[U-Boot] [PATCH 1/1] fs: fat: avoid superfluous conversion calling set_cluster
Parameter size of function set_cluster is of type unsigned long. It makes no sense to convert actsize to int before passing it to set_cluster as size.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- fs/fat/fat_write.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index 2b753df2820..ccc03cecb6e 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -679,7 +679,8 @@ set_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer,
/* set remaining bytes */ actsize = filesize; - if (set_cluster(mydata, curclust, buffer, (int)actsize) != 0) { + if (set_cluster(mydata, curclust, buffer, + (unsigned long)actsize) != 0) { debug("error: writing cluster\n"); return -1; } @@ -696,7 +697,8 @@ set_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer,
return 0; getit: - if (set_cluster(mydata, curclust, buffer, (int)actsize) != 0) { + if (set_cluster(mydata, curclust, buffer, + (unsigned long)actsize) != 0) { debug("error: writing cluster\n"); return -1; }
On Tue, 13 Feb 2018 19:23:29 +0100 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index 2b753df2820..ccc03cecb6e 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -679,7 +679,8 @@ set_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer, /* set remaining bytes */ actsize = filesize;
}(unsigned long)actsize) != 0) { debug("error: writing cluster\n"); return -1;
@@ -696,7 +697,8 @@ set_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer, return 0; getit:
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Lukasz Majewski
