[U-Boot] [PATCH] dm: i2c: implement gpio-based I2C deblock
The commit extract gpio description from device tree, setup pins and toggle them until I2C slave device release SDA.
Any comments? Ideas?
Could someone review the patch and tell that should I do with it in order to bring the patch to u-boot?
Signed-off-by: Alexander Kochetkov al.kochet@gmail.com --- drivers/i2c/i2c-uclass.c | 95 +++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 93 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index 920811a..a451e41 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -11,6 +11,8 @@ #include <malloc.h> #include <dm/device-internal.h> #include <dm/lists.h> +#include <dm/pinctrl.h> +#include <asm/gpio.h>
#define I2C_MAX_OFFSET_LEN 4
@@ -445,9 +447,96 @@ int i2c_get_chip_offset_len(struct udevice *dev) return chip->offset_len; }
+static void i2c_gpio_set_pin(struct gpio_desc *pin, int bit) +{ + if (bit) + dm_gpio_set_dir_flags(pin, GPIOD_IS_IN); + else + dm_gpio_set_dir_flags(pin, GPIOD_IS_OUT | + GPIOD_ACTIVE_LOW | + GPIOD_IS_OUT_ACTIVE); +} + +static int i2c_gpio_get_pin(struct gpio_desc *pin) +{ + return dm_gpio_get_value(pin); +} + +static void i2c_deblock_gpio_run(struct gpio_desc *sda_pin, struct gpio_desc *scl_pin) +{ + int counter = 16; + + i2c_gpio_set_pin(sda_pin, 1); + i2c_gpio_set_pin(scl_pin, 1); + udelay(5); + + while (counter-- >= 0) { + i2c_gpio_set_pin(scl_pin, 1); + udelay(5); + i2c_gpio_set_pin(scl_pin, 0); + udelay(5); + if (i2c_gpio_get_pin(sda_pin)) + break; + } + + i2c_gpio_set_pin(sda_pin, 0); + udelay(5); + + i2c_gpio_set_pin(scl_pin, 1); + udelay(5); + + i2c_gpio_set_pin(sda_pin, 1); + udelay(5); +} + +enum { + PIN_SDA = 0, + PIN_SCL, + PIN_COUNT, +}; + +static int i2c_deblock_gpio(struct udevice *bus) +{ + struct gpio_desc gpios[PIN_COUNT]; + int ret; + + ret = gpio_request_list_by_name(bus, "gpios", gpios, + ARRAY_SIZE(gpios), GPIOD_IS_IN); + if (ret != ARRAY_SIZE(gpios)) { + debug("%s: I2C Node '%s' has no 'gpios' property %s\n", __func__, + dev_read_name(bus), bus->name); + if (ret >= 0) { + gpio_free_list(bus, gpios, ret); + ret = -ENOENT; + } + goto out; + } + + ret = pinctrl_select_state(bus, "gpio"); + if (ret) { + debug("%s: I2C Node '%s' has no 'gpio' pinctrl state. %s\n", __func__, + dev_read_name(bus), bus->name); + goto out_no_pinctrl; + } + + i2c_deblock_gpio_run(&gpios[PIN_SDA], &gpios[PIN_SCL]); + + ret = pinctrl_select_state(bus, "default"); + if (ret) { + debug("%s: I2C Node '%s' has no 'default' pinctrl state. %s\n", __func__, + dev_read_name(bus), bus->name); + } + +out_no_pinctrl: + gpio_free_list(bus, gpios, ARRAY_SIZE(gpios)); +out: + return ret; +} + int i2c_deblock(struct udevice *bus) { struct dm_i2c_ops *ops = i2c_get_ops(bus); + int ret;
/* * We could implement a software deblocking here if we could get @@ -457,8 +546,10 @@ int i2c_deblock(struct udevice *bus) * * See https://patchwork.ozlabs.org/patch/399040/ */ - if (!ops->deblock) - return -ENOSYS; + if (!ops->deblock) { + ret = i2c_deblock_gpio(bus); + return ret ? -ENOSYS : 0; + }
return ops->deblock(bus); }
Hello Alexander,
Am 02.03.2018 um 14:37 schrieb Alexander Kochetkov:
I am fine with this patch, but checkpatch drops some warnings:
WARNING: line over 80 characters #61: FILE: drivers/i2c/i2c-uclass.c:465: +static void i2c_deblock_gpio_run(struct gpio_desc *sda_pin, struct gpio_desc *scl_pin)
WARNING: line over 80 characters #102: FILE: drivers/i2c/i2c-uclass.c:506: + debug("%s: I2C Node '%s' has no 'gpios' property %s\n", __func__,
WARNING: line over 80 characters #113: FILE: drivers/i2c/i2c-uclass.c:517: + debug("%s: I2C Node '%s' has no 'gpio' pinctrl state. %s\n", __func__,
WARNING: line over 80 characters #122: FILE: drivers/i2c/i2c-uclass.c:526: + debug("%s: I2C Node '%s' has no 'default' pinctrl state. %s\n", __func__,
WARNING: ENOSYS means 'invalid syscall nr' and nothing else #147: FILE: drivers/i2c/i2c-uclass.c:551: + return ret ? -ENOSYS : 0;
Could you fix them, also remove from the commit message the question.
Thanks!
bye, Heiko
Hello Alexander,
Am 23.03.2018 um 07:50 schrieb Heiko Schocher:
Hello Alexander,
Just triggered an travis build (not finsihed yet), and your patch drops errors for arm926ejs boards:
https://travis-ci.org/hsdenx/u-boot-i2c/jobs/357258790
So, can you do a full travis build for your patch before sending a v2 and fix the errors it triggers?
Thanks!
bye, Heiko
Hi Heiko!
Thanks for review.
I’ll fix warnings and travis build errors. But I don’t know how to run full travis build. Can you provide a link to page describing how to run travis build?
Regards, Alexander.
Hello Alexander,
Am 23.03.2018 um 08:50 schrieb Alexander Kochetkov:
Hi Heiko!
Thanks for review.
Thanks!
Hmm.. IIRC:
you need a github account, to which you push your (for example) u-boot tree.
Than read the travis docs:
https://docs.travis-ci.com/user/getting-started/
(you do not need to create .travis.yml, as it is already in u-boot)
Hope this helps?
bye, Heiko
Alexander Kochetkov
Heiko Schocher
