[PATCH v2 0/3] Video: Keep fixed/gpio regulator counter in balance
The commit 4fcba5d556b4 ("regulator: implement basic reference counter") have made it more important to keep fixed/gpio regulators enable/disable state in balance.
The regulator_set_enable_if_allowed function is more relaxed and will wrap all cases where the regulator is busy, already active, missing or if DM_REGULATOR is not enabled.
These patches are an expansion of similar Jonas Karlman's patches.
--- Changes from v1: - check return of regulator_set_enable_if_allowed for -ENOSYS to avoid error caused by disabled DM_REGULATOR (Jonas Karlman suggestion) ---
Svyatoslav Ryhel (3): video: pwm_backlight: use regulator_set_enable_if_allowed video: simple_panel: use regulator_set_enable_if_allowed video: tegra20: dsi: use regulator_set_enable_if_allowed
drivers/video/pwm_backlight.c | 13 ++++++------- drivers/video/simple_panel.c | 10 +++++----- drivers/video/tegra20/tegra-dsi.c | 8 +++----- 3 files changed, 14 insertions(+), 17 deletions(-)
With the commit 4fcba5d556b4 ("regulator: implement basic reference counter") the return value of regulator_set_enable may be EALREADY or EBUSY for fixed/gpio regulators and may be further expanded on all regulators.
Change to use the more relaxed regulator_set_enable_if_allowed to continue if regulator already was enabled or disabled.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/pwm_backlight.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/drivers/video/pwm_backlight.c b/drivers/video/pwm_backlight.c index 46c16a8f44..31160d352e 100644 --- a/drivers/video/pwm_backlight.c +++ b/drivers/video/pwm_backlight.c @@ -97,8 +97,8 @@ static int enable_sequence(struct udevice *dev, int seq) plat = dev_get_uclass_plat(priv->reg); log_debug("Enable '%s', regulator '%s'/'%s'\n", dev->name, priv->reg->name, plat->name); - ret = regulator_set_enable(priv->reg, true); - if (ret) { + ret = regulator_set_enable_if_allowed(priv->reg, true); + if (ret && ret != -ENOSYS) { log_debug("Cannot enable regulator for PWM '%s'\n", dev->name); return log_ret(ret); @@ -178,11 +178,10 @@ static int pwm_backlight_set_brightness(struct udevice *dev, int percent) } if (disable) { dm_gpio_set_value(&priv->enable, 0); - if (priv->reg) { - ret = regulator_set_enable(priv->reg, false); - if (ret) - return log_ret(ret); - } + ret = regulator_set_enable_if_allowed(priv->reg, false); + if (ret && ret != -ENOSYS) + return log_ret(ret); + priv->enabled = false; }
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/simple_panel.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/video/simple_panel.c b/drivers/video/simple_panel.c index 6a6473eb0e..efb122b534 100644 --- a/drivers/video/simple_panel.c +++ b/drivers/video/simple_panel.c @@ -114,11 +114,11 @@ static int simple_panel_probe(struct udevice *dev) const u32 dsi_data = dev_get_driver_data(dev); int ret;
- if (CONFIG_IS_ENABLED(DM_REGULATOR) && priv->reg) { - debug("%s: Enable regulator '%s'\n", __func__, priv->reg->name); - ret = regulator_set_enable(priv->reg, true); - if (ret) - return ret; + ret = regulator_set_enable_if_allowed(priv->reg, true); + if (ret && ret != -ENOSYS) { + debug("%s: failed to enable regulator '%s' %d\n", + __func__, priv->reg->name, ret); + return ret; }
switch (dsi_data) {
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/tegra20/tegra-dsi.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/video/tegra20/tegra-dsi.c b/drivers/video/tegra20/tegra-dsi.c index 8c3404e085..b4cf4fad5e 100644 --- a/drivers/video/tegra20/tegra-dsi.c +++ b/drivers/video/tegra20/tegra-dsi.c @@ -831,11 +831,9 @@ static int tegra_dsi_bridge_probe(struct udevice *dev)
tegra_dsi_get_format(device->format, &priv->format);
- if (priv->avdd) { - ret = regulator_set_enable(priv->avdd, true); - if (ret) - return ret; - } + ret = regulator_set_enable_if_allowed(priv->avdd, true); + if (ret && ret != -ENOSYS) + return ret;
tegra_dsi_init_clocks(dev);
Svyatoslav Ryhel
