[U-Boot] [PATCH 1/2] nios2: call board_init_f_mem
We will need CONFIG_SYS_MALLOC_F_LEN to use serial uclass. So we shall undefine CONFIG_SYS_GENERIC_GLOBAL_DATA, and call board_init_f_mem() to allocates early malloc() memory with size of CONFIG_SYS_MALLOC_F_LEN in board_f.c.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/cpu/start.S | 10 ++++++++++ arch/nios2/include/asm/config.h | 2 -- 2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/arch/nios2/cpu/start.S b/arch/nios2/cpu/start.S index 5c7074e..6c7c777 100644 --- a/arch/nios2/cpu/start.S +++ b/arch/nios2/cpu/start.S @@ -120,6 +120,16 @@ _reloc: stw r0, 4(sp) mov fp, sp
+ /* Allocate and zero GD, update SP */ + mov r4, sp + movhi r2, %hi(board_init_f_mem@h) + ori r2, r2, %lo(board_init_f_mem@h) + callr r2 + + /* Update stack- and frame-pointers */ + mov sp, r2 + mov fp, sp + /* * Call board_init_f -- never returns */ diff --git a/arch/nios2/include/asm/config.h b/arch/nios2/include/asm/config.h index 9c13848..cd29734 100644 --- a/arch/nios2/include/asm/config.h +++ b/arch/nios2/include/asm/config.h @@ -7,6 +7,4 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
-#define CONFIG_SYS_GENERIC_GLOBAL_DATA - #endif
Enable malloc() pool before relocation, because this is needed to use serial uclass.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- configs/nios2-generic_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index 2acf45d..9c1bec5 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -1,5 +1,4 @@ CONFIG_NIOS2=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_TARGET_NIOS2_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_HUSH_PARSER=y
Best regards, Marek Vasut
Applied to u-boot-nios.
Thomas Chou
