[U-Boot] [PATCH] serial: serial_sh: bugfix: autoboot fails if serial console is not connected
On kzm9g board (rmobile SoC), autoboot fails if serial console cable is not connected. When serial cable is not connected, serial error occurs and some garbage comes in data register. sh_serial_tstc() in serial_sh.c does not check error status and misunderstand there is some input data. It is the reason that autoboot fails. This patch adds checking error status in sh_serial_tstc().
This patch is based on v2013.01-rc1 tag of u-boot master git.
Signed-off-by: Tetsuyuki Kobayashi koba@kmckk.co.jp --- Hello Iwamatsu-san,
I checked this patch only on kzm9g board. Other SH or rmobile SoC might have the same problem.
drivers/serial/serial_sh.c | 20 +++++++++++++------- 1 file changed, 13 insertions(+), 7 deletions(-)
diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index 3c931d0..ee1f2d7 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -117,6 +117,14 @@ static int serial_rx_fifo_level(void) return scif_rxfill(&sh_sci); }
+static void handle_error(void) +{ + sci_in(&sh_sci, SCxSR); + sci_out(&sh_sci, SCxSR, SCxSR_ERROR_CLEAR(&sh_sci)); + sci_in(&sh_sci, SCLSR); + sci_out(&sh_sci, SCLSR, 0x00); +} + void serial_raw_putc(const char c) { while (1) { @@ -138,16 +146,14 @@ static void sh_serial_putc(const char c)
static int sh_serial_tstc(void) { + if (sci_in(&sh_sci, SCxSR) & SCIF_ERRORS) { + handle_error(); + return 0; + } + return serial_rx_fifo_level() ? 1 : 0; }
-void handle_error(void) -{ - sci_in(&sh_sci, SCxSR); - sci_out(&sh_sci, SCxSR, SCxSR_ERROR_CLEAR(&sh_sci)); - sci_in(&sh_sci, SCLSR); - sci_out(&sh_sci, SCLSR, 0x00); -}
int serial_getc_check(void) {
Applied, thanks. I will push this to v2013.01.
Best regards, Nobuhiro
Nobuhiro Iwamatsu
Tetsuyuki Kobayashi
