[PATCH 00/11] 'eeprom' command improvements
Hi Tom,
this series contains improvements for the 'eeprom' command: - refactors - fixes - improvements - ability to use driver model EEPROMs (uclass UCLASS_I2C_EEPROM) - more flexible EEPROM layout support
It should not cause any behavior change for any existing board.
This series is a dependency for some DDR issue fixes for Turris Omnia. I will be sending that one separately.
github PR link (with CI): https://github.com/u-boot/u-boot/pull/540 - there is a failure for test.py for sandbox sandbox_clang but it seems unrelated to these changes
Marek Behún (11): common: eeprom_layout: Assign default layout methods and parameters before specific ones common: eeprom_layout: Split field finding code from the field update function common: eeprom_field: Fix updating binary field common: eeprom_field: Drop unnecessary comparison cmd: eeprom: Fix usage help for the eeprom command cmd: eeprom: Hide eeprom layout versioning behind a Kconfig option cmd: eeprom: Deduplicate parse_i2c_bus_addr() calls cmd: eeprom: Refactor eeprom device specifier parsing cmd: eeprom: Refactor command execution into function by action cmd: eeprom: Don't read/write whole EEPROM if not necessary cmd: eeprom: Extend to EEPROMs probed via driver model
cmd/Kconfig | 9 +- cmd/eeprom.c | 305 +++++++++++++++++++++++++--------- common/eeprom/eeprom_field.c | 4 +- common/eeprom/eeprom_layout.c | 54 +++--- configs/cm_fx6_defconfig | 1 + configs/cm_t43_defconfig | 1 + include/eeprom_layout.h | 4 + 7 files changed, 273 insertions(+), 105 deletions(-)
Assign the default eeprom layout parameter .data_size and methods .print() and .update() before calling eeprom_layout_assign() in eeprom_layout_setup().
This allows eeprom_layout_assign() to overwrite these if needed.
Signed-off-by: Marek Behún kabel@kernel.org --- common/eeprom/eeprom_layout.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/eeprom/eeprom_layout.c b/common/eeprom/eeprom_layout.c index 5a9be1da06..406db3f7d1 100644 --- a/common/eeprom/eeprom_layout.c +++ b/common/eeprom/eeprom_layout.c @@ -111,14 +111,14 @@ void eeprom_layout_setup(struct eeprom_layout *layout, unsigned char *buf, else layout->layout_version = layout_version;
+ layout->data_size = buf_size; + layout->print = eeprom_layout_print; + layout->update = eeprom_layout_update_field; + eeprom_layout_assign(layout, layout_version); layout->data = buf; for (i = 0; i < layout->num_of_fields; i++) { layout->fields[i].buf = buf; buf += layout->fields[i].size; } - - layout->data_size = buf_size; - layout->print = eeprom_layout_print; - layout->update = eeprom_layout_update_field; }
Split the eeprom layout field finding code from the eeprom_layout_update_field() function in order to make it usable in alternative implementations of update method.
Signed-off-by: Marek Behún kabel@kernel.org --- common/eeprom/eeprom_layout.c | 46 +++++++++++++++++++++++------------ include/eeprom_layout.h | 4 +++ 2 files changed, 35 insertions(+), 15 deletions(-)
diff --git a/common/eeprom/eeprom_layout.c b/common/eeprom/eeprom_layout.c index 406db3f7d1..801e90d38d 100644 --- a/common/eeprom/eeprom_layout.c +++ b/common/eeprom/eeprom_layout.c @@ -56,6 +56,28 @@ static void eeprom_layout_print(const struct eeprom_layout *layout) fields[i].print(&fields[i]); }
+/* + * eeprom_layout_find_field() - finds a layout field by name + * @layout: A pointer to an existing struct layout. + * @field_name: The name of the field to update. + * @warn: Whether to print a warning if the field is not found. + * + * Returns: a pointer to the found field or NULL on failure. + */ +struct eeprom_field *eeprom_layout_find_field(struct eeprom_layout *layout, + char *field_name, bool warn) +{ + for (int i = 0; i < layout->num_of_fields; i++) + if (layout->fields[i].name != RESERVED_FIELDS && + !strcmp(layout->fields[i].name, field_name)) + return &layout->fields[i]; + + if (warn) + printf("No such field '%s'\n", field_name); + + return NULL; +} + /* * eeprom_layout_update_field() - update a single field in the layout data. * @layout: A pointer to an existing struct layout. @@ -67,8 +89,8 @@ static void eeprom_layout_print(const struct eeprom_layout *layout) static int eeprom_layout_update_field(struct eeprom_layout *layout, char *field_name, char *new_data) { - int i, err; - struct eeprom_field *fields = layout->fields; + struct eeprom_field *field; + int err;
if (new_data == NULL) return 0; @@ -76,21 +98,15 @@ static int eeprom_layout_update_field(struct eeprom_layout *layout, if (field_name == NULL) return -1;
- for (i = 0; i < layout->num_of_fields; i++) { - if (fields[i].name == RESERVED_FIELDS || - strcmp(fields[i].name, field_name)) - continue; - - err = fields[i].update(&fields[i], new_data); - if (err) - printf("Invalid data for field %s\n", field_name); - - return err; - } + field = eeprom_layout_find_field(layout, field_name, true); + if (field == NULL) + return -1;
- printf("No such field '%s'\n", field_name); + err = field->update(field, new_data); + if (err) + printf("Invalid data for field %s\n", field_name);
- return -1; + return err; }
/* diff --git a/include/eeprom_layout.h b/include/eeprom_layout.h index 730d963ab9..b1d6220595 100644 --- a/include/eeprom_layout.h +++ b/include/eeprom_layout.h @@ -9,6 +9,8 @@ #ifndef _LAYOUT_ #define _LAYOUT_
+#include <eeprom_field.h> + #define RESERVED_FIELDS NULL #define LAYOUT_VERSION_UNRECOGNIZED -1 #define LAYOUT_VERSION_AUTODETECT -2 @@ -24,6 +26,8 @@ struct eeprom_layout { char *new_data); };
+struct eeprom_field *eeprom_layout_find_field(struct eeprom_layout *layout, + char *field_name, bool warn); void eeprom_layout_setup(struct eeprom_layout *layout, unsigned char *buf, unsigned int buf_size, int layout_version); __weak void __eeprom_layout_assign(struct eeprom_layout *layout,
The __eeprom_field_update_bin() function is expected to parse a hex string into bytes (potentially in reverse order), but the simple_strtoul() function is given 0 as base. This does not work since the string does not contain '0x' prefix. Add explicit base 16.
Signed-off-by: Marek Behún kabel@kernel.org --- common/eeprom/eeprom_field.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/eeprom/eeprom_field.c b/common/eeprom/eeprom_field.c index f56eebe679..9b831414a4 100644 --- a/common/eeprom/eeprom_field.c +++ b/common/eeprom/eeprom_field.c @@ -55,7 +55,7 @@ static int __eeprom_field_update_bin(struct eeprom_field *field, tmp[k] = value[reverse ? i - 1 + k : i + k]; }
- byte = simple_strtoul(tmp, &endptr, 0); + byte = simple_strtoul(tmp, &endptr, 16); if (*endptr != '\0' || byte < 0) return -1;
The byte variable is of type unsigned char, it is never less than zero. The error case is handled by *endptr, so drop the comparison altogether.
diff --git a/common/eeprom/eeprom_field.c b/common/eeprom/eeprom_field.c index 9b831414a4..26f6041e54 100644 --- a/common/eeprom/eeprom_field.c +++ b/common/eeprom/eeprom_field.c @@ -56,7 +56,7 @@ static int __eeprom_field_update_bin(struct eeprom_field *field, }
byte = simple_strtoul(tmp, &endptr, 16); - if (*endptr != '\0' || byte < 0) + if (*endptr != '\0') return -1;
field->buf[j] = byte;
The bus and devaddr arguments of the eeprom command are optional, and if only one is given, it is assumed to be devaddr. Change the usage help from <bus> <devaddr> to [[bus] [devaddr]
Signed-off-by: Marek Behún kabel@kernel.org --- cmd/eeprom.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index 322765ad02..0d604832e4 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -418,14 +418,14 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) U_BOOT_CMD( eeprom, 8, 1, do_eeprom, "EEPROM sub-system", - "read <bus> <devaddr> addr off cnt\n" - "eeprom write <bus> <devaddr> addr off cnt\n" + "read [[bus] devaddr] addr off cnt\n" + "eeprom write [[bus] devaddr] addr off cnt\n" " - read/write `cnt' bytes from `devaddr` EEPROM at offset `off'" #ifdef CONFIG_CMD_EEPROM_LAYOUT "\n" - "eeprom print [-l <layout_version>] <bus> <devaddr>\n" + "eeprom print [-l <layout_version>] [[bus] devaddr]\n" " - Print layout fields and their data in human readable format\n" - "eeprom update [-l <layout_version>] <bus> <devaddr> field_name field_value\n" + "eeprom update [-l <layout_version>] [[bus] devaddr] field_name field_value\n" " - Update a specific eeprom field with new data.\n" " The new data must be written in the same human readable format as shown by the print command.\n" "\n"
Add a new Kconfig option EEPROM_LAYOUT_VERSIONS, and hide eeprom layout versionsing code behind it. Only print the relevant help in 'eeprom' command usage if this option is enabled.
Enable this new option for cm_fx6_defconfig and cm_t43_defconfig. These are the only boards using EEPROM layout versioning.
Signed-off-by: Marek Behún kabel@kernel.org --- cmd/Kconfig | 9 ++++++++- cmd/eeprom.c | 20 +++++++++++++++----- configs/cm_fx6_defconfig | 1 + configs/cm_t43_defconfig | 1 + 4 files changed, 25 insertions(+), 6 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index b026439c77..8c370993f6 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -803,9 +803,16 @@ config CMD_EEPROM_LAYOUT types of eeprom fields. Can be used for defining custom layouts.
+config EEPROM_LAYOUT_VERSIONS + bool "Support specifying eeprom layout version" + depends on CMD_EEPROM_LAYOUT + help + Support specifying eeprom layout version in the 'eeprom' command + via the -l option. + config EEPROM_LAYOUT_HELP_STRING string "Tells user what layout names are supported" - depends on CMD_EEPROM_LAYOUT + depends on EEPROM_LAYOUT_VERSIONS default "<not defined>" help Help printed with the LAYOUT VERSIONS part of the 'eeprom' diff --git a/cmd/eeprom.c b/cmd/eeprom.c index 0d604832e4..d610dc9931 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -252,10 +252,12 @@ static int parse_i2c_bus_addr(int *i2c_bus, ulong *i2c_addr, int argc,
+#ifdef CONFIG_EEPROM_LAYOUT_VERSIONS __weak int eeprom_parse_layout_version(char *str) { return LAYOUT_VERSION_UNRECOGNIZED; } +#endif
static unsigned char eeprom_buf[CONFIG_SYS_EEPROM_SIZE];
@@ -359,7 +361,7 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if (action == EEPROM_ACTION_INVALID) return CMD_RET_USAGE;
-#ifdef CONFIG_CMD_EEPROM_LAYOUT +#ifdef CONFIG_EEPROM_LAYOUT_VERSIONS if (action == EEPROM_PRINT || action == EEPROM_UPDATE) { if (!strcmp(argv[index], "-l")) { NEXT_PARAM(argc, index); @@ -415,6 +417,12 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) field_name, field_value, addr, off, cnt); }
+#ifdef CONFIG_EEPROM_LAYOUT_VERSIONS +#define EEPROM_LAYOUT_SPEC "[-l <layout_version>] " +#else +#define EEPROM_LAYOUT_SPEC "" +#endif + U_BOOT_CMD( eeprom, 8, 1, do_eeprom, "EEPROM sub-system", @@ -423,16 +431,18 @@ U_BOOT_CMD( " - read/write `cnt' bytes from `devaddr` EEPROM at offset `off'" #ifdef CONFIG_CMD_EEPROM_LAYOUT "\n" - "eeprom print [-l <layout_version>] [[bus] devaddr]\n" + "eeprom print " EEPROM_LAYOUT_SPEC "[[bus] devaddr]\n" " - Print layout fields and their data in human readable format\n" - "eeprom update [-l <layout_version>] [[bus] devaddr] field_name field_value\n" + "eeprom update " EEPROM_LAYOUT_SPEC "[[bus] devaddr] field_name field_value\n" " - Update a specific eeprom field with new data.\n" - " The new data must be written in the same human readable format as shown by the print command.\n" - "\n" + " The new data must be written in the same human readable format as shown by the print command." +#ifdef CONFIG_EEPROM_LAYOUT_VERSIONS + "\n\n" "LAYOUT VERSIONS\n" "The -l option can be used to force the command to interpret the EEPROM data using the chosen layout.\n" "If the -l option is omitted, the command will auto detect the layout based on the data in the EEPROM.\n" "The values which can be provided with the -l option are:\n" CONFIG_EEPROM_LAYOUT_HELP_STRING"\n" #endif +#endif ); diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index a4d5f91b35..386616cc42 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -46,6 +46,7 @@ CONFIG_SYS_MAXARGS=32 CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_EEPROM_LAYOUT=y +CONFIG_EEPROM_LAYOUT_VERSIONS=y CONFIG_EEPROM_LAYOUT_HELP_STRING="v2, v3" CONFIG_SYS_I2C_EEPROM_BUS=2 CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=4 diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 93e667292c..32f126a517 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_PROMPT="CM-T43 # " CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_EEPROM_LAYOUT=y +CONFIG_EEPROM_LAYOUT_VERSIONS=y CONFIG_EEPROM_LAYOUT_HELP_STRING="v2, v3" CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=4 CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5
Deduplicate the calls to parse_i2c_bus_addr().
Signed-off-by: Marek Behún kabel@kernel.org --- cmd/eeprom.c | 36 +++++++++++++++++------------------- 1 file changed, 17 insertions(+), 19 deletions(-)
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index d610dc9931..12902e812e 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -339,6 +339,21 @@ static int eeprom_execute_command(enum eeprom_action action, int i2c_bus, return rcode; }
+static int eeprom_action_expected_argc(enum eeprom_action action) +{ + switch (action) { + case EEPROM_READ: + case EEPROM_WRITE: + return 3; + case EEPROM_PRINT: + return 0; + case EEPROM_UPDATE: + return 2; + default: + return CMD_RET_USAGE; + } +} + #define NEXT_PARAM(argc, index) { (argc)--; (index)++; } int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -371,25 +386,8 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } #endif
- switch (action) { - case EEPROM_READ: - case EEPROM_WRITE: - ret = parse_i2c_bus_addr(&i2c_bus, &i2c_addr, argc, - argv + index, 3); - break; - case EEPROM_PRINT: - ret = parse_i2c_bus_addr(&i2c_bus, &i2c_addr, argc, - argv + index, 0); - break; - case EEPROM_UPDATE: - ret = parse_i2c_bus_addr(&i2c_bus, &i2c_addr, argc, - argv + index, 2); - break; - default: - /* Get compiler to stop whining */ - return CMD_RET_USAGE; - } - + ret = parse_i2c_bus_addr(&i2c_bus, &i2c_addr, argc, argv + index, + eeprom_action_expected_argc(action)); if (ret == CMD_RET_USAGE) return ret;
In preparation for allowing to access eeprom by driver-model device name, refactor the eeprom device specifier parsing. Instead of filling two parameters (i2c_bus, i2c_addr), the parsing function now fills one parameter of type struct eeprom_dev_spec.
Signed-off-by: Marek Behún kabel@kernel.org --- cmd/eeprom.c | 77 ++++++++++++++++++++++++++++------------------------ 1 file changed, 41 insertions(+), 36 deletions(-)
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index 12902e812e..e29639780d 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -208,41 +208,42 @@ static long parse_numeric_param(char *str) return (*endptr != '\0') ? -1 : value; }
+struct eeprom_dev_spec { + int i2c_bus; + ulong i2c_addr; +}; + /** - * parse_i2c_bus_addr - parse the i2c bus and i2c devaddr parameters + * parse_eeprom_dev_spec - parse the eeprom device specifier * - * @i2c_bus: address to store the i2c bus - * @i2c_addr: address to store the device i2c address - * @argc: count of command line arguments left to parse + * @dev: pointer to eeprom device specifier + * @argc: count of command line arguments that can be used to parse + * the device specifier * @argv: command line arguments left to parse - * @argc_no_bus_addr: argc value we expect to see when bus & addr aren't given * * @returns: number of arguments parsed or CMD_RET_USAGE if error */ -static int parse_i2c_bus_addr(int *i2c_bus, ulong *i2c_addr, int argc, - char *const argv[], int argc_no_bus_addr) +static int parse_eeprom_dev_spec(struct eeprom_dev_spec *dev, int argc, + char *const argv[]) { - int argc_no_bus = argc_no_bus_addr + 1; - int argc_bus_addr = argc_no_bus_addr + 2; - #ifdef CONFIG_SYS_I2C_EEPROM_ADDR - if (argc == argc_no_bus_addr) { - *i2c_bus = -1; - *i2c_addr = CONFIG_SYS_I2C_EEPROM_ADDR; + if (argc == 0) { + dev->i2c_bus = -1; + dev->i2c_addr = CONFIG_SYS_I2C_EEPROM_ADDR;
return 0; } #endif - if (argc == argc_no_bus) { - *i2c_bus = -1; - *i2c_addr = parse_numeric_param(argv[0]); + if (argc == 1) { + dev->i2c_bus = -1; + dev->i2c_addr = parse_numeric_param(argv[0]);
return 1; }
- if (argc == argc_bus_addr) { - *i2c_bus = parse_numeric_param(argv[0]); - *i2c_addr = parse_numeric_param(argv[1]); + if (argc == 2) { + dev->i2c_bus = parse_numeric_param(argv[0]); + dev->i2c_addr = parse_numeric_param(argv[1]);
return 2; } @@ -287,9 +288,10 @@ static enum eeprom_action parse_action(char *cmd) return EEPROM_ACTION_INVALID; }
-static int eeprom_execute_command(enum eeprom_action action, int i2c_bus, - ulong i2c_addr, int layout_ver, char *key, - char *value, ulong addr, ulong off, ulong cnt) +static int eeprom_execute_command(enum eeprom_action action, + struct eeprom_dev_spec *dev, + int layout_ver, char *key, char *value, + ulong addr, ulong off, ulong cnt) { int rcode = 0; const char *const fmt = @@ -301,25 +303,26 @@ static int eeprom_execute_command(enum eeprom_action action, int i2c_bus, if (action == EEPROM_ACTION_INVALID) return CMD_RET_USAGE;
- eeprom_init(i2c_bus); + eeprom_init(dev->i2c_bus); if (action == EEPROM_READ) { - printf(fmt, i2c_addr, "read", addr, off, cnt); + printf(fmt, dev->i2c_addr, "read", addr, off, cnt);
- rcode = eeprom_read(i2c_addr, off, (uchar *)addr, cnt); + rcode = eeprom_read(dev->i2c_addr, off, (uchar *)addr, cnt);
puts("done\n"); return rcode; } else if (action == EEPROM_WRITE) { - printf(fmt, i2c_addr, "write", addr, off, cnt); + printf(fmt, dev->i2c_addr, "write", addr, off, cnt);
- rcode = eeprom_write(i2c_addr, off, (uchar *)addr, cnt); + rcode = eeprom_write(dev->i2c_addr, off, (uchar *)addr, cnt);
#ifdef CONFIG_CMD_EEPROM_LAYOUT - rcode = eeprom_read(i2c_addr, 0, eeprom_buf, CONFIG_SYS_EEPROM_SIZE); + rcode = eeprom_read(dev->i2c_addr, 0, eeprom_buf, + CONFIG_SYS_EEPROM_SIZE); if (rcode < 0) return rcode;
@@ -333,7 +336,8 @@ static int eeprom_execute_command(enum eeprom_action action, int i2c_bus,
layout.update(&layout, key, value);
- rcode = eeprom_write(i2c_addr, 0, layout.data, CONFIG_SYS_EEPROM_SIZE); + rcode = eeprom_write(dev->i2c_addr, 0, layout.data, + CONFIG_SYS_EEPROM_SIZE); #endif
return rcode; @@ -359,9 +363,9 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { int layout_ver = LAYOUT_VERSION_AUTODETECT; enum eeprom_action action = EEPROM_ACTION_INVALID; - int i2c_bus = -1, index = 0; - ulong i2c_addr = -1, addr = 0, cnt = 0, off = 0; - int ret; + struct eeprom_dev_spec dev; + ulong addr = 0, cnt = 0, off = 0; + int ret, index = 0; char *field_name = ""; char *field_value = "";
@@ -386,8 +390,9 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } #endif
- ret = parse_i2c_bus_addr(&i2c_bus, &i2c_addr, argc, argv + index, - eeprom_action_expected_argc(action)); + ret = parse_eeprom_dev_spec(&dev, + argc - eeprom_action_expected_argc(action), + argv + index); if (ret == CMD_RET_USAGE) return ret;
@@ -411,8 +416,8 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } #endif
- return eeprom_execute_command(action, i2c_bus, i2c_addr, layout_ver, - field_name, field_value, addr, off, cnt); + return eeprom_execute_command(action, &dev, layout_ver, field_name, + field_value, addr, off, cnt); }
Refactor the eeprom_execute_command() function into separate functions do_eeprom_rw(), do_eeprom_print() and do_eeprom_update().
Signed-off-by: Marek Behún kabel@kernel.org --- cmd/eeprom.c | 111 ++++++++++++++++++++++++++++++++------------------- 1 file changed, 71 insertions(+), 40 deletions(-)
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index e29639780d..c76cf43157 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -288,61 +288,75 @@ static enum eeprom_action parse_action(char *cmd) return EEPROM_ACTION_INVALID; }
-static int eeprom_execute_command(enum eeprom_action action, - struct eeprom_dev_spec *dev, - int layout_ver, char *key, char *value, - ulong addr, ulong off, ulong cnt) +static int do_eeprom_rw(struct eeprom_dev_spec *dev, bool read, + ulong addr, ulong off, ulong cnt) { - int rcode = 0; const char *const fmt = "\nEEPROM @0x%lX %s: addr 0x%08lx off 0x%04lx count %ld ... "; + uchar *memloc = (uchar *)addr; + int ret; + + printf(fmt, dev->i2c_addr, read ? "read" : "write", addr, off, cnt); + if (read) + ret = eeprom_read(dev->i2c_addr, off, memloc, cnt); + else + ret = eeprom_write(dev->i2c_addr, off, memloc, cnt); + puts("done\n"); + + return ret; +} + #ifdef CONFIG_CMD_EEPROM_LAYOUT - struct eeprom_layout layout; -#endif
- if (action == EEPROM_ACTION_INVALID) - return CMD_RET_USAGE; +static int do_eeprom_layout(struct eeprom_dev_spec *dev, int layout_ver, + struct eeprom_layout *layout) +{ + int ret;
- eeprom_init(dev->i2c_bus); - if (action == EEPROM_READ) { - printf(fmt, dev->i2c_addr, "read", addr, off, cnt); + ret = eeprom_read(dev->i2c_addr, 0, eeprom_buf, CONFIG_SYS_EEPROM_SIZE); + if (ret) + return ret;
- rcode = eeprom_read(dev->i2c_addr, off, (uchar *)addr, cnt); + eeprom_layout_setup(layout, eeprom_buf, CONFIG_SYS_EEPROM_SIZE, + layout_ver);
- puts("done\n"); - return rcode; - } else if (action == EEPROM_WRITE) { - printf(fmt, dev->i2c_addr, "write", addr, off, cnt); + return 0; +}
- rcode = eeprom_write(dev->i2c_addr, off, (uchar *)addr, cnt); +static int do_eeprom_print(struct eeprom_dev_spec *dev, int layout_ver) +{ + struct eeprom_layout layout; + int ret;
- puts("done\n"); - return rcode; - } + ret = do_eeprom_layout(dev, layout_ver, &layout); + if (ret) + return ret;
-#ifdef CONFIG_CMD_EEPROM_LAYOUT - rcode = eeprom_read(dev->i2c_addr, 0, eeprom_buf, - CONFIG_SYS_EEPROM_SIZE); - if (rcode < 0) - return rcode; + layout.print(&layout);
- eeprom_layout_setup(&layout, eeprom_buf, CONFIG_SYS_EEPROM_SIZE, - layout_ver); + return 0; +}
- if (action == EEPROM_PRINT) { - layout.print(&layout); - return 0; - } +static int do_eeprom_update(struct eeprom_dev_spec *dev, int layout_ver, + char *key, char *value) +{ + struct eeprom_layout layout; + int ret;
- layout.update(&layout, key, value); + ret = do_eeprom_layout(dev, layout_ver, &layout); + if (ret) + return ret;
- rcode = eeprom_write(dev->i2c_addr, 0, layout.data, - CONFIG_SYS_EEPROM_SIZE); -#endif + ret = layout.update(&layout, key, value); + if (ret) + return CMD_RET_FAILURE;
- return rcode; + return eeprom_write(dev->i2c_addr, 0, layout.data, + CONFIG_SYS_EEPROM_SIZE); }
+#endif + static int eeprom_action_expected_argc(enum eeprom_action action) { switch (action) { @@ -361,13 +375,15 @@ static int eeprom_action_expected_argc(enum eeprom_action action) #define NEXT_PARAM(argc, index) { (argc)--; (index)++; } int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - int layout_ver = LAYOUT_VERSION_AUTODETECT; enum eeprom_action action = EEPROM_ACTION_INVALID; struct eeprom_dev_spec dev; ulong addr = 0, cnt = 0, off = 0; int ret, index = 0; +#ifdef CONFIG_CMD_EEPROM_LAYOUT char *field_name = ""; char *field_value = ""; + int layout_ver = LAYOUT_VERSION_AUTODETECT; +#endif
if (argc <= 1) return CMD_RET_USAGE; @@ -416,8 +432,23 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } #endif
- return eeprom_execute_command(action, &dev, layout_ver, field_name, - field_value, addr, off, cnt); + eeprom_init(dev.i2c_bus); + + switch (action) { + case EEPROM_READ: + case EEPROM_WRITE: + return do_eeprom_rw(&dev, action == EEPROM_READ, + addr, off, cnt); +#ifdef CONFIG_CMD_EEPROM_LAYOUT + case EEPROM_PRINT: + return do_eeprom_print(&dev, layout_ver); + case EEPROM_UPDATE: + return do_eeprom_update(&dev, layout_ver, + field_name, field_value); +#endif + default: + return CMD_RET_USAGE; + } }
Don't read/write whole EEPROM if not necessary when printing / updating EEPROM layout fields. Only read/write layout.data_size bytes.
Signed-off-by: Marek Behún kabel@kernel.org --- cmd/eeprom.c | 11 ++--------- 1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index c76cf43157..9c4af88738 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -311,16 +311,10 @@ static int do_eeprom_rw(struct eeprom_dev_spec *dev, bool read, static int do_eeprom_layout(struct eeprom_dev_spec *dev, int layout_ver, struct eeprom_layout *layout) { - int ret; - - ret = eeprom_read(dev->i2c_addr, 0, eeprom_buf, CONFIG_SYS_EEPROM_SIZE); - if (ret) - return ret; - eeprom_layout_setup(layout, eeprom_buf, CONFIG_SYS_EEPROM_SIZE, layout_ver);
- return 0; + return eeprom_read(dev->i2c_addr, 0, eeprom_buf, layout->data_size); }
static int do_eeprom_print(struct eeprom_dev_spec *dev, int layout_ver) @@ -351,8 +345,7 @@ static int do_eeprom_update(struct eeprom_dev_spec *dev, int layout_ver, if (ret) return CMD_RET_FAILURE;
- return eeprom_write(dev->i2c_addr, 0, layout.data, - CONFIG_SYS_EEPROM_SIZE); + return eeprom_write(dev->i2c_addr, 0, layout.data, layout.data_size); }
#endif
Extend the 'eeprom' command to allow accessing EEPROMs probed via driver model, uclass UCLASS_I2C_EEPROM.
When the CONFIG_I2C_EEPROM config option is enabled (and so the i2c-eeprom driver is built), the 'eeprom' command now accepts driver model device name as EEPROM specifier for the 'eeprom' command, in addition to the legacy [[bus] devaddr] specifier.
Moreover if no device specifier is given, then the first UCLASS_I2C_EEPROM device is used, if found.
Signed-off-by: Marek Behún kabel@kernel.org --- cmd/eeprom.c | 122 ++++++++++++++++++++++++++++++++++++++++++++++----- 1 file changed, 112 insertions(+), 10 deletions(-)
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index 9c4af88738..a39fc5ffdc 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -22,8 +22,10 @@ #include <common.h> #include <config.h> #include <command.h> +#include <dm.h> #include <eeprom.h> #include <i2c.h> +#include <i2c_eeprom.h> #include <eeprom_layout.h> #include <linux/delay.h>
@@ -209,10 +211,41 @@ static long parse_numeric_param(char *str) }
struct eeprom_dev_spec { +#if CONFIG_IS_ENABLED(I2C_EEPROM) + struct udevice *dev; +#endif int i2c_bus; ulong i2c_addr; };
+static void eeprom_dev_spec_init(struct eeprom_dev_spec *dev) +{ +#if CONFIG_IS_ENABLED(I2C_EEPROM) + if (!dev->dev) +#endif + eeprom_init(dev->i2c_bus); +} + +static int eeprom_dev_spec_read(struct eeprom_dev_spec *dev, + unsigned offset, uchar *buffer, unsigned cnt) +{ +#if CONFIG_IS_ENABLED(I2C_EEPROM) + if (dev->dev) + return i2c_eeprom_read(dev->dev, offset, buffer, cnt); +#endif + return eeprom_read(dev->i2c_addr, offset, buffer, cnt); +} + +static int eeprom_dev_spec_write(struct eeprom_dev_spec *dev, + unsigned offset, uchar *buffer, unsigned cnt) +{ +#if CONFIG_IS_ENABLED(I2C_EEPROM) + if (dev->dev) + return i2c_eeprom_write(dev->dev, offset, buffer, cnt); +#endif + return eeprom_write(dev->i2c_addr, offset, buffer, cnt); +} + /** * parse_eeprom_dev_spec - parse the eeprom device specifier * @@ -226,6 +259,28 @@ struct eeprom_dev_spec { static int parse_eeprom_dev_spec(struct eeprom_dev_spec *dev, int argc, char *const argv[]) { +#if CONFIG_IS_ENABLED(I2C_EEPROM) + if (argc == 0) { + if (!uclass_first_device_err(UCLASS_I2C_EEPROM, &dev->dev)) + return 0; + } + + if (argc == 1) { + if (!uclass_get_device_by_name(UCLASS_I2C_EEPROM, argv[0], + &dev->dev)) + return 1; + + /* + * If we could not find the device by name and the parameter is + * not numeric (and so won't be handled later), fail. + */ + if (parse_numeric_param(argv[0]) == -1) { + printf("Can't get eeprom device: %s\n", argv[0]); + return CMD_RET_USAGE; + } + } +#endif + #ifdef CONFIG_SYS_I2C_EEPROM_ADDR if (argc == 0) { dev->i2c_bus = -1; @@ -265,6 +320,7 @@ static unsigned char eeprom_buf[CONFIG_SYS_EEPROM_SIZE]; #endif
enum eeprom_action { + EEPROM_LIST, EEPROM_READ, EEPROM_WRITE, EEPROM_PRINT, @@ -274,6 +330,10 @@ enum eeprom_action {
static enum eeprom_action parse_action(char *cmd) { +#if CONFIG_IS_ENABLED(I2C_EEPROM) + if (!strncmp(cmd, "list", 4)) + return EEPROM_LIST; +#endif if (!strncmp(cmd, "read", 4)) return EEPROM_READ; if (!strncmp(cmd, "write", 5)) @@ -288,6 +348,24 @@ static enum eeprom_action parse_action(char *cmd) return EEPROM_ACTION_INVALID; }
+#if CONFIG_IS_ENABLED(I2C_EEPROM) +static int do_eeprom_list(void) +{ + struct udevice *dev; + struct uclass *uc; + int err; + + err = uclass_get(UCLASS_I2C_EEPROM, &uc); + if (err) + return CMD_RET_FAILURE; + + uclass_foreach_dev(dev, uc) + printf("%s (%s)\n", dev->name, dev->driver->name); + + return CMD_RET_SUCCESS; +} +#endif + static int do_eeprom_rw(struct eeprom_dev_spec *dev, bool read, ulong addr, ulong off, ulong cnt) { @@ -298,9 +376,9 @@ static int do_eeprom_rw(struct eeprom_dev_spec *dev, bool read,
printf(fmt, dev->i2c_addr, read ? "read" : "write", addr, off, cnt); if (read) - ret = eeprom_read(dev->i2c_addr, off, memloc, cnt); + ret = eeprom_dev_spec_read(dev, off, memloc, cnt); else - ret = eeprom_write(dev->i2c_addr, off, memloc, cnt); + ret = eeprom_dev_spec_write(dev, off, memloc, cnt); puts("done\n");
return ret; @@ -314,7 +392,7 @@ static int do_eeprom_layout(struct eeprom_dev_spec *dev, int layout_ver, eeprom_layout_setup(layout, eeprom_buf, CONFIG_SYS_EEPROM_SIZE, layout_ver);
- return eeprom_read(dev->i2c_addr, 0, eeprom_buf, layout->data_size); + return eeprom_dev_spec_read(dev, 0, eeprom_buf, layout->data_size); }
static int do_eeprom_print(struct eeprom_dev_spec *dev, int layout_ver) @@ -345,7 +423,7 @@ static int do_eeprom_update(struct eeprom_dev_spec *dev, int layout_ver, if (ret) return CMD_RET_FAILURE;
- return eeprom_write(dev->i2c_addr, 0, layout.data, layout.data_size); + return eeprom_dev_spec_write(dev, 0, layout.data, layout.data_size); }
#endif @@ -353,6 +431,8 @@ static int do_eeprom_update(struct eeprom_dev_spec *dev, int layout_ver, static int eeprom_action_expected_argc(enum eeprom_action action) { switch (action) { + case EEPROM_LIST: + return 0; case EEPROM_READ: case EEPROM_WRITE: return 3; @@ -389,6 +469,11 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if (action == EEPROM_ACTION_INVALID) return CMD_RET_USAGE;
+#if CONFIG_IS_ENABLED(I2C_EEPROM) + if (action == EEPROM_LIST) + return do_eeprom_list(); +#endif + #ifdef CONFIG_EEPROM_LAYOUT_VERSIONS if (action == EEPROM_PRINT || action == EEPROM_UPDATE) { if (!strcmp(argv[index], "-l")) { @@ -425,7 +510,7 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } #endif
- eeprom_init(dev.i2c_bus); + eeprom_dev_spec_init(&dev);
switch (action) { case EEPROM_READ: @@ -450,19 +535,37 @@ int do_eeprom(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) #define EEPROM_LAYOUT_SPEC "" #endif
+#if CONFIG_IS_ENABLED(I2C_EEPROM) +# define EEPROM_DEV_SPEC "[device_specifier]" +#else +# define EEPROM_DEV_SPEC "[[bus] devaddr]" +#endif + U_BOOT_CMD( eeprom, 8, 1, do_eeprom, "EEPROM sub-system", - "read [[bus] devaddr] addr off cnt\n" - "eeprom write [[bus] devaddr] addr off cnt\n" +#if CONFIG_IS_ENABLED(I2C_EEPROM) + "list\n" + "eeprom " +#endif + "read " EEPROM_DEV_SPEC " addr off cnt\n" + "eeprom write " EEPROM_DEV_SPEC " addr off cnt\n" " - read/write `cnt' bytes from `devaddr` EEPROM at offset `off'" #ifdef CONFIG_CMD_EEPROM_LAYOUT "\n" - "eeprom print " EEPROM_LAYOUT_SPEC "[[bus] devaddr]\n" + "eeprom print " EEPROM_LAYOUT_SPEC EEPROM_DEV_SPEC "\n" " - Print layout fields and their data in human readable format\n" - "eeprom update " EEPROM_LAYOUT_SPEC "[[bus] devaddr] field_name field_value\n" + "eeprom update " EEPROM_LAYOUT_SPEC EEPROM_DEV_SPEC " field_name field_value\n" " - Update a specific eeprom field with new data.\n" " The new data must be written in the same human readable format as shown by the print command." +#endif +#if CONFIG_IS_ENABLED(I2C_EEPROM) + "\n\n" + "DEVICE SPECIFIER - the eeprom device can be specified\n" + " [dev_name] - by device name (devices can listed with the eeprom list command)\n" + " [[bus] devaddr] - or by I2C bus and I2C device address\n" + "If no device specifier is given, the first driver-model found device is used." +#endif #ifdef CONFIG_EEPROM_LAYOUT_VERSIONS "\n\n" "LAYOUT VERSIONS\n" @@ -471,5 +574,4 @@ U_BOOT_CMD( "The values which can be provided with the -l option are:\n" CONFIG_EEPROM_LAYOUT_HELP_STRING"\n" #endif -#endif );
- refactors
- fixes
- improvements
Marek Behún
