[U-Boot] [PATCH] mxsboot : Support of 224-bytes OOB area length
Add support for the NAND Flash chip with page size of 4096+224-bytes OOB area length
For example Micron MT29F4G08 NAND flash device defines a OOB area which is 224 bytes long (oobsize).
Signed-off-by: Alexandre Coffignal acoffignal@geral.com --- tools/mxsboot.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/tools/mxsboot.c b/tools/mxsboot.c index 90b2173..6d48cfb 100644 --- a/tools/mxsboot.c +++ b/tools/mxsboot.c @@ -142,6 +142,9 @@ static inline uint32_t mx28_nand_get_ecc_strength(uint32_t page_data_size,
if (page_oob_size == 218) return 16; + + if (page_oob_size == 224) + return 16; }
return 0; @@ -269,6 +272,9 @@ static struct mx28_nand_fcb *mx28_nand_get_fcb(uint32_t size) } else if (nand_oobsize == 218) { fcb->ecc_block_n_ecc_type = 8; fcb->ecc_block_0_ecc_type = 8; + } else if (nand_oobsize == 224) { + fcb->ecc_block_n_ecc_type = 8; + fcb->ecc_block_0_ecc_type = 8; } }
Hi Alexandre,
return 16;
} }fcb->ecc_block_0_ecc_type = 8;
I have not your use case, but it looks ok for me and I merge it.
Applied to -u-boot-imx, thanks !
Best regards, Stefano Babic
Alexandre Coffignal
Stefano Babic
