[U-Boot] [PATCH] common: Iteration limit for memory test.
We want to use mtest for production memory test (though I know it is not recommended). I implemented an iteration limit, so expect can parse the results.
The iteration limit is passed to mtest as a fourth parameter: [start [end [pattern [iterations]]]] If no fourth parameter is supplied, there is no iteration limit and the test will loop forever.
Signed-off-by: Dirk Eibach eibach@gdsys.de ---
- Modified original patch title "Added optional iteration limit for alternative memory test." - Iteration limit is now implemented for both original and alternative memory test.
common/cmd_mem.c | 29 +++++++++++++++++++++++++---- 1 files changed, 25 insertions(+), 4 deletions(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index d7666c2..f87170c 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -672,6 +672,8 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) ulong val; ulong readback; int rcode = 0; + int iterations = 1; + int iteration_limit;
#if defined(CONFIG_SYS_ALT_MEMTEST) vu_long len; @@ -687,7 +689,6 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) vu_long *dummy = 0; /* yes, this is address 0x0, not NULL */ #endif int j; - int iterations = 1;
static const ulong bitpattern[] = { 0x00000001, /* single bit */ @@ -722,6 +723,12 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) pattern = 0; }
+ if (argc > 4) { + iteration_limit = (ulong)simple_strtoul(argv[4], NULL, 16); + } else { + iteration_limit = 0; + } + #if defined(CONFIG_SYS_ALT_MEMTEST) printf ("Testing %08x ... %08x:\n", (uint)start, (uint)end); PRINTF("%s:%d: start 0x%p end 0x%p\n", @@ -733,6 +740,13 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 1; }
+ + if (iteration_limit && iterations > iteration_limit) { + printf ("Tested %d iteration(s) without errors.\n", + iterations-1); + return 0; + } + printf("Iteration: %6d\r", iterations); PRINTF("Iteration: %6d\n", iterations); iterations++; @@ -926,6 +940,13 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 1; }
+ if (iteration_limit && iterations > iteration_limit) { + printf ("Tested %d iteration(s) without errors.\n", + iterations-1); + return 0; + } + ++iterations; + printf ("\rPattern %08lX Writing..." "%12s" "\b\b\b\b\b\b\b\b\b\b", @@ -1277,9 +1298,9 @@ U_BOOT_CMD( #endif /* CONFIG_LOOPW */
U_BOOT_CMD( - mtest, 4, 1, do_mem_mtest, - "mtest - simple RAM test\n", - "[start [end [pattern]]]\n" + mtest, 5, 1, do_mem_mtest, + "mtest - simple RAM test\n", + "[start [end [pattern [iterations]]]]\n" " - simple RAM read/write test\n" );
Dear Dirk Eibach,
Do you really want to use this text as part of the commit message? Maybe not.
- int iteration_limit;
int iterations = 1;
- if (argc > 4) {
- } else {
No braces for one-line commands, please.
Seems we have some duplicated code here?
U_BOOT_CMD(
- mtest, 5, 1, do_mem_mtest,
Please use here TABs for indentation, as in the original code.
Dirk Eibach
