[U-Boot] [PATCH] ZFS: fix some warnings, cleanup
Fix warnings about type mismatch in cmd_zfs. Dont use a global block_dev_desc, instead use a local one in each cmd.
Signed-off-by: Pavel Herrmann morpheus.ibis@gmail.com --- common/cmd_zfs.c | 7 +++++-- fs/zfs/zfs.c | 2 -- include/zfs_common.h | 3 --- 3 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/common/cmd_zfs.c b/common/cmd_zfs.c index a6ea2c0..42e286e 100644 --- a/common/cmd_zfs.c +++ b/common/cmd_zfs.c @@ -46,7 +46,8 @@ #define DOS_FS_TYPE_OFFSET 0x36 #define DOS_FS32_TYPE_OFFSET 0x52
-static int do_zfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +static int do_zfs_load(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) { char *filename = NULL; char *ep; @@ -60,6 +61,7 @@ static int do_zfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) const char *addr_str; struct zfs_file zfile; struct device_s vdev; + struct block_dev_desc *zfs_dev_desc;
if (argc < 3) return CMD_RET_USAGE; @@ -178,7 +180,7 @@ int zfs_print(const char *entry, const struct zfs_dirhook_info *data)
-static int do_zfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +static int do_zfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { const char *filename = "/"; int dev; @@ -186,6 +188,7 @@ static int do_zfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) char *ep; int part_length; struct device_s vdev; + struct block_dev_desc *zfs_dev_desc;
if (argc < 3) return cmd_usage(cmdtp); diff --git a/fs/zfs/zfs.c b/fs/zfs/zfs.c index 360f723..d709e02 100644 --- a/fs/zfs/zfs.c +++ b/fs/zfs/zfs.c @@ -31,8 +31,6 @@ #include <asm/byteorder.h> #include "zfs_common.h"
-block_dev_desc_t *zfs_dev_desc; - /* * The zfs plug-in routines for GRUB are: * diff --git a/include/zfs_common.h b/include/zfs_common.h index 04e73d0..fa0919a 100644 --- a/include/zfs_common.h +++ b/include/zfs_common.h @@ -66,9 +66,6 @@ struct zfs_filesystem { block_dev_desc_t *dev_desc; };
- -extern block_dev_desc_t *zfs_dev_desc; - struct device_s { uint64_t part_length; };
Add some CCs
- char * const argv[])
- The zfs plug-in routines for GRUB are:
Dear Pavel Herrmann,
Did you test the changes?
Add some CCs
The warnings generated would be appreciated in the commit message.
if (argc < 3)
if (argc < 3)
struct device_s {
Best regards, Marek Vasut
[snip]
That's a checkpatch warning, please fix.
Same.
Hi
[snip]
Same.
This patch is no longer relevant, as the important bits have been merged in next by Rob Herring as a part of the get_device_and_partition patch
Pavel Herrmann
Pavel Herrmann
