[U-Boot-Users] [PATCH] Adds Altera Stratix II fpga burn support
too quick on the trigger. (the last patch of the same name does not compile)
this will patch against snapshot 98c440bee623ecdd5322852732b883e696fb2140
Adds generic implementation of Altera Stratix II fpga burn fast passive parallel, and fast passive parallel with security, and passive serial formats.
Signed-off-by: Eran Liberty eran.liberty@gmail.com
diff -x .svn -Nuar u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/include/altera.h u-boot-exsw6000/include/altera.h --- u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/include/altera.h 2007-07-03 16:07:56.000000000 +0300 +++ u-boot-exsw6000/include/altera.h 2007-06-28 10:24:40.000000000 +0300 @@ -27,22 +27,21 @@ #ifndef _ALTERA_H_ #define _ALTERA_H_
-/* - * See include/xilinx.h for another working example. - */ - /* Altera Model definitions *********************************************************************/ #define CFG_ACEX1K CFG_FPGA_DEV( 0x1 ) #define CFG_CYCLON2 CFG_FPGA_DEV( 0x2 ) +#define CFG_STRATIX_II CFG_FPGA_DEV( 0x4 )
#define CFG_ALTERA_ACEX1K (CFG_FPGA_ALTERA | CFG_ACEX1K) #define CFG_ALTERA_CYCLON2 (CFG_FPGA_ALTERA | CFG_CYCLON2) +#define CFG_ALTERA_STRATIX_II (CFG_FPGA_ALTERA | CFG_STRATIX_II) /* Add new models here */
/* Altera Interface definitions *********************************************************************/ #define CFG_ALTERA_IF_PS CFG_FPGA_IF( 0x1 ) /* passive serial */ +#define CFG_ALTERA_IF_FPP CFG_FPGA_IF( 0x2 ) /* fast passive parallel */ /* Add new interfaces here */
typedef enum { /* typedef Altera_iface */ @@ -52,6 +51,8 @@ passive_parallel_asynchronous, /* parallel data */ passive_serial_asynchronous, /* serial data w/ internal clock (not used) */ altera_jtag_mode, /* jtag/tap serial (not used ) */ + fast_passive_parallel, /* fast passive parallel (FPP) */ + fast_passive_parallel_security, /* fast passive parallel with security (FPPS) */ max_altera_iface_type /* insert all new types before this */ } Altera_iface; /* end, typedef Altera_iface */
@@ -59,6 +60,7 @@ min_altera_type, /* insert all new types after this */ Altera_ACEX1K, /* ACEX1K Family */ Altera_CYC2, /* CYCLONII Family */ + Altera_StratixII, /* StratixII Familiy */ /* Add new models here */ max_altera_type /* insert all new types before this */ } Altera_Family; /* end, typedef Altera_Family */ @@ -91,4 +93,15 @@ typedef int (*Altera_abort_fn)( int cookie ); typedef int (*Altera_post_fn)( int cookie );
+typedef struct { + Altera_pre_fn pre; + Altera_config_fn config; + Altera_status_fn status; + Altera_done_fn done; + Altera_clk_fn clk; + Altera_data_fn data; + Altera_abort_fn abort; + Altera_post_fn post; +} altera_board_specific_func; + #endif /* _ALTERA_H_ */ diff -x .svn -Nuar u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/common/altera.c u-boot-exsw6000/common/altera.c --- u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/common/altera.c 2007-07-03 16:07:56.000000000 +0300 +++ u-boot-exsw6000/common/altera.c 2007-07-04 12:26:46.000000000 +0300 @@ -1,4 +1,7 @@ /* + * (C) Copyright 2007 + * Eran Liberty, Extricom , eran.liberty@gmail.com + * * (C) Copyright 2003 * Steven Scholz, imc Measurement & Control, steven.scholz@imc-berlin.de * @@ -30,6 +33,7 @@ */ #include <common.h> #include <ACEX1K.h> +#include <stratixII.h>
/* Define FPGA_DEBUG to get debug printf's */ /* #define FPGA_DEBUG */ @@ -43,7 +47,7 @@ #if (CONFIG_FPGA & CFG_FPGA_ALTERA)
/* Local Static Functions */ -static int altera_validate (Altera_desc * desc, char *fn); +static int altera_validate (Altera_desc * desc,const char *fn);
/* ------------------------------------------------------------------------- */ int altera_load( Altera_desc *desc, void *buf, size_t bsize ) @@ -54,22 +58,27 @@ printf ("%s: Invalid device descriptor\n", __FUNCTION__); } else { switch (desc->family) { - case Altera_ACEX1K: - case Altera_CYC2: #if (CONFIG_FPGA & CFG_ACEX1K) + case Altera_ACEX1K: PRINTF ("%s: Launching the ACEX1K Loader...\n", __FUNCTION__); ret_val = ACEX1K_load (desc, buf, bsize); -#elif (CONFIG_FPGA & CFG_CYCLON2) + break; +#endif +#if (CONFIG_FPGA & CFG_CYCLON2) + case Altera_CYC2: PRINTF ("%s: Launching the CYCLON II Loader...\n", __FUNCTION__); ret_val = CYC2_load (desc, buf, bsize); -#else - printf ("%s: No support for ACEX1K devices.\n", - __FUNCTION__); + break; #endif +#if (CONFIG_FPGA & CFG_STRATIX_II) + case Altera_StratixII: + PRINTF ("%s: Launching the Stratix II Loader...\n", + __FUNCTION__); + ret_val = StratixII_load (desc, buf, bsize); break; - +#endif default: printf ("%s: Unsupported family type, %d\n", __FUNCTION__, desc->family); @@ -87,17 +96,20 @@ printf ("%s: Invalid device descriptor\n", __FUNCTION__); } else { switch (desc->family) { - case Altera_ACEX1K: #if (CONFIG_FPGA & CFG_ACEX) + case Altera_ACEX1K: PRINTF ("%s: Launching the ACEX1K Reader...\n", __FUNCTION__); ret_val = ACEX1K_dump (desc, buf, bsize); -#else - printf ("%s: No support for ACEX1K devices.\n", - __FUNCTION__); + break; #endif +#if (CONFIG_FPGA & CFG_STRATIX_II) + case Altera_StratixII: + PRINTF ("%s: Launching the Stratix II Reader...\n", + __FUNCTION__); + ret_val = StratixII_dump (desc, buf, bsize); break; - +#endif default: printf ("%s: Unsupported family type, %d\n", __FUNCTION__, desc->family); @@ -117,10 +129,13 @@ case Altera_ACEX1K: printf ("ACEX1K\n"); break; - /* Add new family types here */ + case Altera_StratixII: + printf ("Stratix II\n"); + break; case Altera_CYC2: printf ("CYCLON II\n"); break; + /* Add new family types here */ default: printf ("Unknown family type, %d\n", desc->family); } @@ -142,6 +157,12 @@ case altera_jtag_mode: /* Not used */ printf ("JTAG Mode\n"); break; + case fast_passive_parallel: + printf ("Fast Passive Parallel (FPP)\n"); + break; + case fast_passive_parallel_security: + printf ("Fast Passive Parallel with Security (FPPS) \n"); + break; /* Add new interface types here */ default: printf ("Unsupported interface type, %d\n", desc->iface); @@ -154,21 +175,25 @@ if (desc->iface_fns) { printf ("Device Function Table @ 0x%p\n", desc->iface_fns); switch (desc->family) { - case Altera_ACEX1K: - case Altera_CYC2: #if (CONFIG_FPGA & CFG_ACEX1K) + case Altera_ACEX1K: ACEX1K_info (desc); -#elif (CONFIG_FPGA & CFG_CYCLON2) + break; +#endif +#if (CONFIG_FPGA & CFG_CYCLON2) + case Altera_CYC2: CYC2_info (desc); -#else - /* just in case */ - printf ("%s: No support for ACEX1K devices.\n", - __FUNCTION__); + break; #endif +#if (CONFIG_FPGA & CFG_STRATIX_II) + case Altera_StratixII: + StratixII_info (desc); break; +#endif /* Add new family types here */ default: - /* we don't need a message here - we give one up above */ + printf ("%s: Unsupported family type, %d\n", + __FUNCTION__, desc->family); break; } } else { @@ -191,22 +216,21 @@ printf ("%s: Invalid device descriptor\n", __FUNCTION__); } else { switch (desc->family) { - case Altera_ACEX1K: #if (CONFIG_FPGA & CFG_ACEX1K) + case Altera_ACEX1K: ret_val = ACEX1K_reloc (desc, reloc_offset); -#else - printf ("%s: No support for ACEX devices.\n", - __FUNCTION__); + break; #endif +#if (CONFIG_FPGA & CFG_STRATIX_II) + case Altera_StratixII: + ret_val = StratixII_reloc (desc, reloc_offset); break; - case Altera_CYC2: +#endif #if (CONFIG_FPGA & CFG_CYCLON2) + case Altera_CYC2: ret_val = CYC2_reloc (desc, reloc_offset); -#else - printf ("%s: No support for CYCLON II devices.\n", - __FUNCTION__); -#endif break; +#endif /* Add new family types here */ default: printf ("%s: Unsupported family type, %d\n", @@ -219,7 +243,7 @@
-static int altera_validate (Altera_desc * desc, char *fn) +static int altera_validate (Altera_desc * desc, const char *fn) { int ret_val = FALSE;
diff -x .svn -Nuar u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/include/stratixII.h u-boot-exsw6000/include/stratixII.h --- u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/include/stratixII.h 1970-01-01 02:00:00.000000000 +0200 +++ u-boot-exsw6000/include/stratixII.h 2007-06-28 11:22:47.000000000 +0300 @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2007 + * Eran Liberty, Extricom, eran.liberty@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#ifndef _STRATIXII_H_ +#define _STRATIXII_H_ + +extern int StratixII_load (Altera_desc * desc, void *image, size_t size); +extern int StratixII_dump (Altera_desc * desc, void *buf, size_t bsize); +extern int StratixII_info (Altera_desc * desc); +extern int StratixII_reloc (Altera_desc * desc, ulong reloc_off); + +#endif /* _STRATIXII_H_ */ diff -x .svn -Nuar u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/common/stratixII.c u-boot-exsw6000/common/stratixII.c --- u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/common/stratixII.c 1970-01-01 02:00:00.000000000 +0200 +++ u-boot-exsw6000/common/stratixII.c 2007-07-01 17:45:02.000000000 +0300 @@ -0,0 +1,235 @@ +/* + * (C) Copyright 2007 + * Eran Liberty, Extricom , eran.liberty@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> /* core U-Boot definitions */ +#include <altera.h> + +#if (CONFIG_FPGA & (CFG_ALTERA | CFG_STRATIX_II)) + +int StratixII_ps_fpp_load (Altera_desc * desc, void *buf, size_t bsize, + int isSerial, int isSecure); +int StratixII_ps_fpp_dump (Altera_desc * desc, void *buf, size_t bsize); + +/****************************************************************/ +/* Stratix II Generic Implementation */ +int StratixII_load (Altera_desc * desc, void *buf, size_t bsize) +{ + int ret_val = FPGA_FAIL; + + switch (desc->iface) { + case passive_serial: + ret_val = StratixII_ps_fpp_load (desc, buf, bsize, 1 ,0); + break; + case fast_passive_parallel: + ret_val = StratixII_ps_fpp_load (desc, buf, bsize, 0, 0); + break; + case fast_passive_parallel_security: + ret_val = StratixII_ps_fpp_load (desc, buf, bsize, 0, 1); + break; + + /* Add new interface types here */ + default: + printf ("%s: Unsupported interface type, %d\n", __FUNCTION__, + desc->iface); + } + return ret_val; +} + +int StratixII_dump (Altera_desc * desc, void *buf, size_t bsize) +{ + int ret_val = FPGA_FAIL; + + switch (desc->iface) { + case passive_serial: + case fast_passive_parallel: + case fast_passive_parallel_security: + ret_val = StratixII_ps_fpp_dump (desc, buf, bsize); + break; + /* Add new interface types here */ + default: + printf ("%s: Unsupported interface type, %d\n", __FUNCTION__, + desc->iface); + } + return ret_val; +} + +int StratixII_info (Altera_desc * desc) +{ + return FPGA_SUCCESS; +} + +int StratixII_reloc (Altera_desc * desc, ulong reloc_offset) +{ + int i; + void **func_table; + desc->iface_fns = (void *)((ulong) (desc->iface_fns) + reloc_offset); + func_table = (void **)desc->iface_fns; + /* assumes the the relocated function have different upper 8 bits then non relocated */ + if (((uint32_t)(desc->iface_fns) & 0xff000000) != ((uint32_t)(func_table[0]) & 0xff000000)) { + for (i = 0; i < sizeof (altera_board_specific_func) / sizeof (void *); i++) { + func_table[i] = + (void *)((ulong) (func_table[i]) + reloc_offset); + } + } + + return FPGA_SUCCESS; +} + +#endif + +int StratixII_ps_fpp_dump (Altera_desc * desc, void *buf, size_t bsize) +{ + printf ("Stratix II Fast Passive Parallel dump is not implemented\n"); + return FPGA_FAIL; +} + +int StratixII_ps_fpp_load (Altera_desc * desc, void *buf, size_t bsize, int isSerial, int isSecure) +{ + altera_board_specific_func *fns; + int cookie; + int ret_val = FPGA_FAIL; + int bytecount; + char *buff = buf; + int i; + + if (!desc) { + printf ("%s(%d) Altera_desc missing\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!buff) { + printf ("%s(%d) buffer is missing\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!bsize) { + printf ("%s(%d) size is zero\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!desc->iface_fns) { + printf + ("%s(%d) Altera_desc function interface table is missing\n", + __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + fns = (altera_board_specific_func *) (desc->iface_fns); + cookie = desc->cookie; + + if (! + (fns->config && fns->status && fns->done && fns->data + && fns->abort)) { + printf + ("%s(%d) Missing some function in the function interface table\n", + __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + + /* 1. give board specific a chance to do anything before we start */ + if (fns->pre) { + if ((ret_val = fns->pre (cookie)) < 0) { + return ret_val; + } + } + + /* from this point on we must fail gracfully by calling lower layer abort */ + + /* 2. Strat burn cycle by deasserting config for t_CFG and waiting t_CF2CK after reaserted */ + fns->config (0, 1, cookie); + udelay (5); /* nCONFIG low pulse width 2usec */ + fns->config (1, 1, cookie); + udelay (100); /* nCONFIG high to first rising edge on DCLK */ + + /* 3. Start the Data cycle with clk deasserted */ + bytecount = 0; + fns->clk (0, 1, cookie); + + printf ("loading to fpga "); + while (bytecount < bsize) { + /* 3.1 check stratix has not signaled us an error */ + if (fns->status (cookie) != 1) { + printf + ("\n%s(%d) Stratix failed (byte transfered till failure 0x%x)\n", + __FUNCTION__, __LINE__, bytecount); + fns->abort (cookie); + return FPGA_FAIL; + } + if (isSerial) { + int i; + uint8_t data = buff[bytecount++]; + for (i=0;i<8;i++) { + /* 3.2(ps) put data on the bus */ + fns->data ((data >> i) & 1, 1, cookie); + + /* 3.3(ps) clock once */ + ndelay (5); + fns->clk (1, 1, cookie); + ndelay (5); + fns->clk (0, 1, cookie); + } + } + else { + printf("not serial\n"); + /* 3.2(fpp) put data on the bus */ + fns->data (buff[bytecount++], 1, cookie); + + /* 3.3(fpp) clock once */ + ndelay (5); + fns->clk (1, 1, cookie); + ndelay (5); + fns->clk (0, 1, cookie); + + /* 3.4(fpp) for secure cycle push 3 more clocks */ + for (i = 0; isSecure && i < 3; i++) { + ndelay (5); + fns->clk (1, 1, cookie); + ndelay (5); + fns->clk (0, 1, cookie); + } + } + + /* 3.5 while clk is deasserted it is safe to print some progress indication */ + if ((bytecount % (bsize / 100)) == 0) { + printf ("\b\b\b%02d%", bytecount * 100 / bsize); + } + } + + /* 4. Set one last clock and check conf done signal */ + fns->clk (1, 1, cookie); + udelay (100); + if (!fns->done (cookie)) { + printf (" error!.\n"); + fns->abort (cookie); + return FPGA_FAIL; + } else { + printf ("\b\b\b done.\n"); + } + + /* 5. call lower layer post configuration */ + if (fns->post) { + if ((ret_val = fns->pre (cookie)) < 0) { + fns->abort (cookie); + return ret_val; + } + } + + return FPGA_SUCCESS; +} diff -x .svn -Nuar u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/common/Makefile u-boot-exsw6000/common/Makefile --- u-boot.git-98c440bee623ecdd5322852732b883e696fb2140/common/Makefile 2007-07-03 16:07:56.000000000 +0300 +++ u-boot-exsw6000/common/Makefile 2007-07-04 12:24:50.000000000 +0300 @@ -27,7 +27,8 @@
AOBJS =
-COBJS = main.o ACEX1K.o altera.o bedbug.o circbuf.o cmd_autoscript.o \ +COBJS = main.o ACEX1K.o altera.o stratixII.o \ + bedbug.o circbuf.o cmd_autoscript.o \ cmd_bdinfo.o cmd_bedbug.o cmd_bmp.o cmd_boot.o cmd_bootm.o \ cmd_cache.o cmd_console.o \ cmd_date.o cmd_dcr.o cmd_diag.o cmd_display.o cmd_doc.o cmd_dtt.o \
- See include/xilinx.h for another working example.
BTW; the bitfield approach to CONFIG macros is also depreciated; and all CFG_* macros are being converted to CONFIG_*. Depending on when/where your patches get merged, you may be asked to do some rework here. Take a look at jdl's activity on the u-boot-testing tree to see what I mean.
Cheers, g.
LOL one at a time
lets get this one patched in first
Liberty
Cheers, g.
-- Grant Likely, B.Sc., P.Eng. Secret Lab Technologies Ltd. grant.likely@secretlab.ca (403) 399-0195
eran liberty
Grant Likely
