[PATCH] mtd: nand: Allow full NAND framework in SPL
Add configuration option to compile the entire NAND framework into U-Boot SPL. This is required by some drivers, like the Denali NAND, which use a lot of functionality from the NAND core.
Signed-off-by: Marek Vasut marex@denx.de Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- drivers/mtd/nand/raw/Kconfig | 7 +++++++ drivers/mtd/nand/raw/Makefile | 16 +++++++++------- 2 files changed, 16 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index ce67d1abde..a3bd45f24e 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -694,4 +694,11 @@ config SPL_NAND_SIMPLE expose the cmd_ctrl() interface. endif
+config SPL_NAND_FRAMEWORK + bool "Compile the entire NAND framework into the SPL" + help + Some drivers require a lot of functionality from the NAND framework + core when used in SPL. This option allows compiling the full NAND + framework into the SPL instead of it's reduced version. + endif # if NAND diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index a398aa9d88..e0f7045fec 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -3,8 +3,16 @@ # (C) Copyright 2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
+nand-framework-objs := nand.o nand_bbt.o nand_ids.o nand_util.o \ + nand_ecc.o nand_base.o nand_timings.o + ifdef CONFIG_SPL_BUILD
+ifdef CONFIG_SPL_NAND_FRAMEWORK +obj-y += $(nand-framework-objs) +NORMAL_DRIVERS=y +endif + ifdef CONFIG_SPL_NAND_DRIVERS NORMAL_DRIVERS=y endif @@ -27,19 +35,13 @@ else # not spl
NORMAL_DRIVERS=y
-obj-y += nand.o -obj-y += nand_bbt.o -obj-y += nand_ids.o -obj-y += nand_util.o -obj-y += nand_ecc.o -obj-y += nand_base.o obj-y += nand_amd.o obj-y += nand_hynix.o obj-y += nand_macronix.o obj-y += nand_micron.o obj-y += nand_samsung.o obj-y += nand_toshiba.o -obj-y += nand_timings.o +obj-y += $(nand-framework-objs)
endif # not spl
+ MTD mainatainers
Hi Jit,
- MTD mainatainers
There are already other implementations like this in u-boot for different platforms. The idea is to remove this code and implement a more generic management so as not to replicate code. Could you please change your implementation to a more generic version?
Thanks and regards, Dario
Dario Binacchi
Jagan Teki
Jit Loon Lim
