[PATCH] serial: Add a debug console using the RISC-V SBI interface
The RISC-V SBI interface v0.1 provides a function for printing a character to the console. Even though SBI v0.1 functions are deprecated, the SBI console is quite useful for early debugging, because it works without any dcache, memory, or MMIO access in S mode.
Signed-off-by: Samuel Holland samuel@sholland.org ---
drivers/serial/Kconfig | 10 ++++++++++ drivers/serial/Makefile | 1 + drivers/serial/serial_sbi.c | 16 ++++++++++++++++ 3 files changed, 27 insertions(+) create mode 100644 drivers/serial/serial_sbi.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 36ee43210a9..e5f086271ef 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -280,6 +280,14 @@ config DEBUG_EFI_CONSOLE U-Boot when running on top of EFI (Extensive Firmware Interface). This is a type of BIOS used by PCs.
+config DEBUG_SBI_CONSOLE + bool "SBI" + depends on SBI_V01 + help + Select this to enable a debug console which calls back to SBI to + output to the console. This can be useful for early debugging of + U-Boot when running on top of SBI (Supervisor Binary Interface). + config DEBUG_UART_S5P bool "Samsung S5P" depends on ARCH_EXYNOS || ARCH_S5PC1XX @@ -442,6 +450,7 @@ endchoice config DEBUG_UART_BASE hex "Base address of UART" depends on DEBUG_UART + default 0 if DEBUG_SBI_CONSOLE default 0 if DEBUG_UART_SANDBOX help This is the base address of your UART for memory-mapped UARTs. @@ -452,6 +461,7 @@ config DEBUG_UART_BASE config DEBUG_UART_CLOCK int "UART input clock" depends on DEBUG_UART + default 0 if DEBUG_SBI_CONSOLE default 0 if DEBUG_UART_SANDBOX default 0 if DEBUG_MVEBU_A3700_UART help diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 3cbea8156f8..4edd2aa9458 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -36,6 +36,7 @@ obj-$(CONFIG_ATMEL_USART) += atmel_usart.o obj-$(CONFIG_BCM6345_SERIAL) += serial_bcm6345.o obj-$(CONFIG_COREBOOT_SERIAL) += serial_coreboot.o obj-$(CONFIG_CORTINA_UART) += serial_cortina.o +obj-$(CONFIG_DEBUG_SBI_CONSOLE) += serial_sbi.o obj-$(CONFIG_EFI_APP) += serial_efi.o obj-$(CONFIG_LPC32XX_HSUART) += lpc32xx_hsuart.o obj-$(CONFIG_MCFUART) += serial_mcf.o diff --git a/drivers/serial/serial_sbi.c b/drivers/serial/serial_sbi.c new file mode 100644 index 00000000000..b9f35ed36e6 --- /dev/null +++ b/drivers/serial/serial_sbi.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <debug_uart.h> +#include <asm/sbi.h> + +static inline void _debug_uart_init(void) +{ +} + +static inline void _debug_uart_putc(int c) +{ + if (CONFIG_IS_ENABLED(RISCV_SMODE)) + sbi_console_putchar(c); +} + +DEBUG_UART_FUNCS
- bool "SBI"
- depends on SBI_V01
- help
- config DEBUG_UART_S5P bool "Samsung S5P" depends on ARCH_EXYNOS || ARCH_S5PC1XX
- default 0 if DEBUG_SBI_CONSOLE default 0 if DEBUG_UART_SANDBOX help This is the base address of your UART for memory-mapped UARTs.
- default 0 if DEBUG_SBI_CONSOLE default 0 if DEBUG_UART_SANDBOX default 0 if DEBUG_MVEBU_A3700_UART help
- if (CONFIG_IS_ENABLED(RISCV_SMODE))
+DEBUG_UART_FUNCS
Reviewed-by: Sean Anderson seanga2@gmail.com
Bin Meng
Samuel Holland
Sean Anderson
