[U-Boot] [PATCH 1/2] PHY: micrel: helper function for KSZ9031
micrel.c: Add function ksz9031_phy_extended_write, helper to MDD register write micrel.h: Prototype and define MDD registers
Signed-off-by: Leo Sartre lsartre@adeneo-embedded.com --- drivers/net/phy/micrel.c | 29 +++++++++++++++++++++++++++-- include/micrel.h | 7 +++++++ 2 files changed, 34 insertions(+), 2 deletions(-)
diff --git a/drivers/net/phy/micrel.c b/drivers/net/phy/micrel.c index 2a8b6cb..5b5c11b 100644 --- a/drivers/net/phy/micrel.c +++ b/drivers/net/phy/micrel.c @@ -85,7 +85,7 @@ static int ksz90xx_startup(struct phy_device *phydev) } #ifdef CONFIG_PHY_MICREL_KSZ9021
-/* +/** * KSZ9021 */
@@ -148,9 +148,34 @@ static struct phy_driver ksz9021_driver = { }; #endif
-/* +/** * KSZ9031 */ + +/* PHY Registers */ +#define MII_KSZ9031_MMD_ACCES_CTRL 0x0d +#define MII_KSZ9031_MMD_REG_DATA 0x0e + +/* Accessors to extended registers*/ +int ksz9031_phy_extended_write(struct phy_device *phydev, + int devaddr, + int regnum, + u16 val) +{ + /*select register addr for mmd*/ + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_ACCES_CTRL, devaddr); + /*select register for mmd*/ + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_REG_DATA, regnum); + /*setup mode*/ + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_ACCES_CTRL, (devaddr | 0xC000)); + /*write the value*/ + return phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_REG_DATA, val); +} + static struct phy_driver ksz9031_driver = { .name = "Micrel ksz9031", .uid = 0x221620, diff --git a/include/micrel.h b/include/micrel.h index 25e8a46..d63ff45 100644 --- a/include/micrel.h +++ b/include/micrel.h @@ -9,8 +9,15 @@ #define MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW 0x106 #define MII_KSZ9021_EXT_ANALOG_TEST 0x107
+#define MII_KSZ9031_EXT_RGMII_CTRL_SIG_SKEW 0x4 +#define MII_KSZ9031_EXT_RGMII_RX_DATA_SKEW 0x5 +#define MII_KSZ9031_EXT_RGMII_TX_DATA_SKEW 0x6 +#define MII_KSZ9031_EXT_RGMII_CLOCK_SKEW 0x8 + struct phy_device; int ksz9021_phy_extended_write(struct phy_device *phydev, int regnum, u16 val); int ksz9021_phy_extended_read(struct phy_device *phydev, int regnum);
+int ksz9031_phy_extended_write(struct phy_device *phydev, int devaddr, + int regnum, u16 val); #endif
On Thu, Jun 20, 2013 at 8:26 AM, SARTRE Leo lsartre@adeneo-embedded.com wrote:
- KSZ9021
Please drop this change; not need.
- KSZ9031
-- Otavio Salvador O.S. Systems http://www.ossystems.com.br http://projetos.ossystems.com.br Mobile: +55 (53) 9981-7854 Mobile: +1 (347) 903-9750
Hi Joe,
- KSZ9021
- KSZ9031
int devaddr,
int regnum,
u16 val)
- /*select register addr for mmd*/
- phy_write(phydev, MDIO_DEVAD_NONE,
- /*select register for mmd*/
- /*setup mode*/
- /*write the value*/
- return phy_write(phydev, MDIO_DEVAD_NONE,
#endif
This patchset belongs to two are, mainly i.MX (for Congatec) and to Network (this patch). Can you ACK/NACK this ? I will enqueue the other two patches in the meantime. To proceed, I propose I can merge then whole patchset into u-boot-imx to avoid to have inconsistent trees.
Thanks, Stefano
Otavio Salvador
SARTRE Leo
Stefano Babic
