[U-Boot] U-boot networking not working
I've got an sbc6000x from www.armkits.com. I've been working through how to put debian onto this board and was making some progress (im just a beginner), but now I dont have network access when at the U-boot prompt. The Board is connected to the network as the link light is on on the interface. As soon as I try to ping the board itself ie ping 192.192.192.200 (the default ip address) the link light goes out. this is from the command line
U-Boot> ping 192.192.192.200 dm9000 i/o: 0x30000000, id: 0x90000a46 DM9000: running in 16 bit mode MAC: de:ad:be:ef:01:01 operating at 100M full duplex mode ping failed; host 192.192.192.200 is not alive
now if I go ahead and boot the board i can ping once im in the linux root file system that is currently on the board (I've changed the IP address on bootup in the linux image.)
~ $ ping 192.168.0.21 PING 192.168.0.21 (192.168.0.21): 56 data bytes 64 bytes from 192.168.0.21: icmp_seq=0 ttl=64 time=0.5 ms 64 bytes from 192.168.0.21: icmp_seq=1 ttl=64 time=0.3 ms 64 bytes from 192.168.0.21: icmp_seq=2 ttl=64 time=0.3 ms
is there a setting in u-boot that could mean that the network is turned off?
following are the environment variables of u-boot
U-Boot> printenv bootcmd=nand read 0x22000000 0x1A0000 0x200000; bootm 0x22000000 bootdelay=3 baudrate=115200 ethaddr=DE:AD:BE:EF:01:01 ipaddr=192.192.192.200 serverip=192.192.192.105 gatewayip=192.192.192.101 netmask=255.255.255.0 splashimage=0x21000000 bootlogo=0 lcdtype=480x272 bootargs=console=ttyS0,115200 tft=480x272 root=/dev/mtdblock6 mtdparts=at91_nand:128k(bootstrap)ro,256k(uboot)ro,128k(env1)ro,128k(env2)ro,1M(logo)ro,2M(linux),-(root) rw rootfstype=yaffs2
Environment size: 455/131067 bytes
im using u-boot 1.3.4.
Any help with this would be great!
Regards
Mark
Dear Mark Underwood,
Well, I guess you did not read the FAQ...
Ouch.
See FAQ 14.2.13. Ethernet Does Not Work
See also 14.2.14. Where Can I Get a Valid MAC Address from?
Hi!
thanks for your quick replys. More helpful than the manufacturer thats for sure.
I totally admit that im a newbie at all this, so sorry if I dont understand things.
I was under the impression that the MAC address was supplied by the hardware supplier. (at least this seems to be the can in the PC world). Is this not the case in the embedded world?
Cheers
Mark
Ouch.
Mark,
Please do not write your answers above the text you answer to (i.e., do not top-post)
Le 02/12/2010 10:48, Mark Underwood a écrit :
Hi!
No problem -- we all learn something new every day. :)
Yes, it is; but while the supplier provides a unique MAC address for each MAC they send out, they don't necessarily burn it in the HW: it is often configurable.
Here, the MAC is configured from a u-boot env variable; but obviously, the MAC address specified in your u-boot environment is not a valid one (I needed a second look and a step backward to read it as "DEAD BEEF 01 01").
I suggest looking for your MAC address on a sticker or marking on the board, or a printed leaflet, or on the box.
Cheers
Mark
Amicalement,
Albert ARIBAUD
Mark Underwood
