[PATCH 00/13] EFI: capsule: ti: enable authenticated capsules
Create an EFI signature list (.esl) file based on the TI dummy key. Enable capsule authentication for several TI SoC based platforms: AM64, AM62, AM62p, BeaglePlay, J7, and BeagleboneAI.
Jonathan Humphreys (13): ti:keys Add EFI signature list configs: am64x: Set capsule update signature list file configs: am64x: Enable capsule authentication configs: j721e: Set capsule update signature list file configs: j721e: Enable capsule authentication configs: beagleplay: Set capsule update signature list file configs: beagleplay: Enable capsule authentication configs: am62px: Set capsule update signature list file configs: am62px: Enable capsule authentication configs: am62x: Set capsule update signature list file configs: am62x: Enable capsule authentication configs: beagleboneai64: Set capsule update signature list file configs: beagleboneai64: Enable capsule authentication
arch/arm/mach-k3/keys/custMpk.esl | Bin 0 -> 1523 bytes configs/am62px_evm_a53_defconfig | 2 ++ configs/am62x_beagleplay_a53_defconfig | 2 ++ configs/am62x_evm_a53_defconfig | 2 ++ configs/am64x_evm_a53_defconfig | 2 ++ configs/j721e_beagleboneai64_a72_defconfig | 2 ++ configs/j721e_evm_a72_defconfig | 2 ++ 7 files changed, 12 insertions(+) create mode 100644 arch/arm/mach-k3/keys/custMpk.esl
EFI signature list using TI dummy keys.
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com --- arch/arm/mach-k3/keys/custMpk.esl | Bin 0 -> 1523 bytes 1 file changed, 0 insertions(+), 0 deletions(-) create mode 100644 arch/arm/mach-k3/keys/custMpk.esl
diff --git a/arch/arm/mach-k3/keys/custMpk.esl b/arch/arm/mach-k3/keys/custMpk.esl new file mode 100644 index 0000000000000000000000000000000000000000..2feb704e0a5fd126410de451d3c0fa4d3edccc52 GIT binary patch literal 1523 zcmZ1&d0^?2Da*aux2_hA(f&~MnUw(yu0v@E4?-F=u^u*PVqVQ8QZ((-^A*$m*Kg7c z&78AJODc2mtxpELY@Awc9&O)w85y}*84Mcd8gd(OvN4CUun9AT2E#ZUJWL@GhWtR) zKpA!(HkZVloWx>7bput902hy3NNPo5v4Uq_aY<2WZfaf$h@G5YRFGekSdyAzC~P1I zQpnB26;PC)oLXF*UsMbeWai-t@l*&dEdVMmF_blshP#N9QH-w`BJNO<sh6CeYal1i zYh-L-W?*PwYGi0=7A4MWYz$;tLb-$9{Y^|t$U)A?%D~*j#Lr;R#Kgta#Kg$3Uu2!< zjryX?*~({Md+?>+QS$x7=il`0?bc6sZ`Vxxl^6N{>i2E;SY*4-T$+0G;)5dxe+2CR z@4+)sDPWdQb@%6KTpDVdm)v}?GSpG(w_UV)&i+#e3fJowDZO)JR83lIcbw(hMu}}Y z2ZZwYAI-LVx@^G;HdkgxaX&Hnl_l3&{H|3l7uX@Vl5di{>fQQ{pDynFlySp2(z~g) z{LIBUzm&K9j_CMw_SIFfPdcT#zmg6g<ji}(R`6geJLk-#o7bK^&&fT}#2zsD`=c9g zFUCK<Fz@{2kel&$W6zl<d|WNk#ZsNRd{_N_SJxWvh0*K$j!m)c@oT>{#b(Lp`M3Uj zGOKycyEe+n{G(Rmg}jB!)0ySk-!kkj_R7#OT+}pcG0VXh?f+ftRvnyw#hUea^Iyfn ze|zgKPKrqe@jYWU?v<50X(n^lZ*G%j$JyCh`*Px|H*K=2WXP)hx>jng+}Q}N^KoDN z8dh8T-~Dmrp2?yk3O6Gqbz7O@<TEz<^zIa7d#PKtHKHeAg?V0DMSin^o3F|IEfQWk zcmJwBy6&2hKub%G{j3IK(?7m@uI43#1e~wSZJ5sTtDjrp@7@{O3(faN{`Gp}x{$M5 z{A7`c@pjfYq1Z=JvgZ^-zCC<(HFTBwYhTX$k`7IJX`SM!H}f`Mv+(Op6uVY(<(^o4 zpyXAj9nF_c-1A<UIel9%6Eh<NBXSA>W=dcRVPvS;*B%(4`P|iK>Vg$XDgN9sr}Df{ z7X0es=RPHr8RB+*)}q}h%gn?x9PO4y*Qog};x<<LS+lxk$@$kYlG_hXu6p%jvB<%l zmcsdI9w!^rFPt^&c~{1?L~DJ4TRPv>t%rn8xi;KBE9A!Dppb9yru|>RCb9PcXWpE> zKlQ}fzw*izXI|}|r!O*nb&cP9#VhHRn;B<SRflN2Jl(*;W4e0LD$ORRIdjjhURZH+ zXWR0Vllb2@>`1LC^xvIctvLCYhRA_6yCS~2&!0SH1xwv(O~<l(HQxHJxzF!T_>+5t z^|E$S{MM^8j9J5`sQ6pud{2Lz?k`zncbjvHj%eutjusUol}8;%cbPLCO|e;ZJ^tXe z_N{pmM}uCi3UWO3=hMc<s}m1Jx4GS4F(<_N`R|o+)eAK3Yx{o$ygRe!;<_EoF&UhP zrslJ=2XA9^$j#UDYwo;ZvZwb!|L%YP%v|ie|7-1PP+q3DZ&vEWgHHrjHv|NzEVjO? zKFeRbXv>iTPl?N16Xv@buq_d@TU<MB;uD_jX^$J`&*C>`uX0_s&g9M2C6cKx4E;{? zt`1&)Tk-yb?sKMPI~!}xt*d*!tMat!r1`}jul#i@lDB8rnu>ba_-^4!iQ5{|tb3TX z>fTMIw2!Me3{Dw*WZotC<4@h<H`zaL+~Es<{Ccj5yS7zyNU!YsTG`^JqA6NkU%vnV D66<<J
literal 0 HcmV?d00001
Adding vendor public keys into the code base to lock down generated binaries to the vendors unpublished private key does not match well with the intent of the GNU public license.
Best regards
Heinrich
The matching private keys are already published in this same repo/directory (arch/arm/mach-k3/keys).
Andrew
Best regards
Heinrich
Andrew
Why should we create signed capsules which are already compromised by publishing the private key?
Best regards
Heinrich
Best regards
Heinrich
Andrew
If you buy these devices you have two options, you can burn real keys, or you can burn these dummy keys. If you burn dummy keys then these images will boot and so will any image you or anyone else wants to boot on the device. (since the keys are published anyone can make images for them, that is how we do GP (general purpose) devices these days)
If you burn your own keys, then you switch out these keys here and your device will only boot images that you permit by signing with your keys.
You'll find plenty of open source projects do the same and give out example keys to show how to use real keys, even official GNU projects.
https://github.com/gpg/gnupg/tree/master/tests/openpgp/samplekeys
Andrew
Best regards
Heinrich
Best regards
Heinrich
Andrew
I am not sure I am following you here. We don't burn anything in the case of EFI keys. They are placed in an elf section and we assume the device will have a chain of trust enabled, naturally verifying those keys along with the u-boot binary.
Yes, but the keys defined here are useless unless you have a default defconfig that uses them and embeds them in the binary. I am not cc'ed in all the patches of the series, is that added somewhere? And if you unconditionally enable secure boot It would be far more interesting to embed the MS SHIM key along with that special key you are trying to define, so that firmware can boot COTS distros as well
Thanks /Ilias
Andrew
Best regards
Heinrich
Best regards
Heinrich
Andrew
Right, you can (and probably should) use different keys stored in the boot stages to verify the next stages. I was more giving the background to why we publish our "private" keys at all here. Using the same keys for every stage (including burning it in as the HW root of trust key) is to make the examples here easier, but I think I see what you are saying. It could be better to generate a key-pair as part of this build for the EFI keys.
Using MS SHIM keys here does sound interesting, I'll let Jon comment on if we want to add that to this series or save for later.
Thanks, Andrew
Thanks /Ilias
Andrew
Best regards
Heinrich
Best regards
Heinrich
Ilias Apalodimas ilias.apalodimas@linaro.org writes:
Andrew
Yes, they are part of this series https://lore.kernel.org/r/20240408213349.96610-1-j-humphreys@ti.com. Thanks for the reviews.
Yes, we should consider. But since that is outside of the EFI capsule use case, I would rather take it up in a separate patch.
Thanks /Ilias
Andrew
Best regards
Heinrich
Best regards
Heinrich
Hi Jon,
On 4/8/24 23:33, Jonathan Humphreys wrote: > EFI signature list using TI dummy keys.
Andrew
Ok, the commit message wasn't clear, and based on Andrews's initial response I thought you wanted to use those for UEFI secure boot, not capsule updates. Those are your boards so I won't NAK this, but I'd strongly advise *not* to add this. I assume you want capsule auth by default because SystemReady-IR >=2.0 mandates it?
In that case, it would be a far better idea to document the process of creating signed capsules clearly either in U-Boots EFI docs and/or your board docs. I am pretty confident that if we merge this now we will have future products using the keys above
Thanks /Ilias
Thanks /Ilias
Andrew
Best regards
Heinrich
Best regards
Heinrich
> > Signed-off-by: Jonathan Humphreys j-humphreys@ti.com > --- > arch/arm/mach-k3/keys/custMpk.esl | Bin 0 -> 1523 bytes > 1 file changed, 0 insertions(+), 0 deletions(-) > create mode 100644 arch/arm/mach-k3/keys/custMpk.esl > > diff --git a/arch/arm/mach-k3/keys/custMpk.esl > b/arch/arm/mach-k3/keys/custMpk.esl > new file mode 100644 > index > 0000000000000000000000000000000000000000..2feb704e0a5fd126410de451d3c0fa4d3edccc52 > GIT binary patch > literal 1523 > zcmZ1&d0^?2Da*aux2_hA(f&~MnUw(yu0v@E4?-F=u^u*PVqVQ8QZ((-^A*$m*Kg7c > z&78AJODc2mtxpELY@Awc9&O)w85y}*84Mcd8gd(OvN4CUun9AT2E#ZUJWL@GhWtR) > zKpA!(HkZVloWx>7bput902hy3NNPo5v4Uq_aY<2WZfaf$h@G5YRFGekSdyAzC~P1I > zQpnB26;PC)oLXF*UsMbeWai-t@l*&dEdVMmF_blshP#N9QH-w`BJNO<sh6CeYal1i > zYh-L-W?*PwYGi0=7A4MWYz$;tLb-$9{Y^|t$U)A?%D~*j#Lr;R#Kgta#Kg$3Uu2!< > zjryX?*~({Md+?>+QS$x7=il`0?bc6sZ`Vxxl^6N{>i2E;SY*4-T$+0G;)5dxe+2CR > z@4+)sDPWdQb@%6KTpDVdm)v}?GSpG(w_UV)&i+#e3fJowDZO)JR83lIcbw(hMu}}Y > z2ZZwYAI-LVx@^G;HdkgxaX&Hnl_l3&{H|3l7uX@Vl5di{>fQQ{pDynFlySp2(z~g) > z{LIBUzm&K9j_CMw_SIFfPdcT#zmg6g<ji}(R`6geJLk-#o7bK^&&fT}#2zsD`=c9g > zFUCK<Fz@{2kel&$W6zl<d|WNk#ZsNRd{_N_SJxWvh0*K$j!m)c@oT>{#b(Lp`M3Uj > zGOKycyEe+n{G(Rmg}jB!)0ySk-!kkj_R7#OT+}pcG0VXh?f+ftRvnyw#hUea^Iyfn > ze|zgKPKrqe@jYWU?v<50X(n^lZ*G%j$JyCh`*Px|H*K=2WXP)hx>jng+}Q}N^KoDN > z8dh8T-~Dmrp2?yk3O6Gqbz7O@<TEz<^zIa7d#PKtHKHeAg?V0DMSin^o3F|IEfQWk > zcmJwBy6&2hKub%G{j3IK(?7m@uI43#1e~wSZJ5sTtDjrp@7@{O3(faN{`Gp}x{$M5 > z{A7`c@pjfYq1Z=JvgZ^-zCC<(HFTBwYhTX$k`7IJX`SM!H}f`Mv+(Op6uVY(<(^o4 > zpyXAj9nF_c-1A<UIel9%6Eh<NBXSA>W=dcRVPvS;*B%(4`P|iK>Vg$XDgN9sr}Df{ > z7X0es=RPHr8RB+*)}q}h%gn?x9PO4y*Qog};x<<LS+lxk$@$kYlG_hXu6p%jvB<%l > zmcsdI9w!^rFPt^&c~{1?L~DJ4TRPv>t%rn8xi;KBE9A!Dppb9yru|>RCb9PcXWpE> > zKlQ}fzw*izXI|}|r!O*nb&cP9#VhHRn;B<SRflN2Jl(*;W4e0LD$ORRIdjjhURZH+ > zXWR0Vllb2@>`1LC^xvIctvLCYhRA_6yCS~2&!0SH1xwv(O~<l(HQxHJxzF!T_>+5t > z^|E$S{MM^8j9J5`sQ6pud{2Lz?k`zncbjvHj%eutjusUol}8;%cbPLCO|e;ZJ^tXe > z_N{pmM}uCi3UWO3=hMc<s}m1Jx4GS4F(<_N`R|o+)eAK3Yx{o$ygRe!;<_EoF&UhP > zrslJ=2XA9^$j#UDYwo;ZvZwb!|L%YP%v|ie|7-1PP+q3DZ&vEWgHHrjHv|NzEVjO? > zKFeRbXv>iTPl?N16Xv@buq_d@TU<MB;uD_jX^$J`&*C>`uX0_s&g9M2C6cKx4E;{? > zt`1&)Tk-yb?sKMPI~!}xt*d*!tMat!r1`}jul#i@lDB8rnu>ba_-^4!iQ5{|tb3TX > z>fTMIw2!Me3{Dw*WZotC<4@h<H`zaL+~Es<{Ccj5yS7zyNU!YsTG`^JqA6NkU%vnV > D66<<J > > literal 0 > HcmV?d00001 >
Hi Jon,
On 4/8/24 10:34 PM, Heinrich Schuchardt wrote: > On 4/8/24 23:33, Jonathan Humphreys wrote: >> EFI signature list using TI dummy keys. > > Adding vendor public keys into the code base to lock down generated > binaries to the vendors unpublished private key does not match well with > the intent of the GNU public license. >
Andrew
Thanks Ilias.
If I understand you correctly, I don't agree with the approach of not having a working implementation so that developers are forced to think through their support. Not having a feature enabled in upstream leads to latent bugs, bit rot, lack of coordination and openess, etc. It worries me that there are so many claims of authenticated capsule support but nothing in upstream on those devices.
But I absolutely acknowledge your concern that if we make this 'just work' then developers will overlook the details and not properly secure their solutions.
What I suggest to mitigate this: 1) as you say, add documentation, including a 'porting guide' section so developers know what steps they need to take, and 2) Add a developer config that is set by default. With this config set, during capsule updates, emit a warning message that instructs them to read the porting section of the doc to ensure they have secured their solution. To remove the warning, a developer would follow the porting guidelines and then unset the "developer config" configuration to signify they have secured the solution. This is what optee does, emitting the below during boot, until the config is unset:
I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
Last, I am pondering the idea of not including the actual .esl certificate, but rather adding a make step that would generate the certificate from a given keypair. For the TI upstream implementation, we would point to the open developer keys already being used to demonstrate secure boot. As part of porting, the developer would point to their own keys. That way the certificate has the developer's info, even if they are using our open keys for development purposes. Thoughts?
Outside of the capsule authentication aspect, the porting section would be a good place to remind the developer to define his own capsule GUIDs as well.
Jon
Thanks /Ilias
Thanks /Ilias
Andrew
Best regards
Heinrich
> Best regards > > Heinrich > >> >> Signed-off-by: Jonathan Humphreys j-humphreys@ti.com >> --- >> arch/arm/mach-k3/keys/custMpk.esl | Bin 0 -> 1523 bytes >> 1 file changed, 0 insertions(+), 0 deletions(-) >> create mode 100644 arch/arm/mach-k3/keys/custMpk.esl >> >> diff --git a/arch/arm/mach-k3/keys/custMpk.esl >> b/arch/arm/mach-k3/keys/custMpk.esl >> new file mode 100644 >> index >> 0000000000000000000000000000000000000000..2feb704e0a5fd126410de451d3c0fa4d3edccc52 >> GIT binary patch >> literal 1523 >> zcmZ1&d0^?2Da*aux2_hA(f&~MnUw(yu0v@E4?-F=u^u*PVqVQ8QZ((-^A*$m*Kg7c >> z&78AJODc2mtxpELY@Awc9&O)w85y}*84Mcd8gd(OvN4CUun9AT2E#ZUJWL@GhWtR) >> zKpA!(HkZVloWx>7bput902hy3NNPo5v4Uq_aY<2WZfaf$h@G5YRFGekSdyAzC~P1I >> zQpnB26;PC)oLXF*UsMbeWai-t@l*&dEdVMmF_blshP#N9QH-w`BJNO<sh6CeYal1i >> zYh-L-W?*PwYGi0=7A4MWYz$;tLb-$9{Y^|t$U)A?%D~*j#Lr;R#Kgta#Kg$3Uu2!< >> zjryX?*~({Md+?>+QS$x7=il`0?bc6sZ`Vxxl^6N{>i2E;SY*4-T$+0G;)5dxe+2CR >> z@4+)sDPWdQb@%6KTpDVdm)v}?GSpG(w_UV)&i+#e3fJowDZO)JR83lIcbw(hMu}}Y >> z2ZZwYAI-LVx@^G;HdkgxaX&Hnl_l3&{H|3l7uX@Vl5di{>fQQ{pDynFlySp2(z~g) >> z{LIBUzm&K9j_CMw_SIFfPdcT#zmg6g<ji}(R`6geJLk-#o7bK^&&fT}#2zsD`=c9g >> zFUCK<Fz@{2kel&$W6zl<d|WNk#ZsNRd{_N_SJxWvh0*K$j!m)c@oT>{#b(Lp`M3Uj >> zGOKycyEe+n{G(Rmg}jB!)0ySk-!kkj_R7#OT+}pcG0VXh?f+ftRvnyw#hUea^Iyfn >> ze|zgKPKrqe@jYWU?v<50X(n^lZ*G%j$JyCh`*Px|H*K=2WXP)hx>jng+}Q}N^KoDN >> z8dh8T-~Dmrp2?yk3O6Gqbz7O@<TEz<^zIa7d#PKtHKHeAg?V0DMSin^o3F|IEfQWk >> zcmJwBy6&2hKub%G{j3IK(?7m@uI43#1e~wSZJ5sTtDjrp@7@{O3(faN{`Gp}x{$M5 >> z{A7`c@pjfYq1Z=JvgZ^-zCC<(HFTBwYhTX$k`7IJX`SM!H}f`Mv+(Op6uVY(<(^o4 >> zpyXAj9nF_c-1A<UIel9%6Eh<NBXSA>W=dcRVPvS;*B%(4`P|iK>Vg$XDgN9sr}Df{ >> z7X0es=RPHr8RB+*)}q}h%gn?x9PO4y*Qog};x<<LS+lxk$@$kYlG_hXu6p%jvB<%l >> zmcsdI9w!^rFPt^&c~{1?L~DJ4TRPv>t%rn8xi;KBE9A!Dppb9yru|>RCb9PcXWpE> >> zKlQ}fzw*izXI|}|r!O*nb&cP9#VhHRn;B<SRflN2Jl(*;W4e0LD$ORRIdjjhURZH+ >> zXWR0Vllb2@>`1LC^xvIctvLCYhRA_6yCS~2&!0SH1xwv(O~<l(HQxHJxzF!T_>+5t >> z^|E$S{MM^8j9J5`sQ6pud{2Lz?k`zncbjvHj%eutjusUol}8;%cbPLCO|e;ZJ^tXe >> z_N{pmM}uCi3UWO3=hMc<s}m1Jx4GS4F(<_N`R|o+)eAK3Yx{o$ygRe!;<_EoF&UhP >> zrslJ=2XA9^$j#UDYwo;ZvZwb!|L%YP%v|ie|7-1PP+q3DZ&vEWgHHrjHv|NzEVjO? >> zKFeRbXv>iTPl?N16Xv@buq_d@TU<MB;uD_jX^$J`&*C>`uX0_s&g9M2C6cKx4E;{? >> zt`1&)Tk-yb?sKMPI~!}xt*d*!tMat!r1`}jul#i@lDB8rnu>ba_-^4!iQ5{|tb3TX >> z>fTMIw2!Me3{Dw*WZotC<4@h<H`zaL+~Es<{Ccj5yS7zyNU!YsTG`^JqA6NkU%vnV >> D66<<J >> >> literal 0 >> HcmV?d00001 >> >
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com --- configs/am64x_evm_a53_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 8ba17ea89f9..5594d26844e 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -179,3 +179,4 @@ CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 5594d26844e..8490d4e36a8 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -179,4 +179,5 @@ CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com --- configs/j721e_evm_a72_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index b8840a556e1..83bc0576821 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -212,3 +212,4 @@ CONFIG_TI_J721E_UFS=y CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 83bc0576821..c522d8cc9ee 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -212,4 +212,5 @@ CONFIG_TI_J721E_UFS=y CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com --- configs/am62x_beagleplay_a53_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am62x_beagleplay_a53_defconfig b/configs/am62x_beagleplay_a53_defconfig index 23b9c466248..4e0dcf70b25 100644 --- a/configs/am62x_beagleplay_a53_defconfig +++ b/configs/am62x_beagleplay_a53_defconfig @@ -126,3 +126,4 @@ CONFIG_LZO=y CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
diff --git a/configs/am62x_beagleplay_a53_defconfig b/configs/am62x_beagleplay_a53_defconfig index 4e0dcf70b25..99258804f92 100644 --- a/configs/am62x_beagleplay_a53_defconfig +++ b/configs/am62x_beagleplay_a53_defconfig @@ -126,4 +126,5 @@ CONFIG_LZO=y CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com --- configs/am62px_evm_a53_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am62px_evm_a53_defconfig b/configs/am62px_evm_a53_defconfig index 15ba1079760..ea72eaf2d42 100644 --- a/configs/am62px_evm_a53_defconfig +++ b/configs/am62px_evm_a53_defconfig @@ -178,3 +178,4 @@ CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
diff --git a/configs/am62px_evm_a53_defconfig b/configs/am62px_evm_a53_defconfig index ea72eaf2d42..9e633293d49 100644 --- a/configs/am62px_evm_a53_defconfig +++ b/configs/am62px_evm_a53_defconfig @@ -178,4 +178,5 @@ CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com --- configs/am62x_evm_a53_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 11af7b517d1..1accae81564 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -113,3 +113,4 @@ CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 1accae81564..772a6551ff2 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -113,4 +113,5 @@ CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com --- configs/j721e_beagleboneai64_a72_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/j721e_beagleboneai64_a72_defconfig b/configs/j721e_beagleboneai64_a72_defconfig index e74ee68e23e..5aeb4c08d31 100644 --- a/configs/j721e_beagleboneai64_a72_defconfig +++ b/configs/j721e_beagleboneai64_a72_defconfig @@ -174,3 +174,4 @@ CONFIG_LZO=y CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
diff --git a/configs/j721e_beagleboneai64_a72_defconfig b/configs/j721e_beagleboneai64_a72_defconfig index 5aeb4c08d31..c1d30b3db68 100644 --- a/configs/j721e_beagleboneai64_a72_defconfig +++ b/configs/j721e_beagleboneai64_a72_defconfig @@ -174,4 +174,5 @@ CONFIG_LZO=y CONFIG_EFI_SET_TIME=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_EFI_CAPSULE_ESL_FILE="arch/arm/mach-k3/keys/custMpk.esl"
Hello Jonathan,
with the patch a capsule update will not be possible if the capsule is not signed with the private key matching the ESL signature key in patch 1/13.
Why should a user want to lock down their board to a private key over which he has no control? Wouldn't it be in their best interest to create a key pair themselves?
I would have expected a documentation change explaining this to the users.
Best regards
Heinrich
participants (5)
Andrew Davis
Ilias Apalodimas
Jon Humphreys
Jonathan Humphreys
