[U-Boot] [PATCH]omap3: bug fix for NOR boot support
This patch provides bug fix, when omap3 uses nor boot.
Signed-off-by: Penda Naveen Kumarpnaveen@ti.com
Index: u-boot/cpu/arm_cortexa8/omap3/lowlevel_init.S =================================================================== --- u-boot.orig/cpu/arm_cortexa8/omap3/lowlevel_init.S +++ u-boot/cpu/arm_cortexa8/omap3/lowlevel_init.S @@ -135,19 +135,19 @@ _go_to_speed: .word go_to_speed /* these constants need to be close for PIC code */ /* The Nor has to be in the Flash Base CS0 for this condition to happen */ flash_cfg1_addr: - .word (GPMC_CONFIG_CS0 + GPMC_CONFIG1) + .word (GPMC_CONFIG_CS0_BASE + GPMC_CONFIG1) flash_cfg3_addr: - .word (GPMC_CONFIG_CS0 + GPMC_CONFIG3) + .word (GPMC_CONFIG_CS0_BASE + GPMC_CONFIG3) flash_cfg3_val: .word STNOR_GPMC_CONFIG3 flash_cfg4_addr: - .word (GPMC_CONFIG_CS0 + GPMC_CONFIG4) + .word (GPMC_CONFIG_CS0_BASE + GPMC_CONFIG4) flash_cfg4_val: .word STNOR_GPMC_CONFIG4 flash_cfg5_val: .word STNOR_GPMC_CONFIG5 flash_cfg5_addr: - .word (GPMC_CONFIG_CS0 + GPMC_CONFIG5) + .word (GPMC_CONFIG_CS0_BASE + GPMC_CONFIG5) pll_ctl_add: .word CM_CLKEN_PLL pll_div_add1:
Makes sense! Most probably not found earlier because most OMAP3 boards have no NOR.
Acked-by: Dirk Behme dirk.behme@googlemail.com
- .word (GPMC_CONFIG_CS0_BASE + GPMC_CONFIG1)
flash_cfg3_addr:
- .word (GPMC_CONFIG_CS0_BASE + GPMC_CONFIG3)
- .word (GPMC_CONFIG_CS0_BASE + GPMC_CONFIG4)
- .word (GPMC_CONFIG_CS0_BASE + GPMC_CONFIG5)
pll_ctl_add: .word CM_CLKEN_PLL pll_div_add1: _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
please specify on which board you test it
Best Regards, J.
Dear "Penda, Naveen Kumar",
In message 5A47E75E594F054BAF48C5E4FC4B92AB0305F29A9A@dbde02.ent.ti.com you wrote:
Applied, thanks.
Dirk Behme
Jean-Christophe PLAGNIOL-VILLARD
Penda, Naveen Kumar
