[PATCH] env: Remove misuse of env is nowhere driver
From: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com
When using a list of writeable variables, the initial values come from the built-in default environment since commit 5ab81058364b ("env: Complete generic support for writable list"). Remove unnecessary misuse of the env is nowhere driver as default environment.
Signed-off-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com ---
board/aristainetos/aristainetos.c | 19 ------------------- configs/aristainetos2c_defconfig | 1 - configs/aristainetos2ccslb_defconfig | 1 - env/env.c | 2 -- 4 files changed, 23 deletions(-)
diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index 770f3d7d0d..35beda5cf5 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -529,22 +529,3 @@ int embedded_dtb_select(void) return 0; } #endif - -enum env_location env_get_location(enum env_operation op, int prio) -{ - if (op == ENVOP_SAVE || op == ENVOP_ERASE) - return ENVL_SPI_FLASH; - - switch (prio) { - case 0: - return ENVL_NOWHERE; - - case 1: - return ENVL_SPI_FLASH; - - default: - return ENVL_UNKNOWN; - } - - return ENVL_UNKNOWN; -} diff --git a/configs/aristainetos2c_defconfig b/configs/aristainetos2c_defconfig index bd7947b46b..ec93284c20 100644 --- a/configs/aristainetos2c_defconfig +++ b/configs/aristainetos2c_defconfig @@ -58,7 +58,6 @@ CONFIG_OF_CONTROL=y CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_SPI_EARLY=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y diff --git a/configs/aristainetos2ccslb_defconfig b/configs/aristainetos2ccslb_defconfig index 3fb6e71c67..01d9169950 100644 --- a/configs/aristainetos2ccslb_defconfig +++ b/configs/aristainetos2ccslb_defconfig @@ -58,7 +58,6 @@ CONFIG_OF_CONTROL=y CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_SPI_EARLY=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y diff --git a/env/env.c b/env/env.c index ad774f4117..2aa52c98f8 100644 --- a/env/env.c +++ b/env/env.c @@ -217,9 +217,7 @@ int env_load(void) printf("OK\n"); gd->env_load_prio = prio;
-#if !CONFIG_IS_ENABLED(ENV_APPEND) return 0; -#endif } else if (ret == -ENOMSG) { /* Handle "bad CRC" case */ if (best_prio == -1)
Hello Stefan,
NACK.
You completely break the protected environment functionality for the aristainetos board when you remove env_get_location()
Does it build anymore?
Also you mix up a change in common code and in board code.
And grepping in code for ENVL_NOWHERE has much more finds...
bye, Heiko
Hello Stefan,
On 29.04.23 06:30, Heiko Schocher wrote:
Hello Stefan,
NACK.
Sorry for being to fast with my NACK (I was on thw wrong code base ...)!
Tested-by: Heiko Schocher hs@denx.de
Thanks!
bye, Heiko
Hi Heiko,
Am 29.04.2023 um 06:30 schrieb Heiko Schocher:
Hello Stefan,
I use one commit to avoid a breakage in between the commits but it looks like all affected boards use one environment source only so that a separation should be okay.
Thanks for the hint. I have recheck the code and add two additional boards.
Regards Stefan
Heiko Schocher
