Re: [U-Boot-Users] cfi_flash support for 8 bit port width S29GL032M
Ladislav Michl ladis@linux-mips.org wrote:
U could try the flash driver of RPXlite DW. If I remember right, this one could work well for 4*8bit of AM29LV320M. As for cfi driver, I
Well, I made a mistake here. The flash driver is not for AM29LV320M. It is for 4*AM29DL323DB90VI instead. Sorry for this.
Perhaps because some AMD chips are JEDEC compatible? Quick look to datasheet shows that AM29LV320M is JEDEC compatible and therefore cfi_flash driver will not work for it (it works nicely for CFI compatible AMD chips such as AM29DL323).
You delivered a really nice hint. But the example you listed couldn't push youself laugh to the end IMHO. AM29DL323 wasn't supported by cfi_flash driver, at least I tested it for Brad Kemp but we didn't succeed. Maybe now or other configuration can work?
Thanks,
Sam
Sam
_________________________________________________________ Do You Yahoo!? 150万曲MP3疯狂搜,带您闯入音乐殿堂 http://cn.rd.yahoo.com/mail_cn/tag/yisou/music/*http://music.yisou.com/ 美女明星应有尽有,搜遍美图、艳图和酷图 http://cn.rd.yahoo.com/mail_cn/tag/yisou/image/*http://image.yisou.com 1G就是1000兆,雅虎电邮自助扩容! http://cn.rd.yahoo.com/mail_cn/tag/1g/*http://cn.mail.yahoo.com/event/mail_1...
Don't worry about. In fact, I have tested this driver. But the problem pointed out by Sebastian Schau was also present on it: the new S29GLxxxM flashes doesn't support the WRITE BYTE (AO) command, so write has to be allways done through write_buffer.
So, finally, I decided to make some modification to the generic cfi_flash.c driver to support 8 BIT mode and AMD write buffer operation. I will submit a patch in several minutes.
In brief, I have to implement flash_write_cfibuffer and add AMD_ADDR_xxx_8BIT to add support for specific unlock sequence and command addresses.
At least S29GL032M behaves as CFI, and the cfi driver is now working.
Alex BASTOS
Alex BASTOS
Sam Song
