[U-Boot] [PATCH v2 00/35] zynq: More boards support
These changes are from u-boot-xlnx.git repo from git.xilinx.com This repo is well tested on xilinx zynq platform, hence pushing the same on upstream.
-- Thanks, Jagan.
Jagannadha Sutradharudu Teki (35): zynq: Enable CONFIG_FIT_VERBOSE zynq: Enable Boot FreeBSD/vxWorks zynq: Cleanup on miscellaneous configs zynq: Cleanup on memory configs zynq: Minor config cleanup zynq: Enable cache options zynq: Add UART0, UART1 configs support zynq: Add GEM0, GEM1 configs support zynq-common: Rename zynq with zynq-common zynq: Add support to find bootmode spi: Add zynq qspi controller driver zynq-common: Enable CONFIG_ZYNQ_QSPI zynq: Add zynq zc70x board support zynq: Add zynq zed board support zynq-common: Define CONFIG_SPI_FLASH_BAR zynq: Move CONFIG_SYS_SDRAM_SIZE to pre-board configs zynq-common: Define exact TEXT_BASE zynq: zc70x: Add Catalyst 24WC08 EEPROM config support zynq: Add zynq microzed board support zynq: Add zynq_zc770 xm010 board support zynq: Add zynq_zc770 xm013 board support zynq: Add zynq_zc770 xm012 board support nand: Add zynq nand controller driver support zynq-common: Define CONFIG_NAND_ZYNQ zynq: Add zynq_zc770 xm011 board support zynq: Add support to find bootmode zynq-common: Define default environment zynq-common: Change Env. Sector size to 128Kb zynq-common: Define flash env. partition zynq-common: Define CONFIG_ENV_OVERWRITE dts: zynq: Add basic fdt support gpio: zynq: Add dummy gpio routines zynq-common: Enable verified boot(RSA) dts: zynq: Add more zynq dts files doc: Update the zynq u-boot status
README | 4 + arch/arm/cpu/armv7/zynq/slcr.c | 6 + arch/arm/dts/zynq-7000.dtsi | 13 + arch/arm/include/asm/arch-zynq/gpio.h | 25 + arch/arm/include/asm/arch-zynq/hardware.h | 3 + arch/arm/include/asm/arch-zynq/sys_proto.h | 1 + board/xilinx/dts/zynq-microzed.dts | 14 + board/xilinx/dts/zynq-zc702.dts | 14 + board/xilinx/dts/zynq-zc706.dts | 14 + board/xilinx/dts/zynq-zc770-xm010.dts | 14 + board/xilinx/dts/zynq-zc770-xm011.dts | 14 + board/xilinx/dts/zynq-zc770-xm012.dts | 14 + board/xilinx/dts/zynq-zc770-xm013.dts | 14 + board/xilinx/dts/zynq-zed.dts | 14 + board/xilinx/zynq/board.c | 33 + boards.cfg | 9 +- doc/README.zynq | 92 +++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/zynq_nand.c | 1198 ++++++++++++++++++++++++++++ drivers/spi/Makefile | 1 + drivers/spi/zynq_qspi.c | 449 +++++++++++ include/configs/zynq-common.h | 270 +++++++ include/configs/zynq.h | 139 ---- include/configs/zynq_microzed.h | 26 + include/configs/zynq_zc70x.h | 29 + include/configs/zynq_zc770.h | 44 + include/configs/zynq_zed.h | 27 + 27 files changed, 2341 insertions(+), 141 deletions(-) create mode 100644 arch/arm/dts/zynq-7000.dtsi create mode 100644 arch/arm/include/asm/arch-zynq/gpio.h create mode 100644 board/xilinx/dts/zynq-microzed.dts create mode 100644 board/xilinx/dts/zynq-zc702.dts create mode 100644 board/xilinx/dts/zynq-zc706.dts create mode 100644 board/xilinx/dts/zynq-zc770-xm010.dts create mode 100644 board/xilinx/dts/zynq-zc770-xm011.dts create mode 100644 board/xilinx/dts/zynq-zc770-xm012.dts create mode 100644 board/xilinx/dts/zynq-zc770-xm013.dts create mode 100644 board/xilinx/dts/zynq-zed.dts create mode 100644 doc/README.zynq create mode 100644 drivers/mtd/nand/zynq_nand.c create mode 100644 drivers/spi/zynq_qspi.c create mode 100644 include/configs/zynq-common.h delete mode 100644 include/configs/zynq.h create mode 100644 include/configs/zynq_microzed.h create mode 100644 include/configs/zynq_zc70x.h create mode 100644 include/configs/zynq_zc770.h create mode 100644 include/configs/zynq_zed.h
