[U-Boot] [PATCH] spl: Fix compiling warning on gunzip argument
common/spl/spl_fit.c:201:12: warning: passing argument 4 of ‘gunzip’ from incompatible pointer type [-Wincompatible-pointer-types] src, &length))
Signed-off-by: York Sun york.sun@nxp.com Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de ---
common/spl/spl_fit.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 49ccf1c..82943cd 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -135,6 +135,7 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, int offset; size_t length; int len; + ulong size; ulong load_addr, load_ptr; void *src; ulong overhead; @@ -197,8 +198,9 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP && type == IH_TYPE_KERNEL) { + size = length; if (gunzip((void *)load_addr, CONFIG_SYS_BOOTM_LEN, - src, &length)) { + src, &size)) { puts("Uncompressing error\n"); return -EIO; }
Hi York,
- ulong size; ulong load_addr, load_ptr; void *src; ulong overhead;
if (gunzip((void *)load_addr, CONFIG_SYS_BOOTM_LEN,size = length;
src, &length)) {
}src, &size)) { puts("Uncompressing error\n"); return -EIO;
Here I think you should add a length = size; because "length" is used a few lines after (ln 211) : image_info->size = length; JJ
On 09/15/2017 08:10 AM, Jean-Jacques Hiblot wrote:
Hi York,
src, &length)) {
You are correct. I will send an update. Thanks.
York
No, no I didn't. I had this email queued, and forgot to delete it.
Jean-Jacques Hiblot
York Sun
