[PATCH] net: macb: Fix race caused by flushing unwanted descriptors
The rx descriptor list is in cached memory, and there may be multiple descriptors per cache-line. After reclaim_rx_buffers marks a descriptor as unused it does a cache flush, which causes the entire cache-line to be written to memory, which may override other descriptors in the same cache-line that the controller may have written to.
The fix skips freeing descriptors that are not the last in a cache-line, and if the freed descriptor is the last one in a cache-line, it marks all the descriptors in the cache-line as unused. This is similarly to what is done in drivers/net/fec_mxc.c
In my case this bug caused tftpboot to fail some times when other packets are sent to u-boot in addition to the ongoing tftp (e.g. ping). The driver would stop receiving new packets because it is waiting on a descriptor that is marked unused, when in reality the descriptor contains a new unprocessed packet but while freeing the previous buffer descriptor & flushing the cache, the driver accidentally marked the descriptor as unused.
Signed-off-by: Yaron Micher yaronm@hailo.ai --- drivers/net/macb.c | 51 +++++++++++++++++++++++++++++++++++----------- 1 file changed, 39 insertions(+), 12 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index e02a57b411..65ec1f24ad 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -98,6 +98,9 @@ struct macb_dma_desc_64 { #define MACB_RX_DMA_DESC_SIZE (DMA_DESC_BYTES(MACB_RX_RING_SIZE)) #define MACB_TX_DUMMY_DMA_DESC_SIZE (DMA_DESC_BYTES(1))
+#define DESC_PER_CACHELINE_32 (ARCH_DMA_MINALIGN/sizeof(struct macb_dma_desc)) +#define DESC_PER_CACHELINE_64 (ARCH_DMA_MINALIGN/DMA_DESC_SIZE) + #define RXBUF_FRMLEN_MASK 0x00000fff #define TXBUF_FRMLEN_MASK 0x000007ff
@@ -401,32 +404,56 @@ static int _macb_send(struct macb_device *macb, const char *name, void *packet, return 0; }
+static void reclaim_rx_buffer(struct macb_device *macb, + unsigned int idx) +{ + unsigned int mask; + unsigned int shift; + unsigned int i; + + /* + * There may be multiple descriptors per CPU cacheline, + * so a cache flush would flush the whole line, meaning the content of other descriptors + * in the cacheline would also flush. If one of the other descriptors had been + * written to by the controller, the flush would cause those changes to be lost. + * + * To circumvent this issue, we do the actual freeing only when we need to free + * the last descriptor in the current cacheline. When the current descriptor is the + * last in the cacheline, we free all the descriptors that belong to that cacheline. + */ + if (macb->config->hw_dma_cap & HW_DMA_CAP_64B) { + mask = DESC_PER_CACHELINE_64 - 1; + shift = 1; + } else { + mask = DESC_PER_CACHELINE_32 - 1; + shift = 0; + } + + /* we exit without freeing if idx is not the last descriptor in the cacheline */ + if ((idx & mask) != mask) + return; + + for (i = idx & (~mask); i <= idx; i++) + macb->rx_ring[i << shift].addr &= ~MACB_BIT(RX_USED); +} + static void reclaim_rx_buffers(struct macb_device *macb, unsigned int new_tail) { unsigned int i; - unsigned int count;
i = macb->rx_tail;
macb_invalidate_ring_desc(macb, RX); while (i > new_tail) { - if (macb->config->hw_dma_cap & HW_DMA_CAP_64B) - count = i * 2; - else - count = i; - macb->rx_ring[count].addr &= ~MACB_BIT(RX_USED); + reclaim_rx_buffer(macb, i); i++; - if (i > MACB_RX_RING_SIZE) + if (i >= MACB_RX_RING_SIZE) i = 0; }
while (i < new_tail) { - if (macb->config->hw_dma_cap & HW_DMA_CAP_64B) - count = i * 2; - else - count = i; - macb->rx_ring[count].addr &= ~MACB_BIT(RX_USED); + reclaim_rx_buffer(macb, i); i++; }
Yaron Micher
