[PATCH] arm: add initial support for the Phytium Pomelo Board
This adds platform code and the device tree for the Phytium Pomelo Board. The initial support comprises the UART and the PCIE.
Signed-off-by: weichangzheng nicholas_zheng@outlook.com --- arch/arm/Kconfig | 8 ++ arch/arm/dts/Makefile | 1 + arch/arm/dts/phytium-pomelo.dts | 103 +++++++++++++++++++ board/phytium/pomelo/Kconfig | 12 +++ board/phytium/pomelo/MAINTAINERS | 8 ++ board/phytium/pomelo/Makefile | 14 +++ board/phytium/pomelo/cpu.h | 73 ++++++++++++++ board/phytium/pomelo/ddr.c | 164 +++++++++++++++++++++++++++++++ board/phytium/pomelo/pcie.c | 61 ++++++++++++ board/phytium/pomelo/pll.c | 75 ++++++++++++++ board/phytium/pomelo/pomelo.c | 120 ++++++++++++++++++++++ board/phytium/pomelo/sec.c | 40 ++++++++ configs/pomelo_defconfig | 36 +++++++ include/configs/pomelo.h | 45 +++++++++ 14 files changed, 760 insertions(+) create mode 100644 arch/arm/dts/phytium-pomelo.dts create mode 100644 board/phytium/pomelo/Kconfig create mode 100644 board/phytium/pomelo/MAINTAINERS create mode 100644 board/phytium/pomelo/Makefile create mode 100644 board/phytium/pomelo/cpu.h create mode 100644 board/phytium/pomelo/ddr.c create mode 100644 board/phytium/pomelo/pcie.c create mode 100644 board/phytium/pomelo/pll.c create mode 100644 board/phytium/pomelo/pomelo.c create mode 100644 board/phytium/pomelo/sec.c create mode 100644 configs/pomelo_defconfig create mode 100644 include/configs/pomelo.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 31d687ea01..6110fcddad 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1800,6 +1800,13 @@ config TARGET_DURIAN Support for durian platform. It has 2GB Sdram, uart and pcie.
+config TARGET_POMELO + bool "Support Phytium Pomelo Platform" + select ARM64 + help + Support for pomelo platform. + It has 2GB Sdram, uart and pcie. + config TARGET_PRESIDIO_ASIC bool "Support Cortina Presidio ASIC Platform" select ARM64 @@ -2019,6 +2026,7 @@ source "board/toradex/colibri_pxa270/Kconfig" source "board/variscite/dart_6ul/Kconfig" source "board/vscom/baltos/Kconfig" source "board/phytium/durian/Kconfig" +source "board/phytium/pomelo/Kconfig" source "board/xen/xenguest_arm64/Kconfig" source "board/keymile/Kconfig"
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 096068261d..c26692c17e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1098,6 +1098,7 @@ dtb-$(CONFIG_TARGET_MX53PPD) += imx53-ppd.dtb dtb-$(CONFIG_TARGET_TOTAL_COMPUTE) += total_compute.dtb
dtb-$(CONFIG_TARGET_DURIAN) += phytium-durian.dtb +dtb-$(CONFIG_TARGET_POMELO) += phytium-pomelo.dtb
dtb-$(CONFIG_TARGET_PRESIDIO_ASIC) += ca-presidio-engboard.dtb
diff --git a/arch/arm/dts/phytium-pomelo.dts b/arch/arm/dts/phytium-pomelo.dts new file mode 100644 index 0000000000..4961682058 --- /dev/null +++ b/arch/arm/dts/phytium-pomelo.dts @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * dts file for Phytium Pomelo board + * Copyright (C) 2021, Phytium Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ +/dts-v1/; + +/memreserve/ 0x0000000080000000 0x0000000000100000; +/ { + model = "Phytium Pomelo"; + compatible = "phytium,pomelo"; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <0x2>; + #size-cells = <0x0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,armv8"; + reg = <0x0 0x0>; + enable-method = "psci"; + numa-node-id = <0>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,armv8"; + reg = <0x0 0x1>; + enable-method = "psci"; + numa-node-id = <0>; + }; + + cpu4: cpu@4 { + device_type = "cpu"; + compatible = "arm,armv8"; + reg = <0x0 0x100>; + enable-method = "psci"; + numa-node-id = <0>; + }; + + cpu5: cpu@5 { + device_type = "cpu"; + compatible = "arm,armv8"; + reg = <0x0 0x101>; + enable-method = "psci"; + numa-node-id = <0>; + }; + + cpu8: cpu@8 { + device_type = "cpu"; + compatible = "arm,armv8"; + reg = <0x0 0x200>; + enable-method = "psci"; + numa-node-id = <0>; + }; + + cpu9: cpu@9 { + device_type = "cpu"; + compatible = "arm,armv8"; + reg = <0x0 0x201>; + enable-method = "psci"; + numa-node-id = <0>; + }; + + cpu12: cpu@12 { + device_type = "cpu"; + compatible = "arm,armv8"; + reg = <0x0 0x300>; + enable-method = "psci"; + numa-node-id = <0>; + }; + + cpu13: cpu@13 { + device_type = "cpu"; + compatible = "arm,armv8"; + reg = <0x0 0x301>; + enable-method = "psci"; + numa-node-id = <0>; + }; + }; + + pcie-controller@40000000 { + compatible = "pci-host-ecam-generic"; + device_type = "pci"; + #address-cells = <3>; + #size-cells = <2>; + reg = <0x0 0x40000000 0x0 0x10000000>; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x00 0x00000000 0x0 0x50000000 0x0 0x00F00000>, + <0x02000000 0x00 0x58000000 0x0 0x58000000 0x0 0x28000000>, + <0x43000000 0x10 0x00000000 0x10 0x00000000 0x10 0x00000000>; + }; + + uart@28001000 { + compatible = "arm,pl011"; + reg = <0x0 0x28001000 0x0 0x1000>; + clock = <48000000>; + }; +}; diff --git a/board/phytium/pomelo/Kconfig b/board/phytium/pomelo/Kconfig new file mode 100644 index 0000000000..281aa8feff --- /dev/null +++ b/board/phytium/pomelo/Kconfig @@ -0,0 +1,12 @@ +if TARGET_POMELO + +config SYS_BOARD + default "pomelo" + +config SYS_VENDOR + default "phytium" + +config SYS_CONFIG_NAME + default "pomelo" + +endif diff --git a/board/phytium/pomelo/MAINTAINERS b/board/phytium/pomelo/MAINTAINERS new file mode 100644 index 0000000000..950449392b --- /dev/null +++ b/board/phytium/pomelo/MAINTAINERS @@ -0,0 +1,8 @@ +POMELO BOARD +M: lixinde lixinde@phytium.com.cn +M: weichangzheng weichangzheng@phytium.com.cn +S: Maintained +F: board/phytium/pomelo/* +F: include/configs/pomelo.h +F: configs/pomelo_defconfig + diff --git a/board/phytium/pomelo/Makefile b/board/phytium/pomelo/Makefile new file mode 100644 index 0000000000..b9cb3609bd --- /dev/null +++ b/board/phytium/pomelo/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2021 +# lixinde lixinde@phytium.com.cn +# weichangzheng weichangzheng@phytium.com.cn +# + +obj-y += pomelo.o +obj-y += pll.o +obj-y += pcie.o +obj-y += ddr.o +obj-y += sec.o + + diff --git a/board/phytium/pomelo/cpu.h b/board/phytium/pomelo/cpu.h new file mode 100644 index 0000000000..e15917609b --- /dev/null +++ b/board/phytium/pomelo/cpu.h @@ -0,0 +1,73 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2021 + * Phytium Technology Ltd <www.phytium.com> + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#ifndef _FT_POMELO_H +#define _FT_POMELO_H + +/* SMCCC ID */ +#define CPU_SVC_VERSION 0xC2000F00 +#define CPU_GET_RST_SOURCE 0xC2000F01 +#define CPU_INIT_PLL 0xC2000F02 +#define CPU_INIT_PCIE 0xC2000F03 +#define CPU_INIT_MEM 0xC2000F04 +#define CPU_INIT_SEC_SVC 0xC2000F05 + +/*CPU RESET*/ +#define CPU_RESET_POWER_ON 0x1 +#define CPU_RESET_PLL 0x4 +#define CPU_RESET_WATCH_DOG 0x8 + +/* PLL */ +#define PARAMETER_PLL_MAGIC 0x54460010 + +/* PCIE */ +#define PARAMETER_PCIE_MAGIC 0x54460011 +#define CONFIG_INDEPENDENT_TREE 0x0 +#define PCI_PEU0 0x1 +#define PCI_PEU1 0x1 +#define PEU1_OFFSET 16 +#define PEU_C_OFFSET_MODE 16 +#define PEU_C_OFFSET_SPEED 0 +#define RC_MODE 0x1 +#define X8X8 0x1 +#define GEN3 3 + +/* DDR */ +#define PARAMETER_MCU_MAGIC 0x54460014 +#define PARAM_MCU_VERSION 0x1 +#define PARAM_MCU_SIZE 0x100 +#define PARAM_CH_ENABLE 0x3 +#define PARAM_ECC_ENABLE 0x3 +#define PARAM_FORCE_SPD_DISABLE 0x0 +#define PARAM_MCU_MISC_ENABLE 0x0 + +#define UDIMM_TYPE 0x2 +#define DIMM_X8 0x1 +#define NO_MIRROR 0x0 +#define NO_ECC_TYPE 0 +#define DDR4_TYPE 0xC + +/* SEC */ +#define PARAMETER_COMMON_MAGIC 0x54460013 + +/* FLUSH L3 CASHE */ +#define HNF_COUNT 0x8 +#define HNF_PSTATE_REQ (HNF_BASE + 0x10) +#define HNF_PSTATE_STAT (HNF_BASE + 0x18) +#define HNF_PSTATE_OFF 0x0 +#define HNF_PSTATE_SFONLY 0x1 +#define HNF_PSTATE_HALF 0x2 +#define HNF_PSTATE_FULL 0x3 +#define HNF_STRIDE 0x10000 +#define HNF_BASE (unsigned long)(0x3A200000) +void ddr_init(void); +void sec_init(void); +void check_reset(void); +void pcie_init(void); + +#endif /* _FT_POMELO_H */ diff --git a/board/phytium/pomelo/ddr.c b/board/phytium/pomelo/ddr.c new file mode 100644 index 0000000000..88756f5fc1 --- /dev/null +++ b/board/phytium/pomelo/ddr.c @@ -0,0 +1,164 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <linux/arm-smccc.h> +#include "cpu.h" + +struct ddr_spd { + /******************* read from spd *****************/ + unsigned char dimm_type; /* 1: RDIMM;2: UDIMM;3: SODIMM;4: LRDIMM */ + unsigned char data_width; /* 0: x4; 1: x8; 2: x16 */ + unsigned char mirror_type; /* 0: stardard; 1: mirror */ + unsigned char ecc_type; /* 0: no-ecc; 1:ecc */ + unsigned char dram_type; /* 0xB: DDR3; 0xC: DDR4 */ + unsigned char rank_num; + unsigned char row_num; + unsigned char col_num; + + unsigned char bg_num; /*only DDR4*/ + unsigned char bank_num; + unsigned short int module_manufacturer_id; + unsigned short int taamin; + unsigned short int trcdmin; + + unsigned short int trpmin; + unsigned short int trasmin; + unsigned short int trcmin; + unsigned short int tfawmin; + + unsigned short int trrd_smin; /*only DDR4*/ + unsigned short int trrd_lmin; /*only DDR4*/ + unsigned short int tccd_lmin; /*only DDR4*/ + unsigned short int twrmin; + + unsigned short int twtr_smin; /*only DDR4*/ + unsigned short int twtr_lmin; /*only DDR4*/ + unsigned short int twtrmin; /*only DDR3*/ + unsigned short int trrdmin; /*only DDR3*/ + + /******************* RCD control words *****************/ + unsigned char f0rc03; /*bit[3:2]:CS bit[1:0]:CA */ + unsigned char f0rc04; /*bit[3:2]:ODT bit[1:0]:CKE */ + unsigned char f0rc05; /*bit[3:2]:CLK-A side bit[1:0]:CLK-B side */ + unsigned char bc00; + unsigned char bc01; + unsigned char bc02; + unsigned char bc03; + unsigned char bc04; + + unsigned char bc05; + unsigned char f5bc5x; + unsigned char f5bc6x; + /******************* LRDIMM special *****************/ + unsigned char vrefdq_pr0; + unsigned char vrefdq_mdram; + unsigned char rtt_mdram_1866; + unsigned char rtt_mdram_2400; + unsigned char rtt_mdram_3200; + + unsigned char drive_dram; + unsigned char odt_dram_1866; + unsigned char odt_dram_2400; + unsigned char odt_dram_3200; + unsigned char park_dram_1866; + unsigned char park_dram_2400; + unsigned char park_dram_3200; + unsigned char rcd_num; +} __attribute((aligned(4))); + +struct mcu_config { + unsigned int magic; + unsigned int version; + unsigned int size; + unsigned char rev1[4]; + + unsigned char ch_enable; + unsigned char misc1_enable; + unsigned char misc2_enable; + unsigned char force_spd_enable; + unsigned char misc3_enable; + unsigned char train_debug; + unsigned char train_recover; + unsigned char rev2[9]; + + struct ddr_spd ddr_spd_info[2]; +} __attribute((aligned(4))); + +static void get_mcu_up_info_default(struct mcu_config *pm) +{ + pm->magic = PARAMETER_MCU_MAGIC; + pm->version = PARAM_MCU_VERSION; + pm->size = PARAM_MCU_SIZE; + pm->ch_enable = PARAM_CH_ENABLE; + pm->misc1_enable = PARAM_ECC_ENABLE; + pm->force_spd_enable = PARAM_FORCE_SPD_DISABLE; + pm->misc3_enable = PARAM_MCU_MISC_ENABLE; + pm->train_recover = 0x0; +} + +static unsigned char init_dimm_param(unsigned char ch, struct mcu_config *pm) +{ + printf("manual config dimm info...\n"); + pm->ddr_spd_info[ch].dimm_type = UDIMM_TYPE; + pm->ddr_spd_info[ch].data_width = DIMM_X8; + pm->ddr_spd_info[ch].mirror_type = NO_MIRROR; + pm->ddr_spd_info[ch].ecc_type = NO_ECC_TYPE; + pm->ddr_spd_info[ch].dram_type = DDR4_TYPE; + pm->ddr_spd_info[ch].rank_num = 1; + pm->ddr_spd_info[ch].row_num = 16; + pm->ddr_spd_info[ch].col_num = 10; + pm->ddr_spd_info[ch].bg_num = 4; + pm->ddr_spd_info[ch].bank_num = 4; + pm->ddr_spd_info[ch].taamin = 13750; + pm->ddr_spd_info[ch].trcdmin = 13750; + + pm->ddr_spd_info[ch].trpmin = 13750; + pm->ddr_spd_info[ch].trasmin = 32000; + pm->ddr_spd_info[ch].trcmin = 45750; + pm->ddr_spd_info[ch].tfawmin = 21000; + + pm->ddr_spd_info[ch].trrd_smin = 3000; + pm->ddr_spd_info[ch].trrd_lmin = 4900; + pm->ddr_spd_info[ch].tccd_lmin = 5000; + pm->ddr_spd_info[ch].twrmin = 15000; + + pm->ddr_spd_info[ch].twtr_smin = 2500; + pm->ddr_spd_info[ch].twtr_lmin = 7500; + + return 0; +} + +void get_default_mcu_info(unsigned char *data) +{ + get_mcu_up_info_default((struct mcu_config *)data); +} + +void fix_mcu_info(unsigned char *data) +{ + unsigned char ch; + struct mcu_config *mcu_info = (struct mcu_config *)data; + + for (ch = 0; ch < 2; ch++) + init_dimm_param(ch, mcu_info); +} + +void ddr_init(void) +{ + unsigned char buffer[0x100]; + struct arm_smccc_res res; + + get_default_mcu_info(buffer); + fix_mcu_info(buffer); + + arm_smccc_smc(CPU_INIT_MEM, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) { + printf("error x0: 0x%lx, x1: 0x%lx\n", res.a0, res.a1); + while (true) + ; + } +} diff --git a/board/phytium/pomelo/pcie.c b/board/phytium/pomelo/pcie.c new file mode 100644 index 0000000000..3754d8eb9b --- /dev/null +++ b/board/phytium/pomelo/pcie.c @@ -0,0 +1,61 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <linux/arm-smccc.h> +#include "cpu.h" + +struct pcu_ctr { + unsigned int base_config[3]; + unsigned int equalization[3]; + unsigned char rev[80]; +} __attribute((aligned(4))); + +struct pcu_config { + unsigned int magic; + unsigned int version; + unsigned int size; + unsigned char rev1[4]; + unsigned int independent_tree; + unsigned int base_cfg; + unsigned char rev2[16]; + struct pcu_ctr ctr_cfg[2]; +} __attribute((aligned(4))); + +struct pcu_config const peu_base_info = { + .magic = PARAMETER_PCIE_MAGIC, + .version = 0x2, + .size = 0x100, + .independent_tree = CONFIG_INDEPENDENT_TREE, + .base_cfg = ((PCI_PEU1 | (X8X8 << 1)) << PEU1_OFFSET | (PCI_PEU0 | (X8X8 << 1))), + .ctr_cfg[0].base_config[0] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].base_config[1] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].base_config[2] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[0] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[1] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[2] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].equalization[0] = 0x7, + .ctr_cfg[0].equalization[1] = 0x7, + .ctr_cfg[0].equalization[2] = 0x7, + .ctr_cfg[1].equalization[0] = 0x7, + .ctr_cfg[1].equalization[1] = 0x7, + .ctr_cfg[1].equalization[2] = 0x7, +}; + +void pcie_init(void) +{ + unsigned char buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &peu_base_info, sizeof(peu_base_info)); + arm_smccc_smc(CPU_INIT_PCIE, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) { + while (true) + ; + } +} diff --git a/board/phytium/pomelo/pll.c b/board/phytium/pomelo/pll.c new file mode 100644 index 0000000000..1227b7dd80 --- /dev/null +++ b/board/phytium/pomelo/pll.c @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <asm/io.h> +#include <linux/arm-smccc.h> +#include "cpu.h" + +struct pll_config { + unsigned int magic; + unsigned int version; + unsigned int size; + unsigned char rev1[4]; + unsigned int core_pll; + unsigned int res1; + unsigned int lmu_pll; + unsigned int res2; + unsigned int res3; + unsigned int res4; + unsigned int res5; +} __attribute((aligned(4))); + +struct pll_config const pll_base_info = { + .magic = PARAMETER_PLL_MAGIC, + .version = 0x1, + .size = 0x30, + .core_pll = 2300, /*MHz*/ + .lmu_pll = 667, /*MHz*/ +}; + +unsigned int get_reset_source(void) +{ + struct arm_smccc_res res; + + arm_smccc_smc(CPU_GET_RST_SOURCE, 0, 0, 0, 0, 0, 0, 0, &res); + return res.a0; +} + +void pll_init(void) +{ + unsigned char buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &pll_base_info, sizeof(pll_base_info)); + arm_smccc_smc(CPU_INIT_PLL, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) { + while (true) + ; + } +} + +void check_reset(void) +{ + unsigned int rst; + + rst = get_reset_source(); + + switch (rst) { + case CPU_RESET_POWER_ON: + pll_init(); + break; + case CPU_RESET_PLL: + break; + case CPU_RESET_WATCH_DOG: + break; + default: + while (true) + ; + } +} diff --git a/board/phytium/pomelo/pomelo.c b/board/phytium/pomelo/pomelo.c new file mode 100644 index 0000000000..693e891d20 --- /dev/null +++ b/board/phytium/pomelo/pomelo.c @@ -0,0 +1,120 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <command.h> +#include <init.h> +#include <asm/armv8/mmu.h> +#include <asm/io.h> +#include <linux/arm-smccc.h> +#include <scsi.h> +#include "cpu.h" + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->mem_clk = 0; + gd->ram_size = PHYS_SDRAM_1_SIZE; + + printf("Phytium ddr init\n"); + + ddr_init(); + sec_init(); + printf("PBF relocate done\n"); + + return 0; +} + +int board_init(void) +{ + return 0; +} + +void reset_cpu(void) +{ + struct arm_smccc_res res; + + printf("run in reset cpu\n"); + arm_smccc_smc(0x84000009, 0, 0, 0, 0, 0, 0, 0, &res); + printf("reset cpu error, %lx\n", res.a0); +} + +int mach_cpu_init(void) +{ + check_reset(); + return 0; +} + +int board_early_init_f(void) +{ + pcie_init(); + return 0; +} + +int board_early_init_r(void) +{ + return 0; +} + +static struct mm_region pomelo_mem_map[] = { + { + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | + PTE_BLOCK_UXN + }, + { + .virt = (u64)PHYS_SDRAM_1, + .phys = (u64)PHYS_SDRAM_1, + .size = (u64)PHYS_SDRAM_1_SIZE, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_NS | + PTE_BLOCK_INNER_SHARE + }, + { + 0, + } +}; + +struct mm_region *mem_map = pomelo_mem_map; + +int __asm_flush_l3_dcache(void) +{ + int i, pstate; + + for (i = 0; i < HNF_COUNT; i++) + writeq(HNF_PSTATE_SFONLY, HNF_PSTATE_REQ + i * HNF_STRIDE); + for (i = 0; i < HNF_COUNT; i++) { + do { + pstate = readq(HNF_PSTATE_STAT + i * HNF_STRIDE); + } while ((pstate & 0xf) != (HNF_PSTATE_SFONLY << 2)); + } + + for (i = 0; i < HNF_COUNT; i++) + writeq(HNF_PSTATE_FULL, HNF_PSTATE_REQ + i * HNF_STRIDE); + + return 0; +} + +int last_stage_init(void) +{ + int ret; + + /* pci e */ + pci_init(); + /* scsi scan */ + ret = scsi_scan(true); + if (ret) { + printf("scsi scan failed\n"); + return CMD_RET_FAILURE; + } + return ret; +} diff --git a/board/phytium/pomelo/sec.c b/board/phytium/pomelo/sec.c new file mode 100644 index 0000000000..8ec0fa797b --- /dev/null +++ b/board/phytium/pomelo/sec.c @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <linux/arm-smccc.h> +#include "cpu.h" + +struct common_config { + unsigned int magic; + unsigned int version; + unsigned int size; + unsigned char rev1[4]; + unsigned long long core_bit_map; +} __attribute((aligned(4))); + +struct common_config const common_base_info = { + .magic = PARAMETER_COMMON_MAGIC, + .version = 0x1, + .core_bit_map = 0x3333, +}; + +void sec_init(void) +{ + unsigned char buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &common_base_info, sizeof(common_base_info)); + arm_smccc_smc(CPU_INIT_SEC_SVC, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + + if (res.a0 != 0) { + printf("error ret %lx\n", res.a0); + while (true) + ; + } +} diff --git a/configs/pomelo_defconfig b/configs/pomelo_defconfig new file mode 100644 index 0000000000..3e6c18196d --- /dev/null +++ b/configs/pomelo_defconfig @@ -0,0 +1,36 @@ +CONFIG_ARM=y +CONFIG_ARM_SMCCC=y +CONFIG_TARGET_POMELO=y +CONFIG_SYS_TEXT_BASE=0x180000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +# CONFIG_PSCI_RESET is not set +CONFIG_DEFAULT_DEVICE_TREE="phytium-pomelo" +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 earlycon=pl011,0x28001000 root=/dev/sda2 rw" +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_LAST_STAGE_INIT=y +CONFIG_SYS_PROMPT="pomelo#" +# CONFIG_CMD_LZMADEC is not set +# CONFIG_CMD_UNZIP is not set +CONFIG_CMD_PCI=y +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +# CONFIG_NET is not set +CONFIG_DM=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_BLK=y +# CONFIG_MMC is not set +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_PHYTIUM=y +CONFIG_PCIE_ECAM_GENERIC=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_PL01X_SERIAL=y diff --git a/include/configs/pomelo.h b/include/configs/pomelo.h new file mode 100644 index 0000000000..69c4195d86 --- /dev/null +++ b/include/configs/pomelo.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#ifndef __POMELO_CONFIG_H__ +#define __POMELO_CONFIG_H__ + +/* SDRAM Bank #1 start address */ +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE 0x7B000000 +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x10000000) + +/* SIZE of malloc pool */ +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024 + CONFIG_ENV_SIZE) +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R + +#define CONFIG_SYS_INIT_SP_ADDR (0x29800000 + 0x1a000) + +/* PCI CONFIG */ +#define CONFIG_SYS_PCI_64BIT 1 +#define CONFIG_PCI_SCAN_SHOW + +/* SCSI */ +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 4 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE 128 +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SATA_MAX_DEVICE 4 + +/*BOOT*/ +#define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "load_kernel=ext4load scsi 0:1 0x90100000 uImage_old\0" \ + "load_fdt=ext4load scsi 0:1 0x95000000 ft-d2000.dtb\0"\ + "boot_fdt=bootm 0x90100000 -:- 0x17c000\0" \ + "distro_bootcmd=run load_kernel; run boot_fdt" + +#endif
