[PATCH resend] reset: rockchip: implement rk3588 lookup table
The current DT bindings for the rk3588 clock use a different ID than the one that is supposed to be written to the hardware registers. Thus, we cannot use directly the id provided in the phandle, but rather use a lookup table to correctly setup the hardware.
This approach has been implemented already in Linux, by commit : f1c506d152ff ("clk: rockchip: add clock controller for the RK3588")
Hence, implement a similar approach using the lookup table, and adapt the existing reset driver to work with SoCs using lookup table. The file rst-rk3588.c has been copied as much as possible from Linux.
Adapt the clk rk3588 driver as well to bind the reset driver with the lookup table.
Reviewed-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Eugen Hristev eugen.hristev@collabora.com ---
Hi Kever, I rebased this
Thanks, Eugen
arch/arm/include/asm/arch-rockchip/clock.h | 21 + drivers/clk/rockchip/clk_rk3588.c | 2 +- drivers/reset/Makefile | 2 +- drivers/reset/reset-rockchip.c | 46 +- drivers/reset/rst-rk3588.c | 854 +++++++++++++++++++++ 5 files changed, 912 insertions(+), 13 deletions(-) create mode 100644 drivers/reset/rst-rk3588.c
diff --git a/arch/arm/include/asm/arch-rockchip/clock.h b/arch/arm/include/asm/arch-rockchip/clock.h index f002ebcb7ac1..f01c5aeb71cb 100644 --- a/arch/arm/include/asm/arch-rockchip/clock.h +++ b/arch/arm/include/asm/arch-rockchip/clock.h @@ -194,5 +194,26 @@ int rockchip_get_clk(struct udevice **devp); * Return: 0 success, or error value */ int rockchip_reset_bind(struct udevice *pdev, u32 reg_offset, u32 reg_number); +/* + * rockchip_reset_bind_lut() - Bind soft reset device as child of clock device + * using a dedicated SoC lookup table + * @pdev: clock udevice + * @lookup_table: register lookup_table dedicated to SoC + * @reg_offset: the first offset in cru for softreset registers + * @reg_number: the reg numbers of softreset registers + * Return: 0 success, or error value + */ +int rockchip_reset_bind_lut(struct udevice *pdev, const int *lookup_table, + u32 reg_offset, u32 reg_number); +/* + * rk3588_reset_bind_lut() - Bind soft reset device as child of clock device + * using dedicated RK3588 lookup table + * + * @pdev: clock udevice + * @reg_offset: the first offset in cru for softreset registers + * @reg_number: the reg numbers of softreset registers + * Return: 0 success, or error value + */ +int rk3588_reset_bind_lut(struct udevice *pdev, u32 reg_offset, u32 reg_number);
#endif diff --git a/drivers/clk/rockchip/clk_rk3588.c b/drivers/clk/rockchip/clk_rk3588.c index 5c27626df78d..119b1337bdf2 100644 --- a/drivers/clk/rockchip/clk_rk3588.c +++ b/drivers/clk/rockchip/clk_rk3588.c @@ -1996,7 +1996,7 @@ static int rk3588_clk_bind(struct udevice *dev)
#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rk3588_cru, softrst_con[0]); - ret = rockchip_reset_bind(dev, ret, 49158); + ret = rk3588_reset_bind_lut(dev, ret, 49158); if (ret) debug("Warning: software reset driver bind failed\n"); #endif diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 680126818090..e2239a250a3a 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -16,7 +16,7 @@ obj-$(CONFIG_RESET_BCM6345) += reset-bcm6345.o obj-$(CONFIG_RESET_UNIPHIER) += reset-uniphier.o obj-$(CONFIG_RESET_AST2500) += reset-ast2500.o obj-$(CONFIG_RESET_AST2600) += reset-ast2600.o -obj-$(CONFIG_RESET_ROCKCHIP) += reset-rockchip.o +obj-$(CONFIG_RESET_ROCKCHIP) += reset-rockchip.o rst-rk3588.o obj-$(CONFIG_RESET_MESON) += reset-meson.o obj-$(CONFIG_RESET_SOCFPGA) += reset-socfpga.o obj-$(CONFIG_RESET_MEDIATEK) += reset-mediatek.o diff --git a/drivers/reset/reset-rockchip.c b/drivers/reset/reset-rockchip.c index 732ac343b2b6..2ebe3382f70a 100644 --- a/drivers/reset/reset-rockchip.c +++ b/drivers/reset/reset-rockchip.c @@ -21,6 +21,7 @@
struct rockchip_reset_priv { void __iomem *base; + const int *lut; /* Rockchip reset reg locate at cru controller */ u32 reset_reg_offset; /* Rockchip reset reg number */ @@ -30,11 +31,15 @@ struct rockchip_reset_priv { static int rockchip_reset_request(struct reset_ctl *reset_ctl) { struct rockchip_reset_priv *priv = dev_get_priv(reset_ctl->dev); + unsigned long id = reset_ctl->id; + + if (priv->lut) + id = priv->lut[id];
debug("%s(reset_ctl=%p) (dev=%p, id=%lu) (reg_num=%d)\n", __func__, - reset_ctl, reset_ctl->dev, reset_ctl->id, priv->reset_reg_num); + reset_ctl, reset_ctl->dev, id, priv->reset_reg_num);
- if (reset_ctl->id / ROCKCHIP_RESET_NUM_IN_REG >= priv->reset_reg_num) + if (id / ROCKCHIP_RESET_NUM_IN_REG >= priv->reset_reg_num) return -EINVAL;
return 0; @@ -43,12 +48,17 @@ static int rockchip_reset_request(struct reset_ctl *reset_ctl) static int rockchip_reset_assert(struct reset_ctl *reset_ctl) { struct rockchip_reset_priv *priv = dev_get_priv(reset_ctl->dev); - int bank = reset_ctl->id / ROCKCHIP_RESET_NUM_IN_REG; - int offset = reset_ctl->id % ROCKCHIP_RESET_NUM_IN_REG; + unsigned long id = reset_ctl->id; + int bank, offset; + + if (priv->lut) + id = priv->lut[id]; + + bank = id / ROCKCHIP_RESET_NUM_IN_REG; + offset = id % ROCKCHIP_RESET_NUM_IN_REG;
debug("%s(reset_ctl=%p) (dev=%p, id=%lu) (reg_addr=%p)\n", __func__, - reset_ctl, reset_ctl->dev, reset_ctl->id, - priv->base + (bank * 4)); + reset_ctl, reset_ctl->dev, id, priv->base + (bank * 4));
rk_setreg(priv->base + (bank * 4), BIT(offset));
@@ -58,12 +68,17 @@ static int rockchip_reset_assert(struct reset_ctl *reset_ctl) static int rockchip_reset_deassert(struct reset_ctl *reset_ctl) { struct rockchip_reset_priv *priv = dev_get_priv(reset_ctl->dev); - int bank = reset_ctl->id / ROCKCHIP_RESET_NUM_IN_REG; - int offset = reset_ctl->id % ROCKCHIP_RESET_NUM_IN_REG; + unsigned long id = reset_ctl->id; + int bank, offset; + + if (priv->lut) + id = priv->lut[id]; + + bank = id / ROCKCHIP_RESET_NUM_IN_REG; + offset = id % ROCKCHIP_RESET_NUM_IN_REG;
rk_clrreg(priv->base + (bank * 4), BIT(offset));
@@ -98,7 +113,10 @@ static int rockchip_reset_probe(struct udevice *dev) return 0; }
-int rockchip_reset_bind(struct udevice *pdev, u32 reg_offset, u32 reg_number) +int rockchip_reset_bind_lut(struct udevice *pdev, + const int *lookup_table, + u32 reg_offset, + u32 reg_number) { struct udevice *rst_dev; struct rockchip_reset_priv *priv; @@ -113,11 +131,17 @@ int rockchip_reset_bind(struct udevice *pdev, u32 reg_offset, u32 reg_number) priv = malloc(sizeof(struct rockchip_reset_priv)); priv->reset_reg_offset = reg_offset; priv->reset_reg_num = reg_number; + priv->lut = lookup_table; dev_set_priv(rst_dev, priv);
return 0; }
+int rockchip_reset_bind(struct udevice *pdev, u32 reg_offset, u32 reg_number) +{ + return rockchip_reset_bind_lut(pdev, NULL, reg_offset, reg_number); +} + U_BOOT_DRIVER(rockchip_reset) = { .name = "rockchip_reset", .id = UCLASS_RESET, diff --git a/drivers/reset/rst-rk3588.c b/drivers/reset/rst-rk3588.c new file mode 100644 index 000000000000..2c524e4c4033 --- /dev/null +++ b/drivers/reset/rst-rk3588.c @@ -0,0 +1,854 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2021 Rockchip Electronics Co., Ltd. + * Copyright (c) 2022 Collabora Ltd. + * Author: Sebastian Reichel sebastian.reichel@collabora.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/arch-rockchip/clock.h> +#include <dt-bindings/reset/rockchip,rk3588-cru.h> + +/* 0xFD7C0000 + 0x0A00 */ +#define RK3588_CRU_RESET_OFFSET(id, reg, bit) [id] = (0 + reg * 16 + bit) + +/* 0xFD7C8000 + 0x0A00 */ +#define RK3588_PHPTOPCRU_RESET_OFFSET(id, reg, bit) [id] = (0x8000*4 + reg * 16 + bit) + +/* 0xFD7D0000 + 0x0A00 */ +#define RK3588_SECURECRU_RESET_OFFSET(id, reg, bit) [id] = (0x10000*4 + reg * 16 + bit) + +/* 0xFD7F0000 + 0x0A00 */ +#define RK3588_PMU1CRU_RESET_OFFSET(id, reg, bit) [id] = (0x30000*4 + reg * 16 + bit) + +/* mapping table for reset ID to register offset */ +static const int rk3588_register_offset[] = { + /* SOFTRST_CON01 */ + RK3588_CRU_RESET_OFFSET(SRST_A_TOP_BIU, 1, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_TOP_BIU, 1, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_CSIPHY0, 1, 6), + RK3588_CRU_RESET_OFFSET(SRST_CSIPHY0, 1, 7), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_P_CSIPHY1, 1, 8), + RK3588_CRU_RESET_OFFSET(SRST_CSIPHY1, 1, 9), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_A_TOP_M500_BIU, 1, 15), + + /* SOFTRST_CON02 */ + RK3588_CRU_RESET_OFFSET(SRST_A_TOP_M400_BIU, 2, 0), + RK3588_CRU_RESET_OFFSET(SRST_A_TOP_S200_BIU, 2, 1), + RK3588_CRU_RESET_OFFSET(SRST_A_TOP_S400_BIU, 2, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_TOP_M300_BIU, 2, 3), + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY0_INIT, 2, 8), + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY0_CMN, 2, 9), + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY0_LANE, 2, 10), + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY0_PCS, 2, 11), + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY1_INIT, 2, 15), + + /* SOFTRST_CON03 */ + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY1_CMN, 3, 0), + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY1_LANE, 3, 1), + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY1_PCS, 3, 2), + RK3588_CRU_RESET_OFFSET(SRST_DCPHY0, 3, 11), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_P_MIPI_DCPHY0, 3, 14), + RK3588_CRU_RESET_OFFSET(SRST_P_MIPI_DCPHY0_GRF, 3, 15), + + /* SOFTRST_CON04 */ + RK3588_CRU_RESET_OFFSET(SRST_DCPHY1, 4, 0), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_P_MIPI_DCPHY1, 4, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_MIPI_DCPHY1_GRF, 4, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_CDPHY, 4, 5), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_CSIPHY, 4, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_VCCIO3_5, 4, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_VCCIO6, 4, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_EMMCIO, 4, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_IOC_TOP, 4, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_IOC_RIGHT, 4, 11), + + /* SOFTRST_CON05 */ + RK3588_CRU_RESET_OFFSET(SRST_P_CRU, 5, 0), + RK3588_CRU_RESET_OFFSET(SRST_A_CHANNEL_SECURE2VO1USB, 5, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_CHANNEL_SECURE2CENTER, 5, 8), + RK3588_CRU_RESET_OFFSET(SRST_H_CHANNEL_SECURE2VO1USB, 5, 14), + RK3588_CRU_RESET_OFFSET(SRST_H_CHANNEL_SECURE2CENTER, 5, 15), + + /* SOFTRST_CON06 */ + RK3588_CRU_RESET_OFFSET(SRST_P_CHANNEL_SECURE2VO1USB, 6, 0), + RK3588_CRU_RESET_OFFSET(SRST_P_CHANNEL_SECURE2CENTER, 6, 1), + + /* SOFTRST_CON07 */ + RK3588_CRU_RESET_OFFSET(SRST_H_AUDIO_BIU, 7, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_AUDIO_BIU, 7, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_I2S0_8CH, 7, 4), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S0_8CH_TX, 7, 7), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S0_8CH_RX, 7, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_ACDCDIG, 7, 11), + RK3588_CRU_RESET_OFFSET(SRST_H_I2S2_2CH, 7, 12), + RK3588_CRU_RESET_OFFSET(SRST_H_I2S3_2CH, 7, 13), + + /* SOFTRST_CON08 */ + RK3588_CRU_RESET_OFFSET(SRST_M_I2S2_2CH, 8, 0), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S3_2CH, 8, 3), + RK3588_CRU_RESET_OFFSET(SRST_DAC_ACDCDIG, 8, 4), + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIF0, 8, 14), + + /* SOFTRST_CON09 */ + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIF0, 9, 1), + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIF1, 9, 2), + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIF1, 9, 5), + RK3588_CRU_RESET_OFFSET(SRST_H_PDM1, 9, 6), + RK3588_CRU_RESET_OFFSET(SRST_PDM1, 9, 7), + + /* SOFTRST_CON10 */ + RK3588_CRU_RESET_OFFSET(SRST_A_BUS_BIU, 10, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_BUS_BIU, 10, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_GIC, 10, 3), + RK3588_CRU_RESET_OFFSET(SRST_A_GIC_DBG, 10, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_DMAC0, 10, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_DMAC1, 10, 6), + RK3588_CRU_RESET_OFFSET(SRST_A_DMAC2, 10, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_I2C1, 10, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_I2C2, 10, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_I2C3, 10, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_I2C4, 10, 11), + RK3588_CRU_RESET_OFFSET(SRST_P_I2C5, 10, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_I2C6, 10, 13), + RK3588_CRU_RESET_OFFSET(SRST_P_I2C7, 10, 14), + RK3588_CRU_RESET_OFFSET(SRST_P_I2C8, 10, 15), + + /* SOFTRST_CON11 */ + RK3588_CRU_RESET_OFFSET(SRST_I2C1, 11, 0), + RK3588_CRU_RESET_OFFSET(SRST_I2C2, 11, 1), + RK3588_CRU_RESET_OFFSET(SRST_I2C3, 11, 2), + RK3588_CRU_RESET_OFFSET(SRST_I2C4, 11, 3), + RK3588_CRU_RESET_OFFSET(SRST_I2C5, 11, 4), + RK3588_CRU_RESET_OFFSET(SRST_I2C6, 11, 5), + RK3588_CRU_RESET_OFFSET(SRST_I2C7, 11, 6), + RK3588_CRU_RESET_OFFSET(SRST_I2C8, 11, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_CAN0, 11, 8), + RK3588_CRU_RESET_OFFSET(SRST_CAN0, 11, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_CAN1, 11, 10), + RK3588_CRU_RESET_OFFSET(SRST_CAN1, 11, 11), + RK3588_CRU_RESET_OFFSET(SRST_P_CAN2, 11, 12), + RK3588_CRU_RESET_OFFSET(SRST_CAN2, 11, 13), + RK3588_CRU_RESET_OFFSET(SRST_P_SARADC, 11, 14), + + /* SOFTRST_CON12 */ + RK3588_CRU_RESET_OFFSET(SRST_P_TSADC, 12, 0), + RK3588_CRU_RESET_OFFSET(SRST_TSADC, 12, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_UART1, 12, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_UART2, 12, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_UART3, 12, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_UART4, 12, 5), + RK3588_CRU_RESET_OFFSET(SRST_P_UART5, 12, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_UART6, 12, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_UART7, 12, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_UART8, 12, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_UART9, 12, 10), + RK3588_CRU_RESET_OFFSET(SRST_S_UART1, 12, 13), + + /* SOFTRST_CON13 */ + RK3588_CRU_RESET_OFFSET(SRST_S_UART2, 13, 0), + RK3588_CRU_RESET_OFFSET(SRST_S_UART3, 13, 3), + RK3588_CRU_RESET_OFFSET(SRST_S_UART4, 13, 6), + RK3588_CRU_RESET_OFFSET(SRST_S_UART5, 13, 9), + RK3588_CRU_RESET_OFFSET(SRST_S_UART6, 13, 12), + RK3588_CRU_RESET_OFFSET(SRST_S_UART7, 13, 15), + + /* SOFTRST_CON14 */ + RK3588_CRU_RESET_OFFSET(SRST_S_UART8, 14, 2), + RK3588_CRU_RESET_OFFSET(SRST_S_UART9, 14, 5), + RK3588_CRU_RESET_OFFSET(SRST_P_SPI0, 14, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_SPI1, 14, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_SPI2, 14, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_SPI3, 14, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_SPI4, 14, 10), + RK3588_CRU_RESET_OFFSET(SRST_SPI0, 14, 11), + RK3588_CRU_RESET_OFFSET(SRST_SPI1, 14, 12), + RK3588_CRU_RESET_OFFSET(SRST_SPI2, 14, 13), + RK3588_CRU_RESET_OFFSET(SRST_SPI3, 14, 14), + RK3588_CRU_RESET_OFFSET(SRST_SPI4, 14, 15), + + /* SOFTRST_CON15 */ + RK3588_CRU_RESET_OFFSET(SRST_P_WDT0, 15, 0), + RK3588_CRU_RESET_OFFSET(SRST_T_WDT0, 15, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_SYS_GRF, 15, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_PWM1, 15, 3), + RK3588_CRU_RESET_OFFSET(SRST_PWM1, 15, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_PWM2, 15, 6), + RK3588_CRU_RESET_OFFSET(SRST_PWM2, 15, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_PWM3, 15, 9), + RK3588_CRU_RESET_OFFSET(SRST_PWM3, 15, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_BUSTIMER0, 15, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_BUSTIMER1, 15, 13), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER0, 15, 15), + + /* SOFTRST_CON16 */ + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER1, 16, 0), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER2, 16, 1), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER3, 16, 2), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER4, 16, 3), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER5, 16, 4), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER6, 16, 5), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER7, 16, 6), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER8, 16, 7), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER9, 16, 8), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER10, 16, 9), + RK3588_CRU_RESET_OFFSET(SRST_BUSTIMER11, 16, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_MAILBOX0, 16, 11), + RK3588_CRU_RESET_OFFSET(SRST_P_MAILBOX1, 16, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_MAILBOX2, 16, 13), + RK3588_CRU_RESET_OFFSET(SRST_P_GPIO1, 16, 14), + RK3588_CRU_RESET_OFFSET(SRST_GPIO1, 16, 15), + + /* SOFTRST_CON17 */ + RK3588_CRU_RESET_OFFSET(SRST_P_GPIO2, 17, 0), + RK3588_CRU_RESET_OFFSET(SRST_GPIO2, 17, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_GPIO3, 17, 2), + RK3588_CRU_RESET_OFFSET(SRST_GPIO3, 17, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_GPIO4, 17, 4), + RK3588_CRU_RESET_OFFSET(SRST_GPIO4, 17, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_DECOM, 17, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_DECOM, 17, 7), + RK3588_CRU_RESET_OFFSET(SRST_D_DECOM, 17, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_TOP, 17, 9), + RK3588_CRU_RESET_OFFSET(SRST_A_GICADB_GIC2CORE_BUS, 17, 11), + RK3588_CRU_RESET_OFFSET(SRST_P_DFT2APB, 17, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_TOP, 17, 13), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_CDPHY, 17, 14), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_BOT_RIGHT, 17, 15), + + /* SOFTRST_CON18 */ + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_IOC_TOP, 18, 0), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_IOC_RIGHT, 18, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_CSIPHY, 18, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_VCCIO3_5, 18, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_VCCIO6, 18, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_MST_EMMCIO, 18, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_SPINLOCK, 18, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_OTPC_NS, 18, 9), + RK3588_CRU_RESET_OFFSET(SRST_OTPC_NS, 18, 10), + RK3588_CRU_RESET_OFFSET(SRST_OTPC_ARB, 18, 11), + + /* SOFTRST_CON19 */ + RK3588_CRU_RESET_OFFSET(SRST_P_BUSIOC, 19, 0), + RK3588_CRU_RESET_OFFSET(SRST_P_PMUCM0_INTMUX, 19, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_DDRCM0_INTMUX, 19, 5), + + /* SOFTRST_CON20 */ + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_DFICTL_CH0, 20, 0), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_MON_CH0, 20, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_STANDBY_CH0, 20, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_UPCTL_CH0, 20, 3), + RK3588_CRU_RESET_OFFSET(SRST_TM_DDR_MON_CH0, 20, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_GRF_CH01, 20, 5), + RK3588_CRU_RESET_OFFSET(SRST_DFI_CH0, 20, 6), + RK3588_CRU_RESET_OFFSET(SRST_SBR_CH0, 20, 7), + RK3588_CRU_RESET_OFFSET(SRST_DDR_UPCTL_CH0, 20, 8), + RK3588_CRU_RESET_OFFSET(SRST_DDR_DFICTL_CH0, 20, 9), + RK3588_CRU_RESET_OFFSET(SRST_DDR_MON_CH0, 20, 10), + RK3588_CRU_RESET_OFFSET(SRST_DDR_STANDBY_CH0, 20, 11), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR_UPCTL_CH0, 20, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_DFICTL_CH1, 20, 13), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_MON_CH1, 20, 14), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_STANDBY_CH1, 20, 15), + + /* SOFTRST_CON21 */ + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_UPCTL_CH1, 21, 0), + RK3588_CRU_RESET_OFFSET(SRST_TM_DDR_MON_CH1, 21, 1), + RK3588_CRU_RESET_OFFSET(SRST_DFI_CH1, 21, 2), + RK3588_CRU_RESET_OFFSET(SRST_SBR_CH1, 21, 3), + RK3588_CRU_RESET_OFFSET(SRST_DDR_UPCTL_CH1, 21, 4), + RK3588_CRU_RESET_OFFSET(SRST_DDR_DFICTL_CH1, 21, 5), + RK3588_CRU_RESET_OFFSET(SRST_DDR_MON_CH1, 21, 6), + RK3588_CRU_RESET_OFFSET(SRST_DDR_STANDBY_CH1, 21, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR_UPCTL_CH1, 21, 8), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_MSCH0, 21, 13), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_RS_MSCH0, 21, 14), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_FRS_MSCH0, 21, 15), + + /* SOFTRST_CON22 */ + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_SCRAMBLE0, 22, 0), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_FRS_SCRAMBLE0, 22, 1), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_MSCH1, 22, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_RS_MSCH1, 22, 3), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_FRS_MSCH1, 22, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_SCRAMBLE1, 22, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR01_FRS_SCRAMBLE1, 22, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR01_MSCH0, 22, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR01_MSCH1, 22, 8), + + /* SOFTRST_CON23 */ + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_DFICTL_CH2, 23, 0), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_MON_CH2, 23, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_STANDBY_CH2, 23, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_UPCTL_CH2, 23, 3), + RK3588_CRU_RESET_OFFSET(SRST_TM_DDR_MON_CH2, 23, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_GRF_CH23, 23, 5), + RK3588_CRU_RESET_OFFSET(SRST_DFI_CH2, 23, 6), + RK3588_CRU_RESET_OFFSET(SRST_SBR_CH2, 23, 7), + RK3588_CRU_RESET_OFFSET(SRST_DDR_UPCTL_CH2, 23, 8), + RK3588_CRU_RESET_OFFSET(SRST_DDR_DFICTL_CH2, 23, 9), + RK3588_CRU_RESET_OFFSET(SRST_DDR_MON_CH2, 23, 10), + RK3588_CRU_RESET_OFFSET(SRST_DDR_STANDBY_CH2, 23, 11), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR_UPCTL_CH2, 23, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_DFICTL_CH3, 23, 13), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_MON_CH3, 23, 14), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_STANDBY_CH3, 23, 15), + + /* SOFTRST_CON24 */ + RK3588_CRU_RESET_OFFSET(SRST_P_DDR_UPCTL_CH3, 24, 0), + RK3588_CRU_RESET_OFFSET(SRST_TM_DDR_MON_CH3, 24, 1), + RK3588_CRU_RESET_OFFSET(SRST_DFI_CH3, 24, 2), + RK3588_CRU_RESET_OFFSET(SRST_SBR_CH3, 24, 3), + RK3588_CRU_RESET_OFFSET(SRST_DDR_UPCTL_CH3, 24, 4), + RK3588_CRU_RESET_OFFSET(SRST_DDR_DFICTL_CH3, 24, 5), + RK3588_CRU_RESET_OFFSET(SRST_DDR_MON_CH3, 24, 6), + RK3588_CRU_RESET_OFFSET(SRST_DDR_STANDBY_CH3, 24, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR_UPCTL_CH3, 24, 8), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_MSCH2, 24, 13), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_RS_MSCH2, 24, 14), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_FRS_MSCH2, 24, 15), + + /* SOFTRST_CON25 */ + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_SCRAMBLE2, 25, 0), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_FRS_SCRAMBLE2, 25, 1), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_MSCH3, 25, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_RS_MSCH3, 25, 3), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_FRS_MSCH3, 25, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_SCRAMBLE3, 25, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR23_FRS_SCRAMBLE3, 25, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR23_MSCH2, 25, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_DDR23_MSCH3, 25, 8), + + /* SOFTRST_CON26 */ + RK3588_CRU_RESET_OFFSET(SRST_ISP1, 26, 3), + RK3588_CRU_RESET_OFFSET(SRST_ISP1_VICAP, 26, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_ISP1_BIU, 26, 6), + RK3588_CRU_RESET_OFFSET(SRST_H_ISP1_BIU, 26, 8), + + /* SOFTRST_CON27 */ + RK3588_CRU_RESET_OFFSET(SRST_A_RKNN1, 27, 0), + RK3588_CRU_RESET_OFFSET(SRST_A_RKNN1_BIU, 27, 1), + RK3588_CRU_RESET_OFFSET(SRST_H_RKNN1, 27, 2), + RK3588_CRU_RESET_OFFSET(SRST_H_RKNN1_BIU, 27, 3), + + /* SOFTRST_CON28 */ + RK3588_CRU_RESET_OFFSET(SRST_A_RKNN2, 28, 0), + RK3588_CRU_RESET_OFFSET(SRST_A_RKNN2_BIU, 28, 1), + RK3588_CRU_RESET_OFFSET(SRST_H_RKNN2, 28, 2), + RK3588_CRU_RESET_OFFSET(SRST_H_RKNN2_BIU, 28, 3), + + /* SOFTRST_CON29 */ + RK3588_CRU_RESET_OFFSET(SRST_A_RKNN_DSU0, 29, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_NPUTOP_BIU, 29, 5), + RK3588_CRU_RESET_OFFSET(SRST_P_NPU_TIMER, 29, 6), + RK3588_CRU_RESET_OFFSET(SRST_NPUTIMER0, 29, 8), + RK3588_CRU_RESET_OFFSET(SRST_NPUTIMER1, 29, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_NPU_WDT, 29, 10), + RK3588_CRU_RESET_OFFSET(SRST_T_NPU_WDT, 29, 11), + RK3588_CRU_RESET_OFFSET(SRST_P_NPU_PVTM, 29, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_NPU_GRF, 29, 13), + RK3588_CRU_RESET_OFFSET(SRST_NPU_PVTM, 29, 14), + + /* SOFTRST_CON30 */ + RK3588_CRU_RESET_OFFSET(SRST_NPU_PVTPLL, 30, 0), + RK3588_CRU_RESET_OFFSET(SRST_H_NPU_CM0_BIU, 30, 2), + RK3588_CRU_RESET_OFFSET(SRST_F_NPU_CM0_CORE, 30, 3), + RK3588_CRU_RESET_OFFSET(SRST_T_NPU_CM0_JTAG, 30, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_RKNN0, 30, 6), + RK3588_CRU_RESET_OFFSET(SRST_A_RKNN0_BIU, 30, 7), + RK3588_CRU_RESET_OFFSET(SRST_H_RKNN0, 30, 8), + RK3588_CRU_RESET_OFFSET(SRST_H_RKNN0_BIU, 30, 9), + + /* SOFTRST_CON31 */ + RK3588_CRU_RESET_OFFSET(SRST_H_NVM_BIU, 31, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_NVM_BIU, 31, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_EMMC, 31, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_EMMC, 31, 5), + RK3588_CRU_RESET_OFFSET(SRST_C_EMMC, 31, 6), + RK3588_CRU_RESET_OFFSET(SRST_B_EMMC, 31, 7), + RK3588_CRU_RESET_OFFSET(SRST_T_EMMC, 31, 8), + RK3588_CRU_RESET_OFFSET(SRST_S_SFC, 31, 9), + RK3588_CRU_RESET_OFFSET(SRST_H_SFC, 31, 10), + RK3588_CRU_RESET_OFFSET(SRST_H_SFC_XIP, 31, 11), + + /* SOFTRST_CON32 */ + RK3588_CRU_RESET_OFFSET(SRST_P_GRF, 32, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_DEC_BIU, 32, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_PHP_BIU, 32, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_PCIE_GRIDGE, 32, 8), + RK3588_CRU_RESET_OFFSET(SRST_A_PHP_BIU, 32, 9), + RK3588_CRU_RESET_OFFSET(SRST_A_GMAC0, 32, 10), + RK3588_CRU_RESET_OFFSET(SRST_A_GMAC1, 32, 11), + RK3588_CRU_RESET_OFFSET(SRST_A_PCIE_BIU, 32, 12), + RK3588_CRU_RESET_OFFSET(SRST_PCIE0_POWER_UP, 32, 13), + RK3588_CRU_RESET_OFFSET(SRST_PCIE1_POWER_UP, 32, 14), + RK3588_CRU_RESET_OFFSET(SRST_PCIE2_POWER_UP, 32, 15), + + /* SOFTRST_CON33 */ + RK3588_CRU_RESET_OFFSET(SRST_PCIE3_POWER_UP, 33, 0), + RK3588_CRU_RESET_OFFSET(SRST_PCIE4_POWER_UP, 33, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_PCIE0, 33, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_PCIE1, 33, 13), + RK3588_CRU_RESET_OFFSET(SRST_P_PCIE2, 33, 14), + RK3588_CRU_RESET_OFFSET(SRST_P_PCIE3, 33, 15), + + /* SOFTRST_CON34 */ + RK3588_CRU_RESET_OFFSET(SRST_P_PCIE4, 34, 0), + RK3588_CRU_RESET_OFFSET(SRST_A_PHP_GIC_ITS, 34, 6), + RK3588_CRU_RESET_OFFSET(SRST_A_MMU_PCIE, 34, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_MMU_PHP, 34, 8), + RK3588_CRU_RESET_OFFSET(SRST_A_MMU_BIU, 34, 9), + + /* SOFTRST_CON35 */ + RK3588_CRU_RESET_OFFSET(SRST_A_USB3OTG2, 35, 7), + + /* SOFTRST_CON37 */ + RK3588_CRU_RESET_OFFSET(SRST_PMALIVE0, 37, 4), + RK3588_CRU_RESET_OFFSET(SRST_PMALIVE1, 37, 5), + RK3588_CRU_RESET_OFFSET(SRST_PMALIVE2, 37, 6), + RK3588_CRU_RESET_OFFSET(SRST_A_SATA0, 37, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_SATA1, 37, 8), + RK3588_CRU_RESET_OFFSET(SRST_A_SATA2, 37, 9), + RK3588_CRU_RESET_OFFSET(SRST_RXOOB0, 37, 10), + RK3588_CRU_RESET_OFFSET(SRST_RXOOB1, 37, 11), + RK3588_CRU_RESET_OFFSET(SRST_RXOOB2, 37, 12), + RK3588_CRU_RESET_OFFSET(SRST_ASIC0, 37, 13), + RK3588_CRU_RESET_OFFSET(SRST_ASIC1, 37, 14), + RK3588_CRU_RESET_OFFSET(SRST_ASIC2, 37, 15), + + /* SOFTRST_CON40 */ + RK3588_CRU_RESET_OFFSET(SRST_A_RKVDEC_CCU, 40, 2), + RK3588_CRU_RESET_OFFSET(SRST_H_RKVDEC0, 40, 3), + RK3588_CRU_RESET_OFFSET(SRST_A_RKVDEC0, 40, 4), + RK3588_CRU_RESET_OFFSET(SRST_H_RKVDEC0_BIU, 40, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_RKVDEC0_BIU, 40, 6), + RK3588_CRU_RESET_OFFSET(SRST_RKVDEC0_CA, 40, 7), + RK3588_CRU_RESET_OFFSET(SRST_RKVDEC0_HEVC_CA, 40, 8), + RK3588_CRU_RESET_OFFSET(SRST_RKVDEC0_CORE, 40, 9), + + /* SOFTRST_CON41 */ + RK3588_CRU_RESET_OFFSET(SRST_H_RKVDEC1, 41, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_RKVDEC1, 41, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_RKVDEC1_BIU, 41, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_RKVDEC1_BIU, 41, 5), + RK3588_CRU_RESET_OFFSET(SRST_RKVDEC1_CA, 41, 6), + RK3588_CRU_RESET_OFFSET(SRST_RKVDEC1_HEVC_CA, 41, 7), + RK3588_CRU_RESET_OFFSET(SRST_RKVDEC1_CORE, 41, 8), + + /* SOFTRST_CON42 */ + RK3588_CRU_RESET_OFFSET(SRST_A_USB_BIU, 42, 2), + RK3588_CRU_RESET_OFFSET(SRST_H_USB_BIU, 42, 3), + RK3588_CRU_RESET_OFFSET(SRST_A_USB3OTG0, 42, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_USB3OTG1, 42, 7), + RK3588_CRU_RESET_OFFSET(SRST_H_HOST0, 42, 10), + RK3588_CRU_RESET_OFFSET(SRST_H_HOST_ARB0, 42, 11), + RK3588_CRU_RESET_OFFSET(SRST_H_HOST1, 42, 12), + RK3588_CRU_RESET_OFFSET(SRST_H_HOST_ARB1, 42, 13), + RK3588_CRU_RESET_OFFSET(SRST_A_USB_GRF, 42, 14), + RK3588_CRU_RESET_OFFSET(SRST_C_USB2P0_HOST0, 42, 15), + + /* SOFTRST_CON43 */ + RK3588_CRU_RESET_OFFSET(SRST_C_USB2P0_HOST1, 43, 0), + RK3588_CRU_RESET_OFFSET(SRST_HOST_UTMI0, 43, 1), + RK3588_CRU_RESET_OFFSET(SRST_HOST_UTMI1, 43, 2), + + /* SOFTRST_CON44 */ + RK3588_CRU_RESET_OFFSET(SRST_A_VDPU_BIU, 44, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_VDPU_LOW_BIU, 44, 5), + RK3588_CRU_RESET_OFFSET(SRST_H_VDPU_BIU, 44, 6), + RK3588_CRU_RESET_OFFSET(SRST_A_JPEG_DECODER_BIU, 44, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_VPU, 44, 8), + RK3588_CRU_RESET_OFFSET(SRST_H_VPU, 44, 9), + RK3588_CRU_RESET_OFFSET(SRST_A_JPEG_ENCODER0, 44, 10), + RK3588_CRU_RESET_OFFSET(SRST_H_JPEG_ENCODER0, 44, 11), + RK3588_CRU_RESET_OFFSET(SRST_A_JPEG_ENCODER1, 44, 12), + RK3588_CRU_RESET_OFFSET(SRST_H_JPEG_ENCODER1, 44, 13), + RK3588_CRU_RESET_OFFSET(SRST_A_JPEG_ENCODER2, 44, 14), + RK3588_CRU_RESET_OFFSET(SRST_H_JPEG_ENCODER2, 44, 15), + + /* SOFTRST_CON45 */ + RK3588_CRU_RESET_OFFSET(SRST_A_JPEG_ENCODER3, 45, 0), + RK3588_CRU_RESET_OFFSET(SRST_H_JPEG_ENCODER3, 45, 1), + RK3588_CRU_RESET_OFFSET(SRST_A_JPEG_DECODER, 45, 2), + RK3588_CRU_RESET_OFFSET(SRST_H_JPEG_DECODER, 45, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_IEP2P0, 45, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_IEP2P0, 45, 5), + RK3588_CRU_RESET_OFFSET(SRST_IEP2P0_CORE, 45, 6), + RK3588_CRU_RESET_OFFSET(SRST_H_RGA2, 45, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_RGA2, 45, 8), + RK3588_CRU_RESET_OFFSET(SRST_RGA2_CORE, 45, 9), + RK3588_CRU_RESET_OFFSET(SRST_H_RGA3_0, 45, 10), + RK3588_CRU_RESET_OFFSET(SRST_A_RGA3_0, 45, 11), + RK3588_CRU_RESET_OFFSET(SRST_RGA3_0_CORE, 45, 12), + + /* SOFTRST_CON47 */ + RK3588_CRU_RESET_OFFSET(SRST_H_RKVENC0_BIU, 47, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_RKVENC0_BIU, 47, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_RKVENC0, 47, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_RKVENC0, 47, 5), + RK3588_CRU_RESET_OFFSET(SRST_RKVENC0_CORE, 47, 6), + + /* SOFTRST_CON48 */ + RK3588_CRU_RESET_OFFSET(SRST_H_RKVENC1_BIU, 48, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_RKVENC1_BIU, 48, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_RKVENC1, 48, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_RKVENC1, 48, 5), + RK3588_CRU_RESET_OFFSET(SRST_RKVENC1_CORE, 48, 6), + + /* SOFTRST_CON49 */ + RK3588_CRU_RESET_OFFSET(SRST_A_VI_BIU, 49, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_VI_BIU, 49, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_VI_BIU, 49, 5), + RK3588_CRU_RESET_OFFSET(SRST_D_VICAP, 49, 6), + RK3588_CRU_RESET_OFFSET(SRST_A_VICAP, 49, 7), + RK3588_CRU_RESET_OFFSET(SRST_H_VICAP, 49, 8), + RK3588_CRU_RESET_OFFSET(SRST_ISP0, 49, 10), + RK3588_CRU_RESET_OFFSET(SRST_ISP0_VICAP, 49, 11), + + /* SOFTRST_CON50 */ + RK3588_CRU_RESET_OFFSET(SRST_FISHEYE0, 50, 0), + RK3588_CRU_RESET_OFFSET(SRST_FISHEYE1, 50, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_CSI_HOST_0, 50, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_CSI_HOST_1, 50, 5), + RK3588_CRU_RESET_OFFSET(SRST_P_CSI_HOST_2, 50, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_CSI_HOST_3, 50, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_CSI_HOST_4, 50, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_CSI_HOST_5, 50, 9), + + /* SOFTRST_CON51 */ + RK3588_CRU_RESET_OFFSET(SRST_CSIHOST0_VICAP, 51, 4), + RK3588_CRU_RESET_OFFSET(SRST_CSIHOST1_VICAP, 51, 5), + RK3588_CRU_RESET_OFFSET(SRST_CSIHOST2_VICAP, 51, 6), + RK3588_CRU_RESET_OFFSET(SRST_CSIHOST3_VICAP, 51, 7), + RK3588_CRU_RESET_OFFSET(SRST_CSIHOST4_VICAP, 51, 8), + RK3588_CRU_RESET_OFFSET(SRST_CSIHOST5_VICAP, 51, 9), + RK3588_CRU_RESET_OFFSET(SRST_CIFIN, 51, 13), + + /* SOFTRST_CON52 */ + RK3588_CRU_RESET_OFFSET(SRST_A_VOP_BIU, 52, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_VOP_LOW_BIU, 52, 5), + RK3588_CRU_RESET_OFFSET(SRST_H_VOP_BIU, 52, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_VOP_BIU, 52, 7), + RK3588_CRU_RESET_OFFSET(SRST_H_VOP, 52, 8), + RK3588_CRU_RESET_OFFSET(SRST_A_VOP, 52, 9), + RK3588_CRU_RESET_OFFSET(SRST_D_VOP0, 52, 13), + RK3588_CRU_RESET_OFFSET(SRST_D_VOP2HDMI_BRIDGE0, 52, 14), + RK3588_CRU_RESET_OFFSET(SRST_D_VOP2HDMI_BRIDGE1, 52, 15), + + /* SOFTRST_CON53 */ + RK3588_CRU_RESET_OFFSET(SRST_D_VOP1, 53, 0), + RK3588_CRU_RESET_OFFSET(SRST_D_VOP2, 53, 1), + RK3588_CRU_RESET_OFFSET(SRST_D_VOP3, 53, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_VOPGRF, 53, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_DSIHOST0, 53, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_DSIHOST1, 53, 5), + RK3588_CRU_RESET_OFFSET(SRST_DSIHOST0, 53, 6), + RK3588_CRU_RESET_OFFSET(SRST_DSIHOST1, 53, 7), + RK3588_CRU_RESET_OFFSET(SRST_VOP_PMU, 53, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_VOP_CHANNEL_BIU, 53, 9), + + /* SOFTRST_CON55 */ + RK3588_CRU_RESET_OFFSET(SRST_H_VO0_BIU, 55, 5), + RK3588_CRU_RESET_OFFSET(SRST_H_VO0_S_BIU, 55, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_VO0_BIU, 55, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_VO0_S_BIU, 55, 8), + RK3588_CRU_RESET_OFFSET(SRST_A_HDCP0_BIU, 55, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_VO0GRF, 55, 10), + RK3588_CRU_RESET_OFFSET(SRST_H_HDCP_KEY0, 55, 11), + RK3588_CRU_RESET_OFFSET(SRST_A_HDCP0, 55, 12), + RK3588_CRU_RESET_OFFSET(SRST_H_HDCP0, 55, 13), + RK3588_CRU_RESET_OFFSET(SRST_HDCP0, 55, 15), + + /* SOFTRST_CON56 */ + RK3588_CRU_RESET_OFFSET(SRST_P_TRNG0, 56, 1), + RK3588_CRU_RESET_OFFSET(SRST_DP0, 56, 8), + RK3588_CRU_RESET_OFFSET(SRST_DP1, 56, 9), + RK3588_CRU_RESET_OFFSET(SRST_H_I2S4_8CH, 56, 10), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S4_8CH_TX, 56, 13), + RK3588_CRU_RESET_OFFSET(SRST_H_I2S8_8CH, 56, 14), + + /* SOFTRST_CON57 */ + RK3588_CRU_RESET_OFFSET(SRST_M_I2S8_8CH_TX, 57, 1), + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIF2_DP0, 57, 2), + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIF2_DP0, 57, 6), + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIF5_DP1, 57, 7), + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIF5_DP1, 57, 11), + + /* SOFTRST_CON59 */ + RK3588_CRU_RESET_OFFSET(SRST_A_HDCP1_BIU, 59, 6), + RK3588_CRU_RESET_OFFSET(SRST_A_VO1_BIU, 59, 8), + RK3588_CRU_RESET_OFFSET(SRST_H_VOP1_BIU, 59, 9), + RK3588_CRU_RESET_OFFSET(SRST_H_VOP1_S_BIU, 59, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_VOP1_BIU, 59, 11), + RK3588_CRU_RESET_OFFSET(SRST_P_VO1GRF, 59, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_VO1_S_BIU, 59, 13), + + /* SOFTRST_CON60 */ + RK3588_CRU_RESET_OFFSET(SRST_H_I2S7_8CH, 60, 0), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S7_8CH_RX, 60, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_HDCP_KEY1, 60, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_HDCP1, 60, 5), + RK3588_CRU_RESET_OFFSET(SRST_H_HDCP1, 60, 6), + RK3588_CRU_RESET_OFFSET(SRST_HDCP1, 60, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_TRNG1, 60, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_HDMITX0, 60, 11), + + /* SOFTRST_CON61 */ + RK3588_CRU_RESET_OFFSET(SRST_HDMITX0_REF, 61, 0), + RK3588_CRU_RESET_OFFSET(SRST_P_HDMITX1, 61, 2), + RK3588_CRU_RESET_OFFSET(SRST_HDMITX1_REF, 61, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_HDMIRX, 61, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_HDMIRX, 61, 10), + RK3588_CRU_RESET_OFFSET(SRST_HDMIRX_REF, 61, 11), + + /* SOFTRST_CON62 */ + RK3588_CRU_RESET_OFFSET(SRST_P_EDP0, 62, 0), + RK3588_CRU_RESET_OFFSET(SRST_EDP0_24M, 62, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_EDP1, 62, 3), + RK3588_CRU_RESET_OFFSET(SRST_EDP1_24M, 62, 4), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S5_8CH_TX, 62, 8), + RK3588_CRU_RESET_OFFSET(SRST_H_I2S5_8CH, 62, 12), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S6_8CH_TX, 62, 15), + + /* SOFTRST_CON63 */ + RK3588_CRU_RESET_OFFSET(SRST_M_I2S6_8CH_RX, 63, 2), + RK3588_CRU_RESET_OFFSET(SRST_H_I2S6_8CH, 63, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIF3, 63, 4), + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIF3, 63, 7), + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIF4, 63, 8), + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIF4, 63, 11), + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIFRX0, 63, 12), + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIFRX0, 63, 13), + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIFRX1, 63, 14), + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIFRX1, 63, 15), + + /* SOFTRST_CON64 */ + RK3588_CRU_RESET_OFFSET(SRST_H_SPDIFRX2, 64, 0), + RK3588_CRU_RESET_OFFSET(SRST_M_SPDIFRX2, 64, 1), + RK3588_CRU_RESET_OFFSET(SRST_LINKSYM_HDMITXPHY0, 64, 12), + RK3588_CRU_RESET_OFFSET(SRST_LINKSYM_HDMITXPHY1, 64, 13), + RK3588_CRU_RESET_OFFSET(SRST_VO1_BRIDGE0, 64, 14), + RK3588_CRU_RESET_OFFSET(SRST_VO1_BRIDGE1, 64, 15), + + /* SOFTRST_CON65 */ + RK3588_CRU_RESET_OFFSET(SRST_H_I2S9_8CH, 65, 0), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S9_8CH_RX, 65, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_I2S10_8CH, 65, 4), + RK3588_CRU_RESET_OFFSET(SRST_M_I2S10_8CH_RX, 65, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_S_HDMIRX, 65, 8), + + /* SOFTRST_CON66 */ + RK3588_CRU_RESET_OFFSET(SRST_GPU, 66, 4), + RK3588_CRU_RESET_OFFSET(SRST_SYS_GPU, 66, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_S_GPU_BIU, 66, 8), + RK3588_CRU_RESET_OFFSET(SRST_A_M0_GPU_BIU, 66, 9), + RK3588_CRU_RESET_OFFSET(SRST_A_M1_GPU_BIU, 66, 10), + RK3588_CRU_RESET_OFFSET(SRST_A_M2_GPU_BIU, 66, 11), + RK3588_CRU_RESET_OFFSET(SRST_A_M3_GPU_BIU, 66, 12), + RK3588_CRU_RESET_OFFSET(SRST_P_GPU_BIU, 66, 14), + RK3588_CRU_RESET_OFFSET(SRST_P_GPU_PVTM, 66, 15), + + /* SOFTRST_CON67 */ + RK3588_CRU_RESET_OFFSET(SRST_GPU_PVTM, 67, 0), + RK3588_CRU_RESET_OFFSET(SRST_P_GPU_GRF, 67, 2), + RK3588_CRU_RESET_OFFSET(SRST_GPU_PVTPLL, 67, 3), + RK3588_CRU_RESET_OFFSET(SRST_GPU_JTAG, 67, 4), + + /* SOFTRST_CON68 */ + RK3588_CRU_RESET_OFFSET(SRST_A_AV1_BIU, 68, 1), + RK3588_CRU_RESET_OFFSET(SRST_A_AV1, 68, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_AV1_BIU, 68, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_AV1, 68, 5), + + /* SOFTRST_CON69 */ + RK3588_CRU_RESET_OFFSET(SRST_A_DDR_BIU, 69, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_DMA2DDR, 69, 5), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR_SHAREMEM, 69, 6), + RK3588_CRU_RESET_OFFSET(SRST_A_DDR_SHAREMEM_BIU, 69, 7), + RK3588_CRU_RESET_OFFSET(SRST_A_CENTER_S200_BIU, 69, 10), + RK3588_CRU_RESET_OFFSET(SRST_A_CENTER_S400_BIU, 69, 11), + RK3588_CRU_RESET_OFFSET(SRST_H_AHB2APB, 69, 12), + RK3588_CRU_RESET_OFFSET(SRST_H_CENTER_BIU, 69, 13), + RK3588_CRU_RESET_OFFSET(SRST_F_DDR_CM0_CORE, 69, 14), + + /* SOFTRST_CON70 */ + RK3588_CRU_RESET_OFFSET(SRST_DDR_TIMER0, 70, 0), + RK3588_CRU_RESET_OFFSET(SRST_DDR_TIMER1, 70, 1), + RK3588_CRU_RESET_OFFSET(SRST_T_WDT_DDR, 70, 2), + RK3588_CRU_RESET_OFFSET(SRST_T_DDR_CM0_JTAG, 70, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_CENTER_GRF, 70, 5), + RK3588_CRU_RESET_OFFSET(SRST_P_AHB2APB, 70, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_WDT, 70, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_TIMER, 70, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_DMA2DDR, 70, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_SHAREMEM, 70, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_CENTER_BIU, 70, 11), + RK3588_CRU_RESET_OFFSET(SRST_P_CENTER_CHANNEL_BIU, 70, 12), + + /* SOFTRST_CON72 */ + RK3588_CRU_RESET_OFFSET(SRST_P_USBDPGRF0, 72, 1), + RK3588_CRU_RESET_OFFSET(SRST_P_USBDPPHY0, 72, 2), + RK3588_CRU_RESET_OFFSET(SRST_P_USBDPGRF1, 72, 3), + RK3588_CRU_RESET_OFFSET(SRST_P_USBDPPHY1, 72, 4), + RK3588_CRU_RESET_OFFSET(SRST_P_HDPTX0, 72, 5), + RK3588_CRU_RESET_OFFSET(SRST_P_HDPTX1, 72, 6), + RK3588_CRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_BOT_RIGHT, 72, 7), + RK3588_CRU_RESET_OFFSET(SRST_P_USB2PHY_U3_0_GRF0, 72, 8), + RK3588_CRU_RESET_OFFSET(SRST_P_USB2PHY_U3_1_GRF0, 72, 9), + RK3588_CRU_RESET_OFFSET(SRST_P_USB2PHY_U2_0_GRF0, 72, 10), + RK3588_CRU_RESET_OFFSET(SRST_P_USB2PHY_U2_1_GRF0, 72, 11), + RK3588_CRU_RESET_OFFSET(SRST_HDPTX0_ROPLL, 72, 12), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_HDPTX0_LCPLL, 72, 13), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_HDPTX0, 72, 14), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_HDPTX1_ROPLL, 72, 15), // missing in TRM + + /* SOFTRST_CON73 */ + RK3588_CRU_RESET_OFFSET(SRST_HDPTX1_LCPLL, 73, 0), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_HDPTX1, 73, 1), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_HDPTX0_HDMIRXPHY_SET, 73, 2), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY0, 73, 3), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY0_LCPLL, 73, 4), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY0_ROPLL, 73, 5), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY0_PCS_HS, 73, 6), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY1, 73, 7), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY1_LCPLL, 73, 8), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY1_ROPLL, 73, 9), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_USBDP_COMBO_PHY1_PCS_HS, 73, 10), // missing in TRM + RK3588_CRU_RESET_OFFSET(SRST_HDMIHDP0, 73, 12), + RK3588_CRU_RESET_OFFSET(SRST_HDMIHDP1, 73, 13), + + /* SOFTRST_CON74 */ + RK3588_CRU_RESET_OFFSET(SRST_A_VO1USB_TOP_BIU, 74, 1), + RK3588_CRU_RESET_OFFSET(SRST_H_VO1USB_TOP_BIU, 74, 3), + + /* SOFTRST_CON75 */ + RK3588_CRU_RESET_OFFSET(SRST_H_SDIO_BIU, 75, 1), + RK3588_CRU_RESET_OFFSET(SRST_H_SDIO, 75, 2), + RK3588_CRU_RESET_OFFSET(SRST_SDIO, 75, 3), + + /* SOFTRST_CON76 */ + RK3588_CRU_RESET_OFFSET(SRST_H_RGA3_BIU, 76, 2), + RK3588_CRU_RESET_OFFSET(SRST_A_RGA3_BIU, 76, 3), + RK3588_CRU_RESET_OFFSET(SRST_H_RGA3_1, 76, 4), + RK3588_CRU_RESET_OFFSET(SRST_A_RGA3_1, 76, 5), + RK3588_CRU_RESET_OFFSET(SRST_RGA3_1_CORE, 76, 6), + + /* SOFTRST_CON77 */ + RK3588_CRU_RESET_OFFSET(SRST_REF_PIPE_PHY0, 77, 6), + RK3588_CRU_RESET_OFFSET(SRST_REF_PIPE_PHY1, 77, 7), + RK3588_CRU_RESET_OFFSET(SRST_REF_PIPE_PHY2, 77, 8), + + /* PHPTOPCRU_SOFTRST_CON00 */ + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_PHPTOP_CRU, 0, 1), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_PCIE2_GRF0, 0, 2), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_PCIE2_GRF1, 0, 3), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_PCIE2_GRF2, 0, 4), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_PCIE2_PHY0, 0, 5), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_PCIE2_PHY1, 0, 6), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_PCIE2_PHY2, 0, 7), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_PCIE3_PHY, 0, 8), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_P_APB2ASB_SLV_CHIP_TOP, 0, 9), + RK3588_PHPTOPCRU_RESET_OFFSET(SRST_PCIE30_PHY, 0, 10), + + /* PMU1CRU_SOFTRST_CON00 */ + RK3588_PMU1CRU_RESET_OFFSET(SRST_H_PMU1_BIU, 0, 10), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_PMU1_BIU, 0, 11), + RK3588_PMU1CRU_RESET_OFFSET(SRST_H_PMU_CM0_BIU, 0, 12), + RK3588_PMU1CRU_RESET_OFFSET(SRST_F_PMU_CM0_CORE, 0, 13), + RK3588_PMU1CRU_RESET_OFFSET(SRST_T_PMU1_CM0_JTAG, 0, 14), + + /* PMU1CRU_SOFTRST_CON01 */ + RK3588_PMU1CRU_RESET_OFFSET(SRST_DDR_FAIL_SAFE, 1, 1), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_CRU_PMU1, 1, 2), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_PMU1_GRF, 1, 4), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_PMU1_IOC, 1, 5), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_PMU1WDT, 1, 6), + RK3588_PMU1CRU_RESET_OFFSET(SRST_T_PMU1WDT, 1, 7), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_PMU1TIMER, 1, 8), + RK3588_PMU1CRU_RESET_OFFSET(SRST_PMU1TIMER0, 1, 10), + RK3588_PMU1CRU_RESET_OFFSET(SRST_PMU1TIMER1, 1, 11), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_PMU1PWM, 1, 12), + RK3588_PMU1CRU_RESET_OFFSET(SRST_PMU1PWM, 1, 13), + + /* PMU1CRU_SOFTRST_CON02 */ + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_I2C0, 2, 1), + RK3588_PMU1CRU_RESET_OFFSET(SRST_I2C0, 2, 2), + RK3588_PMU1CRU_RESET_OFFSET(SRST_S_UART0, 2, 5), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_UART0, 2, 6), + RK3588_PMU1CRU_RESET_OFFSET(SRST_H_I2S1_8CH, 2, 7), + RK3588_PMU1CRU_RESET_OFFSET(SRST_M_I2S1_8CH_TX, 2, 10), + RK3588_PMU1CRU_RESET_OFFSET(SRST_M_I2S1_8CH_RX, 2, 13), + RK3588_PMU1CRU_RESET_OFFSET(SRST_H_PDM0, 2, 14), + RK3588_PMU1CRU_RESET_OFFSET(SRST_PDM0, 2, 15), + + /* PMU1CRU_SOFTRST_CON03 */ + RK3588_PMU1CRU_RESET_OFFSET(SRST_H_VAD, 3, 0), + RK3588_PMU1CRU_RESET_OFFSET(SRST_HDPTX0_INIT, 3, 11), + RK3588_PMU1CRU_RESET_OFFSET(SRST_HDPTX0_CMN, 3, 12), + RK3588_PMU1CRU_RESET_OFFSET(SRST_HDPTX0_LANE, 3, 13), + RK3588_PMU1CRU_RESET_OFFSET(SRST_HDPTX1_INIT, 3, 15), + + /* PMU1CRU_SOFTRST_CON04 */ + RK3588_PMU1CRU_RESET_OFFSET(SRST_HDPTX1_CMN, 4, 0), + RK3588_PMU1CRU_RESET_OFFSET(SRST_HDPTX1_LANE, 4, 1), + RK3588_PMU1CRU_RESET_OFFSET(SRST_M_MIPI_DCPHY0, 4, 3), + RK3588_PMU1CRU_RESET_OFFSET(SRST_S_MIPI_DCPHY0, 4, 4), + RK3588_PMU1CRU_RESET_OFFSET(SRST_M_MIPI_DCPHY1, 4, 5), + RK3588_PMU1CRU_RESET_OFFSET(SRST_S_MIPI_DCPHY1, 4, 6), + RK3588_PMU1CRU_RESET_OFFSET(SRST_OTGPHY_U3_0, 4, 7), + RK3588_PMU1CRU_RESET_OFFSET(SRST_OTGPHY_U3_1, 4, 8), + RK3588_PMU1CRU_RESET_OFFSET(SRST_OTGPHY_U2_0, 4, 9), + RK3588_PMU1CRU_RESET_OFFSET(SRST_OTGPHY_U2_1, 4, 10), + + /* PMU1CRU_SOFTRST_CON05 */ + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_PMU0GRF, 5, 3), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_PMU0IOC, 5, 4), + RK3588_PMU1CRU_RESET_OFFSET(SRST_P_GPIO0, 5, 5), + RK3588_PMU1CRU_RESET_OFFSET(SRST_GPIO0, 5, 6), + + /* SECURECRU_SOFTRST_CON00 */ + RK3588_SECURECRU_RESET_OFFSET(SRST_A_SECURE_NS_BIU, 0, 10), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_SECURE_NS_BIU, 0, 11), + RK3588_SECURECRU_RESET_OFFSET(SRST_A_SECURE_S_BIU, 0, 12), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_SECURE_S_BIU, 0, 13), + RK3588_SECURECRU_RESET_OFFSET(SRST_P_SECURE_S_BIU, 0, 14), + RK3588_SECURECRU_RESET_OFFSET(SRST_CRYPTO_CORE, 0, 15), + + /* SECURECRU_SOFTRST_CON01 */ + RK3588_SECURECRU_RESET_OFFSET(SRST_CRYPTO_PKA, 1, 0), + RK3588_SECURECRU_RESET_OFFSET(SRST_CRYPTO_RNG, 1, 1), + RK3588_SECURECRU_RESET_OFFSET(SRST_A_CRYPTO, 1, 2), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_CRYPTO, 1, 3), + RK3588_SECURECRU_RESET_OFFSET(SRST_KEYLADDER_CORE, 1, 9), + RK3588_SECURECRU_RESET_OFFSET(SRST_KEYLADDER_RNG, 1, 10), + RK3588_SECURECRU_RESET_OFFSET(SRST_A_KEYLADDER, 1, 11), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_KEYLADDER, 1, 12), + RK3588_SECURECRU_RESET_OFFSET(SRST_P_OTPC_S, 1, 13), + RK3588_SECURECRU_RESET_OFFSET(SRST_OTPC_S, 1, 14), + RK3588_SECURECRU_RESET_OFFSET(SRST_WDT_S, 1, 15), + + /* SECURECRU_SOFTRST_CON02 */ + RK3588_SECURECRU_RESET_OFFSET(SRST_T_WDT_S, 2, 0), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_BOOTROM, 2, 1), + RK3588_SECURECRU_RESET_OFFSET(SRST_A_DCF, 2, 2), + RK3588_SECURECRU_RESET_OFFSET(SRST_P_DCF, 2, 3), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_BOOTROM_NS, 2, 5), + RK3588_SECURECRU_RESET_OFFSET(SRST_P_KEYLADDER, 2, 14), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_TRNG_S, 2, 15), + + /* SECURECRU_SOFTRST_CON03 */ + RK3588_SECURECRU_RESET_OFFSET(SRST_H_TRNG_NS, 3, 0), + RK3588_SECURECRU_RESET_OFFSET(SRST_D_SDMMC_BUFFER, 3, 1), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_SDMMC, 3, 2), + RK3588_SECURECRU_RESET_OFFSET(SRST_H_SDMMC_BUFFER, 3, 3), + RK3588_SECURECRU_RESET_OFFSET(SRST_SDMMC, 3, 4), + RK3588_SECURECRU_RESET_OFFSET(SRST_P_TRNG_CHK, 3, 5), + RK3588_SECURECRU_RESET_OFFSET(SRST_TRNG_S, 3, 6), +}; + +int rk3588_reset_bind_lut(struct udevice *pdev, u32 reg_offset, u32 reg_number) +{ + return rockchip_reset_bind_lut(pdev, rk3588_register_offset, + reg_offset, reg_number); +}
Eugen Hristev
