[U-Boot] [patch 2/2] Add support for building the new U-boot uImage format (FIT-format)
Allow building of the newer FIT-image format for U-boot, while keeping it possible to build the legacy format, for people who do not want to (or can) upgrade to U-boot 1.3.3 or newer.
If an older mkimage is detected, or if there is no dtc (Device Tree Compiler) then automagically the legacy format is created. There is also a possibility to force the legacy format by means of a Kconfig option.
Note: This patch only adapts this for ARM, AVR32, Blackfin and sh architectures. It does not adapt the PowerPC tree, because PowerPC does not use the script at scripts/mkuboot.sh
Signed-off-by: Remy Bohmer linux@bohmer.net --- arch/arm/Kconfig | 10 ++ arch/arm/boot/Makefile | 10 ++ arch/avr32/Kconfig | 14 ++++ arch/avr32/boot/images/Makefile | 8 ++ arch/blackfin/Kconfig | 10 ++ arch/blackfin/boot/Makefile | 8 ++ arch/sh/Kconfig | 10 ++ arch/sh/boot/Makefile | 8 ++ scripts/mkuboot.sh | 140 ++++++++++++++++++++++++++++++++++++++-- 9 files changed, 209 insertions(+), 9 deletions(-)
Index: linux-2.6.27-rc4/arch/arm/Kconfig =================================================================== --- linux-2.6.27-rc4.orig/arch/arm/Kconfig 2008-08-25 20:58:36.000000000 +0200 +++ linux-2.6.27-rc4/arch/arm/Kconfig 2008-08-25 20:58:40.000000000 +0200 @@ -977,6 +977,16 @@ config UNCOMPRESSED_UIMAGE
If unsure, say N.
+config LEGACY_UIMAGE + bool "Use legacy format for building uImage" + default n + help + Enable this option if you want uImage to be build in the legacy + format. If this option is 'N' the uImage will be build in the newer + FIT-image format. (Needs at least 'mkimage v1.3.3', and 'dtc v1.2.0') + + If unsure, say N. + config XIP_PHYS_ADDR hex "XIP Kernel Physical Location" depends on XIP_KERNEL Index: linux-2.6.27-rc4/arch/arm/boot/Makefile =================================================================== --- linux-2.6.27-rc4.orig/arch/arm/boot/Makefile 2008-08-25 20:58:36.000000000 +0200 +++ linux-2.6.27-rc4/arch/arm/boot/Makefile 2008-08-25 20:58:40.000000000 +0200 @@ -59,10 +59,16 @@ $(obj)/zImage: $(obj)/compressed/vmlinux
endif
+ifeq ($(CONFIG_LEGACY_UIMAGE),y) +UIMAGE_FORMAT=legacy +else +UIMAGE_FORMAT=fit +endif + quiet_cmd_uimage = UIMAGE $@ cmd_uimage = $(CONFIG_SHELL) $(MKIMAGE) -A arm -O linux -T kernel \ - -C none -a $(LOADADDR) -e $(LOADADDR) \ - -n 'Linux-$(KERNELRELEASE)' -d $< $@ + -C none -a $(LOADADDR) -e $(LOADADDR) -l $(UIMAGE_FORMAT) \ + -n 'Linux-$(KERNELRELEASE)' -d $< -i $@
ifeq ($(CONFIG_ZBOOT_ROM),y) $(obj)/uImage: LOADADDR=$(CONFIG_ZBOOT_ROM_TEXT) Index: linux-2.6.27-rc4/scripts/mkuboot.sh =================================================================== --- linux-2.6.27-rc4.orig/scripts/mkuboot.sh 2008-08-25 20:58:33.000000000 +0200 +++ linux-2.6.27-rc4/scripts/mkuboot.sh 2008-08-25 21:07:06.000000000 +0200 @@ -1,19 +1,151 @@ #!/bin/bash - # # Build U-Boot image when `mkimage' tool is available. +# Check also if dtc exist and has the right version (at least v 1.2.0) +# +# 25 Aug 2008: Remy Bohmer linux@bohmer.net, +# Added support for FIT and legacy uImages #
MKIMAGE=$(type -path "${CROSS_COMPILE}mkimage") +DTC=$(type -path "${CROSS_COMPILE}dtc") + +function usage () { + echo "Usage: `basename $0` -A arch -O os -T type -C comp -a addr" + echo " -e ep -l <legacy|fit> -n name " + echo " -d data_file[:data_file...] -i image" + echo " -A ==> set architecture to 'arch'" + echo " -O ==> set operating system to 'os'" + echo " -T ==> set image type to 'type'" + echo " -C ==> set compression type 'comp'" + echo " -a ==> set load address to 'addr' (hex)" + echo " -e ==> set entry point to 'ep' (hex)" + echo " -l ==> uImage format type <legacy|fit>" + echo " -n ==> set image name to 'name'" + echo " -d ==> use image data from 'datafile'" + echo " -i ==> destination image" + exit 1 +} + +OPT_CNT=0 +OPT_MASK=0 +function track_opt () { + let OPT_CNT=${OPT_CNT}+1 + let OPT_MASK=${OPT_MASK}+$1 +} + +function gen_tmp_specfile () { +rm -f $1 +cat > $1 << EOF +/ { + description = "kernel ${NAME}"; + #address-cells = <1>; + + images { + kernel@1 { + description = "Linux Kernel"; + data = /incbin/("$(basename ${DATA})"); + type = "${TYPE}"; + arch = "${ARCH}"; + os = "${OS}"; + compression = "${COMPRESS}"; + load = <${LOADADDR}>; + entry = <${ENTRY}>; + hash@1 { + algo = "crc32"; + }; + hash@2 { + algo = "sha1"; + }; + }; + }; + + configurations { + default = "config@1"; + config@1 { + description = "Boot Linux kernel"; + kernel = "kernel@1"; + }; + }; +}; +EOF +} + +# +# Parse command line +# +while getopts ":A:O:T:C:a:e:l:n:d:i:" Option +do + case $Option in + A ) track_opt 1 ; ARCH=$OPTARG;; + O ) track_opt 2 ; OS=$OPTARG;; + T ) track_opt 4 ; TYPE=$OPTARG;; + C ) track_opt 8 ; COMPRESS=$OPTARG;; + a ) track_opt 16 ; LOADADDR=$OPTARG;; + e ) track_opt 32 ; ENTRY=$OPTARG;; + l ) track_opt 64 ; UIMAGE_FORMAT=$OPTARG;; + n ) track_opt 128; NAME=$OPTARG;; + d ) track_opt 256; DATA=$OPTARG;; + i ) track_opt 512; IMAGE=$OPTARG;; + * ) echo "Invalid option passed to '$0' (options:$@)" + usage;; + esac +done + +# strip off the 0x from the LOADADDR and ENTRY (if exists) +LOADADDR=$(echo "${LOADADDR}" | sed s@'0x'@''@g) +ENTRY=$(echo "${ENTRY}" | sed s@'0x'@''@g) + +# All arguments available ? +if [ ${OPT_CNT} -ne 10 -o ${OPT_MASK} -ne 1023 ]; then + usage +fi
if [ -z "${MKIMAGE}" ]; then MKIMAGE=$(type -path mkimage) if [ -z "${MKIMAGE}" ]; then # Doesn't exist - echo '"mkimage" command not found - U-Boot images will not be built' >&2 + echo '"mkimage" command not found' >&2 + echo '--> U-Boot images will not be built' >&2 exit 0; fi fi
-# Call "mkimage" to create U-Boot image -${MKIMAGE} "$@" +if [ "${UIMAGE_FORMAT}" != "legacy" ]; then + if [ "x$(${MKIMAGE} 2>&1 | grep '-f')" = "x" ]; then + echo "'${MKIMAGE}' does not support FIT images" >&2 + echo "Building legacy U-Boot image..." >&2 + UIMAGE_FORMAT=legacy + fi +fi + +if [ "${UIMAGE_FORMAT}" != "legacy" ]; then + # for building FIT images we need the device tree compiler + if [ -z "${DTC}" ]; then + DTC=$(type -path dtc) + if [ -z "${DTC}" ]; then + # Doesn't exist + echo '"dtc" command not found' >&2 + echo '--> Can only built legacy U-Boot images' >&2 + UIMAGE_FORMAT=legacy + else + DTC_VER=$(dtc -v | cut -d' ' -f3 | sed s@'.'@''@g) + if [ ${DTC_VER} -lt 120 ]; then + echo '"dtc" must be at least version 1.2.0' >&2 + echo '-->Can only built legacy U-Boot images'>&2 + UIMAGE_FORMAT=legacy + fi + fi + fi +fi + +if [ "${UIMAGE_FORMAT}" = "legacy" ]; then + # Call "mkimage" in the legacy mode to create U-Boot image + ${MKIMAGE} -A ${ARCH} -O ${OS} -T ${TYPE} \ + -C ${COMPRESS} -a 0x${LOADADDR} -e 0x${ENTRY} \ + -n "${NAME}" -d ${DATA} ${IMAGE} +else + # Call "mkimage" in the FIT mode to create U-Boot image + gen_tmp_specfile ${IMAGE}.its + ${MKIMAGE} -f ${IMAGE}.its ${IMAGE} +fi Index: linux-2.6.27-rc4/arch/blackfin/Kconfig =================================================================== --- linux-2.6.27-rc4.orig/arch/blackfin/Kconfig 2008-08-25 20:58:33.000000000 +0200 +++ linux-2.6.27-rc4/arch/blackfin/Kconfig 2008-08-25 20:58:40.000000000 +0200 @@ -286,6 +286,16 @@ config BOOT_LOAD memory region is used to capture NULL pointer references as well as some core kernel functions.
+config LEGACY_UIMAGE + bool "Use legacy format for building uImage" + default n + help + Enable this option if you want uImage to be build in the legacy + format. If this option is 'N' the uImage will be build in the newer + FIT-image format. (Needs at least 'mkimage v1.3.3', and 'dtc v1.2.0') + + If unsure, say N. + comment "Clock/PLL Setup"
config CLKIN_HZ Index: linux-2.6.27-rc4/arch/blackfin/boot/Makefile =================================================================== --- linux-2.6.27-rc4.orig/arch/blackfin/boot/Makefile 2008-08-25 20:58:33.000000000 +0200 +++ linux-2.6.27-rc4/arch/blackfin/boot/Makefile 2008-08-25 20:58:40.000000000 +0200 @@ -11,11 +11,17 @@ MKIMAGE := $(srctree)/scripts/mkuboot.sh targets := vmImage extra-y += vmlinux.bin vmlinux.gz
+ifeq ($(CONFIG_LEGACY_UIMAGE),y) +UIMAGE_FORMAT=legacy +else +UIMAGE_FORMAT=fit +endif + quiet_cmd_uimage = UIMAGE $@ cmd_uimage = $(CONFIG_SHELL) $(MKIMAGE) -A $(ARCH) -O linux -T kernel \ -C gzip -n 'Linux-$(KERNELRELEASE)' -a $(CONFIG_BOOT_LOAD) \ -e $(shell $(NM) vmlinux | awk '$$NF == "__start" {print $$1}') \ - -d $< $@ + -l $(UIMAGE_FORMAT) -d $< -i $@
$(obj)/vmlinux.bin: vmlinux FORCE $(call if_changed,objcopy) Index: linux-2.6.27-rc4/arch/avr32/Kconfig =================================================================== --- linux-2.6.27-rc4.orig/arch/avr32/Kconfig 2008-08-25 20:58:33.000000000 +0200 +++ linux-2.6.27-rc4/arch/avr32/Kconfig 2008-08-25 20:58:40.000000000 +0200 @@ -147,6 +147,20 @@ config PHYS_OFFSET hex default 0x10000000 if CPU_AT32AP700X=y
+if LOADER_U_BOOT + +config LEGACY_UIMAGE + bool "Use legacy format for building uImage" + default n + help + Enable this option if you want uImage to be build in the legacy + format. If this option is 'N' the uImage will be build in the newer + FIT-image format. (Needs at least 'mkimage v1.3.3', and 'dtc v1.2.0') + + If unsure, say N. + +endif + source "kernel/Kconfig.preempt"
config QUICKLIST Index: linux-2.6.27-rc4/arch/avr32/boot/images/Makefile =================================================================== --- linux-2.6.27-rc4.orig/arch/avr32/boot/images/Makefile 2008-08-25 20:58:33.000000000 +0200 +++ linux-2.6.27-rc4/arch/avr32/boot/images/Makefile 2008-08-25 20:58:40.000000000 +0200 @@ -17,10 +17,16 @@ $(obj)/vmlinux.bin: vmlinux FORCE $(obj)/vmlinux.gz: $(obj)/vmlinux.bin FORCE $(call if_changed,gzip)
+ifeq ($(CONFIG_LEGACY_UIMAGE),y) +UIMAGE_FORMAT=legacy +else +UIMAGE_FORMAT=fit +endif + quiet_cmd_uimage = UIMAGE $@ cmd_uimage = $(CONFIG_SHELL) $(MKIMAGE) -A avr32 -O linux -T kernel \ -C gzip -a $(CONFIG_LOAD_ADDRESS) -e $(CONFIG_ENTRY_ADDRESS) \ - -n 'Linux-$(KERNELRELEASE)' -d $< $@ + -l $(UIMAGE_FORMAT) -n 'Linux-$(KERNELRELEASE)' -d $< -i $@
targets += uImage uImage.srec $(obj)/uImage: $(obj)/vmlinux.gz Index: linux-2.6.27-rc4/arch/sh/Kconfig =================================================================== --- linux-2.6.27-rc4.orig/arch/sh/Kconfig 2008-08-25 20:58:33.000000000 +0200 +++ linux-2.6.27-rc4/arch/sh/Kconfig 2008-08-25 20:58:40.000000000 +0200 @@ -607,6 +607,16 @@ config CMDLINE depends on CMDLINE_BOOL default "console=ttySC1,115200"
+config LEGACY_UIMAGE + bool "Use legacy format for building uImage" + default n + help + Enable this option if you want uImage to be build in the legacy + format. If this option is 'N' the uImage will be build in the newer + FIT-image format. (Needs at least 'mkimage v1.3.3', and 'dtc v1.2.0') + + If unsure, say N. + endmenu
menu "Bus options" Index: linux-2.6.27-rc4/arch/sh/boot/Makefile =================================================================== --- linux-2.6.27-rc4.orig/arch/sh/boot/Makefile 2008-08-25 20:58:33.000000000 +0200 +++ linux-2.6.27-rc4/arch/sh/boot/Makefile 2008-08-25 20:58:40.000000000 +0200 @@ -43,10 +43,16 @@ KERNEL_ENTRY := $(shell /bin/bash -c 'pr $(CONFIG_MEMORY_START) + \ $(CONFIG_ZERO_PAGE_OFFSET) + $(CONFIG_ENTRY_OFFSET)]')
+ifeq ($(CONFIG_LEGACY_UIMAGE),y) +UIMAGE_FORMAT=legacy +else +UIMAGE_FORMAT=fit +endif + quiet_cmd_uimage = UIMAGE $@ cmd_uimage = $(CONFIG_SHELL) $(MKIMAGE) -A sh -O linux -T kernel \ -C gzip -a $(KERNEL_LOAD) -e $(KERNEL_ENTRY) \ - -n 'Linux-$(KERNELRELEASE)' -d $< $@ + -l $(UIMAGE_FORMAT) -n 'Linux-$(KERNELRELEASE)' -d $< -i $@
$(obj)/uImage: $(obj)/vmlinux.bin.gz FORCE $(call if_changed,uimage)
Dear Remy,
Why should there ever be no dtc? It is part of the Linux kernel source tree, see arch/powerpc/boot/dtc-src
As before, I think this should not be implemented as a configuration option; it should be selectable as separate make targets without need to reconfigure / rebuild the kernel.
Hm... Power support would be especially interesting, of course :-)
Hello Wolfgang,
uuh, because it was not there in 2.6.24...? And that was the kernel I made the patch for originally...
Will look into (all) your comments. Thanks,
Remy
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Without facts, the decision cannot be made logically. You must rely on your human intuition. -- Spock, "Assignment: Earth", stardate unknown
Hello Wolfgang,
Okay, I see it is there in 2.6.27-rc, but the version there is pre historical, and definitely in the wrong location, because it is not PowerPC only anymore. It does not support the incbin directive, so it cannot be used to build a uImage. We need at least version 1.2.0 of DTC.
I agree if you are talking about the other patch which was about choosing between compressed image yes/no; related to the current make targets they should indeed be similar to Image/zImage. I made it configurable because that saved me some time adapting the build-tooling for the target-filesystem. (and thought it could be handy for others too)
But, for this patch I disagree, I do not think it should be separate make targets, because it is choosing between a legacy and a new image file format. Legacy means that it is old and should go away some time. When it comes to functionality it will behave the same like the old uImage (on no-powerpc architectures at least), so creating a new filename as make-target would imply all tools that depend on the target name uImage should be adapted to a new name, when there is no new functionality, resulting in a very long time before the new format because 'the standard'. Not to speak about documentation issues. IMO it is a replacement, not just an additional format.
I knew that, that is why I added this note... But I do not have PowerPC systems (except my PS3, or Qemu) so it is not easy to test any modifications in that area, and there is a risk of breaking things. Besides, if I look at how I believe things are done for PowerPC, it can easily be added to the mkuboot.sh script, once it knows about the FIT format, and the proper tools are available. I may look at that later, when I have more free (hobby) time.
Kind Regards,
Remy
Remy Bohmer
