[U-Boot-Users] [Patch 2/9] U-boot-V2:ARM: Introduce additional bitops
Add linux-like bitops definitions - this is based on 2.6.25 rc5 kernel
Signed-off-by: Nishanth Menon x0nishan@ti.com
--- arch/arm/lib/Makefile | 1 arch/arm/lib/findbit.S | 181 +++++++++++++++++++++++++++++++++++++++++++++++ include/asm-arm/bitops.h | 86 +++++++++++++++++++++- 3 files changed, 265 insertions(+), 3 deletions(-)
Index: u-boot-v2.git/arch/arm/lib/findbit.S =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/lib/findbit.S 2008-06-17 17:01:06.000000000 -0500 @@ -0,0 +1,181 @@ +/** + * @file + * @brief common bitops + */ +/* + * Originally from Linux kernel + * arch/arm/lib/findbit.S + * + * Copyright (C) 1995-2000 Russell King + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * 16th March 2001 - John Ripley jripley@sonicblue.com + * Fixed so that "size" is an exclusive not an inclusive quantity. + * All users of these functions expect exclusive sizes, and may + * also call with zero size. + * Reworked by rmk. + */ + .text + +/* + * Purpose : Find a 'zero' bit + * Prototype: int find_first_zero_bit(void *addr, unsigned int maxbit); + */ + .globl _find_first_zero_bit_le; +_find_first_zero_bit_le: + teq r1, #0 + beq 3f + mov r2, #0 +1: ldrb r3, [r0, r2, lsr #3] + eors r3, r3, #0xff @ invert bits + bne .L_found @ any now set - found zero bit + add r2, r2, #8 @ next bit pointer +2: cmp r2, r1 @ any more? + blo 1b +3: mov r0, r1 @ no free bits + mov pc, lr + +/* + * Purpose : Find next 'zero' bit + * Prototype: int find_next_zero_bit(void *addr, unsigned int maxbit, + * int offset) + */ + .globl _find_next_zero_bit_le; +_find_next_zero_bit_le: + teq r1, #0 + beq 3b + ands ip, r2, #7 + beq 1b @ If new byte, goto old routine + ldrb r3, [r0, r2, lsr #3] + eor r3, r3, #0xff @ now looking for a 1 bit + movs r3, r3, lsr ip @ shift off unused bits + bne .L_found + orr r2, r2, #7 @ if zero, then no bits here + add r2, r2, #1 @ align bit pointer + b 2b @ loop for next bit + +/* + * Purpose : Find a 'one' bit + * Prototype: int find_first_bit(const unsigned long *addr, unsigned int maxbit) + */ + .globl _find_first_bit_le; +_find_first_bit_le: + teq r1, #0 + beq 3f + mov r2, #0 +1: ldrb r3, [r0, r2, lsr #3] + movs r3, r3 + bne .L_found @ any now set - found zero bit + add r2, r2, #8 @ next bit pointer +2: cmp r2, r1 @ any more? + blo 1b +3: mov r0, r1 @ no free bits + mov pc, lr + +/* + * Purpose : Find next 'one' bit + * Prototype: int find_next_zero_bit(void *addr, unsigned int maxbit, + * int offset) + */ + .globl _find_next_bit_le; +_find_next_bit_le: + teq r1, #0 + beq 3b + ands ip, r2, #7 + beq 1b @ If new byte, goto old routine + ldrb r3, [r0, r2, lsr #3] + movs r3, r3, lsr ip @ shift off unused bits + bne .L_found + orr r2, r2, #7 @ if zero, then no bits here + add r2, r2, #1 @ align bit pointer + b 2b @ loop for next bit + +#ifdef __ARMEB__ + + .globl _find_first_zero_bit_be; +_find_first_zero_bit_be: + teq r1, #0 + beq 3f + mov r2, #0 +1: eor r3, r2, #0x18 @ big endian byte ordering + ldrb r3, [r0, r3, lsr #3] + eors r3, r3, #0xff @ invert bits + bne .L_found @ any now set - found zero bit + add r2, r2, #8 @ next bit pointer +2: cmp r2, r1 @ any more? + blo 1b +3: mov r0, r1 @ no free bits + mov pc, lr + + .globl _find_next_zero_bit_be; +_find_next_zero_bit_be: + teq r1, #0 + beq 3b + ands ip, r2, #7 + beq 1b @ If new byte, goto old routine + eor r3, r2, #0x18 @ big endian byte ordering + ldrb r3, [r0, r3, lsr #3] + eor r3, r3, #0xff @ now looking for a 1 bit + movs r3, r3, lsr ip @ shift off unused bits + bne .L_found + orr r2, r2, #7 @ if zero, then no bits here + add r2, r2, #1 @ align bit pointer + b 2b @ loop for next bit + + .globl _find_first_bit_be; +_find_first_bit_be: + teq r1, #0 + beq 3f + mov r2, #0 +1: eor r3, r2, #0x18 @ big endian byte ordering + ldrb r3, [r0, r3, lsr #3] + movs r3, r3 + bne .L_found @ any now set - found zero bit + add r2, r2, #8 @ next bit pointer +2: cmp r2, r1 @ any more? + blo 1b +3: mov r0, r1 @ no free bits + mov pc, lr + + .globl _find_next_bit_be; +_find_next_bit_be: + teq r1, #0 + beq 3b + ands ip, r2, #7 + beq 1b @ If new byte, goto old routine + eor r3, r2, #0x18 @ big endian byte ordering + ldrb r3, [r0, r3, lsr #3] + movs r3, r3, lsr ip @ shift off unused bits + bne .L_found + orr r2, r2, #7 @ if zero, then no bits here + add r2, r2, #1 @ align bit pointer + b 2b @ loop for next bit + +#endif + +/* + * One or more bits in the LSB of r3 are assumed to be set. + */ +.L_found: +#if __LINUX_ARM_ARCH__ >= 5 + rsb r1, r3, #0 + and r3, r3, r1 + clz r3, r3 + rsb r3, r3, #31 + add r0, r2, r3 +#else + tst r3, #0x0f + addeq r2, r2, #4 + movne r3, r3, lsl #4 + tst r3, #0x30 + addeq r2, r2, #2 + movne r3, r3, lsl #2 + tst r3, #0x40 + addeq r2, r2, #1 + mov r0, r2 +#endif + mov pc, lr + Index: u-boot-v2.git/arch/arm/lib/Makefile =================================================================== --- u-boot-v2.git.orig/arch/arm/lib/Makefile 2008-06-17 16:52:31.000000000 -0500 +++ u-boot-v2.git/arch/arm/lib/Makefile 2008-06-17 17:01:06.000000000 -0500 @@ -8,6 +8,7 @@ obj-y += _udivsi3.o obj-y += _umodsi3.o obj-y += _lshrdi3.o +obj-y += findbit.o obj-y += arm.o obj-$(CONFIG_MODULES) += module.o extra-$(CONFIG_GENERIC_LINKER_SCRIPT) += u-boot.lds Index: u-boot-v2.git/include/asm-arm/bitops.h =================================================================== --- u-boot-v2.git.orig/include/asm-arm/bitops.h 2008-06-17 16:52:31.000000000 -0500 +++ u-boot-v2.git/include/asm-arm/bitops.h 2008-06-17 17:01:06.000000000 -0500 @@ -75,9 +75,6 @@ return oldval & mask; }
-extern int find_first_zero_bit(void * addr, unsigned size); -extern int find_next_zero_bit(void * addr, int size, int offset); - /* * This routine doesn't need to be atomic. */ @@ -86,6 +83,44 @@ return ((unsigned char *) addr)[nr >> 3] & (1U << (nr & 7)); }
+ + + +#ifndef __ARMEB__ +/* + * These are the little endian definitions. + */ +extern int _find_first_zero_bit_le(const void *p, unsigned size); +extern int _find_next_zero_bit_le(const void *p, int size, int offset); +extern int _find_first_bit_le(const unsigned long *p, unsigned size); +extern int _find_next_bit_le(const unsigned long *p, int size, int offset); +#define find_first_zero_bit(p, sz) _find_first_zero_bit_le(p, sz) +#define find_next_zero_bit(p, sz, off) _find_next_zero_bit_le(p, sz, off) +#define find_first_bit(p, sz) _find_first_bit_le(p, sz) +#define find_next_bit(p, sz, off) _find_next_bit_le(p, sz, off) + +#define WORD_BITOFF_TO_LE(x) ((x)) + +#else + +/* + * These are the big endian definitions. + */ +extern int _find_first_zero_bit_be(const void *p, unsigned size); +extern int _find_next_zero_bit_be(const void *p, int size, int offset); +extern int _find_first_bit_be(const unsigned long *p, unsigned size); +extern int _find_next_bit_be(const unsigned long *p, int size, int offset); +#define find_first_zero_bit(p, sz) _find_first_zero_bit_be(p, sz) +#define find_next_zero_bit(p, sz, off) _find_next_zero_bit_be(p, sz, off) +#define find_first_bit(p, sz) _find_first_bit_be(p, sz) +#define find_next_bit(p, sz, off) _find_next_bit_be(p, sz, off) + +#define WORD_BITOFF_TO_LE(x) ((x) ^ 0x18) + +#endif + +#if (defined(__LINUX_ARM_ARCH__) && (__LINUX_ARM_ARCH__ < 5)) + /* * ffz = Find First Zero in word. Undefined if no zero exists, * so code should check against ~0UL first.. @@ -112,6 +147,51 @@
#define ffs(x) generic_ffs(x)
+#else + +static inline int constant_fls(int x) +{ + int r = 32; + + if (!x) + return 0; + if (!(x & 0xffff0000u)) { + x <<= 16; + r -= 16; + } + if (!(x & 0xff000000u)) { + x <<= 8; + r -= 8; + } + if (!(x & 0xf0000000u)) { + x <<= 4; + r -= 4; + } + if (!(x & 0xc0000000u)) { + x <<= 2; + r -= 2; + } + if (!(x & 0x80000000u)) { + x <<= 1; + r -= 1; + } + return r; +} + +/* + * On ARMv5 and above those functions can be implemented around + * the clz instruction for much better code efficiency. + */ + +#define fls(x) \ + (__builtin_constant_p(x) ? constant_fls(x) : \ + ({ int __r; asm("clz\t%0, %1" : "=r"(__r) : "r"(x) : "cc"); 32-__r; })) +#define ffs(x) ({ unsigned long __t = (x); fls(__t &-__t); }) +#define __ffs(x) (ffs(x) - 1) +#define ffz(x) __ffs(~(x)) + +#endif + /* * hweightN: returns the hamming weight (i.e. the number * of bits set) of a N-bit word
I haven't looked at it, but I guess you need these for the following patches. It would be better to first introduce generic bitops. Otherwise we end up with i2c only working on arm.
Sascha
- @file
- @brief common bitops
- Originally from Linux kernel
- arch/arm/lib/findbit.S
- Copyright (C) 1995-2000 Russell King
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
- 16th March 2001 - John Ripley jripley@sonicblue.com
- Fixed so that "size" is an exclusive not an inclusive quantity.
- All users of these functions expect exclusive sizes, and may
- also call with zero size.
- Reworked by rmk.
.text
- Purpose : Find a 'zero' bit
- Prototype: int find_first_zero_bit(void *addr, unsigned int maxbit);
teq r1, #0
beq 3f
mov r2, #0
blo 1b
mov pc, lr
- Purpose : Find next 'zero' bit
- Prototype: int find_next_zero_bit(void *addr, unsigned int maxbit,
int offset)
teq r1, #0
beq 3b
ands ip, r2, #7
bne .L_found
- Purpose : Find a 'one' bit
- Prototype: int find_first_bit(const unsigned long *addr, unsigned int maxbit)
teq r1, #0
beq 3f
mov r2, #0
movs r3, r3
blo 1b
mov pc, lr
- Purpose : Find next 'one' bit
int offset)
+_find_next_bit_le:
teq r1, #0
beq 3b
ands ip, r2, #7
bne .L_found
+#ifdef __ARMEB__
teq r1, #0
beq 3f
mov r2, #0
blo 1b
mov pc, lr
teq r1, #0
beq 3b
ands ip, r2, #7
bne .L_found
teq r1, #0
beq 3f
mov r2, #0
movs r3, r3
blo 1b
mov pc, lr
+_find_next_bit_be:
teq r1, #0
beq 3b
ands ip, r2, #7
bne .L_found
- One or more bits in the LSB of r3 are assumed to be set.
rsb r1, r3, #0
and r3, r3, r1
clz r3, r3
rsb r3, r3, #31
add r0, r2, r3
+#else
tst r3, #0x0f
addeq r2, r2, #4
tst r3, #0x30
addeq r2, r2, #2
tst r3, #0x40
addeq r2, r2, #1
mov r0, r2
mov pc, lr
- This routine doesn't need to be atomic.
- These are the little endian definitions.
+#else
- These are the big endian definitions.
- ffz = Find First Zero in word. Undefined if no zero exists,
- so code should check against ~0UL first..
+#else
int r = 32;
if (!x)
x <<= 16;
r -= 16;
x <<= 8;
r -= 8;
x <<= 4;
r -= 4;
x <<= 2;
r -= 2;
x <<= 1;
r -= 1;
return r;
- On ARMv5 and above those functions can be implemented around
- the clz instruction for much better code efficiency.
+#define fls(x) \
- hweightN: returns the hamming weight (i.e. the number
- of bits set) of a N-bit word
Sascha,
-----Original Message----- From: Sascha Hauer [mailto:s.hauer@pengutronix.de] Sent: Wednesday, June 18, 2008 10:31 AM To: Menon, Nishanth Cc: Kamat, Nishant; u-boot-users@lists.sourceforge.net; Laurent Desnogues; philip.balister@gmail.com; dirk.behme@googlemail.com Subject: Re: [Patch 2/9] U-boot-V2:ARM: Introduce additional bitops
Would you have a proposal for it? I am not familiar with ppc and other archs :( I can help on ARM side of things.
Regards, Nishanth Menon
On Wed, Jun 18, 2008 at 10:41:44AM -0500, Menon, Nishanth wrote:
Sascha,
In the kernel are generic bitops, #ifdefed with CONFIG_GENERIC_XXX
Regards, Sascha
Sascha, The following 3 patches are for cleaning up the bitops
-----Original Message----- From: Sascha Hauer [mailto:s.hauer@pengutronix.de] Sent: Wednesday, June 18, 2008 10:51 AM To: Menon, Nishanth Cc: Kamat, Nishant; u-boot-users@lists.sourceforge.net; Laurent Desnogues; philip.balister@gmail.com; dirk.behme@googlemail.com Subject: Re: [Patch 2/9] U-boot-V2:ARM: Introduce additional bitops
This introduces selected generic bitop files from kernel. We don't need minix, ext2, sched or lock based bitops. Those have been dropped.
--- include/asm-generic/bitops/__ffs.h | 43 ++++++++++++++++ include/asm-generic/bitops/__fls.h | 43 ++++++++++++++++ include/asm-generic/bitops/ffs.h | 41 +++++++++++++++ include/asm-generic/bitops/ffz.h | 12 ++++ include/asm-generic/bitops/find.h | 15 +++++ include/asm-generic/bitops/fls.h | 41 +++++++++++++++ include/asm-generic/bitops/fls64.h | 36 +++++++++++++ include/asm-generic/bitops/hweight.h | 35 +++++++++++++ include/asm-generic/bitops/ops.h | 91 +++++++++++++++++++++++++++++++++++ 9 files changed, 357 insertions(+)
Index: u-boot-v2.git/include/asm-generic/bitops/__ffs.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/__ffs.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,43 @@ +#ifndef _ASM_GENERIC_BITOPS___FFS_H_ +#define _ASM_GENERIC_BITOPS___FFS_H_ + +#include <asm/types.h> + +/** + * __ffs - find first bit in word. + * @word: The word to search + * + * Undefined if no bit exists, so code should check against 0 first. + */ +static inline unsigned long __ffs(unsigned long word) +{ + int num = 0; + +#if BITS_PER_LONG == 64 + if ((word & 0xffffffff) == 0) { + num += 32; + word >>= 32; + } +#endif + if ((word & 0xffff) == 0) { + num += 16; + word >>= 16; + } + if ((word & 0xff) == 0) { + num += 8; + word >>= 8; + } + if ((word & 0xf) == 0) { + num += 4; + word >>= 4; + } + if ((word & 0x3) == 0) { + num += 2; + word >>= 2; + } + if ((word & 0x1) == 0) + num += 1; + return num; +} + +#endif /* _ASM_GENERIC_BITOPS___FFS_H_ */ Index: u-boot-v2.git/include/asm-generic/bitops/__fls.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/__fls.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,43 @@ +#ifndef _ASM_GENERIC_BITOPS___FLS_H_ +#define _ASM_GENERIC_BITOPS___FLS_H_ + +#include <asm/types.h> + +/** + * __fls - find last (most-significant) set bit in a long word + * @word: the word to search + * + * Undefined if no set bit exists, so code should check against 0 first. + */ +static inline unsigned long __fls(unsigned long word) +{ + int num = BITS_PER_LONG - 1; + +#if BITS_PER_LONG == 64 + if (!(word & (~0ul << 32))) { + num -= 32; + word <<= 32; + } +#endif + if (!(word & (~0ul << (BITS_PER_LONG-16)))) { + num -= 16; + word <<= 16; + } + if (!(word & (~0ul << (BITS_PER_LONG-8)))) { + num -= 8; + word <<= 8; + } + if (!(word & (~0ul << (BITS_PER_LONG-4)))) { + num -= 4; + word <<= 4; + } + if (!(word & (~0ul << (BITS_PER_LONG-2)))) { + num -= 2; + word <<= 2; + } + if (!(word & (~0ul << (BITS_PER_LONG-1)))) + num -= 1; + return num; +} + +#endif /* _ASM_GENERIC_BITOPS___FLS_H_ */ Index: u-boot-v2.git/include/asm-generic/bitops/ffs.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/ffs.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,41 @@ +#ifndef _ASM_GENERIC_BITOPS_FFS_H_ +#define _ASM_GENERIC_BITOPS_FFS_H_ + +/** + * ffs - find first bit set + * @x: the word to search + * + * This is defined the same way as + * the libc and compiler builtin ffs routines, therefore + * differs in spirit from the above ffz (man ffs). + */ +static inline int ffs(int x) +{ + int r = 1; + + if (!x) + return 0; + if (!(x & 0xffff)) { + x >>= 16; + r += 16; + } + if (!(x & 0xff)) { + x >>= 8; + r += 8; + } + if (!(x & 0xf)) { + x >>= 4; + r += 4; + } + if (!(x & 3)) { + x >>= 2; + r += 2; + } + if (!(x & 1)) { + x >>= 1; + r += 1; + } + return r; +} + +#endif /* _ASM_GENERIC_BITOPS_FFS_H_ */ Index: u-boot-v2.git/include/asm-generic/bitops/ffz.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/ffz.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,12 @@ +#ifndef _ASM_GENERIC_BITOPS_FFZ_H_ +#define _ASM_GENERIC_BITOPS_FFZ_H_ + +/* + * ffz - find first zero in word. + * @word: The word to search + * + * Undefined if no zero exists, so code should check against ~0UL first. + */ +#define ffz(x) __ffs(~(x)) + +#endif /* _ASM_GENERIC_BITOPS_FFZ_H_ */ Index: u-boot-v2.git/include/asm-generic/bitops/find.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/find.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,15 @@ +#ifndef _ASM_GENERIC_BITOPS_FIND_H_ +#define _ASM_GENERIC_BITOPS_FIND_H_ + +#ifndef CONFIG_GENERIC_FIND_NEXT_BIT +extern unsigned long find_next_bit(const unsigned long *addr, unsigned long + size, unsigned long offset); + +extern unsigned long find_next_zero_bit(const unsigned long *addr, unsigned + long size, unsigned long offset); +#endif + +#define find_first_bit(addr, size) find_next_bit((addr), (size), 0) +#define find_first_zero_bit(addr, size) find_next_zero_bit((addr), (size), 0) + +#endif /*_ASM_GENERIC_BITOPS_FIND_H_ */ Index: u-boot-v2.git/include/asm-generic/bitops/fls.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/fls.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,41 @@ +#ifndef _ASM_GENERIC_BITOPS_FLS_H_ +#define _ASM_GENERIC_BITOPS_FLS_H_ + +/** + * fls - find last (most-significant) bit set + * @x: the word to search + * + * This is defined the same way as ffs. + * Note fls(0) = 0, fls(1) = 1, fls(0x80000000) = 32. + */ + +static inline int fls(int x) +{ + int r = 32; + + if (!x) + return 0; + if (!(x & 0xffff0000u)) { + x <<= 16; + r -= 16; + } + if (!(x & 0xff000000u)) { + x <<= 8; + r -= 8; + } + if (!(x & 0xf0000000u)) { + x <<= 4; + r -= 4; + } + if (!(x & 0xc0000000u)) { + x <<= 2; + r -= 2; + } + if (!(x & 0x80000000u)) { + x <<= 1; + r -= 1; + } + return r; +} + +#endif /* _ASM_GENERIC_BITOPS_FLS_H_ */ Index: u-boot-v2.git/include/asm-generic/bitops/fls64.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/fls64.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,36 @@ +#ifndef _ASM_GENERIC_BITOPS_FLS64_H_ +#define _ASM_GENERIC_BITOPS_FLS64_H_ + +#include <asm/types.h> + +/** + * fls64 - find last set bit in a 64-bit word + * @x: the word to search + * + * This is defined in a similar way as the libc and compiler builtin + * ffsll, but returns the position of the most significant set bit. + * + * fls64(value) returns 0 if value is 0 or the position of the last + * set bit if value is nonzero. The last (most significant) bit is + * at position 64. + */ +#if BITS_PER_LONG == 32 +static inline int fls64(__u64 x) +{ + __u32 h = x >> 32; + if (h) + return fls(h) + 32; + return fls(x); +} +#elif BITS_PER_LONG == 64 +static inline int fls64(__u64 x) +{ + if (x == 0) + return 0; + return __fls(x) + 1; +} +#else +#error BITS_PER_LONG not 32 or 64 +#endif + +#endif /* _ASM_GENERIC_BITOPS_FLS64_H_ */ Index: u-boot-v2.git/include/asm-generic/bitops/hweight.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/hweight.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,35 @@ +#ifndef _ASM_GENERIC_BITOPS_HWEIGHT_H_ +#define _ASM_GENERIC_BITOPS_HWEIGHT_H_ + +#include <asm/types.h> + +/* + * hweightN: returns the hamming weight (i.e. the number + * of bits set) of a N-bit word + */ + +static inline unsigned int hweight32(unsigned int w) +{ + unsigned int res = (w & 0x55555555) + ((w >> 1) & 0x55555555); + res = (res & 0x33333333) + ((res >> 2) & 0x33333333); + res = (res & 0x0F0F0F0F) + ((res >> 4) & 0x0F0F0F0F); + res = (res & 0x00FF00FF) + ((res >> 8) & 0x00FF00FF); + return (res & 0x0000FFFF) + ((res >> 16) & 0x0000FFFF); +} + +static inline unsigned int hweight16(unsigned int w) +{ + unsigned int res = (w & 0x5555) + ((w >> 1) & 0x5555); + res = (res & 0x3333) + ((res >> 2) & 0x3333); + res = (res & 0x0F0F) + ((res >> 4) & 0x0F0F); + return (res & 0x00FF) + ((res >> 8) & 0x00FF); +} + +static inline unsigned int hweight8(unsigned int w) +{ + unsigned int res = (w & 0x55) + ((w >> 1) & 0x55); + res = (res & 0x33) + ((res >> 2) & 0x33); + return (res & 0x0F) + ((res >> 4) & 0x0F); +} + +#endif /* _ASM_GENERIC_BITOPS_HWEIGHT_H_ */ Index: u-boot-v2.git/include/asm-generic/bitops/ops.h =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/include/asm-generic/bitops/ops.h 2008-06-19 01:06:03.000000000 -0500 @@ -0,0 +1,91 @@ +#ifndef _ASM_GENERIC_BITOPS_OPS_H_ +#define _ASM_GENERIC_BITOPS_OPS_H_ + +#include <asm/types.h> + +/** + * __set_bit - Set a bit in memory + * @nr: the bit to set + * @addr: the address to start counting from + */ +static inline void __set_bit(int nr, volatile unsigned long *addr) +{ + unsigned long mask = BIT_MASK(nr); + unsigned long *p = ((unsigned long *)addr) + BIT_WORD(nr); + + *p |= mask; +} + +static inline void __clear_bit(int nr, volatile unsigned long *addr) +{ + unsigned long mask = BIT_MASK(nr); + unsigned long *p = ((unsigned long *)addr) + BIT_WORD(nr); + + *p &= ~mask; +} + +/** + * __change_bit - Toggle a bit in memory + * @nr: the bit to change + * @addr: the address to start counting from + */ +static inline void __change_bit(int nr, volatile unsigned long *addr) +{ + unsigned long mask = BIT_MASK(nr); + unsigned long *p = ((unsigned long *)addr) + BIT_WORD(nr); + + *p ^= mask; +} + +/** + * __test_and_set_bit - Set a bit and return its old value + * @nr: Bit to set + * @addr: Address to count from + */ +static inline int __test_and_set_bit(int nr, volatile unsigned long *addr) +{ + unsigned long mask = BIT_MASK(nr); + unsigned long *p = ((unsigned long *)addr) + BIT_WORD(nr); + unsigned long old = *p; + + *p = old | mask; + return (old & mask) != 0; +} + +/** + * __test_and_clear_bit - Clear a bit and return its old value + * @nr: Bit to clear + * @addr: Address to count from + */ +static inline int __test_and_clear_bit(int nr, volatile unsigned long *addr) +{ + unsigned long mask = BIT_MASK(nr); + unsigned long *p = ((unsigned long *)addr) + BIT_WORD(nr); + unsigned long old = *p; + + *p = old & ~mask; + return (old & mask) != 0; +} + +static inline int __test_and_change_bit(int nr, + volatile unsigned long *addr) +{ + unsigned long mask = BIT_MASK(nr); + unsigned long *p = ((unsigned long *)addr) + BIT_WORD(nr); + unsigned long old = *p; + + *p = old ^ mask; + return (old & mask) != 0; +} + +/** + * test_bit - Determine whether a bit is set + * @nr: bit number to test + * @addr: Address to start counting from + */ +static inline int test_bit(int nr, const volatile unsigned long *addr) +{ + return 1UL & (addr[BIT_WORD(nr)] >> (nr & (BITS_PER_LONG-1))); +} + +#endif /* _ASM_GENERIC_BITOPS_OPS_H_ */
Again, either leave the above crap out entirely or place it below the triple-dash line.
Line wrap the log message at 70 or 72.
Thanks, jdl
Cleanup of ARM bitops functions. Introduce the findbits.S which allows for optimized algo.
--- arch/arm/lib/Makefile | 1 arch/arm/lib/findbit.S | 181 +++++++++++++++++++++++++++++++++++++++++++++++ include/asm-arm/bitops.h | 133 +++++++++++++++++++++++----------- 3 files changed, 273 insertions(+), 42 deletions(-)
Index: u-boot-v2.git/arch/arm/lib/Makefile =================================================================== --- u-boot-v2.git.orig/arch/arm/lib/Makefile 2008-06-19 00:52:51.000000000 -0500 +++ u-boot-v2.git/arch/arm/lib/Makefile 2008-06-19 00:54:17.000000000 -0500 @@ -8,6 +8,7 @@ obj-y += _udivsi3.o obj-y += _umodsi3.o obj-y += _lshrdi3.o +obj-y += findbit.o obj-y += arm.o obj-$(CONFIG_MODULES) += module.o extra-$(CONFIG_GENERIC_LINKER_SCRIPT) += u-boot.lds Index: u-boot-v2.git/arch/arm/lib/findbit.S =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/lib/findbit.S 2008-06-19 00:54:17.000000000 -0500 @@ -0,0 +1,181 @@ +/** + * @file + * @brief common bitops + */ +/* + * Originally from Linux kernel + * arch/arm/lib/findbit.S + * + * Copyright (C) 1995-2000 Russell King + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * 16th March 2001 - John Ripley jripley@sonicblue.com + * Fixed so that "size" is an exclusive not an inclusive quantity. + * All users of these functions expect exclusive sizes, and may + * also call with zero size. + * Reworked by rmk. + */ + .text + +/* + * Purpose : Find a 'zero' bit + * Prototype: int find_first_zero_bit(void *addr, unsigned int maxbit); + */ + .globl _find_first_zero_bit_le; +_find_first_zero_bit_le: + teq r1, #0 + beq 3f + mov r2, #0 +1: ldrb r3, [r0, r2, lsr #3] + eors r3, r3, #0xff @ invert bits + bne .L_found @ any now set - found zero bit + add r2, r2, #8 @ next bit pointer +2: cmp r2, r1 @ any more? + blo 1b +3: mov r0, r1 @ no free bits + mov pc, lr + +/* + * Purpose : Find next 'zero' bit + * Prototype: int find_next_zero_bit(void *addr, unsigned int maxbit, + * int offset) + */ + .globl _find_next_zero_bit_le; +_find_next_zero_bit_le: + teq r1, #0 + beq 3b + ands ip, r2, #7 + beq 1b @ If new byte, goto old routine + ldrb r3, [r0, r2, lsr #3] + eor r3, r3, #0xff @ now looking for a 1 bit + movs r3, r3, lsr ip @ shift off unused bits + bne .L_found + orr r2, r2, #7 @ if zero, then no bits here + add r2, r2, #1 @ align bit pointer + b 2b @ loop for next bit + +/* + * Purpose : Find a 'one' bit + * Prototype: int find_first_bit(const unsigned long *addr, unsigned int maxbit) + */ + .globl _find_first_bit_le; +_find_first_bit_le: + teq r1, #0 + beq 3f + mov r2, #0 +1: ldrb r3, [r0, r2, lsr #3] + movs r3, r3 + bne .L_found @ any now set - found zero bit + add r2, r2, #8 @ next bit pointer +2: cmp r2, r1 @ any more? + blo 1b +3: mov r0, r1 @ no free bits + mov pc, lr + +/* + * Purpose : Find next 'one' bit + * Prototype: int find_next_zero_bit(void *addr, unsigned int maxbit, + * int offset) + */ + .globl _find_next_bit_le; +_find_next_bit_le: + teq r1, #0 + beq 3b + ands ip, r2, #7 + beq 1b @ If new byte, goto old routine + ldrb r3, [r0, r2, lsr #3] + movs r3, r3, lsr ip @ shift off unused bits + bne .L_found + orr r2, r2, #7 @ if zero, then no bits here + add r2, r2, #1 @ align bit pointer + b 2b @ loop for next bit + +#ifdef __ARMEB__ + + .globl _find_first_zero_bit_be; +_find_first_zero_bit_be: + teq r1, #0 + beq 3f + mov r2, #0 +1: eor r3, r2, #0x18 @ big endian byte ordering + ldrb r3, [r0, r3, lsr #3] + eors r3, r3, #0xff @ invert bits + bne .L_found @ any now set - found zero bit + add r2, r2, #8 @ next bit pointer +2: cmp r2, r1 @ any more? + blo 1b +3: mov r0, r1 @ no free bits + mov pc, lr + + .globl _find_next_zero_bit_be; +_find_next_zero_bit_be: + teq r1, #0 + beq 3b + ands ip, r2, #7 + beq 1b @ If new byte, goto old routine + eor r3, r2, #0x18 @ big endian byte ordering + ldrb r3, [r0, r3, lsr #3] + eor r3, r3, #0xff @ now looking for a 1 bit + movs r3, r3, lsr ip @ shift off unused bits + bne .L_found + orr r2, r2, #7 @ if zero, then no bits here + add r2, r2, #1 @ align bit pointer + b 2b @ loop for next bit + + .globl _find_first_bit_be; +_find_first_bit_be: + teq r1, #0 + beq 3f + mov r2, #0 +1: eor r3, r2, #0x18 @ big endian byte ordering + ldrb r3, [r0, r3, lsr #3] + movs r3, r3 + bne .L_found @ any now set - found zero bit + add r2, r2, #8 @ next bit pointer +2: cmp r2, r1 @ any more? + blo 1b +3: mov r0, r1 @ no free bits + mov pc, lr + + .globl _find_next_bit_be; +_find_next_bit_be: + teq r1, #0 + beq 3b + ands ip, r2, #7 + beq 1b @ If new byte, goto old routine + eor r3, r2, #0x18 @ big endian byte ordering + ldrb r3, [r0, r3, lsr #3] + movs r3, r3, lsr ip @ shift off unused bits + bne .L_found + orr r2, r2, #7 @ if zero, then no bits here + add r2, r2, #1 @ align bit pointer + b 2b @ loop for next bit + +#endif + +/* + * One or more bits in the LSB of r3 are assumed to be set. + */ +.L_found: +#if __LINUX_ARM_ARCH__ >= 5 + rsb r1, r3, #0 + and r3, r3, r1 + clz r3, r3 + rsb r3, r3, #31 + add r0, r2, r3 +#else + tst r3, #0x0f + addeq r2, r2, #4 + movne r3, r3, lsl #4 + tst r3, #0x30 + addeq r2, r2, #2 + movne r3, r3, lsl #2 + tst r3, #0x40 + addeq r2, r2, #1 + mov r0, r2 +#endif + mov pc, lr + Index: u-boot-v2.git/include/asm-arm/bitops.h =================================================================== --- u-boot-v2.git.orig/include/asm-arm/bitops.h 2008-06-19 00:52:51.000000000 -0500 +++ u-boot-v2.git/include/asm-arm/bitops.h 2008-06-19 00:54:30.000000000 -0500 @@ -15,32 +15,28 @@ #ifndef __ASM_ARM_BITOPS_H #define __ASM_ARM_BITOPS_H
+#ifndef _LINUX_BITOPS_H +#error only <linux/bitops.h> can be included directly +#endif + /* - * Function prototypes to keep gcc -Wall happy. + * Functions equivalent of ops.h */ -extern void set_bit(int nr, volatile void * addr); - static inline void __set_bit(int nr, volatile void *addr) { ((unsigned char *) addr)[nr >> 3] |= (1U << (nr & 7)); }
-extern void clear_bit(int nr, volatile void * addr); - static inline void __clear_bit(int nr, volatile void *addr) { ((unsigned char *) addr)[nr >> 3] &= ~(1U << (nr & 7)); }
-extern void change_bit(int nr, volatile void * addr); - static inline void __change_bit(int nr, volatile void *addr) { ((unsigned char *) addr)[nr >> 3] ^= (1U << (nr & 7)); }
-extern int test_and_set_bit(int nr, volatile void * addr); - static inline int __test_and_set_bit(int nr, volatile void *addr) { unsigned int mask = 1 << (nr & 7); @@ -51,8 +47,6 @@ return oldval & mask; }
-extern int test_and_clear_bit(int nr, volatile void * addr); - static inline int __test_and_clear_bit(int nr, volatile void *addr) { unsigned int mask = 1 << (nr & 7); @@ -63,8 +57,6 @@ return oldval & mask; }
-extern int test_and_change_bit(int nr, volatile void * addr); - static inline int __test_and_change_bit(int nr, volatile void *addr) { unsigned int mask = 1 << (nr & 7); @@ -75,9 +67,6 @@ return oldval & mask; }
-extern int find_first_zero_bit(void * addr, unsigned size); -extern int find_next_zero_bit(void * addr, int size, int offset); - /* * This routine doesn't need to be atomic. */ @@ -86,6 +75,48 @@ return ((unsigned char *) addr)[nr >> 3] & (1U << (nr & 7)); }
+#define set_bit(x, y) __set_bit(x, y) +#define clear_bit(x, y) __clear_bit(x, y) +#define change_bit(x, y) __change_bit(x, y) +#define test_and_set_bit(x, y) __test_and_set_bit(x, y) +#define test_and_clear_bit(x, y) __test_and_clear_bit(x, y) +#define test_and_change_bit(x, y) __test_and_change_bit(x, y) + +#ifndef __ARMEB__ +/* + * These are the little endian definitions. + */ +extern int _find_first_zero_bit_le(const void *p, unsigned size); +extern int _find_next_zero_bit_le(const void *p, int size, int offset); +extern int _find_first_bit_le(const unsigned long *p, unsigned size); +extern int _find_next_bit_le(const unsigned long *p, int size, int offset); +#define find_first_zero_bit(p, sz) _find_first_zero_bit_le(p, sz) +#define find_next_zero_bit(p, sz, off) _find_next_zero_bit_le(p, sz, off) +#define find_first_bit(p, sz) _find_first_bit_le(p, sz) +#define find_next_bit(p, sz, off) _find_next_bit_le(p, sz, off) + +#define WORD_BITOFF_TO_LE(x) ((x)) + +#else /* ! __ARMEB__ */ + +/* + * These are the big endian definitions. + */ +extern int _find_first_zero_bit_be(const void *p, unsigned size); +extern int _find_next_zero_bit_be(const void *p, int size, int offset); +extern int _find_first_bit_be(const unsigned long *p, unsigned size); +extern int _find_next_bit_be(const unsigned long *p, int size, int offset); +#define find_first_zero_bit(p, sz) _find_first_zero_bit_be(p, sz) +#define find_next_zero_bit(p, sz, off) _find_next_zero_bit_be(p, sz, off) +#define find_first_bit(p, sz) _find_first_bit_be(p, sz) +#define find_next_bit(p, sz, off) _find_next_bit_be(p, sz, off) + +#define WORD_BITOFF_TO_LE(x) ((x) ^ 0x18) + +#endif /* __ARMEB__ */ + +#if defined(__LINUX_ARM_ARCH__) && (__LINUX_ARM_ARCH__ < 5) + /* * ffz = Find First Zero in word. Undefined if no zero exists, * so code should check against ~0UL first.. @@ -103,35 +134,53 @@ if (word & 0x40000000) { k -= 1; } return k; } +#include <asm-generic/bitops/__ffs.h> +#include <asm-generic/bitops/ffs.h> +#include <asm-generic/bitops/fls.h> +#else /* ! __ARM__USE_GENERIC_FF */ + +static inline int constant_fls(int x) +{ + int r = 32; + + if (!x) + return 0; + if (!(x & 0xffff0000u)) { + x <<= 16; + r -= 16; + } + if (!(x & 0xff000000u)) { + x <<= 8; + r -= 8; + } + if (!(x & 0xf0000000u)) { + x <<= 4; + r -= 4; + } + if (!(x & 0xc0000000u)) { + x <<= 2; + r -= 2; + } + if (!(x & 0x80000000u)) { + x <<= 1; + r -= 1; + } + return r; +}
/* - * ffs: find first bit set. This is defined the same way as - * the libc and compiler builtin ffs routines, therefore - * differs in spirit from the above ffz (man ffs). - */ - -#define ffs(x) generic_ffs(x) - -/* - * hweightN: returns the hamming weight (i.e. the number - * of bits set) of a N-bit word + * On ARMv5 and above those functions can be implemented around + * the clz instruction for much better code efficiency. */ +#define fls(x) \ + (__builtin_constant_p(x) ? constant_fls(x) : \ + ({ int __r; asm("clz\t%0, %1" : "=r"(__r) : "r"(x) : "cc"); 32-__r; })) +#define ffs(x) ({ unsigned long __t = (x); fls(__t &-__t); }) +#define __ffs(x) (ffs(x) - 1) +#define ffz(x) __ffs(~(x)) +#endif /* __ARM__USE_GENERIC_FF */ +#include <asm-generic/bitops/fls64.h>
-#define hweight32(x) generic_hweight32(x) -#define hweight16(x) generic_hweight16(x) -#define hweight8(x) generic_hweight8(x) - -#define ext2_set_bit test_and_set_bit -#define ext2_clear_bit test_and_clear_bit -#define ext2_test_bit test_bit -#define ext2_find_first_zero_bit find_first_zero_bit -#define ext2_find_next_zero_bit find_next_zero_bit - -/* Bitmap functions for the minix filesystem. */ -#define minix_test_and_set_bit(nr,addr) test_and_set_bit(nr,addr) -#define minix_set_bit(nr,addr) set_bit(nr,addr) -#define minix_test_and_clear_bit(nr,addr) test_and_clear_bit(nr,addr) -#define minix_test_bit(nr,addr) test_bit(nr,addr) -#define minix_find_first_zero_bit(addr,size) find_first_zero_bit(addr,size) +#include <asm-generic/bitops/hweight.h>
#endif /* _ARM_BITOPS_H */
Use the asm-generic/bitops/xyz.h instead of using generic_xyz functions.
--- include/asm-blackfin/bitops.h | 18 +--------- include/asm-m68k/bitops.h | 18 +--------- include/asm-ppc/bitops.h | 9 ----- include/linux/bitops.h | 71 ++++-------------------------------------- 4 files changed, 12 insertions(+), 104 deletions(-)
Index: u-boot-v2.git/include/asm-blackfin/bitops.h =================================================================== --- u-boot-v2.git.orig/include/asm-blackfin/bitops.h 2008-06-19 00:50:37.000000000 -0500 +++ u-boot-v2.git/include/asm-blackfin/bitops.h 2008-06-19 00:51:52.000000000 -0500 @@ -268,22 +268,8 @@ return result + ffz(tmp); }
-/* - * ffs: find first bit set. This is defined the same way as - * the libc and compiler builtin ffs routines, therefore - * differs in spirit from the above ffz (man ffs). - */ - -#define ffs(x) generic_ffs(x) - -/* - * hweightN: returns the hamming weight (i.e. the number - * of bits set) of a N-bit word - */ - -#define hweight32(x) generic_hweight32(x) -#define hweight16(x) generic_hweight16(x) -#define hweight8(x) generic_hweight8(x) +#include <asm-generic/bitops/ffs.h> +#include <asm-generic/bitops/hweight.h>
static __inline__ int ext2_set_bit(int nr, volatile void *addr) { Index: u-boot-v2.git/include/asm-m68k/bitops.h =================================================================== --- u-boot-v2.git.orig/include/asm-m68k/bitops.h 2008-06-19 00:50:13.000000000 -0500 +++ u-boot-v2.git/include/asm-m68k/bitops.h 2008-06-19 00:51:52.000000000 -0500 @@ -122,22 +122,8 @@ return k; }
#define ext2_set_bit test_and_set_bit #define ext2_clear_bit test_and_clear_bit Index: u-boot-v2.git/include/linux/bitops.h =================================================================== --- u-boot-v2.git.orig/include/linux/bitops.h 2008-06-19 00:50:13.000000000 -0500 +++ u-boot-v2.git/include/linux/bitops.h 2008-06-19 00:52:34.000000000 -0500 @@ -1,70 +1,13 @@ #ifndef _LINUX_BITOPS_H #define _LINUX_BITOPS_H
- -/* - * ffs: find first bit set. This is defined the same way as - * the libc and compiler builtin ffs routines, therefore - * differs in spirit from the above ffz (man ffs). - */ - -static inline int generic_ffs(int x) -{ - int r = 1; - - if (!x) - return 0; - if (!(x & 0xffff)) { - x >>= 16; - r += 16; - } - if (!(x & 0xff)) { - x >>= 8; - r += 8; - } - if (!(x & 0xf)) { - x >>= 4; - r += 4; - } - if (!(x & 3)) { - x >>= 2; - r += 2; - } - if (!(x & 1)) { - x >>= 1; - r += 1; - } - return r; -} - -/* - * hweightN: returns the hamming weight (i.e. the number - * of bits set) of a N-bit word - */ - -static inline unsigned int generic_hweight32(unsigned int w) -{ - unsigned int res = (w & 0x55555555) + ((w >> 1) & 0x55555555); - res = (res & 0x33333333) + ((res >> 2) & 0x33333333); - res = (res & 0x0F0F0F0F) + ((res >> 4) & 0x0F0F0F0F); - res = (res & 0x00FF00FF) + ((res >> 8) & 0x00FF00FF); - return (res & 0x0000FFFF) + ((res >> 16) & 0x0000FFFF); -} - -static inline unsigned int generic_hweight16(unsigned int w) -{ - unsigned int res = (w & 0x5555) + ((w >> 1) & 0x5555); - res = (res & 0x3333) + ((res >> 2) & 0x3333); - res = (res & 0x0F0F) + ((res >> 4) & 0x0F0F); - return (res & 0x00FF) + ((res >> 8) & 0x00FF); -} - -static inline unsigned int generic_hweight8(unsigned int w) -{ - unsigned int res = (w & 0x55) + ((w >> 1) & 0x55); - res = (res & 0x33) + ((res >> 2) & 0x33); - return (res & 0x0F) + ((res >> 4) & 0x0F); -} +#ifdef __U_BOOT__ +#define BIT(nr) (1UL << (nr)) +#define BIT_MASK(nr) (1UL << ((nr) % BITS_PER_LONG)) +#define BIT_WORD(nr) ((nr) / BITS_PER_LONG) +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) +#endif
#include <asm/bitops.h>
Index: u-boot-v2.git/include/asm-ppc/bitops.h =================================================================== --- u-boot-v2.git.orig/include/asm-ppc/bitops.h 2008-06-19 00:50:37.000000000 -0500 +++ u-boot-v2.git/include/asm-ppc/bitops.h 2008-06-19 00:51:52.000000000 -0500 @@ -178,14 +178,7 @@ return __ilog2(x & -x) + 1; }
-/* - * hweightN: returns the hamming weight (i.e. the number - * of bits set) of a N-bit word - */ - -#define hweight32(x) generic_hweight32(x) -#define hweight16(x) generic_hweight16(x) -#define hweight8(x) generic_hweight8(x) +#include <asm-generic/bitops/hweight.h>
#endif /* __U_BOOT__ */
Jon Loeliger
Menon, Nishanth
Sascha Hauer
