[U-Boot] [PATCH 0/3] sunxi: Yones Toptech BD1078 support
This series goes on top of my previous series that concludes with Ainol AW1 support.
Also, if you're interested by the idea of using sunxi_name_to_gpio_bank, this could be extended for UART as well, where *many* different pin mux setups are possible. We are just lucky that hardware designers usually use the ports that U-Boot selects, but there is no fundamental reason for that.
Each hardware feature exposed through the GPIO pin mux is usually using the same function index (for a given port), so there is no need to define one value per pin: one value per hardware feature per port is sufficient, avoids duplication and makes everything easier to understand.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/cpu/armv7/sunxi/board.c | 29 +++++++++------- arch/arm/cpu/armv7/sunxi/rsb.c | 8 ++--- arch/arm/include/asm/arch-sunxi/gpio.h | 60 +++++++++++----------------------- board/sunxi/board.c | 12 +++---- board/sunxi/gmac.c | 22 ++++++------- drivers/net/sunxi_emac.c | 2 +- drivers/video/sunxi_display.c | 8 ++--- 7 files changed, 62 insertions(+), 79 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index c02c015..c1b4cf5 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -46,28 +46,33 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); #endif - sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUNXI_GPF2_UART0_TX); - sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF4_UART0_RX); +#if defined(CONFIG_MACH_SUN8I) + sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0_TX); + sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0_RX); +#else + sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUNXI_GPF_UART0_TX); + sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0_RX); +#endif sunxi_gpio_set_pull(SUNXI_GPF(4), 1); #elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I)) - sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB22_UART0_TX); - sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB23_UART0_RX); + sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN5I) - sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB19_UART0_TX); - sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB20_UART0_RX); + sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(20), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN6I) - sunxi_gpio_set_cfgpin(SUNXI_GPH(20), SUN6I_GPH20_UART0_TX); - sunxi_gpio_set_cfgpin(SUNXI_GPH(21), SUN6I_GPH21_UART0_RX); + sunxi_gpio_set_cfgpin(SUNXI_GPH(20), SUN6I_GPH_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(21), SUN6I_GPH_UART0); sunxi_gpio_set_pull(SUNXI_GPH(21), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN5I) - sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG3_UART1_TX); - sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG4_UART1_RX); + sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); + sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG_UART1); sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I) - sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL2_R_UART_TX); - sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL3_R_UART_RX); + sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); + sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); #else #error Unsupported console port number. Please fix pin mux settings in board.c diff --git a/arch/arm/cpu/armv7/sunxi/rsb.c b/arch/arm/cpu/armv7/sunxi/rsb.c index b00befb..f115a9c 100644 --- a/arch/arm/cpu/armv7/sunxi/rsb.c +++ b/arch/arm/cpu/armv7/sunxi/rsb.c @@ -21,15 +21,15 @@ static int rsb_set_device_mode(void); static void rsb_cfg_io(void) { #ifdef CONFIG_MACH_SUN8I - sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_GPL0_R_RSB_SCK); - sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_GPL1_R_RSB_SDA); + sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_GPL_R_RSB); + sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_GPL_R_RSB); sunxi_gpio_set_pull(SUNXI_GPL(0), 1); sunxi_gpio_set_pull(SUNXI_GPL(1), 1); sunxi_gpio_set_drv(SUNXI_GPL(0), 2); sunxi_gpio_set_drv(SUNXI_GPL(1), 2); #elif defined CONFIG_MACH_SUN9I - sunxi_gpio_set_cfgpin(SUNXI_GPN(0), SUN9I_GPN0_R_RSB_SCK); - sunxi_gpio_set_cfgpin(SUNXI_GPN(1), SUN9I_GPN1_R_RSB_SDA); + sunxi_gpio_set_cfgpin(SUNXI_GPN(0), SUN9I_GPN_R_RSB); + sunxi_gpio_set_cfgpin(SUNXI_GPN(1), SUN9I_GPN_R_RSB); sunxi_gpio_set_pull(SUNXI_GPN(0), 1); sunxi_gpio_set_pull(SUNXI_GPN(1), 1); sunxi_gpio_set_drv(SUNXI_GPN(0), 2); diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 3a4b8c3..a6b15d6 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -142,59 +142,37 @@ enum sunxi_gpio_number { #define SUNXI_GPIO_INPUT 0 #define SUNXI_GPIO_OUTPUT 1
-#define SUNXI_GPA0_EMAC 2 -#define SUN6I_GPA0_GMAC 2 -#define SUN7I_GPA0_GMAC 5 +#define SUNXI_GPA_EMAC 2 +#define SUN6I_GPA_GMAC 2 +#define SUN7I_GPA_GMAC 5
-#define SUNXI_GPB0_TWI0 2 +#define SUNXI_GPB_TWI0 2 +#define SUN4I_GPB_UART0 2 +#define SUN5I_GPB_UART0 2
-#define SUN4I_GPB22_UART0_TX 2 -#define SUN4I_GPB23_UART0_RX 2 +#define SUNXI_GPC_SDC2 3
-#define SUN5I_GPB19_UART0_TX 2 -#define SUN5I_GPB20_UART0_RX 2 +#define SUNXI_GPD_LCD0 2 +#define SUNXI_GPD_LVDS0 3
-#define SUNXI_GPC6_SDC2 3 +#define SUNXI_GPF_SDC0 2 +#define SUNXI_GPF_UART0 4 +#define SUN8I_GPF_UART0 3
-#define SUNXI_GPD0_LCD0 2 -#define SUNXI_GPD0_LVDS0 3 +#define SUN5I_GPG_SDC1 2 +#define SUN5I_GPG_UART1 4
-#define SUNXI_GPF0_SDC0 2 +#define SUN6I_GPH_UART0 2
-#define SUNXI_GPF2_SDC0 2 - -#ifdef CONFIG_MACH_SUN8I -#define SUNXI_GPF2_UART0_TX 3 -#define SUNXI_GPF4_UART0_RX 3 -#else -#define SUNXI_GPF2_UART0_TX 4 -#define SUNXI_GPF4_UART0_RX 4 -#endif - -#define SUN4I_GPG0_SDC1 4 - -#define SUN5I_GPG3_SDC1 2 - -#define SUN5I_GPG3_UART1_TX 4 -#define SUN5I_GPG4_UART1_RX 4 - -#define SUN4I_GPH22_SDC1 5 - -#define SUN6I_GPH20_UART0_TX 2 -#define SUN6I_GPH21_UART0_RX 2 - -#define SUN4I_GPI4_SDC3 2 +#define SUN4I_GPI_SDC3 2
#define SUN6I_GPL0_R_P2WI_SCK 3 #define SUN6I_GPL1_R_P2WI_SDA 3
-#define SUN8I_GPL0_R_RSB_SCK 2 -#define SUN8I_GPL1_R_RSB_SDA 2 -#define SUN8I_GPL2_R_UART_TX 2 -#define SUN8I_GPL3_R_UART_RX 2 +#define SUN8I_GPL_R_RSB 2 +#define SUN8I_GPL_R_UART 2
-#define SUN9I_GPN0_R_RSB_SCK 3 -#define SUN9I_GPN1_R_RSB_SDA 3 +#define SUN9I_GPN_R_RSB 3
/* GPIO pin pull-up/down config */ #define SUNXI_GPIO_PULL_DISABLE 0 diff --git a/board/sunxi/board.c b/board/sunxi/board.c index becdc8b..3af3973 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -76,7 +76,7 @@ static void mmc_pinmux_setup(int sdc) case 0: /* D1-PF0, D0-PF1, CLK-PF2, CMD-PF3, D3-PF4, D4-PF5 */ for (pin = SUNXI_GPF(0); pin <= SUNXI_GPF(5); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPF0_SDC0); + sunxi_gpio_set_cfgpin(pin, SUNXI_GPF_SDC0); sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(pin, 2); } @@ -85,7 +85,7 @@ static void mmc_pinmux_setup(int sdc) case 1: /* CMD-PG3, CLK-PG4, D0~D3-PG5-8 */ for (pin = SUNXI_GPG(3); pin <= SUNXI_GPG(8); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN5I_GPG3_SDC1); + sunxi_gpio_set_cfgpin(pin, SUN5I_GPG_SDC1); sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(pin, 2); } @@ -94,7 +94,7 @@ static void mmc_pinmux_setup(int sdc) case 2: /* CMD-PC6, CLK-PC7, D0-PC8, D1-PC9, D2-PC10, D3-PC11 */ for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(11); pin++) { - sunxi_gpio_set_cfgpin(pin, SUNXI_GPC6_SDC2); + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(pin, 2); } @@ -103,7 +103,7 @@ static void mmc_pinmux_setup(int sdc) case 3: /* CMD-PI4, CLK-PI5, D0~D3-PI6~9 : 2 */ for (pin = SUNXI_GPI(4); pin <= SUNXI_GPI(9); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN4I_GPI4_SDC3); + sunxi_gpio_set_cfgpin(pin, SUN4I_GPI_SDC3); sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(pin, 2); } @@ -155,8 +155,8 @@ int board_mmc_init(bd_t *bis)
void i2c_init_board(void) { - sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUNXI_GPB0_TWI0); - sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUNXI_GPB0_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUNXI_GPB_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUNXI_GPB_TWI0); clock_twi_onoff(0, 1); #if defined CONFIG_VIDEO_LCD_PANEL_I2C && !(defined CONFIG_SPL_BUILD) soft_i2c_gpio_sda = sunxi_name_to_gpio(CONFIG_VIDEO_LCD_PANEL_I2C_SDA); diff --git a/board/sunxi/gmac.c b/board/sunxi/gmac.c index 8849132..63a7360 100644 --- a/board/sunxi/gmac.c +++ b/board/sunxi/gmac.c @@ -39,45 +39,45 @@ int sunxi_gmac_initialize(bd_t *bis) if (pin == SUNXI_GPA(9) || pin == SUNXI_GPA(14)) continue; #endif - sunxi_gpio_set_cfgpin(pin, SUN7I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN7I_GPA_GMAC); sunxi_gpio_set_drv(pin, 3); } #elif defined CONFIG_RGMII /* Configure sun6i RGMII mode pin mux settings */ for (pin = SUNXI_GPA(0); pin <= SUNXI_GPA(3); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); sunxi_gpio_set_drv(pin, 3); } for (pin = SUNXI_GPA(9); pin <= SUNXI_GPA(14); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); sunxi_gpio_set_drv(pin, 3); } for (pin = SUNXI_GPA(19); pin <= SUNXI_GPA(20); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); sunxi_gpio_set_drv(pin, 3); } for (pin = SUNXI_GPA(25); pin <= SUNXI_GPA(27); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); sunxi_gpio_set_drv(pin, 3); } #elif defined CONFIG_GMII /* Configure sun6i GMII mode pin mux settings */ for (pin = SUNXI_GPA(0); pin <= SUNXI_GPA(27); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); sunxi_gpio_set_drv(pin, 2); } #else /* Configure sun6i MII mode pin mux settings */ for (pin = SUNXI_GPA(0); pin <= SUNXI_GPA(3); pin++) - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); for (pin = SUNXI_GPA(8); pin <= SUNXI_GPA(9); pin++) - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); for (pin = SUNXI_GPA(11); pin <= SUNXI_GPA(14); pin++) - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); for (pin = SUNXI_GPA(19); pin <= SUNXI_GPA(24); pin++) - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); for (pin = SUNXI_GPA(26); pin <= SUNXI_GPA(27); pin++) - sunxi_gpio_set_cfgpin(pin, SUN6I_GPA0_GMAC); + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_GMAC); #endif
#ifdef CONFIG_RGMII diff --git a/drivers/net/sunxi_emac.c b/drivers/net/sunxi_emac.c index 5a06d68..2a9fd56 100644 --- a/drivers/net/sunxi_emac.c +++ b/drivers/net/sunxi_emac.c @@ -497,7 +497,7 @@ int sunxi_emac_initialize(void)
/* Configure pin mux settings for MII Ethernet */ for (pin = SUNXI_GPA(0); pin <= SUNXI_GPA(17); pin++) - sunxi_gpio_set_cfgpin(pin, SUNXI_GPA0_EMAC); + sunxi_gpio_set_cfgpin(pin, SUNXI_GPA_EMAC);
/* Set up clock gating */ setbits_le32(&ccm->ahb_gate0, 0x1 << AHB_GATE_OFFSET_EMAC); diff --git a/drivers/video/sunxi_display.c b/drivers/video/sunxi_display.c index 4e12150..d2341b0 100644 --- a/drivers/video/sunxi_display.c +++ b/drivers/video/sunxi_display.c @@ -665,10 +665,10 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode,
for (pin = SUNXI_GPD(0); pin <= SUNXI_GPD(27); pin++) #ifdef CONFIG_VIDEO_LCD_IF_PARALLEL - sunxi_gpio_set_cfgpin(pin, SUNXI_GPD0_LCD0); + sunxi_gpio_set_cfgpin(pin, SUNXI_GPD_LCD0); #endif #ifdef CONFIG_VIDEO_LCD_IF_LVDS - sunxi_gpio_set_cfgpin(pin, SUNXI_GPD0_LVDS0); + sunxi_gpio_set_cfgpin(pin, SUNXI_GPD_LVDS0); #endif
sunxi_lcdc_pll_set(0, mode->pixclock_khz, &clk_div, &clk_double); @@ -779,8 +779,8 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, &lcdc->tcon1_timing_sync);
if (use_portd_hvsync) { - sunxi_gpio_set_cfgpin(SUNXI_GPD(26), SUNXI_GPD0_LCD0); - sunxi_gpio_set_cfgpin(SUNXI_GPD(27), SUNXI_GPD0_LCD0); + sunxi_gpio_set_cfgpin(SUNXI_GPD(26), SUNXI_GPD_LCD0); + sunxi_gpio_set_cfgpin(SUNXI_GPD(27), SUNXI_GPD_LCD0);
val = 0; if (mode->sync & FB_SYNC_HOR_HIGH_ACT)
Sunxi platforms have different possible mmc pin mux setups (except for mmc0), which are different across platforms.
This lets users configure which is used through the CONFIG_MMC*_PINS Kconfig options. This is especially relevant when a second (in addition to mmc0) port is used and CONFIG_MMC_SUNXI_SLOT_EXTRA is enabled.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/include/asm/arch-sunxi/gpio.h | 13 +++- board/sunxi/Kconfig | 19 +++++ board/sunxi/board.c | 131 +++++++++++++++++++++++++++++++-- drivers/gpio/sunxi_gpio.c | 14 ++++ 4 files changed, 171 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index a6b15d6..f227044 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -145,26 +145,36 @@ enum sunxi_gpio_number { #define SUNXI_GPA_EMAC 2 #define SUN6I_GPA_GMAC 2 #define SUN7I_GPA_GMAC 5 +#define SUN6I_GPA_SDC2 5 +#define SUN6I_GPA_SDC3 4
#define SUNXI_GPB_TWI0 2 #define SUN4I_GPB_UART0 2 #define SUN5I_GPB_UART0 2
#define SUNXI_GPC_SDC2 3 +#define SUN6I_GPC_SDC3 4
+#define SUN8I_GPD_SDC1 3 #define SUNXI_GPD_LCD0 2 #define SUNXI_GPD_LVDS0 3
+#define SUN5I_GPE_SDC2 3 + #define SUNXI_GPF_SDC0 2 #define SUNXI_GPF_UART0 4 #define SUN8I_GPF_UART0 3
+#define SUN4I_GPG_SDC1 4 #define SUN5I_GPG_SDC1 2 +#define SUN6I_GPG_SDC1 2 +#define SUN8I_GPG_SDC1 2 #define SUN5I_GPG_UART1 4
+#define SUN4I_GPH_SDC1 5 #define SUN6I_GPH_UART0 2
-#define SUN4I_GPI_SDC3 2 +#define SUNXI_GPI_SDC3 2
#define SUN6I_GPL0_R_P2WI_SCK 3 #define SUN6I_GPL1_R_P2WI_SDA 3 @@ -189,6 +199,7 @@ int sunxi_gpio_get_cfgbank(struct sunxi_gpio *pio, int bank_offset); int sunxi_gpio_get_cfgpin(u32 pin); int sunxi_gpio_set_drv(u32 pin, u32 val); int sunxi_gpio_set_pull(u32 pin, u32 val); +int sunxi_name_to_gpio_bank(const char *name); int sunxi_name_to_gpio(const char *name); #define name_to_gpio(name) sunxi_name_to_gpio(name)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 5639321..57e7529 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -208,6 +208,25 @@ config MMC3_CD_PIN ---help--- See MMC0_CD_PIN help text.
+config MMC1_PINS + string "Pins for mmc1" + default "" + ---help--- + Set the pins used for mmc1, when applicable. This takes a string in the + format understood by sunxi_name_to_gpio_bank, e.g. PH for port H. + +config MMC2_PINS + string "Pins for mmc2" + default "" + ---help--- + See MMC1_PINS help text. + +config MMC3_PINS + string "Pins for mmc3" + default "" + ---help--- + See MMC1_PINS help text. + config MMC_SUNXI_SLOT_EXTRA int "mmc extra slot number" default -1 diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 3af3973..01b654e 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -71,10 +71,11 @@ int dram_init(void) static void mmc_pinmux_setup(int sdc) { unsigned int pin; + int pins;
switch (sdc) { case 0: - /* D1-PF0, D0-PF1, CLK-PF2, CMD-PF3, D3-PF4, D4-PF5 */ + /* SDC0: PF0-PF5 */ for (pin = SUNXI_GPF(0); pin <= SUNXI_GPF(5); pin++) { sunxi_gpio_set_cfgpin(pin, SUNXI_GPF_SDC0); sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); @@ -83,30 +84,150 @@ static void mmc_pinmux_setup(int sdc) break;
case 1: - /* CMD-PG3, CLK-PG4, D0~D3-PG5-8 */ + pins = sunxi_name_to_gpio_bank(CONFIG_MMC1_PINS); + +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) + if (pins == SUNXI_GPIO_H) { + /* SDC1: PH22-PH-27 */ + for (pin = SUNXI_GPH(22); pin <= SUNXI_GPH(27); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN4I_GPH_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } else { + /* SDC1: PG0-PG5 */ + for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN4I_GPG_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } +#elif defined(CONFIG_MACH_SUN5I) + /* SDC1: PG3-PG8 */ for (pin = SUNXI_GPG(3); pin <= SUNXI_GPG(8); pin++) { sunxi_gpio_set_cfgpin(pin, SUN5I_GPG_SDC1); sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(pin, 2); } +#elif defined(CONFIG_MACH_SUN6I) + /* SDC1: PG0-PG5 */ + for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN6I_GPG_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#elif defined(CONFIG_MACH_SUN8I) + if (pins == SUNXI_GPIO_D) { + /* SDC1: PD2-PD7 */ + for (pin = SUNXI_GPD(2); pin <= SUNXI_GPD(7); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN8I_GPD_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } else { + /* SDC1: PG0-PG5 */ + for (pin = SUNXI_GPG(0); pin <= SUNXI_GPG(5); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN8I_GPG_SDC1); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } +#endif break;
case 2: - /* CMD-PC6, CLK-PC7, D0-PC8, D1-PC9, D2-PC10, D3-PC11 */ + pins = sunxi_name_to_gpio_bank(CONFIG_MMC2_PINS); + +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) + /* SDC2: PC6-PC11 */ for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(11); pin++) { sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(pin, 2); } +#elif defined(CONFIG_MACH_SUN5I) + if (pins == SUNXI_GPIO_E) { + /* SDC2: PE4-PE9 */ + for (pin = SUNXI_GPE(4); pin <= SUNXI_GPD(9); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN5I_GPE_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } else { + /* SDC2: PC6-PC15 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } +#elif defined(CONFIG_MACH_SUN6I) + if (pins == SUNXI_GPIO_A) { + /* SDC2: PA9-PA14 */ + for (pin = SUNXI_GPA(9); pin <= SUNXI_GPA(14); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } else { + /* SDC2: PC6-PC15, PC24 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + + sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(SUNXI_GPC(24), 2); + } +#elif defined(CONFIG_MACH_SUN8I) + /* SDC2: PC5-PC6, PC8-PC16 */ + for (pin = SUNXI_GPC(5); pin <= SUNXI_GPC(6); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + + for (pin = SUNXI_GPC(8); pin <= SUNXI_GPC(16); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } +#endif break;
case 3: - /* CMD-PI4, CLK-PI5, D0~D3-PI6~9 : 2 */ + pins = sunxi_name_to_gpio_bank(CONFIG_MMC3_PINS); + +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) + /* SDC3: PI4-PI9 */ for (pin = SUNXI_GPI(4); pin <= SUNXI_GPI(9); pin++) { - sunxi_gpio_set_cfgpin(pin, SUN4I_GPI_SDC3); + sunxi_gpio_set_cfgpin(pin, SUNXI_GPI_SDC3); sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(pin, 2); } +#elif defined(CONFIG_MACH_SUN6I) + if (pins == SUNXI_GPIO_A) { + /* SDC3: PA9-PA14 */ + for (pin = SUNXI_GPA(9); pin <= SUNXI_GPA(14); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN6I_GPA_SDC3); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + } else { + /* SDC3: PC6-PC15, PC24 */ + for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { + sunxi_gpio_set_cfgpin(pin, SUN6I_GPC_SDC3); + sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(pin, 2); + } + + sunxi_gpio_set_cfgpin(SUNXI_GPC(24), SUN6I_GPC_SDC3); + sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); + sunxi_gpio_set_drv(SUNXI_GPC(24), 2); + } +#endif break;
default: diff --git a/drivers/gpio/sunxi_gpio.c b/drivers/gpio/sunxi_gpio.c index c66aa51..532d489 100644 --- a/drivers/gpio/sunxi_gpio.c +++ b/drivers/gpio/sunxi_gpio.c @@ -115,6 +115,20 @@ int gpio_set_value(unsigned gpio, int value) return sunxi_gpio_output(gpio, value); }
+int sunxi_name_to_gpio_bank(const char *name) +{ + int group = 0; + + if (*name == 'P' || *name == 'p') + name++; + if (*name >= 'A') { + group = *name - (*name > 'a' ? 'a' : 'A'); + return group; + } + + return -1; +} + int sunxi_name_to_gpio(const char *name) { int group = 0;
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/sunxi/MAINTAINERS | 5 +++++ configs/Yones_Toptech_BD1078_defconfig | 21 +++++++++++++++++++++ 2 files changed, 26 insertions(+) create mode 100644 configs/Yones_Toptech_BD1078_defconfig
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index e486458..28c7144 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -148,3 +148,8 @@ WEXLER-TAB7200 BOARD M: Aleksei Mamlin mamlinav@gmail.com S: Maintained F: configs/Wexler_TAB7200_defconfig + +YONES TOPTECH BD1078 BOARD +M: Paul Kocialkowski contact@paulk.fr +S: Maintained +F: configs/Yones_Toptech_BD1078_defconfig diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig new file mode 100644 index 0000000..cddbbb5 --- /dev/null +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -0,0 +1,21 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" +CONFIG_FDTFILE="sun7i-a20-yones-toptech-bd1078.dtb" +CONFIG_MMC_SUNXI_SLOT_EXTRA=1 +CONFIG_MMC1_PINS="PH" +CONFIG_USB_MUSB_SUNXI=y +CONFIG_USB0_VBUS_PIN="PB9" +CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" +CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:24,pclk_khz:63000,le:32,ri:287,up:22,lo:12,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_DCLK_PHASE=0 +CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_VIDEO_LCD_POWER="PH8" +CONFIG_VIDEO_LCD_BL_EN="PH7" +CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW=n +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=408 +CONFIG_DRAM_ZQ=127 +CONFIG_DRAM_EMR1=4
Thanks.
The entire set has been queued up in u-boot-sunxi/next for upstream merging.
Regards,
Hans
p.s.
I'm not really interested in making the #ifdeffery for the uart setup even more complicated, eventually we should get all this info, including all the pinmux stuff from a dtb (shared with the kernel) appended to the u-boot binary, and then this will use standard devicetree pinmux stuff, until we get there I would like to keep this as simple as possible.
Regards,
Hans
Le lundi 23 mars 2015 à 17:26 +0100, Hans de Goede a écrit :
p.s.
Understood. There was a real need for mmc as the previous setups were just wrong for platforms != (sun4i || sun7i), but in the case of UART, it just remains minimalistic, which is fine.
Hans de Goede
Paul Kocialkowski
