[U-Boot] [PATCH 01/26] arm: get rid of bi_env
bi_env is nowhere used, so delete it
Signed-off-by: Heiko Schocher hs@denx.de
similar patch posted from Dirk Behme Tue Jul 27 18:36:09 CEST 2010 http://lists.denx.de/pipermail/u-boot/2010-July/074542.html
so this patch maybe obsolete --- - changes since v1: - synced with patch from Dirk Behme
arch/arm/include/asm/u-boot.h | 4 ---- arch/avr32/include/asm/u-boot.h | 1 - arch/i386/include/asm/u-boot.h | 4 ---- arch/mips/include/asm/u-boot.h | 2 -- common/cmd_bdinfo.c | 1 - 5 files changed, 0 insertions(+), 12 deletions(-)
diff --git a/arch/arm/include/asm/u-boot.h b/arch/arm/include/asm/u-boot.h index cfd5a9b..ed33327 100644 --- a/arch/arm/include/asm/u-boot.h +++ b/arch/arm/include/asm/u-boot.h @@ -39,7 +39,6 @@ typedef struct bd_info { int bi_baudrate; /* serial console baudrate */ unsigned long bi_ip_addr; /* IP Address */ - struct environment_s *bi_env; ulong bi_arch_number; /* unique id for this board */ ulong bi_boot_params; /* where this board expects params */ struct /* RAM configuration */ @@ -49,7 +48,4 @@ typedef struct bd_info { } bi_dram[CONFIG_NR_DRAM_BANKS]; } bd_t;
-#define bi_env_data bi_env->data -#define bi_env_crc bi_env->crc - #endif /* _U_BOOT_H_ */ diff --git a/arch/avr32/include/asm/u-boot.h b/arch/avr32/include/asm/u-boot.h index 7e4001f..8acd056 100644 --- a/arch/avr32/include/asm/u-boot.h +++ b/arch/avr32/include/asm/u-boot.h @@ -26,7 +26,6 @@ typedef struct bd_info { unsigned long bi_baudrate; unsigned long bi_ip_addr; unsigned char bi_phy_id[4]; - struct environment_s *bi_env; unsigned long bi_board_number; void *bi_boot_params; struct { diff --git a/arch/i386/include/asm/u-boot.h b/arch/i386/include/asm/u-boot.h index 9a1eec0..a43b3aa 100644 --- a/arch/i386/include/asm/u-boot.h +++ b/arch/i386/include/asm/u-boot.h @@ -51,7 +51,6 @@ typedef struct bd_info { unsigned long bi_busfreq; /* Bus Freq, in MHz */ unsigned int bi_baudrate; /* Console Baudrate */ unsigned long bi_boot_params; /* where this board expects params */ - struct environment_s *bi_env; struct /* RAM configuration */ { ulong start; @@ -59,7 +58,4 @@ typedef struct bd_info { }bi_dram[CONFIG_NR_DRAM_BANKS]; } bd_t;
-#define bi_env_data bi_env->data -#define bi_env_crc bi_env->crc - #endif /* _U_BOOT_H_ */ diff --git a/arch/mips/include/asm/u-boot.h b/arch/mips/include/asm/u-boot.h index d9c14ca..e839ca1 100644 --- a/arch/mips/include/asm/u-boot.h +++ b/arch/mips/include/asm/u-boot.h @@ -42,7 +42,5 @@ typedef struct bd_info { unsigned long bi_flashsize; /* size of FLASH memory */ unsigned long bi_flashoffset; /* reserved area for startup monitor */ } bd_t; -#define bi_env_data bi_env->data -#define bi_env_crc bi_env->crc
#endif /* _U_BOOT_H_ */ diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index fbe73f1..cc81543 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -330,7 +330,6 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) bd_t *bd = gd->bd;
print_num ("arch_number", bd->bi_arch_number); - print_num ("env_t", (ulong)bd->bi_env); print_num ("boot_params", (ulong)bd->bi_boot_params);
for (i=0; i<CONFIG_NR_DRAM_BANKS; ++i) {
Heiko Schocher
