[U-Boot] [PATCH] davinci/spi: allow usage of other chip selects and buses
Use the spi_slave bus and cs attributes, reduce C2T/T2C delays, allow overriding of spi_cs_is_valid().
As it is, this patch breaks the configuration files for DaVinci boards that only use SPI1.
Signed-off-by: Jérôme Carretero cJ@zougloub.eu CC: Manjunathappa, Prakash prakash.pm@ti.com -- drivers/spi/davinci_spi.c | 16 +++++++++++----- 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index 13aca52..74f385e 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -23,6 +23,9 @@ * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA + * + * References: SPRUH77 Chapter 30 + * */ #include <common.h> #include <spi.h> @@ -50,7 +53,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
ds->slave.bus = bus; ds->slave.cs = cs; - ds->regs = (struct davinci_spi_regs *)CONFIG_SYS_SPI_BASE; + ds->regs = (struct davinci_spi_regs *)(bus == 0 ? DAVINCI_SPI0_BASE : DAVINCI_SPI1_BASE); ds->freq = max_hz;
return &ds->slave; @@ -67,6 +70,7 @@ int spi_claim_bus(struct spi_slave *slave) { struct davinci_spi_slave *ds = to_davinci_spi(slave); unsigned int scalar; + unsigned int cs;
/* Enable the SPI hardware */ writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0); @@ -76,8 +80,9 @@ int spi_claim_bus(struct spi_slave *slave) /* Set master mode, powered up and not activated */ writel(SPIGCR1_MASTER_MASK | SPIGCR1_CLKMOD_MASK, &ds->regs->gcr1);
+ cs = BIT(slave->cs); /* SPIPC0_EN0FUN_MASK ... */ /* CS, CLK, SIMO and SOMI are functional pins */ - writel((SPIPC0_EN0FUN_MASK | SPIPC0_CLKFUN_MASK | + writel((cs | SPIPC0_CLKFUN_MASK | SPIPC0_DOFUN_MASK | SPIPC0_DIFUN_MASK), &ds->regs->pc0);
/* setup format */ @@ -97,11 +102,11 @@ int spi_claim_bus(struct spi_slave *slave) * Including a minor delay. No science here. Should be good even with * no delay */ - writel((50 << SPI_C2TDELAY_SHIFT) | - (50 << SPI_T2CDELAY_SHIFT), &ds->regs->delay); + writel((10 << SPI_C2TDELAY_SHIFT) | + (10 << SPI_T2CDELAY_SHIFT), &ds->regs->delay);
/* default chip select register */ - writel(SPIDEF_CSDEF0_MASK, &ds->regs->def); + writel(cs, &ds->regs->def);
/* no interrupts */ writel(0, &ds->regs->int0); @@ -280,6 +285,7 @@ out: return 0; }
+__attribute__((weak)) int spi_cs_is_valid(unsigned int bus, unsigned int cs) { return bus == 0 && cs == 0;
Signed-off-by: J??r??me Carretero cJ@zougloub.eu CC: Manjunathappa, Prakash prakash.pm@ti.com
Please fix the configs that this patch breaks, thanks!
Jérôme Carretero
