[U-Boot] [PATCH] u-boot-v2 initrd support for ARM
Hi, here's a small patch to make initrd working on ARM in u-boot-v2.
I use it to boot over the network like this: tftp /tftpboot/kernel.uImage kernel tftp /tftpboot/rootfs.uImage rootfs bootm -r rootfs kernel
I create the rootfs image like this: mkimage -A arm -O linux -T ramdisk -C none -a 0xA0800000 -n rootfs \ -d rootfs.cpio.gz rootfs.uImage (this is for imx27)
regards,
Eric
Signed-off-by: Eric Lammerts eric@lammerts.org
diff --git a/arch/arm/lib/armlinux.c b/arch/arm/lib/armlinux.c index ce86ff8..7d686eb 100644 --- a/arch/arm/lib/armlinux.c +++ b/arch/arm/lib/armlinux.c @@ -68,14 +68,12 @@ static void __setup_memory_tags(void); #define setup_memory_tags() do {} while(0) #endif
-#if 0 #ifdef CONFIG_INITRD_TAG static void __setup_initrd_tag(ulong initrd_start, ulong initrd_end); #define setup_initrd_tag __setup_initrd_tag #else #define setup_initrd_tag(a,b) do {} while(0) #endif -#endif
extern ulong calc_fbsize(void); #if defined (CONFIG_VFD) || defined (CONFIG_LCD) @@ -156,10 +154,8 @@ int do_bootm_linux(struct image_data *data) setup_revision_tag(¶ms); setup_memory_tags(); setup_commandline_tag(commandline); -#if 0 - if (initrd_start && initrd_end) - setup_initrd_tag (initrd_start, initrd_end); -#endif + if (data->initrd->data) + setup_initrd_tag ((ulong)data->initrd->data, (ulong)data->initrd->data + ntohl(data->initrd->header.ih_size)); setup_videolfb_tag((gd_t *) gd); setup_end_tag();
Eric Lammerts
