[U-Boot] [PATCH 01/11] powerpc/mpc85xx: Enable L2 at the beginning of U-boot for E6500
Using E6500 L1 cache as initram requires L2 cache enabled. Add l2-cache cluster enabling.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 39 ++++++++++++++++++++++- arch/powerpc/cpu/mpc85xx/start.S | 57 +++++++++++++++++++++++++++++++++ arch/powerpc/include/asm/immap_85xx.h | 43 +++++++++++++++++++++++++ 3 files changed, 138 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 2c78905..1a2858a 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -309,6 +309,34 @@ static void __fsl_serdes__init(void) } __attribute__((weak, alias("__fsl_serdes__init"))) void fsl_serdes_init(void);
+#ifdef CONFIG_E6500 +int enable_cluster_l2(void) +{ + int i = 0; + u32 cluster; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + struct ccsr_cluster_l2 *l2cache; + + cluster = in_be32(&gur->tp_cluster[i++].lower); + if (cluster & TP_CLUSTER_EOC) + return 0; + + do { + l2cache = (void *)(CONFIG_SYS_FSL_CLUSTER_1_L2 + i * 0x40000); + cluster = in_be32(&gur->tp_cluster[i++].lower); + + printf("enable l2 for cluster %d %p\n", i, l2cache); + + out_be32(&l2cache->l2csr0, L2CSR0_L2FI|L2CSR0_L2LFC); + while ((in_be32(&l2cache->l2csr0) & (L2CSR0_L2FI|L2CSR0_L2LFC)) != 0) + ; + out_be32(&l2cache->l2csr0, L2CSR0_L2E); + } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC); + + return 0; +} +#endif + /* * Initialize L2 as cache. * @@ -322,6 +350,11 @@ int cpu_init_r(void) #ifdef CONFIG_SYS_LBC_LCRR volatile fsl_lbc_t *lbc = LBC_BASE_ADDR; #endif +#ifdef CONFIG_L2_CACHE + volatile ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; +#elif defined(CONFIG_E6500) + struct ccsr_cluster_l2 * l2cache = (void *)CONFIG_SYS_FSL_CLUSTER_1_L2; +#endif
#if defined(CONFIG_SYS_P4080_ERRATUM_CPU22) || \ defined(CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011) @@ -363,7 +396,6 @@ int cpu_init_r(void) puts ("L2: ");
#if defined(CONFIG_L2_CACHE) - volatile ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; volatile uint cache_ctl; uint ver; u32 l2siz_field; @@ -474,6 +506,11 @@ int cpu_init_r(void) }
skip_l2: +#elif defined(CONFIG_E6500) + if (l2cache->l2csr0 & L2CSR0_L2E) + printf("%d KB enabled\n", (l2cache->l2cfg0 & 0x3fff) * 64); + + enable_cluster_l2(); #else puts("disabled\n"); #endif diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 2e1d265..739127f 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -762,6 +762,63 @@ delete_temp_tlbs: tlbwe #endif /* #if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) */
+#ifdef CONFIG_E6500 +create_ccsr_l2_tlb: + /* + * Create a TLB for the MMR location of CCSR + * to access L2CSR0 register + */ + lis r0, FSL_BOOKE_MAS0(0, 0, 0)@h + ori r0, r0, FSL_BOOKE_MAS0(0, 0, 0)@l + lis r1, FSL_BOOKE_MAS1(1, 0, 0, 0, BOOKE_PAGESZ_4K)@h + ori r1, r1, FSL_BOOKE_MAS1(1, 0, 0, 0, BOOKE_PAGESZ_4K)@l + lis r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0xC20000, (MAS2_I|MAS2_G))@h + ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0xC20000, (MAS2_I|MAS2_G))@l + lis r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS_LOW + 0xC20000, 0, (MAS3_SW|MAS3_SR))@h + ori r3, r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS_LOW + 0xC20000, 0, (MAS3_SW|MAS3_SR))@l + lis r7, CONFIG_SYS_CCSRBAR_PHYS_HIGH@h + ori r7, r7, CONFIG_SYS_CCSRBAR_PHYS_HIGH@l + mtspr MAS0, r0 + mtspr MAS1, r1 + mtspr MAS2, r2 + mtspr MAS3, r3 + mtspr MAS7, r7 + isync + msync + tlbwe +enable_l2_e6500: + /* enable L2 cache */ + lis r3, (CONFIG_SYS_CCSRBAR + 0xC20000)@h + ori r3, r3, (CONFIG_SYS_CCSRBAR + 0xC20000)@l + lis r4, (L2CSR0_L2FI|L2CSR0_L2LFC)@h + ori r4, r4, (L2CSR0_L2FI|L2CSR0_L2LFC)@l + sync + stw r4, 0(r3) /* invalidate L2 */ +1: sync + lwz r0, 0(r3) + twi 0, r0, 0 + isync + and. r1, r0, r4 + bne 1b + lis r4, L2CSR0_L2E@h + sync + stw r4, 0(r3) /* eanble L2 */ +delete_ccsr_l2_tlb: + lis r0, FSL_BOOKE_MAS0(0, 0, 0)@h + ori r0, r0, FSL_BOOKE_MAS0(0, 0, 0)@l + li r1, 0 + lis r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR, (MAS2_I|MAS2_G))@h + ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR, (MAS2_I|MAS2_G))@l + mtspr MAS0, r0 + mtspr MAS1, r1 + mtspr MAS2, r2 + isync + msync + tlbwe + li r3, 0 + mtspr MAS7, r3 +#endif + #ifdef CONFIG_SYS_FSL_ERRATUM_A004510 #define DCSR_LAWBARH0 (CONFIG_SYS_CCSRBAR + 0x1000) #define LAW_SIZE_1M 0x13 diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 7ce27db..62d8d0b 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2789,6 +2789,7 @@ typedef struct ccsr_snvs_regs { #define CONFIG_SYS_FSL_FM2_RX4_1G_OFFSET 0x58c000 #define CONFIG_SYS_FSL_FM2_RX0_10G_OFFSET 0x590000 #define CONFIG_SYS_FSL_PAMU1_OFFSET 0x21000 +#define CONFIG_SYS_FSL_CLUSTER_1_L2_OFFSET 0xC20000 #else #define CONFIG_SYS_MPC85xx_ECM_OFFSET 0x0000 #define CONFIG_SYS_MPC85xx_DDR_OFFSET 0x2000 @@ -2946,4 +2947,46 @@ typedef struct ccsr_snvs_regs { #define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) #define MDIO_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MDIO1_OFFSET)
+#ifdef CONFIG_E6500 +struct ccsr_cluster_l2 { + u32 l2csr0; /* 0x000 L2 cache control and status register 0 */ + u32 l2csr1; /* 0x004 L2 cache control and status register 1 */ + u32 l2cfg0; /* 0x008 L2 cache configuration register 0 */ + u8 res_0c[500];/* 0x00c - 0x1ff */ + u32 l2pir0; /* 0x200 L2 cache partitioning ID register 0 */ + u8 res_204[4]; + u32 l2par0; /* 0x208 L2 cache partitioning allocation register 0 */ + u32 l2pwr0; /* 0x20c L2 cache partitioning way register 0 */ + u32 l2pir1; /* 0x210 L2 cache partitioning ID register 1 */ + u8 res_214[4]; + u32 l2par1; /* 0x218 L2 cache partitioning allocation register 1 */ + u32 l2pwr1; /* 0x21c L2 cache partitioning way register 1 */ + u32 u2pir2; /* 0x220 L2 cache partitioning ID register 2 */ + u8 res_224[4]; + u32 l2par2; /* 0x228 L2 cache partitioning allocation register 2 */ + u32 l2pwr2; /* 0x22c L2 cache partitioning way register 2 */ + u32 l2pir3; /* 0x230 L2 cache partitioning ID register 3 */ + u8 res_234[5]; + u32 l2par3; /* 0x238 L2 cache partitining allocation register 3 */ + u32 l2pwr3; /* 0x23c L2 cache partitining way register 3 */ + u8 res_240[3008]; /* 0x240 - 0xdff */ + u32 l2errinjhi; /* 0xe00 L2 cache error injection mask high */ + u32 l2errinjlo; /* 0xe04 L2 cache error injection mask low */ + u32 l2errinjctl;/* 0xe08 L2 cache error injection control */ + u8 res_e0c[20]; /* 0xe0c - 0x01f */ + u32 l2captdatahi; /* 0xe20 L2 cache error capture data high */ + u32 l2captdatalo; /* 0xe24 L2 cache error capture data low */ + u32 l2captecc; /* 0xe28 L2 cache error capture ECC syndrome */ + u8 res_e2c[20]; /* 0xe2c - 0xe3f */ + u32 l2errdet; /* 0xe40 L2 cache error detect */ + u32 l2errdis; /* 0xe44 L2 cache error disable */ + u32 l2errinten; /* 0xe48 L2 cache error interrupt enable */ + u32 l2errattr; /* 0xe4c L2 cache error attribute */ + u32 l2erreaddr; /* 0xe50 L2 cache error extended address */ + u32 l2erraddr; /* 0xe54 L2 cache error address */ + u32 l2errctl; /* 0xe58 L2 cache error control */ +}; +#define CONFIG_SYS_FSL_CLUSTER_1_L2 \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CLUSTER_1_L2_OFFSET) +#endif /* CONFIG_E6500 */ #endif /*__IMMAP_85xx__*/
Setup stash id for L1 cache as (coreID) * 2 + 32 + 0 Setup stash id for L2 cache as (cluster) * 2 + 32 + 1 Stash id for L2 is only set for Chassis 2.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Andy Fleming afleming@freescale.com
Rework L2 initialization to get all clusters
The code was double-incrementing the index, and therefore writing the wrong stash ID to the cluster. Added some comments to clarify what was happening, too.
Signed-off-by: Andy Fleming afleming@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 20 ++++++++++++++------ arch/powerpc/cpu/mpc85xx/fdt.c | 13 ++++++++++++- arch/powerpc/cpu/mpc85xx/release.S | 14 +++++++------- arch/powerpc/cpu/mpc85xx/start.S | 8 +++++--- arch/powerpc/include/asm/immap_85xx.h | 24 ++++++++++++++++++++---- 5 files changed, 58 insertions(+), 21 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 1a2858a..e60129a 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -309,7 +309,7 @@ static void __fsl_serdes__init(void) } __attribute__((weak, alias("__fsl_serdes__init"))) void fsl_serdes_init(void);
-#ifdef CONFIG_E6500 +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 int enable_cluster_l2(void) { int i = 0; @@ -317,13 +317,20 @@ int enable_cluster_l2(void) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); struct ccsr_cluster_l2 *l2cache;
- cluster = in_be32(&gur->tp_cluster[i++].lower); + cluster = in_be32(&gur->tp_cluster[i].lower); if (cluster & TP_CLUSTER_EOC) return 0;
+ /* The first cache has already been set up, so skip it */ + i++; + + /* Look through the remaining clusters, and set up their caches */ do { l2cache = (void *)(CONFIG_SYS_FSL_CLUSTER_1_L2 + i * 0x40000); - cluster = in_be32(&gur->tp_cluster[i++].lower); + cluster = in_be32(&gur->tp_cluster[i].lower); + + /* set stash ID to (cluster) * 2 + 32 + 1 */ + clrsetbits_be32(&l2cache->l2csr1, 0xff, 32 + i * 2 + 1);
@@ -331,7 +338,8 @@ int enable_cluster_l2(void) while ((in_be32(&l2cache->l2csr0) & (L2CSR0_L2FI|L2CSR0_L2LFC)) != 0) ; out_be32(&l2cache->l2csr0, L2CSR0_L2E); - } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC); + i++; + } while (!(cluster & TP_CLUSTER_EOC));
return 0; } @@ -352,7 +360,7 @@ int cpu_init_r(void) #endif #ifdef CONFIG_L2_CACHE volatile ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; -#elif defined(CONFIG_E6500) +#elif defined(CONFIG_SYS_FSL_QORIQ_CHASSIS2) struct ccsr_cluster_l2 * l2cache = (void *)CONFIG_SYS_FSL_CLUSTER_1_L2; #endif
@@ -506,7 +514,7 @@ int cpu_init_r(void) }
skip_l2: -#elif defined(CONFIG_E6500) +#elif defined(CONFIG_SYS_FSL_QORIQ_CHASSIS2) if (l2cache->l2csr0 & L2CSR0_L2E) printf("%d KB enabled\n", (l2cache->l2cfg0 & 0x3fff) * 64);
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 40df01c..a15e164 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -220,12 +220,18 @@ static inline void ft_fixup_l2cache(void *blob)
/* we dont bother w/L3 since no platform of this type has one */ } -#elif defined(CONFIG_BACKSIDE_L2_CACHE) +#elif defined(CONFIG_BACKSIDE_L2_CACHE) || defined(CONFIG_SYS_FSL_QORIQ_CHASSIS2) static inline void ft_fixup_l2cache(void *blob) { int off, l2_off, l3_off = -1; u32 *ph; +#ifdef CONFIG_BACKSIDE_L2_CACHE u32 l2cfg0 = mfspr(SPRN_L2CFG0); +#else + struct ccsr_cluster_l2 *l2cache = + (struct ccsr_cluster_l2 *)(CONFIG_SYS_FSL_CLUSTER_1_L2); + u32 l2cfg0 = in_be32(&l2cache->l2cfg0); +#endif u32 size, line_size, num_ways, num_sets; int has_l2 = 1;
@@ -257,7 +263,12 @@ static inline void ft_fixup_l2cache(void *blob) if (has_l2) { #ifdef CONFIG_SYS_CACHE_STASHING u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", 0); +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 + /* Only initialize every eighth thread */ + if (reg && !((*reg) % 8)) +#else if (reg) +#endif fdt_setprop_cell(blob, l2_off, "cache-stash-id", (*reg * 2) + 32 + 1); #endif diff --git a/arch/powerpc/cpu/mpc85xx/release.S b/arch/powerpc/cpu/mpc85xx/release.S index 22e73e0..d9061c3 100644 --- a/arch/powerpc/cpu/mpc85xx/release.S +++ b/arch/powerpc/cpu/mpc85xx/release.S @@ -183,13 +183,6 @@ __secondary_start_page: slwi r8,r4,5 add r10,r3,r8
-#if defined(CONFIG_E500MC) && defined(CONFIG_SYS_CACHE_STASHING) - /* set stash id to (coreID) * 2 + 32 + L1 CT (0) */ - slwi r8,r4,1 - addi r8,r8,32 - mtspr L1CSR2,r8 -#endif - #ifdef CONFIG_E6500 mfspr r0,SPRN_PIR /* @@ -209,6 +202,13 @@ __secondary_start_page:
mtspr SPRN_PIR,r4 /* write to PIR register */
+#ifdef CONFIG_SYS_CACHE_STASHING + /* set stash id to (coreID) * 2 + 32 + L1 CT (0) */ + slwi r8,r4,1 + addi r8,r8,32 + mtspr L1CSR2,r8 +#endif + #if defined(CONFIG_SYS_P4080_ERRATUM_CPU22) || \ defined(CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011) /* diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 739127f..6087f62 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -169,7 +169,7 @@ l2_disabled: * */
-#if defined(CONFIG_E500MC) && defined(CONFIG_SYS_CACHE_STASHING) +#ifdef CONFIG_SYS_CACHE_STASHING /* set stash id to (coreID) * 2 + 32 + L1 CT (0) */ li r2,(32 + 0) mtspr L1CSR2,r2 @@ -762,7 +762,7 @@ delete_temp_tlbs: tlbwe #endif /* #if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) */
-#ifdef CONFIG_E6500 +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 create_ccsr_l2_tlb: /* * Create a TLB for the MMR location of CCSR @@ -786,10 +786,12 @@ create_ccsr_l2_tlb: isync msync tlbwe -enable_l2_e6500: +enable_l2_cluster_l2: /* enable L2 cache */ lis r3, (CONFIG_SYS_CCSRBAR + 0xC20000)@h ori r3, r3, (CONFIG_SYS_CCSRBAR + 0xC20000)@l + li r4, 33 /* stash id */ + stw r4, 4(r3) lis r4, (L2CSR0_L2FI|L2CSR0_L2LFC)@h ori r4, r4, (L2CSR0_L2FI|L2CSR0_L2LFC)@l sync diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 62d8d0b..2a27be9 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2947,7 +2947,7 @@ typedef struct ccsr_snvs_regs { #define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) #define MDIO_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MDIO1_OFFSET)
-#ifdef CONFIG_E6500 +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 struct ccsr_cluster_l2 { u32 l2csr0; /* 0x000 L2 cache control and status register 0 */ u32 l2csr1; /* 0x004 L2 cache control and status register 1 */ @@ -2966,10 +2966,26 @@ struct ccsr_cluster_l2 { u32 l2par2; /* 0x228 L2 cache partitioning allocation register 2 */ u32 l2pwr2; /* 0x22c L2 cache partitioning way register 2 */ u32 l2pir3; /* 0x230 L2 cache partitioning ID register 3 */ - u8 res_234[5]; + u8 res_234[4]; u32 l2par3; /* 0x238 L2 cache partitining allocation register 3 */ u32 l2pwr3; /* 0x23c L2 cache partitining way register 3 */ - u8 res_240[3008]; /* 0x240 - 0xdff */ + u32 l2pir4; /* 0x240 L2 cache partitioning ID register 3 */ + u8 res244[4]; + u32 l2par4; /* 0x248 L2 cache partitioning allocation register 3 */ + u32 l2pwr4; /* 0x24c L2 cache partitioning way register 3 */ + u32 l2pir5; /* 0x250 L2 cache partitioning ID register 3 */ + u8 res_254[4]; + u32 l2par5; /* 0x258 L2 cache partitioning allocation register 3 */ + u32 l2pwr5; /* 0x25c L2 cache partitioning way register 3 */ + u32 l2pir6; /* 0x260 L2 cache partitioning ID register 3 */ + u8 res_264[4]; + u32 l2par6; /* 0x268 L2 cache partitioning allocation register 3 */ + u32 l2pwr6; /* 0x26c L2 cache partitioning way register 3 */ + u32 l2pir7; /* 0x270 L2 cache partitioning ID register 3 */ + u8 res274[4]; + u32 l2par7; /* 0x278 L2 cache partitioning allocation register 3 */ + u32 l2pwr7; /* 0x27c L2 cache partitioning way register 3 */ + u8 res_280[0xb80]; /* 0x280 - 0xdff */ u32 l2errinjhi; /* 0xe00 L2 cache error injection mask high */ u32 l2errinjlo; /* 0xe04 L2 cache error injection mask low */ u32 l2errinjctl;/* 0xe08 L2 cache error injection control */ @@ -2988,5 +3004,5 @@ struct ccsr_cluster_l2 { }; #define CONFIG_SYS_FSL_CLUSTER_1_L2 \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CLUSTER_1_L2_OFFSET) -#endif /* CONFIG_E6500 */ +#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ #endif /*__IMMAP_85xx__*/
Chassis generation 2 has different mask and shift. Use macro instead of magic numbers.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/speed.c | 5 +++-- arch/powerpc/include/asm/immap_85xx.h | 7 +++++++ 2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index 203f53d..6bf49ee 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -1,5 +1,5 @@ /* - * Copyright 2004, 2007-2011 Freescale Semiconductor, Inc. + * Copyright 2004, 2007-2012 Freescale Semiconductor, Inc. * * (C) Copyright 2003 Motorola Inc. * Xianghua Xiao, (X.Xiao@motorola.com) @@ -85,7 +85,8 @@ void get_sys_info (sys_info_t * sysInfo) sysInfo->freqDDRBus = sysclk;
sysInfo->freqSystemBus *= (in_be32(&gur->rcwsr[0]) >> 25) & 0x1f; - mem_pll_rat = (in_be32(&gur->rcwsr[0]) >> 17) & 0x1f; + mem_pll_rat = (in_be32(&gur->rcwsr[0]) >> FSL_CORENET_RCWSR0_MEM_PLL_RAT_SHIFT) + & FSL_CORENET_RCWSR0_MEM_PLL_RAT_MASK; if (mem_pll_rat > 2) sysInfo->freqDDRBus *= mem_pll_rat; else diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 2a27be9..ed42918 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1755,6 +1755,13 @@ typedef struct ccsr_gur { u32 brrl; /* Boot release */ u8 res17[24]; u32 rcwsr[16]; /* Reset control word status */ +#ifndef CONFIG_SYS_FSL_QORIQ_CHASSIS2 +#define FSL_CORENET_RCWSR0_MEM_PLL_RAT_SHIFT 17 +#define FSL_CORENET_RCWSR0_MEM_PLL_RAT_MASK 0x1f +#else +#define FSL_CORENET_RCWSR0_MEM_PLL_RAT_SHIFT 16 +#define FSL_CORENET_RCWSR0_MEM_PLL_RAT_MASK 0x3f +#endif #define FSL_CORENET_RCWSR4_SRDS_PRTCL 0xfc000000 #define FSL_CORENET_RCWSR5_DDR_SYNC 0x00000080 #define FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT 7
Panic if the number of cores is more than CONFIG_MAX_CPUS because it will surely overflow gd structure.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 515dd41..11b83d2 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -127,6 +127,11 @@ int checkcpu (void)
printf(", Version: %d.%d, (0x%08x)\n", major, minor, pvr);
+ if (nr_cores > CONFIG_MAX_CPUS) { + panic("\nUnexpected number of cores: %d, max is %d\n", + nr_cores, CONFIG_MAX_CPUS); + } + get_sys_info(&sysinfo);
puts("Clock Configuration:");
E6500 doesn't allow cache inhibit TLB alias. Use the boot page translation instead. The boot page is always cache inhibit.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/mp.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index ffc2a9a..594f8e8 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -205,7 +205,7 @@ ulong get_spin_phys_addr(void) extern ulong __secondary_start_page; extern ulong __spin_table;
- return (determine_mp_bootpg() + + return (0xfffff000 + (ulong)&__spin_table - (ulong)&__secondary_start_page); }
We're not supposed to create such aliases on any PPC core.
Please move to a cacheable spintable as described in ePAPR 1.1. This probably means not using the boot page window to access it.
-Scott
We seem to have been using it for quite a while, until it is broken here.
No objection here.
York
Just because there wasn't a cop behind the billboard doesn't mean we weren't speeding. :-)
I've gotten machine checks on p4080 from such aliases under specific circumstances (just not in the specific case of what U-Boot does).
No objection here.
While we're touching the spin table stuff, we really should fix the bug that we don't load the upper half of r3 on 64-bit so at least on non-e5500 we won't have old U-Boots floating around that don't do it.
-Scott
Corenet based SoCs have different core clocks starting from Chassis generation 2. Cores are organized into clusters. Each cluster has up to 4 cores sharing same clock, which can be chosen from one of three PLLs in the cluster group with one of the devisors /1, /2 or /4. Two clusters are put together as a cluster group. These two clusters share the PLLs but may have different divisor. For example, core 0~3 are in cluster 1. Core 4~7 are in cluster 2. Core 8~11 are in cluster 3 and so on. Cluster 1 and 2 are cluster group A. Cluster 3 and 4 are in cluster group B. Cluster group A has PLL1, PLL2, PLL3. Cluster group B has PLL4, PLL5. Core 0~3 may have PLL1/2, core 4~7 may have PLL2/2. Core 8~11 may have PLL4/1.
PME and FMan blocks can take different PLLs, configured by RCW.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/speed.c | 138 ++++++++++++++++++++++++++++++--- arch/powerpc/include/asm/immap_85xx.h | 36 +++++---- 2 files changed, 148 insertions(+), 26 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index 6bf49ee..7bf1133 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -76,8 +76,8 @@ void get_sys_info (sys_info_t * sysInfo) [13] = 2, /* CC4 PPL / 2 */ [14] = 4, /* CC4 PPL / 4 */ }; - uint lcrr_div, i, freqCC_PLL[4], rcw_tmp; - uint ratio[4]; + uint i, freqCC_PLL[6], rcw_tmp; + uint ratio[6]; unsigned long sysclk = CONFIG_SYS_CLK_FREQ; uint mem_pll_rat;
@@ -96,21 +96,139 @@ void get_sys_info (sys_info_t * sysInfo) ratio[1] = (in_be32(&clk->pllc2gsr) >> 1) & 0x3f; ratio[2] = (in_be32(&clk->pllc3gsr) >> 1) & 0x3f; ratio[3] = (in_be32(&clk->pllc4gsr) >> 1) & 0x3f; - for (i = 0; i < 4; i++) { + ratio[4] = (in_be32(&clk->pllc5gsr) >> 1) & 0x3f; + ratio[5] = (in_be32(&clk->pllc6gsr) >> 1) & 0x3f; + for (i = 0; i < 6; i++) { if (ratio[i] > 4) freqCC_PLL[i] = sysclk * ratio[i]; else freqCC_PLL[i] = sysInfo->freqSystemBus * ratio[i]; } - rcw_tmp = in_be32(&gur->rcwsr[3]); +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 + /* + * Each cluster has up to 4 cores, sharing the same PLL selection. + * The cluster assignment is fixed per SoC. There is no way identify the + * assignment so far, presuming the "first configuration" which is to + * fill the lower cluster group first before moving up to next group. + * PLL1, PLL2, PLL3 are cluster group A, feeding core 0~3 on cluster 1 + * and core 4~7 on cluster 2 + * PLL4, PLL5, PLL6 are cluster group B, feeding core 8~11 on cluster 3 + * and core 12~15 on cluster 4 if existing + */ for_each_cpu(i, cpu, cpu_numcores(), cpu_mask()) { - u32 c_pll_sel = (in_be32(&clk->clkc0csr + cpu*8) >> 27) & 0xf; + u32 c_pll_sel = (in_be32(&clk->clkc0csr + (cpu / 4) * 8) >> 27) + & 0xf; u32 cplx_pll = core_cplx_PLL[c_pll_sel]; + if (cplx_pll > 3) + printf("Unsupported architecture configuration" + " in function %s\n", __func__); + cplx_pll += (cpu / 8) * 3;
sysInfo->freqProcessor[cpu] = freqCC_PLL[cplx_pll] / core_cplx_PLL_div[c_pll_sel]; } +#define PME_CLK_SEL 0xe0000000 +#define PME_CLK_SHIFT 29 +#define FM1_CLK_SEL 0x1c000000 +#define FM1_CLK_SHIFT 26 + rcw_tmp = in_be32(&gur->rcwsr[7]); + +#ifdef CONFIG_SYS_DPAA_PME + switch ((rcw_tmp & PME_CLK_SEL) >> PME_CLK_SHIFT) { + case 1: + sysInfo->freqPME = freqCC_PLL[0]; + break; + case 2: + sysInfo->freqPME = freqCC_PLL[0] / 2; + break; + case 3: + sysInfo->freqPME = freqCC_PLL[0] / 3; + break; + case 4: + sysInfo->freqPME = freqCC_PLL[0] / 4; + break; + case 6: + sysInfo->freqPME = freqCC_PLL[1] / 2; + break; + case 7: + sysInfo->freqPME = freqCC_PLL[1] / 3; + break; + default: + printf("Error: Unknown PME clock select!\n"); + case 0: + sysInfo->freqPME = sysInfo->freqSystemBus / 2; + break; + + } +#endif
+#ifdef CONFIG_SYS_DPAA_FMAN + switch ((rcw_tmp & FM1_CLK_SEL) >> FM1_CLK_SHIFT) { + case 1: + sysInfo->freqFMan[0] = freqCC_PLL[3]; + break; + case 2: + sysInfo->freqFMan[0] = freqCC_PLL[3] / 2; + break; + case 3: + sysInfo->freqFMan[0] = freqCC_PLL[3] / 3; + break; + case 4: + sysInfo->freqFMan[0] = freqCC_PLL[3] / 4; + break; + case 6: + sysInfo->freqFMan[0] = freqCC_PLL[4] / 2; + break; + case 7: + sysInfo->freqFMan[0] = freqCC_PLL[4] / 3; + break; + default: + printf("Error: Unknown FMan1 clock select!\n"); + case 0: + sysInfo->freqFMan[0] = sysInfo->freqSystemBus / 2; + break; + } +#if (CONFIG_SYS_NUM_FMAN) == 2 +#define FM2_CLK_SEL 0x00000038 +#define FM2_CLK_SHIFT 3 + rcw_tmp = in_be32(&gur->rcwsr[15]); + switch ((rcw_tmp & FM2_CLK_SEL) >> FM2_CLK_SHIFT) { + case 1: + sysInfo->freqFMan[1] = freqCC_PLL[4]; + break; + case 2: + sysInfo->freqFMan[1] = freqCC_PLL[4] / 2; + break; + case 3: + sysInfo->freqFMan[1] = freqCC_PLL[4] / 3; + break; + case 4: + sysInfo->freqFMan[1] = freqCC_PLL[4] / 4; + break; + case 6: + sysInfo->freqFMan[1] = freqCC_PLL[3] / 2; + break; + case 7: + sysInfo->freqFMan[1] = freqCC_PLL[3] / 3; + break; + default: + printf("Error: Unknown FMan2 clock select!\n"); + case 0: + sysInfo->freqFMan[1] = sysInfo->freqSystemBus / 2; + break; + } +#endif /* CONFIG_SYS_NUM_FMAN == 2 */ +#endif /* CONFIG_SYS_DPAA_FMAN */ + +#else /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ + + for_each_cpu(i, cpu, cpu_numcores(), cpu_mask()) { + u32 c_pll_sel = (in_be32(&clk->clkc0csr + cpu*8) >> 27) & 0xf; + u32 cplx_pll = core_cplx_PLL[c_pll_sel]; + + sysInfo->freqProcessor[cpu] = + freqCC_PLL[cplx_pll] / core_cplx_PLL_div[c_pll_sel]; + } #define PME_CLK_SEL 0x80000000 #define FM1_CLK_SEL 0x40000000 #define FM2_CLK_SEL 0x20000000 @@ -158,11 +276,10 @@ void get_sys_info (sys_info_t * sysInfo) #endif #endif
-#else - uint plat_ratio,e500_ratio,half_freqSystemBus; -#if defined(CONFIG_FSL_LBC) - uint lcrr_div; -#endif +#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ + +#else /* CONFIG_FSL_CORENET */ + uint plat_ratio, e500_ratio, half_freqSystemBus; int i; #ifdef CONFIG_QE __maybe_unused u32 qe_ratio; @@ -209,6 +326,7 @@ void get_sys_info (sys_info_t * sysInfo) #endif /* CONFIG_FSL_CORENET */
#if defined(CONFIG_FSL_LBC) + uint lcrr_div; #if defined(CONFIG_SYS_LBC_LCRR) /* We will program LCRR to this value later */ lcrr_div = CONFIG_SYS_LBC_LCRR & LCRR_CLKDIV; diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index ed42918..e5509b4 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1897,34 +1897,38 @@ typedef struct ccsr_gur { #define rmuliodnr rio1maintliodnr
typedef struct ccsr_clk { - u32 clkc0csr; /* Core 0 Clock control/status */ + u32 clkc0csr; /* 0x000 Core 0 Clock control/status */ u8 res1[0x1c]; - u32 clkc1csr; /* Core 1 Clock control/status */ + u32 clkc1csr; /* 0x020 Core 1 Clock control/status */ u8 res2[0x1c]; - u32 clkc2csr; /* Core 2 Clock control/status */ + u32 clkc2csr; /* 0x040 Core 2 Clock control/status */ u8 res3[0x1c]; - u32 clkc3csr; /* Core 3 Clock control/status */ + u32 clkc3csr; /* 0x060 Core 3 Clock control/status */ u8 res4[0x1c]; - u32 clkc4csr; /* Core 4 Clock control/status */ + u32 clkc4csr; /* 0x080 Core 4 Clock control/status */ u8 res5[0x1c]; - u32 clkc5csr; /* Core 5 Clock control/status */ + u32 clkc5csr; /* 0x0a0 Core 5 Clock control/status */ u8 res6[0x1c]; - u32 clkc6csr; /* Core 6 Clock control/status */ + u32 clkc6csr; /* 0x0c0 Core 6 Clock control/status */ u8 res7[0x1c]; - u32 clkc7csr; /* Core 7 Clock control/status */ + u32 clkc7csr; /* 0x0e0 Core 7 Clock control/status */ u8 res8[0x71c]; - u32 pllc1gsr; /* Cluster PLL 1 General Status */ + u32 pllc1gsr; /* 0x800 Cluster PLL 1 General Status */ u8 res10[0x1c]; - u32 pllc2gsr; /* Cluster PLL 2 General Status */ + u32 pllc2gsr; /* 0x820 Cluster PLL 2 General Status */ u8 res11[0x1c]; - u32 pllc3gsr; /* Cluster PLL 3 General Status */ + u32 pllc3gsr; /* 0x840 Cluster PLL 3 General Status */ u8 res12[0x1c]; - u32 pllc4gsr; /* Cluster PLL 4 General Status */ - u8 res13[0x39c]; - u32 pllpgsr; /* Platform PLL General Status */ + u32 pllc4gsr; /* 0x860 Cluster PLL 4 General Status */ + u8 res13[0x1c]; + u32 pllc5gsr; /* 0x880 Cluster PLL 5 General Status */ u8 res14[0x1c]; - u32 plldgsr; /* DDR PLL General Status */ - u8 res15[0x3dc]; + u32 pllc6gsr; /* 0x8a0 Cluster PLL 6 General Status */ + u8 res15[0x35c]; + u32 pllpgsr; /* 0xc00 Platform PLL General Status */ + u8 res16[0x1c]; + u32 plldgsr; /* 0xc20 DDR PLL General Status */ + u8 res17[0x3dc]; } ccsr_clk_t;
Expand the reference clock select to three bits 000: 100 MHz 001: 125 MHz 010: 156.25MHz 011: 150 MHz 100: 161.1328125 MHz All others reserved
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index e5509b4..15d2db4 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2413,12 +2413,13 @@ typedef struct serdes_corenet { #define SRDS_RSTCTL_RSTERR 0x20000000 #define SRDS_RSTCTL_SDPD 0x00000020 u32 pllcr0; /* PLL Control Register 0 */ -#define SRDS_PLLCR0_RFCK_SEL_MASK 0x30000000 +#define SRDS_PLLCR0_RFCK_SEL_MASK 0x70000000 #define SRDS_PLLCR0_PVCOCNT_EN 0x02000000 #define SRDS_PLLCR0_RFCK_SEL_100 0x00000000 #define SRDS_PLLCR0_RFCK_SEL_125 0x10000000 #define SRDS_PLLCR0_RFCK_SEL_156_25 0x20000000 #define SRDS_PLLCR0_RFCK_SEL_150 0x30000000 +#define SRDS_PLLCR0_RFCK_SEL_161_13 0x40000000 #define SRDS_PLLCR0_FRATE_SEL_MASK 0x00030000 #define SRDS_PLLCR0_FRATE_SEL_5 0x00000000 #define SRDS_PLLCR0_FRATE_SEL_6_25 0x00010000
The QCSP registers are at offset 0x1000 for SoCs with QMan v3.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 19 ++++++++++++++++++- 1 files changed, 18 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 15d2db4..20e6915 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2573,13 +2573,18 @@ typedef struct ccsr_sec { #endif
typedef struct ccsr_qman { +#ifdef CONFIG_SYS_FSL_QMAN_V3 + /* T4240, PSC9164 */ + u8 res0[0x200]; +#else + /* P4080, SC4080, P3041, P5020, P1023, SC1023 */ struct { u32 qcsp_lio_cfg; /* 0x0 - SW Portal n LIO cfg */ u32 qcsp_io_cfg; /* 0x4 - SW Portal n IO cfg */ u32 res; u32 qcsp_dd_cfg; /* 0xc - SW Portal n Dynamic Debug cfg */ } qcsp[32]; - +#endif /* Not actually reserved, but irrelevant to u-boot */ u8 res[0xbf8 - 0x200]; u32 ip_rev_1; @@ -2604,6 +2609,18 @@ typedef struct ccsr_qman { u32 ci_rlm_cfg; /* Initiator Read Latency Monitor Cfg */ u32 ci_rlm_avg; /* Initiator Read Latency Monitor Avg */ u8 res7[0x2e8]; +#ifdef CONFIG_SYS_FSL_QMAN_V3 + /* + * T4240 50 software portals + * PSC9164 25 software portals + */ + struct { + u32 qcsp_lio_cfg; /* 0x0 - SW Portal n LIO cfg */ + u32 qcsp_io_cfg; /* 0x4 - SW Portal n IO cfg */ + u32 res; + u32 qcsp_dd_cfg; /* 0xc - SW Portal n Dynamic Debug cfg */ + } qcsp[50]; +#endif } ccsr_qman_t;
typedef struct ccsr_bman {
B4860 is the name, not PSC9164
u8 res0[0x200];
+#else
This comment is somewhat specific. There are others that aren't listed here. And I'm not sure the SC1023 exists (anymore). Probably we should just mention the version of the QMan that this code is for.
B4860
struct {
u32 res;
} qcsp[50];
1.7.0.4
Thanks for pointing out. This patch was written when the name was PSC9164. I will fix it in next version, along with other feedback.
York
Corenet 2nd generation Chassis has different RCW and registers for SerDes.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 99 +++++++++++++++++++++++++++++++-- 1 files changed, 94 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 20e6915..783bc28 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1755,13 +1755,30 @@ typedef struct ccsr_gur { u32 brrl; /* Boot release */ u8 res17[24]; u32 rcwsr[16]; /* Reset control word status */ -#ifndef CONFIG_SYS_FSL_QORIQ_CHASSIS2 -#define FSL_CORENET_RCWSR0_MEM_PLL_RAT_SHIFT 17 -#define FSL_CORENET_RCWSR0_MEM_PLL_RAT_MASK 0x1f -#else + +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 #define FSL_CORENET_RCWSR0_MEM_PLL_RAT_SHIFT 16 #define FSL_CORENET_RCWSR0_MEM_PLL_RAT_MASK 0x3f -#endif +#define FSL_CORENET2_RCWSR4_SRDS1_PRTCL 0xfc000000 +#define FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT 26 +#define FSL_CORENET2_RCWSR4_SRDS2_PRTCL 0x00fe0000 +#define FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT 17 +#define FSL_CORENET2_RCWSR4_SRDS3_PRTCL 0x0000f800 +#define FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT 11 +#define FSL_CORENET2_RCWSR4_SRDS4_PRTCL 0x000000f8 +#define FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT 3 +#define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S1_PLL1 0x00800000 +#define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S1_PLL2 0x00400000 +#define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S2_PLL1 0x00200000 +#define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S2_PLL2 0x00100000 +#define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S3_PLL1 0x00080000 +#define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S3_PLL2 0x00040000 +#define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S4_PLL1 0x00020000 +#define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S4_PLL2 0x00010000 + +#else /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ +#define FSL_CORENET_RCWSR0_MEM_PLL_RAT_SHIFT 17 +#define FSL_CORENET_RCWSR0_MEM_PLL_RAT_MASK 0x1f #define FSL_CORENET_RCWSR4_SRDS_PRTCL 0xfc000000 #define FSL_CORENET_RCWSR5_DDR_SYNC 0x00000080 #define FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT 7 @@ -1770,6 +1787,8 @@ typedef struct ccsr_gur { #define FSL_CORENET_RCWSR6_SB_EN 0x00200000 #define FSL_CORENET_RCWSRn_SRDS_LPD_B2 0x3c000000 /* bits 162..165 */ #define FSL_CORENET_RCWSRn_SRDS_LPD_B3 0x003c0000 /* bits 170..173 */ +#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ + #define FSL_CORENET_RCWSR7_MCK_TO_PLAT_RAT 0x00400000 #define FSL_CORENET_RCWSR8_HOST_AGT_B1 0x00e00000 #define FSL_CORENET_RCWSR8_HOST_AGT_B2 0x00100000 @@ -2405,6 +2424,75 @@ typedef struct ccsr_gur {
#define SDHCDCR_CD_INV 0x80000000 /* invert SDHC card detect */
+#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 +#define MAX_SERDES 4 +typedef struct serdes_corenet { + struct { + u32 rstctl; /* Reset Control Register */ +#define SRDS_RSTCTL_RST 0x80000000 +#define SRDS_RSTCTL_RSTDONE 0x40000000 +#define SRDS_RSTCTL_RSTERR 0x20000000 +#define SRDS_RSTCTL_SWRST 0x10000000 +#define SRDS_RSTCTL_SDPD 0x00000020 + u32 pllcr0; /* PLL Control Register 0 */ +#define SRDS_PLLCR0_POFF 0x80000000 +#define SRDS_PLLCR0_RFCK_SEL_MASK 0x70000000 +#define SRDS_PLLCR0_RFCK_SEL_100 0x00000000 +#define SRDS_PLLCR0_RFCK_SEL_125 0x10000000 +#define SRDS_PLLCR0_RFCK_SEL_156_25 0x20000000 +#define SRDS_PLLCR0_RFCK_SEL_150 0x30000000 +#define SRDS_PLLCR0_RFCK_SEL_161_13 0x40000000 +#define SRDS_PLLCR0_RFCK_SEL_122_88 0x50000000 +#define SRDS_PLLCR0_FRATE_SEL_MASK 0x000f0000 +#define SRDS_PLLCR0_FRATE_SEL_5 0x00000000 +#define SRDS_PLLCR0_FRATE_SEL_3_75 0x00050000 +#define SRDS_PLLCR0_FRATE_SEL_5_15 0x00060000 +#define SRDS_PLLCR0_FRATE_SEL_4 0x00070000 +#define SRDS_PLLCR0_FRATE_SEL_3_12 0x00090000 +#define SRDS_PLLCR0_FRATE_SEL_3 0x000a0000 + u32 pllcr1; /* PLL Control Register 1 */ +#define SRDS_PLLCR1_PLL_BWSEL 0x08000000 + u32 res_0c; /* 0x00c */ + u32 pllcr3; + u32 pllcr4; + u8 res_18[0x20-0x18]; + } bank[2]; + u8 res_40[0x90-0x40]; + u32 srdstcalcr; /* 0x90 TX Calibration Control */ + u8 res_94[0xa0-0x94]; + u32 srdsrcalcr; /* 0xa0 RX Calibration Control */ + u8 res_a4[0xb0-0xa4]; + u32 srdsgr0; /* 0xb0 General Register 0 */ + u8 res_b4[0xe0-0xb4]; + u32 srdspccr0; /* 0xe0 Protocol Converter Config 0 */ + u32 srdspccr1; /* 0xe4 Protocol Converter Config 1 */ + u32 srdspccr2; /* 0xe8 Protocol Converter Config 2 */ + u32 srdspccr3; /* 0xec Protocol Converter Config 3 */ + u32 srdspccr4; /* 0xf0 Protocol Converter Config 4 */ + u8 res_f4[0x100-0xf4]; + struct { + u32 lnpssr; /* 0x100, 0x120, ..., 0x1e0 */ + u8 res_104[0x120-0x104]; + } srdslnpssr[8]; + u8 res_200[0x800-0x200]; + struct { +/* fixme: Document is wrong here */ + u32 gcr0; /* 0x800 General Control Register 0 */ + u32 gcr1; /* 0x804 General Control Register 1 */ + u32 gcr2; /* 0x808 General Control Register 2 */ + u32 res_80c; + u32 recr0; /* 0x810 Receive Equalization Control */ + u32 res_814; + u32 tecr0; /* 0x818 Transmit Equalization Control */ + u32 res_81c; + u32 ttlcr0; /* 0x820 Transition Tracking Loop Ctrl 0 */ + u8 res_824[0x840-0x824]; + } lane[8]; /* Lane A, B, C, D, E, F, G, H */ + u8 res_a00[0x1000-0xa00]; /* from 0xa00 to 0xfff */ +} serdes_corenet_t; + +#else /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ + typedef struct serdes_corenet { struct { u32 rstctl; /* Reset Control Register */ @@ -2464,6 +2552,7 @@ typedef struct serdes_corenet { } lane[24]; u32 res6[384]; } serdes_corenet_t; +#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */
typedef struct serdes2_corenet { u32 rstctl; /* Reset Control Register */
Create new files to handle 2nd generation Chassis as the registers are organized differently.
- Add SerDes protocol parsing and detection - Add support of 4 SerDes - Add CPRI protocol in fsl_serdes.h The Common Public Radio Interface (CPRI) is publicly available specification that standardizes the protocol interface between the radio equipment control (REC) and the radio equipment (RE) in wireless basestations. This allows interoperability of equipment from different vendors,and preserves the software investment made by wireless service providers.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- arch/powerpc/cpu/mpc85xx/Makefile | 3 +- arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c | 159 ++++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.h | 33 +++++ arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h | 13 -- arch/powerpc/include/asm/config_mpc85xx.h | 6 + arch/powerpc/include/asm/fsl_serdes.h | 31 +++++ arch/powerpc/include/asm/immap_85xx.h | 5 +- 7 files changed, 235 insertions(+), 15 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.h
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index da51039..c60320c 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -87,7 +87,8 @@ COBJS-$(CONFIG_PPC_P5040) += p5040_ids.o
COBJS-$(CONFIG_QE) += qe_io.o COBJS-$(CONFIG_CPM2) += serial_scc.o -COBJS-$(CONFIG_FSL_CORENET) += fsl_corenet_serdes.o +COBJS-$(CONFIG_SYS_FSL_QORIQ_CHASSIS1) += fsl_corenet_serdes.o +COBJS-$(CONFIG_SYS_FSL_QORIQ_CHASSIS2) += fsl_corenet2_serdes.o COBJS-$(CONFIG_SECURE_BOOT) += fsl_sfp_snvs.o COBJS-$(CONFIG_CMD_ESBC_VALIDATE) += cmd_esbc_validate.o fsl_validate.o
diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c new file mode 100644 index 0000000..b6800c2 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.c @@ -0,0 +1,159 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_serdes.h> +#include <asm/immap_85xx.h> +#include <asm/io.h> +#include <asm/processor.h> +#include <asm/fsl_law.h> +#include <asm/errno.h> +#include "fsl_corenet2_serdes.h" + +static u64 serdes1_prtcl_map; +static u64 serdes2_prtcl_map; +#if defined(CONFIG_PPC_T4240) +static u64 serdes3_prtcl_map; +static u64 serdes4_prtcl_map; +#endif + +#ifdef DEBUG +static const char *serdes_prtcl_str[] = { + [NONE] = "NA", + [PCIE1] = "PCIE1", + [PCIE2] = "PCIE2", + [PCIE3] = "PCIE3", + [PCIE4] = "PCIE4", + [SATA1] = "SATA1", + [SATA2] = "SATA2", + [SRIO1] = "SRIO1", + [SRIO2] = "SRIO2", + [SGMII_FM1_DTSEC1] = "SGMII_FM1_DTSEC1", + [SGMII_FM1_DTSEC2] = "SGMII_FM1_DTSEC2", + [SGMII_FM1_DTSEC3] = "SGMII_FM1_DTSEC3", + [SGMII_FM1_DTSEC4] = "SGMII_FM1_DTSEC4", + [SGMII_FM1_DTSEC5] = "SGMII_FM1_DTSEC5", + [SGMII_FM2_DTSEC1] = "SGMII_FM2_DTSEC1", + [SGMII_FM2_DTSEC2] = "SGMII_FM2_DTSEC2", + [SGMII_FM2_DTSEC3] = "SGMII_FM2_DTSEC3", + [SGMII_FM2_DTSEC4] = "SGMII_FM2_DTSEC4", + [XAUI_FM1] = "XAUI_FM1", + [XAUI_FM2] = "XAUI_FM2", + [AURORA] = "DEBUG", + [CPRI1] = "CPRI1", + [CPRI2] = "CPRI2", + [CPRI3] = "CPRI3", + [CPRI4] = "CPRI4", + [CPRI5] = "CPRI5", + [CPRI6] = "CPRI6", + [CPRI7] = "CPRI7", + [CPRI8] = "CPRI8", + [XAUI_FM1_MAC9] = "XAUI_FM1_MAC9", + [XAUI_FM1_MAC10] = "XAUI_FM1_MAC10", + [XAUI_FM2_MAC9] = "XAUI_FM2_MAC9", + [XAUI_FM2_MAC10] = "XAUI_FM2_MAC10", + [HIGIG_FM1_MAC9] = "HiGig_FM1_MAC9", + [HIGIG_FM1_MAC10] = "HiGig_FM1_MAC10", + [HIGIG_FM2_MAC9] = "HiGig_FM2_MAC9", + [HIGIG_FM2_MAC10] = "HiGig_FM2_MAC10", + [QSGMII_FM1_A] = "QSGMII_FM1_A", + [QSGMII_FM1_B] = "QSGMII_FM1_B", + [QSGMII_FM2_A] = "QSGMII_FM2_A", + [QSGMII_FM2_B] = "QSGMII_FM2_B", + [XFI_FM1_MAC9] = "XFI_FM1_MAC9", + [XFI_FM1_MAC10] = "XFI_FM1_MAC10", + [XFI_FM2_MAC9] = "XFI_FM2_MAC9", + [XFI_FM2_MAC10] = "XFI_FM2_MAC10", + [INTERLAKEN] = "INTERLAKEN", +}; +#endif + +int is_serdes_configured(enum srds_prtcl device) +{ + u64 ret = 0; + + ret |= (1ULL << device) & serdes1_prtcl_map; + ret |= (1ULL << device) & serdes2_prtcl_map; +#if defined(CONFIG_PPC_T4240) + ret |= (1ULL << device) & serdes3_prtcl_map; + ret |= (1ULL << device) & serdes4_prtcl_map; +#endif + + return !!ret; +} + +int serdes_get_first_lane(enum srds_prtcl device) +{ +/* fixme. this is incomplete. */ + return 0; +} + +u64 serdes_init(u32 sd, u32 sd_addr, u32 sd_prctl_mask, u32 sd_prctl_shift) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u64 serdes_prtcl_map = 0; + u32 cfg; + int lane; + + cfg = in_be32(&gur->rcwsr[4]) & sd_prctl_mask; + /* Is serdes enabled at all? */ + if (!cfg) { + printf("SERDES%d is not enabled\n", sd); + return 0; + } + + cfg >>= sd_prctl_shift; + printf("Using SERDES%d Protocol: 0x%x\n", sd, cfg); + if (!is_serdes_prtcl_valid(sd, cfg)) + printf("SERDES%d[PRTCL] = 0x%x is not valid\n", sd, cfg); + + for (lane = 0; lane < SRDS_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes_get_prtcl(sd, cfg, lane); + serdes_prtcl_map |= (1ULL << lane_prtcl); + } + + return serdes_prtcl_map; +} + +void fsl_serdes_init(void) +{ + + serdes1_prtcl_map = serdes_init(FSL_SRDS_1, + CONFIG_SYS_FSL_CORENET_SERDES_ADDR, + FSL_CORENET2_RCWSR4_SRDS1_PRTCL, + FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT); + serdes2_prtcl_map = serdes_init(FSL_SRDS_2, + CONFIG_SYS_FSL_CORENET_SERDES_ADDR + FSL_SRDS_2 * 0x1000, + FSL_CORENET2_RCWSR4_SRDS2_PRTCL, + FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT); +#if defined(CONFIG_PPC_T4240) + serdes3_prtcl_map = serdes_init(FSL_SRDS_3, + CONFIG_SYS_FSL_CORENET_SERDES_ADDR + FSL_SRDS_3 * 0x1000, + FSL_CORENET2_RCWSR4_SRDS3_PRTCL, + FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT); + serdes4_prtcl_map = serdes_init(FSL_SRDS_4, + CONFIG_SYS_FSL_CORENET_SERDES_ADDR + FSL_SRDS_4 * 0x1000, + FSL_CORENET2_RCWSR4_SRDS4_PRTCL, + FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT); +#endif + +} diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.h b/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.h new file mode 100644 index 0000000..6529a83 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet2_serdes.h @@ -0,0 +1,33 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __FSL_CORENET2_SERDES_H +#define __FSL_CORENET2_SERDES_H + +enum srds { + FSL_SRDS_1 = 0, + FSL_SRDS_2 = 1, + FSL_SRDS_3 = 2, + FSL_SRDS_4 = 3, +}; + +int is_serdes_prtcl_valid(int serdes, u32 prtcl); +int serdes_lane_enabled(int lane); +enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane); +#endif /* __FSL_CORENET2_SERDES_H */ diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h index 96d14ec..3b9816c 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h @@ -22,19 +22,6 @@ #ifndef __FSL_CORENET_SERDES_H #define __FSL_CORENET_SERDES_H
-#if defined(CONFIG_PPC_P5040) -/* - * The fourth SerDes bank is on SerDes2, but U-boot currently only supports - * one SerDes controller. For now, pretend that we have three banks and 18 - * lanes. - */ -#define SRDS_MAX_LANES 18 -#define SRDS_MAX_BANK 3 -#else -#define SRDS_MAX_LANES 18 -#define SRDS_MAX_BANK 3 -#endif - enum srds_bank { FSL_SRDS_BANK_1 = 0, FSL_SRDS_BANK_2 = 1, diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 0b4a519..fe21b61 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -313,6 +313,7 @@ #define CONFIG_SYS_FSL_SRIO_MSG_UNIT_NUM 2
#elif defined(CONFIG_PPC_P2041) /* also supports P2040 */ +#define CONFIG_SYS_FSL_QORIQ_CHASSIS1 #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -343,6 +344,7 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000
#elif defined(CONFIG_PPC_P3041) +#define CONFIG_SYS_FSL_QORIQ_CHASSIS1 #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -374,6 +376,7 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000
#elif defined(CONFIG_PPC_P3060) +#define CONFIG_SYS_FSL_QORIQ_CHASSIS1 #define CONFIG_MAX_CPUS 8 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -397,6 +400,7 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xff000000
#elif defined(CONFIG_PPC_P4080) /* also supports P4040 */ +#define CONFIG_SYS_FSL_QORIQ_CHASSIS1 #define CONFIG_MAX_CPUS 8 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -436,6 +440,7 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xff000000
#elif defined(CONFIG_PPC_P5020) /* also supports P5010 */ +#define CONFIG_SYS_FSL_QORIQ_CHASSIS1 #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -464,6 +469,7 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xc0000000
#elif defined(CONFIG_PPC_P5040) +#define CONFIG_SYS_FSL_QORIQ_CHASSIS1 #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 3 #define CONFIG_SYS_FSL_NUM_LAWS 32 diff --git a/arch/powerpc/include/asm/fsl_serdes.h b/arch/powerpc/include/asm/fsl_serdes.h index 22525f1..9a7c3a1 100644 --- a/arch/powerpc/include/asm/fsl_serdes.h +++ b/arch/powerpc/include/asm/fsl_serdes.h @@ -37,11 +37,17 @@ enum srds_prtcl { SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6, + SGMII_FM1_DTSEC9, + SGMII_FM1_DTSEC10, SGMII_FM2_DTSEC1, SGMII_FM2_DTSEC2, SGMII_FM2_DTSEC3, SGMII_FM2_DTSEC4, SGMII_FM2_DTSEC5, + SGMII_FM2_DTSEC6, + SGMII_FM2_DTSEC9, + SGMII_FM2_DTSEC10, SGMII_TSEC1, SGMII_TSEC2, SGMII_TSEC3, @@ -49,6 +55,31 @@ enum srds_prtcl { XAUI_FM1, XAUI_FM2, AURORA, + CPRI1, + CPRI2, + CPRI3, + CPRI4, + CPRI5, + CPRI6, + CPRI7, + CPRI8, + XAUI_FM1_MAC9, + XAUI_FM1_MAC10, + XAUI_FM2_MAC9, + XAUI_FM2_MAC10, + HIGIG_FM1_MAC9, + HIGIG_FM1_MAC10, + HIGIG_FM2_MAC9, + HIGIG_FM2_MAC10, + QSGMII_FM1_A, /* A indicates MACs 1-4 */ + QSGMII_FM1_B, /* B indicates MACs 5,6,9,10 */ + QSGMII_FM2_A, + QSGMII_FM2_B, + XFI_FM1_MAC9, + XFI_FM1_MAC10, + XFI_FM2_MAC9, + XFI_FM2_MAC10, + INTERLAKEN, };
int is_serdes_configured(enum srds_prtcl device); diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 783bc28..020475b 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2426,6 +2426,8 @@ typedef struct ccsr_gur {
#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 #define MAX_SERDES 4 +#define SRDS_MAX_LANES 8 +#define SRDS_MAX_BANK 2 typedef struct serdes_corenet { struct { u32 rstctl; /* Reset Control Register */ @@ -2476,7 +2478,6 @@ typedef struct serdes_corenet { } srdslnpssr[8]; u8 res_200[0x800-0x200]; struct { -/* fixme: Document is wrong here */ u32 gcr0; /* 0x800 General Control Register 0 */ u32 gcr1; /* 0x804 General Control Register 1 */ u32 gcr2; /* 0x808 General Control Register 2 */ @@ -2493,6 +2494,8 @@ typedef struct serdes_corenet {
+#define SRDS_MAX_LANES 18 +#define SRDS_MAX_BANK 3 typedef struct serdes_corenet { struct { u32 rstctl; /* Reset Control Register */
Corenet 2nd generation Chassis doesn't have ddr_sync bit in RCW. Only async mode is supported.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu.c | 10 ++++++++-- 1 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 11b83d2..95f435e 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -60,7 +60,8 @@ int checkcpu (void) uint major, minor; struct cpu_type *cpu; char buf1[32], buf2[32]; -#if defined(CONFIG_DDR_CLK_FREQ) || defined(CONFIG_FSL_CORENET) +#if defined(CONFIG_DDR_CLK_FREQ) || \ + (defined(CONFIG_FSL_CORENET) && !defined(CONFIG_SYS_FSL_QORIQ_CHASSIS2)) volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif /* CONFIG_FSL_CORENET */ #ifdef CONFIG_DDR_CLK_FREQ @@ -68,8 +69,13 @@ int checkcpu (void) >> MPC85xx_PORPLLSR_DDR_RATIO_SHIFT; #else #ifdef CONFIG_FSL_CORENET - u32 ddr_sync = ((gur->rcwsr[5]) & FSL_CORENET_RCWSR5_DDR_SYNC) + u32 ddr_sync ; +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 + ddr_sync = 0; /* only async mode is supported */ +#else + ddr_sync = ((gur->rcwsr[5]) & FSL_CORENET_RCWSR5_DDR_SYNC) >> FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT; +#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ #else u32 ddr_ratio = 0; #endif /* CONFIG_FSL_CORENET */
If enabling L2 is required for the stack, how are we enabling it in C code? Is this just for non-boot clusters?
- int i = 0;
- u32 cluster;
- ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
- struct ccsr_cluster_l2 *l2cache;
- if (cluster & TP_CLUSTER_EOC)
- do {
This should be a debug message (or removed), not a normal printf.
Timeout?
- struct ccsr_cluster_l2 * l2cache = (void *)CONFIG_SYS_FSL_CLUSTER_1_L2;
If CONFIG_L2_CACHE doesn't apply to e6500, then CONFIG_L2_CACHE is misnamed.
- lis r0, FSL_BOOKE_MAS0(0, 0, 0)@h
- ori r0, r0, FSL_BOOKE_MAS0(0, 0, 0)@l
- lis r1, FSL_BOOKE_MAS1(1, 0, 0, 0, BOOKE_PAGESZ_4K)@h
- ori r1, r1, FSL_BOOKE_MAS1(1, 0, 0, 0, BOOKE_PAGESZ_4K)@l
- lis r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0xC20000, (MAS2_I|MAS2_G))@h
- ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0xC20000, (MAS2_I|MAS2_G))@l
- lis r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS_LOW + 0xC20000, 0, (MAS3_SW|MAS3_SR))@h
- ori r3, r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS_LOW + 0xC20000, 0, (MAS3_SW|MAS3_SR))@l
- lis r7, CONFIG_SYS_CCSRBAR_PHYS_HIGH@h
- ori r7, r7, CONFIG_SYS_CCSRBAR_PHYS_HIGH@l
- mtspr MAS0, r0
- mtspr MAS1, r1
- mtspr MAS2, r2
- mtspr MAS3, r3
- mtspr MAS7, r7
- isync
- msync
- tlbwe
Let's make a macro (asm, not cpp) out of this instead of copy and pasting all over the place. And stop misusing r1/r2.
-Scott
Yes, this is for non-boot clusters. The boot cluster is enabled in start.S.
- int i = 0;
- u32 cluster;
- do {
OK.
Timeout?
I don't have a spec telling me how long.
Maybe it's time to introduce a new name?
- mtspr MAS0, r0
- mtspr MAS1, r1
- mtspr MAS2, r2
- mtspr MAS3, r3
- mtspr MAS7, r7
- isync
- msync
- tlbwe
That's a good idea. I am also tired of this long copy-n-paste. Using a macro increase the chance of overwriting registers, doesn't it? Any good idea to avoid?
York
OK, maybe put a comment on that first EOC check (which I missed). Anything we can do to help people navigate what's going on during 85xx boot would be welcome.
Timeout?
You can estimate an upper bound, so we print a message if we get stuck. It shouldn't take longer than a second, right?
Sure. What is it supposed to refer to?
(MAS2_I|MAS2_G))@h
(MAS2_I|MAS2_G))@l
- mtspr MAS0, r0
- mtspr MAS1, r1
- mtspr MAS2, r2
- mtspr MAS3, r3
- mtspr MAS7, r7
- isync
- msync
- tlbwe
If you can get away with one or two temporary registers, you could pass the temporaries in as parameters. Otherwise, document what you clobber, and stick to registers that are normally caller-saved.
-Scott
Andy Fleming
Scott Wood
York Sun
