[U-Boot] [PATCH] usb: ehci: Convert CONFIG_USB_EHCI_PCI to Kconfig
This converts CONFIG_USB_EHCI_PCI to a Kconfig option, and updates all boards that use it.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
configs/MPC8544DS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + drivers/usb/host/Kconfig | 6 ++++++ include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/efi-x86.h | 1 - include/configs/x86-common.h | 1 - scripts/config_whitelist.txt | 1 - 9 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index 8142cf2..4380a69 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -24,5 +24,6 @@ CONFIG_E1000=y CONFIG_RTL8139=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index 521badc..5646aa8 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -23,5 +23,6 @@ CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 2821c8c..435a20d 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -22,5 +22,6 @@ CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 67ad72b..eb035a4 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -142,6 +142,12 @@ config USB_EHCI_MSM This driver supports combination of Chipidea USB controller and Synapsys USB PHY in host mode only.
+config USB_EHCI_PCI + bool "Support for PCI-based EHCI USB controller" + default y if X86 + help + Enables support for the PCI-based EHCI controller. + config USB_EHCI_RCAR_GEN3 bool "Support for Renesas RCar M3/H3 EHCI USB controller" depends on RCAR_GEN3 diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index b4f4c4e..ffe7cfb 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -358,7 +358,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); */
#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_USB_EHCI_PCI #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_PCI_EHCI_DEVICE 0 #endif diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 9062702..31c5f49 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -556,7 +556,6 @@ */
#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_USB_EHCI_PCI #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_PCI_EHCI_DEVICE 0 #endif diff --git a/include/configs/efi-x86.h b/include/configs/efi-x86.h index 4a6b665..f002470 100644 --- a/include/configs/efi-x86.h +++ b/include/configs/efi-x86.h @@ -14,7 +14,6 @@ #undef CONFIG_TPM_TIS_BASE_ADDRESS
#undef CONFIG_SCSI_AHCI -#undef CONFIG_USB_EHCI_PCI
#define CONFIG_STD_DEVICES_SETTINGS "stdin=usbkbd,vga,serial\0" \ "stdout=vga,serial\0" \ diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index a70fc9d..968229d 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -124,7 +124,6 @@ /*----------------------------------------------------------------------- * USB configuration */ -#define CONFIG_USB_EHCI_PCI #define CONFIG_SYS_USB_EVENT_POLL
#define CONFIG_USB_HOST_ETHER diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 3b5c17a..f281f3b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -5083,7 +5083,6 @@ CONFIG_USB_EHCI_KIRKWOOD CONFIG_USB_EHCI_MX5 CONFIG_USB_EHCI_MXC CONFIG_USB_EHCI_MXS -CONFIG_USB_EHCI_PCI CONFIG_USB_EHCI_RMOBILE CONFIG_USB_EHCI_SPEAR CONFIG_USB_EHCI_SUNXI
Applied, thanks
- bool "Support for PCI-based EHCI USB controller"
- default y if X86
- help
- USB configuration
Hi Marek,
Applied, thanks
Will this patch be in v2017.09?
Regards, Bin
Bin Meng
