[U-Boot] [PATCH 1/3] arm: dra76: fastboot: extend cpu type for getvar command
'commit dda0bd674481 ("arm: dra762: Add support for device package identification")' introduces ABZ and ACD package identification.
This patch is to extend usage of "fastboot getvar cpu" for DRA76x ABZ and ACD devices.
Helps in fixing the boot warning.
Warning: fastboot.cpu: unknown CPU rev: 123863298 on CPU : DRA762-GP ES1.0 ABZ package Model: TI AM5748 IDK Board: AM574x IDK REV 1.0A
Signed-off-by: Praneeth Bajjuri praneeth@ti.com --- arch/arm/mach-omap2/utils.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-omap2/utils.c b/arch/arm/mach-omap2/utils.c index 1d39625..391055e 100644 --- a/arch/arm/mach-omap2/utils.c +++ b/arch/arm/mach-omap2/utils.c @@ -30,6 +30,8 @@ static void omap_set_fastboot_cpu(void)
switch (cpu_rev) { case DRA762_ES1_0: + case DRA762_ABZ_ES1_0: + case DRA762_ACD_ES1_0: cpu = "DRA762"; break; case DRA752_ES1_0:
Only one patch in the series.
Wrong subject [PATCH 1/3]
- case DRA762_ABZ_ES1_0:
- case DRA762_ACD_ES1_0: cpu = "DRA762"; break; case DRA752_ES1_0:
Signed-off-by: Praneeth Bajjuri praneeth@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Bajjuri, Praneeth
Praneeth Bajjuri
