + ALIGN(rd_len, ARCH_DMA_MINALIGN)); + } puts("OK\n"); } } else { @@ -618,20 +608,16 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, error: return -1; } -#endif /* CONFIG_SYS_BOOT_RAMDISK_HIGH */
int boot_get_setup(bootm_headers_t *images, u8 arch, ulong *setup_start, ulong *setup_len) { -#if CONFIG_IS_ENABLED(FIT) + if (!CONFIG_IS_ENABLED(FIT)) + return -ENOENT; + return boot_get_setup_fit(images, arch, setup_start, setup_len); -#else - return -ENOENT; -#endif }
-#if CONFIG_IS_ENABLED(FIT) -#if defined(CONFIG_FPGA) int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, u8 arch, const ulong *ld_start, ulong * const ld_len) { @@ -643,6 +629,9 @@ int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, int err; int devnum = 0; /* TODO support multi fpga platforms */
+ if (!IS_ENABLED(CONFIG_FPGA)) + return -ENOSYS; + /* Check to see if the images struct has a FIT configuration */ if (!genimg_has_config(images)) { debug("## FIT configuration was not specified\n"); @@ -714,7 +703,6 @@ int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images,
return 0; } -#endif
static void fit_loadable_process(u8 img_type, ulong img_data, @@ -812,7 +800,6 @@ int boot_get_loadable(int argc, char *const argv[], bootm_headers_t *images,
return 0; } -#endif
/** * boot_get_cmdline - allocate and initialize kernel cmdline diff --git a/include/image.h b/include/image.h index a8b10a8fddb..6336e55928c 100644 --- a/include/image.h +++ b/include/image.h @@ -297,7 +297,11 @@ typedef struct bootm_headers { image_header_t legacy_hdr_os_copy; /* header copy */ ulong legacy_hdr_valid;
-#if CONFIG_IS_ENABLED(FIT) + /* + * The fit_ members are only used with FIT, but it involves a lot of + * #ifdefs to avoid compiling that code. Since FIT is the standard + * format, even for SPL, this extra data size seems worth it. + */ const char *fit_uname_cfg; /* configuration node unit name */
void *fit_hdr_os; /* os FIT image header */ @@ -315,7 +319,6 @@ typedef struct bootm_headers { void *fit_hdr_setup; /* x86 setup FIT image header */ const char *fit_uname_setup; /* x86 setup subimage node name */ int fit_noffset_setup;/* x86 setup subimage node offset */ -#endif
#ifndef USE_HOSTCC image_info_t os; /* os image info */
Move the variables declarations to where they are needed, to reduce the number of #ifdefs needed.
(no changes since v1)
common/image-board.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/common/image-board.c b/common/image-board.c index 0543c67d3bd..f0ef426d1c9 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -337,18 +337,8 @@ int genimg_has_config(bootm_headers_t *images) int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, u8 arch, ulong *rd_start, ulong *rd_end) { - ulong rd_addr, rd_load; ulong rd_data, rd_len; -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - const image_header_t *rd_hdr; -#endif void *buf; -#if CONFIG_IS_ENABLED(FIT) - const char *fit_uname_config = images->fit_uname_cfg; - const char *fit_uname_ramdisk = NULL; - ulong default_addr; - int rd_noffset; -#endif const char *select = NULL;
*rd_start = 0; @@ -373,8 +363,15 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, rd_len = 0; rd_data = 0; } else if (select || genimg_has_config(images)) { + ulong rd_addr, rd_load; + #if CONFIG_IS_ENABLED(FIT) + const char *fit_uname_config = images->fit_uname_cfg; + const char *fit_uname_ramdisk = NULL; + int rd_noffset; + if (select) { + ulong default_addr; /* * If the init ramdisk comes from the FIT image and * the FIT image address is omitted in the command @@ -427,7 +424,9 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, buf = map_sysmem(rd_addr, 0); switch (genimg_get_format(buf)) { #if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - case IMAGE_FORMAT_LEGACY: + case IMAGE_FORMAT_LEGACY: { + const image_header_t *rd_hdr; + printf("## Loading init Ramdisk from Legacy Image at %08lx ...\n", rd_addr);
@@ -442,6 +441,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, rd_len = image_get_data_size(rd_hdr); rd_load = image_get_load(rd_hdr); break; + } #endif #if CONFIG_IS_ENABLED(FIT) case IMAGE_FORMAT_FIT:
This function is far too long. Before trying to remove #ifdefs, split out the code that deals with selecting the ramdisk into a separate function.
Leave the code indented as it was for easier review. The next patch cleans this up along with checkpatch violations.
common/image-board.c | 147 +++++++++++++++++++++++++------------------ 1 file changed, 87 insertions(+), 60 deletions(-)
diff --git a/common/image-board.c b/common/image-board.c index f0ef426d1c9..c32fff96ece 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -313,57 +313,21 @@ int genimg_has_config(bootm_headers_t *images) }
/** - * boot_get_ramdisk - main ramdisk handling routine - * @argc: command argument count - * @argv: command argument list + * select_ramdisk() - Select and locate the ramdisk to use + * * @images: pointer to the bootm images structure + * @select: name of ramdisk to select, or NULL for any * @arch: expected ramdisk architecture - * @rd_start: pointer to a ulong variable, will hold ramdisk start address - * @rd_end: pointer to a ulong variable, will hold ramdisk end - * - * boot_get_ramdisk() is responsible for finding a valid ramdisk image. - * Currently supported are the following ramdisk sources: - * - multicomponent kernel/ramdisk image, - * - commandline provided address of decicated ramdisk image. - * - * returns: - * 0, if ramdisk image was found and valid, or skiped - * rd_start and rd_end are set to ramdisk start/end addresses if - * ramdisk image is found and valid - * - * 1, if ramdisk image is found but corrupted, or invalid - * rd_start and rd_end are set to 0 if no ramdisk exists + * @rd_datap: pointer to a ulong variable, will hold ramdisk pointer + * @rd_lenp: pointer to a ulong variable, will hold ramdisk length + * @return 0 if OK, -ENOPKG if no ramdisk (but an error should not be reported), + * other -ve value on other error */ -int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, - u8 arch, ulong *rd_start, ulong *rd_end) +static int select_ramdisk(bootm_headers_t *images, const char *select, u8 arch, + ulong *rd_datap, ulong *rd_lenp) { - ulong rd_data, rd_len; - void *buf; - const char *select = NULL; - - *rd_start = 0; - *rd_end = 0; - - if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { - /* Look for an Android boot image */ - buf = map_sysmem(images->os.start, 0); - if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) - select = (argc == 0) ? env_get("loadaddr") : argv[0]; - } - - if (argc >= 2) - select = argv[1]; - - /* - * Look for a '-' which indicates to ignore the - * ramdisk argument - */ - if (select && strcmp(select, "-") == 0) { - debug("## Skipping init Ramdisk\n"); - rd_len = 0; - rd_data = 0; - } else if (select || genimg_has_config(images)) { - ulong rd_addr, rd_load; + ulong rd_addr, rd_load; + char *buf;
#if CONFIG_IS_ENABLED(FIT) const char *fit_uname_config = images->fit_uname_cfg; @@ -403,16 +367,16 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, } else { /* use FIT configuration provided in first bootm * command argument. If the property is not defined, - * quit silently. + * quit silently (with -ENOPKG) */ rd_addr = map_to_sysmem(images->fit_hdr_os); rd_noffset = fit_get_node_from_config(images, FIT_RAMDISK_PROP, rd_addr); if (rd_noffset == -ENOENT) - return 0; + return -ENOPKG; else if (rd_noffset < 0) - return 1; + return rd_noffset; } #endif
@@ -435,10 +399,10 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, images->verify);
if (!rd_hdr) - return 1; + return -ENOENT;
- rd_data = image_get_data(rd_hdr); - rd_len = image_get_data_size(rd_hdr); + *rd_datap = image_get_data(rd_hdr); + *rd_lenp = image_get_data_size(rd_hdr); rd_load = image_get_load(rd_hdr); break; } @@ -451,9 +415,9 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, IH_TYPE_RAMDISK, BOOTSTAGE_ID_FIT_RD_START, FIT_LOAD_OPTIONAL_NON_ZERO, - &rd_data, &rd_len); + rd_datap, rd_lenp); if (rd_noffset < 0) - return 1; + return rd_noffset;
images->fit_hdr_rd = map_sysmem(rd_addr, 0); images->fit_uname_rd = fit_uname_ramdisk; @@ -463,7 +427,7 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, #ifdef CONFIG_ANDROID_BOOT_IMAGE case IMAGE_FORMAT_ANDROID: android_image_get_ramdisk((void *)images->os.start, - &rd_data, &rd_len); + rd_datap, rd_lenp); break; #endif default: @@ -473,15 +437,78 @@ int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, if (select) end = strchr(select, ':'); if (end) { - rd_len = simple_strtoul(++end, NULL, 16); - rd_data = rd_addr; + *rd_lenp = simple_strtoul(++end, NULL, 16); + *rd_datap = rd_addr; break; } } puts("Wrong Ramdisk Image Format\n"); - rd_data = rd_len = rd_load = 0; - return 1; + *rd_datap = *rd_lenp = rd_load = 0; + return -EINVAL; } + + return 0; +} + +/** + * boot_get_ramdisk - main ramdisk handling routine + * @argc: command argument count + * @argv: command argument list + * @images: pointer to the bootm images structure + * @arch: expected ramdisk architecture + * @rd_start: pointer to a ulong variable, will hold ramdisk start address + * @rd_end: pointer to a ulong variable, will hold ramdisk end + * + * boot_get_ramdisk() is responsible for finding a valid ramdisk image. + * Currently supported are the following ramdisk sources: + * - multicomponent kernel/ramdisk image, + * - commandline provided address of decicated ramdisk image. + * + * returns: + * 0, if ramdisk image was found and valid, or skiped + * rd_start and rd_end are set to ramdisk start/end addresses if + * ramdisk image is found and valid + * + * 1, if ramdisk image is found but corrupted, or invalid + * rd_start and rd_end are set to 0 if no ramdisk exists + */ +int boot_get_ramdisk(int argc, char *const argv[], bootm_headers_t *images, + u8 arch, ulong *rd_start, ulong *rd_end) +{ + ulong rd_data, rd_len; + const char *select = NULL; + + *rd_start = 0; + *rd_end = 0; + + if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { + char *buf; + + /* Look for an Android boot image */ + buf = map_sysmem(images->os.start, 0); + if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) + select = (argc == 0) ? env_get("loadaddr") : argv[0]; + } + + if (argc >= 2) + select = argv[1]; + + /* + * Look for a '-' which indicates to ignore the + * ramdisk argument + */ + if (select && strcmp(select, "-") == 0) { + debug("## Skipping init Ramdisk\n"); + rd_len = 0; + rd_data = 0; + } else if (select || genimg_has_config(images)) { + int ret; + + ret = select_ramdisk(images, select, arch, &rd_data, &rd_len); + if (ret == -ENOPKG) + return 0; + else if (ret) + return ret; } else if (images->legacy_hdr_valid && image_check_type(&images->legacy_hdr_os_copy, IH_TYPE_MULTI)) {
Use boolean variables to deal with the strange #ifdef logic of this function, so we can remove the #ifdefs.
common/image-board.c | 139 ++++++++++++++++++++++--------------------- 1 file changed, 72 insertions(+), 67 deletions(-)
diff --git a/common/image-board.c b/common/image-board.c index c32fff96ece..0c057e77951 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -26,7 +26,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) /** * image_get_ramdisk - get and verify ramdisk image * @rd_addr: ramdisk image start address @@ -85,7 +84,6 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, u8 arch,
return rd_hdr; } -#endif
/*****************************************************************************/ /* Shared dual-format routines */ @@ -326,16 +324,18 @@ int genimg_has_config(bootm_headers_t *images) static int select_ramdisk(bootm_headers_t *images, const char *select, u8 arch, ulong *rd_datap, ulong *rd_lenp) { - ulong rd_addr, rd_load; + ulong rd_addr = 0, rd_load; char *buf; + const char *fit_uname_config = images->fit_uname_cfg; + const char *fit_uname_ramdisk = NULL; + bool processed; + int rd_noffset;
-#if CONFIG_IS_ENABLED(FIT) - const char *fit_uname_config = images->fit_uname_cfg; - const char *fit_uname_ramdisk = NULL; - int rd_noffset; + if (select) { + ulong default_addr; + bool done = true;
- if (select) { - ulong default_addr; + if (CONFIG_IS_ENABLED(FIT)) { /* * If the init ramdisk comes from the FIT image and * the FIT image address is omitted in the command @@ -347,8 +347,8 @@ static int select_ramdisk(bootm_headers_t *images, const char *select, u8 arch, else default_addr = image_load_addr;
- if (fit_parse_conf(select, default_addr, - &rd_addr, &fit_uname_config)) { + if (fit_parse_conf(select, default_addr, &rd_addr, + &fit_uname_config)) { debug("* ramdisk: config '%s' from image at 0x%08lx\n", fit_uname_config, rd_addr); } else if (fit_parse_subimage(select, default_addr, @@ -356,61 +356,59 @@ static int select_ramdisk(bootm_headers_t *images, const char *select, u8 arch, &fit_uname_ramdisk)) { debug("* ramdisk: subimage '%s' from image at 0x%08lx\n", fit_uname_ramdisk, rd_addr); - } else -#endif - { - rd_addr = simple_strtoul(select, NULL, 16); - debug("* ramdisk: cmdline image address = 0x%08lx\n", - rd_addr); + } else { + done = false; } -#if CONFIG_IS_ENABLED(FIT) - } else { - /* use FIT configuration provided in first bootm - * command argument. If the property is not defined, - * quit silently (with -ENOPKG) - */ - rd_addr = map_to_sysmem(images->fit_hdr_os); - rd_noffset = fit_get_node_from_config(images, - FIT_RAMDISK_PROP, - rd_addr); - if (rd_noffset == -ENOENT) - return -ENOPKG; - else if (rd_noffset < 0) - return rd_noffset; } -#endif - - /* - * Check if there is an initrd image at the - * address provided in the second bootm argument - * check image type, for FIT images get FIT node. + if (!done) { + rd_addr = simple_strtoul(select, NULL, 16); + debug("* ramdisk: cmdline image address = 0x%08lx\n", + rd_addr); + } + } else if (CONFIG_IS_ENABLED(FIT)) { + /* use FIT configuration provided in first bootm + * command argument. If the property is not defined, + * quit silently (with -ENOPKG ) */ - buf = map_sysmem(rd_addr, 0); - switch (genimg_get_format(buf)) { -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - case IMAGE_FORMAT_LEGACY: { + rd_addr = map_to_sysmem(images->fit_hdr_os); + rd_noffset = fit_get_node_from_config(images, FIT_RAMDISK_PROP, + rd_addr); + if (rd_noffset == -ENOENT) + return -ENOPKG; + else if (rd_noffset < 0) + return rd_noffset; + } + + /* + * Check if there is an initrd image at the + * address provided in the second bootm argument + * check image type, for FIT images get FIT node. + */ + buf = map_sysmem(rd_addr, 0); + processed = false; + switch (genimg_get_format(buf)) { + case IMAGE_FORMAT_LEGACY: + if (CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT)) { const image_header_t *rd_hdr;
bootstage_mark(BOOTSTAGE_ID_CHECK_RAMDISK); - rd_hdr = image_get_ramdisk(rd_addr, arch, - images->verify); - + rd_hdr = image_get_ramdisk(rd_addr, arch, images->verify); if (!rd_hdr) return -ENOENT;
*rd_datap = image_get_data(rd_hdr); *rd_lenp = image_get_data_size(rd_hdr); rd_load = image_get_load(rd_hdr); - break; + processed = true; } -#endif -#if CONFIG_IS_ENABLED(FIT) - case IMAGE_FORMAT_FIT: - rd_noffset = fit_image_load(images, - rd_addr, &fit_uname_ramdisk, + break; + case IMAGE_FORMAT_FIT: + if (CONFIG_IS_ENABLED(FIT)) { + rd_noffset = fit_image_load(images, rd_addr, + &fit_uname_ramdisk, &fit_uname_config, arch, IH_TYPE_RAMDISK, BOOTSTAGE_ID_FIT_RD_START, @@ -422,30 +420,37 @@ static int select_ramdisk(bootm_headers_t *images, const char *select, u8 arch, images->fit_hdr_rd = map_sysmem(rd_addr, 0); images->fit_uname_rd = fit_uname_ramdisk; images->fit_noffset_rd = rd_noffset; - break; -#endif -#ifdef CONFIG_ANDROID_BOOT_IMAGE - case IMAGE_FORMAT_ANDROID: + processed = true; + } + break; + case IMAGE_FORMAT_ANDROID: + if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { android_image_get_ramdisk((void *)images->os.start, rd_datap, rd_lenp); - break; -#endif - default: - if (IS_ENABLED(CONFIG_SUPPORT_RAW_INITRD)) { - char *end = NULL; - - if (select) - end = strchr(select, ':'); - if (end) { - *rd_lenp = simple_strtoul(++end, NULL, 16); - *rd_datap = rd_addr; - break; - } + processed = true; + } + break; + } + + if (!processed) { + if (IS_ENABLED(CONFIG_SUPPORT_RAW_INITRD)) { + char *end = NULL; + + if (select) + end = strchr(select, ':'); + if (end) { + *rd_lenp = simple_strtoul(++end, NULL, 16); + *rd_datap = rd_addr; + processed = true; } + } + + if (!processed) { puts("Wrong Ramdisk Image Format\n"); *rd_datap = *rd_lenp = rd_load = 0; return -EINVAL; } + }
return 0; }
Drop the #ifdefs which are easy to remove without refactoring.
common/Kconfig.boot | 10 ++++++++++ common/image-fit-sig.c | 8 ++------ common/image-fit.c | 7 ++++--- 3 files changed, 16 insertions(+), 9 deletions(-)
diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 03a6e6f214f..a31d9847124 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -191,6 +191,16 @@ config SPL_FIT_SIGNATURE select SPL_IMAGE_SIGN_INFO select SPL_FIT_FULL_CHECK
+config SPL_FIT_SIGNATURE_MAX_SIZE + hex "Max size of signed FIT structures in SPL" + depends on SPL_FIT_SIGNATURE + default 0x10000000 + help + This option sets a max size in bytes for verified FIT uImages. + A sane value of 256MB protects corrupted DTB structures from overlapping + device memory. Assure this size does not extend past expected storage + space. + config SPL_LOAD_FIT bool "Enable SPL loading U-Boot as a FIT (basic fitImage features)" select SPL_FIT diff --git a/common/image-fit-sig.c b/common/image-fit-sig.c index 12a6745c642..22f89861048 100644 --- a/common/image-fit-sig.c +++ b/common/image-fit-sig.c @@ -49,10 +49,8 @@ struct image_region *fit_region_make_list(const void *fit, * Use malloc() except in SPL (to save code size). In SPL the caller * must allocate the array. */ -#ifndef CONFIG_SPL_BUILD - if (!region) + if (!IS_ENABLED(CONFIG_SPL_BUILD) && !region) region = calloc(sizeof(*region), count); -#endif if (!region) return NULL; for (i = 0; i < count; i++) { @@ -72,12 +70,10 @@ static int fit_image_setup_verify(struct image_sign_info *info, char *algo_name; const char *padding_name;
-#ifndef USE_HOSTCC - if (fdt_totalsize(fit) > CONFIG_FIT_SIGNATURE_MAX_SIZE) { + if (fdt_totalsize(fit) > CONFIG_VAL(FIT_SIGNATURE_MAX_SIZE)) { *err_msgp = "Total size too large"; return 1; } -#endif if (fit_image_hash_get_algo(fit, noffset, &algo_name)) { *err_msgp = "Can't get hash algo property"; return -1; diff --git a/common/image-fit.c b/common/image-fit.c index f8aa61fc99d..882e872144f 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1993,9 +1993,6 @@ int fit_image_load(bootm_headers_t *images, ulong addr, int type_ok, os_ok; ulong load, load_end, data, len; uint8_t os, comp; -#ifndef USE_HOSTCC - uint8_t os_arch; -#endif const char *prop_name; int ret;
@@ -2087,8 +2084,12 @@ int fit_image_load(bootm_headers_t *images, ulong addr, }
#ifndef USE_HOSTCC + { + uint8_t os_arch; + fit_image_get_arch(fit, noffset, &os_arch); images->os.arch = os_arch; + } #endif
bootstage_mark(bootstage_id + BOOTSTAGE_SUB_CHECK_ALL);
common/image-fdt.c | 23 +++++++++++------------ 1 file changed, 11 insertions(+), 12 deletions(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index 80bfa625ab2..524adbd1339 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -269,21 +269,10 @@ error: int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch, bootm_headers_t *images, char **of_flat_tree, ulong *of_size) { -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - const image_header_t *fdt_hdr; - ulong load, load_end; - ulong image_start, image_data, image_end; -#endif ulong img_addr; ulong fdt_addr; char *fdt_blob = NULL; void *buf; -#if CONFIG_IS_ENABLED(FIT) - const char *fit_uname_config = images->fit_uname_cfg; - const char *fit_uname_fdt = NULL; - ulong default_addr; - int fdt_noffset; -#endif const char *select = NULL;
*of_flat_tree = NULL; @@ -297,6 +286,11 @@ int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch, select = argv[2]; if (select || genimg_has_config(images)) { #if CONFIG_IS_ENABLED(FIT) + const char *fit_uname_config = images->fit_uname_cfg; + const char *fit_uname_fdt = NULL; + ulong default_addr; + int fdt_noffset; + if (select) { /* * If the FDT blob comes from the FIT image and the @@ -352,7 +346,11 @@ int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch, buf = map_sysmem(fdt_addr, 0); switch (genimg_get_format(buf)) { #if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - case IMAGE_FORMAT_LEGACY: + case IMAGE_FORMAT_LEGACY: { + const image_header_t *fdt_hdr; + ulong load, load_end; + ulong image_start, image_data, image_end; + /* verify fdt_addr points to a valid image header */ printf("## Flattened Device Tree from Legacy Image at %08lx\n", fdt_addr); @@ -391,6 +389,7 @@ int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch,
fdt_addr = load; break; + } #endif case IMAGE_FORMAT_FIT: /*
This function is far too long. Before trying to remove #ifdefs, split out the code that deals with selecting the FDT into a separate function.
common/image-fdt.c | 319 ++++++++++++++++++++++++--------------------- 1 file changed, 173 insertions(+), 146 deletions(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index 524adbd1339..c17c23e1295 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -244,6 +244,173 @@ error: return 1; }
+/** + * select_fdt() - Select and locate the FDT to use + * + * @images: pointer to the bootm images structure + * @select: name of FDT to select, or NULL for any + * @arch: expected FDT architecture + * @fdt_addrp: pointer to a ulong variable, will hold FDT pointer + * @return 0 if OK, -ENOPKG if no FDT (but an error should not be reported), + * other -ve value on other error + */ + +static int select_fdt(bootm_headers_t *images, const char *select, u8 arch, + ulong *fdt_addrp) +{ + const char *buf; + ulong fdt_addr; + +#if CONFIG_IS_ENABLED(FIT) + const char *fit_uname_config = images->fit_uname_cfg; + const char *fit_uname_fdt = NULL; + ulong default_addr; + int fdt_noffset; + + if (select) { + /* + * If the FDT blob comes from the FIT image and the + * FIT image address is omitted in the command line + * argument, try to use ramdisk or os FIT image + * address or default load address. + */ + if (images->fit_uname_rd) + default_addr = (ulong)images->fit_hdr_rd; + else if (images->fit_uname_os) + default_addr = (ulong)images->fit_hdr_os; + else + default_addr = image_load_addr; + + if (fit_parse_conf(select, default_addr, &fdt_addr, + &fit_uname_config)) { + debug("* fdt: config '%s' from image at 0x%08lx\n", + fit_uname_config, fdt_addr); + } else if (fit_parse_subimage(select, default_addr, &fdt_addr, + &fit_uname_fdt)) { + debug("* fdt: subimage '%s' from image at 0x%08lx\n", + fit_uname_fdt, fdt_addr); + } else +#endif + { + fdt_addr = simple_strtoul(select, NULL, 16); + debug("* fdt: cmdline image address = 0x%08lx\n", + fdt_addr); + } +#if CONFIG_IS_ENABLED(FIT) + } else { + /* use FIT configuration provided in first bootm + * command argument + */ + fdt_addr = map_to_sysmem(images->fit_hdr_os); + fdt_noffset = fit_get_node_from_config(images, FIT_FDT_PROP, + fdt_addr); + if (fdt_noffset == -ENOENT) + return -ENOPKG; + else if (fdt_noffset < 0) + return fdt_noffset; + } +#endif + debug("## Checking for 'FDT'/'FDT Image' at %08lx\n", + fdt_addr); + + /* + * Check if there is an FDT image at the + * address provided in the second bootm argument + * check image type, for FIT images get a FIT node. + */ + buf = map_sysmem(fdt_addr, 0); + switch (genimg_get_format(buf)) { +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) + case IMAGE_FORMAT_LEGACY: { + const image_header_t *fdt_hdr; + ulong load, load_end; + ulong image_start, image_data, image_end; + + /* verify fdt_addr points to a valid image header */ + printf("## Flattened Device Tree from Legacy Image at %08lx\n", + fdt_addr); + fdt_hdr = image_get_fdt(fdt_addr); + if (!fdt_hdr) + return -ENOPKG; + + /* + * move image data to the load address, + * make sure we don't overwrite initial image + */ + image_start = (ulong)fdt_hdr; + image_data = (ulong)image_get_data(fdt_hdr); + image_end = image_get_image_end(fdt_hdr); + + load = image_get_load(fdt_hdr); + load_end = load + image_get_data_size(fdt_hdr); + + if (load == image_start || + load == image_data) { + fdt_addr = load; + break; + } + + if ((load < image_end) && (load_end > image_start)) { + fdt_error("fdt overwritten"); + return -EFAULT; + } + + debug(" Loading FDT from 0x%08lx to 0x%08lx\n", + image_data, load); + + memmove((void *)load, + (void *)image_data, + image_get_data_size(fdt_hdr)); + + fdt_addr = load; + break; + } +#endif + case IMAGE_FORMAT_FIT: + /* + * This case will catch both: new uImage format + * (libfdt based) and raw FDT blob (also libfdt + * based). + */ +#if CONFIG_IS_ENABLED(FIT) + /* check FDT blob vs FIT blob */ + if (!fit_check_format(buf, IMAGE_SIZE_INVAL)) { + ulong load, len; + + fdt_noffset = boot_get_fdt_fit(images, fdt_addr, + &fit_uname_fdt, + &fit_uname_config, + arch, &load, &len); + + if (fdt_noffset < 0) + return -ENOENT; + + images->fit_hdr_fdt = map_sysmem(fdt_addr, 0); + images->fit_uname_fdt = fit_uname_fdt; + images->fit_noffset_fdt = fdt_noffset; + fdt_addr = load; + + break; + } else +#endif + { + /* + * FDT blob + */ + debug("* fdt: raw FDT blob\n"); + printf("## Flattened Device Tree blob at %08lx\n", + (long)fdt_addr); + } + break; + default: + puts("ERROR: Did not find a cmdline Flattened Device Tree\n"); + return -ENOENT; + } + *fdt_addrp = fdt_addr; + + return 0; +} + /** * boot_get_fdt - main fdt handling routine * @argc: command argument count @@ -285,153 +452,13 @@ int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch, if (argc > 2) select = argv[2]; if (select || genimg_has_config(images)) { -#if CONFIG_IS_ENABLED(FIT) - const char *fit_uname_config = images->fit_uname_cfg; - const char *fit_uname_fdt = NULL; - ulong default_addr; - int fdt_noffset; - - if (select) { - /* - * If the FDT blob comes from the FIT image and the - * FIT image address is omitted in the command line - * argument, try to use ramdisk or os FIT image - * address or default load address. - */ - if (images->fit_uname_rd) - default_addr = (ulong)images->fit_hdr_rd; - else if (images->fit_uname_os) - default_addr = (ulong)images->fit_hdr_os; - else - default_addr = image_load_addr; - - if (fit_parse_conf(select, default_addr, - &fdt_addr, &fit_uname_config)) { - debug("* fdt: config '%s' from image at 0x%08lx\n", - fit_uname_config, fdt_addr); - } else if (fit_parse_subimage(select, default_addr, - &fdt_addr, &fit_uname_fdt)) { - debug("* fdt: subimage '%s' from image at 0x%08lx\n", - fit_uname_fdt, fdt_addr); - } else -#endif - { - fdt_addr = simple_strtoul(select, NULL, 16); - debug("* fdt: cmdline image address = 0x%08lx\n", - fdt_addr); - } -#if CONFIG_IS_ENABLED(FIT) - } else { - /* use FIT configuration provided in first bootm - * command argument - */ - fdt_addr = map_to_sysmem(images->fit_hdr_os); - fdt_noffset = fit_get_node_from_config(images, - FIT_FDT_PROP, - fdt_addr); - if (fdt_noffset == -ENOENT) - return 0; - else if (fdt_noffset < 0) - return 1; - } -#endif - debug("## Checking for 'FDT'/'FDT Image' at %08lx\n", - fdt_addr); - - /* - * Check if there is an FDT image at the - * address provided in the second bootm argument - * check image type, for FIT images get a FIT node. - */ - buf = map_sysmem(fdt_addr, 0); - switch (genimg_get_format(buf)) { -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - case IMAGE_FORMAT_LEGACY: { - const image_header_t *fdt_hdr; - ulong load, load_end; - ulong image_start, image_data, image_end; - - /* verify fdt_addr points to a valid image header */ - printf("## Flattened Device Tree from Legacy Image at %08lx\n", - fdt_addr); - fdt_hdr = image_get_fdt(fdt_addr); - if (!fdt_hdr) - goto no_fdt; - - /* - * move image data to the load address, - * make sure we don't overwrite initial image - */ - image_start = (ulong)fdt_hdr; - image_data = (ulong)image_get_data(fdt_hdr); - image_end = image_get_image_end(fdt_hdr); - - load = image_get_load(fdt_hdr); - load_end = load + image_get_data_size(fdt_hdr); - - if (load == image_start || - load == image_data) { - fdt_addr = load; - break; - } - - if ((load < image_end) && (load_end > image_start)) { - fdt_error("fdt overwritten"); - goto error; - } - - debug(" Loading FDT from 0x%08lx to 0x%08lx\n", - image_data, load); - - memmove((void *)load, - (void *)image_data, - image_get_data_size(fdt_hdr)); - - fdt_addr = load; - break; - } -#endif - case IMAGE_FORMAT_FIT: - /* - * This case will catch both: new uImage format - * (libfdt based) and raw FDT blob (also libfdt - * based). - */ -#if CONFIG_IS_ENABLED(FIT) - /* check FDT blob vs FIT blob */ - if (!fit_check_format(buf, IMAGE_SIZE_INVAL)) { - ulong load, len; - - fdt_noffset = boot_get_fdt_fit(images, - fdt_addr, &fit_uname_fdt, - &fit_uname_config, - arch, &load, &len); - - if (fdt_noffset < 0) - goto error; - - images->fit_hdr_fdt = map_sysmem(fdt_addr, 0); - images->fit_uname_fdt = fit_uname_fdt; - images->fit_noffset_fdt = fdt_noffset; - fdt_addr = load; - - break; - } else -#endif - { - /* - * FDT blob - */ - debug("* fdt: raw FDT blob\n"); - printf("## Flattened Device Tree blob at %08lx\n", - (long)fdt_addr); - } - break; - default: - puts("ERROR: Did not find a cmdline Flattened Device Tree\n"); - goto error; - } + int ret;
+ ret = select_fdt(images, select, arch, &fdt_addr); + if (ret == -ENOPKG) + goto no_fdt; + else if (ret) + return 1; printf(" Booting using the fdt blob at %#08lx\n", fdt_addr); fdt_blob = map_sysmem(fdt_addr, 0); } else if (images->legacy_hdr_valid &&
Use boolean variables to deal with the strange #ifdef logic of this function, so we can remove the #ifdefs. Also drop one from its caller, boot_get_fdt()
common/image-fdt.c | 201 ++++++++++++++++++++++----------------------- 1 file changed, 100 insertions(+), 101 deletions(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index c17c23e1295..8afd6ed94a6 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -39,7 +39,6 @@ static void fdt_error(const char *msg) puts(" - must RESET the board to recover.\n"); }
-#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) static const image_header_t *image_get_fdt(ulong fdt_addr) { const image_header_t *fdt_hdr = map_sysmem(fdt_addr, 0); @@ -72,7 +71,6 @@ static const image_header_t *image_get_fdt(ulong fdt_addr) } return fdt_hdr; } -#endif
static void boot_fdt_reserve_region(struct lmb *lmb, uint64_t addr, uint64_t size) @@ -258,46 +256,49 @@ error: static int select_fdt(bootm_headers_t *images, const char *select, u8 arch, ulong *fdt_addrp) { - const char *buf; - ulong fdt_addr; - -#if CONFIG_IS_ENABLED(FIT) const char *fit_uname_config = images->fit_uname_cfg; const char *fit_uname_fdt = NULL; - ulong default_addr; int fdt_noffset; + const char *buf; + bool processed; + ulong fdt_addr = 0;
if (select) { - /* - * If the FDT blob comes from the FIT image and the - * FIT image address is omitted in the command line - * argument, try to use ramdisk or os FIT image - * address or default load address. - */ - if (images->fit_uname_rd) - default_addr = (ulong)images->fit_hdr_rd; - else if (images->fit_uname_os) - default_addr = (ulong)images->fit_hdr_os; - else - default_addr = image_load_addr; - - if (fit_parse_conf(select, default_addr, &fdt_addr, - &fit_uname_config)) { - debug("* fdt: config '%s' from image at 0x%08lx\n", - fit_uname_config, fdt_addr); - } else if (fit_parse_subimage(select, default_addr, &fdt_addr, - &fit_uname_fdt)) { - debug("* fdt: subimage '%s' from image at 0x%08lx\n", - fit_uname_fdt, fdt_addr); - } else -#endif - { + ulong default_addr; + bool done = true; + + if (CONFIG_IS_ENABLED(FIT)) { + /* + * If the FDT blob comes from the FIT image and the + * FIT image address is omitted in the command line + * argument, try to use ramdisk or os FIT image + * address or default load address. + */ + if (images->fit_uname_rd) + default_addr = (ulong)images->fit_hdr_rd; + else if (images->fit_uname_os) + default_addr = (ulong)images->fit_hdr_os; + else + default_addr = image_load_addr; + + if (fit_parse_conf(select, default_addr, &fdt_addr, + &fit_uname_config)) { + debug("* fdt: config '%s' from image at 0x%08lx\n", + fit_uname_config, fdt_addr); + } else if (fit_parse_subimage(select, default_addr, &fdt_addr, + &fit_uname_fdt)) { + debug("* fdt: subimage '%s' from image at 0x%08lx\n", + fit_uname_fdt, fdt_addr); + } else { + done = false; + } + } + if (!done) { fdt_addr = simple_strtoul(select, NULL, 16); debug("* fdt: cmdline image address = 0x%08lx\n", fdt_addr); } -#if CONFIG_IS_ENABLED(FIT) - } else { + } else if (CONFIG_IS_ENABLED(FIT)) { /* use FIT configuration provided in first bootm * command argument */ @@ -309,7 +310,6 @@ static int select_fdt(bootm_headers_t *images, const char *select, u8 arch, else if (fdt_noffset < 0) return fdt_noffset; } -#endif debug("## Checking for 'FDT'/'FDT Image' at %08lx\n", fdt_addr);
@@ -319,90 +319,90 @@ static int select_fdt(bootm_headers_t *images, const char *select, u8 arch, * check image type, for FIT images get a FIT node. */ buf = map_sysmem(fdt_addr, 0); + processed = false; switch (genimg_get_format(buf)) { -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - case IMAGE_FORMAT_LEGACY: { - const image_header_t *fdt_hdr; - ulong load, load_end; - ulong image_start, image_data, image_end; - - /* verify fdt_addr points to a valid image header */ - printf("## Flattened Device Tree from Legacy Image at %08lx\n", - fdt_addr); - fdt_hdr = image_get_fdt(fdt_addr); - if (!fdt_hdr) - return -ENOPKG; + case IMAGE_FORMAT_LEGACY: + if (CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT)) { + const image_header_t *fdt_hdr; + ulong load, load_end; + ulong image_start, image_data, image_end; + + processed = true; + /* verify fdt_addr points to a valid image header */ + printf("## Flattened Device Tree from Legacy Image at %08lx\n", + fdt_addr); + fdt_hdr = image_get_fdt(fdt_addr); + if (!fdt_hdr) + return -ENOPKG;
- /* - * move image data to the load address, - * make sure we don't overwrite initial image - */ - image_start = (ulong)fdt_hdr; - image_data = (ulong)image_get_data(fdt_hdr); - image_end = image_get_image_end(fdt_hdr); + /* + * move image data to the load address, + * make sure we don't overwrite initial image + */ + image_start = (ulong)fdt_hdr; + image_data = (ulong)image_get_data(fdt_hdr); + image_end = image_get_image_end(fdt_hdr);
- load = image_get_load(fdt_hdr); - load_end = load + image_get_data_size(fdt_hdr); + load = image_get_load(fdt_hdr); + load_end = load + image_get_data_size(fdt_hdr);
- if (load == image_start || - load == image_data) { - fdt_addr = load; - break; - } + if (load == image_start || + load == image_data) { + fdt_addr = load; + break; + }
- if ((load < image_end) && (load_end > image_start)) { - fdt_error("fdt overwritten"); - return -EFAULT; - } + if (load < image_end && load_end > image_start) { + fdt_error("fdt overwritten"); + return -EFAULT; + }
- debug(" Loading FDT from 0x%08lx to 0x%08lx\n", - image_data, load); + debug(" Loading FDT from 0x%08lx to 0x%08lx\n", + image_data, load);
- memmove((void *)load, - (void *)image_data, - image_get_data_size(fdt_hdr)); + memmove((void *)load, + (void *)image_data, + image_get_data_size(fdt_hdr));
- fdt_addr = load; + fdt_addr = load; + } break; - } -#endif case IMAGE_FORMAT_FIT: /* * This case will catch both: new uImage format * (libfdt based) and raw FDT blob (also libfdt * based). */ -#if CONFIG_IS_ENABLED(FIT) - /* check FDT blob vs FIT blob */ - if (!fit_check_format(buf, IMAGE_SIZE_INVAL)) { - ulong load, len; - - fdt_noffset = boot_get_fdt_fit(images, fdt_addr, - &fit_uname_fdt, - &fit_uname_config, - arch, &load, &len); - - if (fdt_noffset < 0) - return -ENOENT; - - images->fit_hdr_fdt = map_sysmem(fdt_addr, 0); - images->fit_uname_fdt = fit_uname_fdt; - images->fit_noffset_fdt = fdt_noffset; - fdt_addr = load; - - break; - } else -#endif - { - /* - * FDT blob - */ + if (CONFIG_IS_ENABLED(FIT)) { + /* check FDT blob vs FIT blob */ + if (!fit_check_format(buf, IMAGE_SIZE_INVAL)) { + ulong load, len; + + fdt_noffset = boot_get_fdt_fit(images, fdt_addr, + &fit_uname_fdt, + &fit_uname_config, + arch, &load, &len); + + if (fdt_noffset < 0) + return -ENOENT; + + images->fit_hdr_fdt = map_sysmem(fdt_addr, 0); + images->fit_uname_fdt = fit_uname_fdt; + images->fit_noffset_fdt = fdt_noffset; + fdt_addr = load; + processed = true; + } + } + if (!processed) { + /* FDT blob */ debug("* fdt: raw FDT blob\n"); printf("## Flattened Device Tree blob at %08lx\n", (long)fdt_addr); } break; - default: + } + + if (!processed) { puts("ERROR: Did not find a cmdline Flattened Device Tree\n"); return -ENOENT; } @@ -492,8 +492,8 @@ int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch, debug("## No Flattened Device Tree\n"); goto no_fdt; } -#ifdef CONFIG_ANDROID_BOOT_IMAGE - } else if (genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) { + } else if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE) && + genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) { struct andr_img_hdr *hdr = buf; ulong fdt_data, fdt_len; u32 fdt_size, dtb_idx; @@ -525,7 +525,6 @@ int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch,
debug("## Using FDT at ${fdtaddr}=Ox%lx\n", fdt_addr); } -#endif } else { debug("## No Flattened Device Tree\n"); goto no_fdt;
On Mon, May 03, 2021 at 05:10:47PM -0600, Simon Glass wrote:
Much of the image-handling code predates the introduction of Kconfig and has quite a few #ifdefs in it. It also uses its own IMAGE_... defines to help reduce the #ifdefs, which is unnecessary now that we can use IS_ENABLED() et al.
The image code is also where quite a bit of code is shared with the host tools. At present this uses a lot of checks of USE_HOSTCC.
This series introduces 'host' Kconfig options and a way to use CONFIG_IS_ENABLED() to check them. This works in a similar way to SPL, so
will evaluate to true on the host build (USE_HOSTCC) if CONFIG_HOST_FIT is enabled. This allows quite a bit of clean-up of the image.h header file and many of the image C files.
The 'host' Kconfig options should help to solve a more general problem in that we mostly want the host tools to build with all features enabled, no matter which features the 'target' build actually uses. This is a pain to arrange at present, but with 'host' Kconfigs, we can just define them all to y.
There are cases where the host tools do not have features which are present on the target, for example environment and physical addressing. To help with this, some of the core image code is split out into image-board.c and image-host.c files.
Even with these changes, some #ifdefs remain (101 down to 42 in common/image*). But the code is somewhat easier to follow and there are fewer build paths.
In service of the above, this series includes a patch to add an API function for zstd, so the code can be dropped from bootm.c
It also introduces a function to handle manual relocation.
I like this idea overall. The good news is this reduces the size in a few places. The bad news, but I can live with if we can't restructure the changes more, is a few functions grow a bit. This shows the good and the bad (something like sama5d2_ptc_ek_mmc shows only growth, to be clear): px30-core-edimm2.2-px30: all -36 rodata -24 text -12 u-boot: add: 0/0, grow: 3/-4 bytes: 36/-48 (-12) function old new delta boot_get_fdt 896 924 +28 image_decomp 372 376 +4 boot_get_ramdisk 868 872 +4 do_bootm_vxworks 552 540 -12 do_bootm_rtems 124 112 -12 do_bootm_plan9 228 216 -12 do_bootm_netbsd 324 312 -12 odroid-c2 : all -105 bss +128 rodata -65 text -168 u-boot: add: 0/0, grow: 2/-3 bytes: 108/-172 (-64) function old new delta images 504 608 +104 image_decomp 372 376 +4 image_setup_linux 108 96 -12 boot_get_ramdisk 620 580 -40 boot_get_fdt 660 540 -120 origen : all +47 bss +96 rodata -57 text +8 u-boot: add: 0/0, grow: 15/-2 bytes: 180/-104 (76) function old new delta images 288 340 +52 do_bootm_states 1304 1348 +44 do_bootz 164 176 +12 do_bootm_vxworks 332 344 +12 image_setup_libfdt 168 176 +8 image_decomp 156 164 +8 bootm_find_images 212 220 +8 boot_prep_linux 276 284 +8 image_setup_linux 54 58 +4 do_bootm_standalone 60 64 +4 do_bootm_plan9 104 108 +4 do_bootm_netbsd 168 172 +4 boot_prep_vxworks 48 52 +4 boot_jump_vxworks 6 10 +4 boot_jump_linux 148 152 +4 boot_get_ramdisk 420 392 -28 boot_get_fdt 420 344 -76
And looking at ls1088ardb_sdcard_qspi_SECURE_BOOT I think there might be something wrong as that looks to drop all crypto algos from SPL. Other layerscape SECURE_BOOT configs show this as well. It does however seem to clear up some other issues around unused code, so a deeper dive on which patch is dropping stuff is needed. I see a huge drop on am65x_evm_a53 / j721e_evm_a72 SPL as well but I can test those and at least the basic case is fine. socfpga_agilex_atf is one I don't know about being right or wrong. socfpga_agilex_vab dropping hashing code does look worrying however, but maybe it's a configuration issue in the end?
Hi Tom,
OK thanks for that. I will take a look at the cases you mention. I found a fair few problems but clearly not all.
Hi Tom,
What tool do you use to generate this output? Thanks.
--Sean
On Tue, May 04, 2021 at 07:24:25PM -0400, Sean Anderson wrote:
Hi Tom,
buildman will give that for you. This was from my world build before/after wrapper, but for a single machine I have: #!/bin/bash
# Initial and constant buildman args ARGS="-devl" ALL=0 KEEP=0
# Find our arguments while test $# -ne 0; do if [ "$1" == "--all" ]; then ALL=1 shift 1 elif [ "$1" == "--branch" ]; then BRANCH=$2 shift 2 elif [ "$1" == "--keep" ]; then KEEP=1 ARGS="$ARGS -k" shift 1 else MACHINE=$1 shift fi done
if [ -z $MACHINE ]; then echo Usage: $0 MACHINE [--all] [--keep] [--branch BRANCH] exit 1 fi
# If not all, then only first/last if [ $ALL -ne 1 ]; then ARGS="$ARGS --step 0" fi
if [ ! -z $BRANCH ]; then ARGS="$ARGS -b $BRANCH" else ARGS="$ARGS -b `git rev-parse --abbrev-ref HEAD`" fi
mkdir -p /tmp/$MACHINE
export SOURCE_DATE_EPOCH=`date +%s` ./tools/buildman/buildman -o /tmp/$MACHINE $ARGS -SBC $MACHINE ./tools/buildman/buildman -o /tmp/$MACHINE $ARGS -SsB $MACHINE
[ $KEEP -eq 0 ] && rm -rf /tmp/$MACHINE
In a script called "uboot-size-test.sh" to dig in to individual cases more.
Hi Tom,
Yes it seems to be config. Thank you for all the pointers.
The small increase is unavoidable with this approach - basically we add 16 bytes of rodata as part of making the switch cases into if() instead of #ifdef. I found that SPL hashing was dropped, which explained another problem that I had seen but not yet diagnosed.
I will send v2.
participants (6)
Marek Behun
Qu Wenruo
Rasmus Villemoes
Sean Anderson
