Re: [PATCH] image: fix select_ramdisk for raw initrd
Hi Simon, Tom , and ...
Do we need this patch as well as the other one? If so, can you combine them? Also, is it possible to drop the assignment to rd_addr at the top of
the function?
this patch must be replaced by another one https://patchwork.ozlabs.org/project/uboot/patch/20211016051915.4157293-1-ar... ( last patch will be enough alone)
On Mon, Nov 1, 2021 at 7:47 AM Simon Glass sjg@chromium.org wrote:
Hi Artem,
On Fri, 15 Oct 2021 at 04:15, Artem Lapkin email2tema@gmail.com wrote:
Problem
We have unbootable raw initrd images because, select_ramdisk for raw initrd images ignore submited select addr and setup rd_datap value to 0
Solution: setup rd_datap value from select
Signed-off-by: Artem Lapkin art@khadas.com
common/image-board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
Also, is it possible to drop the assignment to rd_addr at the top of the function?
diff --git a/common/image-board.c b/common/image-board.c index e7660352e9..e3c6ea806a 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -439,7 +439,7 @@ static int select_ramdisk(bootm_headers_t *images, const char *select, u8 arch, end = strchr(select, ':'); if (end) { *rd_lenp = hextoul(++end, NULL);
*rd_datap = rd_addr;
*rd_datap = hextoul(select, NULL); processed = true; } }
-- 2.25.1
Art Nikpal
