[U-Boot] socfpga: socdk and socrates share SPI flash config, move it to shared place
Both Socrates and SocDK share same QSPI and SPI flash configuration. Move the common configuration into common place.
Signed-off-by: Pavel Machek pavel@denx.de
diff --git a/arch/arm/dts/socfpga_cyclone5.dtsi b/arch/arm/dts/socfpga_cyclone5.dtsi index 234a901..c40ade5 100644 --- a/arch/arm/dts/socfpga_cyclone5.dtsi +++ b/arch/arm/dts/socfpga_cyclone5.dtsi @@ -37,4 +37,30 @@ cpu1-start-addr = <0xffd080c4>; }; }; + + aliases { + spi0 = "/spi@ff705000"; /* QSPI */ + spi1 = "/spi@fff00000"; + spi2 = "/spi@fff01000"; + }; +}; + +&qspi { + status = "okay"; + + flash0: n25q00@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "n25q00"; + reg = <0>; /* chip select */ + spi-max-frequency = <50000000>; + m25p,fast-read; + page-size = <256>; + block-size = <16>; /* 2^16, 64KB */ + read-delay = <4>; /* delay value in read data capture register */ + tshsl-ns = <50>; + tsd2d-ns = <50>; + tchsh-ns = <4>; + tslch-ns = <4>; + }; }; diff --git a/arch/arm/dts/socfpga_cyclone5_socrates.dts b/arch/arm/dts/socfpga_cyclone5_socrates.dts index ea30483..2a64b3c 100644 --- a/arch/arm/dts/socfpga_cyclone5_socrates.dts +++ b/arch/arm/dts/socfpga_cyclone5_socrates.dts @@ -14,12 +14,6 @@ bootargs = "console=ttyS0,115200"; };
- aliases { - spi0 = "/spi@ff705000"; /* QSPI */ - spi1 = "/spi@fff00000"; - spi2 = "/spi@fff01000"; - }; - memory { name = "memory"; device_type = "memory"; @@ -44,22 +38,3 @@ status = "okay"; };
-&qspi { - status = "okay"; - - flash0: n25q00@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "n25q00"; - reg = <0>; /* chip select */ - spi-max-frequency = <50000000>; - m25p,fast-read; - page-size = <256>; - block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; - }; -};
Is my understanding correct that now all SoCFPGA CV boards will be forced to have this SPI flash ? I believe this is incorrect.
Best regards, Marek Vasut
Yes. Defining such a SPI flash is board specific and shouldn't be moved to the common dtsi file.
Thanks, Stefan
SocDK has same QSPI and SPI flash configuration as Socrates. Add support for it.
diff --git a/arch/arm/dts/socfpga_cyclone5_socdk.dts b/arch/arm/dts/socfpga_cyclone5_socdk.dts index 8e1f88c..70701f0 100644 --- a/arch/arm/dts/socfpga_cyclone5_socdk.dts +++ b/arch/arm/dts/socfpga_cyclone5_socdk.dts @@ -25,6 +25,10 @@ * to be added to the gmac1 device tree blob. */ ethernet0 = &gmac1; + + spi0 = "/spi@ff705000"; /* QSPI */ + spi1 = "/spi@fff00000"; + spi2 = "/spi@fff01000"; };
regulator_3_3v: 3-3-v-regulator { @@ -77,3 +81,23 @@ &usb1 { status = "okay"; }; + +&qspi { + status = "okay"; + + flash0: n25q00@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "n25q00"; + reg = <0>; /* chip select */ + spi-max-frequency = <50000000>; + m25p,fast-read; + page-size = <256>; + block-size = <16>; /* 2^16, 64KB */ + read-delay = <4>; /* delay value in read data capture register */ + tshsl-ns = <50>; + tsd2d-ns = <50>; + tchsh-ns = <4>; + tslch-ns = <4>; + }; +};
Applied, thanks.
Can you please cook one for Arria V too while at it, so we're consistent ?
Applied, thanks.
Ok (if you are sure it has same hardware?). Should something like socfpga_devel_board.dtsi be created so we don't have to copy same piece of dts 3 times? Pavel
Applied, thanks.
Yeah, from this point of view, CV and AV are almost identical. Basically, it's the FPGA which differs, AV is closer to stratix in my opinion.
No, this is board specific. I have a feeling we'll have to just deal with three copies in this case.
Arria V SocDK has same QSPI and SPI flash configuration as Socrates. Add support for it.
diff --git a/arch/arm/dts/socfpga_arria5_socdk.dts b/arch/arm/dts/socfpga_arria5_socdk.dts index 4e529a1..1b86897 100644 --- a/arch/arm/dts/socfpga_arria5_socdk.dts +++ b/arch/arm/dts/socfpga_arria5_socdk.dts @@ -25,6 +25,10 @@ * to be added to the gmac1 device tree blob. */ ethernet0 = &gmac1; + + spi0 = "/spi@ff705000"; /* QSPI */ + spi1 = "/spi@fff00000"; + spi2 = "/spi@fff01000"; };
regulator_3_3v: 3-3-v-regulator { @@ -72,3 +76,23 @@ &usb1 { status = "okay"; }; + +&qspi { + status = "okay"; + + flash0: n25q00@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "n25q00"; + reg = <0>; /* chip select */ + spi-max-frequency = <50000000>; + m25p,fast-read; + page-size = <256>; + block-size = <16>; /* 2^16, 64KB */ + read-delay = <4>; /* delay value in read data capture register */ + tshsl-ns = <50>; + tsd2d-ns = <50>; + tchsh-ns = <4>; + tslch-ns = <4>; + }; +};
I was just curious about this, but why are your patches missing diffstat ?
btw. I presume that there is no opposition to this patch, in my opinion it's perfectly OK.
diffstat was never required part of a patch.
So this means "thank you, applied"? Pavel
Would be nice to have though.
No, that's "applied, thanks" ;-)
Pavel Machek
Stefan Roese
