[U-Boot] [PATCH] README: Cleanup description of supported partitions.
Signed-off-by: Karl O. Pinc kop@meme.com --- I'm still trying to figure things out, and so am trying to clarify the docs as I go. FYI, I'm fuzzy about:
Whether this should read "One or more" or "Zero or more".
Whether the 2TB limit noted in disk/part_efi.c is really still true.
Whether this list is comprehensive.
Whether this list is overly chatty/pedantic.
Whether these sorts of changes should be in the wiki, the README, or both.
README | 15 +++++++++++---- 1 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/README b/README index f9535de..48cc6e5 100644 --- a/README +++ b/README @@ -950,13 +950,20 @@ The following options need to be configured: commands like bootm or iminfo. This option is automatically enabled when you select CONFIG_CMD_DATE .
-- Partition Support: - CONFIG_MAC_PARTITION and/or CONFIG_DOS_PARTITION - and/or CONFIG_ISO_PARTITION and/or CONFIG_EFI_PARTITION +- Partition Labels (disklabels) Supported: + Zero or more of the following: + CONFIG_MAC_PARTITION Apple's MacOS partition table. + CONFIG_DOS_PARTITION MS Dos partition table, traditional on the + Intel architecture, USB sticks, etc. + CONFIG_ISO_PARTITION ISO partition table, used on CDROM etc. + CONFIG_EFI_PARTITION GPT partition table, common when EFI is the + bootloader. Note 2TB partition limit; see + disk/part_efi.c + CONFIG_MTD_PARTITIONS Memory Technology Device partition table.
If IDE or SCSI support is enabled (CONFIG_CMD_IDE or CONFIG_CMD_SCSI) you must configure support for at - least one partition type as well. + least one non-MTD partition type as well.
- IDE Reset method: CONFIG_IDE_RESET_ROUTINE - this is defined in several
Dear "Karl O. Pinc",
Zero or more.
I don't know either.
Whether this list is comprehensive. Whether this list is overly chatty/pedantic.
Looks OK to me.
As we already have this isn the README, it makes a lot sense to fix / update documentation here.
Applied, thanks.
Karl O. Pinc
