[U-Boot-Users] Unable to run hello_world
Hi all,
I'm working on an mcf5272 based board that has 32MB of Flash arranged in uniform sectors of 64KB and 16MB of SDRAM.
I've managed to get u-boot to start from Flash and successfully relocate to SDRAM. Below is the debug output from the console:
DRAM: 16 MB Reserving 217k for U-Boot at: 00fc9000 Reserving 256k for malloc() at: 00f89000 Reserving 64 Bytes for Board Info at: 00f88fc0 Reserving 48 Bytes for Global Data at: 00f88f90 Reserving 64k for boot parameters at: 00f78f90 Stack Pointer at: 00f78f78 Start relocate of code from fe000400 to 00fc9000 Now running in RAM - U-Boot at: 00fc9000 FLASH: flash_protect ON: from 0xFE000000 to 0xFE03FFFF protect on 0 protect on 1 protect on 2 protect on 3 32 MB In: serial Out: serial Err: serial U-Boot relocated to 00fc9000 No PHY device found. ### main_loop entered: bootdelay=5
### main_loop: bootcmd="<UNDEFINED>"
I've configured the hello_world example program to run from SDRAM at 0x40000. Here's a dump of the elf headers:
hello_world: file format elf32-m68k
Sections: Idx Name Size VMA LMA File off Algn 0 .text 000001de 00040000 00040000 00002000 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .rodata 0000008a 000401de 000401de 000021de 2**0 CONTENTS, ALLOC, LOAD, READONLY, DATA 2 .data 00000000 00042268 00042268 00002268 2**2 CONTENTS, ALLOC, LOAD, DATA 3 .got 00000048 00042268 00042268 00002268 2**2 CONTENTS, ALLOC, LOAD, DATA 4 .bss 00000000 000422b0 000422b0 000022b0 2**2 ALLOC 5 .stab 00000e40 00000000 00000000 000022b0 2**2 CONTENTS, READONLY, DEBUGGING 6 .stabstr 00001d3a 00000000 00000000 000030f0 2**0 CONTENTS, READONLY, DEBUGGING 7 .comment 0000014c 00000000 00000000 00004e2a 2**0 CONTENTS, READONLY
I can load the resultant binary using the loadb command but an exception is generated when I attempt to run the program:
-> loadb ## Ready for binary (kermit) download to 0x00040000 at 19200 bps... ## Total Size = 0x000022b0 = 8880 Bytes ## Start Addr = 0x00040000 -> go 40004 ## Starting application at 0x00040004 ...
*** Unexpected exception *** Vector Number: 4 Format: 04 Fault Status: 0
PC: 00ff97b8 SR: 00002004 SP: 00f78c20 D0: 00000004 D1: 000006d0 D2: 00ffa12c D3: 00000000 D4: 00000000 D5: 00000000 D6: 00000001 D7: 00f88f90 A0: 00ff97b8 A1: 00fe9fc8 A2: 00040004 A3: 00000000 A4: 00f78ce0 A5: 00ff8500 A6: 00f78cac
*** Please Reset Board! ***
I had a look at what's going on with the debugger - hello_world is jumping to an incorrect address (0xff97b8). This happens at the very start of the program.
I've read through the README and DULG I've scoured the mailing list archive. I still haven't been able to come up with a solution. Any ideas as to what I could be doing wrong??
Thanks for any help you can give.
Regards, Jim...
This probably means that the stub code which exports U-Boot functions for use in stanbdalone applications is incorrect and/or incomplete for your platform.
Please see doc/README.standalone and check the implementation for your arch.
exception is
is jumping
start of the
program.
I've stepped through the code with the debugger and the stub code seems to be working fine. I set the PC to getc() in hello_world and I was able to jump to serial_getc() in u-boot. D7 is pointing to the start of global data, as expected.
However, I did notice that both the u-boot monitor and the hello_world app are using the same vaue for A5 when jumping to other functions - hello_world is pointing to u-boot's data/bss section. Does anyone know how I can get the hello_world app to load it's own A5 value before it begins its own processing??
list archive.
as to what I
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de To be a winner, all you need to give is all you have.
This SF.net email is sponsored by: IT Product Guide on ITManagersJournal Use IT products in your business? Tell us what you think of them. Give us Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more http://productguide.itmanagersjournal.com/guidepromo.tmpl _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Jim McNamara
