[PATCH 0/7] rockchip: rk35xx: Sync device tree with linux v6.8-rc1
This series sync RK356x and RK3588 device tree with linux v6.8-rc1. It also moves some common/default props into the SoC u-boot.dtsi files.
Also drop the rockchip,rk3568-dwc3 compatible now that dwc3-generic driver support the rockchip,rk3588-dwc3 compatible.
Patch 1-2 sync rk356x device trees Patch 3 move common uart2 props to rk356x-u-boot.dtsi Patch 4-5 sync rk3588 device trees Patch 6 add default u-boot,spl-boot-order prop to rk3588s-u-boot.dtsi Patch 7 remove unnecessary status = "okay" props
Jonas Karlman (7): rockchip: rk356x: Sync device tree from linux v6.7 rockchip: rk356x: Sync device tree from linux v6.8-rc1 rockchip: rk356x: Move common uart2 props to rk356x-u-boot.dtsi rockchip: rk3588: Sync device tree with linux v6.7 rockchip: rk3588: Sync device tree from linux v6.8-rc1 rockchip: rk3588: Add default u-boot,spl-boot-order prop rockchip: rk35xx: Remove unnecessary status props
.../arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi | 7 - arch/arm/dts/rk3566-anbernic-rgxx3.dtsi | 42 ++--- arch/arm/dts/rk3566-quartz64-a-u-boot.dtsi | 12 -- arch/arm/dts/rk3566-quartz64-a.dts | 7 +- arch/arm/dts/rk3566-quartz64-b-u-boot.dtsi | 12 -- arch/arm/dts/rk3566-quartz64-b.dts | 2 - arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi | 12 -- arch/arm/dts/rk3566-radxa-cm3-io.dts | 5 +- arch/arm/dts/rk3566-soquartz-blade.dts | 4 + arch/arm/dts/rk3566-soquartz-cm4.dts | 4 + arch/arm/dts/rk3566-soquartz-model-a.dts | 4 + arch/arm/dts/rk3566-soquartz-u-boot.dtsi | 12 -- arch/arm/dts/rk3566-soquartz.dtsi | 4 - arch/arm/dts/rk3568-bpi-r2-pro-u-boot.dtsi | 13 -- arch/arm/dts/rk3568-evb-u-boot.dtsi | 17 -- arch/arm/dts/rk3568-evb.dts | 3 - arch/arm/dts/rk3568-generic-u-boot.dtsi | 11 -- arch/arm/dts/rk3568-lubancat-2-u-boot.dtsi | 12 -- arch/arm/dts/rk3568-lubancat-2.dts | 3 - arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi | 12 -- arch/arm/dts/rk3568-nanopi-r5s.dtsi | 3 - arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi | 12 -- arch/arm/dts/rk3568-odroid-m1.dts | 3 - arch/arm/dts/rk3568-radxa-cm3i.dtsi | 3 - arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi | 12 -- arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 12 -- arch/arm/dts/rk3568-rock-3a.dts | 7 +- arch/arm/dts/rk356x-u-boot.dtsi | 12 +- arch/arm/dts/rk356x.dtsi | 20 ++- arch/arm/dts/rk3588-edgeble-neu6a-io.dts | 4 - arch/arm/dts/rk3588-edgeble-neu6b-io.dts | 6 +- arch/arm/dts/rk3588-evb1-v10.dts | 99 +++++++++++- arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi | 6 - arch/arm/dts/rk3588-nanopc-t6.dts | 10 +- .../dts/rk3588-orangepi-5-plus-u-boot.dtsi | 6 - arch/arm/dts/rk3588-orangepi-5-plus.dts | 1 - arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi | 6 - arch/arm/dts/rk3588-quartzpro64.dts | 2 +- arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 12 -- arch/arm/dts/rk3588-rock-5b.dts | 13 +- arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi | 7 - arch/arm/dts/rk3588-turing-rk1.dtsi | 6 +- arch/arm/dts/rk3588-u-boot.dtsi | 2 +- arch/arm/dts/rk3588s-orangepi-5.dts | 9 +- arch/arm/dts/rk3588s-pinctrl.dtsi | 2 +- arch/arm/dts/rk3588s-rock-5a-u-boot.dtsi | 6 - arch/arm/dts/rk3588s-rock-5a.dts | 10 +- arch/arm/dts/rk3588s-u-boot.dtsi | 49 ++---- arch/arm/dts/rk3588s.dtsi | 152 ++++++++++++++++++ arch/arm/mach-rockchip/rk3588/syscon_rk3588.c | 2 +- include/dt-bindings/clock/rk3568-cru.h | 1 + include/dt-bindings/soc/rockchip,vop2.h | 4 + 52 files changed, 372 insertions(+), 325 deletions(-)
Sync rk356x device tree from linux v6.7.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3566-anbernic-rgxx3.dtsi | 42 +++++++++++++------------ arch/arm/dts/rk3566-quartz64-a.dts | 2 -- arch/arm/dts/rk3566-quartz64-b.dts | 2 -- arch/arm/dts/rk3566-radxa-cm3-io.dts | 4 +-- arch/arm/dts/rk3566-soquartz.dtsi | 3 -- arch/arm/dts/rk3568-evb.dts | 3 -- arch/arm/dts/rk3568-lubancat-2.dts | 3 -- arch/arm/dts/rk3568-nanopi-r5s.dtsi | 3 -- arch/arm/dts/rk3568-odroid-m1.dts | 3 -- arch/arm/dts/rk3568-radxa-cm3i.dtsi | 3 -- arch/arm/dts/rk3568-rock-3a.dts | 7 +++-- arch/arm/dts/rk356x.dtsi | 20 +++++++++++- include/dt-bindings/clock/rk3568-cru.h | 1 + 13 files changed, 48 insertions(+), 48 deletions(-)
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi index ad43fa199ca5..8cbf3d9a4f22 100644 --- a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi +++ b/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi @@ -191,30 +191,30 @@ }; };
- leds: gpio-leds { - compatible = "gpio-leds"; - pinctrl-0 = <&led_pins>; - pinctrl-names = "default"; + leds: pwm-leds { + compatible = "pwm-leds";
green_led: led-0 { color = <LED_COLOR_ID_GREEN>; default-state = "on"; function = LED_FUNCTION_POWER; - gpios = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + max-brightness = <255>; + pwms = <&pwm6 0 25000 0>; };
amber_led: led-1 { color = <LED_COLOR_ID_AMBER>; function = LED_FUNCTION_CHARGING; - gpios = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>; - retain-state-suspended; + max-brightness = <255>; + pwms = <&pwm7 0 25000 0>; };
red_led: led-2 { color = <LED_COLOR_ID_RED>; default-state = "off"; function = LED_FUNCTION_STATUS; - gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>; + max-brightness = <255>; + pwms = <&pwm0 0 25000 0>; }; };
@@ -356,7 +356,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>; regulator-name = "vdd_logic"; @@ -371,7 +370,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>; regulator-name = "vdd_gpu"; @@ -533,7 +531,6 @@ regulator-boot-on; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1390000>; - regulator-init-microvolt = <900000>; regulator-name = "vdd_cpu"; regulator-ramp-delay = <2300>; vin-supply = <&vcc_sys>; @@ -597,15 +594,6 @@ }; };
- gpio-led { - led_pins: led-pins { - rockchip,pins = - <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>, - <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>, - <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - joy-mux { joy_mux_en: joy-mux-en { rockchip,pins = @@ -654,10 +642,24 @@ vccio7-supply = <&vcc_3v3>; };
+&pwm0 { + pinctrl-0 = <&pwm0m1_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + &pwm5 { status = "okay"; };
+&pwm6 { + status = "okay"; +}; + +&pwm7 { + status = "okay"; +}; + &saradc { vref-supply = <&vcc_1v8>; status = "okay"; diff --git a/arch/arm/dts/rk3566-quartz64-a.dts b/arch/arm/dts/rk3566-quartz64-a.dts index 25a8c781f4e7..854d02b46e6f 100644 --- a/arch/arm/dts/rk3566-quartz64-a.dts +++ b/arch/arm/dts/rk3566-quartz64-a.dts @@ -366,7 +366,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>; regulator-name = "vdd_logic"; @@ -381,7 +380,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>; regulator-name = "vdd_gpu"; diff --git a/arch/arm/dts/rk3566-quartz64-b.dts b/arch/arm/dts/rk3566-quartz64-b.dts index b276eb0810c7..2d92713be2a0 100644 --- a/arch/arm/dts/rk3566-quartz64-b.dts +++ b/arch/arm/dts/rk3566-quartz64-b.dts @@ -277,7 +277,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>;
regulator-state-mem { @@ -292,7 +291,6 @@ regulator-boot-on; regulator-min-microvolt = <900000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>;
regulator-state-mem { diff --git a/arch/arm/dts/rk3566-radxa-cm3-io.dts b/arch/arm/dts/rk3566-radxa-cm3-io.dts index 5e4236af4fcb..1b1c67d5b1ef 100644 --- a/arch/arm/dts/rk3566-radxa-cm3-io.dts +++ b/arch/arm/dts/rk3566-radxa-cm3-io.dts @@ -137,8 +137,8 @@
&mdio1 { rgmii_phy1: ethernet-phy@0 { - compatible="ethernet-phy-ieee802.3-c22"; - reg= <0x0>; + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0x0>; }; };
diff --git a/arch/arm/dts/rk3566-soquartz.dtsi b/arch/arm/dts/rk3566-soquartz.dtsi index 31aa2b8efe39..63bae36b8f7e 100644 --- a/arch/arm/dts/rk3566-soquartz.dtsi +++ b/arch/arm/dts/rk3566-soquartz.dtsi @@ -234,7 +234,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>; regulator-state-mem { @@ -249,7 +248,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>; regulator-state-mem { @@ -272,7 +270,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-name = "vdd_npu"; regulator-state-mem { diff --git a/arch/arm/dts/rk3568-evb.dts b/arch/arm/dts/rk3568-evb.dts index 674792567fa6..19f8fc369b13 100644 --- a/arch/arm/dts/rk3568-evb.dts +++ b/arch/arm/dts/rk3568-evb.dts @@ -293,7 +293,6 @@ regulator-name = "vdd_logic"; regulator-always-on; regulator-boot-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -307,7 +306,6 @@ vdd_gpu: DCDC_REG2 { regulator-name = "vdd_gpu"; regulator-always-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -331,7 +329,6 @@
vdd_npu: DCDC_REG4 { regulator-name = "vdd_npu"; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; diff --git a/arch/arm/dts/rk3568-lubancat-2.dts b/arch/arm/dts/rk3568-lubancat-2.dts index e653b067aa5d..a8a4cc190eb3 100644 --- a/arch/arm/dts/rk3568-lubancat-2.dts +++ b/arch/arm/dts/rk3568-lubancat-2.dts @@ -243,7 +243,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>;
@@ -258,7 +257,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>;
@@ -284,7 +282,6 @@ regulator-boot-on; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; - regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-initial-mode = <0x2>;
diff --git a/arch/arm/dts/rk3568-nanopi-r5s.dtsi b/arch/arm/dts/rk3568-nanopi-r5s.dtsi index 58ba328ea782..93189f830640 100644 --- a/arch/arm/dts/rk3568-nanopi-r5s.dtsi +++ b/arch/arm/dts/rk3568-nanopi-r5s.dtsi @@ -232,7 +232,6 @@ regulator-name = "vdd_logic"; regulator-always-on; regulator-boot-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -246,7 +245,6 @@ vdd_gpu: DCDC_REG2 { regulator-name = "vdd_gpu"; regulator-always-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -270,7 +268,6 @@
vdd_npu: DCDC_REG4 { regulator-name = "vdd_npu"; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; diff --git a/arch/arm/dts/rk3568-odroid-m1.dts b/arch/arm/dts/rk3568-odroid-m1.dts index 59ecf868dbd0..a337f547caf5 100644 --- a/arch/arm/dts/rk3568-odroid-m1.dts +++ b/arch/arm/dts/rk3568-odroid-m1.dts @@ -291,7 +291,6 @@ regulator-name = "vdd_logic"; regulator-always-on; regulator-boot-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -305,7 +304,6 @@ vdd_gpu: DCDC_REG2 { regulator-name = "vdd_gpu"; regulator-always-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -329,7 +327,6 @@
vdd_npu: DCDC_REG4 { regulator-name = "vdd_npu"; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; diff --git a/arch/arm/dts/rk3568-radxa-cm3i.dtsi b/arch/arm/dts/rk3568-radxa-cm3i.dtsi index c50fbdd48680..45b03dcbbad4 100644 --- a/arch/arm/dts/rk3568-radxa-cm3i.dtsi +++ b/arch/arm/dts/rk3568-radxa-cm3i.dtsi @@ -163,7 +163,6 @@ regulator-name = "vdd_logic"; regulator-always-on; regulator-boot-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -177,7 +176,6 @@ vdd_gpu: DCDC_REG2 { regulator-name = "vdd_gpu"; regulator-always-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -201,7 +199,6 @@
vdd_npu: DCDC_REG4 { regulator-name = "vdd_npu"; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; diff --git a/arch/arm/dts/rk3568-rock-3a.dts b/arch/arm/dts/rk3568-rock-3a.dts index 917f5b2b8aab..a5e974ea659e 100644 --- a/arch/arm/dts/rk3568-rock-3a.dts +++ b/arch/arm/dts/rk3568-rock-3a.dts @@ -15,6 +15,7 @@ ethernet0 = &gmac1; mmc0 = &sdhci; mmc1 = &sdmmc0; + mmc2 = &sdmmc2; };
chosen: chosen { @@ -350,7 +351,6 @@ regulator-name = "vdd_logic"; regulator-always-on; regulator-boot-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -364,7 +364,6 @@ vdd_gpu: DCDC_REG2 { regulator-name = "vdd_gpu"; regulator-always-on; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -388,7 +387,6 @@
vdd_npu: DCDC_REG4 { regulator-name = "vdd_npu"; - regulator-init-microvolt = <900000>; regulator-initial-mode = <0x2>; regulator-min-microvolt = <500000>; regulator-max-microvolt = <1350000>; @@ -750,6 +748,9 @@ non-removable; pinctrl-names = "default"; pinctrl-0 = <&sdmmc2m0_bus4 &sdmmc2m0_cmd &sdmmc2m0_clk>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; sd-uhs-sdr104; vmmc-supply = <&vcc3v3_sys>; vqmmc-supply = <&vcc_1v8>; diff --git a/arch/arm/dts/rk356x.dtsi b/arch/arm/dts/rk356x.dtsi index 61680c7ac489..c19c0f1b3778 100644 --- a/arch/arm/dts/rk356x.dtsi +++ b/arch/arm/dts/rk356x.dtsi @@ -613,6 +613,17 @@ #iommu-cells = <0>; };
+ rga: rga@fdeb0000 { + compatible = "rockchip,rk3568-rga", "rockchip,rk3288-rga"; + reg = <0x0 0xfdeb0000 0x0 0x180>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru CLK_RGA_CORE>; + clock-names = "aclk", "hclk", "sclk"; + resets = <&cru SRST_RGA_CORE>, <&cru SRST_A_RGA>, <&cru SRST_H_RGA>; + reset-names = "core", "axi", "ahb"; + power-domains = <&power RK3568_PD_RGA>; + }; + vepu: video-codec@fdee0000 { compatible = "rockchip,rk3568-vepu"; reg = <0x0 0xfdee0000 0x0 0x800>; @@ -948,6 +959,13 @@ reg = <0x0 0xfe1a8100 0x0 0x20>; };
+ dfi: dfi@fe230000 { + compatible = "rockchip,rk3568-dfi"; + reg = <0x00 0xfe230000 0x00 0x400>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + rockchip,pmu = <&pmugrf>; + }; + pcie2x1: pcie@fe260000 { compatible = "rockchip,rk3568-pcie"; reg = <0x3 0xc0000000 0x0 0x00400000>, @@ -959,7 +977,7 @@ <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "sys", "pmc", "msi", "legacy", "err"; + interrupt-names = "sys", "pmc", "msg", "legacy", "err"; bus-range = <0x0 0xf>; clocks = <&cru ACLK_PCIE20_MST>, <&cru ACLK_PCIE20_SLV>, <&cru ACLK_PCIE20_DBI>, <&cru PCLK_PCIE20>, diff --git a/include/dt-bindings/clock/rk3568-cru.h b/include/dt-bindings/clock/rk3568-cru.h index c1942422a438..d29890865150 100644 --- a/include/dt-bindings/clock/rk3568-cru.h +++ b/include/dt-bindings/clock/rk3568-cru.h @@ -478,6 +478,7 @@ #define CPLL_50M 415 #define CPLL_25M 416 #define CPLL_100M 417 +#define SCLK_DDRCLK 418
#define PCLK_CORE_PVTM 450
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- leds: gpio-leds {
leds: pwm-leds {
}; };pwms = <&pwm0 0 25000 0>;
regulator-name = "vdd_cpu"; regulator-ramp-delay = <2300>; vin-supply = <&vcc_sys>;regulator-init-microvolt = <900000>;
- gpio-led {
rockchip,pins =
+&pwm0 {
- pinctrl-0 = <&pwm0m1_pins>;
- status = "okay";
- &pwm5 { status = "okay"; };
+&pwm6 {
- status = "okay";
+&pwm7 {
- status = "okay";
- &saradc { vref-supply = <&vcc_1v8>; status = "okay";
regulator-init-microvolt = <900000>; regulator-ramp-delay = <6001>; regulator-state-mem {
reg= <0x0>;
}; };reg = <0x0>;
@@ -331,7 +329,6 @@
@@ -270,7 +268,6 @@
@@ -329,7 +327,6 @@
@@ -201,7 +199,6 @@
mmc2 = &sdmmc2;
chosen: chosen {
@@ -388,7 +387,6 @@
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50; sd-uhs-sdr104; vmmc-supply = <&vcc3v3_sys>; vqmmc-supply = <&vcc_1v8>;
- rga: rga@fdeb0000 {
- vepu: video-codec@fdee0000 { compatible = "rockchip,rk3568-vepu"; reg = <0x0 0xfdee0000 0x0 0x800>;
- dfi: dfi@fe230000 {
- pcie2x1: pcie@fe260000 { compatible = "rockchip,rk3568-pcie"; reg = <0x3 0xc0000000 0x0 0x00400000>,
bus-range = <0x0 0xf>; clocks = <&cru ACLK_PCIE20_MST>, <&cru ACLK_PCIE20_SLV>, <&cru ACLK_PCIE20_DBI>, <&cru PCLK_PCIE20>,interrupt-names = "sys", "pmc", "msg", "legacy", "err";
Sync rk356x device tree from linux v6.8-rc1.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3566-quartz64-a.dts | 5 +++-- arch/arm/dts/rk3566-radxa-cm3-io.dts | 1 + arch/arm/dts/rk3566-soquartz-blade.dts | 4 ++++ arch/arm/dts/rk3566-soquartz-cm4.dts | 4 ++++ arch/arm/dts/rk3566-soquartz-model-a.dts | 4 ++++ arch/arm/dts/rk3566-soquartz.dtsi | 1 - 6 files changed, 16 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/rk3566-quartz64-a.dts b/arch/arm/dts/rk3566-quartz64-a.dts index 854d02b46e6f..59843a7a199c 100644 --- a/arch/arm/dts/rk3566-quartz64-a.dts +++ b/arch/arm/dts/rk3566-quartz64-a.dts @@ -31,8 +31,9 @@ fan: gpio_fan { compatible = "gpio-fan"; gpios = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>; - gpio-fan,speed-map = <0 0 - 4500 1>; + gpio-fan,speed-map = + < 0 0>, + <4500 1>; pinctrl-names = "default"; pinctrl-0 = <&fan_en_h>; #cooling-cells = <2>; diff --git a/arch/arm/dts/rk3566-radxa-cm3-io.dts b/arch/arm/dts/rk3566-radxa-cm3-io.dts index 1b1c67d5b1ef..3ae24e39450a 100644 --- a/arch/arm/dts/rk3566-radxa-cm3-io.dts +++ b/arch/arm/dts/rk3566-radxa-cm3-io.dts @@ -14,6 +14,7 @@ compatible = "radxa,cm3-io", "radxa,cm3", "rockchip,rk3566";
aliases { + ethernet0 = &gmac1; mmc1 = &sdmmc0; };
diff --git a/arch/arm/dts/rk3566-soquartz-blade.dts b/arch/arm/dts/rk3566-soquartz-blade.dts index 4e49bebf548b..fdbf1c783242 100644 --- a/arch/arm/dts/rk3566-soquartz-blade.dts +++ b/arch/arm/dts/rk3566-soquartz-blade.dts @@ -13,6 +13,10 @@ model = "PINE64 RK3566 SOQuartz on Blade carrier board"; compatible = "pine64,soquartz-blade", "pine64,soquartz", "rockchip,rk3566";
+ aliases { + ethernet0 = &gmac1; + }; + /* labeled VCC3V0_SD in schematic to not conflict with PMIC regulator */ vcc3v0_sd: vcc3v0-sd-regulator { compatible = "regulator-fixed"; diff --git a/arch/arm/dts/rk3566-soquartz-cm4.dts b/arch/arm/dts/rk3566-soquartz-cm4.dts index cddf6cd2fecb..6ed3fa4aee34 100644 --- a/arch/arm/dts/rk3566-soquartz-cm4.dts +++ b/arch/arm/dts/rk3566-soquartz-cm4.dts @@ -8,6 +8,10 @@ model = "Pine64 RK3566 SoQuartz with CM4-IO Carrier Board"; compatible = "pine64,soquartz-cm4io", "pine64,soquartz", "rockchip,rk3566";
+ aliases { + ethernet0 = &gmac1; + }; + /* labeled +12v in schematic */ vcc12v_dcin: vcc12v-dcin-regulator { compatible = "regulator-fixed"; diff --git a/arch/arm/dts/rk3566-soquartz-model-a.dts b/arch/arm/dts/rk3566-soquartz-model-a.dts index 2208dbfb7f0a..f2095dfa4eaf 100644 --- a/arch/arm/dts/rk3566-soquartz-model-a.dts +++ b/arch/arm/dts/rk3566-soquartz-model-a.dts @@ -8,6 +8,10 @@ model = "PINE64 RK3566 SOQuartz on Model A carrier board"; compatible = "pine64,soquartz-model-a", "pine64,soquartz", "rockchip,rk3566";
+ aliases { + ethernet0 = &gmac1; + }; + /* labeled DCIN_12V in schematic */ vcc12v_dcin: vcc12v-dcin-regulator { compatible = "regulator-fixed"; diff --git a/arch/arm/dts/rk3566-soquartz.dtsi b/arch/arm/dts/rk3566-soquartz.dtsi index 63bae36b8f7e..bfb7b952f4c5 100644 --- a/arch/arm/dts/rk3566-soquartz.dtsi +++ b/arch/arm/dts/rk3566-soquartz.dtsi @@ -12,7 +12,6 @@ compatible = "pine64,soquartz", "rockchip,rk3566";
aliases { - ethernet0 = &gmac1; mmc0 = &sdmmc0; mmc1 = &sdhci; mmc2 = &sdmmc1;
Thanks, - Kever
4500 1>;
< 0 0>,
pinctrl-names = "default"; pinctrl-0 = <&fan_en_h>; #cooling-cells = <2>;<4500 1>;
aliases {
mmc1 = &sdmmc0; };ethernet0 = &gmac1;
- aliases {
ethernet0 = &gmac1;
- /* labeled VCC3V0_SD in schematic to not conflict with PMIC regulator */ vcc3v0_sd: vcc3v0-sd-regulator { compatible = "regulator-fixed";
- aliases {
ethernet0 = &gmac1;
- /* labeled +12v in schematic */ vcc12v_dcin: vcc12v-dcin-regulator { compatible = "regulator-fixed";
- aliases {
ethernet0 = &gmac1;
- /* labeled DCIN_12V in schematic */ vcc12v_dcin: vcc12v-dcin-regulator { compatible = "regulator-fixed";
aliases {
mmc0 = &sdmmc0; mmc1 = &sdhci; mmc2 = &sdmmc1;ethernet0 = &gmac1;
Move uart2 bootph-pre-ram and clock-frequency props from board to SoC u-boot.dtsi. Regular board device tree already enables the uart2 node, so status prop is dropped from u-boot.dtsi file.
Also remove unnecessary stdout-path = &uart2, regular board device tree already provide a stdout-path = "serial2:" value.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi | 7 ------- arch/arm/dts/rk3566-quartz64-a-u-boot.dtsi | 12 ------------ arch/arm/dts/rk3566-quartz64-b-u-boot.dtsi | 12 ------------ arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi | 12 ------------ arch/arm/dts/rk3566-soquartz-u-boot.dtsi | 12 ------------ arch/arm/dts/rk3568-bpi-r2-pro-u-boot.dtsi | 13 ------------- arch/arm/dts/rk3568-evb-u-boot.dtsi | 17 ----------------- arch/arm/dts/rk3568-generic-u-boot.dtsi | 11 ----------- arch/arm/dts/rk3568-lubancat-2-u-boot.dtsi | 12 ------------ arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi | 12 ------------ arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi | 12 ------------ arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi | 12 ------------ arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 12 ------------ arch/arm/dts/rk356x-u-boot.dtsi | 5 +++++ 14 files changed, 5 insertions(+), 156 deletions(-)
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi index f986e1941e7f..fa3df73c33db 100644 --- a/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi +++ b/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi @@ -4,7 +4,6 @@
/ { chosen { - stdout-path = &uart2; u-boot,spl-boot-order = "same-as-spl", &sdmmc1, &sdmmc0; };
@@ -88,9 +87,3 @@ vqmmc-supply = <&vcc_1v8>; status = "okay"; }; - -&uart2 { - clock-frequency = <24000000>; - bootph-all; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3566-quartz64-a-u-boot.dtsi b/arch/arm/dts/rk3566-quartz64-a-u-boot.dtsi index 06cc15ed21b8..11976fd3a6e0 100644 --- a/arch/arm/dts/rk3566-quartz64-a-u-boot.dtsi +++ b/arch/arm/dts/rk3566-quartz64-a-u-boot.dtsi @@ -2,12 +2,6 @@
#include "rk356x-u-boot.dtsi"
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &gpio0 { bootph-all; }; @@ -28,12 +22,6 @@ }; };
-&uart2 { - bootph-all; - clock-frequency = <24000000>; - status = "okay"; -}; - /* * U-Boot does not support multiple regulators using the same gpio, * use vcc5v0_usb20_host to fix use of USB 2.0 port diff --git a/arch/arm/dts/rk3566-quartz64-b-u-boot.dtsi b/arch/arm/dts/rk3566-quartz64-b-u-boot.dtsi index 3c2c54e94183..8de9d1535efb 100644 --- a/arch/arm/dts/rk3566-quartz64-b-u-boot.dtsi +++ b/arch/arm/dts/rk3566-quartz64-b-u-boot.dtsi @@ -2,12 +2,6 @@
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v; @@ -24,12 +18,6 @@ }; };
-&uart2 { - bootph-all; - clock-frequency = <24000000>; - status = "okay"; -}; - &usb_host0_xhci { dr_mode = "host"; }; diff --git a/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi b/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi index c925439f71cd..158f652cb3b1 100644 --- a/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi +++ b/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi @@ -5,19 +5,7 @@
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v; }; - -&uart2 { - clock-frequency = <24000000>; - bootph-all; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3566-soquartz-u-boot.dtsi b/arch/arm/dts/rk3566-soquartz-u-boot.dtsi index 793cca2ceaca..f65f4067f3e9 100644 --- a/arch/arm/dts/rk3566-soquartz-u-boot.dtsi +++ b/arch/arm/dts/rk3566-soquartz-u-boot.dtsi @@ -2,12 +2,6 @@
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v; @@ -15,12 +9,6 @@ pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; };
-&uart2 { - bootph-all; - clock-frequency = <24000000>; - status = "okay"; -}; - &usb_host0_xhci { dr_mode = "host"; }; diff --git a/arch/arm/dts/rk3568-bpi-r2-pro-u-boot.dtsi b/arch/arm/dts/rk3568-bpi-r2-pro-u-boot.dtsi index 60a3b21f2d45..5f4f14b3bdae 100644 --- a/arch/arm/dts/rk3568-bpi-r2-pro-u-boot.dtsi +++ b/arch/arm/dts/rk3568-bpi-r2-pro-u-boot.dtsi @@ -4,16 +4,3 @@ */
#include "rk356x-u-boot.dtsi" - -/ { - chosen { - stdout-path = &uart2; - }; -}; - -&uart2 { - clock-frequency = <24000000>; - bootph-pre-ram; - status = "okay"; -}; - diff --git a/arch/arm/dts/rk3568-evb-u-boot.dtsi b/arch/arm/dts/rk3568-evb-u-boot.dtsi index 382a52a28b10..5f4f14b3bdae 100644 --- a/arch/arm/dts/rk3568-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3568-evb-u-boot.dtsi @@ -4,20 +4,3 @@ */
#include "rk356x-u-boot.dtsi" - -/ { - chosen { - stdout-path = &uart2; - u-boot,spl-boot-order = "same-as-spl", &sdmmc0, &sdhci; - }; -}; - -&sdmmc0 { - status = "okay"; -}; - -&uart2 { - clock-frequency = <24000000>; - bootph-pre-ram; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3568-generic-u-boot.dtsi b/arch/arm/dts/rk3568-generic-u-boot.dtsi index 90022580a13b..6e8307e3bdf6 100644 --- a/arch/arm/dts/rk3568-generic-u-boot.dtsi +++ b/arch/arm/dts/rk3568-generic-u-boot.dtsi @@ -1,14 +1,3 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT)
#include "rk356x-u-boot.dtsi" - -/ { - chosen { - stdout-path = &uart2; - }; -}; - -&uart2 { - bootph-pre-ram; - clock-frequency = <24000000>; -}; diff --git a/arch/arm/dts/rk3568-lubancat-2-u-boot.dtsi b/arch/arm/dts/rk3568-lubancat-2-u-boot.dtsi index 27c627752333..a44ac35bdacd 100644 --- a/arch/arm/dts/rk3568-lubancat-2-u-boot.dtsi +++ b/arch/arm/dts/rk3568-lubancat-2-u-boot.dtsi @@ -6,12 +6,6 @@
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v; @@ -19,9 +13,3 @@ mmc-hs400-enhanced-strobe; pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; }; - -&uart2 { - bootph-all; - clock-frequency = <24000000>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi b/arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi index 880f8ff91fcb..62f572c4cf9f 100644 --- a/arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi +++ b/arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi @@ -8,12 +8,6 @@
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &pcie3x1 { /delete-property/ vpcie3v3-supply; }; @@ -27,12 +21,6 @@ pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; };
-&uart2 { - clock-frequency = <24000000>; - bootph-all; - status = "okay"; -}; - &vcc5v0_usb_host { /delete-property/ regulator-always-on; /delete-property/ regulator-boot-on; diff --git a/arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi b/arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi index 0fc360b06df7..ecba91aa30f5 100644 --- a/arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi +++ b/arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi @@ -2,12 +2,6 @@
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &fspi_dual_io_pins { bootph-all; }; @@ -29,9 +23,3 @@ bootph-pre-ram; }; }; - -&uart2 { - bootph-all; - clock-frequency = <24000000>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi b/arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi index 1136f0bb3b81..caf524443079 100644 --- a/arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi +++ b/arch/arm/dts/rk3568-radxa-e25-u-boot.dtsi @@ -2,12 +2,6 @@
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &pcie3x1 { pinctrl-0 = <&pcie30x1_reset_h>; }; @@ -28,12 +22,6 @@ mmc-hs400-enhanced-strobe; };
-&uart2 { - bootph-all; - clock-frequency = <24000000>; - status = "okay"; -}; - &usb_host0_xhci { dr_mode = "host"; }; diff --git a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi index b05b7151e6c7..46ebb77283f1 100644 --- a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi +++ b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi @@ -6,12 +6,6 @@
-/ { - chosen { - stdout-path = &uart2; - }; -}; - &pcie3x2 { pinctrl-0 = <&pcie3x2_reset_h>; }; @@ -48,9 +42,3 @@ spi-tx-bus-width = <1>; }; }; - -&uart2 { - clock-frequency = <24000000>; - bootph-all; - status = "okay"; -}; diff --git a/arch/arm/dts/rk356x-u-boot.dtsi b/arch/arm/dts/rk356x-u-boot.dtsi index 354b6958e572..cacd45348a49 100644 --- a/arch/arm/dts/rk356x-u-boot.dtsi +++ b/arch/arm/dts/rk356x-u-boot.dtsi @@ -141,6 +141,11 @@ bootph-pre-ram; };
+&uart2 { + bootph-pre-ram; + clock-frequency = <24000000>; +}; + #ifdef CONFIG_ROCKCHIP_SPI_IMAGE &binman { simple-bin-spi {
Thanks, - Kever
/ { chosen {
u-boot,spl-boot-order = "same-as-spl", &sdmmc1, &sdmmc0; };stdout-path = &uart2;
-&uart2 {
- bootph-all;
- status = "okay";
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
- U-Boot does not support multiple regulators using the same gpio,
- use vcc5v0_usb20_host to fix use of USB 2.0 port
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
- chosen {
-&uart2 {
- bootph-pre-ram;
- status = "okay";
- chosen {
-&sdmmc0 {
- status = "okay";
-&uart2 {
- bootph-pre-ram;
- status = "okay";
- chosen {
-&uart2 {
- bootph-pre-ram;
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
- chosen {
-&uart2 {
- bootph-all;
- status = "okay";
+&uart2 {
- bootph-pre-ram;
- #ifdef CONFIG_ROCKCHIP_SPI_IMAGE &binman { simple-bin-spi {
Sync rk3588 device tree from linux v6.7.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3588-turing-rk1.dtsi | 4 +-- arch/arm/dts/rk3588-u-boot.dtsi | 2 +- arch/arm/dts/rk3588s-orangepi-5.dts | 2 +- arch/arm/dts/rk3588s-pinctrl.dtsi | 2 +- arch/arm/dts/rk3588s-u-boot.dtsi | 33 +++-------------- arch/arm/dts/rk3588s.dtsi | 36 +++++++++++++++++++ arch/arm/mach-rockchip/rk3588/syscon_rk3588.c | 2 +- 7 files changed, 47 insertions(+), 34 deletions(-)
diff --git a/arch/arm/dts/rk3588-turing-rk1.dtsi b/arch/arm/dts/rk3588-turing-rk1.dtsi index 9570b34aca2e..d88c0e852356 100644 --- a/arch/arm/dts/rk3588-turing-rk1.dtsi +++ b/arch/arm/dts/rk3588-turing-rk1.dtsi @@ -235,13 +235,13 @@ &pinctrl { fan { fan_int: fan-int { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; }; };
hym8563 { hym8563_int: hym8563-int { - rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
diff --git a/arch/arm/dts/rk3588-u-boot.dtsi b/arch/arm/dts/rk3588-u-boot.dtsi index 31046fc7febb..992f7b5d6637 100644 --- a/arch/arm/dts/rk3588-u-boot.dtsi +++ b/arch/arm/dts/rk3588-u-boot.dtsi @@ -7,7 +7,7 @@
/ { usb_host1_xhci: usb@fc400000 { - compatible = "rockchip,rk3588-dwc3", "rockchip,rk3568-dwc3", "snps,dwc3"; + compatible = "rockchip,rk3588-dwc3", "snps,dwc3"; reg = <0x0 0xfc400000 0x0 0x400000>; interrupts = <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru REF_CLK_USB3OTG1>, <&cru SUSPEND_CLK_USB3OTG1>, diff --git a/arch/arm/dts/rk3588s-orangepi-5.dts b/arch/arm/dts/rk3588s-orangepi-5.dts index 8f399c4317bd..e3a839a12dc6 100644 --- a/arch/arm/dts/rk3588s-orangepi-5.dts +++ b/arch/arm/dts/rk3588s-orangepi-5.dts @@ -38,7 +38,7 @@ leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 =<&leds_gpio>; + pinctrl-0 = <&leds_gpio>;
led-1 { gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; diff --git a/arch/arm/dts/rk3588s-pinctrl.dtsi b/arch/arm/dts/rk3588s-pinctrl.dtsi index 63151d9d2377..30db12c4fc82 100644 --- a/arch/arm/dts/rk3588s-pinctrl.dtsi +++ b/arch/arm/dts/rk3588s-pinctrl.dtsi @@ -369,7 +369,7 @@ emmc_data_strobe: emmc-data-strobe { rockchip,pins = /* emmc_data_strobe */ - <2 RK_PA2 1 &pcfg_pull_none>; + <2 RK_PA2 1 &pcfg_pull_down>; }; };
diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index c0fd16c4022b..ebee2131ceeb 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -22,7 +22,7 @@ };
usb_host0_xhci: usb@fc000000 { - compatible = "rockchip,rk3588-dwc3", "rockchip,rk3568-dwc3", "snps,dwc3"; + compatible = "rockchip,rk3588-dwc3", "snps,dwc3"; reg = <0x0 0xfc000000 0x0 0x400000>; interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru REF_CLK_USB3OTG0>, <&cru SUSPEND_CLK_USB3OTG0>, @@ -43,33 +43,6 @@ status = "disabled"; };
- usb_host2_xhci: usb@fcd00000 { - compatible = "rockchip,rk3588-dwc3", "rockchip,rk3568-dwc3", "snps,dwc3"; - reg = <0x0 0xfcd00000 0x0 0x400000>; - interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru REF_CLK_USB3OTG2>, <&cru SUSPEND_CLK_USB3OTG2>, - <&cru ACLK_USB3OTG2>, <&cru CLK_UTMI_OTG2>, - <&cru CLK_PIPEPHY2_PIPE_U3_G>; - clock-names = "ref_clk", "suspend_clk", "bus_clk", "utmi", "pipe"; - dr_mode = "host"; - phys = <&combphy2_psu PHY_TYPE_USB3>; - phy-names = "usb3-phy"; - phy_type = "utmi_wide"; - resets = <&cru SRST_A_USB3OTG2>; - snps,dis_enblslpm_quirk; - snps,dis-u2-freeclk-exists-quirk; - snps,dis-del-phy-power-chg-quirk; - snps,dis-tx-ipgap-linecheck-quirk; - snps,dis_rxdet_inp3_quirk; - status = "disabled"; - }; - - pmu1_grf: syscon@fd58a000 { - bootph-all; - compatible = "rockchip,rk3588-pmu1-grf", "syscon"; - reg = <0x0 0xfd58a000 0x0 0x2000>; - }; - usbdpphy0_grf: syscon@fd5c8000 { compatible = "rockchip,rk3588-usbdpphy-grf", "syscon"; reg = <0x0 0xfd5c8000 0x0 0x4000>; @@ -206,6 +179,10 @@ status = "okay"; };
+&pmu1grf { + bootph-all; +}; + &scmi { bootph-pre-ram; }; diff --git a/arch/arm/dts/rk3588s.dtsi b/arch/arm/dts/rk3588s.dtsi index 61a9a11c3bb0..8aa0499f9b03 100644 --- a/arch/arm/dts/rk3588s.dtsi +++ b/arch/arm/dts/rk3588s.dtsi @@ -443,6 +443,32 @@ status = "disabled"; };
+ usb_host2_xhci: usb@fcd00000 { + compatible = "rockchip,rk3588-dwc3", "snps,dwc3"; + reg = <0x0 0xfcd00000 0x0 0x400000>; + interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru REF_CLK_USB3OTG2>, <&cru SUSPEND_CLK_USB3OTG2>, + <&cru ACLK_USB3OTG2>, <&cru CLK_UTMI_OTG2>, + <&cru CLK_PIPEPHY2_PIPE_U3_G>; + clock-names = "ref_clk", "suspend_clk", "bus_clk", "utmi", "pipe"; + dr_mode = "host"; + phys = <&combphy2_psu PHY_TYPE_USB3>; + phy-names = "usb3-phy"; + phy_type = "utmi_wide"; + resets = <&cru SRST_A_USB3OTG2>; + snps,dis_enblslpm_quirk; + snps,dis-u2-freeclk-exists-quirk; + snps,dis-del-phy-power-chg-quirk; + snps,dis-tx-ipgap-linecheck-quirk; + snps,dis_rxdet_inp3_quirk; + status = "disabled"; + }; + + pmu1grf: syscon@fd58a000 { + compatible = "rockchip,rk3588-pmugrf", "syscon", "simple-mfd"; + reg = <0x0 0xfd58a000 0x0 0x10000>; + }; + sys_grf: syscon@fd58c000 { compatible = "rockchip,rk3588-sys-grf", "syscon"; reg = <0x0 0xfd58c000 0x0 0x1000>; @@ -1329,6 +1355,16 @@ }; };
+ dfi: dfi@fe060000 { + reg = <0x00 0xfe060000 0x00 0x10000>; + compatible = "rockchip,rk3588-dfi"; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH 0>; + rockchip,pmu = <&pmu1grf>; + }; + gmac1: ethernet@fe1c0000 { compatible = "rockchip,rk3588-gmac", "snps,dwmac-4.20a"; reg = <0x0 0xfe1c0000 0x0 0x10000>; diff --git a/arch/arm/mach-rockchip/rk3588/syscon_rk3588.c b/arch/arm/mach-rockchip/rk3588/syscon_rk3588.c index e8772d3a3824..7b2cf37d9da1 100644 --- a/arch/arm/mach-rockchip/rk3588/syscon_rk3588.c +++ b/arch/arm/mach-rockchip/rk3588/syscon_rk3588.c @@ -10,7 +10,7 @@
static const struct udevice_id rk3588_syscon_ids[] = { { .compatible = "rockchip,rk3588-sys-grf", .data = ROCKCHIP_SYSCON_GRF }, - { .compatible = "rockchip,rk3588-pmu1-grf", .data = ROCKCHIP_SYSCON_PMUGRF }, + { .compatible = "rockchip,rk3588-pmugrf", .data = ROCKCHIP_SYSCON_PMUGRF }, { .compatible = "rockchip,rk3588-vop-grf", .data = ROCKCHIP_SYSCON_VOP_GRF }, { .compatible = "rockchip,rk3588-vo-grf", .data = ROCKCHIP_SYSCON_VO_GRF }, { .compatible = "rockchip,pcie30-phy-grf", .data = ROCKCHIP_SYSCON_PCIE30_PHY_GRF },
Sync rk3588 device tree from linux v6.8-rc1.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3588-edgeble-neu6a-io.dts | 4 - arch/arm/dts/rk3588-edgeble-neu6b-io.dts | 6 +- arch/arm/dts/rk3588-evb1-v10.dts | 99 ++++++++++++++++++- arch/arm/dts/rk3588-nanopc-t6.dts | 10 +- arch/arm/dts/rk3588-orangepi-5-plus.dts | 1 - arch/arm/dts/rk3588-quartzpro64.dts | 2 +- arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 8 -- arch/arm/dts/rk3588-rock-5b.dts | 13 ++- arch/arm/dts/rk3588-turing-rk1.dtsi | 2 - arch/arm/dts/rk3588s-orangepi-5.dts | 7 +- arch/arm/dts/rk3588s-rock-5a.dts | 10 +- arch/arm/dts/rk3588s-u-boot.dtsi | 5 - arch/arm/dts/rk3588s.dtsi | 116 +++++++++++++++++++++++ include/dt-bindings/soc/rockchip,vop2.h | 4 + 14 files changed, 251 insertions(+), 36 deletions(-)
diff --git a/arch/arm/dts/rk3588-edgeble-neu6a-io.dts b/arch/arm/dts/rk3588-edgeble-neu6a-io.dts index b51543892078..be6a4f4f90f6 100644 --- a/arch/arm/dts/rk3588-edgeble-neu6a-io.dts +++ b/arch/arm/dts/rk3588-edgeble-neu6a-io.dts @@ -12,10 +12,6 @@ compatible = "edgeble,neural-compute-module-6a-io", "edgeble,neural-compute-module-6a", "rockchip,rk3588";
- aliases { - serial2 = &uart2; - }; - chosen { stdout-path = "serial2:1500000n8"; }; diff --git a/arch/arm/dts/rk3588-edgeble-neu6b-io.dts b/arch/arm/dts/rk3588-edgeble-neu6b-io.dts index 9933765e4097..070baeb63431 100644 --- a/arch/arm/dts/rk3588-edgeble-neu6b-io.dts +++ b/arch/arm/dts/rk3588-edgeble-neu6b-io.dts @@ -9,13 +9,9 @@
/ { model = "Edgeble Neu6B IO Board"; - compatible = "edgeble,neural-compute-module-6b-io", + compatible = "edgeble,neural-compute-module-6a-io", "edgeble,neural-compute-module-6b", "rockchip,rk3588";
- aliases { - serial2 = &uart2; - }; - chosen { stdout-path = "serial2:1500000n8"; }; diff --git a/arch/arm/dts/rk3588-evb1-v10.dts b/arch/arm/dts/rk3588-evb1-v10.dts index b9d789d57862..ac7c677b0fb9 100644 --- a/arch/arm/dts/rk3588-evb1-v10.dts +++ b/arch/arm/dts/rk3588-evb1-v10.dts @@ -16,8 +16,8 @@ compatible = "rockchip,rk3588-evb1-v10", "rockchip,rk3588";
aliases { + ethernet0 = &gmac0; mmc0 = &sdhci; - serial2 = &uart2; };
chosen { @@ -56,6 +56,63 @@ }; };
+ analog-sound { + compatible = "simple-audio-card"; + pinctrl-names = "default"; + pinctrl-0 = <&hp_detect>; + simple-audio-card,name = "RK3588 EVB1 Audio"; + simple-audio-card,aux-devs = <&_headphone>, <&_speaker>; + simple-audio-card,bitclock-master = <&masterdai>; + simple-audio-card,format = "i2s"; + simple-audio-card,frame-master = <&masterdai>; + simple-audio-card,hp-det-gpio = <&gpio1 RK_PD5 GPIO_ACTIVE_LOW>; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,pin-switches = "Headphones", "Speaker"; + simple-audio-card,routing = + "Speaker Amplifier INL", "LOUT2", + "Speaker Amplifier INR", "ROUT2", + "Speaker", "Speaker Amplifier OUTL", + "Speaker", "Speaker Amplifier OUTR", + "Headphones Amplifier INL", "LOUT1", + "Headphones Amplifier INR", "ROUT1", + "Headphones", "Headphones Amplifier OUTL", + "Headphones", "Headphones Amplifier OUTR", + "LINPUT1", "Onboard Microphone", + "RINPUT1", "Onboard Microphone", + "LINPUT2", "Microphone Jack", + "RINPUT2", "Microphone Jack"; + simple-audio-card,widgets = + "Microphone", "Microphone Jack", + "Microphone", "Onboard Microphone", + "Headphone", "Headphones", + "Speaker", "Speaker"; + + simple-audio-card,cpu { + sound-dai = <&i2s0_8ch>; + }; + + masterdai: simple-audio-card,codec { + sound-dai = <&es8388>; + system-clock-frequency = <12288000>; + }; + }; + + amp_headphone: headphone-amplifier { + compatible = "simple-audio-amplifier"; + enable-gpios = <&gpio1 RK_PD2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&headphone_amplifier_en>; + sound-name-prefix = "Headphones Amplifier"; + }; + + amp_speaker: speaker-amplifier { + compatible = "simple-audio-amplifier"; + enable-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&speaker_amplifier_en>; + sound-name-prefix = "Speaker Amplifier"; + }; + backlight: backlight { compatible = "pwm-backlight"; power-supply = <&vcc12v_dcin>; @@ -240,6 +297,32 @@ }; };
+&i2c7 { + status = "okay"; + + es8388: audio-codec@11 { + compatible = "everest,es8388"; + reg = <0x11>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clock-rates = <12288000>; + AVDD-supply = <&avcc_1v8_codec_s0>; + DVDD-supply = <&avcc_1v8_codec_s0>; + HPVDD-supply = <&vcc_3v3_s0>; + PVDD-supply = <&vcc_3v3_s0>; + #sound-dai-cells = <0>; + }; +}; + +&i2s0_8ch { + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; +}; + &mdio0 { rgmii_phy: ethernet-phy@1 { /* RTL8211F */ @@ -273,6 +356,20 @@ };
&pinctrl { + audio { + hp_detect: headphone-detect { + rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + headphone_amplifier_en: headphone-amplifier-en { + rockchip,pins = <1 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + speaker_amplifier_en: speaker-amplifier-en { + rockchip,pins = <1 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + rtl8111 { rtl8111_isolate: rtl8111-isolate { rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; diff --git a/arch/arm/dts/rk3588-nanopc-t6.dts b/arch/arm/dts/rk3588-nanopc-t6.dts index 97af4f912828..d7722772ecd8 100644 --- a/arch/arm/dts/rk3588-nanopc-t6.dts +++ b/arch/arm/dts/rk3588-nanopc-t6.dts @@ -19,7 +19,6 @@ aliases { mmc0 = &sdhci; mmc1 = &sdmmc; - serial2 = &uart2; };
chosen { @@ -537,13 +536,12 @@ };
&sdmmc { - max-frequency = <200000000>; - no-sdio; - no-mmc; bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; disable-wp; + no-mmc; + no-sdio; sd-uhs-sdr104; vmmc-supply = <&vcc_3v3_s3>; vqmmc-supply = <&vccio_sd_s0>; @@ -570,6 +568,8 @@ pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, <&rk806_dvs2_null>, <&rk806_dvs3_null>;
+ system-power-controller; + vcc1-supply = <&vcc4v0_sys>; vcc2-supply = <&vcc4v0_sys>; vcc3-supply = <&vcc4v0_sys>; @@ -590,7 +590,7 @@ #gpio-cells = <2>;
rk806_dvs1_null: dvs1-null-pins { - pins = "gpio_pwrctrl2"; + pins = "gpio_pwrctrl1"; function = "pin_fun0"; };
diff --git a/arch/arm/dts/rk3588-orangepi-5-plus.dts b/arch/arm/dts/rk3588-orangepi-5-plus.dts index 298c183d6f4f..3e660ff6cd5f 100644 --- a/arch/arm/dts/rk3588-orangepi-5-plus.dts +++ b/arch/arm/dts/rk3588-orangepi-5-plus.dts @@ -19,7 +19,6 @@ aliases { mmc0 = &sdhci; mmc1 = &sdmmc; - serial2 = &uart2; };
chosen { diff --git a/arch/arm/dts/rk3588-quartzpro64.dts b/arch/arm/dts/rk3588-quartzpro64.dts index 5c59f9571dce..87a0abf95f7d 100644 --- a/arch/arm/dts/rk3588-quartzpro64.dts +++ b/arch/arm/dts/rk3588-quartzpro64.dts @@ -17,9 +17,9 @@ compatible = "pine64,quartzpro64", "rockchip,rk3588";
aliases { + ethernet0 = &gmac0; mmc0 = &sdhci; mmc1 = &sdmmc; - serial2 = &uart2; };
chosen { diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index b595ddef7028..5fa20cecc044 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -21,10 +21,6 @@ }; };
-&combphy2_psu { - status = "okay"; -}; - &fspim2_pins { bootph-all; }; @@ -129,10 +125,6 @@ status = "okay"; };
-&usb_host2_xhci { - status = "okay"; -}; - &i2c4 { pinctrl-names = "default"; pinctrl-0 = <&i2c4m1_xfer>; diff --git a/arch/arm/dts/rk3588-rock-5b.dts b/arch/arm/dts/rk3588-rock-5b.dts index 741f631db345..a0e303c3a1dc 100644 --- a/arch/arm/dts/rk3588-rock-5b.dts +++ b/arch/arm/dts/rk3588-rock-5b.dts @@ -14,7 +14,6 @@ mmc0 = &sdhci; mmc1 = &sdmmc; mmc2 = &sdio; - serial2 = &uart2; };
chosen { @@ -138,6 +137,10 @@ status = "okay"; };
+&combphy2_psu { + status = "okay"; +}; + &cpu_b0 { cpu-supply = <&vdd_cpu_big0_s0>; }; @@ -423,6 +426,8 @@ pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, <&rk806_dvs2_null>, <&rk806_dvs3_null>;
+ system-power-controller; + vcc1-supply = <&vcc5v0_sys>; vcc2-supply = <&vcc5v0_sys>; vcc3-supply = <&vcc5v0_sys>; @@ -443,7 +448,7 @@ #gpio-cells = <2>;
@@ -765,3 +770,7 @@ &usb_host1_ohci { status = "okay"; }; + +&usb_host2_xhci { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3588-turing-rk1.dtsi b/arch/arm/dts/rk3588-turing-rk1.dtsi index d88c0e852356..dc08da518a76 100644 --- a/arch/arm/dts/rk3588-turing-rk1.dtsi +++ b/arch/arm/dts/rk3588-turing-rk1.dtsi @@ -19,8 +19,6 @@ aliases { ethernet0 = &gmac1; mmc0 = &sdhci; - serial2 = &uart2; - serial9 = &uart9; };
fan: pwm-fan { diff --git a/arch/arm/dts/rk3588s-orangepi-5.dts b/arch/arm/dts/rk3588s-orangepi-5.dts index e3a839a12dc6..25de4362af38 100644 --- a/arch/arm/dts/rk3588s-orangepi-5.dts +++ b/arch/arm/dts/rk3588s-orangepi-5.dts @@ -13,8 +13,8 @@ compatible = "xunlong,orangepi-5", "rockchip,rk3588s";
aliases { + ethernet0 = &gmac1; mmc0 = &sdmmc; - serial2 = &uart2; };
chosen { @@ -314,6 +314,7 @@ pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, <&rk806_dvs2_null>, <&rk806_dvs3_null>; spi-max-frequency = <1000000>; + system-power-controller;
vcc1-supply = <&vcc5v0_sys>; vcc2-supply = <&vcc5v0_sys>; @@ -660,3 +661,7 @@ &usb_host1_ohci { status = "okay"; }; + +&usb_host2_xhci { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3588s-rock-5a.dts b/arch/arm/dts/rk3588s-rock-5a.dts index 8347adcbd003..2002fd0221fa 100644 --- a/arch/arm/dts/rk3588s-rock-5a.dts +++ b/arch/arm/dts/rk3588s-rock-5a.dts @@ -12,9 +12,9 @@ compatible = "radxa,rock-5a", "rockchip,rk3588s";
aliases { + ethernet0 = &gmac1; mmc0 = &sdhci; mmc1 = &sdmmc; - serial2 = &uart2; };
analog-sound { @@ -114,6 +114,10 @@ }; };
+&combphy2_psu { + status = "okay"; +}; + &cpu_b0 { cpu-supply = <&vdd_cpu_big0_s0>; }; @@ -734,3 +738,7 @@ &usb_host1_ohci { status = "okay"; }; + +&usb_host2_xhci { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index ebee2131ceeb..d251a210b313 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -7,11 +7,6 @@
/ { aliases { - spi0 = &spi0; - spi1 = &spi1; - spi2 = &spi2; - spi3 = &spi3; - spi4 = &spi4; spi5 = &sfc; };
diff --git a/arch/arm/dts/rk3588s.dtsi b/arch/arm/dts/rk3588s.dtsi index 8aa0499f9b03..36b1b7acfe6a 100644 --- a/arch/arm/dts/rk3588s.dtsi +++ b/arch/arm/dts/rk3588s.dtsi @@ -18,6 +18,38 @@ #address-cells = <2>; #size-cells = <2>;
+ aliases { + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + gpio3 = &gpio3; + gpio4 = &gpio4; + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + i2c5 = &i2c5; + i2c6 = &i2c6; + i2c7 = &i2c7; + i2c8 = &i2c8; + serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + serial4 = &uart4; + serial5 = &uart5; + serial6 = &uart6; + serial7 = &uart7; + serial8 = &uart8; + serial9 = &uart9; + spi0 = &spi0; + spi1 = &spi1; + spi2 = &spi2; + spi3 = &spi3; + spi4 = &spi4; + }; + cpus { #address-cells = <1>; #size-cells = <0>; @@ -362,6 +394,11 @@ #clock-cells = <0>; };
+ display_subsystem: display-subsystem { + compatible = "rockchip,display-subsystem"; + ports = <&vop_out>; + }; + timer { compatible = "arm,armv8-timer"; interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_HIGH 0>, @@ -474,6 +511,16 @@ reg = <0x0 0xfd58c000 0x0 0x1000>; };
+ vop_grf: syscon@fd5a4000 { + compatible = "rockchip,rk3588-vop-grf", "syscon"; + reg = <0x0 0xfd5a4000 0x0 0x2000>; + }; + + vo1_grf: syscon@fd5a8000 { + compatible = "rockchip,rk3588-vo-grf", "syscon"; + reg = <0x0 0xfd5a8000 0x0 0x100>; + }; + php_grf: syscon@fd5b0000 { compatible = "rockchip,rk3588-php-grf", "syscon"; reg = <0x0 0xfd5b0000 0x0 0x1000>; @@ -593,6 +640,74 @@ status = "disabled"; };
+ vop: vop@fdd90000 { + compatible = "rockchip,rk3588-vop"; + reg = <0x0 0xfdd90000 0x0 0x4200>, <0x0 0xfdd95000 0x0 0x1000>; + reg-names = "vop", "gamma-lut"; + interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_VOP>, + <&cru HCLK_VOP>, + <&cru DCLK_VOP0>, + <&cru DCLK_VOP1>, + <&cru DCLK_VOP2>, + <&cru DCLK_VOP3>, + <&cru PCLK_VOP_ROOT>; + clock-names = "aclk", + "hclk", + "dclk_vp0", + "dclk_vp1", + "dclk_vp2", + "dclk_vp3", + "pclk_vop"; + iommus = <&vop_mmu>; + power-domains = <&power RK3588_PD_VOP>; + rockchip,grf = <&sys_grf>; + rockchip,vop-grf = <&vop_grf>; + rockchip,vo1-grf = <&vo1_grf>; + rockchip,pmu = <&pmu>; + status = "disabled"; + + vop_out: ports { + #address-cells = <1>; + #size-cells = <0>; + + vp0: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + }; + + vp1: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + }; + + vp2: port@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + }; + + vp3: port@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + }; + }; + }; + + vop_mmu: iommu@fdd97e00 { + compatible = "rockchip,rk3588-iommu", "rockchip,rk3568-iommu"; + reg = <0x0 0xfdd97e00 0x0 0x100>, <0x0 0xfdd97f00 0x0 0x100>; + interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + power-domains = <&power RK3588_PD_VOP>; + status = "disabled"; + }; + uart0: serial@fd890000 { compatible = "rockchip,rk3588-uart", "snps,dw-apb-uart"; reg = <0x0 0xfd890000 0x0 0x100>; @@ -916,6 +1031,7 @@ reg = <RK3588_PD_USB>; clocks = <&cru PCLK_PHP_ROOT>, <&cru ACLK_USB_ROOT>, + <&cru ACLK_USB>, <&cru HCLK_USB_ROOT>, <&cru HCLK_HOST0>, <&cru HCLK_HOST_ARB0>, diff --git a/include/dt-bindings/soc/rockchip,vop2.h b/include/dt-bindings/soc/rockchip,vop2.h index 6e66a802b96a..668f199df9f0 100644 --- a/include/dt-bindings/soc/rockchip,vop2.h +++ b/include/dt-bindings/soc/rockchip,vop2.h @@ -10,5 +10,9 @@ #define ROCKCHIP_VOP2_EP_LVDS0 5 #define ROCKCHIP_VOP2_EP_MIPI1 6 #define ROCKCHIP_VOP2_EP_LVDS1 7 +#define ROCKCHIP_VOP2_EP_HDMI1 8 +#define ROCKCHIP_VOP2_EP_EDP1 9 +#define ROCKCHIP_VOP2_EP_DP0 10 +#define ROCKCHIP_VOP2_EP_DP1 11
#endif /* __DT_BINDINGS_ROCKCHIP_VOP2_H */
Seems Quentin also sync rk3588 with v6.8-rc1 in his patch.
Hi Quentin,
Could you update your patchset base on this patch set ?
Thanks,
- Kever
- aliases {
serial2 = &uart2;
- compatible = "edgeble,neural-compute-module-6a-io", "edgeble,neural-compute-module-6b", "rockchip,rk3588";
- aliases {
serial2 = &uart2;
aliases {
mmc0 = &sdhci;ethernet0 = &gmac0;
serial2 = &uart2;
chosen {
- analog-sound {
- amp_headphone: headphone-amplifier {
- amp_speaker: speaker-amplifier {
- backlight: backlight { compatible = "pwm-backlight"; power-supply = <&vcc12v_dcin>;
+&i2c7 {
- status = "okay";
- es8388: audio-codec@11 {
reg = <0x11>;
+&i2s0_8ch {
- pinctrl-0 = <&i2s0_lrck
&i2s0_mclk
&i2s0_sclk
&i2s0_sdi0
&i2s0_sdo0>;
- status = "okay";
- &mdio0 { rgmii_phy: ethernet-phy@1 { /* RTL8211F */
&pinctrl {
- audio {
- rtl8111 { rtl8111_isolate: rtl8111-isolate { rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>;
serial2 = &uart2;
chosen {
&sdmmc {
- no-sdio;
- no-mmc;
- no-sdio; sd-uhs-sdr104; vmmc-supply = <&vcc_3v3_s3>; vqmmc-supply = <&vccio_sd_s0>;
- vcc1-supply = <&vcc4v0_sys>; vcc2-supply = <&vcc4v0_sys>; vcc3-supply = <&vcc4v0_sys>;
};pins = "gpio_pwrctrl1"; function = "pin_fun0";
serial2 = &uart2;
chosen {
aliases {
mmc0 = &sdhci; mmc1 = &sdmmc;ethernet0 = &gmac0;
serial2 = &uart2;
chosen {
-&combphy2_psu {
- status = "okay";
-&usb_host2_xhci {
- status = "okay";
serial2 = &uart2;
chosen {
+&combphy2_psu {
- status = "okay";
- &cpu_b0 { cpu-supply = <&vdd_cpu_big0_s0>; };
- vcc1-supply = <&vcc5v0_sys>; vcc2-supply = <&vcc5v0_sys>; vcc3-supply = <&vcc5v0_sys>;
+&usb_host2_xhci {
- status = "okay";
serial2 = &uart2;
serial9 = &uart9;
fan: pwm-fan {
aliases {
mmc0 = &sdmmc;ethernet0 = &gmac1;
serial2 = &uart2;
chosen {
+&usb_host2_xhci {
- status = "okay";
aliases {
mmc0 = &sdhci; mmc1 = &sdmmc;ethernet0 = &gmac1;
serial2 = &uart2;
analog-sound {
+&combphy2_psu {
- status = "okay";
+&usb_host2_xhci {
- status = "okay";
/ { aliases {
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
spi3 = &spi3;
spi5 = &sfc; };spi4 = &spi4;
- aliases {
gpio0 = &gpio0;
gpio1 = &gpio1;
gpio2 = &gpio2;
gpio3 = &gpio3;
gpio4 = &gpio4;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &i2c7;
i2c8 = &i2c8;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
serial5 = &uart5;
serial6 = &uart6;
serial7 = &uart7;
serial8 = &uart8;
serial9 = &uart9;
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
spi3 = &spi3;
spi4 = &spi4;
- cpus { #address-cells = <1>; #size-cells = <0>;
- display_subsystem: display-subsystem {
ports = <&vop_out>;
- timer { compatible = "arm,armv8-timer"; interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_HIGH 0>,
- vop_grf: syscon@fd5a4000 {
- vo1_grf: syscon@fd5a8000 {
- php_grf: syscon@fd5b0000 { compatible = "rockchip,rk3588-php-grf", "syscon"; reg = <0x0 0xfd5b0000 0x0 0x1000>;
- vop: vop@fdd90000 {
<&cru HCLK_VOP>,
<&cru DCLK_VOP0>,
<&cru DCLK_VOP1>,
<&cru DCLK_VOP2>,
<&cru DCLK_VOP3>,
"hclk",
"dclk_vp0",
"dclk_vp1",
"dclk_vp2",
"dclk_vp3",
"pclk_vop";
vop_out: ports {
#size-cells = <0>;
vp0: port@0 {
#size-cells = <0>;
reg = <0>;
vp1: port@1 {
#size-cells = <0>;
reg = <1>;
vp2: port@2 {
#size-cells = <0>;
reg = <2>;
vp3: port@3 {
#size-cells = <0>;
reg = <3>;
- vop_mmu: iommu@fdd97e00 {
#iommu-cells = <0>;
- uart0: serial@fd890000 { compatible = "rockchip,rk3588-uart", "snps,dw-apb-uart"; reg = <0x0 0xfd890000 0x0 0x100>;
Add a default u-boot,spl-boot-order prop to rk3588s-u-boot.dtsi and remove the prop from board u-boot.dtsi files using the default value.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi | 6 ------ arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi | 6 ------ arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi | 6 ------ arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 4 ---- arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi | 6 ------ arch/arm/dts/rk3588s-rock-5a-u-boot.dtsi | 6 ------ arch/arm/dts/rk3588s-u-boot.dtsi | 4 ++++ 7 files changed, 4 insertions(+), 34 deletions(-)
diff --git a/arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi b/arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi index 87831c9d432a..60494bb8485f 100644 --- a/arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi +++ b/arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi @@ -6,12 +6,6 @@
#include "rk3588-u-boot.dtsi"
-/ { - chosen { - u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; - }; -}; - &fspim1_pins { bootph-all; }; diff --git a/arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi b/arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi index b0f5c667197c..5d5fa6ffb214 100644 --- a/arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi +++ b/arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi @@ -2,12 +2,6 @@
-/ { - chosen { - u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; - }; -}; - &fspim1_pins { bootph-all; }; diff --git a/arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi b/arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi index 191ec988c459..7b937943a53c 100644 --- a/arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi +++ b/arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi @@ -4,9 +4,3 @@ */
#include "rk3588-u-boot.dtsi" - -/ { - chosen { - u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; - }; -}; diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index 5fa20cecc044..e99e60185ebe 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -7,10 +7,6 @@ #include <dt-bindings/usb/pd.h>
/ { - chosen { - u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; - }; - vcc12v_dcin: vcc12v-dcin-regulator { compatible = "regulator-fixed"; regulator-name = "vcc12v_dcin"; diff --git a/arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi b/arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi index 06c6f327c14b..e791b572b6bf 100644 --- a/arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi +++ b/arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi @@ -6,12 +6,6 @@
-/ { - chosen { - u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; - }; -}; - &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v; diff --git a/arch/arm/dts/rk3588s-rock-5a-u-boot.dtsi b/arch/arm/dts/rk3588s-rock-5a-u-boot.dtsi index 584476f77b13..9a6a353088df 100644 --- a/arch/arm/dts/rk3588s-rock-5a-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-rock-5a-u-boot.dtsi @@ -5,12 +5,6 @@
#include "rk3588s-u-boot.dtsi"
-/ { - chosen { - u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; - }; -}; - &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v; diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index d251a210b313..945b2d62a75e 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -10,6 +10,10 @@ spi5 = &sfc; };
+ chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; + }; + dmc { compatible = "rockchip,rk3588-dmc"; bootph-all;
Reviewed-by: Eugen Hristev eugen.hristev@collabora.com
- chosen {
- chosen {
- chosen {
- chosen {
- chosen {
- chosen {
- chosen {
- dmc { compatible = "rockchip,rk3588-dmc"; bootph-all;
Thanks, - Kever
- chosen {
- chosen {
- chosen {
- chosen {
- chosen {
- chosen {
- chosen {
Remove unnecessary status props from rk35xx u-boot.dtsi files, regular device tree files or default value already enable the affected nodes.
Also reorder bootph-pre-ram and clock-frequency props alphabetically in rk3588s-u-boot.dtsi uart2 node.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk356x-u-boot.dtsi | 7 ------- arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi | 1 - arch/arm/dts/rk3588s-u-boot.dtsi | 7 +------ 3 files changed, 1 insertion(+), 14 deletions(-)
diff --git a/arch/arm/dts/rk356x-u-boot.dtsi b/arch/arm/dts/rk356x-u-boot.dtsi index cacd45348a49..d347080577d9 100644 --- a/arch/arm/dts/rk356x-u-boot.dtsi +++ b/arch/arm/dts/rk356x-u-boot.dtsi @@ -19,7 +19,6 @@ dmc: dmc { compatible = "rockchip,rk3568-dmc"; bootph-all; - status = "okay"; };
otp: nvmem@fe38c000 { @@ -27,7 +26,6 @@ reg = <0x0 0xfe38c000 0x0 0x4000>; #address-cells = <1>; #size-cells = <1>; - status = "okay";
cpu_id: id@a { reg = <0x0a 0x10>; @@ -37,27 +35,22 @@
&xin24m { bootph-all; - status = "okay"; };
&cru { bootph-all; - status = "okay"; };
&pmucru { bootph-all; - status = "okay"; };
&grf { bootph-all; - status = "okay"; };
&pmugrf { bootph-all; - status = "okay"; };
&pinctrl { diff --git a/arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi b/arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi index e791b572b6bf..471508a9ed74 100644 --- a/arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi +++ b/arch/arm/dts/rk3588-turing-rk1-u-boot.dtsi @@ -15,5 +15,4 @@ &uart9 { bootph-pre-ram; clock-frequency = <24000000>; - status = "okay"; }; diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index 945b2d62a75e..bf3b1ea8a3c6 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -17,7 +17,6 @@ dmc { compatible = "rockchip,rk3588-dmc"; bootph-all; - status = "okay"; };
usb_host0_xhci: usb@fc000000 { @@ -165,17 +164,14 @@
&cru { bootph-pre-ram; - status = "okay"; };
&sys_grf { bootph-pre-ram; - status = "okay"; };
&pmu1grf { @@ -217,9 +213,8 @@ };
&uart2 { - clock-frequency = <24000000>; bootph-pre-ram; - status = "okay"; + clock-frequency = <24000000>; };
&uart2m0_xfer {
Thanks, - Kever
status = "okay";
status = "okay";
@@ -37,27 +35,22 @@
status = "okay"; };
&cru { bootph-all;
status = "okay"; };
status = "okay"; };
&grf { bootph-all;
status = "okay"; };
status = "okay"; };
&pinctrl {
status = "okay";
status = "okay"; };
status = "okay"; };
status = "okay"; };
&pmu1grf {
&uart2 {
- status = "okay";
&uart2m0_xfer {
Eugen Hristev
Jonas Karlman
Kever Yang
