[U-Boot] [u-boot]: Uboot for MPC8641D uboot getting hanged just before relocating to ram
Hi ,
I am trying to run u-boot from flash and the u-boot gets hanged at relocate_code function below is the log
U-Boot 2010.03 (May 04 2011 - 16:44:35)
Unicore software on multiprocessor system!! To enable mutlticore build define CONFIG_MP CPU: 8641D, Version: 3.0, (0x80900130) Core: E600 Core 0, Version: 2.2, (0x80040202) Clock Configuration: CPU:1056 MHz, MPX:528 MHz DDR:264 MHz (528 MT/s data rate), LBC:33 MHz L1: D-cache 32 KB enabled I-cache 32 KB enabled L2: 512 KB enabled Board: Springbok I2C: ready BIT: DRAM: DDR: 512 MB Top of RAM usable for U-Boot at: 20000000 Reserving 258k for U-Boot at: 1ffbf000 Reserving 256k for malloc() at: 1ff7f000 Reserving 68 Bytes for Board Info at: 1ff7efbc Reserving 72 Bytes for Global Data at: 1ff7ef74 Stack Pointer at: 1ff7ef58
your help appreciated. Thanks in advance
Thanks, purva
Purva Singh
