[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit d3689267f92c5956e09cc7d1baa4700141662bff:
Prepare v2019.01 (2019-01-14 17:02:36 -0500)
git://git.denx.de/u-boot-fsl-qoriq.git tags/fsl-qoriq-for-v2019.04-rc1
for you to fetch changes up to a200ebea630002b14def4a015642fa341dc9cd11:
armv8: ls2088ardb: Update MAINTAINERS (2019-01-17 13:17:51 -0800)
---------------------------------------------------------------- Add TFA boot flow for more boards
Add TFA boot defconfig for ls1088a and ls2088a. Add dts fixup for PCIe endpoint and root complex.
Travis build log is https://travis-ci.org/yorksun/u-boot/builds/481076641
---------------------------------------------------------------- Florinel Iordache (1): ls1046aqds: Bypass xfi port fixup for KR mode
Hou Zhiqiang (2): armv8: ls1043a: add SVR definitions for 23x23 package silicon armv8: ls1043a: correct the PCIe INTx fixup
Laurentiu Tudor (1): armv8: fsl-layerscape: properly configure qdma ICID
Mian Yousaf Kaukab (1): fsl-layerscape: dpaa: fix fsl-mc status in fdt with bootefi
Pankit Garg (3): ls1043a: add support for nand-boot cmd for TFA armv8: ls1088ardb: Add TFABOOT support armv8: ls1088aqds: Add TFABOOT support
Rajesh Bhagat (7): armv8: fsl-layerscape: fixes for TFABOOT framework drivers: ifc: restore the legacy flow for IFC config armv8: ls2088ardb: Add TFABOOT support armv8: ls2088aqds: Add TFABOOT support env: fix allow to build multiple environments configs: update TFABOOT defconfigs for SD boot support armv7: dts: ls1021a: Remove aliases property name warning
Xiaowei Bao (3): pci: layerscape: Modify the EP and RC mode judge method pci: layerscape: Do not scan when PEX work in EP mode pci: layerscape: Add the dts fixup for EP and RC
Yinbo Zhu (1): mmc: fsl_esdhc: make get_cd work well in dm_mmc_ops
York Sun (2): armv8: ls1088ardb: Update MAINTAINERS armv8: ls2088ardb: Update MAINTAINERS
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 26 +-- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 4 +- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 13 +- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 4 + arch/arm/dts/ls1021a-iot.dtsi | 6 +- arch/arm/dts/ls1021a-qds.dtsi | 10 +- arch/arm/dts/ls1021a-twr.dtsi | 6 +- .../arm/include/asm/arch-fsl-layerscape/fsl_icid.h | 6 +- .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 1 + arch/arm/include/asm/arch-fsl-layerscape/soc.h | 3 + board/freescale/ls1046aqds/eth.c | 35 ++-- board/freescale/ls1088a/MAINTAINERS | 5 + board/freescale/ls1088a/ddr.c | 11 ++ board/freescale/ls1088a/ls1088a.c | 196 ++++++++++++++++++++- board/freescale/ls2080a/ls2080a.c | 10 +- board/freescale/ls2080aqds/MAINTAINERS | 2 + board/freescale/ls2080aqds/ddr.c | 12 ++ board/freescale/ls2080aqds/ls2080aqds.c | 3 +- board/freescale/ls2080ardb/MAINTAINERS | 3 + board/freescale/ls2080ardb/ddr.c | 12 ++ board/freescale/ls2080ardb/ls2080ardb.c | 40 ++++- configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 70 ++++++++ configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 64 +++++++ configs/ls1088ardb_tfa_defconfig | 62 +++++++ configs/ls2088aqds_tfa_defconfig | 64 +++++++ configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 74 ++++++++ configs/ls2088ardb_tfa_defconfig | 73 ++++++++ drivers/misc/fsl_ifc.c | 173 ++++++++++++++++++ drivers/mmc/fsl_esdhc.c | 1 - drivers/net/fsl-mc/mc.c | 5 + drivers/pci/pcie_layerscape.c | 21 +-- drivers/pci/pcie_layerscape.h | 1 + drivers/pci/pcie_layerscape_fixup.c | 25 ++- include/configs/ls1043a_common.h | 2 + include/configs/ls1088a_common.h | 11 +- include/configs/ls1088aqds.h | 99 ++++++++++- include/configs/ls1088ardb.h | 137 +++++++++++++- include/configs/ls2080a_common.h | 8 + include/configs/ls2080aqds.h | 40 ++++- include/configs/ls2080ardb.h | 137 +++++++++++++- include/environment.h | 9 - include/fsl-mc/fsl_mc.h | 1 + include/mmc.h | 3 + 48 files changed, 1420 insertions(+), 74 deletions(-) create mode 100644 configs/ls1088aqds_tfa_defconfig create mode 100644 configs/ls1088ardb_tfa_SECURE_BOOT_defconfig create mode 100644 configs/ls1088ardb_tfa_defconfig create mode 100644 configs/ls2088aqds_tfa_defconfig create mode 100644 configs/ls2088ardb_tfa_SECURE_BOOT_defconfig create mode 100644 configs/ls2088ardb_tfa_defconfig
Thanks.
York
On Fri, Jan 18, 2019 at 06:09:19PM +0000, York Sun wrote:
Tom,
York Sun
