[PATCH v6 0/3] Add a clock driver for the imx8mq
This is a DM clock driver for the imx8mq based on the linux kernel driver and the u-boot imx8mm clock driver.
It also removes some code duplication in the imx8m[nmp] clock drivers.
Changes since v5
Added UART clocks Added video clocks Added DRAM clocks
Changes since v4
Rebased onto [1] so patch 4 of 4 was dropped. Added CLK_COMPOSITE_CCF Fixed const* clock definitions
Changes since v3:
Fixed driver spelling Moved rate macros out of the header into the dot c
Changes since v2:
Added kernel commit IDs Re-factored rate table code to remove duplication Remove duplicate code by creating a common clk-imx8m
Changes since v1:
More verbose clock driver description Added forgotten dt-bindings Synced PLL frequencies with mainline kernel
[1] https://patchwork.ozlabs.org/project/uboot/patch/20220320203446.740178-2-sea...
Angus Ainslie (3): dt-bindings: imx8mq-clock: add mainline definitions clk: imx8mq: Add a clock driver for the imx8mq clk: imx8m: reduce rate table duplication
drivers/clk/imx/Kconfig | 18 + drivers/clk/imx/Makefile | 2 + drivers/clk/imx/clk-imx8mm.c | 60 +-- drivers/clk/imx/clk-imx8mn.c | 60 +-- drivers/clk/imx/clk-imx8mp.c | 65 +-- drivers/clk/imx/clk-imx8mq.c | 505 +++++++++++++++++++++++ drivers/clk/imx/clk-pll14xx.c | 61 +++ drivers/clk/imx/clk.h | 4 + include/dt-bindings/clock/imx8mq-clock.h | 16 +- 9 files changed, 625 insertions(+), 166 deletions(-) create mode 100644 drivers/clk/imx/clk-imx8mq.c
Sync the clock ids with the mainline kernel
077de6e1c9f ("clk: imx8mq: add PLL monitor output")
Signed-off-by: Angus Ainslie angus@akkea.ca Reviewed-by: Marek Vasut marex@denx.de --- include/dt-bindings/clock/imx8mq-clock.h | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/include/dt-bindings/clock/imx8mq-clock.h b/include/dt-bindings/clock/imx8mq-clock.h index 9b8045d75b8..82e907ce7bd 100644 --- a/include/dt-bindings/clock/imx8mq-clock.h +++ b/include/dt-bindings/clock/imx8mq-clock.h @@ -431,6 +431,20 @@
#define IMX8MQ_CLK_A53_CORE 289
-#define IMX8MQ_CLK_END 290 +#define IMX8MQ_CLK_MON_AUDIO_PLL1_DIV 290 +#define IMX8MQ_CLK_MON_AUDIO_PLL2_DIV 291 +#define IMX8MQ_CLK_MON_VIDEO_PLL1_DIV 292 +#define IMX8MQ_CLK_MON_GPU_PLL_DIV 293 +#define IMX8MQ_CLK_MON_VPU_PLL_DIV 294 +#define IMX8MQ_CLK_MON_ARM_PLL_DIV 295 +#define IMX8MQ_CLK_MON_SYS_PLL1_DIV 296 +#define IMX8MQ_CLK_MON_SYS_PLL2_DIV 297 +#define IMX8MQ_CLK_MON_SYS_PLL3_DIV 298 +#define IMX8MQ_CLK_MON_DRAM_PLL_DIV 299 +#define IMX8MQ_CLK_MON_VIDEO_PLL2_DIV 300 +#define IMX8MQ_CLK_MON_SEL 301 +#define IMX8MQ_CLK_MON_CLK2_OUT 302 + +#define IMX8MQ_CLK_END 303
#endif /* __DT_BINDINGS_CLOCK_IMX8MQ_H */
This is a DM clock driver based off the imx8mm u-boot driver and the linux kernel driver.
All of the PLLs and clocks are initialized so the subsystems below are functional and tested.
1) USB host and peripheral 2) ECSPI 3) UART 4) I2C all busses 5) USDHC for eMMC support 6) USB storage 7) GPIO 8) DRAM
Signed-off-by: Angus Ainslie angus@akkea.ca Acked-by: Sean Anderson seanga2@gmail.com --- drivers/clk/imx/Kconfig | 18 ++ drivers/clk/imx/Makefile | 2 + drivers/clk/imx/clk-imx8mq.c | 552 +++++++++++++++++++++++++++++++++++ 3 files changed, 572 insertions(+) create mode 100644 drivers/clk/imx/clk-imx8mq.c
diff --git a/drivers/clk/imx/Kconfig b/drivers/clk/imx/Kconfig index cdd348020b0..04d252a1e03 100644 --- a/drivers/clk/imx/Kconfig +++ b/drivers/clk/imx/Kconfig @@ -71,6 +71,24 @@ config CLK_IMX8MP help This enables support clock driver for i.MX8MP platforms.
+config SPL_CLK_IMX8MQ + bool "SPL clock support for i.MX8MQ" + depends on ARCH_IMX8M && SPL + select SPL_CLK + select SPL_CLK_CCF + select SPL_CLK_COMPOSITE_CCF + help + This enables SPL DM/DTS support for clock driver in i.MX8MQ + +config CLK_IMX8MQ + bool "Clock support for i.MX8MQ" + depends on ARCH_IMX8M + select CLK + select CLK_CCF + select CLK_COMPOSITE_CCF + help + This enables support clock driver for i.MX8MQ platforms. + config SPL_CLK_IMXRT1020 bool "SPL clock support for i.MXRT1020" depends on ARCH_IMXRT && SPL diff --git a/drivers/clk/imx/Makefile b/drivers/clk/imx/Makefile index 01bbbdf3aea..c5766901f2b 100644 --- a/drivers/clk/imx/Makefile +++ b/drivers/clk/imx/Makefile @@ -16,6 +16,8 @@ obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MN) += clk-imx8mn.o clk-pll14xx.o \ clk-composite-8m.o obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MP) += clk-imx8mp.o clk-pll14xx.o \ clk-composite-8m.o +obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MQ) += clk-imx8mq.o clk-pll14xx.o \ + clk-composite-8m.o
obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1020) += clk-imxrt1020.o obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1050) += clk-imxrt1050.o diff --git a/drivers/clk/imx/clk-imx8mq.c b/drivers/clk/imx/clk-imx8mq.c new file mode 100644 index 00000000000..4b925265255 --- /dev/null +++ b/drivers/clk/imx/clk-imx8mq.c @@ -0,0 +1,552 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2019 NXP + * Copyright 2022 Purism + * Peng Fan peng.fan@nxp.com + */ + +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <dt-bindings/clock/imx8mq-clock.h> + +#include "clk.h" + +#define PLL_1416X_RATE(_rate, _m, _p, _s) \ + { \ + .rate = (_rate), \ + .mdiv = (_m), \ + .pdiv = (_p), \ + .sdiv = (_s), \ + } + +#define PLL_1443X_RATE(_rate, _m, _p, _s, _k) \ + { \ + .rate = (_rate), \ + .mdiv = (_m), \ + .pdiv = (_p), \ + .sdiv = (_s), \ + .kdiv = (_k), \ + } + +static const struct imx_pll14xx_rate_table imx8mq_pll1416x_tbl[] = { + PLL_1416X_RATE(1800000000U, 225, 3, 0), + PLL_1416X_RATE(1600000000U, 200, 3, 0), + PLL_1416X_RATE(1200000000U, 300, 3, 1), + PLL_1416X_RATE(1000000000U, 250, 3, 1), + PLL_1416X_RATE(800000000U, 200, 3, 1), + PLL_1416X_RATE(750000000U, 250, 2, 2), + PLL_1416X_RATE(700000000U, 350, 3, 2), + PLL_1416X_RATE(600000000U, 300, 3, 2), +}; + +const struct imx_pll14xx_rate_table imx8mq_pll1443x_tbl[] = { + PLL_1443X_RATE(650000000U, 325, 3, 2, 0), + PLL_1443X_RATE(594000000U, 198, 2, 2, 0), + PLL_1443X_RATE(393216000U, 262, 2, 3, 9437), + PLL_1443X_RATE(361267200U, 361, 3, 3, 17511), +}; + +static struct imx_pll14xx_clk imx8mq_1416x_pll __initdata = { + .type = PLL_1416X, + .rate_table = imx8mq_pll1416x_tbl, + .rate_count = ARRAY_SIZE(imx8mq_pll1416x_tbl), +}; + +static struct imx_pll14xx_clk imx8mq_1443x_pll __initdata = { + .type = PLL_1443X, + .rate_table = imx8mq_pll1443x_tbl, + .rate_count = ARRAY_SIZE(imx8mq_pll1443x_tbl), +}; + +static const char *const pll_ref_sels[] = { "clock-osc-25m", "clock-osc-27m", "clock-phy-27m", "dummy", }; +static const char *const arm_pll_bypass_sels[] = {"arm_pll", "arm_pll_ref_sel", }; +static const char *const gpu_pll_bypass_sels[] = {"gpu_pll", "gpu_pll_ref_sel", }; +static const char *const vpu_pll_bypass_sels[] = {"vpu_pll", "vpu_pll_ref_sel", }; +static const char *const audio_pll1_bypass_sels[] = {"audio_pll1", "audio_pll1_ref_sel", }; +static const char *const audio_pll2_bypass_sels[] = {"audio_pll2", "audio_pll2_ref_sel", }; +static const char *const video_pll1_bypass_sels[] = {"video_pll1", "video_pll1_ref_sel", }; + +static const char *const imx8mq_a53_core_sels[] = {"arm_a53_div", "arm_pll_out", }; +static const char *const imx8mq_a53_sels[] = {"clock-osc-25m", "arm_pll_out", "sys_pll2_500m", + "sys_pll2_1000m", "sys_pll1_800m", "sys_pll1_400m", + "audio_pll1_out", "sys_pll3_out", }; + +static const char *const imx8mq_ahb_sels[] = {"clock-osc-25m", "sys_pll1_133m", "sys_pll1_800m", + "sys_pll1_400m", "sys_pll2_125m", "sys_pll3_out", + "audio_pll1_out", "video_pll1_out", }; + +static const char *const imx8mq_dram_alt_sels[] = {"osc_25m", "sys_pll1_800m", "sys_pll1_100m", + "sys_pll2_500m", "sys_pll2_250m", + "sys_pll1_400m", "audio_pll1_out", "sys_pll1_266m", } ; + +static const char * const imx8mq_dram_apb_sels[] = {"osc_25m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll2_out", }; + +static const char *const imx8mq_enet_axi_sels[] = {"clock-osc-25m", "sys_pll1_266m", "sys_pll1_800m", + "sys_pll2_250m", "sys_pll2_200m", "audio_pll1_out", + "video_pll1_out", "sys_pll3_out", }; + +static const char *const imx8mq_enet_ref_sels[] = {"clock-osc-25m", "sys_pll2_125m", "sys_pll2_50m", + "sys_pll2_100m", "sys_pll1_160m", "audio_pll1_out", + "video_pll1_out", "clk_ext4", }; + +static const char *const imx8mq_enet_timer_sels[] = {"clock-osc-25m", "sys_pll2_100m", "audio_pll1_out", + "clk_ext1", "clk_ext2", "clk_ext3", "clk_ext4", + "video_pll1_out", }; + +static const char *const imx8mq_enet_phy_sels[] = {"clock-osc-25m", "sys_pll2_50m", "sys_pll2_125m", + "sys_pll2_200m", "sys_pll2_500m", "video_pll1_out", + "audio_pll2_out", }; + +static const char *const imx8mq_nand_usdhc_sels[] = {"clock-osc-25m", "sys_pll1_266m", "sys_pll1_800m", + "sys_pll2_200m", "sys_pll1_133m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll1_out", }; + +static const char *const imx8mq_usb_bus_sels[] = {"clock-osc-25m", "sys_pll2_500m", "sys_pll1_800m", + "sys_pll2_100m", "sys_pll2_200m", "clk_ext2", + "clk_ext4", "audio_pll2_out", }; + +static const char *const imx8mq_usdhc1_sels[] = {"clock-osc-25m", "sys_pll1_400m", "sys_pll1_800m", + "sys_pll2_500m", "sys_pll3_out", "sys_pll1_266m", + "audio_pll2_out", "sys_pll1_100m", }; + +static const char *const imx8mq_usdhc2_sels[] = {"clock-osc-25m", "sys_pll1_400m", "sys_pll1_800m", + "sys_pll2_500m", "sys_pll3_out", "sys_pll1_266m", + "audio_pll2_out", "sys_pll1_100m", }; + +static const char *const imx8mq_i2c1_sels[] = {"clock-osc-25m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *const imx8mq_i2c2_sels[] = {"clock-osc-25m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *const imx8mq_i2c3_sels[] = {"clock-osc-25m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *const imx8mq_i2c4_sels[] = {"clock-osc-25m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *const imx8mq_uart1_sels[] = {"clock-osc-25m", "sys_pll1_80m", "sys_pll2_200m", + "sys_pll2_100m", "sys_pll3_out", "clk_ext2", + "clk_ext4", "audio_pll2_out", }; + +static const char *const imx8mq_uart2_sels[] = {"clock-osc-25m", "sys_pll1_80m", "sys_pll2_200m", + "sys_pll2_100m", "sys_pll3_out", "clk_ext2", + "clk_ext3", "audio_pll2_out", }; + +static const char *const imx8mq_uart3_sels[] = {"clock-osc-25m", "sys_pll1_80m", "sys_pll2_200m", + "sys_pll2_100m", "sys_pll3_out", "clk_ext2", + "clk_ext4", "audio_pll2_out", }; + +static const char *const imx8mq_uart4_sels[] = {"clock-osc-25m", "sys_pll1_80m", "sys_pll2_200m", + "sys_pll2_100m", "sys_pll3_out", "clk_ext2", + "clk_ext3", "audio_pll2_out", }; + +static const char *const imx8mq_wdog_sels[] = {"clock-osc-25m", "sys_pll1_133m", "sys_pll1_160m", + "vpu_pll_out", "sys_pll2_125m", "sys_pll3_out", + "sys_pll1_80m", "sys_pll2_166m", }; + +static const char *const imx8mq_qspi_sels[] = {"clock-osc-25m", "sys_pll1_400m", "sys_pll2_333m", + "sys_pll2_500m", "audio_pll2_out", "sys_pll1_266m", + "sys_pll3_out", "sys_pll1_100m", }; + +static const char *const imx8mq_usb_core_sels[] = {"clock-osc-25m", "sys_pll1_100m", "sys_pll1_40m", + "sys_pll2_100m", "sys_pll2_200m", "clk_ext2", + "clk_ext3", "audio_pll2_out", }; + +static const char *const imx8mq_usb_phy_sels[] = {"clock-osc-25m", "sys_pll1_100m", "sys_pll1_40m", + "sys_pll2_100m", "sys_pll2_200m", "clk_ext2", + "clk_ext3", "audio_pll2_out", }; + +static const char *const imx8mq_ecspi1_sels[] = {"clock-osc-25m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll2_out", }; + +static const char *const imx8mq_ecspi2_sels[] = {"clock-osc-25m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll2_out", }; + +static const char *const imx8mq_ecspi3_sels[] = {"clock-osc-25m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll2_out", }; + +static const char *const imx8mq_dram_core_sels[] = {"dram_pll_out", "dram_alt_root", }; + +static const char *const pllout_monitor_sels[] = {"clock-osc-25m", "clock-osc-27m", "clock-phy-27m", + "dummy", "clock-ckil", "audio_pll1_out_monitor", + "audio_pll2_out_monitor", "gpu_pll_out_monitor", + "vpu_pll_out_monitor", "video_pll1_out_monitor", + "arm_pll_out_monitor", "sys_pll1_out_monitor", + "sys_pll2_out_monitor", "sys_pll3_out_monitor", + "video_pll2_out_monitor", "dram_pll_out_monitor", }; + +static int imx8mq_clk_probe(struct udevice *dev) +{ + void __iomem *base; + struct clk *c, *p; + int err; + + base = (void *)ANATOP_BASE_ADDR; + + clk_dm(IMX8MQ_CLK_32K, clk_register_fixed_rate(NULL, "ckil", 32768)); + clk_dm(IMX8MQ_CLK_27M, clk_register_fixed_rate(NULL, "clock-osc-27m", 27000000)); + + clk_dm(IMX8MQ_DRAM_PLL1_REF_SEL, + imx_clk_mux("dram_pll_ref_sel", base + 0x60, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MQ_ARM_PLL_REF_SEL, + imx_clk_mux("arm_pll_ref_sel", base + 0x28, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MQ_GPU_PLL_REF_SEL, + imx_clk_mux("gpu_pll_ref_sel", base + 0x18, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MQ_VPU_PLL_REF_SEL, + imx_clk_mux("vpu_pll_ref_sel", base + 0x20, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MQ_SYS3_PLL1_REF_SEL, + imx_clk_mux("sys3_pll_ref_sel", base + 0x48, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MQ_AUDIO_PLL1_REF_SEL, + imx_clk_mux("audio_pll1_ref_sel", base + 0x0, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MQ_AUDIO_PLL2_REF_SEL, + imx_clk_mux("audio_pll2_ref_sel", base + 0x8, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MQ_VIDEO_PLL1_REF_SEL, + imx_clk_mux("video_pll1_ref_sel", base + 0x10, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MQ_VIDEO2_PLL1_REF_SEL, + imx_clk_mux("video_pll2_ref_sel", base + 0x54, 0, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + + clk_dm(IMX8MQ_ARM_PLL, + imx_clk_pll14xx("arm_pll", "arm_pll_ref_sel", + base + 0x28, &imx8mq_1416x_pll)); + clk_dm(IMX8MQ_GPU_PLL, + imx_clk_pll14xx("gpu_pll", "gpu_pll_ref_sel", + base + 0x18, &imx8mq_1416x_pll)); + clk_dm(IMX8MQ_VPU_PLL, + imx_clk_pll14xx("vpu_pll", "vpu_pll_ref_sel", + base + 0x20, &imx8mq_1416x_pll)); + + clk_dm(IMX8MQ_SYS1_PLL1, + clk_register_fixed_rate(NULL, "sys1_pll", 800000000)); + clk_dm(IMX8MQ_SYS2_PLL1, + clk_register_fixed_rate(NULL, "sys2_pll", 1000000000)); + clk_dm(IMX8MQ_SYS2_PLL1, + clk_register_fixed_rate(NULL, "sys3_pll", 1000000000)); + clk_dm(IMX8MQ_AUDIO_PLL1, + imx_clk_pll14xx("audio_pll1", "audio_pll1_ref_sel", + base + 0x0, &imx8mq_1443x_pll)); + clk_dm(IMX8MQ_AUDIO_PLL2, + imx_clk_pll14xx("audio_pll2", "audio_pll2_ref_sel", + base + 0x8, &imx8mq_1443x_pll)); + clk_dm(IMX8MQ_VIDEO_PLL1, + imx_clk_pll14xx("video_pll1", "video_pll1_ref_sel", + base + 0x10, &imx8mq_1443x_pll)); + + /* PLL bypass out */ + clk_dm(IMX8MQ_ARM_PLL_BYPASS, + imx_clk_mux_flags("arm_pll_bypass", base + 0x28, 4, 1, + arm_pll_bypass_sels, + ARRAY_SIZE(arm_pll_bypass_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMX8MQ_GPU_PLL_BYPASS, + imx_clk_mux_flags("gpu_pll_bypass", base + 0x18, 4, 1, + gpu_pll_bypass_sels, + ARRAY_SIZE(gpu_pll_bypass_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMX8MQ_VPU_PLL_BYPASS, + imx_clk_mux_flags("vpu_pll_bypass", base + 0x20, 4, 1, + vpu_pll_bypass_sels, + ARRAY_SIZE(vpu_pll_bypass_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMX8MQ_AUDIO_PLL1_BYPASS, + imx_clk_mux_flags("audio_pll1_bypass", base + 0x0, 4, 1, + audio_pll1_bypass_sels, + ARRAY_SIZE(audio_pll1_bypass_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMX8MQ_AUDIO_PLL2_BYPASS, + imx_clk_mux_flags("audio_pll2_bypass", base + 0x8, 4, 1, + audio_pll2_bypass_sels, + ARRAY_SIZE(audio_pll2_bypass_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMX8MQ_VIDEO_PLL1_BYPASS, + imx_clk_mux_flags("video_pll1_bypass", base + 0x10, 4, 1, + video_pll1_bypass_sels, + ARRAY_SIZE(video_pll1_bypass_sels), + CLK_SET_RATE_PARENT)); + + /* PLL out gate */ + clk_dm(IMX8MQ_DRAM_PLL_OUT, + imx_clk_gate("dram_pll_out", "dram_pll_ref_sel", + base + 0x60, 13)); + clk_dm(IMX8MQ_ARM_PLL_OUT, + imx_clk_gate("arm_pll_out", "arm_pll_bypass", + base + 0x28, 11)); + clk_dm(IMX8MQ_GPU_PLL_OUT, + imx_clk_gate("gpu_pll_out", "gpu_pll_bypass", + base + 0x18, 11)); + clk_dm(IMX8MQ_VPU_PLL_OUT, + imx_clk_gate("vpu_pll_out", "vpu_pll_bypass", + base + 0x20, 11)); + clk_dm(IMX8MQ_AUDIO_PLL1_OUT, + imx_clk_gate("audio_pll1_out", "audio_pll1_bypass", + base + 0x0, 11)); + clk_dm(IMX8MQ_AUDIO_PLL2_OUT, + imx_clk_gate("audio_pll2_out", "audio_pll2_bypass", + base + 0x8, 11)); + clk_dm(IMX8MQ_VIDEO_PLL1_OUT, + imx_clk_gate("video_pll1_out", "video_pll1_bypass", + base + 0x10, 11)); + + clk_dm(IMX8MQ_SYS1_PLL_OUT, + imx_clk_gate("sys_pll1_out", "sys1_pll", + base + 0x30, 11)); + clk_dm(IMX8MQ_SYS2_PLL_OUT, + imx_clk_gate("sys_pll2_out", "sys2_pll", + base + 0x3c, 11)); + clk_dm(IMX8MQ_SYS3_PLL_OUT, + imx_clk_gate("sys_pll3_out", "sys3_pll", + base + 0x48, 11)); + clk_dm(IMX8MQ_VIDEO2_PLL_OUT, + imx_clk_gate("video_pll2_out", "video_pll2_ref_sel", + base + 0x54, 11)); + + /* SYS PLL fixed output */ + clk_dm(IMX8MQ_SYS1_PLL_40M, + imx_clk_fixed_factor("sys_pll1_40m", "sys_pll1_out", 1, 20)); + clk_dm(IMX8MQ_SYS1_PLL_80M, + imx_clk_fixed_factor("sys_pll1_80m", "sys_pll1_out", 1, 10)); + clk_dm(IMX8MQ_SYS1_PLL_100M, + imx_clk_fixed_factor("sys_pll1_100m", "sys_pll1_out", 1, 8)); + clk_dm(IMX8MQ_SYS1_PLL_133M, + imx_clk_fixed_factor("sys_pll1_133m", "sys_pll1_out", 1, 6)); + clk_dm(IMX8MQ_SYS1_PLL_160M, + imx_clk_fixed_factor("sys_pll1_160m", "sys_pll1_out", 1, 5)); + clk_dm(IMX8MQ_SYS1_PLL_200M, + imx_clk_fixed_factor("sys_pll1_200m", "sys_pll1_out", 1, 4)); + clk_dm(IMX8MQ_SYS1_PLL_266M, + imx_clk_fixed_factor("sys_pll1_266m", "sys_pll1_out", 1, 3)); + clk_dm(IMX8MQ_SYS1_PLL_400M, + imx_clk_fixed_factor("sys_pll1_400m", "sys_pll1_out", 1, 2)); + clk_dm(IMX8MQ_SYS1_PLL_800M, + imx_clk_fixed_factor("sys_pll1_800m", "sys_pll1_out", 1, 1)); + + clk_dm(IMX8MQ_SYS2_PLL_50M, + imx_clk_fixed_factor("sys_pll2_50m", "sys_pll2_out", 1, 20)); + clk_dm(IMX8MQ_SYS2_PLL_100M, + imx_clk_fixed_factor("sys_pll2_100m", "sys_pll2_out", 1, 10)); + clk_dm(IMX8MQ_SYS2_PLL_125M, + imx_clk_fixed_factor("sys_pll2_125m", "sys_pll2_out", 1, 8)); + clk_dm(IMX8MQ_SYS2_PLL_166M, + imx_clk_fixed_factor("sys_pll2_166m", "sys_pll2_out", 1, 6)); + clk_dm(IMX8MQ_SYS2_PLL_200M, + imx_clk_fixed_factor("sys_pll2_200m", "sys_pll2_out", 1, 5)); + clk_dm(IMX8MQ_SYS2_PLL_250M, + imx_clk_fixed_factor("sys_pll2_250m", "sys_pll2_out", 1, 4)); + clk_dm(IMX8MQ_SYS2_PLL_333M, + imx_clk_fixed_factor("sys_pll2_333m", "sys_pll2_out", 1, 3)); + clk_dm(IMX8MQ_SYS2_PLL_500M, + imx_clk_fixed_factor("sys_pll2_500m", "sys_pll2_out", 1, 2)); + clk_dm(IMX8MQ_SYS2_PLL_1000M, + imx_clk_fixed_factor("sys_pll2_1000m", "sys_pll2_out", 1, 1)); + + clk_dm(IMX8MQ_CLK_MON_AUDIO_PLL1_DIV, + imx_clk_divider("audio_pll1_out_monitor", "audio_pll1_bypass", base + 0x78, 0, 3)); + clk_dm(IMX8MQ_CLK_MON_AUDIO_PLL2_DIV, + imx_clk_divider("audio_pll2_out_monitor", "audio_pll2_bypass", base + 0x78, 4, 3)); + clk_dm(IMX8MQ_CLK_MON_VIDEO_PLL1_DIV, + imx_clk_divider("video_pll1_out_monitor", "video_pll1_bypass", base + 0x78, 8, 3)); + clk_dm(IMX8MQ_CLK_MON_GPU_PLL_DIV, + imx_clk_divider("gpu_pll_out_monitor", "gpu_pll_bypass", base + 0x78, 12, 3)); + clk_dm(IMX8MQ_CLK_MON_VPU_PLL_DIV, + imx_clk_divider("vpu_pll_out_monitor", "vpu_pll_bypass", base + 0x78, 16, 3)); + clk_dm(IMX8MQ_CLK_MON_ARM_PLL_DIV, + imx_clk_divider("arm_pll_out_monitor", "arm_pll_bypass", base + 0x78, 20, 3)); + clk_dm(IMX8MQ_CLK_MON_SYS_PLL1_DIV, + imx_clk_divider("sys_pll1_out_monitor", "sys_pll1_out", base + 0x7c, 0, 3)); + clk_dm(IMX8MQ_CLK_MON_SYS_PLL2_DIV, + imx_clk_divider("sys_pll2_out_monitor", "sys_pll2_out", base + 0x7c, 4, 3)); + clk_dm(IMX8MQ_CLK_MON_SYS_PLL3_DIV, + imx_clk_divider("sys_pll3_out_monitor", "sys_pll3_out", base + 0x7c, 8, 3)); + clk_dm(IMX8MQ_CLK_MON_DRAM_PLL_DIV, + imx_clk_divider("dram_pll_out_monitor", "dram_pll_out", base + 0x7c, 12, 3)); + clk_dm(IMX8MQ_CLK_MON_VIDEO_PLL2_DIV, + imx_clk_divider("video_pll2_out_monitor", "video_pll2_out", base + 0x7c, 16, 3)); + clk_dm(IMX8MQ_CLK_MON_SEL, + imx_clk_mux_flags("pllout_monitor_sel", base + 0x74, 0, 4, + pllout_monitor_sels, + ARRAY_SIZE(pllout_monitor_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMX8MQ_CLK_MON_CLK2_OUT, + imx_clk_gate4("pllout_monitor_clk2", "pllout_monitor_sel", base + 0x74, 4)); + + base = dev_read_addr_ptr(dev); + if (!base) { + printf("%s : base failed\n", __func__); + return -EINVAL; + } + + clk_dm(IMX8MQ_CLK_A53_SRC, + imx_clk_mux2("arm_a53_src", base + 0x8000, 24, 3, + imx8mq_a53_sels, ARRAY_SIZE(imx8mq_a53_sels))); + clk_dm(IMX8MQ_CLK_A53_CG, + imx_clk_gate3("arm_a53_cg", "arm_a53_src", base + 0x8000, 28)); + clk_dm(IMX8MQ_CLK_A53_DIV, + imx_clk_divider2("arm_a53_div", "arm_a53_cg", + base + 0x8000, 0, 3)); + clk_dm(IMX8MQ_CLK_A53_CORE, + imx_clk_mux2("arm_a53_src", base + 0x9880, 24, 1, + imx8mq_a53_core_sels, ARRAY_SIZE(imx8mq_a53_core_sels))); + + clk_dm(IMX8MQ_CLK_AHB, + imx8m_clk_composite_critical("ahb", imx8mq_ahb_sels, + base + 0x9000)); + clk_dm(IMX8MQ_CLK_IPG_ROOT, + imx_clk_divider2("ipg_root", "ahb", base + 0x9080, 0, 1)); + + clk_dm(IMX8MQ_CLK_ENET_AXI, + imx8m_clk_composite("enet_axi", imx8mq_enet_axi_sels, + base + 0x8880)); + clk_dm(IMX8MQ_CLK_NAND_USDHC_BUS, + imx8m_clk_composite_critical("nand_usdhc_bus", + imx8mq_nand_usdhc_sels, + base + 0x8900)); + clk_dm(IMX8MQ_CLK_USB_BUS, + imx8m_clk_composite("usb_bus", imx8mq_usb_bus_sels, base + 0x8b80)); + + /* DRAM */ + clk_dm(IMX8MQ_CLK_DRAM_CORE, + imx_clk_mux2("dram_core_clk", base + 0x9800, 24, 1, + imx8mq_dram_core_sels, ARRAY_SIZE(imx8mq_dram_core_sels))); + clk_dm(IMX8MQ_CLK_DRAM_ALT, + imx8m_clk_composite("dram_alt", imx8mq_dram_alt_sels, base + 0xa000)); + clk_dm(IMX8MQ_CLK_DRAM_APB, + imx8m_clk_composite_critical("dram_apb", imx8mq_dram_apb_sels, base + 0xa080)); + + /* IP */ + clk_dm(IMX8MQ_CLK_USDHC1, + imx8m_clk_composite("usdhc1", imx8mq_usdhc1_sels, + base + 0xac00)); + clk_dm(IMX8MQ_CLK_USDHC2, + imx8m_clk_composite("usdhc2", imx8mq_usdhc2_sels, + base + 0xac80)); + clk_dm(IMX8MQ_CLK_I2C1, + imx8m_clk_composite("i2c1", imx8mq_i2c1_sels, base + 0xad00)); + clk_dm(IMX8MQ_CLK_I2C2, + imx8m_clk_composite("i2c2", imx8mq_i2c2_sels, base + 0xad80)); + clk_dm(IMX8MQ_CLK_I2C3, + imx8m_clk_composite("i2c3", imx8mq_i2c3_sels, base + 0xae00)); + clk_dm(IMX8MQ_CLK_I2C4, + imx8m_clk_composite("i2c4", imx8mq_i2c4_sels, base + 0xae80)); + clk_dm(IMX8MQ_CLK_WDOG, + imx8m_clk_composite("wdog", imx8mq_wdog_sels, base + 0xb900)); + clk_dm(IMX8MQ_CLK_UART1, + imx8m_clk_composite("uart1", imx8mq_uart1_sels, base + 0xaf00)); + clk_dm(IMX8MQ_CLK_UART2, + imx8m_clk_composite("uart2", imx8mq_uart2_sels, base + 0xaf80)); + clk_dm(IMX8MQ_CLK_UART3, + imx8m_clk_composite("uart3", imx8mq_uart3_sels, base + 0xb000)); + clk_dm(IMX8MQ_CLK_UART4, + imx8m_clk_composite("uart4", imx8mq_uart4_sels, base + 0xb080)); + clk_dm(IMX8MQ_CLK_QSPI, + imx8m_clk_composite("qspi", imx8mq_qspi_sels, base + 0xab80)); + clk_dm(IMX8MQ_CLK_USB_CORE_REF, + imx8m_clk_composite("usb_core_ref", imx8mq_usb_core_sels, base + 0xb100)); + clk_dm(IMX8MQ_CLK_USB_PHY_REF, + imx8m_clk_composite("usb_phy_ref", imx8mq_usb_phy_sels, base + 0xb180)); + clk_dm(IMX8MQ_CLK_ECSPI1, + imx8m_clk_composite("ecspi1", imx8mq_ecspi1_sels, base + 0xb280)); + clk_dm(IMX8MQ_CLK_ECSPI2, + imx8m_clk_composite("ecspi2", imx8mq_ecspi2_sels, base + 0xb300)); + clk_dm(IMX8MQ_CLK_ECSPI3, + imx8m_clk_composite("ecspi3", imx8mq_ecspi3_sels, base + 0xc180)); + + clk_dm(IMX8MQ_CLK_ECSPI1_ROOT, + imx_clk_gate4("ecspi1_root_clk", "ecspi1", base + 0x4070, 0)); + clk_dm(IMX8MQ_CLK_ECSPI2_ROOT, + imx_clk_gate4("ecspi2_root_clk", "ecspi2", base + 0x4080, 0)); + clk_dm(IMX8MQ_CLK_ECSPI3_ROOT, + imx_clk_gate4("ecspi3_root_clk", "ecspi3", base + 0x4090, 0)); + clk_dm(IMX8MQ_CLK_I2C1_ROOT, + imx_clk_gate4("i2c1_root_clk", "i2c1", base + 0x4170, 0)); + clk_dm(IMX8MQ_CLK_I2C2_ROOT, + imx_clk_gate4("i2c2_root_clk", "i2c2", base + 0x4180, 0)); + clk_dm(IMX8MQ_CLK_I2C3_ROOT, + imx_clk_gate4("i2c3_root_clk", "i2c3", base + 0x4190, 0)); + clk_dm(IMX8MQ_CLK_I2C4_ROOT, + imx_clk_gate4("i2c4_root_clk", "i2c4", base + 0x41a0, 0)); + clk_dm(IMX8MQ_CLK_UART1_ROOT, + imx_clk_gate4("uart1_root_clk", "uart1", base + 0x4490, 0)); + clk_dm(IMX8MQ_CLK_UART2_ROOT, + imx_clk_gate4("uart2_root_clk", "uart2", base + 0x44a0, 0)); + clk_dm(IMX8MQ_CLK_UART3_ROOT, + imx_clk_gate4("uart3_root_clk", "uart3", base + 0x44b0, 0)); + clk_dm(IMX8MQ_CLK_UART4_ROOT, + imx_clk_gate4("uart4_root_clk", "uart4", base + 0x44c0, 0)); + clk_dm(IMX8MQ_CLK_OCOTP_ROOT, + imx_clk_gate4("ocotp_root_clk", "ipg_root", base + 0x4220, 0)); + clk_dm(IMX8MQ_CLK_USDHC1_ROOT, + imx_clk_gate4("usdhc1_root_clk", "usdhc1", base + 0x4510, 0)); + clk_dm(IMX8MQ_CLK_USDHC2_ROOT, + imx_clk_gate4("usdhc2_root_clk", "usdhc2", base + 0x4520, 0)); + clk_dm(IMX8MQ_CLK_WDOG1_ROOT, + imx_clk_gate4("wdog1_root_clk", "wdog", base + 0x4530, 0)); + clk_dm(IMX8MQ_CLK_WDOG2_ROOT, + imx_clk_gate4("wdog2_root_clk", "wdog", base + 0x4540, 0)); + clk_dm(IMX8MQ_CLK_WDOG3_ROOT, + imx_clk_gate4("wdog3_root_clk", "wdog", base + 0x4550, 0)); + clk_dm(IMX8MQ_CLK_QSPI_ROOT, + imx_clk_gate4("qspi_root_clk", "qspi", base + 0x42f0, 0)); + clk_dm(IMX8MQ_CLK_USB1_CTRL_ROOT, + imx_clk_gate4("usb1_ctrl_root_clk", "usb_bus", base + 0x44d0, 0)); + clk_dm(IMX8MQ_CLK_USB2_CTRL_ROOT, + imx_clk_gate4("usb2_ctrl_root_clk", "usb_bus", base + 0x44e0, 0)); + clk_dm(IMX8MQ_CLK_USB1_PHY_ROOT, + imx_clk_gate4("usb1_phy_root_clk", "usb_phy_ref", base + 0x44f0, 0)); + clk_dm(IMX8MQ_CLK_USB2_PHY_ROOT, + imx_clk_gate4("usb2_phy_root_clk", "usb_phy_ref", base + 0x4500, 0)); + + clk_dm(IMX8MQ_CLK_ENET_REF, + imx8m_clk_composite("enet_ref", imx8mq_enet_ref_sels, + base + 0xa980)); + clk_dm(IMX8MQ_CLK_ENET_TIMER, + imx8m_clk_composite("enet_timer", imx8mq_enet_timer_sels, + base + 0xaa00)); + clk_dm(IMX8MQ_CLK_ENET_PHY_REF, + imx8m_clk_composite("enet_phy", imx8mq_enet_phy_sels, + base + 0xaa80)); + clk_dm(IMX8MQ_CLK_ENET1_ROOT, + imx_clk_gate4("enet1_root_clk", "enet_axi", + base + 0x40a0, 0)); + + clk_dm(IMX8MQ_CLK_DRAM_ALT_ROOT, + imx_clk_fixed_factor("dram_alt_root", "dram_alt", 1, 4)); + + return 0; +} + +static const struct udevice_id imx8mq_clk_ids[] = { + { .compatible = "fsl,imx8mq-ccm" }, + { }, +}; + +U_BOOT_DRIVER(imx8mq_clk) = { + .name = "clk_imx8mq", + .id = UCLASS_CLK, + .of_match = imx8mq_clk_ids, + .ops = &ccf_clk_ops, + .probe = imx8mq_clk_probe, + .flags = DM_FLAG_PRE_RELOC, +};
Re-factor the imx8m[nmpq] rate tables into the common pll1416x clock driver.
43cdaa1567ad3 ("clk: imx8mm: Move 1443X/1416X PLL clock structure to common place")
Signed-off-by: Angus Ainslie angus@akkea.ca Tested-by: Adam Ford aford173@gmail.com #imx8mm-beacon --- drivers/clk/imx/clk-imx8mm.c | 60 +++----------------------------- drivers/clk/imx/clk-imx8mn.c | 60 +++----------------------------- drivers/clk/imx/clk-imx8mp.c | 65 ++++++----------------------------- drivers/clk/imx/clk-imx8mq.c | 59 ++++--------------------------- drivers/clk/imx/clk-pll14xx.c | 61 ++++++++++++++++++++++++++++++++ drivers/clk/imx/clk.h | 4 +++ 6 files changed, 91 insertions(+), 218 deletions(-)
diff --git a/drivers/clk/imx/clk-imx8mm.c b/drivers/clk/imx/clk-imx8mm.c index 443bbdae332..11213212620 100644 --- a/drivers/clk/imx/clk-imx8mm.c +++ b/drivers/clk/imx/clk-imx8mm.c @@ -15,56 +15,6 @@
#include "clk.h"
-#define PLL_1416X_RATE(_rate, _m, _p, _s) \ - { \ - .rate = (_rate), \ - .mdiv = (_m), \ - .pdiv = (_p), \ - .sdiv = (_s), \ - } - -#define PLL_1443X_RATE(_rate, _m, _p, _s, _k) \ - { \ - .rate = (_rate), \ - .mdiv = (_m), \ - .pdiv = (_p), \ - .sdiv = (_s), \ - .kdiv = (_k), \ - } - -static const struct imx_pll14xx_rate_table imx8mm_pll1416x_tbl[] = { - PLL_1416X_RATE(1800000000U, 225, 3, 0), - PLL_1416X_RATE(1600000000U, 200, 3, 0), - PLL_1416X_RATE(1200000000U, 300, 3, 1), - PLL_1416X_RATE(1000000000U, 250, 3, 1), - PLL_1416X_RATE(800000000U, 200, 3, 1), - PLL_1416X_RATE(750000000U, 250, 2, 2), - PLL_1416X_RATE(700000000U, 350, 3, 2), - PLL_1416X_RATE(600000000U, 300, 3, 2), -}; - -static const struct imx_pll14xx_rate_table imx8mm_drampll_tbl[] = { - PLL_1443X_RATE(650000000U, 325, 3, 2, 0), -}; - -static struct imx_pll14xx_clk imx8mm_dram_pll __initdata = { - .type = PLL_1443X, - .rate_table = imx8mm_drampll_tbl, - .rate_count = ARRAY_SIZE(imx8mm_drampll_tbl), -}; - -static struct imx_pll14xx_clk imx8mm_arm_pll __initdata = { - .type = PLL_1416X, - .rate_table = imx8mm_pll1416x_tbl, - .rate_count = ARRAY_SIZE(imx8mm_pll1416x_tbl), -}; - -static struct imx_pll14xx_clk imx8mm_sys_pll __initdata = { - .type = PLL_1416X, - .rate_table = imx8mm_pll1416x_tbl, - .rate_count = ARRAY_SIZE(imx8mm_pll1416x_tbl), -}; - static const char *pll_ref_sels[] = { "clock-osc-24m", "dummy", "dummy", "dummy", }; static const char *dram_pll_bypass_sels[] = {"dram_pll", "dram_pll_ref_sel", }; static const char *arm_pll_bypass_sels[] = {"arm_pll", "arm_pll_ref_sel", }; @@ -164,19 +114,19 @@ static int imx8mm_clk_probe(struct udevice *dev)
clk_dm(IMX8MM_DRAM_PLL, imx_clk_pll14xx("dram_pll", "dram_pll_ref_sel", - base + 0x50, &imx8mm_dram_pll)); + base + 0x50, &imx_1443x_dram_pll)); clk_dm(IMX8MM_ARM_PLL, imx_clk_pll14xx("arm_pll", "arm_pll_ref_sel", - base + 0x84, &imx8mm_arm_pll)); + base + 0x84, &imx_1416x_pll)); clk_dm(IMX8MM_SYS_PLL1, imx_clk_pll14xx("sys_pll1", "sys_pll1_ref_sel", - base + 0x94, &imx8mm_sys_pll)); + base + 0x94, &imx_1416x_pll)); clk_dm(IMX8MM_SYS_PLL2, imx_clk_pll14xx("sys_pll2", "sys_pll2_ref_sel", - base + 0x104, &imx8mm_sys_pll)); + base + 0x104, &imx_1416x_pll)); clk_dm(IMX8MM_SYS_PLL3, imx_clk_pll14xx("sys_pll3", "sys_pll3_ref_sel", - base + 0x114, &imx8mm_sys_pll)); + base + 0x114, &imx_1416x_pll));
/* PLL bypass out */ clk_dm(IMX8MM_DRAM_PLL_BYPASS, diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index bb62138f8ca..15d7599cfb7 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -15,56 +15,6 @@
#include "clk.h"
-#define PLL_1416X_RATE(_rate, _m, _p, _s) \ - { \ - .rate = (_rate), \ - .mdiv = (_m), \ - .pdiv = (_p), \ - .sdiv = (_s), \ - } - -#define PLL_1443X_RATE(_rate, _m, _p, _s, _k) \ - { \ - .rate = (_rate), \ - .mdiv = (_m), \ - .pdiv = (_p), \ - .sdiv = (_s), \ - .kdiv = (_k), \ - } - -static const struct imx_pll14xx_rate_table imx8mn_pll1416x_tbl[] = { - PLL_1416X_RATE(1800000000U, 225, 3, 0), - PLL_1416X_RATE(1600000000U, 200, 3, 0), - PLL_1416X_RATE(1200000000U, 300, 3, 1), - PLL_1416X_RATE(1000000000U, 250, 3, 1), - PLL_1416X_RATE(800000000U, 200, 3, 1), - PLL_1416X_RATE(750000000U, 250, 2, 2), - PLL_1416X_RATE(700000000U, 350, 3, 2), - PLL_1416X_RATE(600000000U, 300, 3, 2), -}; - -static const struct imx_pll14xx_rate_table imx8mn_drampll_tbl[] = { - PLL_1443X_RATE(650000000U, 325, 3, 2, 0), -}; - -static struct imx_pll14xx_clk imx8mn_dram_pll __initdata = { - .type = PLL_1443X, - .rate_table = imx8mn_drampll_tbl, - .rate_count = ARRAY_SIZE(imx8mn_drampll_tbl), -}; - -static struct imx_pll14xx_clk imx8mn_arm_pll __initdata = { - .type = PLL_1416X, - .rate_table = imx8mn_pll1416x_tbl, - .rate_count = ARRAY_SIZE(imx8mn_pll1416x_tbl), -}; - -static struct imx_pll14xx_clk imx8mn_sys_pll __initdata = { - .type = PLL_1416X, - .rate_table = imx8mn_pll1416x_tbl, - .rate_count = ARRAY_SIZE(imx8mn_pll1416x_tbl), -}; - static const char *pll_ref_sels[] = { "clock-osc-24m", "dummy", "dummy", "dummy", }; static const char *dram_pll_bypass_sels[] = {"dram_pll", "dram_pll_ref_sel", }; static const char *arm_pll_bypass_sels[] = {"arm_pll", "arm_pll_ref_sel", }; @@ -172,19 +122,19 @@ static int imx8mn_clk_probe(struct udevice *dev)
clk_dm(IMX8MN_DRAM_PLL, imx_clk_pll14xx("dram_pll", "dram_pll_ref_sel", - base + 0x50, &imx8mn_dram_pll)); + base + 0x50, &imx_1443x_dram_pll)); clk_dm(IMX8MN_ARM_PLL, imx_clk_pll14xx("arm_pll", "arm_pll_ref_sel", - base + 0x84, &imx8mn_arm_pll)); + base + 0x84, &imx_1416x_pll)); clk_dm(IMX8MN_SYS_PLL1, imx_clk_pll14xx("sys_pll1", "sys_pll1_ref_sel", - base + 0x94, &imx8mn_sys_pll)); + base + 0x94, &imx_1416x_pll)); clk_dm(IMX8MN_SYS_PLL2, imx_clk_pll14xx("sys_pll2", "sys_pll2_ref_sel", - base + 0x104, &imx8mn_sys_pll)); + base + 0x104, &imx_1416x_pll)); clk_dm(IMX8MN_SYS_PLL3, imx_clk_pll14xx("sys_pll3", "sys_pll3_ref_sel", - base + 0x114, &imx8mn_sys_pll)); + base + 0x114, &imx_1416x_pll));
/* PLL bypass out */ clk_dm(IMX8MN_DRAM_PLL_BYPASS, diff --git a/drivers/clk/imx/clk-imx8mp.c b/drivers/clk/imx/clk-imx8mp.c index ad84ce38ede..31689e02927 100644 --- a/drivers/clk/imx/clk-imx8mp.c +++ b/drivers/clk/imx/clk-imx8mp.c @@ -15,56 +15,6 @@
#include "clk.h"
-#define PLL_1416X_RATE(_rate, _m, _p, _s) \ - { \ - .rate = (_rate), \ - .mdiv = (_m), \ - .pdiv = (_p), \ - .sdiv = (_s), \ - } - -#define PLL_1443X_RATE(_rate, _m, _p, _s, _k) \ - { \ - .rate = (_rate), \ - .mdiv = (_m), \ - .pdiv = (_p), \ - .sdiv = (_s), \ - .kdiv = (_k), \ - } - -static const struct imx_pll14xx_rate_table imx8mp_pll1416x_tbl[] = { - PLL_1416X_RATE(1800000000U, 225, 3, 0), - PLL_1416X_RATE(1600000000U, 200, 3, 0), - PLL_1416X_RATE(1200000000U, 300, 3, 1), - PLL_1416X_RATE(1000000000U, 250, 3, 1), - PLL_1416X_RATE(800000000U, 200, 3, 1), - PLL_1416X_RATE(750000000U, 250, 2, 2), - PLL_1416X_RATE(700000000U, 350, 3, 2), - PLL_1416X_RATE(600000000U, 300, 3, 2), -}; - -static const struct imx_pll14xx_rate_table imx8mp_drampll_tbl[] = { - PLL_1443X_RATE(650000000U, 325, 3, 2, 0), -}; - -static struct imx_pll14xx_clk imx8mp_dram_pll __initdata = { - .type = PLL_1443X, - .rate_table = imx8mp_drampll_tbl, - .rate_count = ARRAY_SIZE(imx8mp_drampll_tbl), -}; - -static struct imx_pll14xx_clk imx8mp_arm_pll __initdata = { - .type = PLL_1416X, - .rate_table = imx8mp_pll1416x_tbl, - .rate_count = ARRAY_SIZE(imx8mp_pll1416x_tbl), -}; - -static struct imx_pll14xx_clk imx8mp_sys_pll __initdata = { - .type = PLL_1416X, - .rate_table = imx8mp_pll1416x_tbl, - .rate_count = ARRAY_SIZE(imx8mp_pll1416x_tbl), -}; - static const char *pll_ref_sels[] = { "clock-osc-24m", "dummy", "dummy", "dummy", }; static const char *dram_pll_bypass_sels[] = {"dram_pll", "dram_pll_ref_sel", }; static const char *arm_pll_bypass_sels[] = {"arm_pll", "arm_pll_ref_sel", }; @@ -198,11 +148,16 @@ static int imx8mp_clk_probe(struct udevice *dev) clk_dm(IMX8MP_SYS_PLL2_REF_SEL, imx_clk_mux("sys_pll2_ref_sel", base + 0x104, 0, 2, pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); clk_dm(IMX8MP_SYS_PLL3_REF_SEL, imx_clk_mux("sys_pll3_ref_sel", base + 0x114, 0, 2, pll_ref_sels, ARRAY_SIZE(pll_ref_sels)));
- clk_dm(IMX8MP_DRAM_PLL, imx_clk_pll14xx("dram_pll", "dram_pll_ref_sel", base + 0x50, &imx8mp_dram_pll)); - clk_dm(IMX8MP_ARM_PLL, imx_clk_pll14xx("arm_pll", "arm_pll_ref_sel", base + 0x84, &imx8mp_arm_pll)); - clk_dm(IMX8MP_SYS_PLL1, imx_clk_pll14xx("sys_pll1", "sys_pll1_ref_sel", base + 0x94, &imx8mp_sys_pll)); - clk_dm(IMX8MP_SYS_PLL2, imx_clk_pll14xx("sys_pll2", "sys_pll2_ref_sel", base + 0x104, &imx8mp_sys_pll)); - clk_dm(IMX8MP_SYS_PLL3, imx_clk_pll14xx("sys_pll3", "sys_pll3_ref_sel", base + 0x114, &imx8mp_sys_pll)); + clk_dm(IMX8MP_DRAM_PLL, imx_clk_pll14xx("dram_pll", "dram_pll_ref_sel", base + 0x50, + &imx_1443x_dram_pll)); + clk_dm(IMX8MP_ARM_PLL, imx_clk_pll14xx("arm_pll", "arm_pll_ref_sel", base + 0x84, + &imx_1416x_pll)); + clk_dm(IMX8MP_SYS_PLL1, imx_clk_pll14xx("sys_pll1", "sys_pll1_ref_sel", base + 0x94, + &imx_1416x_pll)); + clk_dm(IMX8MP_SYS_PLL2, imx_clk_pll14xx("sys_pll2", "sys_pll2_ref_sel", base + 0x104, + &imx_1416x_pll)); + clk_dm(IMX8MP_SYS_PLL3, imx_clk_pll14xx("sys_pll3", "sys_pll3_ref_sel", base + 0x114, + &imx_1416x_pll));
clk_dm(IMX8MP_DRAM_PLL_BYPASS, imx_clk_mux_flags("dram_pll_bypass", base + 0x50, 4, 1, dram_pll_bypass_sels, ARRAY_SIZE(dram_pll_bypass_sels), CLK_SET_RATE_PARENT)); clk_dm(IMX8MP_ARM_PLL_BYPASS, imx_clk_mux_flags("arm_pll_bypass", base + 0x84, 4, 1, arm_pll_bypass_sels, ARRAY_SIZE(arm_pll_bypass_sels), CLK_SET_RATE_PARENT)); diff --git a/drivers/clk/imx/clk-imx8mq.c b/drivers/clk/imx/clk-imx8mq.c index 4b925265255..b01c4fbbda5 100644 --- a/drivers/clk/imx/clk-imx8mq.c +++ b/drivers/clk/imx/clk-imx8mq.c @@ -16,53 +16,6 @@
#include "clk.h"
-#define PLL_1416X_RATE(_rate, _m, _p, _s) \ - { \ - .rate = (_rate), \ - .mdiv = (_m), \ - .pdiv = (_p), \ - .sdiv = (_s), \ - } - -#define PLL_1443X_RATE(_rate, _m, _p, _s, _k) \ - { \ - .rate = (_rate), \ - .mdiv = (_m), \ - .pdiv = (_p), \ - .sdiv = (_s), \ - .kdiv = (_k), \ - } - -static const struct imx_pll14xx_rate_table imx8mq_pll1416x_tbl[] = { - PLL_1416X_RATE(1800000000U, 225, 3, 0), - PLL_1416X_RATE(1600000000U, 200, 3, 0), - PLL_1416X_RATE(1200000000U, 300, 3, 1), - PLL_1416X_RATE(1000000000U, 250, 3, 1), - PLL_1416X_RATE(800000000U, 200, 3, 1), - PLL_1416X_RATE(750000000U, 250, 2, 2), - PLL_1416X_RATE(700000000U, 350, 3, 2), - PLL_1416X_RATE(600000000U, 300, 3, 2), -}; - -const struct imx_pll14xx_rate_table imx8mq_pll1443x_tbl[] = { - PLL_1443X_RATE(650000000U, 325, 3, 2, 0), - PLL_1443X_RATE(594000000U, 198, 2, 2, 0), - PLL_1443X_RATE(393216000U, 262, 2, 3, 9437), - PLL_1443X_RATE(361267200U, 361, 3, 3, 17511), -}; - -static struct imx_pll14xx_clk imx8mq_1416x_pll __initdata = { - .type = PLL_1416X, - .rate_table = imx8mq_pll1416x_tbl, - .rate_count = ARRAY_SIZE(imx8mq_pll1416x_tbl), -}; - -static struct imx_pll14xx_clk imx8mq_1443x_pll __initdata = { - .type = PLL_1443X, - .rate_table = imx8mq_pll1443x_tbl, - .rate_count = ARRAY_SIZE(imx8mq_pll1443x_tbl), -}; - static const char *const pll_ref_sels[] = { "clock-osc-25m", "clock-osc-27m", "clock-phy-27m", "dummy", }; static const char *const arm_pll_bypass_sels[] = {"arm_pll", "arm_pll_ref_sel", }; static const char *const gpu_pll_bypass_sels[] = {"gpu_pll", "gpu_pll_ref_sel", }; @@ -231,13 +184,13 @@ static int imx8mq_clk_probe(struct udevice *dev)
clk_dm(IMX8MQ_ARM_PLL, imx_clk_pll14xx("arm_pll", "arm_pll_ref_sel", - base + 0x28, &imx8mq_1416x_pll)); + base + 0x28, &imx_1416x_pll)); clk_dm(IMX8MQ_GPU_PLL, imx_clk_pll14xx("gpu_pll", "gpu_pll_ref_sel", - base + 0x18, &imx8mq_1416x_pll)); + base + 0x18, &imx_1416x_pll)); clk_dm(IMX8MQ_VPU_PLL, imx_clk_pll14xx("vpu_pll", "vpu_pll_ref_sel", - base + 0x20, &imx8mq_1416x_pll)); + base + 0x20, &imx_1416x_pll));
clk_dm(IMX8MQ_SYS1_PLL1, clk_register_fixed_rate(NULL, "sys1_pll", 800000000)); @@ -247,13 +200,13 @@ static int imx8mq_clk_probe(struct udevice *dev) clk_register_fixed_rate(NULL, "sys3_pll", 1000000000)); clk_dm(IMX8MQ_AUDIO_PLL1, imx_clk_pll14xx("audio_pll1", "audio_pll1_ref_sel", - base + 0x0, &imx8mq_1443x_pll)); + base + 0x0, &imx_1443x_pll)); clk_dm(IMX8MQ_AUDIO_PLL2, imx_clk_pll14xx("audio_pll2", "audio_pll2_ref_sel", - base + 0x8, &imx8mq_1443x_pll)); + base + 0x8, &imx_1443x_pll)); clk_dm(IMX8MQ_VIDEO_PLL1, imx_clk_pll14xx("video_pll1", "video_pll1_ref_sel", - base + 0x10, &imx8mq_1443x_pll)); + base + 0x10, &imx_1443x_pll));
/* PLL bypass out */ clk_dm(IMX8MQ_ARM_PLL_BYPASS, diff --git a/drivers/clk/imx/clk-pll14xx.c b/drivers/clk/imx/clk-pll14xx.c index b0ccb6c8eda..b93c0bc64e7 100644 --- a/drivers/clk/imx/clk-pll14xx.c +++ b/drivers/clk/imx/clk-pll14xx.c @@ -52,6 +52,67 @@ struct clk_pll14xx {
#define to_clk_pll14xx(_clk) container_of(_clk, struct clk_pll14xx, clk)
+#define PLL_1416X_RATE(_rate, _m, _p, _s) \ + { \ + .rate = (_rate), \ + .mdiv = (_m), \ + .pdiv = (_p), \ + .sdiv = (_s), \ + } + +#define PLL_1443X_RATE(_rate, _m, _p, _s, _k) \ + { \ + .rate = (_rate), \ + .mdiv = (_m), \ + .pdiv = (_p), \ + .sdiv = (_s), \ + .kdiv = (_k), \ + } + +static const struct imx_pll14xx_rate_table imx_pll1416x_tbl[] = { + PLL_1416X_RATE(1800000000U, 225, 3, 0), + PLL_1416X_RATE(1600000000U, 200, 3, 0), + PLL_1416X_RATE(1500000000U, 375, 3, 1), + PLL_1416X_RATE(1400000000U, 350, 3, 1), + PLL_1416X_RATE(1200000000U, 300, 3, 1), + PLL_1416X_RATE(1000000000U, 250, 3, 1), + PLL_1416X_RATE(800000000U, 200, 3, 1), + PLL_1416X_RATE(750000000U, 250, 2, 2), + PLL_1416X_RATE(700000000U, 350, 3, 2), + PLL_1416X_RATE(600000000U, 300, 3, 2), +}; + +const struct imx_pll14xx_rate_table imx_pll1443x_tbl[] = { + PLL_1443X_RATE(1039500000U, 173, 2, 1, 16384), + PLL_1443X_RATE(650000000U, 325, 3, 2, 0), + PLL_1443X_RATE(594000000U, 198, 2, 2, 0), + PLL_1443X_RATE(519750000U, 173, 2, 2, 16384), + PLL_1443X_RATE(393216000U, 262, 2, 3, 9437), + PLL_1443X_RATE(361267200U, 361, 3, 3, 17511), +}; + +struct imx_pll14xx_clk imx_1443x_pll __initdata = { + .type = PLL_1443X, + .rate_table = imx_pll1443x_tbl, + .rate_count = ARRAY_SIZE(imx_pll1443x_tbl), +}; +EXPORT_SYMBOL_GPL(imx_1443x_pll); + +struct imx_pll14xx_clk imx_1443x_dram_pll __initdata = { + .type = PLL_1443X, + .rate_table = imx_pll1443x_tbl, + .rate_count = ARRAY_SIZE(imx_pll1443x_tbl), + .flags = CLK_GET_RATE_NOCACHE, +}; +EXPORT_SYMBOL_GPL(imx_1443x_dram_pll); + +struct imx_pll14xx_clk imx_1416x_pll __initdata = { + .type = PLL_1416X, + .rate_table = imx_pll1416x_tbl, + .rate_count = ARRAY_SIZE(imx_pll1416x_tbl), +}; +EXPORT_SYMBOL_GPL(imx_1416x_pll); + static const struct imx_pll14xx_rate_table *imx_get_pll_settings( struct clk_pll14xx *pll, unsigned long rate) { diff --git a/drivers/clk/imx/clk.h b/drivers/clk/imx/clk.h index 60f287046b9..0e1eaf03d41 100644 --- a/drivers/clk/imx/clk.h +++ b/drivers/clk/imx/clk.h @@ -41,6 +41,10 @@ struct imx_pll14xx_clk { int flags; };
+extern struct imx_pll14xx_clk imx_1416x_pll; +extern struct imx_pll14xx_clk imx_1443x_pll; +extern struct imx_pll14xx_clk imx_1443x_dram_pll; + struct clk *imx_clk_pll14xx(const char *name, const char *parent_name, void __iomem *base, const struct imx_pll14xx_clk *pll_clk);
Please ignore. I introduced some unused variables. v7 sent.
Angus
Changes since v5
Changes since v4
Changes since v3:
Changes since v2:
Changes since v1:
[1]https://patchwork.ozlabs.org/project/uboot/patch/20220320203446.740178-2-sea...
Angus Ainslie
Angus Ainslie
