[U-Boot] configure USB Host1 in U-Boot of iMx53
Dear All,
I have added the USB host controller driver into our Mx53 loco board's u-boot and also made some changes in mx53_loco.h and mx53_loco.c.
Below is the complete log what I am getting on serial console:
U-Boot 2009.08-dirty (Jan 15 2013 - 12:32:20) CPU: Freescale i.MX53 family 2.1V at 800 MHz mx53 pll1: 800MHz mx53 pll2: 400MHz mx53 pll3: 216MHz mx53 pll4: 455MHz ipg clock : 66666666Hz ipg per clock : 33333333Hz uart clock : 66666666Hz cspi clock : 54000000Hz ahb clock : 133333333Hz axi_a clock : 400000000Hz axi_b clock : 200000000Hz emi_slow clock: 133333333Hz ddr clock : 400000000Hz esdhc1 clock : 80000000Hz esdhc2 clock : 80000000Hz esdhc3 clock : 80000000Hz esdhc4 clock : 80000000Hz nfc clock : 26666666Hz Board: MX53-LOCO 1.0 Boot Reason: [POR] Boot Device: SD I2C: ready DRAM: 1 GB MMC: FSL_ESDHC: 0, FSL_ESDHC: 1 *** Warning - bad CRC or MMC, using default environment
In: serial Out: serial Err: serial
Serial reinitilized! Net: got MAC address from IIM: 00:04:9f:02:41:18 FEC0 [PRIME] Hit any key to stop autoboot: 0 MX53-LOCO U-Boot > MX53-LOCO U-Boot > MX53-LOCO U-Boot > usb start (Re)start USB... USB: Register 10011 NbrPorts 1 USB EHCI 1.00 scanning bus for devices... New Device 0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0x40 USB DESCRIPTOR_1 18 set address 1 usb_control_msg: request: 0x5, requesttype: 0x0, value 0x1 index 0x0 length 0x0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0x12 USB DESCRIPTOR2 18 NEW DEVICE STRINGS : Mfr=1, Product=2, SerialNumber=0 , Dtype=1 , DClass=9 , DProto=1 , Len=18 , MaxP=64 , ConfigNo=1 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x9 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x19 get_conf_no 0 Result 25, wLength 25 if 0, ep 0 ##EP epmaxpacketin[1] = 8 set configuration 1 usb_control_msg: request: 0x9, requesttype: 0x0, value 0x1 index 0x0 length 0x0 new device strings: Mfr=1, Product=2, SerialNumber=0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x300 index 0x0 length 0xFF USB device number 1 default language ID 0x1 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x301 index 0x1 length 0xFF usb_control_msg: request: 0x6, requesttype: 0x80, value 0x302 index 0x1 length 0xFF Manufacturer u-boot Product EHCI Host Controller SerialNumber USB hub found usb_control_msg: request: 0x6, requesttype: 0xA0, value 0x2900 index 0x0 length 0x4 usb_control_msg: request: 0x6, requesttype: 0xA0, value 0x2900 index 0x0 length 0x8 1 ports detected individual port power switching standalone hub global over-current protection power on to power good time: 20ms hub controller current requirement: 0mA port 1 is removable usb_control_msg: request: 0x0, requesttype: 0xA0, value 0x0 index 0x0 length 0x4 get_hub_status returned status 1, change 8101 local power source is lost (inactive) no over-current condition exists enabling power on all ports usb_control_msg: request: 0x3, requesttype: 0x23, value 0x8 index 0x1 length 0x0 port 1 returns 0 usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 Port 1 Status 101 Change 1 port 1 connection change port 1 connection change usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 portstatus 101, change 1, 12 Mb/s usb_control_msg: request: 0x1, requesttype: 0x23, value 0x10 index 0x1 length 0x0 hub_port_reset: resetting port 0... usb_control_msg: request: 0x3, requesttype: 0x23, value 0x4 index 0x1 length 0x0 usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 portstatus 503, change 10, 480 Mb/s STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 1 usb_control_msg: request: 0x1, requesttype: 0x23, value 0x14 index 0x1 length 0x0 New Device 1 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0x40 EHCI timed out on TD - token=0x80008c80 USB DESCRIPTOR_1 64 hub_port_reset: resetting port 0... usb_control_msg: request: 0x3, requesttype: 0x23, value 0x4 index 0x1 length 0x0 usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4 portstatus 503, change 10, 480 Mb/s STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 1 usb_control_msg: request: 0x1, requesttype: 0x23, value 0x14 index 0x1 length 0x0 set address 2 usb_control_msg: request: 0x5, requesttype: 0x0, value 0x2 index 0x0 length 0x0 EHCI timed out on TD - token=0x80008d80 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0x12 EHCI timed out on TD - token=0x80008c80 USB DESCRIPTOR2 18 NEW DEVICE STRINGS : Mfr=0, Product=0, SerialNumber=0 , Dtype=0 , DClass=0 , DProto=0 , Len=0 , MaxP=255 , ConfigNo=0 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x9 EHCI timed out on TD - token=0x80008c80 usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x10 EHCI timed out on TD - token=0x80008c80 get_conf_no 0 Result 16, wLength 16 ERROR: NOT USB_CONFIG_DESC ff set configuration 0 usb_control_msg: request: 0x9, requesttype: 0x0, value 0x0 index 0x0 length 0x0 EHCI timed out on TD - token=0x80008d80 new device strings: Mfr=0, Product=0, SerialNumber=0 Manufacturer Product SerialNumber 2 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found MX53-LOCO U-Boot > usb tree
Device Tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 See Interface (480 Mb/s, 0mA)
Please look into the matter and please suggest, as I am stuck in my development.
Regards, Sarvesh Gupta
________________________________
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech and delete the original message.
On 16/01/2013 11:49, Sarvesh Gupta wrote:
Dear All,
This ML is intended for U-Boot mainline. However, you are using a version provided and modified by the manufacturer. Ask your support for this, or use u-boot mainline (v2013.01) to post your questions on this mailing list.
Best regards, Stefano Babic
Sarvesh,
USB host works by default on mx53loco. As Stefano suggested, please switch to U-boot version 2013.01.
Regards,
Fabio Estevam
Fabio Estevam <festevam <at> gmail.com> writes:
Sarvesh,
Regards,
Fabio Estevam
Fabio,
Thanks, I have started using the 2013.01 and I am able to get the storage device. Fatload and fatls commands are also working.
Now I want to boot my linux from USB stick, So, can you suggest me the procedure for the same? Actually my intention is to boot from USb then mount the sdcard and copy the tar files of u-boot, uTmage and rootfs into sdcard to update. Please suggest.
Fabio Estevam
Sarvesh Gupta
sarvesh gupta
Stefano Babic
