[U-Boot] [PATCH] serial: 16550: Drop OMAP1510 support
The CONFIG_OMAP1510 is no longer defined, so remove this dead code.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org --- drivers/serial/ns16550.c | 20 +++----------------- 1 file changed, 3 insertions(+), 17 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index a1a26a2..30ba0aa 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -128,27 +128,13 @@ static int ns16550_readb(NS16550_t port, int offset) (unsigned char *)addr - (unsigned char *)com_port) #endif
-static inline int calc_divisor(NS16550_t port, int clock, int baudrate) +int ns16550_calc_divisor(NS16550_t port, int clock, int baudrate) { const unsigned int mode_x_div = 16;
return DIV_ROUND_CLOSEST(clock, mode_x_div * baudrate); }
-int ns16550_calc_divisor(NS16550_t port, int clock, int baudrate) -{ -#ifdef CONFIG_OMAP1510 - /* If can't cleanly clock 115200 set div to 1 */ - if ((clock == 12000000) && (baudrate == 115200)) { - port->osc_12m_sel = OSC_12M_SEL; /* enable 6.5 * divisor */ - return 1; /* return 1 for base divisor */ - } - port->osc_12m_sel = 0; /* clear if previsouly set */ -#endif - - return calc_divisor(port, clock, baudrate); -} - static void NS16550_setbrg(NS16550_t com_port, int baud_divisor) { serial_out(UART_LCR_BKSE | UART_LCRVAL, &com_port->lcr); @@ -271,8 +257,8 @@ static inline void _debug_uart_init(void) * feasible. The better fix is to move all users of this driver to * driver model. */ - baud_divisor = calc_divisor(com_port, CONFIG_DEBUG_UART_CLOCK, - CONFIG_BAUDRATE); + baud_divisor = ns16550_calc_divisor(com_port, CONFIG_DEBUG_UART_CLOCK, + CONFIG_BAUDRATE); serial_dout(&com_port->ier, CONFIG_SYS_NS16550_IER); serial_dout(&com_port->mcr, UART_MCRVAL); serial_dout(&com_port->fcr, UART_FCRVAL);
Acked-by: Nishanth Menon nm@ti.com
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Nishanth Menon nm@ti.com
Nishanth Menon
