[U-Boot] [PATCH] powerpc/usb: fix usb mode and phy_type
Currently, to make usb work as different modes, we need to set its' dr_mode string in 'hwconfig', and it will be handled by fdt_fixup_usb_mode_phy_type(). This API has a hardcoded compat which is "fsl-usb2-dr", so it should not be called when handle the 'hwconfig' for 'usb1', 'usb1' has a compat of "fsl-usb2-mph" in dts, otherwise, dr_mode of 'usb2' will be set when handling 'usb1', and this will cause error when handling 'usb2'.
Also, sometimes "phy_type" may need to be set for both USB controllers, hardcoded compat is limited to handle this, so add compat "fsl-usb2-mph" handle in the API.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- arch/powerpc/cpu/mpc8xxx/fdt.c | 40 +++++++++++++++++++--------------------- 1 files changed, 19 insertions(+), 21 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index 112c603..a2b56ae 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -88,9 +88,9 @@ void ft_fixup_num_cores(void *blob) {
#ifdef CONFIG_HAS_FSL_DR_USB static void fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, - const char *phy_type) + const char *phy_type, int port) { - const char *compat = "fsl-usb2-dr"; + const char *compat[] = {"fsl-usb2-mph", "fsl-usb2-dr"}; const char *prop_mode = "dr_mode"; const char *prop_type = "phy_type"; static int start_offset = -1; @@ -98,27 +98,27 @@ static void fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, int err;
node_offset = fdt_node_offset_by_compatible(blob, - start_offset, compat); + start_offset, compat[port]); if (node_offset < 0) { printf("WARNING: could not find compatible node %s: %s.\n", - compat, fdt_strerror(node_offset)); + compat[port], fdt_strerror(node_offset)); return; }
- if (mode) { + if (strlen(mode)) { err = fdt_setprop(blob, node_offset, prop_mode, mode, strlen(mode) + 1); if (err < 0) printf("WARNING: could not set %s for %s: %s.\n", - prop_mode, compat, fdt_strerror(err)); + prop_mode, compat[port], fdt_strerror(err)); }
- if (phy_type) { + if (strlen(phy_type)) { err = fdt_setprop(blob, node_offset, prop_type, phy_type, strlen(phy_type) + 1); if (err < 0) printf("WARNING: could not set %s for %s: %s.\n", - prop_type, compat, fdt_strerror(err)); + prop_type, compat[port], fdt_strerror(err)); }
start_offset = node_offset; @@ -126,8 +126,8 @@ static void fdt_fixup_usb_mode_phy_type(void *blob, const char *mode,
void fdt_fixup_dr_usb(void *blob, bd_t *bd) { - const char *modes[] = { "host", "peripheral", "otg" }; - const char *phys[] = { "ulpi", "umti" }; + const char *modes[] = { "", "host", "peripheral", "otg" }; + const char *phys[] = { "", "ulpi", "umti" }; const char *mode = NULL; const char *phy_type = NULL; char usb1_defined = 0; @@ -135,7 +135,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) int i, j;
for (i = 1; i <= FSL_MAX_NUM_USB_CTRLS; i++) { - int mode_idx = -1, phy_idx = -1; + int mode_idx = 0, phy_idx = 0; sprintf(str, "%s%d", "usb", i); if (hwconfig(str)) { for (j = 0; j < sizeof(modes); j++) { @@ -152,16 +152,14 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) break; } } - if (mode_idx >= 0) - fdt_fixup_usb_mode_phy_type(blob, - modes[mode_idx], NULL); - if (phy_idx >= 0) - fdt_fixup_usb_mode_phy_type(blob, - NULL, phys[phy_idx]); - if (!strcmp(str, "usb1")) - usb1_defined = 1; - if (mode_idx < 0 && phy_idx < 0) + if (!mode_idx && !phy_idx) { printf("WARNING: invalid phy or mode\n"); + } else { + fdt_fixup_usb_mode_phy_type(blob, + modes[mode_idx], phys[phy_idx], i - 1); + if (!strcmp(str, "usb1")) + usb1_defined = 1; + } } } if (!usb1_defined) { @@ -169,7 +167,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) phy_type = getenv("usb_phy_type"); if (!mode && !phy_type) return; - fdt_fixup_usb_mode_phy_type(blob, mode, phy_type); + fdt_fixup_usb_mode_phy_type(blob, modes[1], phys[1], 0); } } #endif /* CONFIG_HAS_FSL_DR_USB */
Shaohui Xie
