Re: [U-Boot] [PATCH 1/7] riscv: add infrastructure for calling functions on other harts
rick@andestech.com 於 2019年2月18日 週一 上午11:00寫道:
-----Original Message----- From: Auer, Lukas [mailto:lukas.auer@aisec.fraunhofer.de] Sent: Monday, February 18, 2019 5:55 AM To: u-boot@lists.denx.de; Anup.Patel@wdc.com Cc: anup@brainfault.org; bmeng.cn@gmail.com; schwab@suse.de; Rick Jian-Zhi Chen(陳建志); palmer@sifive.com; Atish.Patra@wdc.com; agraf@suse.de Subject: Re: [PATCH 1/7] riscv: add infrastructure for calling functions on other harts
On Tue, 2019-02-12 at 01:44 +0000, Anup Patel wrote:
-----Original Message----- From: Lukas Auer [mailto:lukas.auer@aisec.fraunhofer.de] Sent: Tuesday, February 12, 2019 3:44 AM To: u-boot@lists.denx.de Cc: Atish Patra Atish.Patra@wdc.com; Anup Patel Anup.Patel@wdc.com; Bin Meng bmeng.cn@gmail.com; Andreas
Schwab
schwab@suse.de; Palmer Dabbelt palmer@sifive.com; Alexander Graf agraf@suse.de; Lukas Auer lukas.auer@aisec.fraunhofer.de; Anup Patel anup@brainfault.org; Rick Chen rick@andestech.com Subject: [PATCH 1/7] riscv: add infrastructure for calling functions on other harts
Harts on RISC-V boot independently and U-Boot is responsible for managing them. Functions are called on other harts with smp_call_function(), which sends inter-processor interrupts (IPIs) to all other harts. Functions are specified with their address and two function arguments (argument 2 and 3). The first function argument is always the hart ID of the hart calling the function. On the other harts, the IPI interrupt handler handle_ipi() must be called on software interrupts to handle the request and call the specified function.
Functions are stored in the ipi_data data structure. Every hart has its own data structure in global data. While this is not required at the moment (all harts are expected to boot Linux), this does allow future expansion, where other harts may be used for monitoring or other tasks.
Signed-off-by: Lukas Auer lukas.auer@aisec.fraunhofer.de
arch/riscv/Kconfig | 19 +++++ arch/riscv/include/asm/global_data.h | 5 ++ arch/riscv/include/asm/smp.h | 53 +++++++++++++ arch/riscv/lib/Makefile | 1 + arch/riscv/lib/smp.c | 110 +++++++++++++++++++++++++++ 5 files changed, 188 insertions(+) create mode 100644 arch/riscv/include/asm/smp.h create mode 100644 arch/riscv/lib/smp.c
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index c45e4d73a8..c0842178dd 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -116,4 +116,23 @@ config RISCV_RDTIME config SYS_MALLOC_F_LEN default 0x1000
+config SMP
- bool "Symmetric Multi-Processing"
- help
- This enables support for systems with more than one CPU. If
- you say N here, U-Boot will run on single and multiprocessor
- machines, but will use only one CPU of a multiprocessor
- machine. If you say Y here, U-Boot will run on many, but not
- all, single processor machines.
+config NR_CPUS
- int "Maximum number of CPUs (2-32)"
- range 2 32
- depends on SMP
- default "8"
- help
- On multiprocessor machines, U-Boot sets up a stack for each
CPU.
- Stack memory is pre-allocated. U-Boot must therefore know the
- maximum number of CPUs that may be present.
endmenu diff --git a/arch/riscv/include/asm/global_data.h b/arch/riscv/include/asm/global_data.h index a3a342c6e1..23a5f35af5 100644 --- a/arch/riscv/include/asm/global_data.h +++ b/arch/riscv/include/asm/global_data.h @@ -10,12 +10,17 @@ #ifndef __ASM_GBL_DATA_H #define __ASM_GBL_DATA_H
+#include <asm/smp.h>
/* Architecture-specific global data */ struct arch_global_data { long boot_hart; /* boot hart id */ #ifdef CONFIG_SIFIVE_CLINT void __iomem *clint; /* clint base address */ #endif +#ifdef CONFIG_SMP
- struct ipi_data ipi[CONFIG_NR_CPUS]; #endif
#include <asm-generic/global_data.h> diff --git a/arch/riscv/include/asm/smp.h b/arch/riscv/include/asm/smp.h new file mode 100644 index 0000000000..bc863fdbaf --- /dev/null +++ b/arch/riscv/include/asm/smp.h @@ -0,0 +1,53 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
- Copyright (C) 2019 Fraunhofer AISEC,
- Lukas Auer lukas.auer@aisec.fraunhofer.de */
+#ifndef _ASM_RISCV_SMP_H +#define _ASM_RISCV_SMP_H
- struct ipi_data - Inter-processor interrupt (IPI) data
structure
- IPIs are used for SMP support to communicate to other harts
what +function to
- call. Functions are in the form
- void (*addr)(ulong hart, ulong arg0, ulong arg1).
- The function address and the two arguments, arg0 and arg1, are
+stored in the
- IPI data structure. The hart ID is inserted by the hart
handling the +IPI and
- calling the function.
- @addr: Address of function
- @arg0: First argument of function
- @arg1: Second argument of function
+struct ipi_data {
- ulong addr;
- ulong arg0;
- ulong arg1;
- handle_ipi() - interrupt handler for software interrupts
- The IPI interrupt handler must be called to handle software
+interrupts. It
- calls the function specified in the hart's IPI data structure.
- @hart: Hart ID of the current hart
+void handle_ipi(ulong hart);
- smp_call_function() - Call a function on all other harts
- Send IPIs with the specified function call to all harts.
- @return 0 if OK, -ve on error
+int smp_call_function(ulong addr, ulong arg0, ulong arg1);
+#endif diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index edfa61690c..19370f9749 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -14,6 +14,7 @@ obj-$(CONFIG_SIFIVE_CLINT) += sifive_clint.o obj-y += interrupts.o obj-y += reset.o obj-y += setjmp.o +obj-$(CONFIG_SMP) += smp.o
# For building EFI apps CFLAGS_$(EFI_CRT0) := $(CFLAGS_EFI) diff --git a/arch/riscv/lib/smp.c b/arch/riscv/lib/smp.c new file mode 100644 index 0000000000..1266a2a0ef --- /dev/null +++ b/arch/riscv/lib/smp.c @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <dm.h> +#include <asm/barrier.h> +#include <asm/smp.h>
+DECLARE_GLOBAL_DATA_PTR;
- riscv_send_ipi() - Send inter-processor interrupt (IPI)
- Platform code must provide this function.
- @hart: Hart ID of receiving hart
+extern int riscv_send_ipi(int hart);
- riscv_clear_ipi() - Clear inter-processor interrupt (IPI)
- @hart: Hart ID of hart to be cleared
+extern int riscv_clear_ipi(int hart);
+static int send_ipi_many(struct ipi_data *ipi) {
- ofnode node, cpus;
- u32 reg;
- int ret;
- cpus = ofnode_path("/cpus");
- if (!ofnode_valid(cpus)) {
pr_err("Can't find cpus node!\n");
return -EINVAL;
- ofnode_for_each_subnode(node, cpus) {
if (!ofnode_is_available(node))
continue;
It is not correct to assume that whatever CPUs are marked available will come online. It is possible that certain available CPUs failed to come online due HW failure.
This was intended so that we don't send IPIs to harts, which have been explicitly marked as disabled.
Better approach would be keep an atomic bitmask of HARTs that have entered U-Boot. All HARTs that enter U-Boot will update the atomic HART available bitmask. We send IPI only to HARTs that are available as-per atomic HART bitmask.
I'm not sure if this is required in U-Boot, since we are not relying on all harts to boot for U-Boot to function. We only try to boot all harts listed as available in the device tree.
It may also need to get information from each cpu nodes. The cpu nodes is important, they must be match with the bitmask, or it maybe go wrong. So the bitmask way seem not be necessary.
BR Rick
Is there a situation, in which we would want to avoid sending an IPI to an unavailable hart?
Thanks, Lukas
/* read hart ID of CPU */
ret = ofnode_read_u32(node, "reg", ®);
if (ret)
continue;
/* skip if it is the hart we are running on */
if (reg == gd->arch.boot_hart)
continue;
if (reg >= CONFIG_NR_CPUS) {
pr_err("Hart ID %d is out of range, increase
CONFIG_NR_CPUS\n",
reg);
continue;
gd->arch.ipi[reg].addr = ipi->addr;
gd->arch.ipi[reg].arg0 = ipi->arg0;
gd->arch.ipi[reg].arg1 = ipi->arg1;
mb();
ret = riscv_send_ipi(reg);
if (ret)
return ret;
+void handle_ipi(ulong hart) +{
- int ret;
- void (*smp_function)(ulong hart, ulong arg0, ulong arg1);
- if (hart >= CONFIG_NR_CPUS)
return;
- ret = riscv_clear_ipi(hart);
- if (ret) {
pr_err("Cannot clear IPI\n");
return;
- smp_function = (void (*)(ulong, ulong, ulong))gd-
arch.ipi[hart].addr;
- invalidate_icache_all();
- smp_function(hart, gd->arch.ipi[hart].arg0, gd-
arch.ipi[hart].arg1);
+int smp_call_function(ulong addr, ulong arg0, ulong arg1) {
- int ret = 0;
- struct ipi_data ipi;
- ipi.addr = addr;
- ipi.arg0 = arg0;
- ipi.arg1 = arg1;
- ret = send_ipi_many(&ipi);
- return ret;
2.20.1
Regards, Anup
Schwab
+config SMP
- help
+config NR_CPUS
- range 2 32
- depends on SMP
- default "8"
- help
CPU.
structure
what +function to
+stored in the
+struct ipi_data {
- ulong addr;
- ulong arg0;
- ulong arg1;
+interrupts. It
- u32 reg;
- int ret;
return -EINVAL;
continue;
Makes sense. How about considering both HART DT nodes availability and HART online bitmask when sending IPI ?
My motivation behind HART online bitmask in U-Boot is because:
1. HART DT nodes marked available in DTB might actually be in unknown state in case of HW failure. It is commonly seen that as silicon ages or due to continuous heating of silicon new HW failures start showing up over-time. This means even HARTs can fail to come online over-time.
2. We are moving towards SBI v0.2 and SBI PM extensions. This means RISC-V SoCs that implement SBI PM extensions will only bring-up one HART at boot-time. Rest of the HARTs, will have to powerd-up using SBI calls. This means that even if HART DT node is marked available, the HART might be still be offline until someone from S-mode does SBI call to power-up HART.
Of course, we will be handling in above cases in OpenSBI too but it is better to have "HART online bitmask" in U-Boot as well so that it works fine if some buggy proprietary SBI runtime firmware is not handling above cases.
Regards, Anup
Schwab
schwab@suse.de; Palmer Dabbelt palmer@sifive.com; Alexander Graf agraf@suse.de; Lukas Auer <lukas.auer@aisec.fraunhofer.de >; Anup Patel anup@brainfault.org; Rick Chen rick@andestech.com Subject: [PATCH 1/7] riscv: add infrastructure for calling functions on other harts
+config SMP
- help
CPU. If
multiprocessor
but not
+config NR_CPUS
- range 2 32
- depends on SMP
- default "8"
- help
each CPU.
know the
structure
harts what +function to
arg1, are +stored in the
+struct ipi_data {
- ulong addr;
- ulong arg0;
- ulong arg1;
interrupts
software +interrupts. It
structure.
harts
harts.
(IPI)
- u32 reg;
- int ret;
return -EINVAL;
continue;
- HART DT nodes marked available in DTB might actually be in unknown
- We are moving towards SBI v0.2 and SBI PM extensions. This means
Thanks for explaining! I agree, especially for case 2 we will need to handle offline harts. I'll integrate a hart online bitmask in the next version.
Thanks, Lukas
Anup Patel
Auer, Lukas
Rick Chen
