[PATCH v2 1/5] arm64: imx: imx8mp: Enable DM regulator on DH i.MX8MP DHCOM SoM on DRC02 board
Make sure DM regulator support is enabled on this board, just like on all the other DH i.MX8MP DHCOM SoM based boards.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andreas Geisreiter ageisreiter@dh-electronics.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de --- V2: No change --- configs/imx8mp_dhcom_drc02_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/imx8mp_dhcom_drc02_defconfig b/configs/imx8mp_dhcom_drc02_defconfig index d0877ad6f72..ffc9bf0e1c2 100644 --- a/configs/imx8mp_dhcom_drc02_defconfig +++ b/configs/imx8mp_dhcom_drc02_defconfig @@ -161,6 +161,8 @@ CONFIG_TFTP_TSIZE=y CONFIG_PROT_TCP_SACK=y CONFIG_IPV6=y CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 CONFIG_SPL_CLK_COMPOSITE_CCF=y @@ -231,6 +233,7 @@ CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_PCA9450=y CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y CONFIG_SPL_DM_REGULATOR=y CONFIG_DM_REGULATOR_PCA9450=y CONFIG_SPL_DM_REGULATOR_PCA9450=y
The DRC02 carrier board does not expose PCIe in any way, disable PCIe support.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andreas Geisreiter ageisreiter@dh-electronics.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de --- V2: No change --- configs/imx8mp_dhcom_drc02_defconfig | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/configs/imx8mp_dhcom_drc02_defconfig b/configs/imx8mp_dhcom_drc02_defconfig index ffc9bf0e1c2..366e5bbbb74 100644 --- a/configs/imx8mp_dhcom_drc02_defconfig +++ b/configs/imx8mp_dhcom_drc02_defconfig @@ -35,7 +35,6 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_ENV_OFFSET_REDUND=0xFF0000 CONFIG_IMX_BOOTAUX=y CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 -CONFIG_PCI=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y @@ -105,7 +104,6 @@ CONFIG_CMD_BKOPS_ENABLE=y CONFIG_MMC_SPEED_MODE_SET=y CONFIG_CMD_MTD=y CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y CONFIG_CMD_READ=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -220,10 +218,7 @@ CONFIG_DWC_ETH_QOS_IMX=y CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y -CONFIG_NVME_PCI=y -CONFIG_PCIE_DW_IMX=y CONFIG_PHY_IMX8MQ_USB=y -CONFIG_PHY_IMX8M_PCIE=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y
Neither the DRC02 nor PicoITX carrier board contains the PCA954x I2C mux chip, the chip is only present on PDK3 carrier board. Disable support for the PCA954x mux chip and I2C mux altogether on both i.MX8MP DHCOM DRC02 and PicoITX.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andreas Geisreiter ageisreiter@dh-electronics.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de --- V2: No change --- configs/imx8mp_dhcom_drc02_defconfig | 2 -- configs/imx8mp_dhcom_picoitx_defconfig | 2 -- 2 files changed, 4 deletions(-)
diff --git a/configs/imx8mp_dhcom_drc02_defconfig b/configs/imx8mp_dhcom_drc02_defconfig index 366e5bbbb74..c6e3c1b9a8a 100644 --- a/configs/imx8mp_dhcom_drc02_defconfig +++ b/configs/imx8mp_dhcom_drc02_defconfig @@ -184,8 +184,6 @@ CONFIG_SPL_GPIO_HOG=y CONFIG_MXC_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y -CONFIG_I2C_MUX=y -CONFIG_I2C_MUX_PCA954x=y # CONFIG_INPUT is not set CONFIG_LED=y CONFIG_LED_BLINK=y diff --git a/configs/imx8mp_dhcom_picoitx_defconfig b/configs/imx8mp_dhcom_picoitx_defconfig index 7cefe9ae821..f4e9ba91bcf 100644 --- a/configs/imx8mp_dhcom_picoitx_defconfig +++ b/configs/imx8mp_dhcom_picoitx_defconfig @@ -184,8 +184,6 @@ CONFIG_SPL_GPIO_HOG=y CONFIG_MXC_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y -CONFIG_I2C_MUX=y -CONFIG_I2C_MUX_PCA954x=y # CONFIG_INPUT is not set CONFIG_LED=y CONFIG_LED_BLINK=y
Deduplicate defconfigs for all DH i.MX8MP DHSOM by factoring out the common parts into generic _dhsom_defconfig and including those using the #include <configs/...> preprocessor macro, which is applicable to defconfigs as well. This enables CMD_EXPORTENV on all iMX8MP DHSOM systems to be consistent with other DHSOM systems.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andreas Geisreiter ageisreiter@dh-electronics.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de --- V2: Rename generic _defconfig to .config to work around buildman limitation --- configs/dhsom.config | 56 +++++ configs/imx8mp_dhcom_drc02_defconfig | 270 +----------------------- configs/imx8mp_dhcom_pdk2_defconfig | 270 +----------------------- configs/imx8mp_dhcom_pdk3_defconfig | 276 +------------------------ configs/imx8mp_dhcom_picoitx_defconfig | 270 +----------------------- configs/imx8mp_dhsom.config | 158 ++++++++++++++ configs/imx_dhsom.config | 96 +++++++++ 7 files changed, 326 insertions(+), 1070 deletions(-) create mode 100644 configs/dhsom.config create mode 100644 configs/imx8mp_dhsom.config create mode 100644 configs/imx_dhsom.config
diff --git a/configs/dhsom.config b/configs/dhsom.config new file mode 100644 index 00000000000..fc76632630e --- /dev/null +++ b/configs/dhsom.config @@ -0,0 +1,56 @@ +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set + +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BKOPS_ENABLE=y +CONFIG_CMD_BOOTCOUNT=y +CONFIG_CMD_BTRFS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_CAT=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DHCP6=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_FS_UUID=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_I2C=y +CONFIG_CMD_KASLRSEED=y +CONFIG_CMD_LSBLK=y +CONFIG_CMD_MBR=y +CONFIG_CMD_MD5SUM=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MII=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y +CONFIG_CMD_PART=y +CONFIG_CMD_PING=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_PXE=y +CONFIG_CMD_READ=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_SHA1SUM=y +CONFIG_CMD_SPI=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_UUID=y +CONFIG_CMD_WGET=y +CONFIG_CMD_XXD=y +CONFIG_CRC32_VERIFY=y +CONFIG_HASH_VERIFY=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_SHA1SUM_VERIFY=y + +CONFIG_VERSION_VARIABLE=y diff --git a/configs/imx8mp_dhcom_drc02_defconfig b/configs/imx8mp_dhcom_drc02_defconfig index c6e3c1b9a8a..c43839cecf5 100644 --- a/configs/imx8mp_dhcom_drc02_defconfig +++ b/configs/imx8mp_dhcom_drc02_defconfig @@ -1,271 +1,7 @@ +#include <configs/imx8mp_dhsom.config> + CONFIG_ARM=y CONFIG_ARCH_IMX8M=y -CONFIG_TEXT_BASE=0x40200000 -CONFIG_SYS_MALLOC_LEN=0x1000000 -CONFIG_SYS_MALLOC_F_LEN=0x18000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SF_DEFAULT_SPEED=50000000 -CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0xFE0000 -CONFIG_ENV_SECT_SIZE=0x1000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mp-dhcom-drc02" -CONFIG_SPL_TEXT_BASE=0x920000 -CONFIG_TARGET_IMX8MP_DH_DHCOM_PDK2=y -CONFIG_DM_RESET=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 -CONFIG_SPL_STACK=0x96fc00 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x96fc00 -CONFIG_SPL_BSS_MAX_SIZE=0x400 -CONFIG_SYS_BOOTM_LEN=0x8000000 -CONFIG_SYS_LOAD_ADDR=0x50000000 -CONFIG_SPL=y -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_DEBUG_UART_BASE=0x30860000 -CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_ENV_OFFSET_REDUND=0xFF0000 -CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 -CONFIG_DEBUG_UART=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_FIT=y -CONFIG_FIT_EXTERNAL_OFFSET=0x3000 -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 -CONFIG_SPL_LOAD_FIT_APPLY_OVERLAY=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_USE_BOOTARGS=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run dh_update_env distro_bootcmd ; reset" -CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="imx8mp-dhcom-drc02.dtb" -CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_PBSIZE=2081 -CONFIG_CONSOLE_MUX=y -CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_MAX_SIZE=0x26000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_BOOTROM_SUPPORT=y -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y -CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 -CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 -CONFIG_SPL_SYS_MMCSD_RAW_MODE=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 -# CONFIG_SPL_FIT_IMAGE_TINY is not set -CONFIG_SPL_I2C=y -CONFIG_SPL_POWER=y -CONFIG_SPL_WATCHDOG=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="u-boot=> " -# CONFIG_BOOTM_NETBSD is not set -# CONFIG_BOOTM_PLAN9 is not set -# CONFIG_BOOTM_RTEMS is not set -# CONFIG_BOOTM_VXWORKS is not set -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_EXPORTENV is not set -CONFIG_CMD_ERASEENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 -CONFIG_SYS_EEPROM_SIZE=16384 -CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 -CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 -CONFIG_CMD_MD5SUM=y -CONFIG_MD5SUM_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_SHA1SUM=y -CONFIG_SHA1SUM_VERIFY=y -CONFIG_CMD_CLK=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FUSE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_GPT_RENAME=y -CONFIG_CMD_I2C=y -CONFIG_CMD_LSBLK=y -CONFIG_CMD_MBR=y -CONFIG_CMD_MMC=y -CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_MMC_SPEED_MODE_SET=y -CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y -CONFIG_CMD_READ=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_SDP=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_CAT=y -CONFIG_CMD_XXD=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_DHCP6=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_WGET=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_PXE=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_GETTIME=y -CONFIG_CMD_KASLRSEED=y -CONFIG_CMD_SYSBOOT=y -CONFIG_CMD_UUID=y -CONFIG_CMD_PMIC=y -CONFIG_CMD_REGULATOR=y -CONFIG_CMD_SMC=y -CONFIG_HASH_VERIFY=y -CONFIG_CMD_BTRFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_FS_UUID=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y -CONFIG_MTDIDS_DEFAULT="nor0=flash@0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" -CONFIG_PARTITION_TYPE_GUID=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_NOWHERE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_SECT_SIZE_AUTO=y -CONFIG_ENV_SPI_MAX_HZ=80000000 -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_VERSION_VARIABLE=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_NETCONSOLE=y -CONFIG_IP_DEFRAG=y -CONFIG_TFTP_TSIZE=y -CONFIG_PROT_TCP_SACK=y -CONFIG_IPV6=y -CONFIG_SPL_DM=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 -CONFIG_SPL_CLK_COMPOSITE_CCF=y -CONFIG_CLK_COMPOSITE_CCF=y -CONFIG_SPL_CLK_IMX8MP=y -CONFIG_CLK_IMX8MP=y -CONFIG_FSL_CAAM=y -CONFIG_IMX8M_DRAM_INLINE_ECC=y -CONFIG_DFU_TFTP=y -CONFIG_DFU_TIMEOUT=y -CONFIG_DFU_MMC=y -CONFIG_DFU_MTD=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x42800000 -CONFIG_FASTBOOT_BUF_SIZE=0x20000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_GPIO_HOG=y -CONFIG_SPL_GPIO_HOG=y -CONFIG_MXC_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -# CONFIG_INPUT is not set -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x50 -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_SPL_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_SPL_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_ES_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_FSL_USDHC=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -# CONFIG_SPI_FLASH_UNLOCK_ALL is not set -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_PHY_SMSC=y -CONFIG_DM_MDIO=y -CONFIG_DM_ETH_PHY=y -CONFIG_DWC_ETH_QOS=y -CONFIG_DWC_ETH_QOS_IMX=y -CONFIG_FEC_MXC=y -CONFIG_RGMII=y -CONFIG_MII=y -CONFIG_PHY_IMX8MQ_USB=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_PINCTRL_IMX8M=y -CONFIG_POWER_DOMAIN=y -CONFIG_IMX8M_POWER_DOMAIN=y -CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y -CONFIG_DM_PMIC=y -CONFIG_DM_PMIC_PCA9450=y -CONFIG_SPL_DM_PMIC_PCA9450=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_PCA9450=y -CONFIG_SPL_DM_REGULATOR_PCA9450=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_RNG=y -CONFIG_DM_RTC=y -CONFIG_RTC_M41T62=y -CONFIG_CONS_INDEX=2 -CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set -CONFIG_MXC_UART=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_NXP_FSPI=y -CONFIG_MXC_SPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_PSCI=y -CONFIG_SYSRESET_WATCHDOG=y -CONFIG_DM_THERMAL=y -CONFIG_IMX_TMU=y -CONFIG_USB=y -# CONFIG_SPL_DM_USB is not set -CONFIG_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="DH electronics" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 -CONFIG_USB_FUNCTION_ACM=y -CONFIG_USB_ETHER=y -CONFIG_USB_ETH_CDC=y -CONFIG_IMX_WATCHDOG=y +CONFIG_PREBOOT="" diff --git a/configs/imx8mp_dhcom_pdk2_defconfig b/configs/imx8mp_dhcom_pdk2_defconfig index d72862c1641..aae2e210f44 100644 --- a/configs/imx8mp_dhcom_pdk2_defconfig +++ b/configs/imx8mp_dhcom_pdk2_defconfig @@ -1,273 +1,9 @@ +#include <configs/imx8mp_dhsom.config> + CONFIG_ARM=y CONFIG_ARCH_IMX8M=y -CONFIG_TEXT_BASE=0x40200000 -CONFIG_SYS_MALLOC_LEN=0x1000000 -CONFIG_SYS_MALLOC_F_LEN=0x18000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SF_DEFAULT_SPEED=50000000 -CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0xFE0000 -CONFIG_ENV_SECT_SIZE=0x1000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mp-dhcom-pdk2" -CONFIG_SPL_TEXT_BASE=0x920000 -CONFIG_TARGET_IMX8MP_DH_DHCOM_PDK2=y -CONFIG_DM_RESET=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 -CONFIG_SPL_STACK=0x96fc00 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x96fc00 -CONFIG_SPL_BSS_MAX_SIZE=0x400 -CONFIG_SYS_BOOTM_LEN=0x8000000 -CONFIG_SYS_LOAD_ADDR=0x50000000 -CONFIG_SPL=y -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_DEBUG_UART_BASE=0x30860000 -CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_ENV_OFFSET_REDUND=0xFF0000 -CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 -CONFIG_DEBUG_UART=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_FIT=y -CONFIG_FIT_EXTERNAL_OFFSET=0x3000 -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 -CONFIG_SPL_LOAD_FIT_APPLY_OVERLAY=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_USE_BOOTARGS=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run dh_update_env distro_bootcmd ; reset" -CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="freescale/imx8mp-dhcom-pdk2.dtb" -CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_PBSIZE=2081 -CONFIG_CONSOLE_MUX=y -CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_MAX_SIZE=0x26000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_BOOTROM_SUPPORT=y -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y -CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 -CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 -CONFIG_SPL_SYS_MMCSD_RAW_MODE=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 -# CONFIG_SPL_FIT_IMAGE_TINY is not set -CONFIG_SPL_I2C=y -CONFIG_SPL_POWER=y -CONFIG_SPL_WATCHDOG=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="u-boot=> " -# CONFIG_BOOTM_NETBSD is not set -# CONFIG_BOOTM_PLAN9 is not set -# CONFIG_BOOTM_RTEMS is not set -# CONFIG_BOOTM_VXWORKS is not set -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_EXPORTENV is not set -CONFIG_CMD_ERASEENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 -CONFIG_SYS_EEPROM_SIZE=16384 -CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 -CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 -CONFIG_CMD_MD5SUM=y -CONFIG_MD5SUM_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_SHA1SUM=y -CONFIG_SHA1SUM_VERIFY=y -CONFIG_CMD_CLK=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FUSE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_GPT_RENAME=y -CONFIG_CMD_I2C=y -CONFIG_CMD_LSBLK=y -CONFIG_CMD_MBR=y -CONFIG_CMD_MMC=y -CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_MMC_SPEED_MODE_SET=y -CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y -CONFIG_CMD_READ=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_SDP=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_CAT=y -CONFIG_CMD_XXD=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_DHCP6=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_WGET=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_PXE=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_GETTIME=y -CONFIG_CMD_KASLRSEED=y -CONFIG_CMD_SYSBOOT=y -CONFIG_CMD_UUID=y -CONFIG_CMD_PMIC=y -CONFIG_CMD_REGULATOR=y -CONFIG_CMD_SMC=y -CONFIG_HASH_VERIFY=y -CONFIG_CMD_BTRFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_FS_UUID=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y -CONFIG_MTDIDS_DEFAULT="nor0=flash@0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" -CONFIG_PARTITION_TYPE_GUID=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y +CONFIG_PREBOOT="" CONFIG_OF_UPSTREAM=y CONFIG_OF_UPSTREAM_INCLUDE_LOCAL_FALLBACK_DTBOS=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_NOWHERE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_SECT_SIZE_AUTO=y -CONFIG_ENV_SPI_MAX_HZ=80000000 -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_VERSION_VARIABLE=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_NETCONSOLE=y -CONFIG_IP_DEFRAG=y -CONFIG_TFTP_TSIZE=y -CONFIG_PROT_TCP_SACK=y -CONFIG_IPV6=y -CONFIG_SPL_DM=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 -CONFIG_SPL_CLK_COMPOSITE_CCF=y -CONFIG_CLK_COMPOSITE_CCF=y -CONFIG_SPL_CLK_IMX8MP=y -CONFIG_CLK_IMX8MP=y -CONFIG_FSL_CAAM=y -CONFIG_IMX8M_DRAM_INLINE_ECC=y -CONFIG_DFU_TFTP=y -CONFIG_DFU_TIMEOUT=y -CONFIG_DFU_MMC=y -CONFIG_DFU_MTD=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x42800000 -CONFIG_FASTBOOT_BUF_SIZE=0x20000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_GPIO_HOG=y -CONFIG_SPL_GPIO_HOG=y -CONFIG_MXC_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -# CONFIG_INPUT is not set -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x50 -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_SPL_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_SPL_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_ES_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_FSL_USDHC=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -# CONFIG_SPI_FLASH_UNLOCK_ALL is not set -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_PHY_SMSC=y -CONFIG_DM_MDIO=y -CONFIG_DM_ETH_PHY=y -CONFIG_DWC_ETH_QOS=y -CONFIG_DWC_ETH_QOS_IMX=y -CONFIG_FEC_MXC=y -CONFIG_RGMII=y -CONFIG_MII=y -CONFIG_PHY_IMX8MQ_USB=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_PINCTRL_IMX8M=y -CONFIG_POWER_DOMAIN=y -CONFIG_IMX8M_POWER_DOMAIN=y -CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y -CONFIG_DM_PMIC=y -CONFIG_DM_PMIC_PCA9450=y -CONFIG_SPL_DM_PMIC_PCA9450=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_PCA9450=y -CONFIG_SPL_DM_REGULATOR_PCA9450=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_RNG=y -CONFIG_DM_RTC=y -CONFIG_RTC_M41T62=y -CONFIG_CONS_INDEX=2 -CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set -CONFIG_MXC_UART=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_NXP_FSPI=y -CONFIG_MXC_SPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_PSCI=y -CONFIG_SYSRESET_WATCHDOG=y -CONFIG_DM_THERMAL=y -CONFIG_IMX_TMU=y -CONFIG_USB=y -# CONFIG_SPL_DM_USB is not set -CONFIG_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="DH electronics" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 -CONFIG_USB_FUNCTION_ACM=y -CONFIG_USB_ETHER=y -CONFIG_USB_ETH_CDC=y -CONFIG_IMX_WATCHDOG=y diff --git a/configs/imx8mp_dhcom_pdk3_defconfig b/configs/imx8mp_dhcom_pdk3_defconfig index 046013804a3..f40bf269d97 100644 --- a/configs/imx8mp_dhcom_pdk3_defconfig +++ b/configs/imx8mp_dhcom_pdk3_defconfig @@ -1,278 +1,16 @@ +#include <configs/imx8mp_dhsom.config> + CONFIG_ARM=y CONFIG_ARCH_IMX8M=y -CONFIG_TEXT_BASE=0x40200000 -CONFIG_SYS_MALLOC_LEN=0x1000000 -CONFIG_SYS_MALLOC_F_LEN=0x18000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SF_DEFAULT_SPEED=50000000 -CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0xFE0000 -CONFIG_ENV_SECT_SIZE=0x1000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mp-dhcom-pdk3" -CONFIG_SPL_TEXT_BASE=0x920000 -CONFIG_TARGET_IMX8MP_DH_DHCOM_PDK2=y -CONFIG_DM_RESET=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 -CONFIG_SPL_STACK=0x96fc00 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x96fc00 -CONFIG_SPL_BSS_MAX_SIZE=0x400 -CONFIG_SYS_BOOTM_LEN=0x8000000 -CONFIG_SYS_LOAD_ADDR=0x50000000 -CONFIG_SPL=y -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_DEBUG_UART_BASE=0x30860000 -CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_ENV_OFFSET_REDUND=0xFF0000 -CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 -CONFIG_PCI=y -CONFIG_DEBUG_UART=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_FIT=y -CONFIG_FIT_EXTERNAL_OFFSET=0x3000 -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 -CONFIG_SPL_LOAD_FIT_APPLY_OVERLAY=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_USE_BOOTARGS=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run dh_update_env distro_bootcmd ; reset" -CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="gpio clear GPIO1_11 ; sleep 0.1 ; gpio set GPIO1_11 ; sleep 0.1 ; i2c dev 4 && i2c mw 0x70 0 4 && i2c probe 0x2d && i2c mw 0x2d 0xaa55.2 0" CONFIG_DEFAULT_FDT_FILE="freescale/imx8mp-dhcom-pdk3.dtb" -CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_PBSIZE=2081 -CONFIG_CONSOLE_MUX=y -CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_MAX_SIZE=0x26000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_BOOTROM_SUPPORT=y -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y -CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 -CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 -CONFIG_SPL_SYS_MMCSD_RAW_MODE=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 -# CONFIG_SPL_FIT_IMAGE_TINY is not set -CONFIG_SPL_I2C=y -CONFIG_SPL_POWER=y -CONFIG_SPL_WATCHDOG=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="u-boot=> " -# CONFIG_BOOTM_NETBSD is not set -# CONFIG_BOOTM_PLAN9 is not set -# CONFIG_BOOTM_RTEMS is not set -# CONFIG_BOOTM_VXWORKS is not set -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_EXPORTENV is not set -CONFIG_CMD_ERASEENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 -CONFIG_SYS_EEPROM_SIZE=16384 -CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 -CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 -CONFIG_CMD_MD5SUM=y -CONFIG_MD5SUM_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_SHA1SUM=y -CONFIG_SHA1SUM_VERIFY=y -CONFIG_CMD_CLK=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FUSE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_GPT_RENAME=y -CONFIG_CMD_I2C=y -CONFIG_CMD_LSBLK=y -CONFIG_CMD_MBR=y -CONFIG_CMD_MMC=y -CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_MMC_SPEED_MODE_SET=y -CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y -CONFIG_CMD_READ=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_SDP=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_CAT=y -CONFIG_CMD_XXD=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_DHCP6=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_WGET=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_PXE=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_GETTIME=y -CONFIG_CMD_KASLRSEED=y -CONFIG_CMD_SYSBOOT=y -CONFIG_CMD_UUID=y -CONFIG_CMD_PMIC=y -CONFIG_CMD_REGULATOR=y -CONFIG_CMD_SMC=y -CONFIG_HASH_VERIFY=y -CONFIG_CMD_BTRFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_FS_UUID=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y -CONFIG_MTDIDS_DEFAULT="nor0=flash@0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" -CONFIG_PARTITION_TYPE_GUID=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y +CONFIG_PREBOOT="gpio clear GPIO1_11 ; sleep 0.1 ; gpio set GPIO1_11 ; sleep 0.1 ; i2c dev 4 && i2c mw 0x70 0 4 && i2c probe 0x2d && i2c mw 0x2d 0xaa55.2 0" CONFIG_OF_UPSTREAM=y CONFIG_OF_UPSTREAM_INCLUDE_LOCAL_FALLBACK_DTBOS=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_NOWHERE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_SECT_SIZE_AUTO=y -CONFIG_ENV_SPI_MAX_HZ=80000000 -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_VERSION_VARIABLE=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_NETCONSOLE=y -CONFIG_IP_DEFRAG=y -CONFIG_TFTP_TSIZE=y -CONFIG_PROT_TCP_SACK=y -CONFIG_IPV6=y -CONFIG_SPL_DM=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 -CONFIG_SPL_CLK_COMPOSITE_CCF=y -CONFIG_CLK_COMPOSITE_CCF=y -CONFIG_SPL_CLK_IMX8MP=y -CONFIG_CLK_IMX8MP=y -CONFIG_FSL_CAAM=y -CONFIG_IMX8M_DRAM_INLINE_ECC=y -CONFIG_DFU_TFTP=y -CONFIG_DFU_TIMEOUT=y -CONFIG_DFU_MMC=y -CONFIG_DFU_MTD=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x42800000 -CONFIG_FASTBOOT_BUF_SIZE=0x20000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_GPIO_HOG=y -CONFIG_SPL_GPIO_HOG=y -CONFIG_MXC_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_I2C_MUX=y -CONFIG_I2C_MUX_PCA954x=y -# CONFIG_INPUT is not set -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x50 -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_SPL_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_SPL_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_ES_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_FSL_USDHC=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -# CONFIG_SPI_FLASH_UNLOCK_ALL is not set -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_PHY_SMSC=y -CONFIG_DM_MDIO=y -CONFIG_DM_ETH_PHY=y -CONFIG_DWC_ETH_QOS=y -CONFIG_DWC_ETH_QOS_IMX=y -CONFIG_FEC_MXC=y -CONFIG_RGMII=y -CONFIG_MII=y +CONFIG_CMD_PCI=y CONFIG_NVME_PCI=y +CONFIG_PCI=y CONFIG_PCIE_DW_IMX=y -CONFIG_PHY_IMX8MQ_USB=y CONFIG_PHY_IMX8M_PCIE=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_PINCTRL_IMX8M=y -CONFIG_POWER_DOMAIN=y -CONFIG_IMX8M_POWER_DOMAIN=y -CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y -CONFIG_DM_PMIC=y -CONFIG_DM_PMIC_PCA9450=y -CONFIG_SPL_DM_PMIC_PCA9450=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_PCA9450=y -CONFIG_SPL_DM_REGULATOR_PCA9450=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_RNG=y -CONFIG_DM_RTC=y -CONFIG_RTC_M41T62=y -CONFIG_CONS_INDEX=2 -CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set -CONFIG_MXC_UART=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_NXP_FSPI=y -CONFIG_MXC_SPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_PSCI=y -CONFIG_SYSRESET_WATCHDOG=y -CONFIG_DM_THERMAL=y -CONFIG_IMX_TMU=y -CONFIG_USB=y -# CONFIG_SPL_DM_USB is not set -CONFIG_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="DH electronics" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 -CONFIG_USB_FUNCTION_ACM=y -CONFIG_USB_ETHER=y -CONFIG_USB_ETH_CDC=y -CONFIG_IMX_WATCHDOG=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/imx8mp_dhcom_picoitx_defconfig b/configs/imx8mp_dhcom_picoitx_defconfig index f4e9ba91bcf..99cd5f279dc 100644 --- a/configs/imx8mp_dhcom_picoitx_defconfig +++ b/configs/imx8mp_dhcom_picoitx_defconfig @@ -1,271 +1,7 @@ +#include <configs/imx8mp_dhsom.config> + CONFIG_ARM=y CONFIG_ARCH_IMX8M=y -CONFIG_TEXT_BASE=0x40200000 -CONFIG_SYS_MALLOC_LEN=0x1000000 -CONFIG_SYS_MALLOC_F_LEN=0x18000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SF_DEFAULT_SPEED=50000000 -CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0xFE0000 -CONFIG_ENV_SECT_SIZE=0x1000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mp-dhcom-picoitx" -CONFIG_SPL_TEXT_BASE=0x920000 -CONFIG_TARGET_IMX8MP_DH_DHCOM_PDK2=y -CONFIG_DM_RESET=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 -CONFIG_SPL_STACK=0x96fc00 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x96fc00 -CONFIG_SPL_BSS_MAX_SIZE=0x400 -CONFIG_SYS_BOOTM_LEN=0x8000000 -CONFIG_SYS_LOAD_ADDR=0x50000000 -CONFIG_SPL=y -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_DEBUG_UART_BASE=0x30860000 -CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_ENV_OFFSET_REDUND=0xFF0000 -CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 -CONFIG_DEBUG_UART=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_FIT=y -CONFIG_FIT_EXTERNAL_OFFSET=0x3000 -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 -CONFIG_SPL_LOAD_FIT_APPLY_OVERLAY=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_USE_BOOTARGS=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run dh_update_env distro_bootcmd ; reset" -CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="imx8mp-dhcom-picoitx.dtb" -CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_PBSIZE=2081 -CONFIG_CONSOLE_MUX=y -CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_MAX_SIZE=0x26000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_BOOTROM_SUPPORT=y -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y -CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 -CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 -CONFIG_SPL_SYS_MMCSD_RAW_MODE=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 -# CONFIG_SPL_FIT_IMAGE_TINY is not set -CONFIG_SPL_I2C=y -CONFIG_SPL_POWER=y -CONFIG_SPL_WATCHDOG=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="u-boot=> " -# CONFIG_BOOTM_NETBSD is not set -# CONFIG_BOOTM_PLAN9 is not set -# CONFIG_BOOTM_RTEMS is not set -# CONFIG_BOOTM_VXWORKS is not set -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_EXPORTENV is not set -CONFIG_CMD_ERASEENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 -CONFIG_SYS_EEPROM_SIZE=16384 -CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 -CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 -CONFIG_CMD_MD5SUM=y -CONFIG_MD5SUM_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_SHA1SUM=y -CONFIG_SHA1SUM_VERIFY=y -CONFIG_CMD_CLK=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FUSE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_GPT_RENAME=y -CONFIG_CMD_I2C=y -CONFIG_CMD_LSBLK=y -CONFIG_CMD_MBR=y -CONFIG_CMD_MMC=y -CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_MMC_SPEED_MODE_SET=y -CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y -CONFIG_CMD_READ=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_SDP=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_CAT=y -CONFIG_CMD_XXD=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_DHCP6=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_WGET=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_PXE=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_GETTIME=y -CONFIG_CMD_KASLRSEED=y -CONFIG_CMD_SYSBOOT=y -CONFIG_CMD_UUID=y -CONFIG_CMD_PMIC=y -CONFIG_CMD_REGULATOR=y -CONFIG_CMD_SMC=y -CONFIG_HASH_VERIFY=y -CONFIG_CMD_BTRFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_FS_UUID=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y -CONFIG_MTDIDS_DEFAULT="nor0=flash@0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" -CONFIG_PARTITION_TYPE_GUID=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_NOWHERE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_SECT_SIZE_AUTO=y -CONFIG_ENV_SPI_MAX_HZ=80000000 -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_VERSION_VARIABLE=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_NETCONSOLE=y -CONFIG_IP_DEFRAG=y -CONFIG_TFTP_TSIZE=y -CONFIG_PROT_TCP_SACK=y -CONFIG_IPV6=y -CONFIG_SPL_DM=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 -CONFIG_SPL_CLK_COMPOSITE_CCF=y -CONFIG_CLK_COMPOSITE_CCF=y -CONFIG_SPL_CLK_IMX8MP=y -CONFIG_CLK_IMX8MP=y -CONFIG_FSL_CAAM=y -CONFIG_IMX8M_DRAM_INLINE_ECC=y -CONFIG_DFU_TFTP=y -CONFIG_DFU_TIMEOUT=y -CONFIG_DFU_MMC=y -CONFIG_DFU_MTD=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x42800000 -CONFIG_FASTBOOT_BUF_SIZE=0x20000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_GPIO_HOG=y -CONFIG_SPL_GPIO_HOG=y -CONFIG_MXC_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -# CONFIG_INPUT is not set -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x50 -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_SPL_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_SPL_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_ES_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_FSL_USDHC=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -# CONFIG_SPI_FLASH_UNLOCK_ALL is not set -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_PHY_SMSC=y -CONFIG_DM_MDIO=y -CONFIG_DM_ETH_PHY=y -CONFIG_DWC_ETH_QOS=y -CONFIG_DWC_ETH_QOS_IMX=y -CONFIG_FEC_MXC=y -CONFIG_RGMII=y -CONFIG_MII=y -CONFIG_PHY_IMX8MQ_USB=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_PINCTRL_IMX8M=y -CONFIG_POWER_DOMAIN=y -CONFIG_IMX8M_POWER_DOMAIN=y -CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y -CONFIG_DM_PMIC=y -CONFIG_DM_PMIC_PCA9450=y -CONFIG_SPL_DM_PMIC_PCA9450=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_PCA9450=y -CONFIG_SPL_DM_REGULATOR_PCA9450=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_RNG=y -CONFIG_DM_RTC=y -CONFIG_RTC_M41T62=y -CONFIG_CONS_INDEX=2 -CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set -CONFIG_MXC_UART=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_NXP_FSPI=y -CONFIG_MXC_SPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_PSCI=y -CONFIG_SYSRESET_WATCHDOG=y -CONFIG_DM_THERMAL=y -CONFIG_IMX_TMU=y -CONFIG_USB=y -# CONFIG_SPL_DM_USB is not set -CONFIG_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="DH electronics" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 -CONFIG_USB_FUNCTION_ACM=y -CONFIG_USB_ETHER=y -CONFIG_USB_ETH_CDC=y -CONFIG_IMX_WATCHDOG=y +CONFIG_PREBOOT="" diff --git a/configs/imx8mp_dhsom.config b/configs/imx8mp_dhsom.config new file mode 100644 index 00000000000..416143178c8 --- /dev/null +++ b/configs/imx8mp_dhsom.config @@ -0,0 +1,158 @@ +#include <configs/imx_dhsom.config> + +CONFIG_TARGET_IMX8MP_DH_DHCOM_PDK2=y +# CONFIG_INPUT is not set +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_BOOTCOMMAND="run dh_update_env distro_bootcmd ; reset" +CONFIG_NR_DRAM_BANKS=2 +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 +CONFIG_SYS_BOOTM_LEN=0x8000000 +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y +CONFIG_SYS_LOAD_ADDR=0x50000000 +CONFIG_SYS_MALLOC_F_LEN=0x18000 +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_SYS_MONITOR_LEN=1048576 +CONFIG_SYS_PBSIZE=2081 +CONFIG_TEXT_BASE=0x40200000 +CONFIG_USE_BOOTARGS=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_USE_PREBOOT=y + +# CONFIG_SPL_FIT_IMAGE_TINY is not set +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_BSS_MAX_SIZE=0x400 +CONFIG_SPL_BSS_START_ADDR=0x96fc00 +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 +CONFIG_SPL_DM=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 +CONFIG_SPL_LOAD_FIT_APPLY_OVERLAY=y +CONFIG_SPL_MAX_SIZE=0x26000 +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_STACK=0x96fc00 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_TEXT_BASE=0x920000 + +CONFIG_CONSOLE_MUX=y +CONFIG_CONS_INDEX=2 +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x30860000 +CONFIG_DEBUG_UART_CLOCK=24000000 + +CONFIG_CMD_EEPROM=y +CONFIG_CMD_SMC=y +CONFIG_SPL_I2C=y +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 +CONFIG_SYS_EEPROM_SIZE=16384 +CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 + +CONFIG_ENV_OFFSET=0xFE0000 +CONFIG_ENV_OFFSET_REDUND=0xFF0000 +CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SPI_MAX_HZ=80000000 +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NXP_FSPI=y +CONFIG_SF_DEFAULT_SPEED=50000000 +# CONFIG_SPI_FLASH_UNLOCK_ALL is not set + +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 + +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_CLK_IMX8MP=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MP=y + +CONFIG_FSL_CAAM=y + +CONFIG_IMX8M_DRAM_INLINE_ECC=y + +CONFIG_IMX_BOOTAUX=y + +CONFIG_DM_PCA953X=y +CONFIG_SPL_GPIO_HOG=y + +CONFIG_DM_ETH_PHY=y +CONFIG_DM_MDIO=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_PHY_SMSC=y +CONFIG_RGMII=y + +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_SPEED_MODE_SET=y +CONFIG_SPL_MMC_IO_VOLTAGE=y +CONFIG_SPL_MMC_UHS_SUPPORT=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y + +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_PCA9450=y +CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_POWER_DOMAIN=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR_PCA9450=y +CONFIG_SPL_POWER=y + +CONFIG_PINCTRL_IMX8M=y +CONFIG_SPL_PINCTRL=y + +CONFIG_CMD_SPI=y +CONFIG_DM_MTD=y + +CONFIG_DM_RESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y + +CONFIG_DM_RNG=y + +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIME=y +CONFIG_DM_RTC=y +CONFIG_RTC_M41T62=y + +CONFIG_CMD_USB_SDP=y +CONFIG_DM_USB_GADGET=y +CONFIG_FASTBOOT_BUF_ADDR=0x42800000 +CONFIG_FASTBOOT_BUF_SIZE=0x20000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_PHY_IMX8MQ_USB=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y +CONFIG_USB_FUNCTION_ACM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y +CONFIG_USB_XHCI_HCD=y + +CONFIG_DFU_MMC=y +CONFIG_DFU_MTD=y +CONFIG_DFU_RAM=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_TIMEOUT=y diff --git a/configs/imx_dhsom.config b/configs/imx_dhsom.config new file mode 100644 index 00000000000..d166b2cda2b --- /dev/null +++ b/configs/imx_dhsom.config @@ -0,0 +1,96 @@ +#include <configs/dhsom.config> + +CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y +CONFIG_FIT=y +CONFIG_OF_CONTROL=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " + +CONFIG_SPL=y +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_WATCHDOG=y +# CONFIG_SPL_DM_SERIAL is not set +# CONFIG_SPL_DM_USB is not set + +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_SYSBOOT=y + +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_SECT_SIZE_AUTO=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y + +CONFIG_REGMAP=y +CONFIG_SYSCON=y + +CONFIG_DM_GPIO=y +CONFIG_GPIO_HOG=y +CONFIG_MXC_GPIO=y + +CONFIG_DM_I2C=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 + +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y + +CONFIG_FSL_USDHC=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_SUPPORT_EMMC_BOOT=y + +CONFIG_IPV6=y +CONFIG_FEC_MXC=y +CONFIG_IP_DEFRAG=y +CONFIG_MII=y +CONFIG_NETCONSOLE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_PHY_ANEG_TIMEOUT=20000 +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_PROT_TCP_SACK=y +CONFIG_TFTP_TSIZE=y + +CONFIG_MTD=y +CONFIG_MTDIDS_DEFAULT="nor0=flash@0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" +CONFIG_MXC_SPI=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_WINBOND=y + +CONFIG_PINCTRL=y + +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y + +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y + +CONFIG_IMX_WATCHDOG=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y + +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y + +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="DH electronics" +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_STORAGE=y
Deduplicate defconfigs for all DH i.MX6 DHSOM by including common configs/imx_dhsom_defconfig . This does introduce changes to the board configuration, namely it enables commands used on all DHSOM devices consistenty, the prompt is changed to u-boot=>, support for booting non-Linux OS which was likely never used is disabled, GPT partition table support is enabled, generic MTD support is enabled, LED support is enabled, DM PHY, PMIC and regulator support is also enabled, KASLR command is enabled.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andreas Geisreiter ageisreiter@dh-electronics.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de --- V2: No change --- configs/dh_imx6_defconfig | 169 +++++++++++++------------------------- 1 file changed, 58 insertions(+), 111 deletions(-)
diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 27dab9e2e95..32be8cdcacf 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -1,132 +1,79 @@ +#include <configs/imx_dhsom.config> + CONFIG_ARM=y -CONFIG_SPL_SYS_L2_PL310=y CONFIG_ARCH_MX6=y -CONFIG_TEXT_BASE=0x17800000 -CONFIG_SYS_MALLOC_F_LEN=0x1000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_SF_DEFAULT_SPEED=25000000 -CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_OFFSET=0x100000 -CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MX6QDL=y -CONFIG_MX6_DDRCAL=y CONFIG_TARGET_DHCOMIMX6=y -CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx6q-dhcom-pdk2" +CONFIG_TEXT_BASE=0x17800000 CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_SYS_L2_PL310=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-dhcom-pdk2" +CONFIG_MX6_DDRCAL=y +CONFIG_NR_DRAM_BANKS=1 CONFIG_OF_LIBFDT_OVERLAY=y -CONFIG_SYS_MONITOR_LEN=409600 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0x020CC068 -CONFIG_WATCHDOG_TIMEOUT_MSECS=60000 -CONFIG_SPL=y -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_ENV_OFFSET_REDUND=0x110000 -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -CONFIG_AHCI=y -CONFIG_SYS_MEMTEST_START=0x10000000 -CONFIG_SYS_MEMTEST_END=0x20000000 -CONFIG_LTO=y -CONFIG_FIT=y +CONFIG_OF_LIST="imx6q-dhcom-pdk2 imx6dl-dhcom-pdk2 imx6s-dhcom-drc02 imx6dl-dhcom-picoitx" CONFIG_FIT_VERBOSE=y -CONFIG_SPL_FIT=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_PBSIZE=532 +CONFIG_MULTI_DTB_FIT=y +CONFIG_LTO=y + CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 -CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_MALLOC_F_LEN=0x1000 CONFIG_SYS_MAXARGS=32 -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_UNZIP=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y +CONFIG_SYS_MEMTEST_END=0x20000000 +CONFIG_SYS_MEMTEST_START=0x10000000 +CONFIG_SYS_MONITOR_LEN=409600 +CONFIG_SYS_PBSIZE=532 + +CONFIG_SYS_BOOTCOUNT_ADDR=0x020CC068 +CONFIG_SYS_BOOTCOUNT_BE=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTDELAY=3 + +CONFIG_BZIP2=y CONFIG_CMD_SATA=y -# CONFIG_CMD_SCSI is not set -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_UNZIP=y CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP6=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_WGET=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_BTRFS=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="imx6q-dhcom-pdk2 imx6dl-dhcom-pdk2 imx6s-dhcom-drc02 imx6dl-dhcom-picoitx" -CONFIG_MULTI_DTB_FIT=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_USE_ETHPRIME=y -CONFIG_ETHPRIME="FEC" -CONFIG_VERSION_VARIABLE=y -CONFIG_ARP_TIMEOUT=200 -CONFIG_IP_DEFRAG=y -CONFIG_TFTP_TSIZE=y -CONFIG_PROT_TCP_SACK=y -CONFIG_IPV6=y +CONFIG_DISTRO_DEFAULTS=y + +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_OFFSET_REDUND=0x110000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_SIZE=0x4000 + +# CONFIG_CMD_SCSI is not set +CONFIG_AHCI=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y CONFIG_LBA48=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_BE=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_MXC=y -CONFIG_MISC=y -CONFIG_I2C_EEPROM=y -CONFIG_FSL_USDHC=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SCSI=y + +CONFIG_ARP_TIMEOUT=200 +CONFIG_ETHPRIME="FEC" +CONFIG_USE_ETHPRIME=y +CONFIG_PHYLIB=y + +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_PHYLIB=y -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_FEC_MXC=y -CONFIG_MII=y -CONFIG_PINCTRL=y +CONFIG_SPI_FLASH_UNLOCK_ALL=y + +CONFIG_MISC=y + CONFIG_PINCTRL_IMX6=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_SCSI=y -CONFIG_DM_SERIAL=y -CONFIG_MXC_UART=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_MXC_SPI=y -CONFIG_SYSRESET=y -CONFIG_SYSRESET_WATCHDOG=y -CONFIG_USB=y -CONFIG_SPL_USB_HOST=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_GADGET=y + +CONFIG_SDP_LOADADDR=0x17ffffc0 +CONFIG_SPL_FIT=y +CONFIG_SPL_SPI=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="dh" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_SPL_USB_HOST=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 CONFIG_CI_UDC=y -CONFIG_SDP_LOADADDR=0x17ffffc0 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_SPL_USB_SDP_SUPPORT=y -CONFIG_IMX_WATCHDOG=y -CONFIG_BZIP2=y + +CONFIG_WATCHDOG_TIMEOUT_MSECS=60000
Applied all, thanks.
Fabio Estevam
