[U-Boot] [PATCH 1/2] powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants.
CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file.
CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated.
Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated.
README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros.
Signed-off-by: Timur Tabi timur@freescale.com --- README | 37 ++++++++++++++++++++++ arch/powerpc/include/asm/config_mpc85xx.h | 39 ++++++++++++++++++++++++ include/configs/MPC8536DS.h | 16 +-------- include/configs/MPC8540ADS.h | 10 +----- include/configs/MPC8541CDS.h | 9 +----- include/configs/MPC8544DS.h | 9 +----- include/configs/MPC8548CDS.h | 9 +----- include/configs/MPC8555CDS.h | 9 +----- include/configs/MPC8560ADS.h | 10 +----- include/configs/MPC8568MDS.h | 9 +----- include/configs/MPC8569MDS.h | 14 +------- include/configs/MPC8572DS.h | 16 +-------- include/configs/P1022DS.h | 13 +------- include/configs/P1023RDS.h | 9 ----- include/configs/P1_P2_RDB.h | 18 +---------- include/configs/P2020DS.h | 13 +------- include/configs/P2041RDB.h | 14 -------- include/configs/SBC8540.h | 14 -------- include/configs/TQM85xx.h | 15 ++------- include/configs/corenet_ds.h | 13 -------- include/configs/mpq101.h | 16 +-------- include/configs/sbc8548.h | 9 +----- include/configs/sbc8560.h | 14 -------- include/configs/socrates.h | 9 +----- include/configs/stxgp3.h | 7 +--- include/configs/stxssa.h | 8 ++--- include/configs/xpedite520x.h | 10 +----- include/configs/xpedite537x.h | 10 +----- include/configs/xpedite550x.h | 10 +----- include/mpc85xx.h | 47 +++++++++++++++++++++++++++++ 30 files changed, 159 insertions(+), 277 deletions(-)
diff --git a/README b/README index 294b39e..d47ebc1 100644 --- a/README +++ b/README @@ -2785,6 +2785,43 @@ Low Level (hardware related) configuration options: and RPXsuper) to be able to adjust the position of the IMMR register after a reset.
+- CONFIG_SYS_CCSRBAR_DEFAULT: + Default (power-on reset) physical address of CCSR on Freescale + PowerPC SOCs. + +- CONFIG_SYS_CCSRBAR: + Virtual address of CCSR. On a 32-bit build, this is typically + the same value as CONFIG_SYS_CCSRBAR_DEFAULT. + + CONFIG_SYS_DEFAULT_IMMR must also be set to this value, + for cross-platform code that uses that macro instead. + +- CONFIG_SYS_CCSRBAR_PHYS: + Physical address of CCSR. CCSR can be relocated to a new + physical address, if desired. In this case, this macro should + be set to that address. Otherwise, it should be set to the + same value as CONFIG_SYS_CCSRBAR_DEFAULT. For example, CCSR + is typically relocated on 36-bit builds. It is recommended + that this macro be defined via the _HIGH and _LOW macros: + + #define CONFIG_SYS_CCSRBAR_PHYS ((CONFIG_SYS_CCSRBAR_PHYS_HIGH + * 1ull) << 32 | CONFIG_SYS_CCSRBAR_PHYS_LOW) + +- CONFIG_SYS_CCSRBAR_PHYS_HIGH: + Bits 33-36 of CONFIG_SYS_CCSRBAR_PHYS. This value is typically + either 0 (32-bit build) or 0xF (36-bit build). This macro is + used in assembly code, so it must not contain typecasts or + integer size suffixes (e.g. "ULL"). + +- CONFIG_SYS_CCSRBAR_PHYS_LOW: + Lower 32-bits of CONFIG_SYS_CCSRBAR_PHYS. This macro is + used in assembly code, so it must not contain typecasts or + integer size suffixes (e.g. "ULL"). + +- CONFIG_SYS_CCSR_DO_NOT_RELOCATE: + If this macro is defined, then CONFIG_SYS_CCSRBAR_PHYS will be + forced to a value that ensures that CCSR is not relocated. + - Floppy Disk Support: CONFIG_SYS_FDC_DRIVE_NUMBER
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 04ca989..3006548 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -23,6 +23,10 @@
/* SoC specific defines for Freescale MPC85xx (PQ3) and QorIQ processors */
+#ifdef CONFIG_SYS_CCSRBAR_DEFAULT +#error "Do not define CONFIG_SYS_CCSRBAR_DEFAULT in the board header file" +#endif + /* Number of TLB CAM entries we have on FSL Book-E chips */ #if defined(CONFIG_E500MC) #define CONFIG_SYS_NUM_TLBCAMS 64 @@ -34,34 +38,41 @@ #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8540) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 8 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8541) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 8 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8544) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 10 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8548) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 10 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8555) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 8 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8560) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 8 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8568) #define CONFIG_MAX_CPUS 1 @@ -70,6 +81,7 @@ #define QE_MURAM_SIZE 0x10000UL #define MAX_QE_RISC 2 #define QE_NUM_OF_SNUM 28 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8569) #define CONFIG_MAX_CPUS 1 @@ -78,11 +90,13 @@ #define QE_MURAM_SIZE 0x20000UL #define MAX_QE_RISC 4 #define QE_NUM_OF_SNUM 46 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
#elif defined(CONFIG_MPC8572) #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_DDR_115 #define CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134
@@ -105,6 +119,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
@@ -115,6 +130,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xffe00000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define QE_MURAM_SIZE 0x6000UL @@ -127,6 +143,7 @@ #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_FSL_SATA_ERRATUM_A001 @@ -149,6 +166,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
@@ -164,6 +182,7 @@ #define QE_MURAM_SIZE 0x6000UL #define MAX_QE_RISC 1 #define QE_NUM_OF_SNUM 28 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000
/* P1017 is single core version of P1023 */ #elif defined(CONFIG_P1017) @@ -177,6 +196,7 @@ #define CONFIG_SYS_BMAN_NUM_PORTALS 3 #define CONFIG_SYS_FM_MURAM_SIZE 0x10000 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff600000
#elif defined(CONFIG_P1020) #define CONFIG_MAX_CPUS 2 @@ -184,6 +204,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
@@ -193,6 +214,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define QE_MURAM_SIZE 0x6000UL @@ -204,6 +226,7 @@ #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_FSL_SATA_ERRATUM_A001 @@ -219,6 +242,7 @@ #define CONFIG_SYS_BMAN_NUM_PORTALS 3 #define CONFIG_SYS_FM_MURAM_SIZE 0x10000 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff600000
/* P1024 is lower end variant of P1020 */ #elif defined(CONFIG_P1024) @@ -227,6 +251,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
@@ -237,6 +262,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define QE_MURAM_SIZE 0x6000UL @@ -248,6 +274,7 @@ #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_ESDHC_A001
@@ -255,6 +282,7 @@ #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_ESDHC_A001
@@ -271,6 +299,7 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#elif defined(CONFIG_PPC_P2041) @@ -287,6 +316,7 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#elif defined(CONFIG_PPC_P3041) @@ -303,6 +333,7 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#elif defined(CONFIG_PPC_P4040) @@ -313,6 +344,7 @@ #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,p4080-pcie" +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000
#elif defined(CONFIG_PPC_P4080) #define CONFIG_MAX_CPUS 8 @@ -328,6 +360,7 @@ #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,p4080-pcie" +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_ERRATUM_CPC_A002 #define CONFIG_SYS_FSL_ERRATUM_CPC_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003 @@ -356,6 +389,7 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#elif defined(CONFIG_PPC_P5020) @@ -372,10 +406,15 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#else #error Processor type not defined for this platform #endif
+#ifndef CONFIG_SYS_CCSRBAR_DEFAULT +#error "CONFIG_SYS_CCSRBAR_DEFAULT is not defined for this platform" +#endif + #endif /* _ASM_MPC85xx_CONFIG_H_ */ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 783ed51..3253b18 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -127,22 +127,10 @@ #define CONFIG_SYS_L2_SIZE (512 << 10) #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE)
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR 0xffe00000 /* relocated CCSRBAR */ -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull /* physical addr of CCSRBAR */ -#else -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR -#endif -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xffe00000
#if defined(CONFIG_RAMBOOT_NAND) && !defined(CONFIG_NAND_SPL) -#define CONFIG_SYS_CCSRBAR_DEFAULT CONFIG_SYS_CCSRBAR -#else -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ +#define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif
/* DDR Setup */ diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index e1d933e..74ec3c8 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -89,15 +89,7 @@ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest region */ #define CONFIG_SYS_MEMTEST_END 0x00400000
- -/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ -#define CONFIG_SYS_CCSRBAR 0xe0000000 /* relocated CCSRBAR */ -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xe0000000
/* DDR Setup */ #define CONFIG_FSL_DDR1 diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 5918e64..c774aa1 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -62,14 +62,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000
/* DDR Setup */ #define CONFIG_FSL_DDR1 diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index b25fb55..cab8ba6 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -74,14 +74,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_PANIC_HANG /* do not reset board on panic */
/* DDR Setup */ #define CONFIG_FSL_DDR2 diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index c9a0f60..151d3f0 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -77,14 +77,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000
/* DDR Setup */ #define CONFIG_FSL_DDR2 diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 4c580a3..4976dbb 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -62,14 +62,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000
/* DDR Setup */ #define CONFIG_FSL_DDR1 diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index f55ef9d..6ff9078 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -86,15 +86,7 @@ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest region */ #define CONFIG_SYS_MEMTEST_END 0x00400000
/* DDR Setup */ #define CONFIG_FSL_DDR1 diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index f7df7f0..4317212 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -71,14 +71,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000
/* DDR Setup */ #define CONFIG_FSL_DDR2 diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index fa626bb..cd96f7c 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -105,20 +105,10 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_L2_SIZE (512 << 10) #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE)
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR 0xe0000000 /* relocated CCSRBAR */ -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR - /* physical addr of CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR - /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xe0000000
/* DDR Setup */ diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index bb8fb66..4451321 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -112,22 +112,10 @@ #define CONFIG_SYS_L2_SIZE (512 << 10) #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE)
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR 0xffe00000 /* relocated CCSRBAR */ -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull /* physical addr of CCSRBAR */ -#else -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#endif -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xffe00000
/* DDR Setup */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index a118975..57affa6 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -64,18 +64,7 @@ #define CONFIG_SYS_MEMTEST_START 0x00000000 #define CONFIG_SYS_MEMTEST_END 0x7fffffff
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ -#define CONFIG_SYS_CCSRBAR 0xffe00000 /* relocated CCSRBAR */ -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull -#else -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR -#endif -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR +#define CONFIG_SYS_CCSRBAR 0xffe00000
/* DDR Setup */ #define CONFIG_DDR_SPD diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h index 4f14a02..6b0c9f0 100644 --- a/include/configs/P1023RDS.h +++ b/include/configs/P1023RDS.h @@ -99,15 +99,6 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_SYS_LBC_LBCR 0x00000000 /* Implement conversion of addresses in the LBC */ -/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff600000 /* CCSRBAR Default */ -#define CONFIG_SYS_CCSRBAR 0xff600000 /* relocated CCSRBAR */ -/* physical addr of CCSRBAR */ -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */
/* DDR Setup */ #define CONFIG_VERY_BIG_RAM diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index df88b79..805d58b 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -148,24 +148,10 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_L2_SIZE (512 << 10) #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE)
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR 0xffe00000 /* relocated CCSRBAR */ -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull -#else -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR -#endif - /* CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses */ - /* CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xffe00000
/* DDR Setup */ diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index 90fe7c4..fca4c0b 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -118,18 +118,7 @@ #define CONFIG_SYS_L2_SIZE (512 << 10) #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE)
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ -#define CONFIG_SYS_CCSRBAR 0xffe00000 /* relocated CCSRBAR */ -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull /* physical addr of CCSRBAR */ -#else -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#endif -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xffe00000
/* DDR Setup */ #define CONFIG_VERY_BIG_RAM diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 2beb357..2adbd52 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -136,20 +136,6 @@ #define CONFIG_SYS_L3_SIZE (1024 << 10) #define CONFIG_SYS_INIT_L3_END (CONFIG_SYS_INIT_L3_ADDR + CONFIG_SYS_L3_SIZE)
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 /* CCSRBAR Default */ -#define CONFIG_SYS_CCSRBAR 0xfe000000 /* relocated CCSRBAR */ -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_CCSRBAR_PHYS 0xffe000000ull -#else -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR -#endif -/* PQII uses CONFIG_SYS_IMMR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR - #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_DCSRBAR 0xf0000000 #define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull diff --git a/include/configs/SBC8540.h b/include/configs/SBC8540.h index 72559c0..b5612d6 100644 --- a/include/configs/SBC8540.h +++ b/include/configs/SBC8540.h @@ -94,20 +94,6 @@ #error "You can only use ONE of PCI Ethernet Card or TSEC Ethernet or CPM FCC." #endif
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ - -#if XXX - #define CONFIG_SYS_CCSRBAR 0xfdf00000 /* relocated CCSRBAR */ -#else - #define CONFIG_SYS_CCSRBAR 0xff700000 /* default CCSRBAR */ -#endif -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ - #define CONFIG_SYS_SDRAM_SIZE 512 /* DDR is 512MB */
/* DDR Setup */ diff --git a/include/configs/TQM85xx.h b/include/configs/TQM85xx.h index b336723..daa1255 100644 --- a/include/configs/TQM85xx.h +++ b/include/configs/TQM85xx.h @@ -130,18 +130,11 @@ #define CONFIG_SYS_MEMTEST_START 0x00000000 #define CONFIG_SYS_MEMTEST_END 0x10000000
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xFF700000 /* CCSRBAR Default */ #ifdef CONFIG_TQM_BIGFLASH -#define CONFIG_SYS_CCSRBAR 0xA0000000 /* relocated CCSRBAR */ -#else /* !CONFIG_TQM_BIGFLASH */ -#define CONFIG_SYS_CCSRBAR 0xE0000000 /* relocated CCSRBAR */ -#endif /* CONFIG_TQM_BIGFLASH */ -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xA0000000 +#else +#define CONFIG_SYS_CCSRBAR 0xE0000000 +#endif
/* * DDR Setup diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 0b7becb..0174a95 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -144,19 +144,6 @@ #define CONFIG_SYS_L3_SIZE (1024 << 10) #define CONFIG_SYS_INIT_L3_END (CONFIG_SYS_INIT_L3_ADDR + CONFIG_SYS_L3_SIZE)
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 /* CCSRBAR Default */ -#define CONFIG_SYS_CCSRBAR 0xfe000000 /* relocated CCSRBAR */ -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_CCSRBAR_PHYS 0xffe000000ull /* physical addr of CCSRBAR */ -#else -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#endif -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ - #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_DCSRBAR 0xf0000000 #define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h index e76ca73..f0ed4d1 100644 --- a/include/configs/mpq101.h +++ b/include/configs/mpq101.h @@ -64,20 +64,8 @@
#define CONFIG_SYS_CLK_FREQ 33000000 /* sysclk for MPC85xx */
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 -#define CONFIG_SYS_CCSRBAR 0xe0000000 - -#ifdef CONFIG_PHYS_64BIT -# define CONFIG_SYS_CCSRBAR_PHYS 0xfe0000000ull -#else -# define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR -#endif - -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR +#define CONFIG_SYS_CCSRBAR 0xe0000000 +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR
/* DDR Setup */ #define CONFIG_FSL_DDR2 diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 7bf9fc7..5fcad08 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -103,14 +103,7 @@ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000
/* DDR Setup */ #define CONFIG_FSL_DDR2 diff --git a/include/configs/sbc8560.h b/include/configs/sbc8560.h index 435b148..e0af0d2 100644 --- a/include/configs/sbc8560.h +++ b/include/configs/sbc8560.h @@ -92,20 +92,6 @@ #error "You can only use ONE of PCI Ethernet Card or TSEC Ethernet or CPM FCC." #endif
/* DDR Setup */ diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 5f2fb1e..0f6bd9e 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -91,14 +91,7 @@ #define CONFIG_SYS_MEMTEST_START 0x00400000 #define CONFIG_SYS_MEMTEST_END 0x00C00000
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xFF700000 /* CCSRBAR Default */ -#define CONFIG_SYS_CCSRBAR 0xE0000000 /* relocated CCSRBAR */ -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xE0000000
/* DDR Setup */ #define CONFIG_FSL_DDR2 diff --git a/include/configs/stxgp3.h b/include/configs/stxgp3.h index fc3881d..66738d5 100644 --- a/include/configs/stxgp3.h +++ b/include/configs/stxgp3.h @@ -109,12 +109,9 @@
#ifdef CONFIG_SYS_RAMBOOT #define CONFIG_SYS_CCSRBAR_DEFAULT 0x40000000 /* CCSRBAR by BDI cfg */ -#else -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ #endif -#define CONFIG_SYS_CCSRBAR 0xfdf00000 /* relocated CCSRBAR */ -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xfdf00000 +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR
/* DDR Setup */ #define CONFIG_FSL_DDR1 diff --git a/include/configs/stxssa.h b/include/configs/stxssa.h index d5dd94f..a1efe11 100644 --- a/include/configs/stxssa.h +++ b/include/configs/stxssa.h @@ -121,12 +121,10 @@
#ifdef CONFIG_SYS_RAMBOOT #define CONFIG_SYS_CCSRBAR_DEFAULT 0x40000000 /* CCSRBAR by BDI cfg */ -#else -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ #endif -#define CONFIG_SYS_CCSRBAR 0xe0000000 /* relocated CCSRBAR */ -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ + +#define CONFIG_SYS_CCSRBAR 0xe0000000 +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR
/* DDR Setup */ #define CONFIG_FSL_DDR1 diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index b6b391f..42517c9 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -78,14 +78,8 @@ #define CONFIG_BTB /* toggle branch predition */ #define CONFIG_ENABLE_36BIT_PHYS 1
-/* - * Base addresses -- Note these are effective addresses where the - * actual resources get mapped (not physical addresses) - */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ -#define CONFIG_SYS_CCSRBAR 0xef000000 /* relocated CCSRBAR */ -#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_CCSRBAR 0xef000000 +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR
/* * Diagnostics diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index a74766d..202f209 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -96,14 +96,8 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_BTB /* toggle branch predition */ #define CONFIG_ENABLE_36BIT_PHYS 1
/* * Diagnostics diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 17aab5a..f13e4db 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -93,14 +93,8 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_BTB /* toggle branch predition */ #define CONFIG_ENABLE_36BIT_PHYS 1
/* * Diagnostics diff --git a/include/mpc85xx.h b/include/mpc85xx.h index 2495b99..4b61bc0 100644 --- a/include/mpc85xx.h +++ b/include/mpc85xx.h @@ -26,4 +26,51 @@ #define SCCR_DFBRG10 0x00000002 /* BRGCLK division by 64 */ #define SCCR_DFBRG11 0x00000003 /* BRGCLK division by 256 */
+/* + * Define default values for some CCSR macros to make header files cleaner* + * + * To completely disable CCSR relocation in a board header file, define + * CONFIG_SYS_CCSR_DO_NOT_RELOCATE. This will force CONFIG_SYS_CCSRBAR_PHYS + * to a value that is the same as CONFIG_SYS_CCSRBAR. + */ + +#ifdef CONFIG_SYS_CCSRBAR_PHYS +#error "Do not define CONFIG_SYS_CCSRBAR_PHYS directly. Use \ + CONFIG_SYS_CCSRBAR_PHYS_LOW and CONFIG_SYS_CCSRBAR_PHYS_HIGH instead." +#endif + +#ifdef CONFIG_SYS_CCSR_DO_NOT_RELOCATE +#if defined(CONFIG_SYS_CCSRBAR_PHYS_LOW) || defined(CONFIG_SYS_CCSRBAR_PHYS_HIGH) +#warning "CONFIG_SYS_CCSR_DO_NOT_RELOCATE is defined and will override \ + existing definitions of CONFIG_SYS_CCSRBAR_PHYS_LOW and/or \ + CONFIG_SYS_CCSRBAR_PHYS_HIGH." +#endif +#undef CONFIG_SYS_CCSRBAR_PHYS_HIGH +#undef CONFIG_SYS_CCSRBAR_PHYS_LOW +#define CONFIG_SYS_CCSRBAR_PHYS_HIGH 0 +#endif + +#ifndef CONFIG_SYS_CCSRBAR +#define CONFIG_SYS_CCSRBAR CONFIG_SYS_CCSRBAR_DEFAULT +#endif + +#ifndef CONFIG_SYS_CCSRBAR_PHYS_HIGH +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_CCSRBAR_PHYS_HIGH 0xf +#else +#define CONFIG_SYS_CCSRBAR_PHYS_HIGH 0 +#endif +#endif + +#ifndef CONFIG_SYS_CCSRBAR_PHYS_LOW +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR_DEFAULT +#endif + +#define CONFIG_SYS_CCSRBAR_PHYS ((CONFIG_SYS_CCSRBAR_PHYS_HIGH * 1ull) << 32 | \ + CONFIG_SYS_CCSRBAR_PHYS_LOW) + +#ifndef CONFIG_SYS_IMMR +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR +#endif + #endif /* __MPC85xx_H__ */
Before main memory (DDR) is initialized, the on-chip L1 cache is used as a memory area for the stack and the global data (gd_t) structure. This is called the initial RAM area, or initram. The L1 cache is locked and the TLBs point to a non-existent address (so that there's no chance it will overlap main memory or any device). The L1 cache is also configured not to write out to memory or the L2 cache, so everything stays in the L1 cache.
One of the things we might do while running out of initram is relocate CCSR. On reset, CCSR is typically located at some high 32-bit address, like 0xfe000000, and this may not be the best place for CCSR. For example, on 36-bit systems, CCSR is relocated to 0xffe000000, near the top of 36-bit memory space.
On some future Freescale SOCs, the L1 cache will be forced to write to the backing store, so we can no longer have the TLBs point to non-existent address. Instead, we will point the TLBs to an unused area in CCSR. In order for this technique to work, CCSR needs to be relocated before the initram memory is enabled.
Unlike the original CCSR relocation code in cpu_init_early_f(), the TLBs we create now for relocating CCSR are deleted after the relocation is finished. cpu_init_early_f() will still need to create a TLB for CCSR (at the new location) for normal U-Boot purposes. This is done to keep the impact to existing U-Boot code minimal and to better isolate the CCSR relocation code.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 58 ------- arch/powerpc/cpu/mpc85xx/start.S | 234 +++++++++++++++++++++++++++++ 2 files changed, 234 insertions(+), 58 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 32aa94b..64eda94 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -24,51 +24,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) -#ifdef CONFIG_FSL_CORENET -static void setup_ccsrbar(void) -{ - u32 temp; - volatile u32 *ccsr_virt = (volatile u32 *)(CONFIG_SYS_CCSRBAR + 0x1000); - volatile ccsr_local_t *ccm; - - /* - * We can't call set_law() because we haven't moved - * CCSR yet. - */ - ccm = (void *)ccsr_virt; - - out_be32(&ccm->law[0].lawbarh, - (u64)CONFIG_SYS_CCSRBAR_PHYS >> 32); - out_be32(&ccm->law[0].lawbarl, (u32)CONFIG_SYS_CCSRBAR_PHYS); - out_be32(&ccm->law[0].lawar, - LAW_EN | (0x1e << 20) | LAW_SIZE_4K); - - in_be32((u32 *)(ccsr_virt + 0)); - in_be32((u32 *)(ccsr_virt + 1)); - isync(); - - ccm = (void *)CONFIG_SYS_CCSRBAR; - /* Now use the temporary LAW to move CCSR */ - out_be32(&ccm->ccsrbarh, (u64)CONFIG_SYS_CCSRBAR_PHYS >> 32); - out_be32(&ccm->ccsrbarl, (u32)CONFIG_SYS_CCSRBAR_PHYS); - out_be32(&ccm->ccsrar, CCSRAR_C); - temp = in_be32(&ccm->ccsrar); - disable_law(0); -} -#else -static void setup_ccsrbar(void) -{ - u32 temp; - volatile u32 *ccsr_virt = (volatile u32 *)(CONFIG_SYS_CCSRBAR + 0x1000); - - temp = in_be32(ccsr_virt); - out_be32(ccsr_virt, CONFIG_SYS_CCSRBAR_PHYS >> 12); - temp = in_be32((volatile u32 *)CONFIG_SYS_CCSRBAR); -} -#endif -#endif - /* We run cpu_init_early_f in AS = 1 */ void cpu_init_early_f(void) { @@ -93,19 +48,6 @@ void cpu_init_early_f(void)
write_tlb(mas0, mas1, mas2, mas3, mas7);
- /* set up CCSR if we want it moved */ -#if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) - mas0 = MAS0_TLBSEL(0) | MAS0_ESEL(1); - /* mas1 is the same as above */ - mas2 = FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0x1000, MAS2_I|MAS2_G); - mas3 = FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_DEFAULT, 0, MAS3_SW|MAS3_SR); - mas7 = FSL_BOOKE_MAS7(CONFIG_SYS_CCSRBAR_DEFAULT); - - write_tlb(mas0, mas1, mas2, mas3, mas7); - - setup_ccsrbar(); -#endif - init_laws(); invalidate_tlb(0); init_tlbs(); diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 5777493..c9cf8fb 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -284,6 +284,240 @@ _start_e500:
#endif /* CONFIG_MPC8569 */
+/* + * Relocate CCSR, if necessary. We relocate CCSR if (obviously) the default + * location is not where we want it. This typically happens on a 36-bit + * system, where we want to move CCSR to near the top of 36-bit address space. + * + * To move CCSR, we create two temporary TLBs, one for the old location, and + * another for the new location. On CoreNet systems, we also need to create + * a special, temporary LAW. + * + * As a general rule, TLB0 is used for short-term TLBs, and TLB1 is used for + * long-term TLBs, so we use TLB0 here. + */ +#if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) + +#if !defined(CONFIG_SYS_CCSRBAR_PHYS_HIGH) || !defined(CONFIG_SYS_CCSRBAR_PHYS_LOW) +#error "CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW) must be defined." +#endif + +purge_old_ccsr_tlb: + lis r8, CONFIG_SYS_CCSRBAR@h + ori r8, r8, CONFIG_SYS_CCSRBAR@l + lis r9, (CONFIG_SYS_CCSRBAR + 0x1000)@h + ori r9, r9, (CONFIG_SYS_CCSRBAR + 0x1000)@l + + /* + * In a multi-stage boot (e.g. NAND boot), a previous stage may have + * created a TLB for CCSR, which will interfere with our relocation + * code. Since we're going to create a new TLB for CCSR anyway, + * it should be safe to delete this old TLB here. We have to search + * for it, though. + */ + + li r1, 0 + mtspr MAS6, r1 /* Search the current address space and PID */ + tlbsx 0, r8 + mfspr r1, MAS1 + andis. r2, r1, MAS1_VALID@h /* Check for the Valid bit */ + beq 1f /* Skip if no TLB found */ + + rlwinm r1, r1, 0, 1, 31 /* Clear Valid bit */ + mtspr MAS1, r1 + tlbwe +1: + +create_ccsr_new_tlb: + /* + * Create a TLB for the new location of CCSR. Register R8 is reserved + * for the virtual address of this TLB (CONFIG_SYS_CCSRBAR). + */ + lis r0, FSL_BOOKE_MAS0(0, 0, 0)@h + ori r0, r0, FSL_BOOKE_MAS0(0, 0, 0)@l + lis r1, FSL_BOOKE_MAS1(1, 0, 0, 0, BOOKE_PAGESZ_4K)@h + ori r1, r1, FSL_BOOKE_MAS1(1, 0, 0, 0, BOOKE_PAGESZ_4K)@l + lis r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR, (MAS2_I|MAS2_G))@h + ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR, (MAS2_I|MAS2_G))@l + lis r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS_LOW, 0, (MAS3_SW|MAS3_SR))@h + ori r3, r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS_LOW, 0, (MAS3_SW|MAS3_SR))@l + lis r7, CONFIG_SYS_CCSRBAR_PHYS_HIGH@h + ori r7, r7, CONFIG_SYS_CCSRBAR_PHYS_HIGH@l + mtspr MAS0, r0 + mtspr MAS1, r1 + mtspr MAS2, r2 + mtspr MAS3, r3 + mtspr MAS7, r7 + isync + msync + tlbwe + + /* + * Create a TLB for the old location of CCSR. Register R9 is reserved + * for the virtual address of this TLB (CONFIG_SYS_CCSRBAR + 0x1000). + */ +create_ccsr_old_tlb: + lis r0, FSL_BOOKE_MAS0(0, 1, 0)@h + ori r0, r0, FSL_BOOKE_MAS0(0, 1, 0)@l + lis r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0x1000, (MAS2_I|MAS2_G))@h + ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0x1000, (MAS2_I|MAS2_G))@l + lis r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_DEFAULT, 0, (MAS3_SW|MAS3_SR))@h + ori r3, r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_DEFAULT, 0, (MAS3_SW|MAS3_SR))@l + li r7, 0 /* The default CCSR address is always a 32-bit number */ + mtspr MAS0, r0 + /* MAS1 is the same as above */ + mtspr MAS2, r2 + mtspr MAS3, r3 + mtspr MAS7, r7 + isync + msync + tlbwe + +#ifdef CONFIG_FSL_CORENET + +#define CCSR_LAWBARH0 (CONFIG_SYS_CCSRBAR + 0x1000) +#define LAW_EN 0x80000000 +#define LAW_SIZE_4K 0xb +#define CCSRBAR_LAWAR (LAW_EN | (0x1e << 20) | LAW_SIZE_4K) +#define CCSRAR_C 0x80000000 /* Commit */ + +create_temp_law: + /* + * On CoreNet systems, we create the temporary LAW using a special LAW + * target ID of 0x1e. LAWBARH is at offset 0xc00 in CCSR. + */ + lis r0, CONFIG_SYS_CCSRBAR_PHYS_HIGH@h + ori r0, r0, CONFIG_SYS_CCSRBAR_PHYS_HIGH@l + lis r1, CONFIG_SYS_CCSRBAR_PHYS_LOW@h + ori r1, r1, CONFIG_SYS_CCSRBAR_PHYS_LOW@l + lis r2, CCSRBAR_LAWAR@h + ori r2, r2, CCSRBAR_LAWAR@l + + stw r0, 0xc00(r9) /* LAWBARH0 */ + stw r1, 0xc04(r9) /* LAWBARL0 */ + sync + stw r2, 0xc08(r9) /* LAWAR0 */ + + /* + * Read back from LAWAR to ensure the update is complete. e500mc + * cores also require an isync. + */ + lwz r0, 0xc08(r9) /* LAWAR0 */ + isync + + /* + * Read the current CCSRBARH and CCSRBARL using load word instructions. + * Follow this with an isync instruction. This forces any outstanding + * accesses to configuration space to completion. + */ +read_old_ccsrbar: + lwz r0, 0(r9) /* CCSRBARH */ + lwz r0, 4(r9) /* CCSRBARH */ + isync + + /* + * Write the new values for CCSRBARH and CCSRBARL to their old + * locations. The CCSRBARH has a shadow register. When the CCSRBARH + * has a new value written it loads a CCSRBARH shadow register. When + * the CCSRBARL is written, the CCSRBARH shadow register contents + * along with the CCSRBARL value are loaded into the CCSRBARH and + * CCSRBARL registers, respectively. Follow this with a sync + * instruction. + */ +write_new_ccsrbar: + lis r0, CONFIG_SYS_CCSRBAR_PHYS_HIGH@h + ori r0, r0, CONFIG_SYS_CCSRBAR_PHYS_HIGH@l + lis r1, CONFIG_SYS_CCSRBAR_PHYS_LOW@h + ori r1, r1, CONFIG_SYS_CCSRBAR_PHYS_LOW@l + lis r2, CCSRAR_C@h + ori r2, r2, CCSRAR_C@l + + stw r0, 0(r9) /* Write to CCSRBARH */ + sync /* Make sure we write to CCSRBARH first */ + stw r1, 4(r9) /* Write to CCSRBARL */ + sync + + /* + * Write a 1 to the commit bit (C) of CCSRAR at the old location. + * Follow this with a sync instruction. + */ + stw r2, 8(r9) + sync + + /* Delete the temporary LAW */ +delete_temp_law: + li r1, 0 + stw r1, 0xc08(r8) + sync + stw r1, 0xc00(r8) + stw r1, 0xc04(r8) + sync + +#else /* #ifdef CONFIG_FSL_CORENET */ + +write_new_ccsrbar: + /* + * Read the current value of CCSRBAR using a load word instruction + * followed by an isync. This forces all accesses to configuration + * space to complete. + */ + sync + lwz r0, 0(r9) + isync + +/* CONFIG_SYS_CCSRBAR_PHYS right shifted by 12 */ +#define CCSRBAR_PHYS_RS12 ((CONFIG_SYS_CCSRBAR_PHYS_HIGH << 20) | \ + (CONFIG_SYS_CCSRBAR_PHYS_LOW >> 12)) + + /* Write the new value to CCSRBAR. */ + lis r0, CCSRBAR_PHYS_RS12@h + ori r0, r0, CCSRBAR_PHYS_RS12@l + stw r0, 0(r9) + sync + + /* + * The manual says to perform a load of an address that does not + * access configuration space or the on-chip SRAM using an existing TLB, + * but that doesn't appear to be necessary. We will do the isync, + * though. + */ + isync + + /* + * Read the contents of CCSRBAR from its new location, followed by + * another isync. + */ + lwz r0, 0(r8) + isync + +#endif /* #ifdef CONFIG_FSL_CORENET */ + + /* Delete the temporary TLBs */ +delete_temp_tlbs: + lis r0, FSL_BOOKE_MAS0(0, 0, 0)@h + ori r0, r0, FSL_BOOKE_MAS0(0, 0, 0)@l + li r1, 0 + lis r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR, (MAS2_I|MAS2_G))@h + ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR, (MAS2_I|MAS2_G))@l + mtspr MAS0, r0 + mtspr MAS1, r1 + mtspr MAS2, r2 + isync + msync + tlbwe + + lis r0, FSL_BOOKE_MAS0(0, 1, 0)@h + ori r0, r0, FSL_BOOKE_MAS0(0, 1, 0)@l + lis r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0x1000, (MAS2_I|MAS2_G))@h + ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0x1000, (MAS2_I|MAS2_G))@l + mtspr MAS0, r0 + mtspr MAS2, r2 + isync + msync + tlbwe +#endif /* #if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) */ + +create_init_ram_area: lis r6,FSL_BOOKE_MAS0(1, 15, 0)@h ori r6,r6,FSL_BOOKE_MAS0(1, 15, 0)@l
Timur Tabi
